  4. Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]
    6.6k
45 Beiträge 3 Kommentatoren 5.1k Aufrufe 2 Beobachtet
  • K Krissie777
    @marc-berg said in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
    iob diag
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     15:37:31 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Fri 2024-08-23 15:37:31 CEST
               Universal time: Fri 2024-08-23 13:37:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.0G        1.4G        9.0M        1.5G        2.8G
    Swap:           99M          0B         99M
    Total:         3.9G        1.0G        1.5G
    Active iob-Instances:   15
             3837 M total memory
             1010 M used memory
              331 M active memory
             2050 M inactive memory
             1351 M free memory
               87 M buffer memory
             1387 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 15:37:32 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
    Tasks: 156 total,   2 running, 154 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 18.3 us, 20.4 sy,  0.0 ni, 58.1 id,  1.1 wa,  0.0 hi,  2.2 si,  0.0 st
    MiB Mem :   3837.7 total,   1351.6 free,   1010.7 used,   1475.5 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2827.9 avail Mem
    *** FAILED SERVICES ***
      UNIT               LOAD   ACTIVE SUB    DESCRIPTION
    * PiEMItMgmt.service loaded failed failed PiEM-It! Mgmt-Modul, respawn
    * Webserver.service  loaded failed failed PiEM-It! Webserver-Modul, respawn
    2 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  49% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  9.6M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Fri Aug 23 14:14:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hd        mi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=E4:5F:01:57:C6:34 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tt        yS0,115200 console=tty1 root=PARTUUID=d2b297f7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.igno        re-serial-consoles
    [Fri Aug 23 14:14:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Aug 23 14:14:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Aug 23 14:14:58 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE     FSTYPE     OPTIONS
    /                                     /dev/sda2  ext4       rw,noatime
    |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
    | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
    |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | |-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | | `-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
    | `-/sys/kernel/config                configfs   configfs   rw,relatime
    |-/proc                               proc       proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
    | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
    `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mi        xed,errors=remount-ro
    /var:
    2.6G    /var/
    1.5G    /var/cache/apt
    1.5G    /var/cache
    1.4G    /var/cache/apt/archives
    789M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.3G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    824M    /opt/iobroker/iobroker-data/
    696M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Device_GmbH_DvIR-USB_DvIR-USB_000524-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.3-1nodesource1 600
         18.20.2-1nodesource1 600
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              -  enabled
    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "ebus"         : 3.3.4    , installed 3.3.4
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "hmip"         : 1.23.3   , installed 1.23.3
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
    Objects and States
    Objects:        9367
    States:         8906
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 https://repo.ebusd.eu/apt/default/buster buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20676      721/sshd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        20846      703/influxd
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          19480      707/ebusd
    tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          19481      707/ebusd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          21030      783/smbd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19427      970/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19420      970/iobroker.js-con
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          21031      783/smbd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21373      989/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24742      1140/io.ws.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        19334      703/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20686      721/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18719      718/xrdp-sesman
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23966      1155/io.simple-api.
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        21203      695/grafana-server
    tcp6       0      0 :::3389                 :::*                    LISTEN      111        21042      746/xrdp
    tcp6       0      0 :::445                  :::*                    LISTEN      0          21028      783/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          21029      783/smbd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15346      692/dhcpcd
    udp        0      0 0.0.0.0:50817           0.0.0.0:*                           108        15105      437/avahi-daemon: r
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          19917      694/nmbd
    udp        0      0 192.168.178.47:137      0.0.0.0:*                           0          19916      694/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19904      694/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          19919      694/nmbd
    udp        0      0 192.168.178.47:138      0.0.0.0:*                           0          19918      694/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19905      694/nmbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15103      437/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15357      692/dhcpcd
    udp6       0      0 :::52931                :::*                                108        15106      437/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15104      437/avahi-daemon: r
    2024-08-23 15:36:15.729  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:36:22.548  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:36:29.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:36:36.396  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:36:43.393  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:36:50.112  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:36:57.033  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:03.747  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:11.014  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:18.072  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:24.543  - error: ebus.0 (8494) exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
    2024-08-23 15:37:25.231  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:32.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:39.536  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:46.531  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:37:53.634  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:00.732  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:07.896  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:15.017  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:22.246  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:30.347  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:36.389  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:43.653  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:51.001  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    2024-08-23 15:38:58.341  - info: smartmeter.0 (1093) Received 6 values, 3 updated
    HomoranH Offline
    HomoranH Offline
    @krissie777 sagte in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
    tcp
    da steht aber wieder was anderes!
    zeig die Konfiguration!
    • Marc BergM Marc Berg
      Du machst mich fertig. In die ebusd muss 8889 rein als httpport, nicht 8089.
      EDIT: es sind doch nur zwei Zahlen, ZWEI! 😥
      Krissie777
      @marc-berg
      Hallo Marc, im Adapter ist es so eingestellt, wie ich gesagt hatte:
      Wo die 8080 herkommt weiß ich nicht...
      LG
      Kris
      • K Krissie777
        @marc-berg
        LG
        Kris
        HomoranH Offline
        HomoranH Offline
        nicht 8080, sondern 8089.
        die kommt vom ebusd nehme ich an
          Krissie777
          @marc-berg
          das ist doch in der Zeile bei influx, oder?
          LG
          Kris
            Krissie777
            Hallo Hormoran, entschuldige ich meinte 8089, hatte mich verschieben.
            In dem Screenshot seht Ihr dass ich die Adressen richtig eingestellt habe, oder?
            LG
            Kris
            • K Krissie777
              @marc-berg
              LG
              Kris
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Nein, ganz andere Baustelle.
              Hier hattest du es gaaanz oben schon richtig:
              EBUSD_OPTS="--device=192.178.168.70:5002 --httpport=8889 --scanconfig --latency=30000 --configpath=http://ebusd.eu/config/"
              Hinter "httpport=", 8889. acht-acht-acht-neun
              • K Krissie777
                LG
                Kris
                HomoranH Offline
                HomoranH Offline
                im Adapter, und was steht im ebusd?
                  Krissie777
                  @marc-berg
                  Hallo MArc, bin in die Konfig rein, die stimmt doch?
                  EBUSD_OPTS="--device=127.0.0.1:8889 --httpport=8888 --scanconfig=full --latency=30000 --configpath=/etc/ebusd"
                  Ich habe hier nichts mehr verändert.
                  LG
                  Kris
                  Entschuldigt bitte, ich hatte eine stärkere Grippe...
                  HomoranH Marc BergM 2 Antworten Letzte Antwort
                  • K Krissie777
                    @marc-berg
                    LG
                    Kris
                    HomoranH Offline
                    HomoranH Offline
                    httpport=8888
                    • K Krissie777
                      @marc-berg
                      LG
                      Kris
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      --httpport=8888
                      sorry, ich geb' auf. Mach weiter, wenn Die Grippe vorbei ist.
                        httpport=8888
                        Krissie777
                        danke mist, kann leider nicht 100% klar denken...
                        LG ändere es sofort
                        • K Krissie777
                          LG ändere es sofort
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          Dann ist es leider etwas unfair, die Denkarbeit auf andere zu verlagern.
                          K 2 Antworten Letzte Antwort
                            Krissie777
                            @marc-berg
                            Hallo Marc, das kann ich verstehen und melde mich, wenn es mir wieder besser geht. Ist das io für Dich?
                            Das letzte was ich noch probiere ist:
                            EBUSD_OPTS="--device=127.0.0.1:8889 --httpport=8889 --scanconfig=full --latency=30000 --configpath=/etc/ebusd"
                            LG und bis bald
                            Vielen Dank bisherr fü alles
                            • K Krissie777
                              @marc-berg
                              LG und bis bald
                              HomoranH Offline
                              HomoranH Offline
                              jetzt hast du beides auf 8889 gestellt.
                              nennt dich Corona!
                              gute Besserung.
                              Das wird auch noch Wochen anhalten
                                Krissie777
                                @marc-berg
                                Hallo Marc, nochmal vielen Dank für Deine Hilfe und Unterstützung vergangenes Jahr.
                                Ich habe jetzt da ich endlich die Zeit hatte, ein komplett neues Debian System aufgesetzt und es funktioniert alles wunderbar bis auf den Ebus.
                                Da dieser Chat schon sehr alt ist habe ich einen neuen angelegt:
                                https://forum.iobroker.net/post/1291620
                                Darf ich Dich bitten, hier noch zusätzlich zu untersützen?
                                Danke Dir und LG
                                Kris
                                  nennt dich Corona!
                                  gute Besserung.
                                  Krissie777
                                  Hallo homoran, nochmal vielen Dank für Deine Hilfe und Unterstützung vergangenes Jahr.
                                  Danke Dir und LG
                                  Kris
