  3. Einsteigerfragen
  4. Logeinträge: Ping und Host.*
    5.4k
19 Beiträge 6 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • T tklein
    @homoran said in Logeinträge: Ping und Host.*:
    iob diag
    done:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi-iob
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     16:58:19 up 8 days, 21:50,  2 users,  load average: 2.45, 2.18, 2.51
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-09-09 16:58:19 CEST
               Universal time: Mon 2024-09-09 14:58:19 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        2.4G        994M         33M        491M        1.3G
    Swap:           10G        2.0G        8.3G
    Total:          14G        4.3G        9.3G
    Active iob-Instances:   36
             3837 M total memory
             2351 M used memory
             1508 M active memory
             1201 M inactive memory
              994 M free memory
               89 M buffer memory
              402 M swap cache
            10239 M total swap
             1953 M used swap
             8286 M free swap
    top - 16:58:20 up 8 days, 21:50,  2 users,  load average: 2.45, 2.18, 2.51
    Tasks: 172 total,   3 running, 169 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 40.0 us,  8.6 sy,  0.0 ni, 47.1 id,  0.0 wa,  0.0 hi,  4.3 si,  0.0 st
    MiB Mem :   3837.7 total,    994.5 free,   2350.4 used,    492.8 buff/cache
    MiB Swap:  10240.0 total,   8286.5 free,   1953.5 used.   1319.8 avail Mem
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * lightdm.service loaded failed failed Light Display Manager
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      220G   32G  180G  15% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  185M  1.7G  10% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Sat Aug 31 19:07:29 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): 11 orphan inodes deleted
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): 1 truncate cleaned up
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): recovery complete
    [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Aug 31 19:07:31 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Aug 31 19:07:33 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE     FSTYPE     OPTIONS
    /                                     /dev/sda2  ext4       rw,noatime
    |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
    | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
    |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | `-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
    | `-/sys/kernel/config                configfs   configfs   rw,relatime
    |-/proc                               proc       proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=40,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
    | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
    `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    7.0G    /var/
    1.4G    /var/cache/apt/archives
    1.4G    /var/cache/apt
    1.4G    /var/cache
    1.3G    /var/lib
    Archived and active journals take up 183.9M in the file system.
    /opt/iobroker/backups:
    899M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.9G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    618M    /opt/iobroker/iobroker-data/backup-objects
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    65M     /opt/iobroker/iobroker-data/objects.jsonl
    48M     /opt/iobroker/iobroker-data/states.jsonl
    42M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A94ZVX1D-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.0.0
    /usr/bin/node           v18.0.0
    /usr/bin/npm            8.6.0
    /usr/bin/npx            8.6.0
    /usr/bin/corepack       0.10.0
    nodejs:
      Installed: 18.0.0-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
         18.20.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
     *** 18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    (node:24672) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    (Use `node --trace-warnings ...` to show where the warning was created)
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    (node:24724) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    js-controller:  5.0.19
    (node:24740) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    admin:          7.0.23
    (node:24753) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    javascript:     8.7.6
    nodejs modules from github:     6
    +-- iobroker.bmw@2.6.3 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#4d2becc9814575c1387493d403ee6b435578997c)
    +-- iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606)
    +-- iobroker.labcom@0.1.5 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#13ae01a87552c17f49fc39f49ae3dd5bde870906)
    | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
    | | +-- browser-serialport@2.0.3 (git+ssh://git@github.com/noopkat/browser-serialport.git#c8628c41c11890d3058875994c15f83f2df8185b)
    +-- iobroker.sourceanalytix@0.4.12-1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#362346b297c0a21c717ec20bd8d16331bca3b22d)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : raspberrypi-iob                          -  enabled
    + system.adapter.admin.0                  : admin                 : raspberrypi-iob                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi-iob                          -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi-iob                          -  enabled
      system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi-iob                          - disabled
      system.adapter.apple-find-me.1          : apple-find-me         : raspberrypi-iob                          - disabled
      system.adapter.apple-find-me.2          : apple-find-me         : raspberrypi-iob                          - disabled
      system.adapter.apple-find-me.3          : apple-find-me         : raspberrypi-iob                          - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi-iob                          -  enabled
      system.adapter.bmw.0                    : bmw                   : raspberrypi-iob                          - disabled
      system.adapter.bmw.1                    : bmw                   : raspberrypi-iob                          - disabled
      system.adapter.bring.0                  : bring                 : raspberrypi-iob                          - disabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi-iob                          -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi-iob                          -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi-iob                          - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi-iob                          - disabled
      system.adapter.device-reminder.0        : device-reminder       : raspberrypi-iob                          - disabled
      system.adapter.device-watcher.0         : device-watcher        : raspberrypi-iob                          - disabled
      system.adapter.devices.0                : devices               : raspberrypi-iob                          -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi-iob                          - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi-iob                          -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi-iob                          -  enabled
      system.adapter.enigma2.1                : enigma2               : raspberrypi-iob                          - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi-iob                          - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi-iob                          -  enabled
    + system.adapter.fhem.0                   : fhem                  : raspberrypi-iob                          -  enabled, port: 7072
      system.adapter.firetv.0                 : firetv                : raspberrypi-iob                          - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi-iob                          -  enabled
      system.adapter.followthesun.0           : followthesun          : raspberrypi-iob                          - disabled
      system.adapter.geofency.0               : geofency              : raspberrypi-iob                          - disabled, port: 7999, bind: 0.0.0.0
      system.adapter.govee.0                  : govee                 : raspberrypi-iob                          - disabled
      system.adapter.habpanel.0               : habpanel              : raspberrypi-iob                          -  enabled
    + system.adapter.ham.0                    : ham                   : raspberrypi-iob                          -  enabled
      system.adapter.history.0                : history               : raspberrypi-iob                          - disabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi-iob                          -  enabled
      system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi-iob                          - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi-iob                          -  enabled
      system.adapter.ico-cloud.0              : ico-cloud             : raspberrypi-iob                          -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi-iob                          -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypi-iob                          -  enabled
    + system.adapter.iot.1                    : iot                   : raspberrypi-iob                          -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi-iob                          -  enabled
      system.adapter.labcom.0                 : labcom                : raspberrypi-iob                          -  enabled
      system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi-iob                          - disabled
    + system.adapter.linux-control.0          : linux-control         : raspberrypi-iob                          -  enabled
      system.adapter.meater.0                 : meater                : raspberrypi-iob                          - disabled
      system.adapter.meross.0                 : meross                : raspberrypi-iob                          - disabled
      system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi-iob                          - disabled
      system.adapter.milight-smart-light.2    : milight-smart-light   : raspberrypi-iob                          - disabled
      system.adapter.milight-smart-light.3    : milight-smart-light   : raspberrypi-iob                          - disabled
      system.adapter.milight-smart-light.4    : milight-smart-light   : raspberrypi-iob                          - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-iob                          -  enabled, port: 1888, bind: 192.168.0.20
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
    + system.adapter.nina.0                   : nina                  : raspberrypi-iob                          -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi-iob                          - disabled
      system.adapter.parcel.0                 : parcel                : raspberrypi-iob                          - disabled
      system.adapter.parser.0                 : parser                : raspberrypi-iob                          - disabled
      system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi-iob                          - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi-iob                          -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi-iob                          -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi-iob                          -  enabled
      system.adapter.reolink.0                : reolink               : raspberrypi-iob                          - disabled
    + system.adapter.ring.0                   : ring                  : raspberrypi-iob                          -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-iob                          -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi-iob                          -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi-iob                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi-iob                          -  enabled, port: 1889, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi-iob                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi-iob                          - disabled
      system.adapter.sonoff.0                 : sonoff                : raspberrypi-iob                          - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.sonos.0                  : sonos                 : raspberrypi-iob                          - disabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi-iob                          - disabled
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi-iob                          - disabled
      system.adapter.sql.0                    : sql                   : raspberrypi-iob                          - disabled, port: 3306
      system.adapter.systeminfo.0             : systeminfo            : raspberrypi-iob                          - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-iob                          -  enabled
    + system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi-iob                          -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi-iob                          -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : raspberrypi-iob                          - disabled, port: 8089, bind: 192.168.0.20, run as: admin
      system.adapter.text2command.0           : text2command          : raspberrypi-iob                          - disabled
    + system.adapter.tibberlink.0             : tibberlink            : raspberrypi-iob                          -  enabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi-iob                          - disabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-iob                          -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi-iob                          -  enabled
      system.adapter.twinkly.0                : twinkly               : raspberrypi-iob                          - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-iob                          -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-iob                          -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-iob                          - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi-iob                          -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi-iob                          -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi-iob                          - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-iob                          - disabled
    + system.adapter.web.0                    : web                   : raspberrypi-iob                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : raspberrypi-iob                          -  enabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi-iob                          - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi-iob                          -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
    + instance is alive
    ioBroker-Repositories
    (node:24770) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    Active repo(s): stable
    Installed ioBroker-Instances
    (node:24779) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    Used repository: stable
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "alarm"        : 3.6.1    , installed 3.6.1
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.22   , installed 3.0.19 [Updatable]
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "broadlink2"   : 2.3.0    , installed 2.2.0  [Updatable]
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.15 [Updatable]
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fhem"         : 2.0.5    , installed 2.0.5
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "followthesun" : 0.5.1    , installed 0.5.0  [Updatable]
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.11   , installed 5.0.19 [Updatable]
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "meater"       : 1.1.1    , installed 1.1.1
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "milight"      : 0.4.0    , installed 0.4.0
    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.2    , installed 2.2.2
    Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "reolink"      : 1.1.1    , installed 1.1.1
    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
    Adapter    "rflink"       : 2.1.12   , installed 2.1.12
    Adapter    "ring"         : 5.1.0    , installed 5.0.10 [Updatable]
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "scenes"       : 3.2.1    , installed 3.2.1
    Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 7.0.0    , installed 6.8.0  [Updatable]
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 2.0.0    , installed 1.7.4  [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
    Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.0.0  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        47310
    States:         3
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://repos.influxdata.com/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    E: Broken packages
    Pending Updates:
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19638      653/perl
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17073      549/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          24749532   1565/cupsd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        18835      506/influxd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19824      982/exim4
    tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       26535      2032/io.mqtt.0
    tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19670      653/perl
    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       32926      2073/io.shelly.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23582      507/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20350      507/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23510      1406/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30869      2134/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      116        21367      506/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17083      549/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          24749531   1565/cupsd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30132      2234/io.simple-api.
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19825      982/exim4
    tcp6       0      0 :::3306                 :::*                    LISTEN      115        18243      647/mysqld
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32892      1916/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32893      1916/io.tuya.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33696      1668/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21700      419/dhcpcd
    udp        0      0 0.0.0.0:47191           0.0.0.0:*                           1001       26236      1639/io.broadlink2.
    udp        0      0 0.0.0.0:60531           0.0.0.0:*                           108        17643      401/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          24746963   1566/cups-browsed
    udp        0      0 0.0.0.0:60026           0.0.0.0:*                           1001       26235      1639/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       28061      1639/io.broadlink2.
    udp        0      0 0.0.0.0:36572           0.0.0.0:*                           1001       26238      1639/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       30520      2020/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29903      2265/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17641      401/avahi-daemon: r
    udp        0      0 0.0.0.0:33143           0.0.0.0:*                           1001       26811587   1639/io.broadlink2.
    udp6       0      0 :::546                  :::*                                0          21724      419/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        17642      401/avahi-daemon: r
    udp6       0      0 :::49409                :::*                                108        17644      401/avahi-daemon: r
    2024-09-09 16:59:49.516  - error: host.raspberrypi-iob Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
    2024-09-09 16:59:49.516  - error: host.raspberrypi-iob Caught by controller[1]:     at processImmediate (node:internal/timers:473:21)
    2024-09-09 16:59:49.516  - error: host.raspberrypi-iob instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-09-09 16:59:49.516  - info: host.raspberrypi-iob Restart adapter system.adapter.ping.0 because enabled
    2024-09-09 17:00:08.903  - info: host.raspberrypi-iob instance system.adapter.dwd.0 started with pid 24837
    2024-09-09 17:00:14.186  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 started with pid 24848
    2024-09-09 17:00:20.339  - info: host.raspberrypi-iob instance system.adapter.labcom.0 started with pid 24870
    2024-09-09 17:00:24.812  - info: host.raspberrypi-iob instance system.adapter.ping.0 started with pid 24881
    2024-09-09 17:00:26.757  - warn: netatmo-crawler.0 (24848) slow connection to states DB. Still waiting ...
    2024-09-09 17:00:30.245  - info: host.raspberrypi-iob instance system.adapter.ical.0 started with pid 24892
    2024-09-09 17:01:21.461  - info: host.raspberrypi-iob instance system.adapter.labcom.0 terminated with code 0 (NO_ERROR)
    2024-09-09 17:01:26.416  - error: ping.0 (24881) uncaught exception: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
    2024-09-09 17:01:26.420  - error: ping.0 (24881) Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
        at Function.assertBoolean (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19)
        at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23)
    2024-09-09 17:01:26.422  - error: ping.0 (24881) Parameter "ack" needs to be of type "boolean" but type "object" has been passed
    2024-09-09 17:01:27.942  - error: host.raspberrypi-iob Caught by controller[1]: Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
    2024-09-09 17:01:27.943  - error: host.raspberrypi-iob Caught by controller[1]:     at Function.assertBoolean (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19)
    2024-09-09 17:01:27.943  - error: host.raspberrypi-iob Caught by controller[1]:     at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23)
    2024-09-09 17:01:27.944  - error: host.raspberrypi-iob Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
    2024-09-09 17:01:27.944  - error: host.raspberrypi-iob Caught by controller[1]:     at processImmediate (node:internal/timers:473:21)
    2024-09-09 17:01:27.944  - error: host.raspberrypi-iob instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-09-09 17:01:27.945  - info: host.raspberrypi-iob Restart adapter system.adapter.ping.0 because enabled
    @tklein sagte in Logeinträge: Ping und Host.*:
    (buster)
    Kannste nur neuinstallieren, diesmal in der 64Bit Lite-Version.
    Denn das Dateisystem hat Einschläge:
    nodejs total veraltet.
    E: Broken packages
    Paketverwaltung hin.
    T paul53P 2 Antworten Letzte Antwort
    • T tklein
      @meister-mopper oha, so schlimm? lasse gerade ein neues erstellen da ich von heute nacht (automatisch) bis gerade einiges gemacht habe
      Meister MopperM Online
      Meister Mopper
      @tklein
      Leider hat dein Dateisystem einen Turmtreffer, und buster ist auch nicht wiederbelebbar.
      Da hilft nur eine Neuinstallation mit einer aktuellen Debian 12 (bookworm) lite mit 64 bit und anschließendem backitup restore.
      Proxmox und HA ...
      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
        (buster)
        E: Broken packages
        tklein
        @thomas-braun ja ich drück mich schon recht lange davor. habe ca 120 zigbee device die alle neu angelernt werden müssten... derzeit noch am conbee2 als coordinator
        Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
        • T tklein
          Meister Mopper
          Davor drücken bringt nix, wie du gerade erfährst. Selbst die Zigbee-Konfiguration kannst du super mit dem backitup Adapter sichern.
          Proxmox und HA ...
          • T tklein
            Je länger du dich 'drückst', umso komplizierter wird es.
            Der einzige gangbare Weg ist die Neuinstallation, daher musst du dir über Alternativen erst gar nicht den Kopf zerbrechen.
              (buster)
              E: Broken packages
              @thomas-braun sagte: das Dateisystem hat Einschläge:
              Sieht ganz danach aus:
              Objects:        47310
              States:         3
              T Thomas BraunT 2 Antworten Letzte Antwort
                tklein
                @meister-mopper ich dachte, dass die zigbee devices neu gepairt werden müssten
                  Objects:        47310
                  States:         3
                  tklein
                  @paul53 was soll/kann mir das sagen? ssd-fehler?
                    Objects:        47310
                    States:         3
                    @paul53 sagte in Logeinträge: Ping und Host.*:
                    Da stellt sich auch die Frage, ob man aus dem wurmstichigen Ding überhaupt noch ein solides Backup ziehen kann.
                    • T tklein
                      @tklein sagte: was soll/kann mir das sagen?
                      Offenbar kann die Datei "states.jsonl" nicht gelesen werden, denn nur 3 States gibt es nicht.
                        tklein
                        da muss ich mich wohl nach einer zweiten ssd und einem neuen zigbee coordinator umschauen.
                        Der Raspi sollte wohl nur für den iob ohne grafana reichen, oder?
                          Node ist v18.0.0.
                          und der Rest?
                          Bitte iob diag in der Langfassung.
                          tklein
                          hier ein Update nach Neustart mit 40 K states :-)
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : 32 bit
                           17:36:47 up 5 min,  2 users,  load average: 5.36, 3.22, 1.39
                          CPU threads: 4
                          Current issues:
                                         Local time: Mon 2024-09-09 17:36:47 CEST
                                     Universal time: Mon 2024-09-09 15:36:47 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           3.8G        3.0G        506M        2.0M        356M        728M
                          Swap:           10G         16M         10G
                          Total:          14G        3.0G         10G
                          Active iob-Instances:   37
                                   3837 M total memory
                                   2976 M used memory
                                    198 M active memory
                                   3011 M inactive memory
                                    505 M free memory
                                     92 M buffer memory
                                    263 M swap cache
                                  10239 M total swap
                                     16 M used swap
                                  10223 M free swap
                          top - 17:36:48 up 5 min,  2 users,  load average: 5.36, 3.22, 1.39
                          Tasks: 168 total,   5 running, 163 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 39.2 us,  4.1 sy,  0.0 ni, 54.1 id,  0.0 wa,  0.0 hi,  2.7 si,  0.0 st
                          MiB Mem :   3837.7 total,    508.3 free,   2973.2 used,    356.2 buff/cache
                          MiB Swap:  10240.0 total,  10223.7 free,     16.3 used.    730.8 avail Mem
                          *** FILESYSTEM ***
                          /dev/root      ext4      220G   32G  180G  16% /
                          tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
                          [Mon Sep  9 17:31:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          [Mon Sep  9 17:31:30 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                          [Mon Sep  9 17:31:30 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Mon Sep  9 17:31:32 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                          | | `-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
                          | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                          /var:
                          7.0G    /var/
                          1.4G    /var/lib
                          1.4G    /var/cache/apt
                          1.4G    /var/cache
                          Archived and active journals take up 8.0M in the file system.
                          1.3G    /opt/iobroker/backups/
                          18M     /opt/iobroker/backups/tmpScripts
                          80M     /opt/iobroker/iobroker-data/objects.jsonl
                          52M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            8.6.0
                          /usr/bin/npx            8.6.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          (node:2655) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                           Cannot determine Set feature status: Connection is closed.
                           Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                           Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                           Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                          Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                          (node:2693) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                          (node:2710) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                          admin:          7.0.23
                          (node:2725) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                          javascript:     8.7.6
                          Adapter State
                          + system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
                          + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
                          + system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
                          + instance is alive
                          (node:2742) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                          (node:2761) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                          Objects and States
                          Objects:        47312
                          States:         40875
                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                          E: Broken packages
                          Pending Updates:
                          tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        17916      631/perl
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18710      509/sshd
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17539      386/cupsd
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        18730      487/influxd
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19104      939/exim4
                          tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       28325      1484/io.mqtt.0
                          tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        17925      631/perl
                          tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       31851      1560/io.shelly.1
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23723      490/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       21315      490/iobroker.js-con
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21479      1232/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27435      1651/io.web.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      116        21325      487/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          17176      509/sshd
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       28482      1718/io.simple-api.
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17538      386/cupsd
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19105      939/exim4
                          tcp6       0      0 :::3306                 :::*                    LISTEN      115        17362      610/mysqld
                          udp        0      0 0.0.0.0:48541           0.0.0.0:*                           1001       23439      1342/io.broadlink2.
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       29396      1406/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       29397      1406/io.tuya.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       32260      1356/io.shelly.0
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19413      428/dhcpcd
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17755      500/cups-browsed
                          udp        0      0 0.0.0.0:38536           0.0.0.0:*                           1001       23440      1342/io.broadlink2.
                          udp        0      0 0.0.0.0:54408           0.0.0.0:*                           108        17006      378/avahi-daemon: r
                          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       24717      1342/io.broadlink2.
                          udp        0      0 0.0.0.0:58599           0.0.0.0:*                           1001       38025      1342/io.broadlink2.
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       27151      1450/io.ham.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25363      1788/io.wled.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17004      378/avahi-daemon: r
                          udp        0      0 0.0.0.0:55640           0.0.0.0:*                           1001       23438      1342/io.broadlink2.
                          udp6       0      0 :::546                  :::*                                0          21565      428/dhcpcd
                          udp6       0      0 :::5353                 :::*                                108        17005      378/avahi-daemon: r
                          udp6       0      0 :::55692                :::*                                108        17007      378/avahi-daemon: r
                           / "{\"error\":\"timeout\"}\n""
                          2024-09-09 17:40:21.500  - warn: influxdb.0 (1280) Error on writePoint("{"value":180,"time":"2024-09-09T15:40:01.410Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:21.877  - warn: influxdb.0 (1280) Error on writePoint("{"value":47.4,"time":"2024-09-09T15:40:01.769Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:21.901  - warn: influxdb.0 (1280) Error on writePoint("{"value":189.3,"time":"2024-09-09T15:40:01.778Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:21.914  - warn: influxdb.0 (1280) Error on writePoint("{"value":95.087,"time":"2024-09-09T15:40:01.780Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:22.061  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 started with pid 2977
                          2024-09-09 17:40:23.819  - warn: influxdb.0 (1280) Error on writePoint("{"value":0.78,"time":"2024-09-09T15:39:53.553Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:23.840  - warn: influxdb.0 (1280) Error on writePoint("{"value":178.5,"time":"2024-09-09T15:39:53.553Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:23.913  - warn: influxdb.0 (1280) Error on writePoint("{"value":47,"time":"2024-09-09T15:39:53.558Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:23.927  - warn: influxdb.0 (1280) Error on writePoint("{"value":187.8,"time":"2024-09-09T15:39:53.558Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:23.945  - warn: influxdb.0 (1280) Error on writePoint("{"value":95.048,"time":"2024-09-09T15:39:53.559Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:23.960  - warn: influxdb.0 (1280) Error on writePoint("{"value":187.8,"time":"2024-09-09T15:39:53.560Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                          2024-09-09 17:40:35.930  - warn: dwd.0 (2956) slow connection to objects DB. Still waiting ...
                          2024-09-09 17:40:37.402  - warn: netatmo-crawler.0 (2977) slow connection to objects DB. Still waiting ...
                          2024-09-09 17:40:46.034  - warn: netatmo-crawler.0 (2977) slow connection to states DB. Still waiting ...
                          • Thomas BraunT Online
                            @tklein
                            Verbessert die Gesamtsituation aber nur marginalst.
