  4. Script wird immer mehr verzögert ausgeführt
    5.1k
21 Beiträge 6 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • S stein
    @ro75 so, ich dachte erst das Problem sei weg mit dem kräftigeren NUC, aber es dauert nun einfach nur länger bis es auftritt. Hier hob drag in der Langfassung:
    Script v.2024-10-19
    *** BASE SYSTEM ***
    Hardware Vendor : Hyrican Informationssysteme AG
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v10.0.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     22:49:38 up 21 days, 14:47,  0 user,  load average: 0.40, 0.43, 0.55
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
    Fri Nov 29 21:49:38 UTC 2024
    Fri Nov 29 22:49:39 CET 2024
    CET +0100
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.2G        3.7G        1.2G         17M        3.6G        4.5G
    Swap:           4.3G        289M        4.0G
    Total:           12G        4.0G        5.2G
    Active iob-Instances:   22
             7831 M total memory
             3533 M used memory
             3398 M active memory
             2491 M inactive memory
             1176 M free memory
              630 M buffer memory
             2818 M swap cache
             4095 M total swap
              276 M used swap
             3819 M free swap
    top - 22:49:39 up 21 days, 14:47,  0 user,  load average: 0.40, 0.43, 0.55
    Tasks:  32 total,   1 running,  31 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7831.5 total,   1176.2 free,   3533.8 used,   3448.7 buff/cache
    MiB Swap:   4096.0 total,   3819.5 free,    276.5 used.   4297.7 avail Mem
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                        Type     Size  Used Avail Use% Mounted on
    overlay                           overlay  479G   35G  425G   8% /
    tmpfs                             tmpfs     64M     0   64M   0% /dev
    shm                               tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4     479G   35G  425G   8% /opt/iobroker
    tmpfs                             tmpfs    3.9G     0  3.9G   0% /proc/asound
    tmpfs                             tmpfs    3.9G     0  3.9G   0% /proc/acpi
    tmpfs                             tmpfs    3.9G     0  3.9G   0% /proc/scsi
    tmpfs                             tmpfs    3.9G     0  3.9G   0% /sys/firmware
    tmpfs                             tmpfs    3.9G     0  3.9G   0% /sys/devices/virtual/powercap
    Show mounted filesystems:
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/volumes/smarthome_iobroker_data/_data]                                                   ext4   rw,relatime
    /etc/resolv.conf /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/64e43fe8d8457e655b28afd933c97c3086873d873f49f391b66b4cc891120a53/resolv.conf] ext4   rw,relatime
    /etc/hostname    /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/64e43fe8d8457e655b28afd933c97c3086873d873f49f391b66b4cc891120a53/hostname]    ext4   rw,relatime
    /etc/hosts       /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/64e43fe8d8457e655b28afd933c97c3086873d873f49f391b66b4cc891120a53/hosts]       ext4   rw,relatime
    /var:
    35M     /var/
    33M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    14M     /var/lib/dpkg
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    758M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    14M     /opt/iobroker/iobroker-data/states.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
         20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
     *** 20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    64e43fe8d845        64e43fe8d845 (version: 7.0.3, hostname: 64e43fe8d845  , alive, uptime: 677)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : 64e43fe8d845                             -  enabled, port: 443, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.daswetter.0              : daswetter             : 64e43fe8d845                             -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : 64e43fe8d845                             -  enabled
      system.adapter.discovery.0              : discovery             : 64e43fe8d845                             - disabled
    + system.adapter.homeconnect.0            : homeconnect           : 64e43fe8d845                             -  enabled
      system.adapter.ical.0                   : ical                  : 64e43fe8d845                             -  enabled
    + system.adapter.influxdb.0               : influxdb              : 64e43fe8d845                             -  enabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : 64e43fe8d845                             - disabled
    + system.adapter.javascript.0             : javascript            : 64e43fe8d845                             -  enabled
    + system.adapter.javascript.1             : javascript            : 64e43fe8d845                             -  enabled
    + system.adapter.modbus.0                 : modbus                : 64e43fe8d845                             -  enabled
    + system.adapter.modbus.1                 : modbus                : 64e43fe8d845                             -  enabled
    + system.adapter.modbus.2                 : modbus                : 64e43fe8d845                             -  enabled
      system.adapter.modbus.3                 : modbus                : 64e43fe8d845                             - disabled
    + system.adapter.mqtt.0                   : mqtt                  : 64e43fe8d845                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.openknx.0                : openknx               : 64e43fe8d845                             -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : 64e43fe8d845                             -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : 64e43fe8d845                             -  enabled
    + system.adapter.pvforecast.2             : pvforecast            : 64e43fe8d845                             -  enabled
    + system.adapter.shelly.0                 : shelly                : 64e43fe8d845                             -  enabled, port: 1882, bind: 10.11.5.250
    + system.adapter.signal-cmb.0             : signal-cmb            : 64e43fe8d845                             -  enabled
    + system.adapter.telegram.0               : telegram              : 64e43fe8d845                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : 64e43fe8d845                             -  enabled
    + system.adapter.tuya.0                   : tuya                  : 64e43fe8d845                             -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : 64e43fe8d845                             -  enabled
      system.adapter.web.0                    : web                   : 64e43fe8d845                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : 64e43fe8d845                             -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
    Adapter    "openknx"      : 0.9.0    , installed 0.9.0
    Adapter    "pvforecast"   : 3.0.0    , installed 4.0.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects:        18611
    States:         18001
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 31
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       88708202   -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       88708233   -
    tcp        0      0 0.0.0.0:44439           0.0.0.0:*               LISTEN      1000       88711056   -
    tcp        0      0 127.0.0.1:43901         0.0.0.0:*               LISTEN      1000       88711060   -
    tcp        0      0 127.0.0.11:40619        0.0.0.0:*               LISTEN      0          88702878   -
    tcp        0      0 10.11.5.250:1882        0.0.0.0:*               LISTEN      1000       88711495   -
    tcp6       0      0 :::443                  :::*                    LISTEN      1000       88706672   -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        88706593   -
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       88711611   -
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       88711612   -
    udp        0      0 127.0.0.11:52655        0.0.0.0:*                           0          88702877   -
    udp        0      0 0.0.0.0:40425           0.0.0.0:*                           1000       88711408   -
    udp        0      0 0.0.0.0:36812           0.0.0.0:*                           103        88706595   -
    udp6       0      0 :::5353                 :::*                                103        88706594   -
    udp6       0      0 :::48027                :::*                                103        88706596   -
    2024-11-06 21:53:59.088  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40542_Heatsink_Temperature to buffer again, error-count=2
    2024-11-06 21:53:59.123  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.123  - warn: influxdb.0 (241) Error on writePoint("{"value":25,"time":"2024-11-06T20:53:47.809Z","from":"system.adapter.modbus.1","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.123  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40541_Transformator_Temperature to buffer again, error-count=2
    2024-11-06 21:53:59.202  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.202  - warn: influxdb.0 (241) Error on writePoint("{"value":4286,"time":"2024-11-06T20:53:47.867Z","from":"system.adapter.modbus.1","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.203  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40620_Grid_power_total to buffer again, error-count=2
    2024-11-06 21:53:59.255  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.255  - warn: influxdb.0 (241) Error on writePoint("{"value":24,"time":"2024-11-06T20:53:47.809Z","from":"system.adapter.modbus.1","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.256  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40587_Battery_Temperature to buffer again, error-count=2
    2024-11-06 21:53:59.304  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.304  - warn: influxdb.0 (241) Error on writePoint("{"value":0,"time":"2024-11-06T20:53:47.869Z","from":"system.adapter.modbus.1","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.304  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40674_PV_input_power_west to buffer again, error-count=2
    2024-11-06 21:53:59.347  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.347  - warn: influxdb.0 (241) Error on writePoint("{"value":0,"time":"2024-11-06T20:53:47.869Z","from":"system.adapter.modbus.1","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.347  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40673_PV_input_power_east to buffer again, error-count=2
    2024-11-06 21:53:59.438  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.439  - warn: influxdb.0 (241) Error on writePoint("{"value":4143,"time":"2024-11-06T20:53:47.869Z","from":"system.adapter.modbus.1","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.439  - info: influxdb.0 (241) Add point that had error for modbus.1.holdingRegisters.40654_Load_Power_Total to buffer again, error-count=2
    2024-11-06 21:53:59.446  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.447  - warn: influxdb.0 (241) Error on writePoint("{"value":0,"time":"2024-11-06T20:53:45.713Z","from":"system.adapter.modbus.0","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.448  - info: influxdb.0 (241) Add point that had error for modbus.0.inputRegisters.38001_Leistungsvorgabe-Verdichter to buffer again, error-count=2
    2024-11-06 21:53:59.570  - warn: influxdb.0 (241) Point could not be written to database: iobroker
    2024-11-06 21:53:59.571  - warn: influxdb.0 (241) Error on writePoint("{"value":0,"time":"2024-11-06T20:53:45.714Z","from":"system.adapter.modbus.0","q":0,"ack":true}): Error: getaddrinfo ENOTFOUND influxdbbackend / "getaddrinfo ENOTFOUND influxdbbackend""
    2024-11-06 21:53:59.571  - info: influxdb.0 (241) Add point that had error for modbus.0.inputRegisters.38002_Heiz-Kuehlleistung-Gemessen to buffer again, error-count=2
    HomoranH Offline
    HomoranH Offline
    @stein sagte in Script wird immer mehr verzögert ausgeführt:
    was feuert denn da im Millisekundentakt in die influxDB?
    Dazu noch mit Fehlern?
      stein
      @homoran das sind werte aus dem Wechselrichter, der Fehler war am 06.11. da war der influx host kurz down. Das ist im Millisekunden Takt weil es halt verschiedene Werte sind die per Modbus mit Millisekunden Abstand rein kommen. Der Zyklus ist aber immer >10 Sekunden und das wird auch nur sehr gefiltert in die DB geschrieben (z.B. nur wenn sich der Wert um eine gewisse Spanne verändert hat).
      • S stein
        HomoranH Offline
        HomoranH Offline
        @stein OK, wenn das nicht zur Verzögerung geführt hat sehe ich nichts bösartiges.
        Lediglich um
        Pending Updates: 31
        solltest du dich auf jeden Fall kümmern
          stein
          @homoran Das kann ich machen, aber der Container ist auch keine 3 Wochen alt. Das wird nichts kritisches sein.
          Fällt irgendjemanden eine Queue ein die mit der Zeit vorlaufen könnte und daher diese steigende Verzögerung auslösen könnte? Sonst ist meine letzte Lösung ein cron der iobroker einmal die Woche neustartet 😵
          • S stein
            T Nicht stören
            T Nicht stören
            ticaki
            @stein
            Ich weiß ja nicht was sonst da noch läuft. Ich habe die Tage mein Timemaschine Backup auf einen Sambacontrainer(PVE) beendet weil es den io Delay auf 70%-90% hoch gejagt hat und die Downzeit des iobrokers beim Backup von 10-20 Sekunden auf 20-30 Minuten erhöht hat und das mit steigender Tendenz.
            Aber der iobroker an sich war auch zickig in dem Zeitraum.
            EDIT: influx kannst du aber so einstellen das die Werte gesammelt werden. Die werden dann als Block mit den jeweiligen Aktualisierungszeiten geschrieben.
            Ach bei ^da oben war die Auslastung vom System und der einzelnen Container unauffällig nur der io Delay war sehr hoch.
            Spenden
            • T ticaki
              @stein
              stein
              @ticaki influx hab ich jetzt mal auf schreiben alle 60sekunden umgestellt. Ich glaube ich bin blind, wo hast du io Delay gefunden?
              • S stein
                T Nicht stören
                T Nicht stören
                ticaki
                @stein
                Ich benutze Proxmox und da gibt es diese Anzeige. Die hat nichts mit iobroker zu tun.
                Spenden
                  stein
                  Also, das Problem besteht noch. Das Buffern vom influx hat es gefühlt verlängert bis es auftritt, aber bestehen tut es noch. Auslastung der Maschine jetzt bei <25% (meist <10%)
                  • S stein
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    @stein
                    Das hätte ich wohl zu erst fragen sollen, aber was meinst du mit verzögert? Regieren die Skripte verzögert auf Trigger ereignisse? Oder fängt der schedule an nach zu laufen?
                    Bei Triggern schon mal geprüft ob es tatsächlich eine verzögerung gibt zwischen dem umschalten des States und der ausführung des skripts?
                    Spenden
                      stein
                      schrieb am zuletzt editiert von stein
                      Oh man, ich schäme mich ein bisschen, ich habe grade den Verdacht dass es der openknx adapter ist. Wenn ich einen state von hand (ohne script) änder dauert es auch einige Sekunden bis der state sich ändert. Andersrum kommen aber state Änderungen auf dem bus sofort im iobroker an.
                      Sehe jetzt auch dass die geschrieben states vom iobroker auf dem openknx adapter sehr lange noch rot, also nicht acknowledged sind. Das wird mein Problem sein. Aber warum ist das wohl so?
                      • S stein
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        Mach nen neuen Thread auf, KNX ist was ganz anderes als Skripte und dafür brauchst du die Aufmerksamkeit von anderen Leuten, verlinke dann auf den hier.
                        Ich hab davon keine Ahnung :)
                        Spenden
