  4. Test Adapter iobroker.Zigbee 1.10.10
190 Beiträge 19 Kommentatoren 48.8k Aufrufe 23 Beobachtet
  • AsgothianA Asgothian
    @ritter sagte in Test Adapter iobroker.Zigbee 1.10.10:
    @asgothian Hallo, bin leider erst jetzt dazugekommen.
    Reicht dir das mit ELEVATED gefilterte oder brauchst du das ganze log?
    Eine IKEA E27 Lampe mit weißtönen.
    zigbee.0
    2024-10-19 19:05:34.943	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:34.884	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":100,"ack":false,"ts":1729357534876,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357534876}
    zigbee.0
    2024-10-19 19:05:34.083	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:34.026	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":13,"ack":false,"ts":1729357534017,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357534017}
    zigbee.0
    2024-10-19 19:05:33.042	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:32.990	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":87,"ack":false,"ts":1729357532988,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357532988}
    zigbee.0
    2024-10-19 19:05:31.278	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:31.231	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":221,"ack":false,"ts":1729357531229,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357531229}
    zigbee.0
    2024-10-19 19:05:28.349	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:28.278	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":true,"ack":false,"ts":1729357528269,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357528269}
    zigbee.0
    2024-10-19 19:05:25.494	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:25.448	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":false,"ack":false,"ts":1729357525446,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357525446}
    zigbee.0
    2024-10-19 19:05:23.255	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:23.198	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":500,"ack":false,"ts":1729357523190,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357523190}
    zigbee.0
    2024-10-19 19:05:19.526	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:19.480	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":156,"ack":false,"ts":1729357519478,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357519478}
    zigbee.0
    2024-10-19 19:05:16.680	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:16.623	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":11,"ack":false,"ts":1729357516621,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357516621}
    zigbee.0
    2024-10-19 19:05:16.175	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 19:05:16.119	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":30,"ack":false,"ts":1729357516110,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729357516110}
    Zigbee 1.txt
    bitte lass den nochmal laufen, aber ohne das der Adapter im Debug läuft - da sind viel zu viele Nachrichten um da die Fehlermeldungen zu finden - so sie denn existieren.
    Die Elevated Meldungen sind auf jeden Fall auffällig - mir fehlt da was.
    A.
    Ritter
    schrieb am zuletzt editiert von Ritter
    @asgothian Reicht info aus?
    zigbee.0
    2024-10-19 21:24:10.569	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:24:10.518	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":true,"ack":false,"ts":1729365850512,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365850512}
    zigbee.0
    2024-10-19 21:24:03.414	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:24:03.330	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":435,"ack":false,"ts":1729365843320,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365843320}
    zigbee.0
    2024-10-19 21:24:02.999	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:24:02.913	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":390,"ack":false,"ts":1729365842904,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365842904}
    zigbee.0
    2024-10-19 21:24:02.043	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:24:01.988	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":83,"ack":false,"ts":1729365841979,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365841979}
    zigbee.0
    2024-10-19 21:24:01.475	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:24:01.411	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":54,"ack":false,"ts":1729365841401,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365841401}
    zigbee.0
    2024-10-19 21:23:32.981	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:32.890	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":false,"ack":false,"ts":1729365812887,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365812887}
    zigbee.0
    2024-10-19 21:23:30.769	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:30.703	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":true,"ack":false,"ts":1729365810701,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365810701}
    zigbee.0
    2024-10-19 21:23:27.532	warn	ELEVATED Change state 'state' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:27.465	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.state {"val":false,"ack":false,"ts":1729365807463,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365807463}
    zigbee.0
    2024-10-19 21:23:17.406	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:17.358	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":11,"ack":false,"ts":1729365797356,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365797356}
    zigbee.0
    2024-10-19 21:23:14.583	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:14.524	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":150,"ack":false,"ts":1729365794515,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365794515}
    zigbee.0
    2024-10-19 21:23:13.283	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:13.226	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":228,"ack":false,"ts":1729365793217,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365793217}
    zigbee.0
    2024-10-19 21:23:11.507	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:23:11.454	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":100,"ack":false,"ts":1729365791448,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365791448}
    zigbee.0
    2024-10-19 21:21:43.544	info	List of port: [{"path":"/dev/ttyS0","vendorId":"8086","productId":"9d27"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    zigbee.0
    2024-10-19 21:20:38.809	warn	ELEVATED Change state 'colortemp' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:20:38.749	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.colortemp {"val":344,"ack":false,"ts":1729365638740,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365638740}
    zigbee.0
    2024-10-19 21:20:37.275	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:20:37.191	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":46,"ack":false,"ts":1729365637186,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365637186}
    zigbee.0
    2024-10-19 21:20:36.857	warn	ELEVATED Change state 'brightness' at device 0x943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:20:36.808	warn	ELEVATED: User stateChange zigbee.0.943469fffe55fc9e.brightness {"val":30,"ack":false,"ts":1729365636805,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729365636805}
    zigbee.0
    2024-10-19 21:19:40.163	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-19 21:19:40.163	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:19:37.174	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-19 21:19:37.173	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:19:34.173	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-19 21:19:34.172	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:19:31.157	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-19 21:19:31.156	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    zigbee.0
    2024-10-19 21:19:28.203	warn	ELEVATED publishToState: value generated '76' from device 943469fffe55fc9e for 'Link quality'
    zigbee.0
    2024-10-19 21:19:28.202	warn	ELEVATED publishToState: message received '{"linkquality":76}' from device 943469fffe55fc9e type 'LED2003G10'
    Das passiert nach einem Neustart:
    Zigbee Neustart.txt
    • ? Offline
      @asgothian
      hier mit der aktuellen 1.10.10:
      Edit: Docker V10, js-controller 7.00
      host.iobroker
      2024-10-19 22:29:09.887	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker
      2024-10-19 22:29:09.887	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at Controller.onZclPayload (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:844:26)
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at Controller.identifyUnknownDevice (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:543:26)
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:311:16)
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:403:47
      host.iobroker
      2024-10-19 22:29:09.887	error	Caught by controller[2]: at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23)
      host.iobroker
      2024-10-19 22:29:09.886	error	Caught by controller[2]: Error: AREQ - ZDO - ieeeAddrRsp after 10000ms
      host.iobroker
      2024-10-19 22:29:09.886	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      2024-10-19 22:29:09.343	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2024-10-19 22:29:09.342	info	terminating
      zigbee.0
      2024-10-19 22:29:05.740	info	Zigbee: disabling joining new devices.
      zigbee.0
      2024-10-19 22:29:05.738	info	cleaned everything up...
      zigbee.0
      2024-10-19 22:29:05.733	error	AREQ - ZDO - ieeeAddrRsp after 10000ms
      zigbee.0
      2024-10-19 22:29:05.732	error	Error: AREQ - ZDO - ieeeAddrRsp after 10000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:403:47 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:311:16) at Controller.identifyUnknownDevice (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:543:26) at Controller.onZclPayload (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:844:26)
      zigbee.0
      2024-10-19 22:29:05.720	error	unhandled promise rejection: AREQ - ZDO - ieeeAddrRsp after 10000ms
      zigbee.0
      2024-10-19 22:29:05.719	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      influxdb.0
      2024-10-19 22:28:59.059	info	Store 1001 buffered influxDB history points
        @asgothian
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        influxdb.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @ilovegym sagte in Test Adapter iobroker.Zigbee 1.10.10:
        • Welche Koordinator Hardware
        • Welche Firmware auf dem Koordinator ?
          @asgothian
          cc26x2r1
          965b0fda-32e2-4a2f-884e-91663a843fa3-A7D1AC31-13D3-4B64-9EF6-408D86712A52_1_201_a.jpeg
            @asgothian
            cc26x2r1
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            Bitte installiert die aktuelle Version. Ich habe noch eine Anpassung durchgeführt.
            A.
            R 1 Antwort Letzte Antwort
              A.
              Ritter
              @asgothian Leider keine Änderung.
                Aktuelle Test Version 1.10.10
                Veröffentlichungsdatum 17.10.2024
                Github Link https://github.com/ioBroker/ioBroker.zigbee
                • Update zigbee-herdsman auf 2.1.1
                • Update to zigbee-herdsman-converters auf 20.28.0
                • Neue Optionen bei der Darstellung der Gerätekarte.
                Hinweis - bei den Tests gab es einen Fall das ein Downgrade von 1.10.10 auf 1.10.9 nicht funktioniert hat. Daher bitte vor dem Installieren die folgenden Schritte durchführen:
                • Adapter anhalten
                • Daten aus dem Adapter Datenverzeichnis (üblicherweise /opt/iobroker/iobroker-data/zigbee_0) kopieren.
                • Adapter aktualisieren
                Für den Fall das es Probleme mit der 1.10.10 gibt bitte den Adapter auf 1.10.9 oder 1.10.3 (release) zurück spielen. Sollte es dabei Probleme beim Start des Adapters geben:
                • Adapter anhalten
                • Gesicherte Daten zurück spielen
                • Adapter wieder starten
                Wichtig - das zurückspielen nur mit dem 1.10.9 oder 1.10.3 durchführen.
                Bitte Erfahrungen mit dem Adapter hier posten, incl. Informationen über den verwendeten Koordinator und dessen Firmware.
                A.
                @asgothian
                hmm etwas besser, aber es kommen keine Werte an..
                startet jetzt, dann kommt empty object...
                host.iobroker
                2024-10-20 00:12:06.413	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.iobroker
                2024-10-20 00:12:06.412	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:383:37)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10907:34)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at Zigbee.emit (node:domain:488:12)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at Zigbee.emit (node:events:531:35)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:16:48)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:84:34)
                host.iobroker
                2024-10-20 00:12:06.412	error	Caught by controller[4]: at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:513:52)
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[4]: at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1020:41)
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[4]: at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:276:34)
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[4]: at Function.createRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:57:19)
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[4]: Error: Command request 'mgmtNwkUpdateReq' from subsystem '5' not found
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[3]: TICMeter: Exposes: No endpoint
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[2]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose...
                host.iobroker
                2024-10-20 00:12:06.411	error	Caught by controller[1]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase
                host.iobroker
                2024-10-20 00:12:06.410	error	Caught by controller[0]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique
                zigbee.0
                2024-10-20 00:12:05.852	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee.0
                2024-10-20 00:12:05.851	info	terminating
                zigbee.0
                2024-10-20 00:12:05.028	info	Zigbee: disabling joining new devices.
                zigbee.0
                2024-10-20 00:12:05.026	info	cleaned everything up...
                zigbee.0
                2024-10-20 00:12:05.021	error	Command request 'mgmtNwkUpdateReq' from subsystem '5' not found
                zigbee.0
                2024-10-20 00:12:05.021	error	Error: Command request 'mgmtNwkUpdateReq' from subsystem '5' not found at Function.createRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:57:19) at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:276:34) at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1020:41) at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:513:52) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:84:34) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:16:48) at Zigbee.emit (node:events:531:35) at Zigbee.emit (node:domain:488:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10907:34) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:383:37)
                zigbee.0
                2024-10-20 00:12:04.924	error	unhandled promise rejection: Command request 'mgmtNwkUpdateReq' from subsystem '5' not found
                zigbee.0
                2024-10-20 00:12:04.924	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                tuya.0
                2024-10-20 00:12:04.867	info	bfd7260934b09826b5fki4: Error on Reconnect (7): connection timed out
                tuya.0
                2024-10-20 00:12:03.019	info	bfeeaa29ccb41608a6wp8h: Error on Reconnect (5): connection timed out
                tuya.0
                2024-10-20 00:12:01.801	info	bf173c5af3445d8de5ayds: Error on Reconnect (1): connection timed out
                zigbee.0
                2024-10-20 00:12:00.459	error	empty object!
                sonoff.0
                2024-10-20 00:11:59.670	info	Client [USBSwitch15] connected with secret 1729375919669_1883
                zigbee.0
                2024-10-20 00:11:59.227	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.218	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.179	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.168	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.116	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.102	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.098	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.067	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.023	error	empty object!
                zigbee.0
                2024-10-20 00:11:59.013	error	empty object!
                zigbee.0
                2024-10-20 00:11:58.980	error	empty object!
                zigbee.0
                2024-10-20 00:11:58.975	error	empty object!
                zigbee.0
                2024-10-20 00:11:58.929	error	empty object!
                zigbee.0
                2024-10-20 00:11:58.917	info	List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
                zigbee.0
                2024-10-20 00:11:58.864	error	empty object!
                zigbee.0
                2024-10-20 00:11:58.860	error	empty object!
                zigbee.0
                2024-10-20 00:11:58.829	error	empty object!
                  @asgothian
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  tuya.0
                  tuya.0
                  tuya.0
                  zigbee.0
                  sonoff.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  Kannst du beschreiben was du genau getan hast ?
                  Bei mir läuft der Adapter prinzipiell so, allerdings kann ich den hier geposteten Fehler erzwingen.
                  • Wie entsteht der Fehler bei Dir ?
                  • was passiert wenn du versuchst Zigbee-Geräte zu steuern ? Gibt es Fehlermeldungen im Log ?
                  • Wie sieht die Kommunikation mit einem Gerät bei Dir aus, wenn du wie @ritter ein Gerät für die Debug-Messages einträgst (Anleitung dazu weiter oben) ?
                  A.
                    A.
                    @asgothian
                    frag nich.. ich hatte ja diese Testversion 1.10.9 aus deinem Repo die ganze Zeit laufen, lief auch zu 98% gut.
                    Jetzt startet der Zigbee gar nicht mehr, immer mit diesem Fehler, gerade von Git geladen:
                    zigbee.0
                    2024-10-20 10:21:09.494	error	Error herdsman start
                    zigbee.0
                    2024-10-20 10:21:09.494	error	Failed to start Zigbee
                    zigbee.0
                    2024-10-20 10:21:09.493	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms\n at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23)\n at ZnpAdapterManager.beginCommissioning (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:370:31)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\n at ZnpAdapterManager.start (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:91:21)\n at ZStackAdapter.start (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:158:16)\n at Controller.start (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)\n at ZigbeeController.start (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:131:13)\n at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:316:13))"
                      @asgothian
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      @ilovegym
                      gerade nochmal Adapter gestoppt, den TI power-resetted, in den Einstellungen des Adapters gesehen, dass bei Sendeleistung Sendeleistung stand, also anstatt normal, high usw. stand da Sendeleistung Sendeleistung drin..
                      Hab jetzt mal auf normal gestellt.. und der Adapter startet...
                        • Adapter anhalten
                        • Adapter anhalten
                        A.
                        @asgothian adapter ist gestartet, laeuft, aber alle Devices offline.
                        Hier mal eins auf Debug gesetzt:
                        2024-10-20 10:38:31.240  - info: zigbee.0 (16360) starting. Version 1.10.10 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 7.0.0
                        2024-10-20 10:38:31.282  - info: zigbee.0 (16360) Starting Zigbee  npm ...
                        2024-10-20 10:38:31.436  - info: zigbee.0 (16360) Installed Version: ioBroker/ioBroker.zigbee
                        2024-10-20 10:38:32.733  - info: zigbee.0 (16360) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
                        2024-10-20 10:38:32.733  - info: zigbee.0 (16360) Unable to disable LED, unsupported function.
                        2024-10-20 10:38:32.741  - info: zigbee.0 (16360)   --> transmitPower : normal
                        2024-10-20 10:38:33.026  - info: zigbee.0 (16360) Currently 247 devices are joined:
                        2024-10-20 10:38:33.453  - info: sonoff.0 (1174) Client [USBSwitch15] connected with secret 1729413513415_6160
                        2024-10-20 10:38:33.588  - info: zigbee.0 (16360) 0x00158d00011083e8 (addr 4803): MFKZQ01LM - Aqara Cube (EndDevice)
                        2024-10-20 10:38:33.593  - info: zigbee.0 (16360) 0x00158d00042adb71 (addr 7040): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.595  - info: zigbee.0 (16360) 0x00158d00022daa58 (addr 24588): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.596  - info: zigbee.0 (16360) 0x00158d00022efe8a (addr 10197): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.596  - info: zigbee.0 (16360) 0x00158d0005d10648 (addr 10084): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.597  - info: zigbee.0 (16360) 0x00158d0002325709 (addr 17093): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.598  - info: zigbee.0 (16360) 0x00158d00020edd4a (addr 8765): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.598  - info: zigbee.0 (16360) 0x00158d00022efe3a (addr 44959): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.599  - info: zigbee.0 (16360) 0x00158d000255be9d (addr 28986): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.600  - info: zigbee.0 (16360) 0x00158d0002289d91 (addr 3167): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.600  - info: zigbee.0 (16360) 0x00158d0002b728d7 (addr 50115): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.601  - info: zigbee.0 (16360) 0x00158d0001245a23 (addr 12995): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.601  - info: zigbee.0 (16360) 0x04cf8cdf3c7d0f25 (addr 19206): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                        2024-10-20 10:38:33.602  - info: zigbee.0 (16360) 0x04cf8cdf3c78ccbd (addr 37431): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                        2024-10-20 10:38:33.602  - info: zigbee.0 (16360) 0x00158d0001f40701 (addr 17431): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.603  - info: zigbee.0 (16360) 0x00158d0001fa4d24 (addr 25921): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.604  - info: zigbee.0 (16360) 0x00158d0001e63db3 (addr 57819): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.604  - info: zigbee.0 (16360) 0x00158d0001f536ab (addr 24346): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.605  - info: zigbee.0 (16360) 0x00158d00032c0ff2 (addr 56767): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.605  - info: zigbee.0 (16360) 0x00158d0001a920f2 (addr 15393): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.606  - info: zigbee.0 (16360) 0x00158d0002280fbe (addr 50294): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.606  - info: zigbee.0 (16360) 0x04cf8cdf3c7d1801 (addr 38880): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                        2024-10-20 10:38:33.607  - info: zigbee.0 (16360) 0x04cf8cdf3c78a5f5 (addr 14379): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                        2024-10-20 10:38:33.607  - info: zigbee.0 (16360) 0x00158d000232d0ab (addr 16466): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.608  - info: zigbee.0 (16360) 0x00158d0002278b91 (addr 40132): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.608  - info: zigbee.0 (16360) 0x00158d0001fa6c38 (addr 18271): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.609  - info: zigbee.0 (16360) 0x00158d000237c84c (addr 44377): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.609  - info: zigbee.0 (16360) 0x00158d0001bb8e47 (addr 31591): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.610  - info: zigbee.0 (16360) 0x00158d00023f3787 (addr 2485): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.610  - info: zigbee.0 (16360) 0x00158d0001f46f70 (addr 43937): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.611  - info: zigbee.0 (16360) 0x00158d0006f944f9 (addr 28162): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.612  - info: zigbee.0 (16360) 0x00158d00057fc8a4 (addr 5764): 371000001 - Paulmann SmartHome led spot tuneable white (Router)
                        2024-10-20 10:38:33.612  - info: zigbee.0 (16360) 0x00158d00024ee7c0 (addr 46689): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.613  - info: zigbee.0 (16360) 0x00158d00054276b5 (addr 4401): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.614  - info: zigbee.0 (16360) 0x00158d0003495ba6 (addr 49186): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.614  - info: zigbee.0 (16360) 0x00158d000201c965 (addr 19255): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.615  - info: zigbee.0 (16360) 0x00158d00022f1480 (addr 9249): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.615  - info: zigbee.0 (16360) 0x00158d0002b5d5c8 (addr 58030): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.615  - info: zigbee.0 (16360) 0x00158d0002018617 (addr 36042): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.616  - info: zigbee.0 (16360) 0x00158d000200cfd1 (addr 40754): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.616  - info: zigbee.0 (16360) 0x00158d00022dab84 (addr 40011): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.617  - info: zigbee.0 (16360) 0x00158d0001dbc002 (addr 33235): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.617  - info: zigbee.0 (16360) 0x00158d0001f40767 (addr 50712): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.618  - info: zigbee.0 (16360) 0x00158d0001dbbb73 (addr 50776): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.618  - info: zigbee.0 (16360) 0x00158d0001dd4820 (addr 33469): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.618  - info: zigbee.0 (16360) 0x00158d0005cf42b3 (addr 26094): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.619  - info: zigbee.0 (16360) 0x00158d00027ce18e (addr 9232): MFKZQ01LM - Aqara Cube (EndDevice)
                        2024-10-20 10:38:33.619  - info: zigbee.0 (16360) 0x00158d000275dc7a (addr 9581): MFKZQ01LM - Aqara Cube (EndDevice)
                        2024-10-20 10:38:33.620  - info: zigbee.0 (16360) 0x00158d0002b49e19 (addr 16019): WXKG02LM_rev2 - Aqara Wireless remote switch (double rocker), 2018 model (EndDevice)
                        2024-10-20 10:38:33.620  - info: zigbee.0 (16360) 0x00158d0001d58d56 (addr 8293): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.621  - info: zigbee.0 (16360) 0x00158d0002310183 (addr 25226): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.621  - info: zigbee.0 (16360) 0x00158d000237d2a4 (addr 39589): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.622  - info: zigbee.0 (16360) 0xe0798dfffe8d93b8 (addr 23959): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.622  - info: zigbee.0 (16360) 0x00158d000232aa16 (addr 24079): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.623  - info: zigbee.0 (16360) 0x00158d0001c2025b (addr 37180): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
                        2024-10-20 10:38:33.623  - info: zigbee.0 (16360) 0x00158d00020e386c (addr 36436): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.624  - info: zigbee.0 (16360) 0x00158d000238693f (addr 60259): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.624  - info: zigbee.0 (16360) 0x00158d0002327f1b (addr 60990): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.624  - info: zigbee.0 (16360) 0x00158d000232cc33 (addr 32866): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.625  - info: zigbee.0 (16360) 0x00158d000273a07a (addr 8591): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.625  - info: zigbee.0 (16360) 0x00158d00022efe53 (addr 20447): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.626  - info: zigbee.0 (16360) 0x00158d000201c424 (addr 36727): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.626  - info: zigbee.0 (16360) 0x00158d0002a61db3 (addr 10566): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.626  - info: zigbee.0 (16360) 0x00158d00032ba8af (addr 59474): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.627  - info: zigbee.0 (16360) 0x00158d00054cbc44 (addr 61339): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.627  - info: zigbee.0 (16360) 0x00158d0002ea6c32 (addr 24967): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.628  - info: zigbee.0 (16360) 0x00158d000232c479 (addr 9366): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.628  - info: zigbee.0 (16360) 0x00158d00034cc811 (addr 49714): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.629  - info: zigbee.0 (16360) 0x00158d000232063c (addr 28969): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.629  - info: zigbee.0 (16360) 0x00158d00024e8913 (addr 18390): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.630  - info: zigbee.0 (16360) 0x00158d0001e455ee (addr 61858): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.630  - info: zigbee.0 (16360) 0x00158d000232dae3 (addr 59674): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.631  - info: zigbee.0 (16360) 0x00158d00022da934 (addr 36495): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.631  - info: zigbee.0 (16360) 0x00158d00022f14ed (addr 215): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.631  - info: zigbee.0 (16360) 0x00158d00022d2c0e (addr 13316): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.632  - info: zigbee.0 (16360) 0x00158d0002329643 (addr 1740): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.632  - info: zigbee.0 (16360) 0x00158d000232a905 (addr 19605): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.633  - info: zigbee.0 (16360) 0x00158d00032d59fc (addr 12931): ZNCZ02LM - Xiaomi Mi smart plug (EndDevice)
                        2024-10-20 10:38:33.633  - info: zigbee.0 (16360) 0x588e81fffe2323bd (addr 39259): ZS110050078 - Linkind Door/window Sensor (EndDevice)
                        2024-10-20 10:38:33.634  - info: zigbee.0 (16360) 0x04cf8cdf3c7b02d2 (addr 17497): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
                        2024-10-20 10:38:33.634  - info: zigbee.0 (16360) 0x00158d00047d2647 (addr 27181): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.634  - info: zigbee.0 (16360) 0x00158d000208ee42 (addr 37596): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.635  - info: zigbee.0 (16360) 0x00158d000255bfa2 (addr 49961): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.635  - info: zigbee.0 (16360) 0x00158d0005d0c418 (addr 33604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.636  - info: zigbee.0 (16360) 0x00158d0009f480e3 (addr 3320): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.637  - info: zigbee.0 (16360) 0x0015bc003100960d (addr 8528): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.638  - info: zigbee.0 (16360) 0x00158d0002d7955b (addr 16257): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.638  - info: zigbee.0 (16360) 0x00158d00022efe7d (addr 34496): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.639  - info: zigbee.0 (16360) 0x00158d0001e09ad4 (addr 34166): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.640  - info: zigbee.0 (16360) 0x00158d000897586e (addr 25931): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.640  - info: zigbee.0 (16360) 0x8cf681fffe5a0b56 (addr 9848): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.641  - info: zigbee.0 (16360) 0x00158d0004036d72 (addr 27962): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.641  - info: zigbee.0 (16360) 0x00158d0004036dd5 (addr 38500): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.642  - info: zigbee.0 (16360) 0x00158d0004036d92 (addr 26458): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.642  - info: zigbee.0 (16360) 0x00158d00022d2bbe (addr 18004): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.642  - info: zigbee.0 (16360) 0x00158d00036b4cda (addr 44425): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.643  - info: zigbee.0 (16360) 0x00158d000247ec94 (addr 25492): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.644  - info: zigbee.0 (16360) 0x00158d0002325798 (addr 2351): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.644  - info: zigbee.0 (16360) 0x00158d00042ad980 (addr 20878): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.645  - info: zigbee.0 (16360) 0x00158d00053ec985 (addr 63537): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.645  - info: zigbee.0 (16360) 0x00158d0004910948 (addr 47132): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.645  - info: zigbee.0 (16360) 0x00158d00032bd9a5 (addr 8662): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.646  - info: zigbee.0 (16360) 0x00158d00044fec5e (addr 18503): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.647  - info: zigbee.0 (16360) 0x04cf8cdf3c7b0fdc (addr 18943): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
                        2024-10-20 10:38:33.647  - info: zigbee.0 (16360) 0x0015bc0031009604 (addr 42613): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.648  - info: zigbee.0 (16360) 0x2c1165fffec7fa43 (addr 37980): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.648  - info: zigbee.0 (16360) 0x00158d0002c39587 (addr 6275): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.649  - info: zigbee.0 (16360) 0x00158d0002e230ba (addr 12534): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.649  - info: zigbee.0 (16360) 0x00124b002a524a99 (addr 56949): SNZB-03 - SONOFF Motion sensor (EndDevice)
                        2024-10-20 10:38:33.650  - info: zigbee.0 (16360) 0x00158d0002a4ea25 (addr 45985): DJT11LM - Aqara Vibration sensor (EndDevice)
                        2024-10-20 10:38:33.650  - info: zigbee.0 (16360) 0x00158d00053ec625 (addr 32664): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.651  - info: zigbee.0 (16360) 0x00158d000387ef1d (addr 56573): 404001 - Müller Licht LED bulb E27 806 lumen, dimmable (Router)
                        2024-10-20 10:38:33.651  - info: zigbee.0 (16360) 0x00158d00029c04f1 (addr 29160): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.654  - info: zigbee.0 (16360) 0x00158d00030212a8 (addr 25106): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.655  - info: zigbee.0 (16360) 0x00158d0005229809 (addr 10473): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.655  - info: zigbee.0 (16360) 0x00158d00053ec684 (addr 36999): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                        2024-10-20 10:38:33.656  - info: zigbee.0 (16360) 0x00158d0002a4e97a (addr 26754): DJT11LM - Aqara Vibration sensor (EndDevice)
                        2024-10-20 10:38:33.657  - info: zigbee.0 (16360) 0x00158d0002c3957a (addr 56544): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.657  - info: zigbee.0 (16360) 0x00158d0002c98638 (addr 27881): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.657  - info: zigbee.0 (16360) 0x00158d000319c202 (addr 27138): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.658  - info: zigbee.0 (16360) 0x00158d0002018f16 (addr 28477): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.659  - info: zigbee.0 (16360) 0x00158d0002c986f2 (addr 2332): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.659  - info: zigbee.0 (16360) 0x00158d0004857dbe (addr 31513): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.660  - info: zigbee.0 (16360) 0x00158d000232cb6c (addr 97): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.660  - info: zigbee.0 (16360) 0x00158d00023e9030 (addr 52182): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.661  - info: zigbee.0 (16360) 0x00158d000237e696 (addr 38312): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.661  - info: zigbee.0 (16360) 0x54ef441000302725 (addr 19428): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                        2024-10-20 10:38:33.662  - info: zigbee.0 (16360) 0x00158d000286d63f (addr 35930): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.663  - info: zigbee.0 (16360) 0x04cf8cdf3c7db61c (addr 48769): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
                        2024-10-20 10:38:33.663  - info: zigbee.0 (16360) 0x04cf8cdf3c7c4a7c (addr 35669): WXCJKG12LM - Aqara Opple wireless switch (double band) (EndDevice)
                        2024-10-20 10:38:33.664  - info: zigbee.0 (16360) 0x00158d0008059cfb (addr 48558): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.664  - info: zigbee.0 (16360) 0x00158d00038bb932 (addr 63584): 404002 - Müller Licht Tint dim remote control (EndDevice)
                        2024-10-20 10:38:33.665  - info: zigbee.0 (16360) 0x00158d0005402670 (addr 61035): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.665  - info: zigbee.0 (16360) 0x00158d00044fd6f8 (addr 12359): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.666  - info: zigbee.0 (16360) 0x00158d00045fb6dc (addr 30895): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.666  - info: zigbee.0 (16360) 0x60a423fffe39de4e (addr 25007): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice)
                        2024-10-20 10:38:33.667  - info: zigbee.0 (16360) 0x60a423fffe39d80d (addr 62437): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice)
                        2024-10-20 10:38:33.667  - info: zigbee.0 (16360) 0x60a423fffe2dafe2 (addr 45046): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice)
                        2024-10-20 10:38:33.668  - info: zigbee.0 (16360) 0x60a423fffe39ec56 (addr 34675): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice)
                        2024-10-20 10:38:33.668  - info: zigbee.0 (16360) 0x00158d0008064403 (addr 49599): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.669  - info: zigbee.0 (16360) 0x00158d0001dffea5 (addr 20408): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.670  - info: zigbee.0 (16360) 0x00158d0001dfd06e (addr 34708): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.670  - info: zigbee.0 (16360) 0x00158d0001dfeed0 (addr 30647): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.671  - info: zigbee.0 (16360) 0x00158d0005052924 (addr 8505): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.672  - info: zigbee.0 (16360) 0x60a423fffe651f06 (addr 27808): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router)
                        2024-10-20 10:38:33.673  - info: zigbee.0 (16360) 0x60a423fffe61d14f (addr 32136): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router)
                        2024-10-20 10:38:33.674  - info: zigbee.0 (16360) 0x60a423fffe6214a4 (addr 15357): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router)
                        2024-10-20 10:38:33.674  - info: zigbee.0 (16360) 0x847127fffed314af (addr 18791): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
                        2024-10-20 10:38:33.675  - info: zigbee.0 (16360) 0x847127fffedaa98c (addr 21309): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
                        2024-10-20 10:38:33.675  - info: zigbee.0 (16360) 0x847127fffecfc43c (addr 3437): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
                        2024-10-20 10:38:33.676  - info: zigbee.0 (16360) 0x00158d0001e4a41c (addr 63779): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.676  - info: zigbee.0 (16360) 0x54ef4410003012cd (addr 25400): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                        2024-10-20 10:38:33.677  - info: zigbee.0 (16360) 0x00158d0005052fc5 (addr 39590): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.677  - info: zigbee.0 (16360) 0x00158d000238c86f (addr 57843): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.678  - info: zigbee.0 (16360) 0x847127fffe27e9d0 (addr 1330): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
                        2024-10-20 10:38:33.678  - info: zigbee.0 (16360) 0x00158d00038b894e (addr 38108): 404002 - Müller Licht Tint dim remote control (EndDevice)
                        2024-10-20 10:38:33.679  - info: zigbee.0 (16360) 0x84b4dbfffef358d7 (addr 22826): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.679  - info: zigbee.0 (16360) -> Configuring 0xa4c138907173660d SNZB-04
                        2024-10-20 10:38:33.682  - info: zigbee.0 (16360) 0x04cf8cdf3c7d3803 (addr 25683): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
                        2024-10-20 10:38:33.682  - info: zigbee.0 (16360) 0x00158d0005c135bf (addr 33786): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.683  - info: zigbee.0 (16360) 0x00158d0002437883 (addr 64834): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.683  - info: zigbee.0 (16360) 0x00158d0005c1376a (addr 9604): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.683  - info: zigbee.0 (16360) 0x00124b00226080a8 (addr 18183): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice)
                        2024-10-20 10:38:33.684  - info: zigbee.0 (16360) 0xa4c138f6e24e9518 (addr 10237): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.684  - info: zigbee.0 (16360) 0xa4c13850d89c91d4 (addr 31791): TS0011_switch_module - Tuya 1 gang switch module - (without neutral) (EndDevice)
                        2024-10-20 10:38:33.684  - info: zigbee.0 (16360) 0xbc33acfffe058459 (addr 51483): HS1EB/HS1EB-E - HEIMAN Smart emergency button (EndDevice)
                        2024-10-20 10:38:33.685  - info: zigbee.0 (16360) 0x00158d0002b5309f (addr 53282): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.685  - info: zigbee.0 (16360) 0x84fd27fffebaba79 (addr 35919): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                        2024-10-20 10:38:33.685  - info: zigbee.0 (16360) 0x00124b0022ff4bf2 (addr 33692): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice)
                        2024-10-20 10:38:33.686  - info: zigbee.0 (16360) 0x00124b0022607ff4 (addr 46156): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice)
                        2024-10-20 10:38:33.686  - info: zigbee.0 (16360) 0x00124b002257644d (addr 34417): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice)
                        2024-10-20 10:38:33.687  - info: zigbee.0 (16360) 0x04cd15fffe7ff62f (addr 21404): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                        2024-10-20 10:38:33.687  - info: zigbee.0 (16360) 0x00124b0022ff500c (addr 47760): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice)
                        2024-10-20 10:38:33.687  - info: zigbee.0 (16360) 0x00124b0022ff5019 (addr 99): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice)
                        2024-10-20 10:38:33.688  - info: zigbee.0 (16360) 0x0015bc00310096b8 (addr 54496): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.688  - info: zigbee.0 (16360) 0x0015bc0031009956 (addr 35937): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.689  - info: zigbee.0 (16360) 0x60a423fffe7085e5 (addr 49707): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.689  - info: zigbee.0 (16360) 0x0015bc0031009708 (addr 8811): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.690  - info: zigbee.0 (16360) 0x0015bc00310097b8 (addr 18040): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.690  - info: zigbee.0 (16360) 0x0015bc003100965a (addr 42015): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.691  - info: zigbee.0 (16360) 0x00158d0005827d47 (addr 52072): 371232040 - Paulmann LED panels (Router)
                        2024-10-20 10:38:33.691  - info: zigbee.0 (16360) 0xa4c13894439e1934 (addr 54463): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.692  - info: zigbee.0 (16360) 0xa4c1381bba0f4a1c (addr 36972): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
                        2024-10-20 10:38:33.693  - info: zigbee.0 (16360) 0x0015bc003100961f (addr 13371): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
                        2024-10-20 10:38:33.693  - info: zigbee.0 (16360) 0x00158d00075f4e3d (addr 17853): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.694  - info: zigbee.0 (16360) 0x00158d00077533df (addr 12705): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.694  - info: zigbee.0 (16360) 0x00158d00042ad981 (addr 35923): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                        2024-10-20 10:38:33.695  - info: zigbee.0 (16360) 0xa4c1387e983fbbe5 (addr 41835): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
                        2024-10-20 10:38:33.695  - info: zigbee.0 (16360) 0x00158d00047d278e (addr 18698): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.696  - info: zigbee.0 (16360) 0xb4e3f9fffed1a86c (addr 21272): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                        2024-10-20 10:38:33.696  - info: zigbee.0 (16360) 0x04cd15fffe268b9b (addr 12743): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                        2024-10-20 10:38:33.697  - info: zigbee.0 (16360) 0x847127fffe11062a (addr 7421): TS0215A_sos - Tuya SOS button (EndDevice)
                        2024-10-20 10:38:33.697  - info: zigbee.0 (16360) 0xa4c138de33384682 (addr 51670): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.697  - info: zigbee.0 (16360) 0xa4c138a6c7567ee7 (addr 23739): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.698  - info: zigbee.0 (16360) 0x680ae2fffee56802 (addr 7832): ZS1100400-IN-V1A02 - Linkind PIR motion sensor, wireless motion detector (EndDevice)
                        2024-10-20 10:38:33.699  - info: zigbee.0 (16360) 0xa4c138426b2558f7 (addr 46648): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
                        2024-10-20 10:38:33.699  - info: zigbee.0 (16360) 0x00158d0004036de7 (addr 56350): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice)
                        2024-10-20 10:38:33.700  - info: zigbee.0 (16360) 0xa4c138f6c5036b4b (addr 10061): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
                        2024-10-20 10:38:33.701  - info: zigbee.0 (16360) 0xa4c1385eec9c1b64 (addr 27424): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
                        2024-10-20 10:38:33.701  - info: zigbee.0 (16360) 0xa4c1388d6d1ced01 (addr 48092): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.701  - info: zigbee.0 (16360) 0xa4c1382376f04085 (addr 2119): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.701  - info: zigbee.0 (16360) 0xa4c138b3542a8f53 (addr 4148): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.702  - info: zigbee.0 (16360) 0xa4c138e49b987eae (addr 63206): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.702  - info: zigbee.0 (16360) 0xa4c1384c039fd50e (addr 45282): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.702  - info: zigbee.0 (16360) 0xa4c13883d7b2a308 (addr 2304): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice)
                        2024-10-20 10:38:33.703  - info: zigbee.0 (16360) 0x00158d000234b762 (addr 8037): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.703  - info: zigbee.0 (16360) 0x00158d000233e9b8 (addr 13464): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.703  - info: zigbee.0 (16360) 0x00158d00023d7ff0 (addr 54780): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.704  - info: zigbee.0 (16360) 0x00158d00023cf008 (addr 44987): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice)
                        2024-10-20 10:38:33.704  - info: zigbee.0 (16360) 0xbc33acfffe08ff77 (addr 61290): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                        2024-10-20 10:38:33.704  - info: zigbee.0 (16360) 0xbc33acfffe5d3a48 (addr 47051): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                        2024-10-20 10:38:33.705  - info: zigbee.0 (16360) 0x04cf8cdf3c802917 (addr 64498): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
                        2024-10-20 10:38:33.705  - info: zigbee.0 (16360) 0x04cf8cdf3c803870 (addr 51062): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
                        2024-10-20 10:38:33.706  - info: zigbee.0 (16360) 0x04cf8cdf3c77dc49 (addr 32178): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
                        2024-10-20 10:38:33.706  - info: zigbee.0 (16360) 0x04cf8cdf3c8038bb (addr 28632): ZNCZ04LM - Xiaomi Mi smart plug EU (Router)
                        2024-10-20 10:38:33.706  - info: zigbee.0 (16360) 0x00158d000237c88f (addr 25455): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-10-20 10:38:33.707  - info: zigbee.0 (16360) 0x84fd27fffebabacd (addr 28744): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
                        2024-10-20 10:38:33.707  - info: zigbee.0 (16360) 0x00124b002a524ccb (addr 14812): SNZB-03 - SONOFF Motion sensor (EndDevice)
                        2024-10-20 10:38:33.707  - info: zigbee.0 (16360) 0x540f57fffe0f49de (addr 11785): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router)
                        2024-10-20 10:38:33.708  - info: zigbee.0 (16360) 0x540f57fffe0f341c (addr 60838): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router)
                        2024-10-20 10:38:33.708  - info: zigbee.0 (16360) 0x00158d000a823b63 (addr 26166): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.708  - info: zigbee.0 (16360) 0x540f57fffe2b26bf (addr 36694): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router)
                        2024-10-20 10:38:33.709  - info: zigbee.0 (16360) 0x00158d0009765328 (addr 12543): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                        2024-10-20 10:38:33.709  - info: zigbee.0 (16360) 0x2c1165fffec8080d (addr 56620): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.709  - info: zigbee.0 (16360) 0x00124b002a654531 (addr 28102): SNZB-03 - SONOFF Motion sensor (EndDevice)
                        2024-10-20 10:38:33.710  - info: zigbee.0 (16360) 0x84b4dbfffeec9ace (addr 24796): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.710  - info: zigbee.0 (16360) 0x2c1165fffec800f4 (addr 29834): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.711  - info: zigbee.0 (16360) 0x00158d000abda409 (addr 38181): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.711  - info: zigbee.0 (16360) 0x00158d000a8242d2 (addr 22546): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.711  - info: zigbee.0 (16360) 0x00158d000a824194 (addr 12036): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.712  - info: zigbee.0 (16360) 0x00158d000a822f77 (addr 11674): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                        2024-10-20 10:38:33.712  - info: zigbee.0 (16360) 0x84b4dbfffef35708 (addr 29246): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.713  - info: zigbee.0 (16360) 0x84b4dbfffecf289d (addr 50337): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.713  - info: zigbee.0 (16360) 0x8cf681fffe5a0dba (addr 26521): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.714  - info: zigbee.0 (16360) 0x2c1165fffe5b4ff4 (addr 22916): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.714  - info: zigbee.0 (16360) 0xa4c138907173660d (addr 16286): SNZB-04 - SONOFF Contact sensor (EndDevice)
                        2024-10-20 10:38:33.715  - info: zigbee.0 (16360) 0xe0798dfffea87db0 (addr 12178): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.715  - info: zigbee.0 (16360) 0x84ba20fffe77b161 (addr 54713): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.716  - info: zigbee.0 (16360) 0xb4e3f9fffe05fa4c (addr 35948): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.716  - info: zigbee.0 (16360) 0x2c1165fffed743db (addr 17097): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.716  - info: zigbee.0 (16360) 0x2c1165fffec801c0 (addr 6186): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.717  - info: zigbee.0 (16360) 0x8cf681fffe4b74bb (addr 41987): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.717  - info: zigbee.0 (16360) 0x84b4dbfffef35752 (addr 62408): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.718  - info: zigbee.0 (16360) 0x8cf681fffe5a09c2 (addr 6446): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.718  - info: zigbee.0 (16360) 0x847127fffe9b54dc (addr 36266): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.719  - info: zigbee.0 (16360) 0x2c1165fffec80908 (addr 50356): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
                        2024-10-20 10:38:33.719  - info: zigbee.0 (16360) 0x84b4dbfffeec9b65 (addr 36348): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router)
                        2024-10-20 10:38:33.720  - info: zigbee.0 (16360) 0x000d6f00162b1ba1 (addr 28536): HS2WD-E - HEIMAN Smart siren (Router)
                        2024-10-20 10:38:33.720  - info: zigbee.0 (16360) Zigbee started
                        2024-10-20 10:38:34.060  - info: zigbee.0 (16360) debug devices set to ["00158d000200cfd1"]
                        2024-10-20 10:38:34.716  - warn: zigbee.0 (16360) ELEVATED publishToState: message received '{"available":true}' from device 00158d000200cfd1 type 'RTCGQ11LM'
                        2024-10-20 10:38:34.716  - warn: zigbee.0 (16360) ELEVATED publishToState: value generated 'true' from device 00158d000200cfd1 for 'Available'
                        2024-10-20 10:38:34.716  - warn: zigbee.0 (16360) ELEVATED publishToState: message received '{"linkquality":10}' from device 00158d000200cfd1 type 'RTCGQ11LM'
                        2024-10-20 10:38:34.717  - warn: zigbee.0 (16360) ELEVATED publishToState: value generated '10' from device 00158d000200cfd1 for 'Link quality'
                        2024-10-20 10:38:36.020  - info: host.iobroker instance system.adapter.uv-protect.0 in version "0.6.3" started with pid 16384
                        2024-10-20 10:38:36.350  - info: sonoff.0 (1174) Client [USBSwitch11] connected with secret 1729413516331_2057
                        2024-10-20 10:38:36.478  - info: sonoff.0 (1174) Client [USBSwitch10] reconnected. Old secret 1729413455625_6393 ==> New secret 1729413516478_9810
                        2024-10-20 10:38:42.336  - info: tuya.0 (1396) 485606842cf43272918b: Connect locally to device
                        2024-10-20 10:38:42.336  - info: tuya.0 (1396) 485606842cf43272918b Init with IP=10.1.12.100, Key=3d7bdc1f319219bb, Version=3.3
                        2024-10-20 10:38:43.996  - info: admin.0 (3391) <== Disconnect system.user.admin from 192.168.0.21
                        2024-10-20 10:38:44.087  - warn: zigbee.0 (16360) DeviceConfigure: 0xa4c138907173660d SNZB-04 Failed to configure. When device works is all fine when not wake up the device and check again
                        In den Objekten kommt nix, die sind leer, das meine ich:
                        • AsgothianA Asgothian
                          • Adapter anhalten
                          • Adapter anhalten
                          A.
                          @asgothian
                          gerade mal das Pairing gestartet, das macht er, allerdings zaehlt er keinen Countdown, einfach im Fenster nur Paring startet
                          Im log, das Interessante, mein TI ist per Ethernet angebunden, und in der Config steht tcp://10.1.1.98:20108 :
                          zigbee.0
                          2024-10-20 10:47:47.976	info	Zigbee: allowing new devices to join.
                          zigbee.0
                          2024-10-20 10:47:44.748	info	List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
                          • R Ritter
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            Zigbee Neustart.txt
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @ritter sagte in Test Adapter iobroker.Zigbee 1.10.10:
                            Ich werde aus der Info immer noch nicht schlau. Lt. dem was du gepostet hast gibt es keine Fehlermeldungen beim Versuch geräte zu schalten, auch wenn diese nicht reagieren. Allerdings habe ich die elevated nachrichten erweitert, und würde Dich bitten meinen Fork von
                            https://github.com/asgothian/ioBroker.zigbee
                            zu installieren und dann zu posten was an nachrichten auftaucht. Auch weiterhin wichtig: Gibt es innerhalb von 60 Sekunden von einer Anpassung die nicht bis zum Gerät kommt eine Fehlermeldung ?
                            @ilovegym Auch dich würde ich bitten den Test-Branch zu installieren, da bei Dir die Geräte auch nicht reagieren.
                            A.
                              @asgothian
                              zigbee.0
                              zigbee.0
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @asgothian
                              zigbee.0
                              zigbee.0
                              Das er die Port-Liste liefert ist standard - der Adapter enumeriert alle seriellen Schnittstellen um dem Benutzer diese zur Auswahl anzubieten. Es werden alle gefundenen Ports auch im Log hinterlegt, da es oft mit der seriellen Anbindung Probleme gibt.
                              A.
                                @asgothian
                                zigbee.0
                                zigbee.0
                                A.
                                @asgothian
                                es erfolgt einfach keine Communication mit dem Stick mehr - hab schon den baugleichen Ersatz mal dran gesteckt, das gleiche.
                                Weder wird der Countdown gestartet, noch wird irgendein Device ausgelesen.
                                Auch kommt beim Stick gar nicht viel an, bzw sind das meist innerhalb von Minuten einige MB:
                                  @asgothian
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @asgothian
                                  Wichtig ist was der Adapter dazu sagt wenn du versuchst etwas an den Stick zu senden. Die Datenmengen sind immer gering.
                                  Die Fehlermeldungen die der Adapter bringt bringen mir hoffentlich Informationen dazu was da schief geht.
                                  • R Offline
                                    Ritter
                                    Die Kommunikation ist aber nicht ganz unterbrochen, denn wenn man den Knopf an einer Funksteckdose drückt geht der Ein-Aus Schieber an der Zigbee Kachel mit nur nicht umgekehrt.
                                    AsgothianA 2 Antworten Letzte Antwort
                                    • R Ritter
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      Dein Fehler und der von @ilovegym sind nicht gleich. Ich habe insbesondere die Log-Meldungen beim Senden erweitert und will sehen an welcher Stelle das schief geht.
                                      A.
                                        A.
                                        @asgothian
                                        mal eine Steckdose eingeschaltet:
                                        zigbee.0
                                        2024-10-20 11:28:58.451	debug	target: {"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1}},"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","stackVersion":0,"dateCode":""}},"seMetering":{"attributes":{"currentSummDelivered":[0,11339],"divisor":100,"multiplier":1}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":225,"rmsCurrent":0,"activePower":0}}},"deviceIeeeAddress":"0x60a423fffe651f06","deviceNetworkAddress":27808,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1}],"_configuredReportings":[{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null},{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x60a423fffe651f06"}}
                                        zigbee.0
                                        2024-10-20 11:28:58.451	debug	convert state, "ON", {}
                                        zigbee.0
                                        2024-10-20 11:28:58.451	debug	Type of toZigbee is 'object', Contains key ["zclcommand"]
                                        zigbee.0
                                        2024-10-20 11:28:58.451	debug	Type of toZigbee is 'object', Contains key ["reset"]
                                        zigbee.0
                                        2024-10-20 11:28:58.451	debug	Type of toZigbee is 'object', Contains key ["command"]
                                        zigbee.0
                                        2024-10-20 11:28:58.451	debug	Type of toZigbee is 'object', Contains key ["write"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["read"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["scene_rename"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["scene_remove_all"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["scene_remove"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["scene_add"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["scene_recall"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["scene_store"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["backlight_mode","indicator_mode"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["power_on_behavior","power_outage_memory"]
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]}
                                        zigbee.0
                                        2024-10-20 11:28:58.450	debug	Type of toZigbee is 'object', Contains key ["state","on_time","off_wait_time"]
                                        zigbee.0
                                        2024-10-20 11:28:58.449	debug	entity: 0x60a423fffe651f06 TS0121_plug {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":147,"_applicationVersion":65,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1}},"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","stackVersion":0,"dateCode":""}},"seMetering":{"attributes":{"currentSummDelivered":[0,11339],"divisor":100,"multiplier":1}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":225,"rmsCurrent":0,"activePower":0}}},"deviceIeeeAddress":"0x60a423fffe651f06","deviceNetworkAddress":27808,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1}],"_configuredReportings":[{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null},{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x60a423fffe651f06"}}],"_hardwareVersion":1,"_ieeeAddr":"0x60a423fffe651f06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728793934222,"_manufacturerID":4098,"_manufacturerName":"_TZ3000_g5xawfcq","_modelID":"TS0121","_networkAddress":27808,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":356340264}},"mapped":{"zigbeeModel":["TS0121"],"model":"TS0121_plug","description":"10A UK or 16A EU smart plug","whiteLabel":[{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"Connecte","model":"4500990"},{"vendor":"Connecte","model":"4500991"},{"vendor":"Connecte","model":"4500992"},{"vendor":"Connecte","model":"4500993"}],"vendor":"Tuya","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"options":[{"name":"measurement_poll_interval","label":"Measurement poll interval","access":2,"type":"numeric","property":"measurement_poll_interval","description":"This device does not support reporting electric measurements so it is polled instead. The default poll interval is 60 seconds, set to -1 to disable.","value_min":-1},{"name":"power_calibration","label":"Power calibration","access":2,"type":"numeric","property":"power_calibration","description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"name":"power_precision","label":"Power precision","access":2,"type":"numeric","property":"power_precision","description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"current_calibration","label":"Current calibration","access":2,"type":"numeric","property":"current_calibration","description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"name":"current_precision","label":"Current precision","access":2,"type":"numeric","property":"current_precision","description":"Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"voltage_calibration","label":"Voltage calibration","access":2,"type":"numeric","property":"voltage_calibration","description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"name":"voltage_precision","label":"Voltage precision","access":2,"type":"numeric","property":"voltage_precision","description":"Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"energy_calibration","label":"Energy calibration","access":2,"type":"numeric","property":"energy_calibration","description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."},{"name":"energy_precision","label":"Energy precision","access":2,"type":"numeric","property":"energy_precision","description":"Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},"[Circular]"],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"power","label":"Power","access":1,"type":"numeric","property":"power","description":"Instantaneous measured power","category":"diagnostic","unit":"W"},{"name":"current","label":"Current","access":1,"type":"numeric","property":"current","description":"Instantaneous measured electrical current","category":"diagnostic","unit":"A"},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Measured electrical potential value","category":"diagnostic","unit":"V"},{"name":"energy","label":"Energy","access":1,"type":"numeric","property":"energy","description":"Sum of consumed energy","unit":"kWh"},{"name":"power_outage_memory","label":"Power outage memory","access":7,"type":"enum","property":"power_outage_memory","description":"Recover state after power outage","values":["on","off","restore"]},{"name":"indicator_mode","label":"Indicator mode","access":7,"type":"enum","property":"indicator_mode","description":"LED indicator mode","values":["off","off/on","on/off"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x60a423fffe651f06"}
                                        zigbee.0
                                        2024-10-20 11:28:58.448	debug	publishFromState : 0x60a423fffe651f06 TS0121_plug [{"stateDesc":{"id":"state","prop":"state","name":"On/off state of the switch","role":"switch","write":true,"read":true,"type":"boolean","setattr":"state","readable":true,"writable":true},"value":true,"index":0,"timeout":0}]
                                        zigbee.0
                                        2024-10-20 11:28:58.445	debug	Change state 'state' at device 0x60a423fffe651f06 type 'TS0121_plug'
                                        zigbee.0
                                        2024-10-20 11:28:58.440	debug	User stateChange zigbee.0.60a423fffe651f06.state {"val":true,"ack":false,"ts":1729416538438,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1729416538438}
                                        Edit:
                                        dann kam das:
                                        zigbee.0
                                        2024-10-20 11:29:25.384	debug	DeviceAvailability:Non-pingable device 0x00158d00011083e8 lumi.sensor_cube was last seen '624802.431' seconds ago.
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                          @asgothian
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          Edit:
                                          dann kam das:
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          @ilovegym sagte in Test Adapter iobroker.Zigbee 1.10.10:
                                          @asgothian
                                          Das hilft leider so gar nicht.
                                          • Es ist nicht die von mir oben gewünschte Version mit den Zusatzausgaben
                                          • der Adapter läuft im Debug - sprich es werden viel zu viele Meldungen gespeichert.
                                          Bitte mach das was ich hier beschrieben habe.
                                          A.
