  4. Node-Red
  5. Shelly Plus Plug S - Node Red
8 Beiträge 2 Kommentatoren 977 Aufrufe 2 Beobachtet
  • hotspot_2H Offline
    hotspot_2H Offline
    hotspot_2
    Hallo zusammen.
    ich benutze diese Node-Red um Shelly Plus 1 / 1 PM usw. zu schalten und die Energiewerte abzufragen. Das hat bisher einwandfrei funktioniert.
            "id": "72491a9c9d7f59d3",
            "type": "mqtt in",
            "z": "9531c5f14d11e22e",
            "name": "",
            "topic": "shellies/schalter/keller/gefrierschrkeller/status/switch:0",
            "qos": "2",
            "datatype": "auto-detect",
            "broker": "b22fc4d3e3f172bb",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 0,
            "x": 220,
            "y": 1880,
            "wires": [
                    "9a7043332dadd08d",
                    "324b7e7e8f5f7616"
            "id": "9a7043332dadd08d",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.output",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 550,
            "y": 1880,
            "wires": [
                    "fb9e879fe3e34581"
            "id": "fb9e879fe3e34581",
            "type": "ioBroker out",
            "name": "switch",
            "topic": "0_userdata.0.shellies.schalter.keller.gefrierschrkeller.switch",
            "ack": "true",
            "autoCreate": "true",
            "stateName": "",
            "role": "",
            "payloadType": "boolean",
            "readonly": "false",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 730,
            "y": 1880,
            "wires": []
            "id": "f831d0c916d2017f",
            "type": "ioBroker in",
            "name": "switch",
            "attrname": "",
            "payloadType": "value",
            "onlyack": "command",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 70,
            "y": 2000,
            "wires": [
                    "fee25176647f047d"
            "id": "e9396edc08b9f61f",
            "type": "mqtt out",
            "name": "",
            "topic": "shellies/schalter/keller/gefrierschrkeller/rpc",
            "qos": "",
            "retain": "",
            "respTopic": "",
            "contentType": "",
            "userProps": "",
            "correl": "",
            "expiry": "",
            "x": 610,
            "y": 2000,
            "wires": []
            "id": "fee25176647f047d",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "{\t   \"id\":141,\t   \"src\":\"hotspot_2\",\t   \"method\":\"Switch.Set\",\t   \"params\":{\"id\":0,\"on\":payload}\t}\t \t",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 230,
            "y": 2000,
            "wires": [
                    "e9396edc08b9f61f"
            "id": "324b7e7e8f5f7616",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.apower",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 550,
            "y": 1940,
            "wires": [
                    "cfeeb61019d8da71"
            "id": "cfeeb61019d8da71",
            "name": "power",
            "topic": "0_userdata.0.shellies.schalter.keller.gefrierschrkeller.power",
            "ack": "true",
            "stateName": "",
            "role": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 730,
            "y": 1940,
            "wires": []
            "id": "b22fc4d3e3f172bb",
            "type": "mqtt-broker",
            "name": "iobroker mqtt adapter",
            "broker": "localhost",
            "port": "1883",
            "clientid": "mqttin_nodered",
            "autoConnect": true,
            "usetls": false,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "userProps": "",
            "sessionExpiry": ""
    Leider funktioniert das mit einem Shelly Plug S nicht mehr.
    Hat mir jemand einen Tipp was man da anpassen muss? Mit der Shelly Doku bin ich irgendwie nicht weiter gekommen.
    Danke schon mal!
    • hotspot_2H hotspot_2
      Hallo zusammen.
              "type": "mqtt in",
              "name": "",
              "qos": "2",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 220,
              "y": 1880,
              "wires": [
                      "9a7043332dadd08d",
                      "324b7e7e8f5f7616"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 550,
              "y": 1880,
              "wires": [
                      "fb9e879fe3e34581"
              "name": "switch",
              "ack": "true",
              "stateName": "",
              "role": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 730,
              "y": 1880,
              "wires": []
              "name": "switch",
              "attrname": "",
              "func": "all",
              "gap": "",
              "x": 70,
              "y": 2000,
              "wires": [
                      "fee25176647f047d"
              "type": "mqtt out",
              "name": "",
              "qos": "",
              "retain": "",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "x": 610,
              "y": 2000,
              "wires": []
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 230,
              "y": 2000,
              "wires": [
                      "e9396edc08b9f61f"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 550,
              "y": 1940,
              "wires": [
                      "cfeeb61019d8da71"
              "name": "power",
              "ack": "true",
              "stateName": "",
              "role": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 730,
              "y": 1940,
              "wires": []
              "port": "1883",
              "usetls": false,
              "keepalive": "60",
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      Danke schon mal!
      mickymM Offline
      mickymM Offline
      mickym
      @hotspot_2 Meines Erachtens muss man das nicht so komplziert über rpc Objekte machen - die sollten eigentlich funktionieren, wie Du es gemacht hast.
      Aber ansonsten probiere halt die einfache Variante:
             "id": "2ef69fbc49bacbff",
             "type": "inject",
             "z": "7e6af0015415146d",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "on",
             "payloadType": "str",
             "x": 310,
             "y": 6760,
             "wires": [
                     "838d68081715eadb"
             "id": "6f1c16bfbd1b5ff6",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "off",
             "x": 310,
             "y": 6800,
             "wires": [
                     "838d68081715eadb"
             "id": "838d68081715eadb",
             "type": "mqtt out",
             "name": "",
             "topic": "shellies/schalter/keller/gefrierschrkeller/command/switch:0",
             "qos": "",
             "retain": "",
             "respTopic": "",
             "contentType": "",
             "userProps": "",
             "correl": "",
             "expiry": "",
             "x": 630,
             "y": 6780,
             "wires": []
             "port": "1883",
             "usetls": false,
             "keepalive": "60",
             "birthTopic": "",
             "birthQos": "0",
             "birthPayload": "",
             "birthMsg": {},
             "closeTopic": "",
             "closeQos": "0",
             "closePayload": "",
             "closeMsg": {},
             "willTopic": "",
             "willQos": "0",
             "willPayload": "",
             "willMsg": {},
             "userProps": "",
             "sessionExpiry": ""
      Ansonsten kann ich keinen Fehler entdecken - wenn Du wirklich ein Boolean schickst, das kann ich nicht sehen, was in deinem Datenpunkt ist. Überprüf halt mal ob das wirklich ein Boolean und kein Text ist.
      Ansonsten nimm halt die einfache Variante
             "type": "mqtt out",
             "name": "",
             "qos": "",
             "retain": "",
             "respTopic": "",
             "contentType": "",
             "userProps": "",
             "correl": "",
             "expiry": "",
             "x": 810,
             "y": 6640,
             "wires": []
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 470,
             "y": 6660,
             "wires": [
                     "e9396edc08b9f61f",
                     "57b411b641a4cb3b"
             "id": "d1eada87cb8c80f4",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "true",
             "payloadType": "bool",
             "x": 290,
             "y": 6640,
             "wires": [
                     "fee25176647f047d"
             "id": "30d45467d3d7f8d2",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "false",
             "x": 290,
             "y": 6680,
             "wires": [
                     "fee25176647f047d"
             "id": "57b411b641a4cb3b",
             "type": "debug",
             "name": "rpc - set",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 700,
             "y": 6700,
             "wires": []
             "port": "1883",
             "usetls": false,
             "keepalive": "60",
             "birthTopic": "",
             "birthQos": "0",
             "birthPayload": "",
             "birthMsg": {},
             "closeTopic": "",
             "closeQos": "0",
             "closePayload": "",
             "closeMsg": {},
             "willTopic": "",
             "willQos": "0",
             "willPayload": "",
             "willMsg": {},
             "userProps": "",
             "sessionExpiry": ""
      hotspot_2H 1 Antwort Letzte Antwort
      • mickymM mickym
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "on",
               "x": 310,
               "y": 6760,
               "wires": [
                       "838d68081715eadb"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "off",
               "x": 310,
               "y": 6800,
               "wires": [
                       "838d68081715eadb"
               "type": "mqtt out",
               "name": "",
               "qos": "",
               "retain": "",
               "respTopic": "",
               "contentType": "",
               "userProps": "",
               "correl": "",
               "expiry": "",
               "x": 630,
               "y": 6780,
               "wires": []
               "port": "1883",
               "usetls": false,
               "keepalive": "60",
               "birthTopic": "",
               "birthQos": "0",
               "birthPayload": "",
               "birthMsg": {},
               "closeTopic": "",
               "closeQos": "0",
               "closePayload": "",
               "closeMsg": {},
               "willTopic": "",
               "willQos": "0",
               "willPayload": "",
               "willMsg": {},
               "userProps": "",
               "sessionExpiry": ""
               "type": "mqtt out",
               "name": "",
               "qos": "",
               "retain": "",
               "respTopic": "",
               "contentType": "",
               "userProps": "",
               "correl": "",
               "expiry": "",
               "x": 810,
               "y": 6640,
               "wires": []
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 470,
               "y": 6660,
               "wires": [
                       "e9396edc08b9f61f",
                       "57b411b641a4cb3b"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "true",
               "x": 290,
               "y": 6640,
               "wires": [
                       "fee25176647f047d"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "false",
               "x": 290,
               "y": 6680,
               "wires": [
                       "fee25176647f047d"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 700,
               "y": 6700,
               "wires": []
               "port": "1883",
               "usetls": false,
               "keepalive": "60",
               "birthTopic": "",
               "birthQos": "0",
               "birthPayload": "",
               "birthMsg": {},
               "closeTopic": "",
               "closeQos": "0",
               "closePayload": "",
               "closeMsg": {},
               "willTopic": "",
               "willQos": "0",
               "willPayload": "",
               "willMsg": {},
               "userProps": "",
               "sessionExpiry": ""
        hotspot_2H Offline
        hotspot_2H Offline
        hotspot_2
        schrieb am zuletzt editiert von hotspot_2
        @mickym Ich hätte noch was schreiben sollen.
        Das Problem ist im MQTT Adapter beim Shelly Plug S der Ordner /rpc nicht mehr auftaucht. Es gibt nur noch events/rpc und damit kann man nicht schalten. Aus der Doku bin ich nicht schlau geworden.
        Bei den anderen Gen2 Shellys, die ich habe, funktioniert das Beispiel von mir einwandfrei. Haben wir ja auch mal zusammen erstellt.
        mickymM 3 Antworten Letzte Antwort
          mickymM Offline
          mickymM Offline
          mickym
          @hotspot_2 Die events sind deswegen da , da die Events vom Gerät kommen. Alle topics, die Du schickst legt das Gerät nicht an, sondern die kommen von Dir in dem Du diese topics beschreibst. Das Gerät subscribed die.
          Also der rpc ist da sobald du was publishst und ein Gerät legt nie die topics an, auf die es hört.
            mickymM Offline
            mickymM Offline
            mickym
            @hotspot_2 sagte in Shelly Plus Plug S - Node Red:
            Das hängt davon ab, ob es ein Shelly Plug S Gen 3 oder Gen 1 ist - oder ein Plus mit Gen 2. Ab Generation 2 haben die, diese rpc Channels.
              mickymM Offline
              mickymM Offline
              mickym
              @hotspot_2 Hast du die simple Variante ohne rpc direkt als command versucht?
              • mickymM mickym
                hotspot_2H Offline
                hotspot_2H Offline
                hotspot_2
                @mickym sagte in Shelly Plus Plug S - Node Red:
                Verstanden. Einmal schalten dann passt das. Danke!
                • mickymM mickym
                  hotspot_2H Offline
                  hotspot_2H Offline
                  hotspot_2
                  Das teste ich noch.
