  3. Einsteigerfragen
  4. Zigbee Fingerbot, heute gibts kein Kaffee [gel.]
25 Beiträge 6 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • DuffyD Offline
    DuffyD Offline
    Duffy
    schrieb am zuletzt editiert von Duffy
    Guten Morgen alle zusammen,
    neues Jahr neues Pech (mit Zigbee)
    Seit heute Morgen will mein Fingerbot nicht mehr funktionieren. Ich habe ihn schon aus den Objekten gelöscht, neu gekoppelt, Zigbee Adapter und Pi neu gestartet aber es kommt immer folgende Meldung wenn ich den Fingerbot über die Zigbee Adapter Oberfläche antriggere:
    host.raspberrypi
    	2025-01-02 08:21:25.363	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi
    	2025-01-02 08:21:25.362	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    	2025-01-02 08:21:25.362	error	Caught by controller[1]: at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:652:23)
    host.raspberrypi
    	2025-01-02 08:21:25.362	error	Caught by controller[1]: at Array.forEach (<anonymous>)
    host.raspberrypi
    	2025-01-02 08:21:25.361	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:726:31
    host.raspberrypi
    	2025-01-02 08:21:25.361	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'includes')
    host.raspberrypi
    	2025-01-02 08:21:25.360	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    	2025-01-02 08:21:24.566	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2025-01-02 08:21:24.564	info	terminating
    zigbee.0
    	2025-01-02 08:21:24.005	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2025-01-02 08:21:24.000	info	cleaned everything up...
    zigbee.0
    	2025-01-02 08:21:23.978	error	Cannot read properties of undefined (reading 'includes')
    zigbee.0
    	2025-01-02 08:21:23.978	error	TypeError: Cannot read properties of undefined (reading 'includes') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:726:31 at Array.forEach (<anonymous>) at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:652:23)
    zigbee.0
    	2025-01-02 08:21:23.977	error	unhandled promise rejection: Cannot read properties of undefined (reading 'includes')
    zigbee.0
    	2025-01-02 08:21:23.976	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2025-01-02 08:21:15.460	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
    admin.0
    	2025-01-02 08:21:15.058	info	==> Connected system.user.admin from ::ffff:192.168.178.116
    Ausserdem erscheint unter "Host" diese Meldung:
    In diesem Zusammenhang sollte ich vielleicht noch erwähnen das auch andere, Baugleiche Fingerbots nicht mehr wollen.
    Bedauerlicherweise kann ich mit der Meldung aus dem Protokoll nichts anfangen.
    Kann mir wohl jemand einen Tipp geben was ich tun kann das die Fingerbots wieder funktionieren?
    Es sind diese Fingerbots:
    Ich würde mich über Eure Unterstützung freuen.
    Gruß Duffy
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.2
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    • DuffyD Duffy
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      admin.0
      Gruß Duffy
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @duffy Installier bitte die 1.10.14 aus dem latest, dann gibt es auch wieder Kaffee.
      A.
      DuffyD 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        A.
        DuffyD Offline
        DuffyD Offline
        Duffy
        @asgothian
        Guten Morgen Asgothian,
        ist das hier gemeint?
        Edit:
        Verdammt ich weis nicht mehr wie das ging.
        Ich habe mir jetzt mal den Link auf Github geholt und den Benutzerdefiniert installiert.
        https://github.com/ioBroker/ioBroker.zigbee/releases/tag/v1.10.14
        Jetzt ist es aber immer noch 1.10.13.
        Irgendwas war da das man jetzt die 1.10.14 installieren muß aber ich weis nicht mehr wie und wo.
        Kannst du mir bitte noch mal unter die Arme greifen?
        Edit / Edit. Das war wohl falsch im Protokoll kam die Meldung das der Link nicht stimmt; konkret:
        iobroker Cannot install from GitHub. Invalid URL https://github.com/ioBroker/ioBroker.zigbee/releases/tag/v1.10.14
        LG Duffy
        Node.js: v22.23.2
        NPM: 10.9.4
        js-controller 7.1.2
        Linux: Trixie
        • DuffyD Duffy
          @asgothian
          Edit:
          LG Duffy
          DuffyD Offline
          DuffyD Offline
          Duffy
          Dank des Lösungsansatzes von @Asgothian und meinem Testpi* habe ich jetzt die Version installiert bekommen.
          Lieber erst mal am Testpi testen bevor ich mir mein Aktivsystem zerschiesse.
          Für alle die ahnungslos sind wie ich hier kurz wie ich es gemacht habe.
          Beta Repsoitorry aktiviert.
          Expertenmodus aktiviert
          über die Katze, von Github (mittlerer Reiter) Zigbee ausgewählt und installiert.
          Schon läuft wieder der Kaffee :-)
          Vergesst was ich oben geschrieben habe war auch wieder falsch auch wenn der Kaffee wieder läuft :-(
          Vielen Dank an Asgothian und entschuldige bitte meine Ahnungslosigkeit ;-(
          VG Duffy
          Vielleicht noch eine Frage aus Interesse, warum ging der Fingerbot Monate lang und dann von heute auf morgen nicht mehr?
          Node.js: v22.23.2
          NPM: 10.9.4
          js-controller 7.1.2
          Linux: Trixie
          HomoranH AsgothianA 2 Antworten Letzte Antwort
          • DuffyD Duffy
            VG Duffy
            @duffy sagte in Zigbee Fingerbot, heute gibts kein Kaffee:
            davon hatte aber niemand etwas gesagt!
            nicht github, sondern
            @asgothian sagte in Zigbee Fingerbot, heute gibts kein Kaffee:
              DuffyD Offline
              DuffyD Offline
              Duffy
              Das war ja genau mein Problem was ich hatte ;-( ich weis nicht wie aber die 1.10.14 habe ich trotzdem drauf? Zufall?
              Verrätst mir bitte wie das mit der Latest geht?
              Node.js: v22.23.2
              NPM: 10.9.4
              js-controller 7.1.2
              Linux: Trixie
              • DuffyD Duffy
                @duffy sagte in Zigbee Fingerbot, heute gibts kein Kaffee [gel.]:
                entweder umschalten des Repos mit anschließendem Neuladen der Adapterliste
                oder über die "böse" Katze und dort dem ersten Reiter (npm)
                  DuffyD Offline
                  DuffyD Offline
                  Duffy
                  @homoran sagte in Zigbee Fingerbot, heute gibts kein Kaffee [gel.]:
                  Also auf Beta?
                  Jetzt wird bei mir da vermutlich nichts mehr kommen weil ich ja schon die 1.10.14 drauf habe oder?
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  • DuffyD Duffy
                    Also auf Beta?
                    Also auf Beta?
                    ja!
                    "latest" war die frühere Bezeichnung und ist noch weit verbreitet.
                    oder
                    ja!
                    DuffyD 2 Antworten Letzte Antwort
                      Also auf Beta?
                      ja!
                      oder
                      ja!
                      DuffyD Offline
                      DuffyD Offline
                      Duffy
                      Ich bin zu doof dafür.
                      Ich habe jetzt auf Beta umgestellt und es zeigt mir 14 mögliche Updates an.
                      Zigbee aber nicht mehr. Ok, ist ja schon installiert.
                      Aber wie um alles in der Welt könnte ich jetzt beispielsweise den Alexa Adapter von 3.26.5 auf 3.26.7 heben?
                      Man ist das kompliziert ;-(
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                      GaspodeG HomoranH 2 Antworten Letzte Antwort
                      • DuffyD Duffy
                        GaspodeG Offline
                        GaspodeG Offline
                        Gaspode
                        @duffy said in Zigbee Fingerbot, heute gibts kein Kaffee [gel.]:
                        Hast du im Admin auf "Adapter auf Updates überprüfen" geklickt?
                        • GaspodeG Gaspode
                          DuffyD Offline
                          DuffyD Offline
                          Duffy
                          @gaspode
                          Ja, deshalb kamen ja die Vorschläge welche Adapter aktualisiert werden könnten (als Latest)
                          Nur dann weis ich nicht mehr weiter.
                          Inzwischen geht es ja eher um das, wie installiert man ein Latest (wenn man es nicht über npm macht)
                          weil der Zigbee Adapter ja jetzt schon installiert ist.
                          Um beim Beispiel vom Alexa Adapter zu bleiben, wo müsste ich da klicken um die Latset Version installiert zu bekommen?
                          Ich finde auch nichts hier im Forum wie man das macht und ein Link von @Homoran von 2019 funktioniert nicht mehr.
                          Gruß Duffy
                          Node.js: v22.23.2
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
                          GaspodeG 1 Antwort Letzte Antwort
                          • DuffyD Duffy
                            @gaspode
                            Gruß Duffy
                            GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            schrieb am zuletzt editiert von Gaspode
                            Das sieht in der Adapterliste das Admins normalerweise so aus:
                            Irgendwie ist deine Ansicht da ziemlich lückenhaft. Mal mit F5 oder in hartnäckigen Fällen Strg + F5 die Browser-Ansicht aktualisiert?
                            • DuffyD Duffy
                              Warum willst du das?
                              Willst du stabile Adapter haben, oder willst du Betatester für neue Versionen sein?
                              Schalt das Repo zurück auf stable und lade die Adapterliste noch mal neu!
                              • DuffyD Duffy
                                VG Duffy
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                VG Duffy
                                Du hattest eine 1.10.13 von Github oder eine 1.10.3 aus dem Stable laufen.
                                Seitens der zigbee-herdsman-converters Bibliothek war eine Änderung gemacht worden, die zu dem Absturz führt. diesen habe ich nach Umstellen auf die neue Bibliothek behoben - allerdings war da die GitHub version schon auf npm veröffentlicht, weswegen meine Änderungen nicht mehr in der aktuellen 1.10.13 Stable enthalten sind.
                                die 1.10.14 aus dem Latest hat die dann wieder.
                                A.
                                • BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  Welches Fingerbot hast du denn / Bezugsquelle?
                                  Ich hatte vor ein paar Monaten auch ZigBee-Fingerbots bestellt - bei denen sich herausstellte das diese in Wirklichkeit nur Bluetooth können und nur an einem Tuya-Zigbee-Smartgateway funktionieren - welches auch Bluetooth kann.
                                  • GaspodeG Gaspode
                                    DuffyD Offline
                                    DuffyD Offline
                                    Duffy
                                    @gaspode
                                    Ich habe jetzt wieder auf Stablke gestellt jetzt sieht es deinem Screenshot etwas ähnlicher:
                                    Leider zeigt es bei mir nicht die 3.26.7 an.
                                    Nicht das ich die jetzt bei Alexa2 bräuchte mir geht es nur um das Verständnis wie man die Latest installiert.
                                    Node.js: v22.23.2
                                    NPM: 10.9.4
                                    js-controller 7.1.2
                                    Linux: Trixie
                                    • DuffyD Duffy
                                      @gaspode
                                      Entweder das entsprechende Repository solo freischalten (nicht stable und Beta gleichzeitig betreiben, gibt nur Chaos) oder bei aktivem stable aus dem Reiter npm installieren. Allerdings setzt das voraus, das es auch schon ein stabiles Release gibt.
                                        DuffyD Offline
                                        DuffyD Offline
                                        Duffy
                                        Ich will eigentlich nur die Stable haben, wird hier im Forum ja auch immer angeraten und ich halte mich in der Regel daran.
                                        Es war jetzt nur die Ausnahme wegen meinem Fingerbot.
                                        (Denke als Betatester wäre ich mehr als ungeignet 👎 )
                                        "Schalt das Repo zurück auf stable und lade die Adapterliste noch mal neu!"
                                        Habe ich gemacht und die sieht jetzt so aus:
                                        Node.js: v22.23.2
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          @gaspode
                                          Natürlich nicht!
                                          die 26.7 ist auch nicht stable
                                          das hatten wir doch vorhin:
                                          aber nochmal:
