  4. JavaScript
  5. E3DC Hauskraftwerk steuern
3.6k Beiträge 73 Kommentatoren 2.1m Aufrufe 64 Beobachtet
  • P psrelax
    @arnod
    Ich hatte heute den ganzen Tag eine Entladesperre. Sollte doch eigentlich nicht sein, oder?
    2024-10-15 18:00:00.212  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.1.14 *******************
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: timerIds =
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: timerTarget = []
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: timerState = []
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: timerObjektID = []
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: besteLadezeit = Laden mit PV-Leistung
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: billigsterEinzelpreisBlock = 0.2861
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: billigsterBlockPreis = 0.2887
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: minStrompreis_48h = 0.2347
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Schwellwert Preisspitze = 0.5682
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Schwellwert hoher Strompreis =
    0.50
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Schwellwert niedriger Strompreis =
    0.10
    2024-10-15 18:00:00.213  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: schneeBedeckt = false
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Prognose PV-Leistung heute = 20.428800000000003 kWh
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Prognose PV-Leistung morgen = 39.58080000000001 kWh
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: batterieKapazitaet_kWh = 15
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Batterie_SOC = 48
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: prognoseLadezeitBatterie = 1
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: pvLeistungAusreichend = false
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: reichweiteBatterie = 4:60 h / 4:60 h
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: batteriepreisAktiv = true
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: strompreisBatterie = 0.2267
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: bruttoPreisBatterie = 0.2576
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Aktueller Preis Tibber = 0.3489
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: BatterieEntladenSperren = true
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: BatterieLaden = false
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Power_Bat_W = 0
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: Power_Grid = 668
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: eAutoLaden = true
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: naechsteNiedrigphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null}
    2024-10-15 18:00:00.214  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: naechsteHochphase = {"Startzeit":null,"Endzeit":null,"StartzeitLokal":null,"EndzeitLokal":null}
    2024-10-15 18:00:00.215  - info: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: preisPhasen = {"highPhases":[],"lowPhases":[]}
    2024-10-15 18:00:00.215  - warn: javascript.0 (18305) script.js.E3DC_ChargeControl.Tibber: ProgrammAblauf = 25,1,2,4,5,6,6,8,10,12,20,22,
    Nachtrag 16.10.2024
    Ich habe fast durchgehend eine Entladesperre. Was passt an meiner Einstellung nicht? :-(
    ArnoD
    #2844
    @psrelax
    Das hat nichts mit deinen Einstellungen zu tun, sondern mit meiner Zeit die Fehler zu beheben :-)
    Das Thema Entladesperre habe ich kurzfristig zurückgestellt, um mich erstmal auf die Fehler beim Laden zu konzentrieren.
    Es sind noch einige Situationen, wo das Laden nicht so funktioniert wie ich mir das vorstelle.
    Es wird aber jeden Tag besser und ich muss jetzt erstmal mein Script wieder aufräumen und alte Versuche entfernen, sonst wird es zu unstrukturiert und umso schwerer die Fehler zu finden.
    Nachtrag: Setze mal deinen Schwellwert hoher Strompreis auf 0,26€ dann denke ich sollte es so funktionieren wie du es erwartest.
    P 1 Antwort Letzte Antwort
    • A ArnoD
      @azzkikrboy sagte in E3DC Hauskraftwerk steuern:
      Könnte das an den Änderungen an den API-requests von Solcast liegen?
      Nein, wie der Fehlercode 429 bereits aussagt, liegt das an zu häufigen Verbindungsversuche.
      Ist dein Script kompatible mit der neuen Version des E3DC.RSCP adapter (1.3.x) ?
      Ja
      azzkikrboyA Offline
      azzkikrboyA Offline
      azzkikrboy
      #2845
      @arnod
      OK. Danke für die schnelle Antwort
        Abyss
        schrieb am zuletzt editiert von Abyss
        #2846
        Hallo @ArnoD
        sorry wenn ich in die Tibber-Diskussion so reingrätsche, aber mir ist grad ein möglicher Fehler im Heizstabscript aufgefallen.
        Wie es scheint wird für das Script ja der Datenpunkt '0_userdata.0.Charge_Control.Allgemein.Hausverbrauch' verwendet.
        Aus diesem wird aber nach meinem Verständnis im Charge-Control Script der Verbrauch einer Wärmepumpe, Wallbox und des Heizstabs rausgerechnet.
        Der Verbrauch der Wärmepumpe und der Wallbox dürfen in diesem Fall aber nicht rausgerechnet werden, da man sonst ja einen falschen Überschuss ermittelt, den es so gar nicht gibt.
        Das führt aktuell dazu, dass bei mir momentan der Heizstab mit einem vermeintlichen Übeschuss getriggert wird, den aber zeitgleich die Wärmepumpe nutzt und ich somit in einer Entladung der Batterie bzw. Netzbezug und einem ewigen hin und her lande.
        Vermutlich müsste man im Heizstabscript den Hausverbrauch neu berechnen um den reinen Überschuss zu ermitteln oder die Variable "Hausverbrauch_W" incl. Wärempumpe und Wallbox neu beschreiben?
        EDIT
        grad nochmal über das Script geschaut....die Wallbox wird scheinbar berücksichtigt, somit fehlt ansich nur noch der Verbrauch der Wärmepumpe...
        azzkikrboyA A 2 Antworten Letzte Antwort
        • A Abyss
          Hallo @ArnoD
          EDIT
          azzkikrboyA Offline
          azzkikrboyA Offline
          azzkikrboy
          #2847
          @abyss sagte in E3DC Hauskraftwerk steuern:
          Sorry, aber hier grätsche ich auch mal rein 😊
          Wo kommt dann der Verbrauch Wärmepumpe her, der rausgerechnet wird ?
          • A Abyss
            Hallo @ArnoD
            EDIT
            ArnoD
            #2848
            Ja, da hast du recht.
            Ist bis jetzt nicht aufgefallen, da anscheinend keiner eine WP hat und ich keinen Heizstab.
            Du bist der Erste, der beides hat. :-)
            Ich werde das im my-pv Heizstab Script anpassen, danke für den Hinweis.
            Nachtrag: Korrigierte Version auf Github hochgeladen. Kann es aber bei mir nicht testen.
            • A ArnoD
              @psrelax
              psrelax
              #2849
              @arnod
              Ich hab das einen Tag nach deiner Empfehlung auf 0,26 eingestellt.
              Macht irgendwie nicht wirklich einen Unterschied.
              Ich würde gerne testen und dir behilflich mit meinen Tests sein, weiß aber nicht wie, da ich praktisch nicht klar komme.
              Ich habe das Problem, dass ich nicht weiß, wenn ich das ändere, muss das Ergebnis kommen.
              Somit muss ich warten, bis du etwas änderst oder es von dir getestet ist.
                matze191174
                #2850
                hab mal eine Frage zu dem Log Eintrag.
                Was bedeuten eigentlich die Zahlen hinter "ProgrammAblauf"?
                2024-10-17 22:40:00.264 - warn: javascript.0 (351) script.js.common.tibber-skript: ProgrammAblauf = 25,1,2,4,5,6,9,11,24,28,
                • M matze191174
                  ArnoD
                  #2851
                  @matze191174
                  Das ist eine Hilfe, um zu erkennen, wie der Programmablauf war, um so schneller den Fehler zu finden.
                  Wenn man nicht davor sitzt, ist es sonst schwierig zu verstehen, warum der Code nicht funktioniert.
                  25 = Funktion zum Berechnen vom Batteriepreis durchlaufen
                  1 = Funktion tibberSteuerungHauskraftwerk()
                  2 = Reichweite der Batterie überprüft
                  usw.
                  • P psrelax
                    @arnod
                    ArnoD
                    #2852
                    @psrelax
                    Warte noch etwas mit dem testen.
                    Wenn es bei mir mal einigermaßen fehlerfrei läuft, macht das mehr Sinn.
                    Aktuell finde ich jeden Tag noch einige Fehler, die ich jetzt nach und nach korrigiere.
                    • A ArnoD
                      Abyss
                      #2853
                      @arnod
                      Danke für die schnelle Umsetzung.
                      Ich bin grad mal dabei es einzuspielen, scheinbar mag er aber die neue const "LeistungWP" nicht.
                      "cannot redeclare block scoped variable 'LeistungWP'"
                      Das führt dann zu einem Fehler beim Einlesen.
                      Ich hab die Variable mal in "LeistungLW_Pumpe" und die gefüllte Variabel in "LeistungLW_Pumpe_W" umbenannt, dann funktioniert es.
                      Ich teste...
                      // defintion which instances has to be used
                      const instanzE3DC_RSCP       = 'e3dc-rscp.0'
                      const instanzHeizstab_Modbus = 'modbus.1'
                      // E3DC Komponenten Definition
                      const sID_PV_Leistung       = `${instanzE3DC_RSCP}.EMS.POWER_PV`; // PV power
                      const sID_Netz_Leistung     = `${instanzE3DC_RSCP}.EMS.POWER_GRID`; // Grid power
                      const sID_Wallbox_Leistung  = `${instanzE3DC_RSCP}.EMS.POWER_WB_ALL`; // Wallbox power
                      const sID_Batterie_Leistung = `${instanzE3DC_RSCP}.EMS.POWER_BAT`; // Battery power
                      const sID_Power_Mode        = `${instanzE3DC_RSCP}.EMS.MODE`; // Power mode state
                      const sID_Batterie_Status   = `${instanzE3DC_RSCP}.EMS.BAT_SOC`; // Battery status state
                      const sID_Bat_Charge_Limit  = `${instanzE3DC_RSCP}.EMS.SYS_SPECS.maxBatChargePower`;// Batterie Ladelimit
                      // selbst definierte Variablen
                      const sID_Eigenverbrauch    = '0_userdata.0.Charge_Control.Allgemein.Hausverbrauch'; 					// Household consumption power
                      const sID_M_Power_W         = '0_userdata.0.Charge_Control.Allgemein.Akt_Berechnete_Ladeleistung_W'; 	// Calculated required charging power
                      const sID_LeistungLW_Pumpe_W = 'shelly.0.shellypro3em#a0dd6ca0bf44#1.EM0.TotalActivePower';                   // Pfad zu den Leistungswerte Wärmepumpe eintragen ansonsten leer lassen
                      // Heistab Modbus Variablen
                      const sID_LeistungHeizstab_W        = `${instanzHeizstab_Modbus}.holdingRegisters.41001_Power`; // Current power consumption of heating element in W
                      const sID_Soll_LeistungHeizstab_W   = `${instanzHeizstab_Modbus}.holdingRegisters.41001_Power`; // Target heating element power
                      const sID_IstTempHeizstab           = `${instanzHeizstab_Modbus}.holdingRegisters.41002_Temp1`; // Current temperature at the heating element
                      const sID_MaxTempHeizstab           = `${instanzHeizstab_Modbus}.holdingRegisters.41003_WW1_Temp_max`; // Maximum temperature
                      // Heistab states manuell zu erstellen für Statistikwerte
                      const sID_previousHeizstabLeistung_W    = '0_userdata.0.Heizung.E3DC.previousHeizstabLeistung'; // Previous heating element load power
                      const sID_Heizstab_Gesamtenergie        = '0_userdata.0.Heizung.E3DC.Heizstab_Gesamtenergie'; // Cumulative energy
                      const sID_Heizstab_LetzteAktualisierung = '0_userdata.0.Heizung.E3DC.Heizstab_LetzteAktualisierung'; // Last update
                      // Defintion von Heizstabparametern und Sicherheitsmechanismen
                      const debounceInterval          = 3000; // Minimum interval between updates in milliseconds
                      const temperatureBuffer         = 3;    // Buffer in degrees Celsius to prevent frequent on/off cycling
                      const minimumHeizstabLeistung   = 300;  // Minimum power for heating element
                      const sicherheitspuffer         = 300;  // Safety buffer to avoid frequent switching
                      const MaximalLeistungHeizstab_W = 3000; // Maximum power in watt of the heating element
                      let debounceTimer;
                      async function fetchAndUpdateHeizstabLeistung() {
                          try {
                              // Zustände abfragen
                              const states = await Promise.all([
                                  getStateAsync(sID_Wallbox_Leistung),
                                  getStateAsync(sID_Netz_Leistung),
                                  getStateAsync(sID_LeistungHeizstab_W),
                                  getStateAsync(sID_Eigenverbrauch),
                                  getStateAsync(sID_M_Power_W),
                                  getStateAsync(sID_Batterie_Leistung),
                                  getStateAsync(sID_IstTempHeizstab),
                                  getStateAsync(sID_MaxTempHeizstab),
                                  getStateAsync(sID_PV_Leistung),
                                  getStateAsync(sID_Soll_LeistungHeizstab_W),
                                  getStateAsync(sID_Power_Mode),
                                  getStateAsync(sID_Batterie_Status),
                                  getStateAsync(sID_Bat_Charge_Limit),
                      			getStateAsync(sID_LeistungLW_Pumpe_W)
                              const [
                                  Wallbox_Leistung, Netz_Leistung, LeistungHeizstab, Eigenverbrauch, M_Power, Batterie_Leistung,
                                  IstTempHeizstab, MaxTempHeizstab, PV_Leistung, SollLeistungHeizstab,
                                  Power_Mode, Batterie_Status, Bat_Charge_Limit, LeistungLW_Pumpe
                              ] = states;
                              // Ensure all states are fetched correctly
                              const stateNames = [
                                  'Wallbox_Leistung', 'Netz_Leistung', 'LeistungHeizstab', 'Eigenverbrauch', 'M_Power', 'Batterie_Leistung',
                                  'IstTempHeizstab', 'MaxTempHeizstab', 'PV_Leistung', 'SollLeistungHeizstab',
                                  'Power_Mode', 'Batterie_Status', 'Bat_Charge_Limit', 'LeistungLW_Pumpe'
                              stateNames.forEach((name, index) => {
                                  if (states[index] === null || states[index] === undefined) {
                                      console.error(`State ${name} is null or undefined`);
                              if (states.some(state => state === null || state === undefined)) {
                                  throw new Error('One or more states are null or undefined');
                              // Werte extrahieren
                              let [
                                  Wallbox_Leistung_W, NetzLeistung_W, LeistungHeizstab_W, Hausverbrauch_W, M_Power_W, BatterieLeistung_W,
                                  IstTemp, MaxTemp, PV_Leistung_W, SollLeistungHeizstab_W,
                                  PowerMode, BatterieStatus, Charge_Limit, LeistungLW_Pumpe_W
                              ] = states.map(state => state.val);
                              console.log(`Zustände abgefragt: Netz=${NetzLeistung_W}W, PV=${PV_Leistung_W}W, Hausverbrauch=${Hausverbrauch_W}W, LeistungHeizstab=${LeistungHeizstab_W}W, Batterie=${BatterieLeistung_W}W, IstTemp=${IstTemp}°C, MaxTemp=${MaxTemp}°C, SollLeistungHeizstab=${SollLeistungHeizstab_W}W, PowerMode=${PowerMode}, BatterieStatus=${BatterieStatus}, Charge_Limit=${Charge_Limit}, M_Power_W=${M_Power_W}W, LeistungWP = ${LeistungLW_Pumpe_W}W`);
                              // Bedingungen prüfen
                              if (PowerMode === 2 && Charge_Limit == M_Power_W && BatterieLeistung_W > 0) {
                                  console.log('Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.');
                                  await setStateAsync(sID_Soll_LeistungHeizstab_W, 0);
                                  return;
                              // Verfügbaren Überschuss berechnen
                              let verfuegbarerUeberschuss_W = PV_Leistung_W - Hausverbrauch_W - M_Power_W- Wallbox_Leistung_W - LeistungLW_Pumpe_W - sicherheitspuffer; // Verfügbarer Überschuss unter Berücksichtigung von PV-Leistung, Hausverbrauch, Wärmepumpe, Soll-Ladeleistung und Sicherheitspuffer
                              verfuegbarerUeberschuss_W = Math.max(verfuegbarerUeberschuss_W, 0); // Stellen Sie sicher, dass der Wert nicht negativ wird
                              // Heizstab-Leistung bestimmen
                              let HeizstabLadeleistung_W = 0;
                              if (IstTemp < MaxTemp - temperatureBuffer && verfuegbarerUeberschuss_W >= minimumHeizstabLeistung) { // Stellen Sie sicher, dass die Temperaturbedingung mit Puffer erfüllt ist und die Mindestleistung verfügbar ist
                                  HeizstabLadeleistung_W = Math.min(verfuegbarerUeberschuss_W, MaximalLeistungHeizstab_W); // Begrenzen Sie auf 3000W oder verfügbare Energie
                              } else {
                                  HeizstabLadeleistung_W = 0; // Heizstab ausschalten, wenn die Bedingungen nicht erfüllt sind
                              await setStateAsync(sID_Soll_LeistungHeizstab_W, HeizstabLadeleistung_W);
                              // Aktualisiere den vorherigen Wert der Heizstabladeleistung
                              await setStateAsync(sID_previousHeizstabLeistung_W, HeizstabLadeleistung_W);
                              // Kumulierte Energieberechnung, Aktualisierung und Logging
                              const jetzt = Date.now();
                              const letzteAktualisierung = await getStateAsync(sID_Heizstab_LetzteAktualisierung);
                              const vergangeneZeitInStunden = (jetzt - (letzteAktualisierung.val || 0)) / (1000 * 60 * 60);
                              const verbrauchteEnergie = (LeistungHeizstab_W * vergangeneZeitInStunden) / 1000; // In kWh umrechnen
                              const aktuelleGesamtenergie = (await getStateAsync(sID_Heizstab_Gesamtenergie)).val || 0;
                              const neueGesamtenergie = aktuelleGesamtenergie + verbrauchteEnergie;
                              await setStateAsync(sID_Heizstab_Gesamtenergie, neueGesamtenergie);
                              await setStateAsync(sID_Heizstab_LetzteAktualisierung, jetzt);
                              console.log(`Update: Netz=${NetzLeistung_W}W, PV=${PV_Leistung_W}W, Heizstab=${HeizstabLadeleistung_W}W, Überschuss=${verfuegbarerUeberschuss_W}W`);
                          } catch (error) {
                              // @ts-ignore
                              console.error('Fehler bei der Aktualisierung der Heizstab-Leistung:', error.message);
                              console.error(error.stack);
                      function debounceUpdate() {
                          if (debounceTimer) return;
                          fetchAndUpdateHeizstabLeistung();
                          debounceTimer = setTimeout(() => {
                              debounceTimer = null;
                          }, debounceInterval);
                      // Register listeners for relevant state changes
                      const ids = [
                          sID_Wallbox_Leistung,
                          sID_PV_Leistung,
                          sID_Netz_Leistung,
                          sID_Eigenverbrauch,
                          sID_Batterie_Leistung,
                          sID_LeistungHeizstab_W,
                          sID_M_Power_W,
                          sID_Power_Mode,
                          sID_Batterie_Status
                      ids.forEach(id => {
                          on({ id, change: "ne" }, debounceUpdate);
                          console.log(`Listener registered for ${id}`);
                      // Initial call
                      Gestern sind mir noch zwei Punkte aufgefallen:
                      • wenn der Akku auf 100% steht, bleibt "M_Power_W" bei 3000 hängen (max. Batterieladung bei meiner S10), somit fehlen diese 3000W bei der Berechnung von "verfuegbarerUeberschuss_W"
                      • und vor allem Vormittags wird der Heizstab blockiert mit der Meldung "Power_Mode ist 2" um die Batterieladung zu priorisieren. Das ist grundsätzlich toll, führt aber bei Sonne dazu, dass dann mit 3000-4000W eingespeist wird, was man aber besser in den Heizstab umleiten könnte.
                        Evtl. könnte man hier noch eine Prüfung reinmachen, dass wenn Einspeisung > 1000W dann ignoriere Power_Mode 2 oder sowas in der Art?
                      @azzkikrboy
                      Ich habe an meiner Wärmepumpe einen Shelli 3EM Pro hängen der mir die Leistung der Wärmepumpe ermittelt.
                      Das wird dann im Charge-Control in "sID_LeistungLW_Pumpe_W" eingetragen um diese dann aus dem eigentlichen Hausverbrauch rauszurechnen und die Leistungswerte separat darstellen zu können.
                      • R Offline
                        Ronniboy
                        #2854
                        Hallo Zusammen,
                        erstmal ein dickes LOB für die Entwicklung von E3DC Control
                        Mein neuer Stromtarif rechnet in dem Zeitraum 0.00 – 5:00 Uhr mit 8,48 €/kwh.
                        Ich möchte programmmäßig über den IOBROKER und mit RSCP folgende Befehle anstoßen:
                        1.) Zu einem bestimmten Zeitpunkt das „manuelle Speicherladen“ aus dem Netz anstoßen
                        2.) Festlegen der gewünschten Energiemenge
                        3.) Batteriespeicher Entladung sperren/freigeben
                        Hat das jemand mit IOBROKER umgesetzt?
                        Das Programm e3dc-control wollte ich nicht einsetzen, erscheint mir für meine Bedürfnisse zu umfangreich.
                        Oder gibt es eine fertige Alternative ,etwa eine E3DC Control light Version?
                        LG Ronald
                          ArnoD
                          #2855
                          Ja, mein Fehler habe das _W bei LeistungWP vergessen, so wäre es richtig: LeistungWP_W.
                          Habe ich korrigiert. M_Power_W ist nur relevant, wenn PowerMode auf 2 (Charge) steht.
                          Vermute, das passiert jedes Mal, wenn E3DC die Regelung übernimmt und die Batterie geladen wird, dann wird M_Power nicht mehr aktualisiert und bleibt auf dem max. Wert stehen. In dem Fall müsste M_Power die aktuelle Ladeleistung der Batterie enthalten, damit die Berechnung vom Überschuss wieder stimmt.
                          Das Problem wird hier wieder die Trägheit der Regelung sein, sodass dann ständig zwischen Regelung E3DC und Script gewechselt wird.
                          Ich kann es ja mal einbauen und du kannst dann testen, ob das was bringt.
                          Nachtrag: neue Version auf Github hochgeladen. Kannst du das bei Gelegenheit mal testen.
                          • R Ronniboy
                            Hallo Zusammen,
                            LG Ronald
                            ArnoD
                            #2856
                            @ronniboy
                            Kann man sicher mit einem Script und dem e3dc-rscp Adapter umsetzen, aber eine fertige Lösung, die deine Wünsche erfüllt, kenne ich nicht.
                            Das ist auch so speziell, dass es nur wenige überhaupt brauchen werden.
                            R 1 Antwort Letzte Antwort
                            • A ArnoD
                              Abyss
                              #2857
                              @arnod
                              Danke.
                              Habs soeben eingepsielt, startet ohne Fehler. ;)
                              Ich werds die kommenden Tage beobachten und hoffe auf mehr Sonne.
                              Grüße und schöne Wochenende ;)
                              • A ArnoD
                                @ronniboy
                                Ronniboy
                                schrieb am zuletzt editiert von Ronniboy
                                #2858
                                @arnod sagte in E3DC Hauskraftwerk steuern:
                                @ronniboy
                                das habe ich schon gedacht das es keine fertige Lösung gibt.
                                aber so ganz speziell ist das Programm doch gar nicht.
                                Bedingung:
                                In der Zeit von 0:00 - 5:00 Speicher mit max 3000 Watt laden bis SOC max 90%
                                Täglich in der Zeit von 5:00 bis 9:00 Entladesperre setzen. (könnte ich auch über die App einstellen)
                                Was ich benötige
                                welche Datenpunkte im RSCP sind für
                                Befehl ->Speicher laden aus dem Netz
                                Befehl -> Speicher mit max ???? W laden
                                Befehl -> Entladessperre setzen
                                Diese Info müssen doch in dem E3DC Control doch irgendwo umgesetzt worden sein.
                                • R Ronniboy
                                  @ronniboy
                                  Bedingung:
                                  Was ich benötige
                                  ArnoD
                                  #2859
                                  @ronniboy
                                  Nicht das Programm, sondern der Anwendungsfall ist speziell.
                                  Speicher laden aus dem Netz: e3dc-rscp.0.EMS.SET_POWER_MODE == 4 und e3dc-rscp.0.EMS.SET_POWER_VALUE alle 4 sek. die Ladeleistung eintragen.
                                  Speicher mit max ???? W laden musst du in deinem Script selber überwachen und dann einfach keine Werte mehr übertragen.
                                  Entladesperre setzen: e3dc-rscp.0.EMS.SET_POWER_MODE == 1 und e3dc-rscp.0.EMS.SET_POWER_VALUE alle 4 sek. den Wert 0 eintragen (Hier wird aber dann Laden und Entladen gesperrt)
                                  • A Abyss
                                    @arnod
                                    Danke.
                                    Abyss
                                    #2860
                                    @ArnoD
                                    Momentan hat das Script leider das Verhalten, dass es ständig an und ausgeht.
                                    Sobald Leistung in den Heizstab umgeleitet wird kommt als nächstes der Power-Mode 2 und schaltet direkt wieder aus
                                    19.10.2024, 12:23:12.718	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2829W, PV=6740W, Hausverbrauch=1010W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.5°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:12.805	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:23:12.848	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2829W, PV=6740W, Heizstab=2532.735W, Überschuss=2532.735W
                                    19.10.2024, 12:23:16.726	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-578W, PV=6748W, Hausverbrauch=1006W, LeistungHeizstab=2286W, Batterie=2892W, IstTemp=54.5°C, MaxTemp=61°C, SollLeistungHeizstab=2286W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:16.726	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:23:20.722	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2851W, PV=6739W, Hausverbrauch=989W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.6°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:20.769	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:23:20.811	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2851W, PV=6739W, Heizstab=2552.735W, Überschuss=2552.735W
                                    19.10.2024, 12:23:24.217	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-536W, PV=6733W, Hausverbrauch=3299W, LeistungHeizstab=2301W, Batterie=2892W, IstTemp=54.6°C, MaxTemp=61°C, SollLeistungHeizstab=2301W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:24.217	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:23:28.724	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2847W, PV=6740W, Hausverbrauch=1008W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.6°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:28.796	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:23:28.839	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2847W, PV=6740W, Heizstab=2534.516W, Überschuss=2534.516W
                                    19.10.2024, 12:23:32.724	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-527W, PV=6690W, Hausverbrauch=1009W, LeistungHeizstab=2283W, Batterie=2892W, IstTemp=54.6°C, MaxTemp=61°C, SollLeistungHeizstab=2283W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:32.724	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:23:36.719	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2713W, PV=6671W, Hausverbrauch=1017W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.7°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:36.766	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:23:36.809	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2713W, PV=6671W, Heizstab=2456.516W, Überschuss=2456.516W
                                    19.10.2024, 12:23:40.764	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-564W, PV=6652W, Hausverbrauch=3257W, LeistungHeizstab=2213W, Batterie=2892W, IstTemp=54.7°C, MaxTemp=61°C, SollLeistungHeizstab=2213W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:40.764	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:23:44.688	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2809W, PV=6715W, Hausverbrauch=991W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.7°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:44.773	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:23:44.817	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2809W, PV=6715W, Heizstab=2526.415W, Überschuss=2526.415W
                                    19.10.2024, 12:23:48.687	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-556W, PV=6718W, Hausverbrauch=987W, LeistungHeizstab=2277W, Batterie=2892W, IstTemp=54.7°C, MaxTemp=61°C, SollLeistungHeizstab=2277W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:48.687	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:23:52.728	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2768W, PV=6685W, Hausverbrauch=997W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.7°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:52.775	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:23:52.818	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2768W, PV=6685W, Heizstab=2490.415W, Überschuss=2490.415W
                                    19.10.2024, 12:23:56.114	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-451W, PV=6627W, Hausverbrauch=3277W, LeistungHeizstab=2243W, Batterie=2892W, IstTemp=54.7°C, MaxTemp=61°C, SollLeistungHeizstab=2243W, PowerMode=2, BatterieStatus=67, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:23:56.114	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:00.686	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2670W, PV=6548W, Hausverbrauch=1001W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.8°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:00.810	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:00.853	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2670W, PV=6548W, Heizstab=2349.364W, Überschuss=2349.364W
                                    19.10.2024, 12:24:04.622	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-567W, PV=6563W, Hausverbrauch=3097W, LeistungHeizstab=2121W, Batterie=2892W, IstTemp=54.8°C, MaxTemp=61°C, SollLeistungHeizstab=2121W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:04.622	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:08.727	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2736W, PV=6629W, Hausverbrauch=1010W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.8°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:08.773	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:08.816	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2736W, PV=6629W, Heizstab=2421.364W, Überschuss=2421.364W
                                    19.10.2024, 12:24:12.058	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-571W, PV=6646W, Hausverbrauch=3176W, LeistungHeizstab=2188W, Batterie=2892W, IstTemp=54.9°C, MaxTemp=61°C, SollLeistungHeizstab=2188W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:12.058	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:16.731	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2834W, PV=6755W, Hausverbrauch=1026W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=54.9°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:16.777	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:16.820	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2834W, PV=6755W, Heizstab=2531.482W, Überschuss=2531.482W
                                    19.10.2024, 12:24:20.554	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-586W, PV=6753W, Hausverbrauch=3268W, LeistungHeizstab=2277W, Batterie=2892W, IstTemp=54.9°C, MaxTemp=61°C, SollLeistungHeizstab=2277W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:20.554	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:24.725	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2804W, PV=6661W, Hausverbrauch=997W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:24.771	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:24.813	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2804W, PV=6661W, Heizstab=2466.482W, Überschuss=2466.482W
                                    19.10.2024, 12:24:27.944	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-519W, PV=6635W, Hausverbrauch=3217W, LeistungHeizstab=2219W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=2219W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:27.944	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:32.726	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2706W, PV=6605W, Hausverbrauch=1007W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:32.814	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:32.857	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2706W, PV=6605W, Heizstab=2400.095W, Überschuss=2400.095W
                                    19.10.2024, 12:24:36.495	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-548W, PV=6594W, Hausverbrauch=3147W, LeistungHeizstab=2162W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=2162W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = [object Object]W
                                    19.10.2024, 12:24:36.495	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:36.774	[info ]: javascript.0 (49474) Stopping script script.js.VIS-Script.my-pv_Heizstab_ArnoD
                                    19.10.2024, 12:24:36.858	[info ]: javascript.0 (49474) Start JavaScript script.js.VIS-Script.my-pv_Heizstab_ArnoD (Javascript/js)
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for e3dc-rscp.0.EMS.POWER_WB_ALL
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for e3dc-rscp.0.EMS.POWER_PV
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for e3dc-rscp.0.EMS.POWER_GRID
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for 0_userdata.0.Charge_Control.Allgemein.Hausverbrauch
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for e3dc-rscp.0.EMS.POWER_BAT
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for modbus.1.holdingRegisters.41001_Power
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for 0_userdata.0.Charge_Control.Allgemein.Akt_Berechnete_Ladeleistung_W
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for e3dc-rscp.0.EMS.MODE
                                    19.10.2024, 12:24:36.866	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Listener registered for e3dc-rscp.0.EMS.BAT_SOC
                                    19.10.2024, 12:24:36.867	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: registered 9 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    19.10.2024, 12:24:36.909	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-554W, PV=6599W, Hausverbrauch=3147W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.905W
                                    19.10.2024, 12:24:36.909	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:38.726	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2736W, PV=6624W, Hausverbrauch=3147W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.905W
                                    19.10.2024, 12:24:38.772	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:38.815	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2736W, PV=6624W, Heizstab=0W, Überschuss=279.095W
                                    19.10.2024, 12:24:42.767	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2706W, PV=6601W, Hausverbrauch=1012W, LeistungHeizstab=0W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.905W
                                    19.10.2024, 12:24:42.813	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:42.856	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2706W, PV=6601W, Heizstab=2391.095W, Überschuss=2391.095W
                                    19.10.2024, 12:24:46.730	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-520W, PV=6572W, Hausverbrauch=3146W, LeistungHeizstab=2157W, Batterie=2892W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=2157W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.905W
                                    19.10.2024, 12:24:46.730	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:50.730	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2680W, PV=6564W, Hausverbrauch=982W, LeistungHeizstab=0W, Batterie=2898W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.434W
                                    19.10.2024, 12:24:50.776	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:50.818	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2680W, PV=6564W, Heizstab=2378.566W, Überschuss=2378.566W
                                    19.10.2024, 12:24:54.554	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-484W, PV=6572W, Hausverbrauch=3184W, LeistungHeizstab=2152W, Batterie=2898W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=2152W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.434W
                                    19.10.2024, 12:24:54.554	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:24:58.739	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2696W, PV=6579W, Hausverbrauch=972W, LeistungHeizstab=0W, Batterie=2898W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.434W
                                    19.10.2024, 12:24:58.837	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:24:58.879	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2696W, PV=6579W, Heizstab=2403.566W, Überschuss=2403.566W
                                    19.10.2024, 12:25:02.745	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-506W, PV=6597W, Hausverbrauch=3153W, LeistungHeizstab=2169W, Batterie=2898W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=2169W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.434W
                                    19.10.2024, 12:25:02.745	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    19.10.2024, 12:25:06.733	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-2664W, PV=6564W, Hausverbrauch=982W, LeistungHeizstab=0W, Batterie=2898W, IstTemp=55°C, MaxTemp=61°C, SollLeistungHeizstab=0W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 5.77W
                                    19.10.2024, 12:25:06.778	[warn ]: javascript.0 (49474)     at fetchAndUpdateHeizstabLeistung (script.js.VIS-Script.my-pv_Heizstab_ArnoD:130:15)
                                    19.10.2024, 12:25:06.821	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Update: Netz=-2664W, PV=6564W, Heizstab=2378.23W, Überschuss=2378.23W
                                    19.10.2024, 12:25:10.454	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Zustände abgefragt: Netz=-513W, PV=6541W, Hausverbrauch=3123W, LeistungHeizstab=2146W, Batterie=2898W, IstTemp=55.1°C, MaxTemp=61°C, SollLeistungHeizstab=2146W, PowerMode=2, BatterieStatus=68, Charge_Limit=3000, M_Power_W=3000W, LeistungWP = 11.473W
                                    19.10.2024, 12:25:10.454	[info ]: javascript.0 (49474) script.js.VIS-Script.my-pv_Heizstab_ArnoD: Power_Mode ist 2 und Batterie soll mit max. Leistung geladen werden. Heizstab wird nicht aktiviert.
                                    Beim Console-Log war noch das Objekt für die LeistungWP falsch, das hab ich angepasst. hier fehlt ein _W
                                    • A ArnoD
                                      @ronniboy
                                      Ronniboy
                                      #2861
                                      @arnod
                                      das sieht doch gut aus
                                      werde ich ausprobieren
                                      Vielen Dank
                                      Könnte ich für mein Anwendungsfall auch E3DC-Contol verwenden?
                                      • P Offline
                                        psrelax
                                        #2862
                                        @ArnoD
                                        Ich habe heute Nacht einmal getestet, ob die Notstrom Nachladefunktion noch funktioniert.
                                        Dem ist anscheinend nicht so.
                                        Vielleicht kannst du dir das bei Gelegenheit einmal anschauen :-)
                                        • A Abyss
                                          @ArnoD
                                          ArnoD
                                          #2863
                                          @abyss
                                          Erhöhe mal bitte oben im Script unter // Defintion von Heizstabparametern und Sicherheitsmechanismen den sicherheitspuffer auf 500 W und teste dann, ob es funktioniert.
