  4. Bluelink Anfragen überschreiten Limit / Sperrung
    1.0k
    6.1k
28 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
    @hammerhead86
    ok, keine Daten, kein Support. Ich bin raus.
    hammerhead86
    @ilovegym
    Sorry, hat etwas gedauert. Vom Handy nicht so einfach, aber ich versuche euch alles zur Verfügung zu stellen.
    bash
    Script v.2024-10-26 Raspbian
    *** BASE SYSTEM ***
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to: debian
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     13:54:30 up 2 days,  2:58,  1 user,  load average: 2.07, 2.10, 2.04
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2024-11-08 13:54:30 CET
               Universal time: Fri 2024-11-08 12:54:30 UTC
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:            7.9G        3.0G        991M        3.0M        3.9G        4.9G
    Swap:            99M          0B         99M
    Total:          8.0G        3.0G        1.1G
    Active iob-Instances: 	53
             7862 M total memory
             2985 M used memory
             3766 M active memory
             2195 M inactive memory
              990 M free memory
              433 M buffer memory
             3453 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 13:54:31 up 2 days,  2:58,  1 user,  load average: 2.07,
    Tasks: 258 total,   1 running, 257 sleeping,   0 stopped,   0 z
    %Cpu(s): 23.9 us,  2.8 sy,  0.0 ni, 71.8 id,  0.0 wa,  0.0 hi,
    MiB Mem :   7862.2 total,    990.3 free,   2985.8 used,   3886.
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4883.
    *** FAILED SERVICES ***
      UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
    * media-nas\x2dalex.mount   loaded failed failed /media/nas-alex
    * media-nas\x2dbackup.mount loaded failed failed /media/nas-backup
    * nut-monitor.service       loaded failed failed Network UPS Tools - power device monitor and shutdown controller
    * nut-server.service        loaded failed failed Network UPS Tools - power devices information server
    * proftpd.service           loaded failed failed ProFTPD FTP Server
    * rc-local.service          loaded failed failed /etc/rc.local Compatibility
    6 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      118G   27G   87G  24% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
    [Wed Nov  6 10:56:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:BB:67:F0 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=8b45a858-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Nov  6 10:56:03 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Wed Nov  6 10:56:03 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Wed Nov  6 10:56:03 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Wed Nov  6 10:56:03 2024] EXT4-fs (sda2): 44 orphan inodes deleted
    [Wed Nov  6 10:56:03 2024] EXT4-fs (sda2): recovery complete
    [Wed Nov  6 10:56:03 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  6 10:56:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Nov  6 10:56:05 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    9.1G	/var/
    4.8G	/var/log
    3.9G	/var/lib
    3.8G	/var/log/journal/4ffc24f9f1764bfd9c99f9114f341977
    Archived and active journals take up 3.7G in the file system.
    /opt/iobroker/backups:
    544M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G	/opt/iobroker/iobroker-data/
    913M	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    73M	/opt/iobroker/iobroker-data/objects.jsonl
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M	/opt/iobroker/iobroker-data/states.jsonl
    27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.0
    /usr/bin/node 		v20.18.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 20984)
    Core adapters versions
    js-controller: 	6.0.11
    admin: 		7.1.5
    javascript: 	8.8.3
    nodejs modules from github: 	5
    +-- iobroker.blockly-plus@0.0.1 (git+ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git#8487239d69fc53c13853013110da15b42bc487e9)
    +-- iobroker.fitbit-fitness@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.fitbit-fitness.git#36a426abe0f6999aed316dd1bc6aba0d21150f4a)
    +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
    +-- iobroker.parcel@0.2.7 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#a9656c8ef3d0e85a75d911c9392440e98e13b958)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker-pi                              -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker-pi                              -  enabled
    + system.adapter.asterisk.0               : asterisk              : iobroker-pi                              -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      system.adapter.blockly-plus.0           : blockly-plus          : iobroker-pi                              -  enabled
    + system.adapter.bluelink.0               : bluelink              : iobroker-pi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker-pi                              -  enabled
      system.adapter.devices.0                : devices               : iobroker-pi                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-pi                              - disabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker-pi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker-pi                              -  enabled
    + system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobroker-pi                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : iobroker-pi                              -  enabled
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker-pi                              -  enabled
    + system.adapter.hass.0                   : hass                  : iobroker-pi                              -  enabled, port: 8123
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker-pi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-pi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker-pi                              -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobroker-pi                              -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker-pi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-pi                              -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker-pi                              -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker-pi                              -  enabled
      system.adapter.octoprint.0              : octoprint             : iobroker-pi                              - disabled
    + system.adapter.operating-hours.0        : operating-hours       : iobroker-pi                              -  enabled
    + system.adapter.parcel.0                 : parcel                : iobroker-pi                              -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
    + system.adapter.places.0                 : places                : iobroker-pi                              -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker-pi                              -  enabled
    + system.adapter.pushover.1               : pushover              : iobroker-pi                              -  enabled
    + system.adapter.reolink.0                : reolink               : iobroker-pi                              -  enabled
      system.adapter.ring.0                   : ring                  : iobroker-pi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
    + system.adapter.samsung.0                : samsung               : iobroker-pi                              -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-pi                              - disabled, port: 8002
    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker-pi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : iobroker-pi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
      system.adapter.terminal.0               : terminal              : iobroker-pi                              - disabled, port: 8432, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : iobroker-pi                              -  enabled
    + system.adapter.tr-064.2                 : tr-064                : iobroker-pi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker-pi                              -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
    + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : iobroker-pi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.88:20108
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa-timer-vis": 2.0.5  , installed 2.0.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "bluelink"     : 2.3.6    , installed 3.1.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fitbit-fitness": 0.5.0   , installed 0.5.0
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "operating-hours": 1.1.0  , installed 1.1.0
    Adapter    "places"       : 1.2.0    , installed 1.2.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "ring"         : 6.2.1    , installed 6.2.1
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wled"         : 0.7.2    , installed 0.7.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects: 	21627
    States: 	16224
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://repos.influxdata.com/debian bullseye InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://download.docker.com/linux/raspbian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Get:7 https://pkgs.tailscale.com/stable/raspbian bullseye InRelease
    Fetched 6581 B in 2s (3663 B/s)
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       44474748   14225/nc
    tcp        0      0 192.168.178.128:2010    0.0.0.0:*               LISTEN      1001       39683014   29570/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       39684343   28812/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       39688140   29674/io.shelly.1
    tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      0          17363      1408/docker-proxy
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15515      507/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          19115      1384/docker-proxy
    tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      0          16312      1431/docker-proxy
    tcp        0      0 100.89.213.39:51228     0.0.0.0:*               LISTEN      0          37863      390/tailscaled
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      112        15844      661/asterisk
    tcp        0      0 0.0.0.0:9009            0.0.0.0:*               LISTEN      0          16325      1473/docker-proxy
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       39676781   27835/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       39677715   27835/iobroker.js-c
    tcp        0      0 192.168.178.128:3493    0.0.0.0:*               LISTEN      0          114518     31987/upsd
    tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1000       1816       463/transmission-da
    tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          17371      1427/docker-proxy
    tcp        0      0 0.0.0.0:51413           0.0.0.0:*               LISTEN      1000       1817       463/transmission-da
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        16389      676/influxd
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          114527     31987/upsd
    tcp6       0      0 fd7a:115c:a1e0:ab:51228 :::*                    LISTEN      0          37864      390/tailscaled
    tcp6       0      0 :::8444                 :::*                    LISTEN      0          19200      1428/docker-proxy
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15517      507/sshd: /usr/sbin
    tcp6       0      0 :::8888                 :::*                    LISTEN      0          17346      1392/docker-proxy
    tcp6       0      0 :::8880                 :::*                    LISTEN      0          16319      1475/docker-proxy
    tcp6       0      0 :::9009                 :::*                    LISTEN      0          17797      1504/docker-proxy
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       39723099   409/io.lovelace.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       39680093   27855/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39689513   29988/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       39721333   3820/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       39692579   30059/io.simple-api
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        33794      676/influxd
    tcp6       0      0 :::8000                 :::*                    LISTEN      0          17781      1436/docker-proxy
    tcp6       0      0 :::51413                :::*                    LISTEN      1000       1819       463/transmission-da
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        33850      2357/grafana
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       39684320   28543/io.nuki-exten
    udp        0      0 0.0.0.0:49099           0.0.0.0:*                           108        1654       370/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14664      652/dhcpcd
    udp        0      0 100.89.213.39:123       0.0.0.0:*                           109        44040      499/ntpd
    udp        0      0 169.254.65.18:123       0.0.0.0:*                           109        32228      499/ntpd
    udp        0      0 169.254.17.3:123        0.0.0.0:*                           109        32226      499/ntpd
    udp        0      0 169.254.148.181:123     0.0.0.0:*                           109        32224      499/ntpd
    udp        0      0 169.254.191.119:123     0.0.0.0:*                           109        32222      499/ntpd
    udp        0      0 192.168.178.128:123     0.0.0.0:*                           109        32219      499/ntpd
    udp        0      0 172.17.0.1:123          0.0.0.0:*                           109        22330      499/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          14553      499/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          14548      499/ntpd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       39684955   28955/io.mihome-vac
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           112        15877      661/asterisk
    udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          43584859   390/tailscaled
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           112        15879      661/asterisk
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       44034870   21854/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1652       370/avahi-daemon: r
    udp        0      0 0.0.0.0:58636           0.0.0.0:*                           112        16779      661/asterisk
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       39686344   28987/io.shelly.0
    udp        0      0 0.0.0.0:51413           0.0.0.0:*                           1000       1820       463/transmission-da
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       39679912   28476/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       39679913   28476/io.tuya.0
    udp6       0      0 :::40802                :::*                                108        1655       370/avahi-daemon: r
    udp6       0      0 2001:9e8:4b3e:2000::123 :::*                                109        42030720   499/ntpd
    udp6       0      0 fd7a:115c:a1e0:ab12:123 :::*                                109        44052      499/ntpd
    udp6       0      0 fe80::98b5:19ff:fef:123 :::*                                109        22350      499/ntpd
    udp6       0      0 fe80::d1ed:2278:73e:123 :::*                                109        22348      499/ntpd
    udp6       0      0 fe80::30ac:e7ff:fe5:123 :::*                                109        22346      499/ntpd
    udp6       0      0 fe80::8c53:510f:ac9:123 :::*                                109        22344      499/ntpd
    udp6       0      0 fe80::64b7:26ff:fe5:123 :::*                                109        22342      499/ntpd
    udp6       0      0 fe80::7078:3680:6fe:123 :::*                                109        22340      499/ntpd
    udp6       0      0 fe80::b25d:49c0:1cb:123 :::*                                109        22338      499/ntpd
    udp6       0      0 fe80::42:f8ff:fe14::123 :::*                                109        22336      499/ntpd
    udp6       0      0 fe80::d910:e3d4:a93:123 :::*                                109        15724      499/ntpd
    udp6       0      0 fe80::d50b:f842:242:123 :::*                                109        14653      499/ntpd
    udp6       0      0 ::1:123                 :::*                                0          14555      499/ntpd
    udp6       0      0 :::123                  :::*                                0          14545      499/ntpd
    udp6       0      0 :::546                  :::*                                0          14127      652/dhcpcd
    udp6       0      0 :::41641                :::*                                0          43584856   390/tailscaled
    udp6       0      0 :::5353                 :::*                                108        1653       370/avahi-daemon: r
    udp6       0      0 :::44082                :::*                                112        16780      661/asterisk
    2024-11-08 13:29:50.977  - info: host.iobroker-pi iobroker Installing iobroker.wled@0.7.3... (System call)
    2024-11-08 13:30:00.036  - warn: host.iobroker-pi instance system.adapter.device-watcher.0 already running with pid 28972
    2024-11-08 13:30:13.513  - info: host.iobroker-pi iobroker added 1 package, and changed 3 packages in 22s
    2024-11-08 13:30:13.515  - info: host.iobroker-pi iobroker
    2024-11-08 13:30:13.520  - info: host.iobroker-pi iobroker 204 packages are looking for funding  run `npm fund` for details
    2024-11-08 13:30:13.933  - info: host.iobroker-pi iobroker Update "system.adapter.wled.0"
    2024-11-08 13:30:13.962  - info: host.iobroker-pi stopInstance system.adapter.wled.0 (force=false, process=true)
    2024-11-08 13:30:14.192  - info: host.iobroker-pi stopInstance system.adapter.wled.0 send kill signal
    2024-11-08 13:30:14.976  - info: host.iobroker-pi instance system.adapter.wled.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-08 13:30:15.143  - info: host.iobroker-pi iobroker upload [7] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/admin.d.ts admin.d.ts video/mp2t
    2024-11-08 13:30:15.182  - info: host.iobroker-pi iobroker upload [6] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/button.png button.png image/png
    2024-11-08 13:30:15.204  - info: host.iobroker-pi iobroker upload [5] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/index_m.html index_m.html text/html
    2024-11-08 13:30:15.216  - info: host.iobroker-pi iobroker upload [4] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/style.css style.css text/css
    2024-11-08 13:30:15.243  - info: host.iobroker-pi iobroker upload [3] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled.png wled.png image/png
    2024-11-08 13:30:15.265  - info: host.iobroker-pi iobroker upload [2] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled_large.png wled_large.png image/png
    2024-11-08 13:30:15.290  - info: host.iobroker-pi iobroker upload [1] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/wled_logo_akemi.png wled_logo_akemi.png image/png
    2024-11-08 13:30:15.305  - info: host.iobroker-pi iobroker upload [0] wled.admin /opt/iobroker/node_modules/iobroker.wled/admin/words.js words.js application/javascript
    2024-11-08 13:30:16.373  - info: host.iobroker-pi iobroker exit 0
    2024-11-08 13:30:18.941  - info: host.iobroker-pi instance system.adapter.wled.0 in version "0.7.3" started with pid 21854
    2024-11-08 13:31:33.703  - info: admin.0 (27855) <== Disconnect system.user.admin from ::ffff:192.168.178.2 admin
    2024-11-08 13:31:44.261  - info: admin.0 (27855) ==> Connected system.user.admin from ::ffff:192.168.178.2
    2024-11-08 13:32:10.853  - info: admin.0 (27855) <== Disconnect system.user.admin from ::ffff:192.168.178.2 admin
    2024-11-08 13:44:14.576  - warn: places.0 (29695) Found a newer place for this user: skipping update
    2024-11-08 13:45:00.028  - warn: host.iobroker-pi instance system.adapter.device-watcher.0 already running with pid 28972
    2024-11-08 13:54:27.102  - warn: places.0 (29695) Found a newer place for this user: skipping update
    H HomoranH 2 Antworten Letzte Antwort
    • H hammerhead86
      @ilovegym
      bash
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7862 M total memory
               2985 M used memory
                990 M free memory
                433 M buffer memory
               3453 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      9.1G	/var/
      4.8G	/var/log
      3.9G	/var/lib
      USB-Devices by-id:
      HINT:
      tcp
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.1.5
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	21627
      States: 	16224
      Pending Updates: 4
      hammerhead86
      diag.log
      Hier als Datei. Ist vielleicht besser zur Diagnose
        @hammerhead86 sagte in Bluelink Anfragen überschreiten Limit / Sperrung:
        Da die Zeile aber direkt verschwindet,
        Die Eingabezeile verschwindet?
        das ist nicht üblich!
        Was ist das für ein Terminalprogramm?
        immerhin sehe ich jetzt den Folgeprompt.
        Ist das ein Raspberry?
        dann mach mal
        curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
        chmod 744 iob_diag.sh
        ./iob_diag.sh
        und poste das vollständige Ergebnis
        hammerhead86
        @homoran sagte in Bluelink Anfragen überschreiten Limit / Sperrung:
        dann mach mal
        ./iob_diag.sh
        Danke für den Tipp.
        Hat funktioniert (siehe vorheriger Beitrag)
        • H hammerhead86
          dann mach mal
          ./iob_diag.sh
          Danke für den Tipp.
          @hammerhead86
          Dein Dateisystem ist wurmstichig.
          • H hammerhead86
            dann mach mal
            ./iob_diag.sh
            Danke für den Tipp.
            @hammerhead86
            Neben dem wurmstichigen Dateisystem:
            Kernel : aarch64
            Userland : 32 bit
            Mix aus 64Bit-Kernel und 32Bit Userland.
            Installier da komplett NEU Debian 12 'Bookworm'.
            Dann auch direkt mit individuellem User, nicht 'pi', nicht 'iobroker', nicht 'root', nicht 'admin' oder sowas. Vorname oder Forumsnick ist besser.
            Vielleicht erledigen sich damit auch die 6 'failed services'.
            Dateisystem hatten wir ja schon:
            Bei iobroker.blockly-plus weiß ich gar nicht, ob das noch kompatibel zum aktuellen js-script-Adapter ist. Im Zweifel rauskicken.
            • H Offline
              hammerhead86
              Was meint ihr mit wurmstichig? 🫣
              Der Raspi ist mittlerweile 3 Jahre online und da war der Pi-nutzer noch Standard.
              Von den Services konnte ich immerhin drei korrigieren. (Hab nen neues NAS eingerichtet und das mounten hat nicht ganz funktioniert)
              An der Nut Geschichte hänge ich noch dran. Läuft aber komischerweise.
              Proftpd hab ich eigentlich deinstalliert, scheint aber noch irgendwo zu schlummern.
              Die Userland Geschichte ist mir zu hoch. Versteh ich nicht 🫣
              Ja....das Bookworm Update sollte ich mal machen 😕
              Schon krass, was man über iob diag so mal eben über sein System erfährt.
              Vielen Dank euch für die Tipps 👍
              By the way.... Bluelink scheint nach Neuinstallation (im Moment) zu funktionieren
              • H hammerhead86
                @ilovegym
                bash
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 32 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: n/a
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         7862 M total memory
                         2985 M used memory
                          990 M free memory
                          433 M buffer memory
                         3453 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                /var:
                9.1G	/var/
                4.8G	/var/log
                3.9G	/var/lib
                USB-Devices by-id:
                HINT:
                tcp
                /usr/bin/npm 		10.8.2
                /usr/bin/npx 		10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin: 		7.1.5
                javascript: 	8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	21627
                States: 	16224
                Pending Updates: 4
                wie schon @Thomas-Braun schrieb
                @thomas-braun sagte in Bluelink Anfragen überschreiten Limit / Sperrung:
                @hammerhead86
                und zwar deutlich!
                Man kann nicht mehr nachvollziehen welche Dateien davon betroffen sind.
                Da ist alles möglich. Nur kein sinnvolles Arbeiten mehr.
                Eine saubere Neuinstallation auf einer neuen Karte ist da die einzig reelle Option.
                • H hammerhead86
                  RaspberryOS hat mal mit irgendeinem Update angefangen auf reinen 32Bit-Kisten einen 64Bit-Kernel zu installieren. Kann man machen, ist aber höchstens halbgesprungen. Ein richtiges 64Bit-System bekommst du nur per Neuinstallation hin. Ebenso wie einen Switch auf Raspberry 12 'Bookworm'.
                  Und die zerstörten inodes bekommst du auch nicht wieder. Auch hier ist eine Neuinstallation angezeigt.
                  H 1 Antwort Letzte Antwort
                    hammerhead86
                    Danke euch für die Hilfe / Ratschläge.
                    Dann werde ich mich demnächst mal da Ran setzen.
                    Entweder den Raspi5 mal auspacken, der im Regal liegt, oder vielleicht doch Wechsel auf nen MiniPC mit proxmox.
                    Kommt Zeit kommt Rat.
                    Nochmal danke 👍
                    • H hammerhead86
                      Nochmal danke 👍
                      Demnöchst ist zu spät!
                      Jetzt ist der späteste Zeitpunkt.
                      Bei dir hat das System 44(!!!) verlorene Dateifragmente gefunden, due nicht mehr wiederhergestellt werden konnten.
                      Das ist eine tickende Zeitbombe!
                      Niemand kann dir sagen, welche Dateien in welchem Umfang betroffen sind.
                      Das muss umgehend neu aufgesetzt werden!
                      Hattest du (öfters) mal den Stecker im laufenden Betrieb gezogen?
                        hammerhead86
                        Da gebe ich dir natürlich Recht.
                        Vor sich her schieben macht keinen Sinn.
                        Aber ist ja auch nicht in 5 Minuten erledigt.
                        Und aktuell fehlt mir dazu echt die Zeit und die Nerven.
                        Ich hatte tatsächlich gestern einen Stromausfall. Das könnte das ganze erklären.
                        Aus mir unbekannten Gründen ist nämlich da auch die USV nicht angesprungen (die ich extra für solche Fälle angeschafft habe).
                        Oder es hängt in irgend einer Form mit dem schiefgelaufenen Mounten vom NAS zusammen.
                        Oder oder oder...
                        Ich werde es definitiv zeitnah neu aufsetzen 👍
                        • H hammerhead86
                          Oder oder oder...
                          naja, sollte unter 1h erledigt sein.
                          Aber besorg dir ne neue Karte!
                          dann kannst du übrigens jederzeit abbrechen und die alte wieder reinschieben, wenn's zeitlich nicht mehr ausgeht.
                            hammerhead86
                            Da ist von Anfang an keine Sd-Karte drin.
                            Da hab ich damals schon drauf geachtet, weil die ja gerne den Geist aufgeben.
                            Der Raspi läuft mit nem USB-SSD-Stick.
                            Aber danke für den Tipp.
                            Last but not least:
                            Ich denke mal, das ursprüngliche Thema hat sich erledigt.
                            Läuft aktuell alles wie es soll mit Bluelink und co.
                            • H hammerhead86
                              Last but not least:
                              wr sagt das?
                              laufen seit 10 Jahren bei mir auf diversen SBC nur auf SD.
                              Und das mit 60GB History
                                wr sagt das?
                                hammerhead86
                                Nunja, das liest man sehr oft in diversen Foren etc.
                                Kommt nicht von mir die Aussage.
                                Aber grade in Verbindung mit History oder InfluxDB kommen die SD-Karten angeblich oft an ihre Grenzen (irgendwas mit Schreiblimit oder so).
                                Deswegen hatte ich damals direkt auf SSD gesetzt.
                                Zumindest auf dem Raspi für Iobroker.
                                Hab noch zwei andere (Homematic und Octoprint), die haben "normale" SD Karten drin und laufen auch ohne Probleme.
