  4. Adapter Fehlermeldung nach update - npm ist komisch
    6.7k
37 Beiträge 4 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • apollon77A apollon77
    @würfel Jetzt starte mal ... kommt fehler immer noch?
    W Offline
    W Offline
    Würfel
    @apollon77
    Hab iobroker gestoppt und gestartet
    host.PI250GBUSBC
    2024-09-19 11:16:22.532	info	iobroker rebuild
    host.PI250GBUSBC
    2024-09-19 11:16:22.531	warn	adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    host.PI250GBUSBC
    2024-09-19 11:16:22.529	info	system.adapter.echarts.0 will be rebuilt
    host.PI250GBUSBC
    2024-09-19 11:16:22.528	info	Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
    host.PI250GBUSBC
    2024-09-19 11:16:22.527	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.PI250GBUSBC
    2024-09-19 11:16:22.527	error	Caught by controller[0]: Node.js v20.17.0
    host.PI250GBUSBC
    2024-09-19 11:16:22.526	error	Caught by controller[0]: }
    host.PI250GBUSBC
    2024-09-19 11:16:22.526	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
    host.PI250GBUSBC
    2024-09-19 11:16:22.526	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.PI250GBUSBC
    2024-09-19 11:16:22.525	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
    host.PI250GBUSBC
    2024-09-19 11:16:22.525	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
    host.PI250GBUSBC
    2024-09-19 11:16:22.524	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
    host.PI250GBUSBC
    2024-09-19 11:16:22.524	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    host.PI250GBUSBC
    2024-09-19 11:16:22.523	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
    host.PI250GBUSBC
    2024-09-19 11:16:22.523	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
    host.PI250GBUSBC
    2024-09-19 11:16:22.522	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.PI250GBUSBC
    2024-09-19 11:16:22.521	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
    host.PI250GBUSBC
    2024-09-19 11:16:22.520	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
    host.PI250GBUSBC
    2024-09-19 11:16:22.520	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
    host.PI250GBUSBC
    2024-09-19 11:16:22.519	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
    host.PI250GBUSBC
    2024-09-19 11:16:22.518	error	Caught by controller[0]: Require stack:
    host.PI250GBUSBC
    2024-09-19 11:16:22.518	error	Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
    host.PI250GBUSBC
    2024-09-19 11:16:22.518	error	Caught by controller[0]: ^
    host.PI250GBUSBC
    2024-09-19 11:16:22.517	error	Caught by controller[0]: throw err;
    host.PI250GBUSBC
    2024-09-19 11:16:22.516	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
    • apollon77A Offline
      Also bei Dir hat sich npm aber mal ganz gewaltig verklemmt. AM Ende gibts zwei Optionen:
      1.) Zurechfrickeln ... das fixt es ggf jetzt aber wird später wieder/neue issues machen
      2.) Sauber fixen.
      Was magst?
      W 1 Antwort Letzte Antwort
        2.) Sauber fixen.
        Was magst?
        W Offline
        W Offline
        Würfel
        schrieb am zuletzt editiert von Würfel
        @apollon77
        Kann man die Version zurück spielen auf die alte?
        Sauber wird wohl heißen Backup einspielen?!
        • W Würfel
          @apollon77
          @würfel Kannst es versuchen aber wird fürchte ich nichts bringen weil dein npm tree komisch/kaputt ist.
          Am Ende wenn du die versionsnummer kennst dann wie oben mit dem "npm i iobroker.echarts@x.y.z" die Verison dran hängen (cd ins richtige Dir und upload danach nicht vergessen). Würde mich aber sehr wundern wenn das einen unterschied macht.
            W Offline
            W Offline
            Würfel
            @apollon77
            Das natürlich blöd, wenn einem das System das Update anbietet und dann so schief läuft
            Was ist die saubere Variante?
            • W Würfel
              @apollon77
              @würfel lso zuerst nochmal: Ich glaube hier hat sich was in deinem npm tree der gesamten Pakete verklemmt. Das ist als ein sehr lokales Problem und sehr besonders!!!!
              Diese ganzen "overrides" in dem npm list sind normalerweise nie so. Da müsste ein Paket ganz oben im Tree liegen und alle anderen haben "deduped" ... Also da ist was bei dir lokal strange ... Grund: unbekannt! Schwierig das auf "iobroker als System" zu schieben :-)
              Ok bevor wir anfangen: Wie sieht deine package.json in/opt/iobroker aus?
              • W Offline
                W Offline
                Würfel
                @apollon77
                da traut man sich in Zukunft aber langsam nicht mehr updates noch zu machen
                total 1024
                drwxrwxr-x+    6 iobroker iobroker   4096 Sep 19 00:53 .
                drwxr-xr-x     3 root     root       4096 Jul  7  2023 ..
                drwxrwxr-x+    2 iobroker iobroker   4096 Jul  7  2023 backups
                -rwxrwxrwx+    1 iobroker iobroker    445 Sep 19 00:53 INSTALLER_INFO.txt
                lrwxrwxrwx     1 iobroker iobroker     22 Sep 19 00:53 iob -> /opt/iobroker/iobroker
                -rwxr-xr-x+    1 iobroker iobroker    701 Sep 19 00:53 iobroker
                drwxrwxr-x+    7 iobroker iobroker   4096 Sep 19 11:15 iobroker-data
                drwxrwxr-x+    2 iobroker iobroker   4096 Sep 19 11:30 log
                drwxrwxr-x+ 1144 iobroker iobroker  36864 Sep 19 10:09 node_modules
                -rw-rwxr--+    1 iobroker iobroker    155 Sep 19 00:53 .npmrc
                -rw-rwxr--+    1 iobroker iobroker   2599 Sep 19 10:09 package.json
                -rw-rwxr--+    1 iobroker iobroker 968612 Sep 19 10:09 package-lock.json
                • W Würfel
                  @apollon77
                  total 1024
                  @würfel sagte in Adapter Fehlermeldung nach update - npm ist komisch:
                  Puhhh... Wenn Du Dir diese Angst behalten willst viel Spass dabei, ich finde Sie nicht sinnvoll um mal ganz ehrlich zu sein. Ich kann nur sagen das ich diesen Fall hier noch nie gesehen hab. Und das heisst einiges.
                  Weiterhin kannst Du ja nicht behaupten das dir gerade niemand mit dem Problem hilft ... also wenn es Probleme gibt haben wir Die immer gelöst bekommen.
                  Ich würde gern den Inhalt der package.json sehen :-)
                    W Offline
                    W Offline
                    Würfel
                    @apollon77
                    Das möchte ich auch nicht behaupten, nur schreckt es ja auch etwas ab.... Auch wenn der support hier super ist, geht ja für alle Seiten Zeit drauf dabei....
                    Wie kann ich den inhalt anzeigen?
                    • W Würfel
                      @apollon77
                      @würfel cat package.json
                        W Offline
                        W Offline
                        Würfel
                        @apollon77
                        Eben auch gegoogelt nebenbei
                        {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=12.0.0"},"dependencies":{"iobroker.admin":"7.0.23","iobroker.backitup":"3.0.22","iobroker.botslab360":"0.0.2","iobroker.cameras":"2.1.2","iobroker.cloud":"5.0.1","iobroker.devices":"1.1.5","iobroker.discovery":"5.0.0","iobroker.dwd":"2.8.5","iobroker.echarts":"^1.7.2","iobroker.ecoflow":"github:Newan/ioBroker.ecoflow#3280c2dc52b2c6e88a39d142c8cc3d4de5fecf2f","iobroker.energiefluss":"3.6.0","iobroker.epson_ecotank_et_2750":"0.0.12","iobroker.fahrplan":"1.2.3","iobroker.fb-checkpresence":"1.2.4","iobroker.feiertage":"1.2.0","iobroker.flot":"1.12.0","iobroker.history":"3.0.1","iobroker.hm-rega":"5.0.0","iobroker.hm-rpc":"1.17.0","iobroker.homeconnect":"1.4.1","iobroker.ical":"1.15.0","iobroker.icons-addictive-flavour-png":"0.1.0","iobroker.icons-fatcow-hosting":"0.1.0","iobroker.icons-material-png":"0.1.0","iobroker.icons-material-svg":"0.1.0","iobroker.icons-mfd-png":"1.2.1","iobroker.icons-mfd-svg":"1.2.0","iobroker.icons-open-icon-library-png":"0.1.2","iobroker.icons-smarthome":"1.0.0","iobroker.icons-ultimate-png":"1.0.1","iobroker.influxdb":"4.0.2","iobroker.info":"2.0.0","iobroker.javascript":"8.7.6","iobroker.js-controller":"6.0.11","iobroker.luftdaten":"4.0.0","iobroker.melcloud":"2.0.2","iobroker.meteoalarm":"3.0.3","iobroker.mihome":"1.4.0","iobroker.nina":"0.0.25","iobroker.onvif":"1.1.4","iobroker.parcel":"0.0.27","iobroker.reolink":"1.1.1","iobroker.scenes":"3.2.1","iobroker.shelly":"7.0.0","iobroker.simple-api":"2.8.0","iobroker.smartcontrol":"2.0.1","iobroker.smartthings":"0.0.4","iobroker.socketio":"6.7.1","iobroker.sourceanalytix":"github:DrozmotiX/ioBroker.sourceanalytix#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19","iobroker.sprinklecontrol":"0.2.13","iobroker.tankerkoenig":"3.4.0","iobroker.tr-064":"4.3.0","iobroker.trashschedule":"3.3.0","iobroker.tuya":"3.16.0","iobroker.unifi":"0.7.0","iobroker.virtualpowermeter":"1.4.6","iobroker.vis":"1.5.6","iobroker.vis-bars":"0.1.4","iobroker.vis-colorpicker":"2.0.3","iobroker.vis-fancyswitch":"1.1.0","iobroker.vis-history":"1.0.0","iobroker.vis-hqwidgets":"1.5.1","iobroker.vis-icontwo":"1.5.0","iobroker.vis-inventwo":"3.3.4","iobroker.vis-jqui-mfd":"1.1.1","iobroker.vis-justgage":"2.1.7","iobroker.vis-map":"1.1.2","iobroker.vis-material-advanced":"1.7.4","iobroker.vis-metro":"1.2.0","iobroker.vis-plumb":"1.0.2","iobroker.vis-rgraph":"0.0.2","iobroker.vw-connect":"^0.6.0","iobroker.web":"6.2.5","iobroker.worx":"3.0.2","iobroker.ws":"2.6.2"},"overrides":{"@iobroker/adapter-core":"^3.1.6"}}p
                        • W Würfel
                          @apollon77
                          @würfel
                          Ist jq installiert?
                          Dann besser
                          jq . package.json
                            @würfel
                            Ist jq installiert?
                            Dann besser
                            jq . package.json
                            W Offline
                            W Offline
                            Würfel
                            @thomas-braun sagte in Adapter Fehlermeldung nach update - npm ist komisch:
                            jq . package.json
                            pi@PI250GBUSBC:/opt/iobroker $ jq . package.json
                            -bash: jq: command not found
                            • W Würfel
                              jq . package.json
                              @würfel Alles gut, konnte es lesen. Checke gerade was
                                @apollon77 Ok, also das ist ok ... ich habe gerade nbei mir nochmmal geschaut und sieht vergleichbar aus und mein npm tree ist alles deduped. Also Sauber
                                1.) BACKUP!!!!
                                2.) hast Du Backup gemacht? ;-) Wenn nein ... go to 1. ...
                                3.) Das wäre noch ein versuch, der schieff gehen kann, falls ja dann machen wir mit #4 weiter :-)
                                • iob stop
                                • cd /opt/iobroker
                                • npm dedupe
                                  Wenn alles klappt sollte npm seinen Scheiss damit selbst aufäumen - oder er macht alles kaputt ... eins von beidem :-)
                                  Also danach mal "npm list ..." machen und vergleichen. Wenn es noch genauso aussieht dann hats nichts gebracht. Falls es deduped ist mal starten ... Falls irgendwas nicht startet ggf diese Adapter nochmal neu installieren ... oder einfach bei 4.) weitermachen. Wenn nach dem hier alles tut dann fertig
                                4.) Ok dann quasi "neuinstallation der Pakete mit alten Daten"
                                • iob stop
                                • cd /opt/iobroker
                                • rm -rf node_modules package-lock.json
                                • npm i iobroker.js-controller
                                • iob start
                                Jetzt dauert es weil er jeden Adapter den er starten will nicht finden wird und deswegen neu installiert. Das sorgt aber an sich dafür das der npm Baum neu (und sauber) aufgebaut wird. Danach sollte auch das "npm list" von oben etwas anders aussehen.
                                Es kann sein (habe gesehen Du hast einen Adapter aus Git installiert) das der nicht neu installiert werden kann falls der Git hash inzwischen ungültig ist ... also am Ende ins Log bzw in die instanzen schauen was noch übrig bleibt. Das müssen wir dann nach fixen - am Einfachsten dann in dem man die Release version neu installiert.
                                Viel Erfolg
                                W Jim KnopfJ 2 Antworten Letzte Antwort
                                  1.) BACKUP!!!!
                                  • iob stop
                                  • cd /opt/iobroker
                                  • npm dedupe
                                  • iob stop
                                  • cd /opt/iobroker
                                  • iob start
                                  Viel Erfolg
                                  W Offline
                                  W Offline
                                  Würfel
                                  @apollon77
                                  Zwischenstand...
                                  Lasse iob gerade starten
                                  pi@PI250GBUSBC:/opt/iobroker $ npm dedupe
                                  npm warn deprecated glob@7.2.0: Glob versions prior to v9 are no longer supporte             d
                                  added 26 packages, removed 69 packages, and changed 127 packages in 4m
                                  417 packages are looking for funding
                                    run `npm fund` for details
                                  pi@PI250GBUSBC:/opt/iobroker $ npm list @iobroker/adapter-core
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├─┬ iobroker.admin@7.0.23
                                  │ ├── @iobroker/adapter-core@3.1.6 overridden
                                  │ └─┬ @iobroker/socket-classes@1.5.6
                                  │   └── @iobroker/adapter-core@3.1.6 deduped
                                  ├─┬ iobroker.backitup@3.0.22
                                  ├─┬ iobroker.botslab360@0.0.2
                                  ├─┬ iobroker.cameras@2.1.2
                                  ├─┬ iobroker.cloud@5.0.1
                                  │ ├── @iobroker/adapter-core@3.1.6 deduped
                                  │ └─┬ @iobroker/socket-classes@1.5.0
                                  ├─┬ iobroker.discovery@5.0.0
                                  ├─┬ iobroker.dwd@2.8.5
                                  ├─┬ iobroker.ecoflow@0.0.4 (git+ssh://git@github.com/Newan/ioBroker.ecoflow.git#3280c2dc52b2c6e88a39d142c8cc3d4de5fecf2f)
                                  ├─┬ iobroker.energiefluss@3.6.0
                                  ├─┬ iobroker.epson_ecotank_et_2750@0.0.12
                                  ├─┬ iobroker.fahrplan@1.2.3
                                  ├─┬ iobroker.fb-checkpresence@1.2.4
                                  ├─┬ iobroker.feiertage@1.2.0
                                  ├─┬ iobroker.flot@1.12.0
                                  ├─┬ iobroker.history@3.0.1
                                  ├─┬ iobroker.hm-rega@5.0.0
                                  ├─┬ iobroker.hm-rpc@1.17.0
                                  │ └─┬ @iobroker/dm-utils@0.1.9
                                  ├─┬ iobroker.homeconnect@1.4.1
                                  ├─┬ iobroker.ical@1.15.0
                                  ├─┬ iobroker.influxdb@4.0.2
                                  ├─┬ iobroker.info@2.0.0
                                  ├─┬ iobroker.javascript@8.7.6
                                  ├─┬ iobroker.luftdaten@4.0.0
                                  ├─┬ iobroker.melcloud@2.0.2
                                  ├─┬ iobroker.meteoalarm@3.0.3
                                  ├─┬ iobroker.mihome@1.4.0
                                  ├─┬ iobroker.nina@0.0.25
                                  ├─┬ iobroker.onvif@1.1.4
                                  ├─┬ iobroker.parcel@0.0.27
                                  ├─┬ iobroker.reolink@1.1.1
                                  ├─┬ iobroker.scenes@3.2.1
                                  ├─┬ iobroker.shelly@7.0.0
                                  ├─┬ iobroker.simple-api@2.8.0
                                  ├─┬ iobroker.smartcontrol@2.0.1
                                  ├─┬ iobroker.smartthings@0.0.4
                                  ├─┬ iobroker.socketio@6.7.1
                                  ├─┬ iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                                  ├─┬ iobroker.sprinklecontrol@0.2.13
                                  ├─┬ iobroker.tankerkoenig@3.4.0
                                  ├─┬ iobroker.tr-064@4.3.0
                                  ├─┬ iobroker.trashschedule@3.3.0
                                  ├─┬ iobroker.tuya@3.16.0
                                  ├─┬ iobroker.unifi@0.7.0
                                  ├─┬ iobroker.virtualpowermeter@1.4.6
                                  ├─┬ iobroker.vis-colorpicker@2.0.3
                                  ├─┬ iobroker.vis-history@1.0.0
                                  ├─┬ iobroker.vis-icontwo@1.5.0
                                  ├─┬ iobroker.vis-inventwo@3.3.4
                                  ├─┬ iobroker.vis-metro@1.2.0
                                  ├─┬ iobroker.vis-plumb@1.0.2
                                  ├─┬ iobroker.vis@1.5.6
                                  ├─┬ iobroker.vw-connect@0.6.0
                                  ├─┬ iobroker.web@6.2.5
                                  │ ├─┬ iobroker.socketio@6.6.1
                                  │ │ └── @iobroker/adapter-core@3.1.6 deduped
                                  │ └─┬ iobroker.ws@2.5.11
                                  ├─┬ iobroker.worx@3.0.2
                                  └─┬ iobroker.ws@2.6.2
                                  • W Würfel
                                    @apollon77
                                    Zwischenstand...
                                    @würfel Ok dann warte mal kurz und schaue obs geht und falls nicht mach nochmal ..
                                    npm i iobroker.echarts@1.9.2 und upload
                                      W Offline
                                      W Offline
                                      Würfel
                                      @apollon77
                                      bisher gibs nur die beiden errors und charts ist grün unter instanzen
                                      Nun zicken vw und scource und onvif etwas anscheinend.
                                      neuinstallieren?
                                      unifi.0
                                      2024-09-19 12:18:32.132	error	Error site undefined: SSL/Certificate issue: certificate has expired
                                      tuya.0
                                      2024-09-19 12:18:31.222	error	Login for MQTT failed: TypeError: Cannot destructure property 'access_token' of 'res.result' as it is undefined.
                                      onvif.0
                                      2024-09-19 12:19:57.152	error	Error Error: ONVIF SOAP Fault: Error 401: HTTP 401 Unauthorized
                                      onvif.0
                                      2024-09-19 12:19:57.151	error	Failed to login to 192.168.178.162:8000 with admin:d********!
                                      onvif.0
                                      2024-09-19 12:19:56.657	error	Error Error: Wrong ONVIF SOAP response
                                      onvif.0
                                      2024-09-19 12:19:56.656	error	Failed to login to 192.168.178.101:5357 with admin:d********!
                                      onvif.0
                                      2024-09-19 12:19:56.528	error	Error Error: Wrong ONVIF SOAP response
                                      onvif.0
                                      2024-09-19 12:19:56.527	error	Failed to login to 192.168.178.161:5357 with admin:d********!
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.295	error	Initialization of javascript.0.scriptEnabled.Messungen.SolarGesamtLeistung failed, check warn messages !
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.295	error	Cannot handle calculations for javascript.0.scriptEnabled.Messungen.SolarGesamtLeistung, check log messages and adjust settings!
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.294	error	Troubleshoot Data javascript.0.scriptEnabled.Messungen.SolarGesamtLeistung custom Data : {"common":{"name":"SolarGesamtLeistung","desc":"Manuell erzeugt","role":"state","type":"number","read":true,"write":true,"def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":false,"threshold":10,"start_day":648227.5300000001,"start_week":194367.27000000002,"start_month":520466.6400000003,"start_quarter":0,"start_year":0,"consumption":true,"costs":true,"selectedPrice":"ElectricityDelivery","valueAtDeviceReset":716492.4000000004,"valueAtDeviceInit":421.33,"cumulativeValue":648227.5300000001},"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":false,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":63072000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":0}}},"type":"state","native":{},"_id":"javascript.0.scriptEnabled.Messungen.SolarGesamtLeistung","from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1677933144922,"acl":{"object":1636,"state":1636,"file":1632,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.294	error	Check settings for javascript.0.scriptEnabled.Messungen.SolarGesamtLeistung ! Known valueAtDeviceReset : (716492.4000000004) > known cumulative value (716461.4100000004) cannot proceed
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.240	error	Initialization of javascript.0.scriptEnabled.Messungen.HausVerbrauchShellyGemessen failed, check warn messages !
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.239	error	Cannot handle calculations for javascript.0.scriptEnabled.Messungen.HausVerbrauchShellyGemessen, check log messages and adjust settings!
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.238	error	Troubleshoot Data javascript.0.scriptEnabled.Messungen.HausVerbrauchShellyGemessen custom Data : {"common":{"name":"HausVerbrauchShellyGemessen","desc":"Manuell erzeugt","role":"number","type":"number","read":true,"write":true,"def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":false,"threshold":10,"start_day":330899.8399999997,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"costs":true,"consumption":true,"basicRate":true,"selectedPrice":"ElectricityDay","valueAtDeviceReset":533449.6799999988,"valueAtDeviceInit":741.21,"cumulativeValue":330899.8399999997},"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":false,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":63072000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":0}}},"type":"state","native":{},"_id":"javascript.0.scriptEnabled.Messungen.HausVerbrauchShellyGemessen","acl":{"object":1636,"state":1636,"file":1632,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1704521507117}
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.237	error	Check settings for javascript.0.scriptEnabled.Messungen.HausVerbrauchShellyGemessen ! Known valueAtDeviceReset : (533449.6799999988) > known cumulative value (533432.9299999988) cannot proceed
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.181	error	Initialization of javascript.0.scriptEnabled.Messungen.HausVerbrauchHomematicGemessen failed, check warn messages !
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.179	error	Cannot handle calculations for javascript.0.scriptEnabled.Messungen.HausVerbrauchHomematicGemessen, check log messages and adjust settings!
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.178	error	Troubleshoot Data javascript.0.scriptEnabled.Messungen.HausVerbrauchHomematicGemessen custom Data : {"common":{"name":"HausVerbrauchHomematicGemessen","desc":"Manuell erzeugt","role":"number","type":"number","read":true,"write":true,"def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":false,"threshold":10,"start_day":39655,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"costs":true,"consumption":true,"basicRate":true,"selectedPrice":"ElectricityDay","valueAtDeviceReset":80601,"valueAtDeviceInit":620,"cumulativeValue":39655},"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":false,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":63072000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":0}}},"type":"state","native":{},"_id":"javascript.0.scriptEnabled.Messungen.HausVerbrauchHomematicGemessen","acl":{"object":1636,"state":1636,"file":1632,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1704521528524}
                                      sourceanalytix.0
                                      2024-09-19 12:19:47.178	error	Check settings for javascript.0.scriptEnabled.Messungen.HausVerbrauchHomematicGemessen ! Known valueAtDeviceReset : (80601) > known cumulative value (80584) cannot proceed
                                      vw-connect.0
                                      2024-09-19 12:19:34.916	error	{"error":{"group":2,"retry":true,"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112}}
                                      vw-connect.0
                                      2024-09-19 12:19:34.915	error	No shortterm trips found please disable in your settings
                                      vw-connect.0
                                      2024-09-19 12:19:34.914	error	AxiosError: Request failed with status code 404
                                      vw-connect.0
                                      2024-09-19 12:19:34.762	error	{"error":{"group":2,"retry":true,"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112}}
                                      vw-connect.0
                                      2024-09-19 12:19:34.760	error	No longterm trips found please disable in your settings
                                      vw-connect.0
                                      2024-09-19 12:19:34.758	error	AxiosError: Request failed with status code 404
                                      vw-connect.0
                                      2024-09-19 12:19:34.594	error	{"error":{"code":4112,"group":2,"retry":true,"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support."}}
                                      vw-connect.0
                                      2024-09-19 12:19:34.592	error	No shortterm trips found please disable in your settings
                                      vw-connect.0
                                      2024-09-19 12:19:34.591	error	AxiosError: Request failed with status code 404
                                        na prima,
                                        inzwischen hab ich auch erfahren was das Problem ist ...
                                        Echarts in 1.7.2 hatte einen Bug das es eine Abhängigkeit nicht angegeben hat. Das hat dann in 9x% der Fälle geklapüpt weil es normalerweise "deduped" ist ... bei dir war aber as irgendwelchen gründen halt nichts deduped was dann zu genau dem Issue geführt hat.
                                        Warum npm sich entschieden hat vorhin nicht ne aktuelle Version zu installieren ist eine andere Frage ...
                                        Aber naja .. wenn jetzt alles tut. dann super - und dein npm tree ist jetzt besser
                                          Also diese unifi bzw onvif Fehler sehen mir eher nach anderen Dingen aus ... Da am besten mal spezifisch bei den Adaptern schauen was da los sein kann. Bzw "Failed to login" klingt nach .. Daten prüfen :-)
