  4. Pool Thermometer und Chlormesser
    6.8k
allgemein
118 Beiträge 30 Kommentatoren 27.5k Aufrufe 40 Beobachtet
  • D Diamand2k22
    @oxident
    Hallo oxident, könntest du mir bitte die yaml zur Verfügung stellen?
    Eine Frage noch, ist es dann möglich, die Messung unabhängig anzutriggern? Bei mir wird aktuell alle 75 Minuten über Sigfox gemessen natürlich mit Abo 😀
    O Online
    O Online
    oxident
    #98
    @diamand2k22 Hoppla, sorry. Völlig vergessen:
    substitutions:
      # Blueconnect
      blueriiot2_mac: '00:A0:50:24:79:67' # ANPASSEN
      blueriiot2_name_prefix: 'spa'
      blueriiot2_id_prefix: 'sp'
      # send true 0x01 to this service ID
      blueriiot_send_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
      blueriiot_send_characteristic_uuid: 'F3300002-F0A2-9B06-0C59-1BC4763B5C00'
      # notification is recieved on this Service ID
      blueriiot_recieve_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
      blueriiot_recieve_characteristic_uuid: 'F3300003-F0A2-9B06-0C59-1BC4763B5C00'
    esphome:
      friendly_name: Pool
      on_boot:
        priority: 600
        then:
          - delay: 20s
    esp32:
      board: m5stack-atom # ANPASSEN
      framework:
        type: esp-idf
        version: recommended
    # Enable logging
    logger:
      #level: VERY_VERBOSE
      level: INFO
    # Enable Home Assistant API
    api:
      password: "1234"
    ota:
      password: "1234"
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
    web_server:
      port: 80
    output:
      # Countermeasure to the problem that CH552 applies 4v to GPIO0, thus reducing WiFi sensitivity.
      # Setting output_high adds a bias of 3.3v and suppresses overvoltage.
      # From: https://github.com/m5stack/M5Unified/blob/d26d2415f409b664631ff066ceeaffd6a753a4ff/src/M5Unified.cpp#L506
      - platform: gpio
        pin: GPIO0
    esp32_ble_tracker:
      scan_parameters:
        active: false
        interval: 1000ms
        window: 700ms
      on_ble_advertise:
        - mac_address: ${blueriiot2_mac}
          then:
            - logger.log:
                format: "Found Spa sensor with RSSI %d"
                args: [ "x.get_rssi()"]
                level: "INFO"
    ble_client:
        on_connect:
          then:
            - logger.log:
                format: "Connected to 2nd sensor"
                level: "INFO"
            - lambda: "id(binary_sensor_${blueriiot2_id_prefix}_connected).publish_state(true);"
            - delay: 2s
            - button.press: button_${blueriiot2_id_prefix}_doreading
        on_disconnect: [lambda: "id(binary_sensor_${blueriiot2_id_prefix}_connected).publish_state(false);"]
    binary_sensor:
     - platform: template
       device_class: connectivity
       entity_category: diagnostic
    # OPTIONAL und SPEZIFISCH für M5Atom
    # derzeit: Led bei Knopfdruck an-/ausschalten
    #  - platform: gpio # btn
    #    id: pushbutton
    #    pin:
    #      number: 39
    #      inverted: true
    #    on_click:
    #      then:
    #        - if:
    #            condition:
    #              - light.is_on: matrix_light
    #            then:
    #              - light.turn_off: matrix_light
    #            else:
    #              - light.turn_on:
    #                  id: matrix_light
    #                  effect: rainbow
    #light:
    #  - platform: fastled_clockless # 5x5 RGB Matrix (WS2812C)
    #    name: "5x5 Matrix"
    #    id: matrix_light
    #    pin: 27
    #    chipset: WS2812
    #    num_leds: 25
    #    color_correct: [50%, 50%, 50%] # The LED's on the Atom Matrix should not be run at full power
    #    effects:
    #      - addressable_rainbow:
    #          name: rainbow
    # ENDE spezifischer Teil M5Atom
    sensor:
      - platform: ble_rssi
        name: "RSSI value Spa sensor"
        name: ${blueriiot2_name_prefix} Temperature
        # Optional variables:
        unit_of_measurement: "°C"
        icon: "mdi:water-percent"
        device_class: "temperature"
        state_class: "measurement"
        accuracy_decimals: 1
        #unit_of_measurement: "°C"
        #icon: "mdi:water-percent"
        #device_class: "temperature"
        device_class: "voltage"
        unit_of_measurement: "%"
        device_class: "battery"
        unit_of_measurement: "g/L"
        name: ${blueriiot2_name_prefix} Conductivity
        unit_of_measurement: "mS/cm"
    switch:
      - platform: ble_client
        ble_client_id: ble_client_${blueriiot2_id_prefix}
      - platform: restart
    button:
        name: ${blueriiot2_name_prefix} do reading
        internal: true
        on_press:
          then:
            - logger.log:
                format: "Writing to 2nd sensor..."
                level: "INFO"
            - ble_client.ble_write:
                service_uuid: ${blueriiot_send_service_uuid}
                characteristic_uuid: ${blueriiot_send_characteristic_uuid}
                # A lambda returning an std::vector<uint8_t>.
                value: !lambda |-
                  return {0x01};
    text_sensor:
        name: ${blueriiot2_name_prefix} reading data
        internal: true
        service_uuid: ${blueriiot_recieve_service_uuid}
        characteristic_uuid: ${blueriiot_recieve_characteristic_uuid}
        notify: true
        update_interval: never
        on_notify:
          then:
           lambda: |-
              std::string rawhex = format_hex_pretty((uint8_t *) x.c_str(), x.size()).c_str();
              ESP_LOGD("raw_hex", "%s", rawhex.c_str());
              float temperature = (float)((int16_t)(x[2]<< 8) + x[1])/100;
              ESP_LOGD("temp", "%f", temperature);
              id(sensor_${blueriiot2_id_prefix}_temperature).publish_state(temperature);
              float raw_ph = (float)( (int16_t) (x[4]<< 8) + x[3]) ;
              float ph = (float)( (int16_t) (2048 - raw_ph)) / 232  + 7 ;
              ESP_LOGD("ph", "%f", ph);
              id(sensor_${blueriiot2_id_prefix}_ph).publish_state(ph);
              float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 3.86  - 21.57826;
              ESP_LOGD("orp", "%f", orp);
              id(sensor_${blueriiot2_id_prefix}_orp).publish_state(orp);
              float salt = (float)( (int16_t) (x[8]<< 8) + x[7]) / 25.0;
              ESP_LOGD("salt", "%f", salt);
              id(sensor_${blueriiot2_id_prefix}_salt).publish_state(salt);
              float cond = (float)( (int16_t) (x[10]<< 8) + x[9]) / 0.4134;
              ESP_LOGD("cond", "%f", cond);
              id(sensor_${blueriiot2_id_prefix}_cond).publish_state(cond);
              float bat = (float)( (int16_t) x[11]);
              ESP_LOGD("bat", "%f", bat);
              id(sensor_${blueriiot2_id_prefix}_bat).publish_state(bat);
              id(switch_${blueriiot2_id_prefix}_enable).turn_off();
    Du müsstest eigentlich nur die MAC-Adresse ganz oben eintragen und den Rest nach belieben anpassen. Ich habe es auf einem m5stack-Atom laufen ... bei anderen solltest Du eventuell noch die "platform" ändern.
    Ja, dann kannst Du so oft Du willst die Messung anstoßen. Einfach den "... enable" switch setzen und abwarten.
    • O oxident
      substitutions:
        # Blueconnect
      esphome:
        friendly_name: Pool
        on_boot:
          priority: 600
          then:
            - delay: 20s
      esp32:
        framework:
          type: esp-idf
      # Enable logging
      logger:
        level: INFO
      api:
        password: "1234"
      ota:
        password: "1234"
      wifi:
      web_server:
        port: 80
      output:
        - platform: gpio
          pin: GPIO0
      esp32_ble_tracker:
        scan_parameters:
          active: false
          interval: 1000ms
          window: 700ms
        on_ble_advertise:
            then:
              - logger.log:
                  level: "INFO"
      ble_client:
          on_connect:
            then:
              - logger.log:
                  level: "INFO"
              - delay: 2s
      binary_sensor:
      #    id: pushbutton
      #    pin:
      #      number: 39
      #      inverted: true
      #    on_click:
      #      then:
      #        - if:
      #            condition:
      #            then:
      #            else:
      #              - light.turn_on:
      #                  id: matrix_light
      #                  effect: rainbow
      #light:
      #    id: matrix_light
      #    pin: 27
      #    chipset: WS2812
      #    num_leds: 25
      #    effects:
      #          name: rainbow
      sensor:
      switch:
        - platform: restart
      button:
          internal: true
          on_press:
            then:
              - logger.log:
                  level: "INFO"
                  value: !lambda |-
                    return {0x01};
      text_sensor:
          internal: true
          notify: true
          on_notify:
            then:
             lambda: |-
      Diamand2k22
      #99
      @oxident
      Super danke dir 👍🏻 hattest du nicht ein ESP32 WROOM 32 DevKitC V4 38 Pin Board?
      O 1 Antwort Letzte Antwort
      • D Diamand2k22
        @oxident
        O Online
        O Online
        oxident
        #100
        @diamand2k22 Ja, in der Tat. Das nutze ich aber zusätzlich noch für ein paar andere Sachen (Poolabdeckung und ein paar Taster). Da war mir die YAML zu kompliziert zum Auseinanderpflücken ;-)
        Habe daher die "alte" Version gepostet. Im Blueconnect-Teil hat sich aber nix verändert.
        • O oxident
          Diamand2k22
          #101
          @oxident
          Danke dir, ich probiere es mal aus. Ist mein erster esp32 😀
          • D Diamand2k22
            @oxident
            O Online
            O Online
            oxident
            #102
            @diamand2k22 Steile Lernkurve ... aber letzten Endes lohnt es sich und macht Spaß :-)
            • M mameier1234
              @sithys-mahony Da liegst du richtig ...
              Username und Passwort, aus der App....
              vowillV Offline
              vowillV Offline
              vowill
              #103
              Danke an @mameier1234 für den Blueconnect-Adapter - funktioniert einwandfrei!
              Ein Hinweis für alle, die sich - wie ich zunächst - über den Zeitversatz bei der letzten Messung wundern: Der über den Adapter in xx.timestamp gelieferte Zeitstempel ist im GMT-Format. Für Deutschland müssen da also 1 (Winterzeit) bzw. 2 (Sommerzeit) Stunden hinzuaddiert werden. Oder man nutzt in einem Skript die Funktion:
              // Umwandlung Zeitstempel von GMT nach ME(S)Z
              timestamp_in_ME_S_Z = formatDate(getDateObject(getState('blueconnect.0.xxxx.ph.timestamp').val), 'TT.MM.JJJJ SS:mm:ss');
              bzw. als Blockly:
              ioBroker im lxc auf NUC / Aktive Instanzen: 38
              • O oxident
                Diamand2k22
                #104
                @oxident
                Wie hast du die Mac Adresse von dem BlueConnect herausgefunden?
                vowillV O 2 Antworten Letzte Antwort
                • D Diamand2k22
                  @oxident
                  vowillV Offline
                  vowillV Offline
                  vowill
                  #105
                  @diamand2k22 Die Adresse wird vom Adapter automatisch eingetragen, wenn man sich mit Name und Passwort (aus der App) anmeldet. Voraussetzung ist, wie weiter oben geschrieben, dass man entweder einen Blueconnect Go Plus hat oder für den 'normalen' Blueconnect ein Abo bucht.
                  • D Diamand2k22
                    @oxident
                    O Online
                    O Online
                    oxident
                    #106
                    @diamand2k22 Ehrlich gesagt habe ich auf irgendeinem Gerät, ich glaube, es war ein Shelly, mal mitgeloggt, welche BLE-Geräte sich immer so melden ;-)
                    Vielleicht kannst Du es auch auf dem Handy mit der App herausfinden.
                    • O oxident
                      Diamand2k22
                      #107
                      @oxident
                      In der App stehts leider nicht drin,
                      das war meine erste Idee 😀
                      Nagut dann muss ich mal schauen wie ich das mache, notfalls über Shelly.
                      Ich hab mir jetzt übrigens auch einen M5Stack Atom besorgt, da sollte ich ja deine komplette yaml 1:1 bis auf die Mac Adresse übernehmen können oder ?
                      • D Diamand2k22
                        @oxident
                        O Online
                        O Online
                        oxident
                        #108
                        @diamand2k22 Ja, klar. Aber eigentlich sollte auch jeder andere ESP32 funktionieren. Beim M5Stack ist halt etwas doof, dass er keine Antenne hat und Bluetooth/Wifi gleichzeitig auch manchmal hakt...
                        • O oxident
                          Diamand2k22
                          schrieb am zuletzt editiert von Diamand2k22
                          #109
                          @oxident
                          Ich hab mir den jetzt mal aufgrund des Gehäuses gekauft, da ich bei den anderen esp32 Platinen mir immer zusätzlich was basteln musst und ich wollte den M5Atom mal ausprobieren 😀
                          Von der Reichweite sollte es gehen, der Pool ist ca. 3Meter vom m5atom entfernt .
                          • D Diamand2k22
                            @oxident
                            O Online
                            O Online
                            oxident
                            #110
                            @diamand2k22 Ja, das müsste passen. Viel Erfolg ;-)
                            • O oxident
                              Diamand2k22
                              #111
                              @oxident
                              hab's hinbekommen mit ble tracker und logging level verbose.
                              jetzt läuft alles, danke dir nochmal!
                              • D Diamand2k22
                                @oxident
                                O Online
                                O Online
                                oxident
                                #112
                                @diamand2k22 Gerne. Aber es bleibt noch "work in progress" ... wenn Du Fehler findest, gerne Bescheid sagen!
                                • O oxident
                                  @diamand2k22 Letzten Endes habe ich diesen ESP32 hier benutzt: https://www.ebay.de/itm/373835160946?mkcid=16&mkevt=1&mkrid=707-127634-2357-0&ssspo=VPl0vy4uQMu&sssrc=4429486&ssuid=l3eyvw_dRxm&var=&widget_ver=artemis&media=COPY
                                  Wichtig war die Antenne halt bei mir wegen WLAN und Bluetooth. Die regulären ESP32 konnten halt kaum eine Verbindung zum Blueconnect herstellen und hatten erst Recht Stress, wenn gleichzeitig Daten ins WLAN gesendet wurden.
                                  Der neue ESP ist deutlich leistungsfähiger und bekommt zuverlässig die Daten vom Sensor.
                                  Wie gesagt, YAML liefere ich nach, sobald ich zu Hause bin.
                                  W Offline
                                  W Offline
                                  willywonka89
                                  #113
                                  @oxident said in Pool Thermometer und Chlormesser:
                                  Hi!
                                  @oxident welchen esp32 hast du genau genommen? Der ebay link funktioniert leider nicht mehr 🙁
                                  • W willywonka89
                                    Hi!
                                    O Online
                                    O Online
                                    oxident
                                    #114
                                    @willywonka89 Also eigentlich war escein ganz normaler ESP32-WROOM mit externer Antenne.
                                    Schau mal hier: https://www.ebay.de/itm/286506582655?mkcid=16&mkevt=1&mkrid=707-127634-2357-0&ssspo=IA0Xwa_pTMi&sssrc=4429486&ssuid=l3eyvw_dRxm&var=&widget_ver=artemis&media=COPY
                                    W 1 Antwort Letzte Antwort
                                    • O oxident
                                      W Offline
                                      W Offline
                                      willywonka89
                                      #115
                                      @oxident super danke für die Info! Hast du dann im Endeffekt eben so einen ESP32 WROOM genutzt oder den M5Atom?
                                      lg rainer
                                      • W willywonka89
                                        lg rainer
                                        O Online
                                        O Online
                                        oxident
                                        #116
                                        @willywonka89 Letzten Endes des WROOM ... der M5 hatte leider immer Stress gemacht, wenn ich Wifi und BLE gleichzeitig genutzt habe. Kann aber auch am schlechten (BLE-)Empfang gelegen haben.
                                        Ansonsten wäre der M5 natürlich super geeignet.
                                        • Vanom VineV Offline
                                          Vanom VineV Offline
                                          Vanom Vine
                                          #117
                                          Moin. Habe mir einen Blueconnect geholt. Habe den auch im Iobroker eingebunden und kann Daten ziehen und lesen. Allerdings nur wenn ich per Bluetooth über das Handy eine Abfrage mache. Bekomme also keine Automatisch (oder alle 24H) auf den iobroker...
                                          Abo habe ich nicht. Bin aber angemeldet...
                                          Danke euch
