  4. [gelöst] Zigbee Blackout
    1.0k
    6.1k
problemverbindungzigbee
24 Beiträge 8 Kommentatoren 3.4k Aufrufe 7 Beobachtet
  • R Offline
    Rushmed
    schrieb am zuletzt editiert von Rushmed
    seit drei Tagen baut mien Zigbee Netzwerk welches vorher solide lief massiv ab. Aktuell funktioniert quasi nichts mehr.
    Im LOG bekomme ich Folgende Meldungen:
    zigbee.0
    2024-10-11 23:41:47.616	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
    zigbee.0
    2024-10-11 23:40:05.547	error	Error 225 on send command to 0x000b57fffe349293. Error: Error: ZCL command 0x000b57fffe349293/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:39:56.823	error	Error 225 on send command to 0x000b57fffe349293. Error: Error: ZCL command 0x000b57fffe349293/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:39:47.653	error	Error 225 on send command to 0x000b57fffe349293. Error: Error: ZCL command 0x000b57fffe349293/1 genLevelCtrl.moveToLevelWithOnOff({"level":2,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:39:33.887	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":223,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:39:25.229	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":208,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:39:16.086	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":106,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:39:06.703	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":63,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:38:24.568	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:38:15.820	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:38:08.976	info	Zigbee: stop joining
    zigbee.0
    2024-10-11 23:37:35.535	info	Device '0x00178801099f4997' announced itself
    zigbee.0
    2024-10-11 23:37:07.717	info	Zigbee: allowing new devices to join.
    zigbee.0
    2024-10-11 23:36:49.360	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
    zigbee.0
    2024-10-11 23:28:52.732	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-10-11 23:27:45.063	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
    zigbee.0
    2024-10-11 23:25:50.741	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
    zigbee.0
    2024-10-11 23:25:14.606	info	Zigbee: stop joining
    LOG vom Adapterstart:
    zigbee.0
    2024-10-11 23:46:40.087	warn	DeviceAvailability:Failed to ping 0x0017880106c1f6e4 LWE002
    zigbee.0
    2024-10-11 23:46:39.870	warn	DeviceAvailability:Failed to ping 0x50325ffffe452f8f TRADFRI Driver 10W
    zigbee.0
    2024-10-11 23:46:35.273	warn	DeviceAvailability:Failed to ping 0x00178801099a727d LWE002
    zigbee.0
    2024-10-11 23:46:35.209	warn	DeviceAvailability:Failed to ping 0x003c84fffeb5efd7 TRADFRIbulbE27WSglobeclear806lm
    zigbee.0
    2024-10-11 23:46:34.518	warn	DeviceAvailability:Failed to ping 0xec1bbdfffed4493f TRADFRI bulb E27 WW 806lm
    zigbee.0
    2024-10-11 23:46:33.862	warn	DeviceAvailability:Failed to ping 0x003c84fffe2e20b6 TRADFRIbulbE27WSglobeclear806lm
    zigbee.0
    2024-10-11 23:46:33.760	warn	DeviceAvailability:Failed to ping 0x001788010bd75cd7 LWA009
    zigbee.0
    2024-10-11 23:46:33.442	warn	DeviceAvailability:Failed to ping 0xec1bbdfffe94bbcb TRADFRI bulb E14 WS opal 600lm
    zigbee.0
    2024-10-11 23:46:32.964	warn	DeviceAvailability:Failed to ping 0x5c0272fffe92177a TRADFRI Driver 30W
    zigbee.0
    2024-10-11 23:46:32.079	warn	DeviceAvailability:Failed to ping 0xb4e3f9fffea666ae TRADFRI Driver 30W
    zigbee.0
    2024-10-11 23:46:25.655	warn	DeviceAvailability:Failed to ping 0x086bd7fffe3ed067 TRADFRI Driver 30W
    zigbee.0
    2024-10-11 23:46:25.611	warn	DeviceAvailability:Failed to ping 0x50325ffffe35f6e1 TRADFRI Driver 10W
    zigbee.0
    2024-10-11 23:46:18.381	warn	DeviceAvailability:Failed to ping 0x001788010c314523 LWA017
    zigbee.0
    2024-10-11 23:46:18.325	warn	DeviceAvailability:Failed to ping 0x5c0272fffe88b629 FLOALT panel WS 60x60
    zigbee.0
    2024-10-11 23:46:18.294	warn	DeviceAvailability:Failed to ping 0xccccccfffedbebdc TRADFRI bulb E27 WW 806lm
    zigbee.0
    2024-10-11 23:46:18.181	warn	DeviceAvailability:Failed to ping 0xec1bbdfffeb19154 TRADFRI bulb E27 WW 806lm
    zigbee.0
    2024-10-11 23:46:18.103	warn	DeviceAvailability:Failed to ping 0x00178801099f4997 LWA009
    zigbee.0
    2024-10-11 23:46:17.993	warn	DeviceAvailability:Failed to ping 0x0017880108ff0d07 LWA009
    zigbee.0
    2024-10-11 23:46:17.812	warn	DeviceAvailability:Failed to ping 0x000b57fffe349293 TRADFRI bulb E27 opal 1000lm
    zigbee.0
    2024-10-11 23:46:17.753	warn	DeviceAvailability:Failed to ping 0xa4c13830a258e9b4 TS011F
    zigbee.0
    2024-10-11 23:46:07.996	info	Method "deleteDevice" is deprecated and will be removed in js-controller 7, use "delObject" instead
    zigbee.0
    2024-10-11 23:46:07.994	info	Method "deleteDevice" is deprecated and will be removed in js-controller 7, use "delObject" instead
    zigbee.0
    2024-10-11 23:46:07.835	info	Method "deleteDevice" is deprecated and will be removed in js-controller 7, use "delObject" instead
    zigbee.0
    2024-10-11 23:46:05.318	info	debug devices set to []
    zigbee.0
    2024-10-11 23:46:05.285	info	deregister device Ping for deactivated device "0xa4c138fa74651615"
    zigbee.0
    2024-10-11 23:46:05.283	info	deregister device Ping for deactivated device "0xa4c1381f329e8ab8"
    zigbee.0
    2024-10-11 23:46:05.282	info	deregister device Ping for deactivated device "0xa4c13844911e10c6"
    zigbee.0
    2024-10-11 23:46:05.282	info	deregister device Ping for deactivated device "0xa4c1380dab82a533"
    zigbee.0
    2024-10-11 23:46:05.263	info	deregister device Ping for deactivated device "0xa4c138ba26206f69"
    zigbee.0
    2024-10-11 23:46:05.262	info	deregister device Ping for deactivated device "0xa4c1389a9a95cc10"
    zigbee.0
    2024-10-11 23:46:05.260	info	deregister device Ping for deactivated device "0x00158d0002f26d49"
    zigbee.0
    2024-10-11 23:46:05.258	info	deregister device Ping for deactivated device "0x00178801090ed414"
    zigbee.0
    2024-10-11 23:46:05.257	info	deregister device Ping for deactivated device "0x00178801090ed9c2"
    zigbee.0
    2024-10-11 23:46:05.256	info	deregister device Ping for deactivated device "0x00178801090c125a"
    zigbee.0
    2024-10-11 23:46:05.249	info	deregister device Ping for deactivated device "0xa4c138c1782d2a29"
    zigbee.0
    2024-10-11 23:46:05.248	info	deregister device Ping for deactivated device "0x00178801090c0c72"
    zigbee.0
    2024-10-11 23:46:05.233	info	deregister device Ping for deactivated device "0xcc86ecfffe1183fc"
    zigbee.0
    2024-10-11 23:46:05.217	info	deregister device Ping for deactivated device "0xa4c138a481b709c3"
    zigbee.0
    2024-10-11 23:46:04.830	info	Zigbee started
    zigbee.0
    2024-10-11 23:46:04.829	info	0x881a14fffef103da (addr 25258): E2202 - IKEA BADRING water leakage sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.827	info	0x881a14fffef0d0e8 (addr 8978): E2202 - IKEA BADRING water leakage sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.826	info	0x881a14fffef0f450 (addr 3529): E2202 - IKEA BADRING water leakage sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.824	info	0x086bd7fffe3ed067 (addr 29080): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
    zigbee.0
    2024-10-11 23:46:04.822	info	0x00158d000aca4051 (addr 27563): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.820	info	0xa4c138fa74651615 (addr 26739): A1Z - Nous Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-10-11 23:46:04.818	info	0xa4c1381f329e8ab8 (addr 29515): A1Z - Nous Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-10-11 23:46:04.816	info	0xa4c13844911e10c6 (addr 49722): A1Z - Nous Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-10-11 23:46:04.813	info	0xa4c1380dab82a533 (addr 25470): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
    zigbee.0
    2024-10-11 23:46:04.811	info	0xa4c138ba26206f69 (addr 34894): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
    zigbee.0
    2024-10-11 23:46:04.809	info	0xa4c1389a9a95cc10 (addr 14994): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
    zigbee.0
    2024-10-11 23:46:04.806	info	0x00158d0008d07e4c (addr 47919): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.805	info	0x50325ffffe35f6e1 (addr 11713): ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 10 w (Router)
    zigbee.0
    2024-10-11 23:46:04.803	info	0x00158d0002f26d49 (addr 32660): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.801	info	0x50325ffffe452f8f (addr 15995): ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 10 w (Router)
    zigbee.0
    2024-10-11 23:46:04.800	info	0x0017880106c1f6e4 (addr 54856): 9290020399 - Philips Hue white E14 (Router)
    zigbee.0
    2024-10-11 23:46:04.799	info	0x00178801090ed414 (addr 51894): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
    zigbee.0
    2024-10-11 23:46:04.797	info	0x00178801090ed9c2 (addr 58928): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
    zigbee.0
    2024-10-11 23:46:04.795	info	0x00178801090c125a (addr 52884): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
    zigbee.0
    2024-10-11 23:46:04.791	info	0x00158d0008d07e48 (addr 11592): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.789	info	0x00158d000838096f (addr 63520): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.788	info	0x54ef44100042afab (addr 58829): WXCJKG12LM - Aqara Opple wireless switch (double band) (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.786	info	0x00158d000587059d (addr 29129): DJT11LM - Aqara Vibration sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.784	info	0x00178801099a727d (addr 20805): 9290020399 - Philips Hue white E14 (Router)
    zigbee.0
    2024-10-11 23:46:04.783	info	0x00158d0003a4860a (addr 1831): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.782	info	0x00158d0003a351c4 (addr 53515): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.780	info	0x00158d0004020836 (addr 62856): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.778	info	0x842e14fffe471ae1 (addr 14292): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.775	info	0x003c84fffe2e20b6 (addr 21751): LED2004G8 - IKEA TRADFRI bulb E26/E27, white spectrum, globe, clear, 800/806 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.773	info	0x003c84fffeb5efd7 (addr 22851): LED2004G8 - IKEA TRADFRI bulb E26/E27, white spectrum, globe, clear, 800/806 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.769	info	0x000d6f000fbd8e3c (addr 61010): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.767	info	0x00158d000a827a14 (addr 54285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.764	info	0x00158d0003a48625 (addr 34067): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.762	info	0x001788010c314523 (addr 19382): 929002469202 - Philips Hue white A60 bulb E27 1050lm with Bluetooth (Router)
    zigbee.0
    2024-10-11 23:46:04.759	info	0xa4c138c1782d2a29 (addr 22396): A1Z - Nous Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-10-11 23:46:04.757	info	0x00178801090c0c72 (addr 13249): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
    zigbee.0
    2024-10-11 23:46:04.754	info	0x00158d0008d07ff2 (addr 47060): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.752	info	0x90fd9ffffed895cf (addr 2822): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.750	info	0x5c0272fffe88b629 (addr 56924): L1529 - IKEA FLOALT light panel, white spectrum, 60x60 cm (Router)
    zigbee.0
    2024-10-11 23:46:04.745	info	0x00158d0002e34375 (addr 59924): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.742	info	0x000d6f000fbd45c4 (addr 37996): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.740	info	0x680ae2fffe0a50c2 (addr 21884): E1743 - IKEA TRADFRI on/off switch (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.737	info	0xb4e3f9fffe0dcce7 (addr 21109): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.734	info	0x84fd27fffe2580df (addr 63575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.732	info	0x04cf8cdf3c7d89f6 (addr 45463): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.729	info	0x00158d0002e33879 (addr 8612): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.727	info	0x00158d00035389bd (addr 21392): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.724	info	0x00158d0003c7f9a7 (addr 14395): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.720	info	0x00158d000847e692 (addr 5547): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.717	info	0x00158d000847cee2 (addr 538): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.715	info	0xccccccfffedbebdc (addr 1415): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.712	info	0x00158d0001e0d56b (addr 19518): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.709	info	0x00158d00040aa56f (addr 38815): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.707	info	0x00158d000450d167 (addr 18406): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.704	info	0x001788010bd75cd7 (addr 52586): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
    zigbee.0
    2024-10-11 23:46:04.702	info	0xec1bbdfffed4493f (addr 29043): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.699	info	0x8cf681fffe03b46b (addr 8686): E1743 - IKEA TRADFRI on/off switch (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.697	info	0x680ae2fffe12f5b2 (addr 32806): E1743 - IKEA TRADFRI on/off switch (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.693	info	0xec1bbdfffe94bbcb (addr 47022): LED1733G7 - IKEA TRADFRI bulb E14, white spectrum, globe, opal, 600 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.691	info	0xa4c1382c8738170e (addr 15166): TS0601_soil - TuYa Soil sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.688	info	0xec1bbdfffea04dd2 (addr 9470): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.685	info	0xec1bbdfffeb19154 (addr 16801): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.683	info	0x00178801099f4997 (addr 51279): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
    zigbee.0
    2024-10-11 23:46:04.680	info	0xcc86ecfffe1183fc (addr 63037): HG06104A - Lidl Livarno Lux smart LED light strip 2.5m (Router)
    zigbee.0
    2024-10-11 23:46:04.676	info	0x0017880108ff0d07 (addr 9509): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
    zigbee.0
    2024-10-11 23:46:04.673	info	0x00158d00093e472a (addr 42638): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.669	info	0x000b57fffe349293 (addr 1015): LED1623G12 - IKEA TRADFRI bulb E27, white, globe, opal, 1000 lm (Router)
    zigbee.0
    2024-10-11 23:46:04.667	info	0xa4c13830a258e9b4 (addr 43754): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-10-11 23:46:04.663	info	0x5c0272fffe92177a (addr 8037): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
    zigbee.0
    2024-10-11 23:46:04.660	info	0xb4e3f9fffea666ae (addr 5426): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
    zigbee.0
    2024-10-11 23:46:04.655	info	0xcc86ecfffed10c5f (addr 64156): LCZ030 - TuYa Temperature & humidity & illuminance sensor with display (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.651	info	0x00158d0004abe765 (addr 56313): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.648	info	0x000d6f000fbd3eb7 (addr 39112): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.645	info	0x00158d000421184f (addr 44938): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.641	info	0x00158d0001e0045e (addr 6318): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    zigbee.0
    2024-10-11 23:46:04.630	info	0xa4c138a481b709c3 (addr 21686): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
    zigbee.0
    2024-10-11 23:46:04.292	info	Currently 76 devices are joined:
    zigbee.0
    2024-10-11 23:46:04.268	info	--> transmitPower : low
    zigbee.0
    2024-10-11 23:46:04.237	info	Unable to disable LED, unsupported function.
    zigbee.0
    2024-10-11 23:46:04.205	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
    zigbee.0
    2024-10-11 23:46:03.446	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.0
    2024-10-11 23:46:02.545	info	Starting Zigbee npm ...
    zigbee.0
    2024-10-11 23:46:02.542	info	delete old Backup files. keep only last 10
    zigbee.0
    2024-10-11 23:46:02.396	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
    Ich habe zwei Sonoff Dongles (die goßen) mit der gleichen FW, das Verhalten tritt bei beiden auf:
    Ich weiß, die FW soll wohl buggy sein. Lief bei mir aber jetzt 1,5 Jahre super.
    Die Geräte lassen sich nicht steuern:
    und alle Verbindungen sind weg.
    Funkkanalüberlagerungen haben sich nicht geändert. Zigbee funkt auf 13; Wlan auf 6 und 11.
    Iob Diag:
    bash
    Skript v.2024-08-12
    *** BASE SYSTEM ***
     Static hostname: Smartazamba
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     23:56:56 up  1:25,  2 users,  load average: 1.58, 1.36, 1.40
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-10-11 23:56:57 CEST
               Universal time: Fri 2024-10-11 21:56:57 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        3.4G        2.0G        3.1M        3.0G        4.8G
    Swap:             0B          0B          0B
    Total:          8.2G        3.4G        2.0G
    Active iob-Instances:   37
             7808 M total memory
             3232 M used memory
             4158 M active memory
             1455 M inactive memory
             1878 M free memory
              405 M buffer memory
             2433 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 23:56:57 up  1:25,  2 users,  load average: 1.58, 1.36, 1.40
    Tasks: 217 total,   1 running, 216 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7809.0 total,   1875.9 free,   3234.6 used,   2839.5 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4574.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      110G   29G   79G  27% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  3.0M  1.6G   1% /run
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      253M   44M  209M  18% /boot/firmware
    /dev/sdc       ext4      5.5T  3.5T  1.7T  68% /media/HDD2
    /dev/sdb1      ext4      4.6T  3.5T  825G  82% /media/HDD1
    tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
    [Fri Oct 11 22:31:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Oct 11 22:31:23 2024] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
    [Fri Oct 11 22:31:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Oct 11 22:31:40 2024] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w. Quota mode: none.
    [Fri Oct 11 22:31:43 2024] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
    [Fri Oct 11 22:31:43 2024] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    |-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    |-/media/HDD2    /dev/sdc  ext4   rw,nosuid,nodev,noexec,relatime
    `-/media/HDD1    /dev/sdb1 ext4   rw,nosuid,nodev,noexec,relatime
    /var:
    8.0G    /var/
    4.8G    /var/log
    3.7G    /var/log/journal/3dd7c02f298247188f8650087c821e8c
    645M    /var/cache
    Archived and active journals take up 3.6G in the file system.
    /opt/iobroker/backups:
    3.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    809M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    58M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    18M     /opt/iobroker/iobroker-data/states.jsonl
    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     2
    +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#6b97f67d1d1ce6af3a0e598ba77eec8f570a0854)
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    Adapter State
    + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
    + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
      system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
    + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Smartazamba                              - disabled
    + system.adapter.esphome.0                : esphome               : Smartazamba                              -  enabled
      system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
      system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
    + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
    + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
      system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
    + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
    + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
    + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
      system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
      system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
    + system.adapter.proxmox.0                : proxmox               : Smartazamba                              -  enabled, port: 8006
    + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
    + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
    + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.windows-control.0        : windows-control       : Smartazamba                              -  enabled
      system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              - disabled, port: 5000
    + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
    + system.adapter.ws.0                     : ws                    : Smartazamba                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "deyeidc"      : 0.1.0    , installed 0.1.0
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        25452
    States:         17493
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 7
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3068       651/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          5536       824/smbd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          5535       824/smbd
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       5104       845/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       5109       845/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       10146      1178/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       11823      1211/io.shelly.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       10519      1278/io.sonoff.0
    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       293368     78949/nc
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1002       13447      1557/python3
    tcp6       0      0 :::21                   :::*                    LISTEN      0          5426       642/vsftpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3070       651/sshd: /usr/sbin
    tcp6       0      0 :::139                  :::*                    LISTEN      0          5534       824/smbd
    tcp6       0      0 :::445                  :::*                    LISTEN      0          5533       824/smbd
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        5572       844/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       7590       900/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       11871      1609/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1002       13822      1674/io.ws.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1002       10931      1573/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6895       744/influxd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          7175       802/nmbd
    udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          7174       802/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1018       802/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          7177       802/nmbd
    udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          7176       802/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1019       802/nmbd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       10765      1362/io.mihome-vacu
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       10797      1410/io.mihome-vacu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       10843      1651/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       11657      1145/io.esphome.0
    udp        0      0 192.168.178.20:5353     0.0.0.0:*                           1002       13453      1557/python3
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1002       13452      1557/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       13448      1557/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        850        478/avahi-daemon: r
    udp        0      0 0.0.0.0:51543           0.0.0.0:*                           108        852        478/avahi-daemon: r
    udp6       0      0 :::52956                :::*                                108        853        478/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        851        478/avahi-daemon: r
    2024-10-11 23:53:53.142  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:54:04.664  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:54:15.884  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:54:27.346  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:54:38.579  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:54:49.941  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:55:01.346  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:55:13.614  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:55:26.539  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:55:38.145  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:55:48.033  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 75611
    2024-10-11 23:55:49.681  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:55:53.654  - info: weatherunderground.0 (75611) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.0, js-controller: 6.0.11
    2024-10-11 23:56:00.137  - info: weatherunderground.0 (75611) Terminated (NO_ERROR): Without reason
    2024-10-11 23:56:00.666  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 75611 terminated with code 0 (NO_ERROR)
    2024-10-11 23:56:04.709  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:56:17.296  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:56:28.804  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:56:40.544  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:56:52.733  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:57:04.579  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:57:19.334  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:57:32.240  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:57:44.459  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    2024-10-11 23:57:56.267  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
    Was ist da passiert und wie bekomme ich das mit geringstmöglichem Aufwand wieder hin?
    Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
    • R Rushmed
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Iob Diag:
      bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
               7808 M total memory
               3232 M used memory
               1878 M free memory
                405 M buffer memory
               2433 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      8.0G    /var/
      4.8G    /var/log
      645M    /var/cache
      USB-Devices by-id:
      HINT:
      tcp
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.1.5
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        25452
      States:         17493
      Pending Updates: 7
      @rushmed sagte in Zigbee Blackout:
      Wenn du die hochdrehst?
      R 1 Antwort Letzte Antwort
        Rushmed
        @thomas-braun Da passiert erstmal nichts, aber wie gesagt, das setup lief mit den Einstellungen lange problemfrei.
        • R Rushmed
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          Iob Diag:
          bash
          Skript v.2024-08-12
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   7808 M total memory
                   3232 M used memory
                   1878 M free memory
                    405 M buffer memory
                   2433 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          8.0G    /var/
          4.8G    /var/log
          645M    /var/cache
          USB-Devices by-id:
          HINT:
          tcp
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        25452
          States:         17493
          Pending Updates: 7
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @rushmed bitte ausprobieren:
          • zigbee adapter anhalten
          • stick abziehen
          • 60 s warten
          • Stick anstecken
          • Adapter starten
          A.
          • AsgothianA Asgothian
            • stick abziehen
            • 60 s warten
            • Stick anstecken
            • Adapter starten
            A.
            Rushmed
            @asgothian Das hat leider auch nichts gebracht.
            • R Rushmed
              MartinPM Online
              MartinPM Online
              MartinP
              @rushmed Kanalfrequenz herausfinden, schauen, welche WiFi Kanäle damit kollidieren, und mit dem Smartphone nach der WiFi Nachbarschaft Schauen.
              Vielleicht hat aber auch die Nachbarschaft die Segnungen von Zigbee entdeckt, und sich ausgestattet ...
              • MartinPM MartinP
                Rushmed
                @martinp Danke.
                Habe soeben versucht ein Fullbackup von bevor die Symptome auftraten wieder her zu stellen. Leider mit dem gleichen Ergebnis.
                • R Rushmed
                  @martinp Danke.
                  Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  schrieb am zuletzt editiert von Jey Cee
                  @rushmed wenn dein Setup nicht geändert hast, hast du dir neue WLAN oder Bluetooth Geräte zugelegt?
                  Wie ist deine Wohnsituation, Einfamilienhaus oder Wohnblock?
                  Achso wenn du ne Fritzbox hast, schau da mal bei den Wlan Einstellungen. Dort gibt es die Möglichkeit die Auslastung des WLAN Frequenzbandes. Da werden auch Störquellen angezeigt.
                  Persönlicher Support
                  Spenden -> paypal.me/J3YC33
                  • Jey CeeJ Jey Cee
                    Rushmed
                    @jey-cee Nein, keine neuen Geräte.
                    Einfammlienhaus und die nächsten Nachbarn sind im Urlaub, als installieren die wohl auch gerade keine Geräte.
                    Unify System.
                    Ich kann auch Geräte nicht neu verbinden.
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      @rushmed auszug aus der FAQ von zigbee2mqtt:
                      MAC_CHANNEL_ACCESS_FAILURE: this happens when the wireless spectrum is too occupied. Mostly happens when a microwave is on or when there are WiFi networks on the same channel. See Reduce Wifi interference by changing the Zigbee channel how to fix this.
                      Irgendwas verstopft also vermutlich dein Zigbee Kanal.
                      • R Offline
                        Rushmed
                        Beim Versuch die Geräte neu zu pairen kommt:
                        zigbee.0
                        2024-10-12 10:06:06.246	error	Failed to open the network: Error: Data request failed with error: 'No network route' (205) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:229:13) at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:251:13) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:238:9) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:525:17)
                        Es sieht so aus als wären alle Zigbee Geräte die mit Netzspannug versorgt werden nicht erreichbar. Die Battariegeräte sind da aber funktionieren auch nicht zu 100%.
                        • black.falcon87B Offline
                          black.falcon87
                          Ich würde mal testweise nach und nach alle möglichen Geräte aus den Steckdosen ziehen. Z.B. USB Netzteil usw.
                          Im Zweifel halt alles und dann mal ioBroker neu starten und schauen ob es hilft.
                          Wenn ja dann halt anschließend nach und nach Geräte wieder in Betrieb nehmen und schauen wann es wieder schlechter wird
                          • R Offline
                            Rushmed
                            Hier noch der LOG vom Zigbee Adapter Neustart:
                            Lässt sich leider nicht einbette wegen seiner Länge.
                            Zigbee LOG.txt
                            • R Offline
                              Rushmed
                              Interessant! Ich habe jetzt mal meinen Mini PC der etwa 20 cm neben dem Raspi auf dem der ioBroker läuft ausgeschaltet und jetzt scheint das Problem behoben. Ich beobachte weiter.
                              Das Gerät kam mir erstmal gar nicht in den Sinn, da es weder mit dem ioBroker verbunden ist noch Wlan oder BT hat.
                              MartinPM AsgothianA BananaJoeB 3 Antworten Letzte Antwort
                              • R Rushmed
                                MartinPM Online
                                MartinPM Online
                                MartinP
                                Ist das Gehäuse des Mini-PC im normalen Zustand, oder offen?
                                Bei Zigbee-USB-Sticks wird empfohlen, sie an ein USB -Verlängerungskabel zu hängen, damit sie in etwas Sicherheitsabstand zum System einhalten können.
                                • R Rushmed
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  WLan und BT sind bei weitem nicht die einzigen Stoerquellen:
                                  • USB3, insbesondere bei Festplatten / SSD stört gerne im 2.4 GHz Band
                                  • Proprietäre Funkadapter arbeiten auch im 2.4 GHz Band (Kopfhörer, Maus/Tastatur, aber auch DECT, etc.)
                                  Dazu kommt das die Summe der Sender zählt - der Mini-PC kann also an der Störung teilhaben, aber auch nicht weiter verantwortlich sein wenn ein anderes Gerät das Funknetz belastet.
                                  A.
                                  • R Rushmed
                                    BananaJoeB Online
                                    BananaJoeB Online
                                    BananaJoe
                                    Diese Teile mit Intel N95 / N100 Prozessor die es für 150 bis 300 Euro im Moment zu Hauf gibt?
                                    Ist mir auch schon aufgefallen das die ja ein reines Kunststoffgehäuse ohne Schirmung (auch keine Metallbeschichtung von innen) haben ... Bei einem stand meine ich auch in der beiliegenden Anleitung das man bestimmte Geräte nicht zu nahe daran stellen soll wegen Störungen (ich meine bezogen auf USB).
                                      A.
                                      Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      @asgothian sagte in Zigbee Blackout:
                                      Nicht zu vergessen Schaltnetzteile, die heute fast Überall verwendet werden. Wenn die schlecht gebaut oder Kaputt können Stören.
                                      • MartinPM MartinP
                                        Rushmed
                                        @martinp Das Gehäuse ist geschlossen. Der Stick hängt sowieso an einem Verlängerungskabel und außerhalb vom Serverschrank.
                                        @BananaJoe Der Server ist ein HP Prodesk mini mit nem i5.
                                        Tatsächlich hatte ich gestern eine USB SSD an den Server gesteckt bevor das Netz zusammenbrach.
                                        Was mache ich denn da jetzt am besten? Räumliche Distanz zwischen den Geräten schaffen oder gibts geschirmte USB Kabel?
                                        Meister MopperM AsgothianA 2 Antworten Letzte Antwort
                                        • R Rushmed
                                          Meister MopperM Online
                                          Meister Mopper
                                          Ich würde zu Testzwecken die SSD mal oben ankleben.
                                          Proxmox und HA ...
