  3. Cloud Dienste
  4. Erledigt! Einige Lampen nicht mehr über iob steuerbar
    6.4k
39 Beiträge 3 Kommentatoren 4.5k Aufrufe 2 Beobachtet
  • tiobbT tiobb
    vielleicht kannst Du damit etwas anfangen?
    2024-11-07 11:46:06.336  - debug: yeelight-2.0 (4680) ERROR YEELIGHT CONNECTION: 0x000000000000001: Connection 192.168.178.34:5544: Error: connect ECONNREFUSED 192.168.178.34:5544
    2024-11-07 11:46:06.632  - debug: yeelight-2.0 (4680) ERROR YEELIGHT CONNECTION: null: SyntaxError: Unexpected token  in JSON at position 0: �F
    2024-11-07 11:46:06.801  - warn: shelly.0 (876) [authEnabled] 192.168.178.5 (shellyswitch25 / shellyswitch25-E8DB84A00809 / SHSW-25#E8DB84A00809#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-11-07 11:46:07.086  - debug: yeelight-2.0 (4680) ERROR YEELIGHT CONNECTION: 0x000000000000003: Connection 192.168.178.32:5544: Error: connect ECONNREFUSED 192.168.178.32:5544
    2024-11-07 11:46:07.232  - debug: yeelight-2.0 (4680) RESPONSE MESSAGE: from: 0x000000000000004, id: 3, result:[off,100,16711680,2,4000]}
    2024-11-07 11:46:07.233  - debug: yeelight-2.0 (4680) DEVICE FOUND IN CONFIG: {"name":"Ecklampe2","ip":"192.168.178.","port":"55443","smart_name":"","type":"color","id":"0x000000000000004","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2024-11-07 11:46:07.529  - debug: yeelight-2.0 (4680) ERROR YEELIGHT CONNECTION: 0x000000000000005: Connection 192.168.178.44:55443: Error: connect ECONNREFUSED 192.168.178.44:5544
    2024-11-07 11:46:07.844  - debug: yeelight-2.0 (4680) RESPONSE MESSAGE: from: 0x000000000000006, id: 3, result:[off,22,16711680,2,2200]}
    2024-11-07 11:46:07.846  - debug: yeelight-2.0 (4680) DEVICE FOUND IN CONFIG: {"name":"Sofa","ip":"192.168.178.4","port":"55443","smart_name":"","type":"color","id":"0x000000000000006","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2024-11-07 11:46:08.133  - debug: yeelight-2.0 (4680) ERROR YEELIGHT CONNECTION: 0x000000000000007: Connection 192.168.178.38:55443: Error: connect ECONNREFUSED 192.168.178.38:5544
    @tiobb sagte in Einige Lampen nicht mehr über iobroker steuerbar:
    hier steht ja die volle IP und dass die Lampe die Verbindung ablehnt.
    Wieso ein anderer Port?
    irgendwas stimmt mit deinem Token wohl nicht
    tiobbT 1 Antwort Letzte Antwort
      tiobbT Offline
      tiobbT Offline
      tiobb
      Oh, die hab ich übersehen. Aber nun weiß ich ja das ich sie besser nicht gekürzt hätte.
      Ich habe an den Ports nichts verändert, wie gesagt, ich hatte nur die Fritzbox neu eingerichtet und danach viel mir halt auf das einige Lampen die per Bewegungsmelder geschaltet werden nicht mehr funktionieren, und dann habe ich gesehen das ich mehrere Leuchtmittel nicht mehr über die Objekte ansteuern kann. Ecklampe1 ist ein Leuchtmittel von zweien in dieser Ecklampe, Ecklampe2 kann ich schalten.
      Was ist ein Token?
      Raspberry Pi 4 8gb
      • tiobbT tiobb
        Was ist ein Token?
        einmal 55443, sonst 5544
        und dann werden die IPs neu vergeben, wenn diese per DHCP gesetzt sind.
        Was ist ein Token?
        ein Werkzeug für gesicherten Zugriff
        • tiobbT Offline
          tiobbT Offline
          tiobb
          Asche auf mein Haupt, maxima mea culpa 😔
          gekürzte und übersehende "IP´s 🙈
          Raspberry Pi 4 8gb
          • tiobbT tiobb
            heisst was genau?
            läuft's wieder?
              heisst was genau?
              läuft's wieder?
              tiobbT Offline
              tiobbT Offline
              tiobb
              Das ich die 55443 hier im Log gekürzt habe in 5544 und die andere übersehen habe. Kommt nicht mehr vor, macht es euch nur schwerer. Nochmals sorry dafür. Also im System habe ich nichts angefasst bzw. verändert.
              Raspberry Pi 4 8gb
              • tiobbT tiobb
                @tiobb Also läuft's noch nicht wieder 😠
                Dann musst du mal bei einer Lampe herausfinden warum sie die Verbindung ablehnt (ECONNREFUSED)
                  tiobbT Offline
                  tiobbT Offline
                  tiobb
                  Wo fange ich an zu suchen, ich hab absolut keine Ahnung. Ich hab den Raspberry neu gestartet, die Lampen vom Netz genommen, Adapter neu gestartet, de- und wieder installiert...In der Fritzbox finde ich auch keine Auffälligkeiten, dürfte ja auch nicht, sonst könnte ich sie ja nicht über Alexa steuern.
                  Raspberry Pi 4 8gb
                  • tiobbT tiobb
                    keine Ahnung!
                    wie gesagt weiss ich über den Adapter nichts.
                    über Alexa steuern.
                    Direkt Alexa, oder per Alexa über iobroker?
                    ganz allgemein aber:
                    bitte immer nur eine!
                    und dann das log beobachten
                      keine Ahnung!
                      über Alexa steuern.
                      tiobbT Offline
                      tiobbT Offline
                      tiobb
                      @homoran sagte in Einige Lampen nicht mehr über iobroker steuerbar:
                      Direkt über Alexa.
                      Raspberry Pi 4 8gb
                      • tiobbT tiobb
                        Direkt über Alexa.
                        Direkt über Alexa.
                        die greift bestimmt nicht über die IP, Port und Token darauf zu.
                        Aber da bin ich jetzt auch raus
                          Direkt über Alexa.
                          tiobbT Offline
                          tiobbT Offline
                          tiobb
                          schrieb am zuletzt editiert von tiobb
                          Das komische ist ja, dass ich 2 Lampen über die Objekte ansteuern kann. Wenn jetzt alles ausgefallen wäre könnte ich da ja vielleicht noch verstehen, und würde im iob. alles neu installieren, aber so?
                          Aber trotzdem danke für deine Hilfe, trotz meines Fauxpas. mit den gekürzten IP`s.
                          Raspberry Pi 4 8gb
                          • tiobbT tiobb
                            stimmen diese denn in Instanz und Fritzbox überein?
                            keine Leerzeichen drin versteckt usw...
                              tiobbT Offline
                              tiobbT Offline
                              tiobb
                              ich sehe gerade das sich die Namen einiger Geräte unterscheiden. Aber die zwei die ich über den iob ansteuern kann, heißen in der Fritzbox anders als in der Instanz. Scheint scheinbar egal zu sein.
                              Aber die Fritzbox hat einfach alle IP Adressen verändert. Musste jetzt jede einzelne Lampe vom Netz nehmen und in der Fritzbox schauen welches Gerät als ungenutzt angezeigt wurde und habe dann die IP in den Instanzen geändert. So ein Sch.... Ich muss gucken wie ich das verhindern kann dass das nochmal passiert.
                              Nochmals vielen Dank!!!
                              Raspberry Pi 4 8gb
                              • tiobbT tiobb
                                @tiobb sagte in Erledigt! Einige Lampen nicht mehr über iob steuerbar:
                                host names verwenden.
                                Oder die vergebenen IPs in der FritzBox festtackern.
                                • tiobbT tiobb
                                  Natürlich!
                                  wie ich bereits schrob:
                                  @homoran sagte in Erledigt! Einige Lampen nicht mehr über iob steuerbar:
                                  schön dass es jetzt läuft!
                                  ...und immer in die logs sehen ;-)
                                  BTW debug wieder ausschalten!
                                    tiobbT Offline
                                    tiobbT Offline
                                    tiobb
                                    @thomas-braun sagte in Erledigt! Einige Lampen nicht mehr über iob steuerbar:
                                    Wie Tacker ich die Fest, indem ich in der Fritzbox auf die Geräte gehe und den Haken bei "Diesem Netzwerkgerät immer die gleiche IPv4-Adresse zuweisen." setze?
                                    Komisch aber das z.B. meine ganzen Shelly Schalter keine neuen Ip´s erhalten haben.
                                    Debug ist abgeschaltet
                                    Vielen Dank!!!
                                    Raspberry Pi 4 8gb
                                    • tiobbT tiobb
                                      Vielen Dank!!!
                                      Ja.
                                      • tiobbT tiobb
                                        Vielen Dank!!!
                                        habe selbst keine Shellys.
                                        Aber wenn die IPs fest in den Geräten definiert sind, bleiben die so.
                                        Das solltest du unbedingt prüfen, da fixe IPs außerhalb des DHCP Bereichs liegen müssen, sonst gibt es früher oder später Ärger
                                          Ja.
                                          tiobbT Offline
                                          tiobbT Offline
                                          tiobb
                                          Ja.
                                          Merci!
                                          Das kann natürlich sein.
                                          Werde ich machen, Danke.
                                          Raspberry Pi 4 8gb
