  3. Einsteigerfragen
  4. Logeinträge: Ping und Host.*
    5.4k
19 Beiträge 6 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • T tklein
    folgendes finde ich minütlich im Log:
    A:
    host.raspberrypi-iob 2024-09-09 16:46:36.674	error	instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at processImmediate (node:internal/timers:473:21)
    host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
    host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23)
    host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at Function.assertBoolean (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19)
    host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
    host.raspberrypi-iob 2024-09-09 16:46:36.673	error	Caught by controller[0]: (Use `node --trace-warnings ...` to show where the warning was created)
    host.raspberrypi-iob 2024-09-09 16:46:36.673	error	Caught by controller[0]: (node:22777) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
    B:
    ping.0 22777	2024-09-09 16:46:36.142	error	Parameter "ack" needs to be of type "boolean" but type "object" has been passed
    ping.0 22777	2024-09-09 16:46:36.141	error	Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed at Function.assertBool (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38) at processImmediate (node:internal/timers:473:21)
    ping.0 22777	2024-09-09 16:46:36.139	error	uncaught exception: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
    Was kann ich machen, damit es nicht mehr im Log steht?
    Node ist v18.0.0.
    Thomas
    mcm1957M Online
    mcm1957M Online
    mcm1957
    @tklein said in Logeinträge: Ping und Host.*:
    A:
    B:
    Node ist v18.0.0.
    Thomas
    Bitte putz mal deine Glaskugel und schau welche Versionen da installiert sind:
    adapter
    admin
    js-controller
    node
    o/s
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
      @tklein sagte in Logeinträge: Ping und Host.*:
      Node ist v18.0.0.
      und der Rest?
      Bitte iob diag in der Langfassung.
      tklein
      @homoran said in Logeinträge: Ping und Host.*:
      iob diag
      done:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi-iob
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       16:58:19 up 8 days, 21:50,  2 users,  load average: 2.45, 2.18, 2.51
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-09-09 16:58:19 CEST
                 Universal time: Mon 2024-09-09 14:58:19 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        2.4G        994M         33M        491M        1.3G
      Swap:           10G        2.0G        8.3G
      Total:          14G        4.3G        9.3G
      Active iob-Instances:   36
               3837 M total memory
               2351 M used memory
               1508 M active memory
               1201 M inactive memory
                994 M free memory
                 89 M buffer memory
                402 M swap cache
              10239 M total swap
               1953 M used swap
               8286 M free swap
      top - 16:58:20 up 8 days, 21:50,  2 users,  load average: 2.45, 2.18, 2.51
      Tasks: 172 total,   3 running, 169 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 40.0 us,  8.6 sy,  0.0 ni, 47.1 id,  0.0 wa,  0.0 hi,  4.3 si,  0.0 st
      MiB Mem :   3837.7 total,    994.5 free,   2350.4 used,    492.8 buff/cache
      MiB Swap:  10240.0 total,   8286.5 free,   1953.5 used.   1319.8 avail Mem
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4      220G   32G  180G  15% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G  185M  1.7G  10% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Sat Aug 31 19:07:29 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): write access will be enabled during recovery
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): 11 orphan inodes deleted
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): 1 truncate cleaned up
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): recovery complete
      [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Aug 31 19:07:31 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Aug 31 19:07:33 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                                SOURCE     FSTYPE     OPTIONS
      /                                     /dev/sda2  ext4       rw,noatime
      |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
      | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
      |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | | `-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
      | `-/sys/kernel/config                configfs   configfs   rw,relatime
      |-/proc                               proc       proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=40,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
      `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      7.0G    /var/
      1.4G    /var/cache/apt/archives
      1.4G    /var/cache/apt
      1.4G    /var/cache
      1.3G    /var/lib
      Archived and active journals take up 183.9M in the file system.
      /opt/iobroker/backups:
      899M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.9G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      618M    /opt/iobroker/iobroker-data/backup-objects
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      65M     /opt/iobroker/iobroker-data/objects.jsonl
      48M     /opt/iobroker/iobroker-data/states.jsonl
      42M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A94ZVX1D-if00-port0
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.0.0
      /usr/bin/node           v18.0.0
      /usr/bin/npm            8.6.0
      /usr/bin/npx            8.6.0
      /usr/bin/corepack       0.10.0
      nodejs:
        Installed: 18.0.0-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
           18.20.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.20.3-1nodesource1 1001
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
       *** 18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      (node:24672) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      (node:24724) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      js-controller:  5.0.19
      (node:24740) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      admin:          7.0.23
      (node:24753) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      javascript:     8.7.6
      nodejs modules from github:     6
      +-- iobroker.bmw@2.6.3 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#4d2becc9814575c1387493d403ee6b435578997c)
      +-- iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606)
      +-- iobroker.labcom@0.1.5 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#13ae01a87552c17f49fc39f49ae3dd5bde870906)
      | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
      | | +-- browser-serialport@2.0.3 (git+ssh://git@github.com/noopkat/browser-serialport.git#c8628c41c11890d3058875994c15f83f2df8185b)
      +-- iobroker.sourceanalytix@0.4.12-1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#362346b297c0a21c717ec20bd8d16331bca3b22d)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi-iob                          -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi-iob                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi-iob                          -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi-iob                          -  enabled
        system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi-iob                          - disabled
        system.adapter.apple-find-me.1          : apple-find-me         : raspberrypi-iob                          - disabled
        system.adapter.apple-find-me.2          : apple-find-me         : raspberrypi-iob                          - disabled
        system.adapter.apple-find-me.3          : apple-find-me         : raspberrypi-iob                          - disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi-iob                          -  enabled
        system.adapter.bmw.0                    : bmw                   : raspberrypi-iob                          - disabled
        system.adapter.bmw.1                    : bmw                   : raspberrypi-iob                          - disabled
        system.adapter.bring.0                  : bring                 : raspberrypi-iob                          - disabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi-iob                          -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi-iob                          -  enabled
        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi-iob                          - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi-iob                          - disabled
        system.adapter.device-reminder.0        : device-reminder       : raspberrypi-iob                          - disabled
        system.adapter.device-watcher.0         : device-watcher        : raspberrypi-iob                          - disabled
        system.adapter.devices.0                : devices               : raspberrypi-iob                          -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi-iob                          - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi-iob                          -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi-iob                          -  enabled
        system.adapter.enigma2.1                : enigma2               : raspberrypi-iob                          - disabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi-iob                          - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi-iob                          -  enabled
      + system.adapter.fhem.0                   : fhem                  : raspberrypi-iob                          -  enabled, port: 7072
        system.adapter.firetv.0                 : firetv                : raspberrypi-iob                          - disabled
        system.adapter.flot.0                   : flot                  : raspberrypi-iob                          -  enabled
        system.adapter.followthesun.0           : followthesun          : raspberrypi-iob                          - disabled
        system.adapter.geofency.0               : geofency              : raspberrypi-iob                          - disabled, port: 7999, bind: 0.0.0.0
        system.adapter.govee.0                  : govee                 : raspberrypi-iob                          - disabled
        system.adapter.habpanel.0               : habpanel              : raspberrypi-iob                          -  enabled
      + system.adapter.ham.0                    : ham                   : raspberrypi-iob                          -  enabled
        system.adapter.history.0                : history               : raspberrypi-iob                          - disabled
      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi-iob                          -  enabled
        system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi-iob                          - disabled
        system.adapter.ical.0                   : ical                  : raspberrypi-iob                          -  enabled
        system.adapter.ico-cloud.0              : ico-cloud             : raspberrypi-iob                          -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi-iob                          -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi-iob                          -  enabled
      + system.adapter.iot.1                    : iot                   : raspberrypi-iob                          -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi-iob                          -  enabled
        system.adapter.labcom.0                 : labcom                : raspberrypi-iob                          -  enabled
        system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi-iob                          - disabled
      + system.adapter.linux-control.0          : linux-control         : raspberrypi-iob                          -  enabled
        system.adapter.meater.0                 : meater                : raspberrypi-iob                          - disabled
        system.adapter.meross.0                 : meross                : raspberrypi-iob                          - disabled
        system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi-iob                          - disabled
        system.adapter.milight-smart-light.2    : milight-smart-light   : raspberrypi-iob                          - disabled
        system.adapter.milight-smart-light.3    : milight-smart-light   : raspberrypi-iob                          - disabled
        system.adapter.milight-smart-light.4    : milight-smart-light   : raspberrypi-iob                          - disabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-iob                          -  enabled, port: 1888, bind: 192.168.0.20
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
      + system.adapter.nina.0                   : nina                  : raspberrypi-iob                          -  enabled
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi-iob                          - disabled
        system.adapter.parcel.0                 : parcel                : raspberrypi-iob                          - disabled
        system.adapter.parser.0                 : parser                : raspberrypi-iob                          - disabled
        system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi-iob                          - disabled
        system.adapter.ping.0                   : ping                  : raspberrypi-iob                          -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi-iob                          -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi-iob                          -  enabled
        system.adapter.reolink.0                : reolink               : raspberrypi-iob                          - disabled
      + system.adapter.ring.0                   : ring                  : raspberrypi-iob                          -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-iob                          -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi-iob                          -  enabled
        system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi-iob                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : raspberrypi-iob                          -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi-iob                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi-iob                          - disabled
        system.adapter.sonoff.0                 : sonoff                : raspberrypi-iob                          - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.sonos.0                  : sonos                 : raspberrypi-iob                          - disabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi-iob                          - disabled
        system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi-iob                          - disabled
        system.adapter.sql.0                    : sql                   : raspberrypi-iob                          - disabled, port: 3306
        system.adapter.systeminfo.0             : systeminfo            : raspberrypi-iob                          - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-iob                          -  enabled
      + system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi-iob                          -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi-iob                          -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : raspberrypi-iob                          - disabled, port: 8089, bind: 192.168.0.20, run as: admin
        system.adapter.text2command.0           : text2command          : raspberrypi-iob                          - disabled
      + system.adapter.tibberlink.0             : tibberlink            : raspberrypi-iob                          -  enabled
        system.adapter.tr-064.0                 : tr-064                : raspberrypi-iob                          - disabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-iob                          -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi-iob                          -  enabled
        system.adapter.twinkly.0                : twinkly               : raspberrypi-iob                          - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-iob                          -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-iob                          -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-iob                          - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi-iob                          -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi-iob                          -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi-iob                          - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-iob                          - disabled
      + system.adapter.web.0                    : web                   : raspberrypi-iob                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : raspberrypi-iob                          -  enabled
        system.adapter.yahka.0                  : yahka                 : raspberrypi-iob                          - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi-iob                          -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
      + instance is alive
      ioBroker-Repositories
      (node:24770) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      Active repo(s): stable
      Installed ioBroker-Instances
      (node:24779) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      Used repository: stable
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "alarm"        : 3.6.1    , installed 3.6.1
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 3.0.22   , installed 3.0.19 [Updatable]
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "broadlink2"   : 2.3.0    , installed 2.2.0  [Updatable]
      Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.15 [Updatable]
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fhem"         : 2.0.5    , installed 2.0.5
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "followthesun" : 0.5.1    , installed 0.5.0  [Updatable]
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 5.0.19 [Updatable]
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
      Adapter    "meater"       : 1.1.1    , installed 1.1.1
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "milight"      : 0.4.0    , installed 0.4.0
      Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "parser"       : 2.2.2    , installed 2.2.2
      Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
      Adapter    "reolink"      : 1.1.1    , installed 1.1.1
      Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
      Adapter    "rflink"       : 2.1.12   , installed 2.1.12
      Adapter    "ring"         : 5.1.0    , installed 5.0.10 [Updatable]
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shelly"       : 7.0.0    , installed 6.8.0  [Updatable]
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "telegram-menu": 2.0.0    , installed 1.7.4  [Updatable]
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
      Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.0.0  [Updatable]
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        47310
      States:         3
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://repos.influxdata.com/debian buster InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      E: Broken packages
      Pending Updates:
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19638      653/perl
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17073      549/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          24749532   1565/cupsd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        18835      506/influxd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19824      982/exim4
      tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       26535      2032/io.mqtt.0
      tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19670      653/perl
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       32926      2073/io.shelly.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23582      507/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20350      507/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23510      1406/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30869      2134/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      116        21367      506/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17083      549/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          24749531   1565/cupsd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30132      2234/io.simple-api.
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19825      982/exim4
      tcp6       0      0 :::3306                 :::*                    LISTEN      115        18243      647/mysqld
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32892      1916/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32893      1916/io.tuya.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33696      1668/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21700      419/dhcpcd
      udp        0      0 0.0.0.0:47191           0.0.0.0:*                           1001       26236      1639/io.broadlink2.
      udp        0      0 0.0.0.0:60531           0.0.0.0:*                           108        17643      401/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          24746963   1566/cups-browsed
      udp        0      0 0.0.0.0:60026           0.0.0.0:*                           1001       26235      1639/io.broadlink2.
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       28061      1639/io.broadlink2.
      udp        0      0 0.0.0.0:36572           0.0.0.0:*                           1001       26238      1639/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       30520      2020/io.ham.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29903      2265/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17641      401/avahi-daemon: r
      udp        0      0 0.0.0.0:33143           0.0.0.0:*                           1001       26811587   1639/io.broadlink2.
      udp6       0      0 :::546                  :::*                                0          21724      419/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        17642      401/avahi-daemon: r
      udp6       0      0 :::49409                :::*                                108        17644      401/avahi-daemon: r
      2024-09-09 16:59:49.516  - error: host.raspberrypi-iob Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
      2024-09-09 16:59:49.516  - error: host.raspberrypi-iob Caught by controller[1]:     at processImmediate (node:internal/timers:473:21)
      2024-09-09 16:59:49.516  - error: host.raspberrypi-iob instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-09-09 16:59:49.516  - info: host.raspberrypi-iob Restart adapter system.adapter.ping.0 because enabled
      2024-09-09 17:00:08.903  - info: host.raspberrypi-iob instance system.adapter.dwd.0 started with pid 24837
      2024-09-09 17:00:14.186  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 started with pid 24848
      2024-09-09 17:00:20.339  - info: host.raspberrypi-iob instance system.adapter.labcom.0 started with pid 24870
      2024-09-09 17:00:24.812  - info: host.raspberrypi-iob instance system.adapter.ping.0 started with pid 24881
      2024-09-09 17:00:26.757  - warn: netatmo-crawler.0 (24848) slow connection to states DB. Still waiting ...
      2024-09-09 17:00:30.245  - info: host.raspberrypi-iob instance system.adapter.ical.0 started with pid 24892
      2024-09-09 17:01:21.461  - info: host.raspberrypi-iob instance system.adapter.labcom.0 terminated with code 0 (NO_ERROR)
      2024-09-09 17:01:26.416  - error: ping.0 (24881) uncaught exception: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      2024-09-09 17:01:26.420  - error: ping.0 (24881) Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      2024-09-09 17:01:26.422  - error: ping.0 (24881) Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      2024-09-09 17:01:27.942  - error: host.raspberrypi-iob Caught by controller[1]: Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      2024-09-09 17:01:27.943  - error: host.raspberrypi-iob Caught by controller[1]:     at Function.assertBoolean (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19)
      2024-09-09 17:01:27.943  - error: host.raspberrypi-iob Caught by controller[1]:     at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23)
      2024-09-09 17:01:27.944  - error: host.raspberrypi-iob Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
      2024-09-09 17:01:27.944  - error: host.raspberrypi-iob Caught by controller[1]:     at processImmediate (node:internal/timers:473:21)
      2024-09-09 17:01:27.944  - error: host.raspberrypi-iob instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-09-09 17:01:27.945  - info: host.raspberrypi-iob Restart adapter system.adapter.ping.0 because enabled
      Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
      • T tklein
        iob diag
        done:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           10G        2.0G        8.3G
                 3837 M total memory
                 2351 M used memory
                  994 M free memory
                   89 M buffer memory
                  402 M swap cache
                10239 M total swap
                 1953 M used swap
                 8286 M free swap
        *** FILESYSTEM ***
        /var:
        7.0G    /var/
        1.4G    /var/cache/apt
        1.4G    /var/cache
        1.3G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            8.6.0
        /usr/bin/npx            8.6.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.0.23
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        47310
        States:         3
        E: Broken packages
        Pending Updates:
        Meister MopperM Offline
        Meister Mopper
        Da weiß man ja gar nicht wo man mit der Hilfe anfangen soll. Hast du aktuelle Backups vom backitup-Adapter?
        Proxmox und HA ...
        Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
          tklein
          @meister-mopper oha, so schlimm? lasse gerade ein neues erstellen da ich von heute nacht (automatisch) bis gerade einiges gemacht habe
          • T tklein
            iob diag
            done:
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : 32 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           10G        2.0G        8.3G
                     3837 M total memory
                     2351 M used memory
                      994 M free memory
                       89 M buffer memory
                      402 M swap cache
                    10239 M total swap
                     1953 M used swap
                     8286 M free swap
            *** FILESYSTEM ***
            /var:
            7.0G    /var/
            1.4G    /var/cache/apt
            1.4G    /var/cache
            1.3G    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            8.6.0
            /usr/bin/npx            8.6.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          7.0.23
            javascript:     8.7.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        47310
            States:         3
            E: Broken packages
            Pending Updates:
            (buster)
            Kannste nur neuinstallieren, diesmal in der 64Bit Lite-Version.
            Denn das Dateisystem hat Einschläge:
            nodejs total veraltet.
            E: Broken packages
            Paketverwaltung hin.
            T paul53P 2 Antworten Letzte Antwort
            • T tklein
              Meister Mopper
              @tklein
              Leider hat dein Dateisystem einen Turmtreffer, und buster ist auch nicht wiederbelebbar.
              Da hilft nur eine Neuinstallation mit einer aktuellen Debian 12 (bookworm) lite mit 64 bit und anschließendem backitup restore.
              Proxmox und HA ...
                (buster)
                E: Broken packages
                tklein
                @thomas-braun ja ich drück mich schon recht lange davor. habe ca 120 zigbee device die alle neu angelernt werden müssten... derzeit noch am conbee2 als coordinator
                • T tklein
                  Meister Mopper
                  Davor drücken bringt nix, wie du gerade erfährst. Selbst die Zigbee-Konfiguration kannst du super mit dem backitup Adapter sichern.
                  Proxmox und HA ...
                  • T tklein
                    Je länger du dich 'drückst', umso komplizierter wird es.
                    Der einzige gangbare Weg ist die Neuinstallation, daher musst du dir über Alternativen erst gar nicht den Kopf zerbrechen.
                      (buster)
                      E: Broken packages
                      @thomas-braun sagte: das Dateisystem hat Einschläge:
                      Sieht ganz danach aus:
                      Objects:        47310
                      States:         3
                      T Thomas BraunT 2 Antworten Letzte Antwort
                        tklein
                        @meister-mopper ich dachte, dass die zigbee devices neu gepairt werden müssten
                          Objects:        47310
                          States:         3
                          tklein
                          @paul53 was soll/kann mir das sagen? ssd-fehler?
                            Objects:        47310
                            States:         3
                            @paul53 sagte in Logeinträge: Ping und Host.*:
                            Da stellt sich auch die Frage, ob man aus dem wurmstichigen Ding überhaupt noch ein solides Backup ziehen kann.
                            • T tklein
                              @tklein sagte: was soll/kann mir das sagen?
                              Offenbar kann die Datei "states.jsonl" nicht gelesen werden, denn nur 3 States gibt es nicht.
                                tklein
                                da muss ich mich wohl nach einer zweiten ssd und einem neuen zigbee coordinator umschauen.
                                Der Raspi sollte wohl nur für den iob ohne grafana reichen, oder?
                                  Node ist v18.0.0.
                                  und der Rest?
                                  tklein
                                  hier ein Update nach Neustart mit 40 K states :-)
                                  Skript v.2024-05-22
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm
                                  Docker          : false
                                  Kernel          : armv7l
                                  Userland        : 32 bit
                                   17:36:47 up 5 min,  2 users,  load average: 5.36, 3.22, 1.39
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Mon 2024-09-09 17:36:47 CEST
                                             Universal time: Mon 2024-09-09 15:36:47 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:           3.8G        3.0G        506M        2.0M        356M        728M
                                  Swap:           10G         16M         10G
                                  Total:          14G        3.0G         10G
                                  Active iob-Instances:   37
                                           3837 M total memory
                                           2976 M used memory
                                            198 M active memory
                                           3011 M inactive memory
                                            505 M free memory
                                             92 M buffer memory
                                            263 M swap cache
                                          10239 M total swap
                                             16 M used swap
                                          10223 M free swap
                                  top - 17:36:48 up 5 min,  2 users,  load average: 5.36, 3.22, 1.39
                                  Tasks: 168 total,   5 running, 163 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s): 39.2 us,  4.1 sy,  0.0 ni, 54.1 id,  0.0 wa,  0.0 hi,  2.7 si,  0.0 st
                                  MiB Mem :   3837.7 total,    508.3 free,   2973.2 used,    356.2 buff/cache
                                  MiB Swap:  10240.0 total,  10223.7 free,     16.3 used.    730.8 avail Mem
                                  *** FILESYSTEM ***
                                  /dev/root      ext4      220G   32G  180G  16% /
                                  tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
                                  [Mon Sep  9 17:31:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                  [Mon Sep  9 17:31:30 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                  [Mon Sep  9 17:31:30 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                  [Mon Sep  9 17:31:32 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                                  | | `-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
                                  | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                  /var:
                                  7.0G    /var/
                                  1.4G    /var/lib
                                  1.4G    /var/cache/apt
                                  1.4G    /var/cache
                                  Archived and active journals take up 8.0M in the file system.
                                  1.3G    /opt/iobroker/backups/
                                  18M     /opt/iobroker/backups/tmpScripts
                                  80M     /opt/iobroker/iobroker-data/objects.jsonl
                                  52M     /opt/iobroker/iobroker-data/states.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            8.6.0
                                  /usr/bin/npx            8.6.0
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  (node:2655) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                   Cannot determine Set feature status: Connection is closed.
                                   Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                                   Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                   Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                  Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                  (node:2693) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                  (node:2710) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                  admin:          7.0.23
                                  (node:2725) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                  javascript:     8.7.6
                                  Adapter State
                                  + system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
                                  + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
                                  + system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
                                  + instance is alive
                                  (node:2742) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                  (node:2761) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                  Objects and States
                                  Objects:        47312
                                  States:         40875
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                  E: Broken packages
                                  Pending Updates:
                                  tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        17916      631/perl
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18710      509/sshd
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17539      386/cupsd
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        18730      487/influxd
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19104      939/exim4
                                  tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       28325      1484/io.mqtt.0
                                  tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        17925      631/perl
                                  tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       31851      1560/io.shelly.1
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23723      490/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       21315      490/iobroker.js-con
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21479      1232/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27435      1651/io.web.0
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      116        21325      487/influxd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17176      509/sshd
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       28482      1718/io.simple-api.
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17538      386/cupsd
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19105      939/exim4
                                  tcp6       0      0 :::3306                 :::*                    LISTEN      115        17362      610/mysqld
                                  udp        0      0 0.0.0.0:48541           0.0.0.0:*                           1001       23439      1342/io.broadlink2.
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       29396      1406/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       29397      1406/io.tuya.0
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       32260      1356/io.shelly.0
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19413      428/dhcpcd
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17755      500/cups-browsed
                                  udp        0      0 0.0.0.0:38536           0.0.0.0:*                           1001       23440      1342/io.broadlink2.
                                  udp        0      0 0.0.0.0:54408           0.0.0.0:*                           108        17006      378/avahi-daemon: r
                                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       24717      1342/io.broadlink2.
                                  udp        0      0 0.0.0.0:58599           0.0.0.0:*                           1001       38025      1342/io.broadlink2.
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       27151      1450/io.ham.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25363      1788/io.wled.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17004      378/avahi-daemon: r
                                  udp        0      0 0.0.0.0:55640           0.0.0.0:*                           1001       23438      1342/io.broadlink2.
                                  udp6       0      0 :::546                  :::*                                0          21565      428/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        17005      378/avahi-daemon: r
                                  udp6       0      0 :::55692                :::*                                108        17007      378/avahi-daemon: r
                                   / "{\"error\":\"timeout\"}\n""
                                  2024-09-09 17:40:21.500  - warn: influxdb.0 (1280) Error on writePoint("{"value":180,"time":"2024-09-09T15:40:01.410Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:21.877  - warn: influxdb.0 (1280) Error on writePoint("{"value":47.4,"time":"2024-09-09T15:40:01.769Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:21.901  - warn: influxdb.0 (1280) Error on writePoint("{"value":189.3,"time":"2024-09-09T15:40:01.778Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:21.914  - warn: influxdb.0 (1280) Error on writePoint("{"value":95.087,"time":"2024-09-09T15:40:01.780Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:22.061  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 started with pid 2977
                                  2024-09-09 17:40:23.819  - warn: influxdb.0 (1280) Error on writePoint("{"value":0.78,"time":"2024-09-09T15:39:53.553Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:23.840  - warn: influxdb.0 (1280) Error on writePoint("{"value":178.5,"time":"2024-09-09T15:39:53.553Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:23.913  - warn: influxdb.0 (1280) Error on writePoint("{"value":47,"time":"2024-09-09T15:39:53.558Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:23.927  - warn: influxdb.0 (1280) Error on writePoint("{"value":187.8,"time":"2024-09-09T15:39:53.558Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:23.945  - warn: influxdb.0 (1280) Error on writePoint("{"value":95.048,"time":"2024-09-09T15:39:53.559Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:23.960  - warn: influxdb.0 (1280) Error on writePoint("{"value":187.8,"time":"2024-09-09T15:39:53.560Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                  2024-09-09 17:40:35.930  - warn: dwd.0 (2956) slow connection to objects DB. Still waiting ...
                                  2024-09-09 17:40:37.402  - warn: netatmo-crawler.0 (2977) slow connection to objects DB. Still waiting ...
                                  2024-09-09 17:40:46.034  - warn: netatmo-crawler.0 (2977) slow connection to states DB. Still waiting ...
                                  • Thomas BraunT Online
                                    @tklein
                                    Verbessert die Gesamtsituation aber nur marginalst.
