  4. [HOW-TO] backitup Konfiguration mit nfs
backitup nasiob nfs bookworm
61 Beiträge 3 Kommentatoren 7.5k Aufrufe 3 Beobachtet
    @norbert999 sagte in [HOW-TO] backitup Konfiguration mit nfs:
    Und jetzt?
    Run iobroker start to start ioBroker again!
    N Offline
    N Offline
    norbert999
    @homoran said in [HOW-TO] backitup Konfiguration mit nfs:
    pi@raspi5:~ $ iobroker start
    pi@raspi5:~ $ iob status
    Objects type: jsonl
    States  type: jsonl
    pi@raspi5:~ $
    Jetzt geht der iob status, der definitiv vorher nicht ging!
    • N norbert999
      Objects type: jsonl
      States  type: jsonl
      pi@raspi5:~ $
      da war ja auch alles massiv verbogen
      • N Offline
        N Offline
        norbert999
        @thomas-braun said in [HOW-TO] backitup Konfiguration mit nfs:
        Jag den Fixer mal über das System
        Fixer habe ich erfolgreich ausgeführt. Danach nochmal iob diag:
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
         Static hostname: raspi5
               Icon name: computer
                  Kernel: Linux 6.6.62+rpt-rpi-2712
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         09:58:28 up 1 min,  4 users,  load average: 5.60, 2.02, 0.73
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-01-15 09:58:28 CET
                   Universal time: Wed 2025-01-15 08:58:28 UTC
                         RTC time: Wed 2025-01-15 08:58:29
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            8.4G        1.9G        5.4G         39M        1.2G        6.5G
        Swap:           536M          0B        536M
        Total:          9.0G        1.9G        5.9G
        Active iob-Instances:   12
                 8052 M total memory
                 1854 M used memory
                 2143 M active memory
                  505 M inactive memory
                 5134 M free memory
                   59 M buffer memory
                 1132 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        top - 09:58:29 up 1 min,  4 users,  load average: 5.60, 2.02, 0.73
        Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8052.2 total,   5133.2 free,   1855.9 used,   1192.1 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6196.3 avail Mem
        *** FAILED SERVICES ***
          UNIT               LOAD   ACTIVE SUB    DESCRIPTION
        * nut-server.service loaded failed failed Network UPS Tools - power devices information server
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                            Type      Size  Used Avail Use% Mounted on
        udev                                  devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs                                 tmpfs     806M  6.2M  800M   1% /run
        /dev/sda2                             ext4       29G   10G   18G  37% /
        tmpfs                                 tmpfs     4.0G  3.3M  4.0G   1% /dev/shm
        tmpfs                                 tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/sda1                             vfat      510M   67M  444M  14% /boot/firmware
        192.168.1.12:/share/backup_raspi5     nfs       5.4T  3.0T  2.4T  56% /opt/iobroker/backups
        192.168.1.12:/share/backup_raspberry5 nfs       5.4T  3.0T  2.4T  56% /backup
        tmpfs                                 tmpfs     806M  192K  806M   1% /run/user/1000
        [Wed Jan 15 09:56:40 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:8D:08:0B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1cf07110-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Wed Jan 15 09:56:45 2025] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
        [Wed Jan 15 09:56:46 2025] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                  SOURCE                                FSTYPE      OPTIONS
        /                       /dev/sda2                             ext4        rw,noatime
        |-/run/user/1000/doc    portal                                fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware        /dev/sda1                             vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/opt/iobroker/backups 192.168.1.12:/share/backup_raspi5     nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=all,addr=192.168.1.12
        `-/backup               192.168.1.12:/share/backup_raspberry5 nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=all,addr=192.168.1.12
        /var:
        1.6G    /var/
        482M    /var/cache
        476M    /var/cache/apt
        361M    /var/cache/apt/archives
        354M    /var/log
        Archived and active journals take up 332.6M in the file system.
        /opt/iobroker/backups:
        64M     /opt/iobroker/backups/
        16K     /opt/iobroker/backups/.@__thumb
        12K     /opt/iobroker/backups/@Recycle
        8.0K    /opt/iobroker/backups/raspi5
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        1007M   /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
        24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
        24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
        15M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspi5              raspi5 (version: 7.0.6, hostname: raspi5        , alive, uptime: 72)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.4.10
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
        + system.adapter.discovery.0              : discovery             : raspi5                                   -  enabled
          system.adapter.dwd.0                    : dwd                   : raspi5                                   -  enabled
          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi5                                   -  enabled
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspi5                                   -  enabled
          system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : raspi5                                   -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : raspi5                                   -  enabled
        + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
        + system.adapter.nut.0                    : nut                   : raspi5                                   -  enabled
          system.adapter.pi-hole.0                : pi-hole               : raspi5                                   -  enabled
          system.adapter.pushover.0               : pushover              : raspi5                                   -  enabled
        + system.adapter.snmp.0                   : snmp                  : raspi5                                   -  enabled
        + system.adapter.snmp.1                   : snmp                  : raspi5                                   -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
          system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
          system.adapter.vis-2.0                  : vis-2                 : raspi5                                   -  enabled
          system.adapter.vis.0                    : vis                   : raspi5                                   -  enabled
          system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects:        7241
        States:         5787
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8348       921/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4884       822/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8334       974/lighttpd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5920       812/cupsd
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        8354       921/pihole-FTL
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7816       1217/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9732       1217/iobroker.js-co
        tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7090       824/unbound
        tcp        0      0 192.168.1.6:2001        0.0.0.0:*               LISTEN      1001       14578      2412/io.hm-rpc.0
        tcp        0      0 192.168.1.6:2010        0.0.0.0:*               LISTEN      1001       13581      2452/io.hm-rpc.1
        tcp6       0      0 :::53                   :::*                    LISTEN      999        8350       921/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          4886       822/sshd: /usr/sbin
        tcp6       0      0 :::80                   :::*                    LISTEN      0          8333       974/lighttpd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13362      1584/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13700      2575/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      995        10517      897/influxd
        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        8355       921/pihole-FTL
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5919       812/cupsd
        tcp6       0      0 :::3000                 :::*                    LISTEN      113        9167       1216/grafana
        udp        0      0 0.0.0.0:55571           0.0.0.0:*                           1001       13679      2366/io.snmp.0
        udp        0      0 0.0.0.0:43935           0.0.0.0:*                           104        6932       561/avahi-daemon: r
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8347       921/pihole-FTL
        udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7089       824/unbound
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6930       561/avahi-daemon: r
        udp        0      0 0.0.0.0:50633           0.0.0.0:*                           1001       12860      2377/io.snmp.1
        udp6       0      0 :::44673                :::*                                104        6933       561/avahi-daemon: r
        udp6       0      0 :::53                   :::*                                999        8349       921/pihole-FTL
        udp6       0      0 fe80::f0ae:1c2a:23c:546 :::*                                0          6011       777/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        6931       561/avahi-daemon: r
        2025-01-15 09:58:30.841  - info: pi-hole.0 (2784) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:33.986  - info: host.raspi5 instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 2885
        2025-01-15 09:58:34.908  - info: energiefluss-erweitert.0 (2885) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:34.927  - info: energiefluss-erweitert.0 (2885) Adapter started. Loading config!
        2025-01-15 09:58:35.312  - info: energiefluss-erweitert.0 (2885) Configuration loaded!
        2025-01-15 09:58:35.313  - info: energiefluss-erweitert.0 (2885) Requesting the following states: energiefluss-erweitert.0.configuration,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerPV.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerLoad.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerFeedIn.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.BattSOC.value,0_userdata.0.Photovoltaik.BattLoadState,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerBattCharge.value,0_userdata.0.Photovoltaik.BattCapac,energiefluss-erweitert.0.calculation.battery.remaining,0_userdata.0.Photovoltaik.FlowSelfConsumption,0_userdata.0.Photovoltaik.PowerIntoGrid,0_userdata.0.Photovoltaik.BattMinDischarge,0_userdata.0.Photovoltaik.FlowBattCharge
        2025-01-15 09:58:35.941  - info: web.0 (2575) <== Disconnect system.user.admin from ::ffff:192.168.1.209
        2025-01-15 09:58:36.090  - info: web.0 (2575) ==> Connected system.user.admin from ::ffff:192.168.1.209
        2025-01-15 09:58:37.946  - info: host.raspi5 instance system.adapter.vis-2.0 in version "2.9.64" started with pid 2931
        2025-01-15 09:58:38.730  - info: vis-2.0 (2931) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:38.889  - info: vis-2.0 (2931) vis-2 license is OK.
        2025-01-15 09:58:42.004  - info: host.raspi5 instance scheduled system.adapter.dwd.0 */5 * * * *
        2025-01-15 09:58:42.007  - info: host.raspi5 instance system.adapter.dwd.0 in version "2.8.5" started with pid 2999
        2025-01-15 09:58:42.953  - info: dwd.0 (2999) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:43.273  - info: dwd.0 (2999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-01-15 09:58:43.799  - info: host.raspi5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-01-15 09:58:48.496  - info: vis.0 (3014) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:50.064  - info: host.raspi5 instance system.adapter.pushover.0 in version "4.1.0" started with pid 3046
        2025-01-15 09:58:51.750  - info: pushover.0 (3046) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:52.051  - info: vis.0 (3014) Terminated (NO_ERROR): Without reason
        2025-01-15 09:58:52.588  - info: host.raspi5 instance system.adapter.vis.0 terminated while should be started once
        2025-01-15 09:58:53.946  - info: host.raspi5 instance system.adapter.fronius-wattpilot.0 in version "4.6.3" started with pid 3078
        2025-01-15 09:58:54.866  - info: fronius-wattpilot.0 (3078) starting. Version 4.6.3 in /opt/iobroker/node_modules/iobroker.fronius-wattpilot, node: v20.18.1, js-controller: 7.0.6
        2025-01-15 09:58:54.880  - info: fronius-wattpilot.0 (3078) Try to connect to: ws://192.168.1.132/ws
        2025-01-15 09:58:56.402  - info: fronius-wattpilot.0 (3078) Connected!
        Siehts jetzt besser aus?
        • N norbert999
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           536M          0B        536M
                   8052 M total memory
                   1854 M used memory
                   5134 M free memory
                     59 M buffer memory
                   1132 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          *** FILESYSTEM ***
          /var:
          1.6G    /var/
          482M    /var/cache
          476M    /var/cache/apt
          354M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.4.10
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        7241
          States:         5787
          Pending Updates: 0
          • nut-server.service loaded failed failed Network UPS Tools - power devices information server*** FAILED SERVICES ***
          Musst du dir anschauen.
          Die NFS-Freigaben auf dem Host 192.168.1.12 musst du dir auch anschauen. Da stimmt was mit den Rechten und/oder Versionen nicht.
          Näheres hier: https://wiki.ubuntuusers.de/NFS/ Insbesondere unter 'Problembehebung' schauen.
          N 1 Antwort Letzte Antwort
            N Offline
            N Offline
            norbert999
            Ich kriege es einfach nicht hin.
            Habe jetzt folgendes gemacht: Neues, frisches OS auf raspi installiert. Dazu noch iob installiert mit 2 Adaptern, dass da was drin ist.
            Dann habe ich raspiBackup installiert. Habe das Verzeichnis /backup auf dem raspi erstellt und den QNAP share statisch über fstab gemounted.
            Wenn ich nun raspiBackup starte, gibt es wie immer eine Rechte-Fehlermeldung.
            Ich bitte um Hilfe, bin am verzweifeln. Es kann doch nicht sein, dass das mit frischem OS immer noch nicht funzt.
            Hier die Ausgabe:
            pi@raspi5:/backup $ sudo raspiBackup
            --- RBK0009I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:53:50 CET 2025 gestartet.
            ??? RBK0266E: Es fehlt die Berechtigung um Linux Dateiattribute auf /backup zu erstellen (Dateisystem: nfs).
            --- RBK0033I: Bitte warten bis aufgeräumt wurde.
            --- RBK0043I: Unvollständiges Backup in /backup/raspi5/raspi5-rsync-backup-20250115-145350 wird gelöscht. Das kann etwas dauern. Bitte Geduld.
            ??? RBK0005E: Backup fehlerhaft beendet. Siehe vorhergehende Fehlermeldungen.
            --- RBK0010I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:54:03 CET 2025 beendet mit Returncode 102.
            --- RBK0026I: Debug Logdatei wurde in /home/pi/raspiBackup.log gesichert.
            pi@raspi5:/backup $ more /home/pi/raspiBackup.log
            20250115-145350 DBG 2101:  --- Logfiles used: /tmp/raspiBackup.log and /tmp/raspiBackup.msg
            20250115-145350 DBG 2112:  --- raspiBackup.sh 0.6.9.1, 2024-09-28/22:55:07 - be4ba6d
            20250115-145350 DBG 2115:  --- +================================================================================================================
            20250115-145350 DBG 2116:  --- | ===> A lot of sensitive information is masqueraded in this log file. Nevertheless please check the log carefull
            y before you distribute it <=== |
            20250115-145350 DBG 2117:  --- +================================================================================================================
            20250115-145350 DBG 1943:  --> trapWithArg cleanupStartup SIGINT SIGTERM EXIT
            20250115-145350 DBG 1948:  <-- trapWithArg
            20250115-145350 DBG 3813:  --> readConfigParameters
            20250115-145350 DBG 3511:      --> extractVersionFromFile /usr/local/etc/raspiBackup.conf VERSION_.*CONF.*
            20250115-145350 DBG 3515:      <-- extractVersionFromFile 0.1.8
            20250115-145350 DBG 3840:      --- Read config /usr/local/etc/raspiBackup.conf : 0.1.8
            20250115-145350 DBG 3840:      --- VERSION_CONFIG="0.1.8"
            20250115-145350 DBG 3840:      --- DEFAULT_BACKUPPATH="/backup"
            20250115-145350 DBG 3840:      --- DEFAULT_BACKUPTYPE="rsync"
            20250115-145350 DBG 3840:      --- DEFAULT_ZIP_BACKUP="0"
            20250115-145350 DBG 3840:      --- DEFAULT_DD_BACKUP_SAVE_USED_PARTITIONS_ONLY=0
            20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS="10"
            20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_DD=0
            20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_DDZ=0
            20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_TAR=0
            20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_TGZ=0
            20250115-145350 DBG 3840:      --- DEFAULT_KEEPBACKUPS_RSYNC=0
            20250115-145350 DBG 3840:      --- DEFAULT_SMART_RECYCLE="0"
            20250115-145350 DBG 3840:      --- DEFAULT_SMART_RECYCLE_DRYRUN="1"
            20250115-145350 DBG 3840:      --- DEFAULT_SMART_RECYCLE_OPTIONS="7 4 12 1"
            20250115-145350 DBG 3840:      --- DEFAULT_STOPSERVICES=":"
            20250115-145350 DBG 3840:      --- DEFAULT_STARTSERVICES=":"
            20250115-145350 DBG 3840:      --- DEFAULT_BEFORE_STOPSERVICES=""
            20250115-145350 DBG 3840:      --- DEFAULT_AFTER_STARTSERVICES=""
            20250115-145350 DBG 3840:      --- DEFAULT_EMAIL=""
            20250115-145350 DBG 3840:      --- DEFAULT_SENDER_EMAIL=""
            20250115-145350 DBG 3840:      --- DEFAULT_EMAIL_PARMS=""
            20250115-145350 DBG 3840:      --- DEFAULT_MAIL_PROGRAM="mail"
            20250115-145350 DBG 3840:      --- DEFAULT_TELEGRAM_TOKEN=""
            20250115-145350 DBG 3840:      --- DEFAULT_TELEGRAM_CHATID=""
            20250115-145350 DBG 3840:      --- DEFAULT_TELEGRAM_NOTIFICATIONS="F"
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_ADDITIONAL_OPTIONS=""
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_DEVICE=""
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_TOKEN=""
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_USER=""
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_NOTIFICATIONS="F"
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_SOUND_SUCCESS=""
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_SOUND_FAILURE=""
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_PRIORITY_SUCCESS="0"
            20250115-145350 DBG 3840:      --- DEFAULT_PUSHOVER_PRIORITY_FAILURE="1"
            20250115-145350 DBG 3840:      --- DEFAULT_SLACK_WEBHOOK_URL=""
            20250115-145350 DBG 3840:      --- DEFAULT_SLACK_NOTIFICATIONS=""
            20250115-145350 DBG 3840:      --- DEFAULT_NOTIFY_START=0
            20250115-145350 DBG 3840:      --- DEFAULT_MAIL_ON_ERROR_ONLY=0
            20250115-145350 DBG 3840:      --- DEFAULT_MSG_LEVEL="0"
            20250115-145350 DBG 3840:      --- DEFAULT_COLORING="CM"
            20250115-145350 DBG 3840:      --- DEFAULT_EMAIL_COLORING="SUBJECT"
            20250115-145350 DBG 3840:      --- DEFAULT_COLOR_CODES=("#FF8000 33" "#FF0000 31")
            20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_DEVICE=""
            20250115-145350 DBG 3840:      --- DEFAULT_VERBOSE=0
            20250115-145350 DBG 3840:      --- DEFAULT_SKIPLOCALCHECK=0
            20250115-145350 DBG 3840:      --- DEFAULT_DD_BLOCKSIZE=1M
            20250115-145350 DBG 3840:      --- DEFAULT_DD_PARMS=""
            20250115-145350 DBG 3840:      --- DEFAULT_EXCLUDE_LIST=""
            20250115-145350 DBG 3840:      --- DEFAULT_EXTENSIONS="mem temp disk"
            20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_EXTENSIONS=""
            20250115-145350 DBG 3840:      --- DEFAULT_LANGUAGE="DE"
            20250115-145350 DBG 3840:      --- DEFAULT_DEPLOYMENT_HOSTS=""
            20250115-145350 DBG 3840:      --- DEFAULT_RESIZE_ROOTFS=1
            20250115-145350 DBG 3840:      --- DEFAULT_LINK_BOOTPARTITIONFILES=0
            20250115-145350 DBG 3840:      --- DEFAULT_TAR_BOOT_PARTITION_ENABLED=0
            20250115-145350 DBG 3840:      --- DEFAULT_SKIP_DEPRECATED=""
            20250115-145350 DBG 3840:      --- DEFAULT_CHECK_FOR_BAD_BLOCKS=0
            20250115-145350 DBG 3840:      --- DEFAULT_TIMESTAMPS=0
            20250115-145350 DBG 3840:      --- DEFAULT_SYSTEMSTATUS=0
            20250115-145350 DBG 3840:      --- DEFAULT_REBOOT_SYSTEM=0
            20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_REMINDER_INTERVAL=6
            20250115-145350 DBG 3840:      --- DEFAULT_RESTORE_REMINDER_REPEAT=3
            20250115-145350 DBG 3840:      --- DEFAULT_OLD_REMINDER_REPEAT="5"
            20250115-145350 DBG 3840:      --- DEFAULT_PARTITIONBASED_BACKUP="1"
            20250115-145350 DBG 3840:      --- DEFAULT_PARTITIONS_TO_BACKUP="1 2"
            20250115-145350 DBG 3840:      --- DEFAULT_PARTITIONS_TO_RESTORE="1 2"
            20250115-145350 DBG 3840:      --- DEFAULT_DYNAMIC_MOUNT=""
            20250115-145350 DBG 3870:  <-- readConfigParameters
            20250115-145350 DBG 2660:  --> logOptions Standard option files
            20250115-145350 DBG 2662:      --- Options:
            20250115-145350 DBG 2663:      --- AFTER_STARTSERVICES=
            20250115-145350 DBG 2664:      --- APPEND_LOG=0
            20250115-145350 DBG 2665:      --- APPEND_LOG_OPTION=-a
            20250115-145350 DBG 2666:      --- BACKUPPATH=/backup
            20250115-145350 DBG 2667:      --- BACKUPTYPE=rsync
            20250115-145350 DBG 2668:      --- BEFORE_STOPSERVICES=
            20250115-145350 DBG 2669:      --- BOOT_DEVICE=
            20250115-145350 DBG 2670:      --- CHECK_FOR_BAD_BLOCKS=0
            20250115-145350 DBG 2671:      --- COLOR_CODES=#FF8000 33 #FF0000 31
            20250115-145350 DBG 2672:      --- COLORING=CM
            20250115-145350 DBG 2673:      --- CONFIG_FILE=
            20250115-145350 DBG 2674:      --- DD_BACKUP_SAVE_USED_PARTITIONS_ONLY=0
            20250115-145350 DBG 2675:      --- DD_BLOCKSIZE=1M
            20250115-145350 DBG 2676:      --- DD_PARMS=
            20250115-145350 DBG 2677:      --- DD_WARNING=0
            20250115-145350 DBG 2678:      --- DEPLOYMENT_HOSTS=
            20250115-145350 DBG 2679:      --- DYNAMIC_MOUNT=
            20250115-145350 DBG 2680:      --- EMAIL=
            20250115-145350 DBG 2681:      --- EMAIL_COLORING=SUBJECT
            20250115-145350 DBG 2682:      --- EMAIL_PARMS=
            20250115-145350 DBG 2683:      --- EXCLUDE_LIST=
            20250115-145350 DBG 2684:      --- EXTENSIONS=mem temp disk
            20250115-145350 DBG 2685:      --- FAKE=0
            20250115-145350 DBG 2686:      --- FINAL_COMMAND=
            20250115-145350 DBG 2687:      --- HANDLE_DEPRECATED=
            20250115-145350 DBG 2688:      --- IGNORE_ADDITIONAL_PARTITIONS=0
            20250115-145350 DBG 2689:      --- KEEPBACKUPS=10
            20250115-145350 DBG 2690:      --- KEEPBACKUPS_DD=0
            20250115-145350 DBG 2691:      --- KEEPBACKUPS_DDZ=0
            20250115-145350 DBG 2692:      --- KEEPBACKUPS_TAR=0
            20250115-145350 DBG 2693:      --- KEEPBACKUPS_TGZ=0
            20250115-145350 DBG 2694:      --- KEEPBACKUPS_RSYNC=0
            20250115-145350 DBG 2695:      --- LANGUAGE=EN
            20250115-145350 DBG 2696:      --- LINK_BOOTPARTITIONFILES=0
            20250115-145350 DBG 2697:      --- LOG_LEVEL=1
            20250115-145350 DBG 2698:      --- LOG_OUTPUT=2
            20250115-145350 DBG 2699:      --- MAIL_ON_ERROR_ONLY=0
            20250115-145350 DBG 2700:      --- MAIL_PROGRAM=mail
            20250115-145350 DBG 2701:      --- MSG_LEVEL=0
            20250115-145350 DBG 2702:      --- NOTIFY_START=0
            20250115-145350 DBG 2703:      --- NOTIFY_UPDATE=1
            20250115-145350 DBG 2704:      --- PARTITIONBASED_BACKUP=1
            20250115-145350 DBG 2705:      --- PARTITIONS_TO_BACKUP=1 2
            20250115-145350 DBG 2706:      --- PUSHOVER_TOKEN=
            20250115-145350 DBG 2707:      --- PUSHOVER_USER=
            20250115-145350 DBG 2708:      --- PUSHOVER_NOTIFICATIONS=F
            20250115-145350 DBG 2709:      --- PUSHOVER_SOUND_SUCCESS=
            20250115-145350 DBG 2710:      --- PUSHOVER_SOUND_FAILURE=
            20250115-145350 DBG 2711:      --- PUSHOVER_PRIORITY_SUCCESS=0
            20250115-145350 DBG 2712:      --- PUSHOVER_PRIORITY_FAILURE=1
            20250115-145350 DBG 2713:      --- REBOOT_SYSTEM=0
            20250115-145350 DBG 2714:      --- RESIZE_ROOTFS=1
            20250115-145350 DBG 2715:      --- RESTORE_DEVICE=
            20250115-145350 DBG 2716:      --- RESTORE_EXTENSIONS=
            20250115-145350 DBG 2717:      --- ROOT_PARTITION=
            20250115-145350 DBG 2718:      --- RSYNC_BACKUP_ADDITIONAL_OPTIONS=
            20250115-145350 DBG 2719:      --- RSYNC_BACKUP_OPTIONS=-aHAx --delete
            20250115-145350 DBG 2720:      --- RSYNC_IGNORE_ERRORS=
            20250115-145350 DBG 2721:      --- SENDER_EMAIL=
            20250115-145350 DBG 2722:      --- SKIP_DEPRECATED=
            20250115-145350 DBG 2723:      --- SKIPLOCALCHECK=0
            20250115-145350 DBG 2724:      --- SLACK_WEBHOOK_URL=
            20250115-145350 DBG 2725:      --- SLACK_NOTIFICATIONS=
            20250115-145350 DBG 2726:      --- SMART_RECYCLE=0
            20250115-145350 DBG 2727:      --- SMART_RECYCLE_DRYRUN=1
            20250115-145350 DBG 2728:      --- SMART_RECYCLE_OPTIONS=7 4 12 1
            20250115-145350 DBG 2729:      --- STARTSERVICES=:
            20250115-145350 DBG 2730:      --- STOPSERVICES=:
            20250115-145350 DBG 2731:      --- SYSTEMSTATUS=0
            20250115-145350 DBG 2732:      --- TAR_BACKUP_ADDITIONAL_OPTIONS=
            20250115-145350 DBG 2733:      --- TAR_BACKUP_OPTIONS=-cpi --one-file-system
            20250115-145350 DBG 2734:      --- TAR_BOOT_PARTITION_ENABLED=0
            20250115-145350 DBG 2735:      --- TAR_IGNORE_ERRORS=
            20250115-145350 DBG 2736:      --- TAR_RESTORE_ADDITIONAL_OPTIONS=
            20250115-145350 DBG 2737:      --- TELEGRAM_TOKEN=
            20250115-145350 DBG 2738:      --- TELEGRAM_CHATID=
            20250115-145350 DBG 2739:      --- TELEGRAM_NOTIFICATIONS=F
            20250115-145350 DBG 2740:      --- TIMESTAMPS=0
            20250115-145350 DBG 2741:      --- UPDATE_UUIDS=1
            20250115-145350 DBG 2742:      --- VERBOSE=0
            20250115-145350 DBG 2743:      --- YES_NO_RESTORE_DEVICE=loop
            20250115-145350 DBG 2744:      --- ZIP_BACKUP=0
            20250115-145350 DBG 2746:  <-- logOptions
            20250115-145350 DBG 2388:  --> isSupportedEnvironment
            20250115-145350 DBG 2405:      --- PRETTY_NAME="Debian GNU/Linux 12 (bookworm)" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)"
            VERSION_CODENAME=bookworm ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs
            .debian.org/"
            20250115-145350 DBG 2410:      --- IS_UBUNTU: 0
            20250115-145350 DBG 2418:      --- Modelpath: Raspberry Pi 5 Model B Rev 1.0
            20250115-145350 DBG 2423:      --- /etc/rpi-issue: Raspberry Pi reference 2024-11-19
            20250115-145350 DBG 2423:      --- Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 891df1e21ed2b6099a2e6a13e26c91dea44b34d4, stage
            20250115-145350 DBG 2424:  <-- isSupportedEnvironment 0
            20250115-145350 DBG 8738:  --> check4RequiredCommands
            20250115-145350 DBG 8759:  <-- check4RequiredCommands
            20250115-145350 DBG 9570:  --- RESTORE: 0 - fileParameter:
            20250115-145350 DBG 9591:  --- Enabling trap handler
            20250115-145350 DBG 1943:  --> trapWithArg cleanup SIGINT SIGTERM EXIT
            20250115-145350 DBG 4754:  --> lockMe
            20250115-145350 DBG 4756:  <-- lockMe
            --- RBK0009I: @HOSTNAME@: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:53:50 CET 2025 gestartet.
            20250115-145350 DBG 3875:  --> setupEnvironment
            20250115-145350 DBG 3935:      --- BACKUPTARGET_DIR: /backup/@HOSTNAME@/@HOSTNAME@-rsync-backup-20250115-145350
            20250115-145350 DBG 3936:      --- BACKUPTARGET_FILE: /backup/@HOSTNAME@/@HOSTNAME@-rsync-backup-20250115-145350/@HOSTNAME@-rsync-backup-2025011
            5-145350
            20250115-145350 DBG 3938:  <-- setupEnvironment
            20250115-145350 DBG 9628:  --- Read config /usr/local/etc/raspiBackup.conf : 0.1.8
            20250115-145350 DBG 9628:  --- VERSION_CONFIG="0.1.8"
            20250115-145350 DBG 9628:  --- DEFAULT_BACKUPPATH="/backup"
            20250115-145350 DBG 9628:  --- DEFAULT_BACKUPTYPE="rsync"
            20250115-145350 DBG 9628:  --- DEFAULT_ZIP_BACKUP="0"
            20250115-145350 DBG 9628:  --- DEFAULT_DD_BACKUP_SAVE_USED_PARTITIONS_ONLY=0
            20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS="10"
            20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_DD=0
            20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_DDZ=0
            20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_TAR=0
            20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_TGZ=0
            20250115-145350 DBG 9628:  --- DEFAULT_KEEPBACKUPS_RSYNC=0
            20250115-145350 DBG 9628:  --- DEFAULT_SMART_RECYCLE="0"
            20250115-145350 DBG 9628:  --- DEFAULT_SMART_RECYCLE_DRYRUN="1"
            20250115-145350 DBG 9628:  --- DEFAULT_SMART_RECYCLE_OPTIONS="7 4 12 1"
            20250115-145350 DBG 9628:  --- DEFAULT_STOPSERVICES=":"
            20250115-145350 DBG 9628:  --- DEFAULT_STARTSERVICES=":"
            20250115-145350 DBG 9628:  --- DEFAULT_BEFORE_STOPSERVICES=""
            20250115-145350 DBG 9628:  --- DEFAULT_AFTER_STARTSERVICES=""
            20250115-145350 DBG 9628:  --- DEFAULT_EMAIL=""
            20250115-145350 DBG 9628:  --- DEFAULT_SENDER_EMAIL=""
            20250115-145350 DBG 9628:  --- DEFAULT_EMAIL_PARMS=""
            20250115-145350 DBG 9628:  --- DEFAULT_MAIL_PROGRAM="mail"
            20250115-145350 DBG 9628:  --- DEFAULT_TELEGRAM_TOKEN=""
            20250115-145350 DBG 9628:  --- DEFAULT_TELEGRAM_CHATID=""
            20250115-145350 DBG 9628:  --- DEFAULT_TELEGRAM_NOTIFICATIONS="F"
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_ADDITIONAL_OPTIONS=""
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_DEVICE=""
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_TOKEN=""
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_USER=""
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_NOTIFICATIONS="F"
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_SOUND_SUCCESS=""
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_SOUND_FAILURE=""
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_PRIORITY_SUCCESS="0"
            20250115-145350 DBG 9628:  --- DEFAULT_PUSHOVER_PRIORITY_FAILURE="1"
            20250115-145350 DBG 9628:  --- DEFAULT_SLACK_WEBHOOK_URL=""
            20250115-145350 DBG 9628:  --- DEFAULT_SLACK_NOTIFICATIONS=""
            20250115-145350 DBG 9628:  --- DEFAULT_NOTIFY_START=0
            20250115-145350 DBG 9628:  --- DEFAULT_MAIL_ON_ERROR_ONLY=0
            20250115-145350 DBG 9628:  --- DEFAULT_MSG_LEVEL="0"
            20250115-145350 DBG 9628:  --- DEFAULT_COLORING="CM"
            20250115-145350 DBG 9628:  --- DEFAULT_EMAIL_COLORING="SUBJECT"
            20250115-145350 DBG 9628:  --- DEFAULT_COLOR_CODES=("#FF8000 33" "#FF0000 31")
            20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_DEVICE=""
            20250115-145350 DBG 9628:  --- DEFAULT_VERBOSE=0
            20250115-145350 DBG 9628:  --- DEFAULT_SKIPLOCALCHECK=0
            20250115-145350 DBG 9628:  --- DEFAULT_DD_BLOCKSIZE=1M
            20250115-145350 DBG 9628:  --- DEFAULT_DD_PARMS=""
            20250115-145350 DBG 9628:  --- DEFAULT_EXCLUDE_LIST=""
            20250115-145350 DBG 9628:  --- DEFAULT_EXTENSIONS="mem temp disk"
            20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_EXTENSIONS=""
            20250115-145350 DBG 9628:  --- DEFAULT_LANGUAGE="DE"
            20250115-145350 DBG 9628:  --- DEFAULT_DEPLOYMENT_HOSTS=""
            20250115-145350 DBG 9628:  --- DEFAULT_RESIZE_ROOTFS=1
            20250115-145350 DBG 9628:  --- DEFAULT_LINK_BOOTPARTITIONFILES=0
            20250115-145350 DBG 9628:  --- DEFAULT_TAR_BOOT_PARTITION_ENABLED=0
            20250115-145350 DBG 9628:  --- DEFAULT_SKIP_DEPRECATED=""
            20250115-145350 DBG 9628:  --- DEFAULT_CHECK_FOR_BAD_BLOCKS=0
            20250115-145350 DBG 9628:  --- DEFAULT_TIMESTAMPS=0
            20250115-145350 DBG 9628:  --- DEFAULT_SYSTEMSTATUS=0
            20250115-145350 DBG 9628:  --- DEFAULT_REBOOT_SYSTEM=0
            20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_REMINDER_INTERVAL=6
            20250115-145350 DBG 9628:  --- DEFAULT_RESTORE_REMINDER_REPEAT=3
            20250115-145350 DBG 9628:  --- DEFAULT_OLD_REMINDER_REPEAT="5"
            20250115-145350 DBG 9628:  --- DEFAULT_PARTITIONBASED_BACKUP="1"
            20250115-145350 DBG 9628:  --- DEFAULT_PARTITIONS_TO_BACKUP="1 2"
            20250115-145350 DBG 9628:  --- DEFAULT_PARTITIONS_TO_RESTORE="1 2"
            20250115-145350 DBG 9628:  --- DEFAULT_DYNAMIC_MOUNT=""
            20250115-145350 DBG 2660:  --> logOptions Invocation options
            20250115-145350 DBG 2695:      --- LANGUAGE=DE
            20250115-145350 DBG 2033:  --> logSystem
            20250115-145350 DBG 2034:          *** uname -a
            20250115-145350 DBG 2034:              Linux @HOSTNAME@ 6.6.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
            20250115-145350 DBG 2035:          *** cat /etc/os-release
            20250115-145350 DBG 2035:              PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
            20250115-145350 DBG 2035:              NAME="Debian GNU/Linux"
            20250115-145350 DBG 2035:              VERSION_ID="12"
            20250115-145350 DBG 2035:              VERSION="12 (bookworm)"
            20250115-145350 DBG 2035:              VERSION_CODENAME=bookworm
            20250115-145350 DBG 2035:              ID=debian
            20250115-145350 DBG 2035:              HOME_URL="https://www.debian.org/"
            20250115-145350 DBG 2035:              SUPPORT_URL="https://www.debian.org/support"
            20250115-145350 DBG 2035:              BUG_REPORT_URL="https://bugs.debian.org/"
            20250115-145350 DBG 2036:          *** cat /etc/debian_version
            20250115-145350 DBG 2036:              12.9
            20250115-145350 DBG 2037:          *** cat /etc/fstab
            20250115-145350 DBG 2037:              proc            /proc           proc    defaults          0       0
            20250115-145350 DBG 2037:              PARTUUID=3ee3f3c5-01  /boot/firmware  vfat    defaults          0       2
            20250115-145350 DBG 2037:              PARTUUID=3ee3f3c5-02  /               ext4    defaults,noatime  0       1
            20250115-145350 DBG 2037:              # pount point for QNAP NAS used in rsync backup.
            20250115-145350 DBG 2037:              # inserted by nt Jan 15, 2025
            20250115-145350 DBG 2037:              192.168.1.12:/share/backup_@HOSTNAME@ /backup nfs rw     0       0
            20250115-145350 DBG 2037:              # a swapfile is not a swap partition, no line here
            20250115-145350 DBG 2037:              #   use  dphys-swapfile swap[on|off]  for that
            20250115-145350 DBG 2038:          *** locale
            20250115-145350 DBG 2038:              LANG=en_GB.UTF-8
            20250115-145350 DBG 2038:              LANGUAGE=
            20250115-145350 DBG 2038:              LC_CTYPE="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_NUMERIC="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_TIME="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_COLLATE="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_MONETARY="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_MESSAGES="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_PAPER="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_NAME="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_ADDRESS="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_TELEPHONE="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_MEASUREMENT="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_IDENTIFICATION="en_GB.UTF-8"
            20250115-145350 DBG 2038:              LC_ALL=
            20250115-145350 DBG 2039:  <-- logSystem
            20250115-145350 DBG 3134:  --> downloadPropertiesFile
            20250115-145350 DBG 3226:      --> shouldRenewDownloadPropertiesFile
            20250115-145350 DBG 3240:          --- 20250115 : 20250115
            20250115-145350 DBG 3243:          --- Skip download
            20250115-145350 DBG 3249:      <-- shouldRenewDownloadPropertiesFile 1
            20250115-145350 DBG 3171:  <-- downloadPropertiesFile 0
            20250115-145350 DBG 8125:  --> updateRestoreReminder
            20250115-145350 DBG 8173:  <-- updateRestoreReminder
            20250115-145350 DBG 6876:  --> reportNews
            20250115-145350 DBG 3113:      --> isUpdatePossible
            20250115-145350 DBG 3354:          --> isNewVersionAvailable
            20250115-145350 DBG 3368:              --- Versionsplit: 0.6.9.1 -
            20250115-145350 DBG 3397:              --- Returning: 0.0 0.0 0.6.9.1
            20250115-145350 DBG 3399:          <-- isNewVersionAvailable 99
            20250115-145350 DBG 3128:      <-- isUpdatePossible
            20250115-145350 DBG 5021:      --> isBetaAvailable
            20250115-145350 DBG 5031:      <-- isBetaAvailable
            20250115-145350 DBG 6893:  <-- reportNews
            20250115-145350 DBG 3204:  --> isVersionDeprecated
            20250115-145350 DBG 3220:  <-- isVersionDeprecated 1
            20250115-145350 DBG 6385:  --> doit
            20250115-145350 DBG 6388:      --- Startingdirectory: /backup
            20250115-145350 DBG 6389:          *** fdisk -l | grep -v ^
            20250115-145350 DBG 6389:              fdisk from util-linux 2.38.1
            20250115-145350 DBG 6390:          *** mount
            20250115-145350 DBG 6390:              sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              proc on /proc type proc (rw,relatime)
            20250115-145350 DBG 6390:              udev on /dev type devtmpfs (rw,nosuid,relatime,size=4080976k,nr_inodes=255061,mode=755)
            20250115-145350 DBG 6390:              devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
            20250115-145350 DBG 6390:              tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755)
            20250115-145350 DBG 6390:              /dev/mmcblk0p2 on / type ext4 (rw,noatime)
            20250115-145350 DBG 6390:              securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
            20250115-145350 DBG 6390:              tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
            20250115-145350 DBG 6390:              cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
            20250115-145350 DBG 6390:              pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
            20250115-145350 DBG 6390:              systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto
            =5,direct,pipe_ino=4595)
            20250115-145350 DBG 6390:              mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
            20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
            20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,
            mode=700)
            20250115-145350 DBG 6390:              /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=asci
            i,shortname=mixed,errors=remount-ro)
            20250115-145350 DBG 6390:              ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode
            =700)
            20250115-145350 DBG 6390:              binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
            20250115-145350 DBG 6390:              sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
            20250115-145350 DBG 6390:              192.168.1.12:/share/backup_@HOSTNAME@ on /backup type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576
            ,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=none,addr=19
            2.168.1.12)
            20250115-145350 DBG 6390:              tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1
            000,gid=1000)
            20250115-145350 DBG 6390:              gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=10
            00)
            20250115-145350 DBG 6390:              portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
            20250115-145350 DBG 2379:      --> isUnsupportedVersion
            20250115-145350 DBG 2382:      <-- isUnsupportedVersion 1
            20250115-145350 DBG 6899:      --> doitBackup 1
            20250115-145350 DBG 6650:          --> getRootPartition
            20250115-145350 DBG 6655:                  *** cat /proc/cmdline
            20250115-145351 DBG 6655:                      reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=int
            erleave  smsc95xx.macaddr=2C:CF:67:56:DA:B9 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PAR
            TUUID=3ee3f3c5-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
            20250115-145351 DBG 6658:              --- RootPartition: PARTUUID=3ee3f3c5-02
            20250115-145351 DBG 6662:          <-- getRootPartition PARTUUID=3ee3f3c5-02
            20250115-145351 DBG 6687:          --> inspect4Backup
            20250115-145351 DBG 6689:                  *** ls -1 /dev/mmcblk*
            20250115-145351 DBG 6689:                      /dev/mmcblk0
            20250115-145351 DBG 6689:                      /dev/mmcblk0p1
            20250115-145351 DBG 6689:                      /dev/mmcblk0p2
            20250115-145351 DBG 6690:                  *** ls -1 /dev/sd*
            20250115-145351 DBG 6690:                      ls: cannot access '/dev/sd*': No such file or directory
            20250115-145351 DBG 6691:                  *** ls -1 /dev/nvme*
            20250115-145351 DBG 6691:                      ls: cannot access '/dev/nvme*': No such file or directory
            20250115-145351 DBG 6712:              --- Starting boot discovery
            20250115-145351 DBG 6717:              --- bootMountpoint1: /boot mounted?
            20250115-145351 DBG 6722:              --- bootMountpoint2: /boot/firmware mounted? /dev/mmcblk0p1
            20250115-145351 DBG 6732:              --- bootMountpoint: /boot/firmware, bootPartition: /dev/mmcblk0p1
            20250115-145351 DBG 6734:              --- Starting root discovery
            20250115-145351 DBG 6738:              --- rootPartition: / mounted? /dev/mmcblk0p2
            20250115-145351 DBG 6674:              --> deviceInfo /dev/mmcblk0p1
            20250115-145351 DBG 6682:              <-- deviceInfo mmcblk0 1
            20250115-145351 DBG 6674:              --> deviceInfo /dev/mmcblk0p2
            20250115-145351 DBG 6682:              <-- deviceInfo mmcblk0 2
            20250115-145351 DBG 6759:              --- boot: mmcblk0 1
            20250115-145351 DBG 6760:              --- root: mmcblk0 2
            20250115-145351 DBG 6780:              --- BOOT_DEVICE: mmcblk0
            20250115-145351 DBG 6784:              --- BOOT_DEVICENAME: /dev/mmcblk0
            20250115-145351 DBG 3019:              --> getPartitionPrefix mmcblk0
            20250115-145351 DBG 3028:              <-- getPartitionPrefix mmcblk0p
            20250115-145351 DBG 6788:              --- BOOT_PARTITION_PREFIX: mmcblk0p
            20250115-145351 DBG 6791:          <-- inspect4Backup
            20250115-145351 DBG 6614:          --> commonChecks
            20250115-145351 DBG 6644:          <-- commonChecks
            20250115-145351 DBG 3747:          --> getFsType /backup
            20250115-145351 DBG 3790:              --> findMountPath /backup
            20250115-145351 DBG 3798:                  --- Path: /backup
            20250115-145351 DBG 3806:              <-- findMountPath /backup
            20250115-145351 DBG 3750:              --- Mountpoint: /backup
            20250115-145351 DBG 3753:              --- df -T: nfs
            20250115-145351 DBG 3756:          <-- getFsType nfs
            20250115-145351 DBG 6935:          --- Found partitions on /dev/mmcblk0: 2
            20250115-145351 DBG 3685:          --> supportsHardlinks /backup
            20250115-145351 DBG 3698:              --- Links: 2
            20250115-145351 DBG 3708:          <-- supportsHardlinks 0
            20250115-145351 DBG 7060:          --- Filesystem: nfs
            20250115-145351 DBG 3629:          --> supportsFileAttributes /backup
            20250115-145351 DBG 3646:              --- ----r-xrwx # nobody # nogroup
            cp: failed to preserve ownership for '//backup/raspiBackup.fileattributes': Operation not permitted
            20250115-145351 DBG 3654:              --- cp failed with rc 1 - retryCount
            cp: cannot create regular file '//backup/raspiBackup.fileattributes': Permission denied
            20250115-145354 DBG 3654:              --- cp failed with rc 1 - retryCount
            20250115-145357 DBG 3654:              --- cp failed with rc 1 - retryCount
            20250115-145400 DBG 3654:              --- cp failed with rc 1 - retryCount
            20250115-145403 DBG 3676:          <-- supportsFileAttributes 1
            20250115-145403 DBG 3790:          --> findMountPath /backup
            20250115-145403 DBG 3798:              --- Path: /backup
            20250115-145403 DBG 3806:          <-- findMountPath /backup
            20250115-145403 DBG 2529:          --> exitError 102
            20250115-145403 DBG 2536:          <-- exitError 102
            20250115-145403 DBG 4767:          --> cleanup
            20250115-145403 DBG 5037:              --> cleanupBackup
            20250115-145403 DBG 5039:                  --- Got trap EXIT
            20250115-145403 DBG 5040:                  --- rc: 102
            20250115-145403 DBG 6299:                  --> umountSDPartitions
            20250115-145403 DBG 6301:                      --- BEFORE: mount sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- proc on /proc type proc (rw,relatime)
            20250115-145403 DBG 6301:                      --- udev on /dev type devtmpfs (rw,nosuid,relatime,size=4080976k,nr_inodes=255061,mode=755)
            20250115-145403 DBG 6301:                      --- devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
            20250115-145403 DBG 6301:                      --- tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755)
            20250115-145403 DBG 6301:                      --- /dev/mmcblk0p2 on / type ext4 (rw,noatime)
            20250115-145403 DBG 6301:                      --- securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
            20250115-145403 DBG 6301:                      --- tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
            20250115-145403 DBG 6301:                      --- cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_rec
            ursiveprot)
            20250115-145403 DBG 6301:                      --- pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
            20250115-145403 DBG 6301:                      --- systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minprot
            o=5,maxproto=5,direct,pipe_ino=4595)
            20250115-145403 DBG 6301:                      --- mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,
            mode=700)
            20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatim
            e,mode=700)
            20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noex
            20250115-145403 DBG 6301:                      --- /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,io
            charset=ascii,shortname=mixed,errors=remount-ro)
            20250115-145403 DBG 6301:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,r
            elatime,mode=700)
            20250115-145403 DBG 6301:                      --- binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6301:                      --- sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
            20250115-145403 DBG 6301:                      --- 192.168.1.12:/share/backup_@HOSTNAME@ on /backup type nfs (rw,relatime,vers=3,rsize=1048576,w
            size=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=
            none,addr=192.168.1.12)
            20250115-145403 DBG 6301:                      --- tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mo
            de=700,uid=1000,gid=1000)
            20250115-145403 DBG 6301:                      --- gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000
            ,group_id=1000)
            20250115-145403 DBG 6301:                      --- portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id
            =1000)
            20250115-145403 DBG 3733:                      --> isMounted /tmp/mmcblk0p1 2
            20250115-145403 DBG 3741:                      <-- isMounted 1
            20250115-145403 DBG 6313:                      --- AFTER: mount sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- proc on /proc type proc (rw,relatime)
            20250115-145403 DBG 6313:                      --- udev on /dev type devtmpfs (rw,nosuid,relatime,size=4080976k,nr_inodes=255061,mode=755)
            20250115-145403 DBG 6313:                      --- devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
            20250115-145403 DBG 6313:                      --- tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=824560k,mode=755)
            20250115-145403 DBG 6313:                      --- /dev/mmcblk0p2 on / type ext4 (rw,noatime)
            20250115-145403 DBG 6313:                      --- securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
            20250115-145403 DBG 6313:                      --- tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
            20250115-145403 DBG 6313:                      --- cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_rec
            ursiveprot)
            20250115-145403 DBG 6313:                      --- pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
            20250115-145403 DBG 6313:                      --- systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minprot
            20250115-145403 DBG 6313:                      --- mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,
            mode=700)
            20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatim
            e,mode=700)
            20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noex
            20250115-145403 DBG 6313:                      --- /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,io
            20250115-145403 DBG 6313:                      --- ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,r
            elatime,mode=700)
            20250115-145403 DBG 6313:                      --- binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
            20250115-145403 DBG 6313:                      --- sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
            20250115-145403 DBG 6313:                      --- 192.168.1.12:/share/backup_@HOSTNAME@ on /backup type nfs (rw,relatime,vers=3,rsize=1048576,w
            20250115-145403 DBG 6313:                      --- tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mo
            20250115-145403 DBG 6313:                      --- gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000
            ,group_id=1000)
            20250115-145403 DBG 6313:                      --- portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id
            =1000)
            20250115-145403 DBG 6315:                  <-- umountSDPartitions
            20250115-145403 DBG 3463:                  --> startServices
            20250115-145403 DBG 2052:                      --> logSystemServices
            20250115-145403 DBG 2061:                      <-- logSystemServices
            20250115-145403 DBG 3489:                  <-- startServices
            20250115-145403 DBG 3493:                  --> executeAfterStartServices
            20250115-145403 DBG 3507:                  <-- executeAfterStartServices
            20250115-145403 DBG 4512:                  --> cleanupBackupDirectory
            --- RBK0043I: Unvollständiges Backup in /backup/@HOSTNAME@/@HOSTNAME@-rsync-backup-20250115-145350 wird gelöscht. Das kann etwas dauern. Bitte G
            eduld.
            20250115-145403 DBG 4529:                  <-- cleanupBackupDirectory
            20250115-145403 DBG 5055:              <-- cleanupBackup
            20250115-145403 DBG 5061:              --> cleanupTempFiles
            20250115-145403 DBG 5068:              <-- cleanupTempFiles
            20250115-145403 DBG 3446:              --> finalCommand
            20250115-145403 DBG 3458:              <-- finalCommand
            20250115-145403 DBG 4800:              --- Terminate now with rc 102
            --- RBK0010I: @HOSTNAME@: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Wed 15 Jan 14:54:03 CET 2025 beendet mit Returncode 102.
            20250115-145403 DBG 4384:              --> sendEMail
            20250115-145403 DBG 4506:              <-- sendEMail
            20250115-145403 DBG 4603:              --- Masquerading some mount options
            20250115-145403 DBG 4634:              --- Masquerading home directory name
            20250115-145403 DBG 4639:              --- Masquerading hostname
            20250115-145403 DBG 4644:              --- Masquerading sensitive non local IPs
            20250115-145403 DBG 2123:              --> logFinish
            20250115-145403 DBG 2134:                  --- 102 2 0
            20250115-145403 DBG 2139:                  --- LOG_OUTPUT=3
            20250115-145403 DBG 2143:                  --- LOG_OUTPUT: 3
            20250115-145403 DBG 2170:                  --- DEST_LOGFILE: /home/pi/raspiBackup.log
            20250115-145403 DBG 2171:                  --- DEST_MSGFILE: /home/pi/raspiBackup.msg
            20250115-145403 DBG 2174:                  --- Moving Logfile: /tmp/raspiBackup.log
            20250115-145403 DBG 2177:                  --- Logfiles used: /home/pi/raspiBackup.log and /tmp/raspiBackup.msg
            20250115-145403 DBG 2180:                  --- Moving Msgfile: /tmp/raspiBackup.msg
            20250115-145403 DBG 2183:                  --- Logfiles used: /home/pi/raspiBackup.log and /home/pi/raspiBackup.msg
            20250115-145403 DBG 2190:                      *** cat /tmp/raspiBackup.logf
            20250115-145403 DBG 2205:              <-- logFinish
            20250115-145403 DBG 4704:              --> callNotificationExtension 102
            20250115-145403 DBG 2230:                  --> callExtensions notify
            20250115-145403 DBG 2297:                      --- raspiBackup_mem.sh not found - skipping
            20250115-145403 DBG 2297:                      --- raspiBackup_temp.sh not found - skipping
            20250115-145403 DBG 2297:                      --- raspiBackup_disk.sh not found - skipping
            20250115-145403 DBG 2302:                  <-- callExtensions
            20250115-145403 DBG 4713:                  --- NotificationExtension rc: 0
            20250115-145403 DBG 4718:              <-- callNotificationExtension 0
            20250115-145403 DBG 4898:          <-- cleanup
            20250115-145403 DBG 4760:          --> unLockMe
            20250115-145403 DBG 4762:          <-- unLockMe
            code_text
            • N norbert999
              Hier die Ausgabe:
              .debian.org/"
              5-145350
              mode=700)
              =700)
              2.168.1.12)
              000,gid=1000)
              00)
              ursiveprot)
              mode=700)
              e,mode=700)
              elatime,mode=700)
              ,group_id=1000)
              =1000)
              ursiveprot)
              mode=700)
              e,mode=700)
              elatime,mode=700)
              ,group_id=1000)
              =1000)
              eduld.
              code_text
              Das hat ja auch nix mit dem Raspberry OS zu tun, die Freigabe auf dem NAS muss angepasst werden. Sofern möglich.
                N Offline
                N Offline
                norbert999
                @thomas-braun Das sind die Stellschrauben auf dem QNAP. Es muss doch eine Möglichkeit geben, systematisch sich der Problemursache zu nähern. Mit rumprobieren (auch nach zig Std lesen) komme ich nicht weiter.
                • N norbert999
                  @norbert999
                  Zu QNAP kann ich dir nix sagen, hab ich nicht im Einsatz.
                  Aber offenbar fehlen da Berechtigungen für den user 'iobroker' und dessen UID/GID.
                    @norbert999
                    N Offline
                    N Offline
                    norbert999
                    Kannst Du mir sagen, woran Du das siehst?
                    Muss der Nutzer "iobroker" auf dem QNAP eingerichtet sein? Und wenn ja, zu welcher Gruppe muss er gehören?
                    • N norbert999
                      @norbert999
                      Ja, auf dem NFS-Server muss ein User mit den gleichen UID/GID existieren wie auf dem System wo das Dateisystem gemountet werden soll. Usernames sind dabei irrelevant, die Kisten sprechen nur über IDs miteinander.
                      Die IDs findest du per
                      id
                      Bzw. per
                      sudo -u iobroker id
                      N 2 Antworten Letzte Antwort
                        @norbert999
                        id
                        Bzw. per
                        sudo -u iobroker id
                        N Offline
                        N Offline
                        norbert999
                        @thomas-braun Danke Dir für Deine Antwort.
                        pi@raspi5:/backup $ id
                        uid=1000(pi) gid=1000(pi) groups=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),60(games),100(users),102(input),105(render),110(netdev),115(lpadmin),993(gpio),994(i2c),995(spi),1001(iobroker)
                        pi@raspi5:/backup $
                        D.h. ich brauche auf dem QNAP einen user mit uid=1000 und gid=1000
                        Ist das richtig?
                        sudo -u iobroker id
                        Dein alternatives Kommando hat nicht funktioniert:
                        pi@raspi5:/backup $ sudo iobroker id
                        ***For security reasons ioBroker should not be run or administrated as root.***
                        By default only a user that is member of iobroker group can execute ioBroker commands.
                        Please read the Documentation on how to set up such a user, if not done yet.
                        Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                        Please note that this option may be disabled in the future, so please change your setup accordingly now.
                        • N norbert999
                          pi@raspi5:/backup $
                          Ist das richtig?
                          sudo -u iobroker id
                          Das würde funktionieren, wenn du es auch genauso eingegeben hättest...
                          Edit: Weitere Voraussetzungen sind übrigens ein NFS-Server in gleicher Major-Version wie auf dem Client sowie ein Dateisystem auf dem Server, das die unix-Rechte auch kennt.
                            @norbert999
                            id
                            Bzw. per
                            sudo -u iobroker id
                            N Offline
                            N Offline
                            norbert999
                            pi@raspi5:/backup $ sudo -u iobroker id
                            uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev),108(bluetooth),993(gpio),994(i2c)
                            pi@raspi5:/backup $
                            Wer ist denn der user, der raspiBackup ausführt? ist das pi mit uid1000 oder iobroker mit 1001?
                            • N norbert999
                              pi@raspi5:/backup $
                              @norbert999
                              Der user iobroker natürlich.
                                @norbert999
                                N Offline
                                N Offline
                                norbert999
                                D.h. ich muss auf dem NAS folgenden user haben:
                                uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker). Richtig?
                                • N norbert999
                                  @norbert999
                                  Ja die UID/GID wird durchgereicht.
                                    @norbert999
                                    N Offline
                                    N Offline
                                    norbert999
                                    Hallo Thomas, muss Dich schon wieder nerven. Habe jetzt folgendes "erreicht":
                                    Auf raspi5 user iobroker in gruppe iobroker mit uid=1001 und gid=1001:
                                    pi@raspi5:/backup $ id iobroker
                                    uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev),108(bluetooth),994(i2c),993(gpio)
                                    Auf QNAP user iobroker in gruppe iobroker mit uid=1001 und gid=1001:
                                    [/] # id iobroker
                                    uid=1001(iobroker) gid=100(everyone) groups=100(everyone),1001(iobroker)
                                    Der mount statische mount auf dem raspi ist da:
                                    pi@raspi5:/backup $ mount
                                    192.168.1.12:/share/backup_raspi5 on /backup type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=44352,mountproto=udp,local_lock=none,addr=192.168.1.12)
                                    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=824544k,nr_inodes=206136,mode=700,uid=1000,gid=1000)
                                    Leider geht es immer noch nicht, gleicher Fehler bei raspiBackup:
                                    --- RBK0009I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Thu 16 Jan 09:02:46 CET 2025 gestartet.
                                    --- RBK0043I: Unvollständiges Backup in /backup/raspi5/raspi5-rsync-backup-20250116-090246 wird gelöscht. Das kann etwas dauern. Bitte Geduld.
                                    --- RBK0010I: raspi5: raspiBackup.sh V0.6.9.1 - 2024-09-28 (be4ba6d) Thu 16 Jan 09:02:59 CET 2025 beendet mit Returncode 102.
                                    pi@raspi5:/backup $
                                    Hast Du noch eine Idee für mich, wie ich weiter vorgehen kann?
                                    • N norbert999
                                      [/] # id iobroker
                                      pi@raspi5:/backup $
                                      @norbert999
                                      Welches Dateisystem ist auf dem NAS angelegt?
                                      Welche Version des NFS-Servers werkelt auf dem NAS?
                                        @norbert999
                                        N Offline
                                        N Offline
                                        norbert999
                                        ext4 (wie kann das nochmal über ssh auf dem NAS überprüfen?)
                                        NFSv3
                                        • N norbert999
                                          NFSv3
                                          @norbert999
                                          Auf dem Client wird NFS4 laufen. Das ist aber nicht vollständig abwärtskompatibel zu NFS3.
                                          blkid
