  4. Backitup Error
    1.0k
    6.1k
Backitup Error
65 Beiträge 10 Kommentatoren 10.7k Aufrufe 8 Beobachtet
  • Michael SchmittM Michael Schmitt
    @simatec mir sind keine Fehler aufgefallen. Das stand im Log als ich nochmal installiert habe.
    Was mich wundert das in dem oben angegebenen Ordner nichts ist.
    backitup.0
    2024-08-09 19:08:13.453	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
    admin.0
    2024-08-09 19:07:36.959	warn	backitup has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"tabsStyle"},"message":"must NOT have additional properties"}]
    admin.0
    2024-08-09 19:07:22.452	warn	backitup has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"tabsStyle"},"message":"must NOT have additional properties"}]
    javascript.0
    2024-08-09 19:06:28.365	info	script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: backitup.0 is connectedtrueAdapter ist wieder erreichbar
    backitup.0
    2024-08-09 19:05:43.398	info	[iobroker] backup will be activated at 03:35 every 1 day(s)
    backitup.0
    2024-08-09 19:05:43.317	info	starting. Version 3.0.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.16.0, js-controller: 6.0.9
    host.raspberrypi
    2024-08-09 19:05:40.827	info	iobroker exit 0
    host.raspberrypi
    2024-08-09 19:05:40.034	info	instance system.adapter.backitup.0 in version "3.0.16" started with pid 28329
    host.raspberrypi
    2024-08-09 19:05:39.346	info	"system.adapter.backitup.0" enabled
    host.raspberrypi
    2024-08-09 19:05:39.240	info	iobroker host.raspberrypi Adapter "system.adapter.backitup.0" is started
    host.raspberrypi
    2024-08-09 19:05:39.229	info	iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:39.217	info	iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:39.198	info	iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:39.186	info	iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:39.176	info	iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    host.raspberrypi
    2024-08-09 19:05:39.166	info	iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    host.raspberrypi
    2024-08-09 19:05:39.148	info	iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    host.raspberrypi
    2024-08-09 19:05:39.113	info	iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
    javascript.0
    2024-08-09 19:05:25.270	info	script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: backitup.0 is connectedfalseAdapter NICHT erreichbar
    host.raspberrypi
    2024-08-09 19:05:24.301	info	iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.map static/js/main.ce422ec2.js.map application/json
    host.raspberrypi
    2024-08-09 19:05:24.286	info	iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.LICENSE.txt static/js/main.ce422ec2.js.LICENSE.txt text/plain
    host.raspberrypi
    2024-08-09 19:05:22.719	info	iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js static/js/main.ce422ec2.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:22.711	info	iobroker upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css.map static/css/main.bd1167d4.css.map application/json
    host.raspberrypi
    2024-08-09 19:05:22.698	info	iobroker upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
    host.raspberrypi
    2024-08-09 19:05:22.689	info	iobroker upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.680	info	iobroker upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.672	info	iobroker upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.661	info	iobroker upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.650	info	iobroker upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.640	info	iobroker upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.632	info	iobroker upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.624	info	iobroker upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
    host.raspberrypi
    2024-08-09 19:05:22.549	info	iobroker upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    host.raspberrypi
    2024-08-09 19:05:22.467	info	iobroker upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/grafana.jsonConfig.json5 grafana.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:22.357	info	iobroker upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:21.884	info	iobroker upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.e5d86866.chunk.js custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.e5d86866.chunk.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:20.824	info	iobroker upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/node_modules_prop-types_index_js.7e14cd38.chunk.js custom/static/js/node_modules_prop-types_index_js.7e14cd38.chunk.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:20.755	info	iobroker upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
    host.raspberrypi
    2024-08-09 19:05:20.688	info	iobroker upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/cifs.jsonConfig.json5 cifs.jsonConfig.json5 application/json5
    host.raspberrypi
    2024-08-09 19:05:20.649	info	iobroker upload [95] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    host.raspberrypi
    2024-08-09 19:05:14.131	info	iobroker 123 packages are looking for funding run `npm fund` for details
    host.raspberrypi
    2024-08-09 19:05:14.123	info	iobroker
    host.raspberrypi
    2024-08-09 19:05:14.121	info	iobroker added 95 packages in 18s
    host.raspberrypi
    2024-08-09 19:05:12.561	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v8+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.16.0gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
    host.raspberrypi
    2024-08-09 19:05:12.557	info	iobroker gyp ERR! build error
    host.raspberrypi
    2024-08-09 19:05:12.549	info	iobroker make: Verzeichnis „/opt/iobroker/node_modules/opengpio/build“ wird verlassen
    host.raspberrypi
    2024-08-09 19:05:12.548	info	iobroker make: *** [opengpio.target.mk:106: Release/obj.target/opengpio/cpp/opengpio.o] Fehler 1
    host.raspberrypi
    2024-08-09 19:05:12.542	info	iobroker | ^~~~~~~~~~~compilation terminated.
    host.raspberrypi
    2024-08-09 19:05:12.541	info	iobroker ../cpp/opengpio.cpp:3:10: fatal error: gpiod.hpp: Datei oder Verzeichnis nicht gefunden 3 | #include <gpiod.hpp>
    host.raspberrypi
    2024-08-09 19:05:12.251	info	iobroker CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
    host.raspberrypi
    2024-08-09 19:05:12.247	info	iobroker make: Verzeichnis „/opt/iobroker/node_modules/opengpio/build“ wird betreten
    host.raspberrypi
    2024-08-09 19:05:12.242	info	iobroker gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    host.raspberrypi
    2024-08-09 19:05:12.241	info	iobroker gyp info spawn make
    host.raspberrypi
    2024-08-09 19:05:11.521	info	iobroker gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.16.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.16.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.16.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
    host.raspberrypi
    2024-08-09 19:05:11.514	info	iobroker gyp info spawn /usr/bin/python3
    host.raspberrypi
    2024-08-09 19:05:11.472	info	iobroker
    host.raspberrypi
    2024-08-09 19:05:11.054	info	iobroker gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    host.raspberrypi
    2024-08-09 19:05:10.817	info	iobroker gyp info using node@20.16.0 | linux | arm
    host.raspberrypi
    2024-08-09 19:05:10.816	info	iobroker gyp info using node-gyp@10.1.0
    host.raspberrypi
    2024-08-09 19:05:10.813	info	iobroker gyp info it worked if it ends with ok
    host.raspberrypi
    2024-08-09 19:05:10.477	info	iobroker > opengpio@1.1.0 install> node-gyp rebuild
    host.raspberrypi
    2024-08-09 19:05:10.475	info	iobroker
    host.raspberrypi
    2024-08-09 19:04:55.261	info	iobroker Installing iobroker.backitup@3.0.16... (System call)
    host.raspberrypi
    2024-08-09 19:04:55.260	info	iobroker NPM version: 10.8.1
    host.raspberrypi
    2024-08-09 19:04:55.236	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    backitup.0
    2024-08-09 19:04:55.122	info	terminating
    host.raspberrypi
    2024-08-09 19:04:54.647	info	stopInstance system.adapter.backitup.0 send kill signal
    backitup.0
    2024-08-09 19:04:54.620	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0
    2024-08-09 19:04:54.616	info	terminating
    backitup.0
    2024-08-09 19:04:54.613	info	cleaned everything up...
    backitup.0
    2024-08-09 19:04:54.611	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    2024-08-09 19:04:54.596	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
    host.raspberrypi
    2024-08-09 19:04:54.596	info	"system.adapter.backitup.0" disabled
    host.raspberrypi
    2024-08-09 19:04:54.516	info	iobroker host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
    host.raspberrypi
    2024-08-09 19:04:54.458	info	iobroker removed 95 packages in 9s107 packages are looking for funding run `npm fund` for details
    host.raspberrypi
    2024-08-09 19:04:45.027	info	iobroker Uninstall npm packet "iobroker.backitup" for a clean re-installation
    host.raspberrypi
    2024-08-09 19:04:45.025	info	iobroker Update backitup from @3.0.16 to @3.0.16
    host.raspberrypi
    2024-08-09 19:04:41.807	info	iobroker upgrade backitup@3.0.16 --debug
    mcm1957M Online
    mcm1957M Online
    mcm1957
    @michael-schmitt said in Backitup Error:
    npm optimiert die installierten Dependencies. Da adapter-core von ein "paar" Adaptern benutzt wird, wird es durch die Optimierung nicht im lokalen node_modules installiert sondern eine Ebene höher und von allen Adaptern benutzt die diese Version "vertragen". Sollte unter /opt/iobroker/node_modules/@iobroker zu finden sein. Lokal werden jene dependencies installiert, die von der "großen Menge" abweichen.
    Ist jetzt nur sehr grob beschrieben. Bi Details verweise ich auf npm Doku.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    Michael SchmittM 1 Antwort Letzte Antwort
    • mcm1957M mcm1957
      Michael SchmittM Online
      Michael Schmitt
      Bis jetzt waren keine Fehler mehr im Log. In dem Pfad von dir ist auch die gesuchte Datei.
      Das Backup wurde heute auch gemacht.
      Ich melde mich wenn wieder was vor kommt. Danke für die Informationen ;)
        ich habe gestern meinen Backitup Adapter + js controller geupdatet. Nun bekomme ich einen Error beim Backup und es wird kein Backup erstellt.
        backitup.0
        2024-08-09 18:31:27.463	error	Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
        admin.0
        2024-08-09 18:31:24.900	warn	backitup has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"tabsStyle"},"message":"must NOT have additional properties"}]
        Was kann man da machen ?
        • Adaptername: Backitup
        • Adapterversion: 3.0.16
        • js-controller Version: 6.0.9
        • Admin Version: 7.0.22
        • Hardwaresystem: Pi4
        • Arbeitsspeicher: 4GB
        • Festplattenart: SSD
        • Betriebssystem: Linux
        • Nodejs-Version: v20.16.0
        • NPM-Version: 10.8.1
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         18:42:18 up 1 day,  3:40,  2 users,  load average: 0.77, 0.73, 0.57
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2024-08-09 18:42:19 CEST
                   Universal time: Fri 2024-08-09 16:42:19 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            4.0G        1.1G        2.0G        1.1M        953M        2.8G
        Swap:           209M          0B        209M
        Total:          4.2G        1.1G        2.2G
        Active iob-Instances:   19
                 3793 M total memory
                 1096 M used memory
                 1130 M active memory
                  578 M inactive memory
                 1864 M free memory
                  180 M buffer memory
                  728 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 18:42:19 up 1 day,  3:40,  2 users,  load average: 0.77, 0.73, 0.57
        Tasks: 152 total,   2 running, 150 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 12.5 us, 12.5 sy,  0.0 ni, 62.5 id, 12.5 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3793.3 total,   1862.7 free,   1097.7 used,    909.5 buff/cache
        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2695.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      220G  9.3G  202G   5% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.1M  758M   1% /run
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Thu Aug  8 15:02:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:05:E3:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=fae45d57-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Thu Aug  8 15:02:21 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Aug  8 15:02:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Thu Aug  8 15:02:25 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE      FSTYPE      OPTIONS
        /                                                       /dev/sda2   ext4        rw,noatime
        |-/dev                                                  devtmpfs    devtmpfs    rw,relatime,size=1677960k,nr_inodes=419490,mode=755
        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc        proc        rw,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
        |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
        | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
        `-/boot                                                 /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        2.0G    /var/
        1.5G    /var/log/journal/17d80a2ed91e4fbcb19dfd9141eb79e6
        1.5G    /var/log
        240M    /var/cache
        Archived and active journals take up 1.4G in the file system.
        /opt/iobroker/backups:
        496M    /opt/iobroker/backups/
        908K    /opt/iobroker/backups/scripte
        904K    /opt/iobroker/backups/scripte/common
        124K    /opt/iobroker/backups/scripte/common/Licht_Wecker
        100K    /opt/iobroker/backups/scripte/common/Wichtig
        /opt/iobroker/iobroker-data:
        825M    /opt/iobroker/iobroker-data/
        687M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        20M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2419780-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        nodejs:
          Installed: 20.16.0-1nodesource1
          Candidate: 20.16.0-1nodesource1
          Version table:
         *** 20.16.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2+rpi1 500
                500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.info.0                   : info                  : raspberrypi                              - disabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          system.adapter.material.0               : material              : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Instances
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.16   , installed 3.0.16
        Adapter    "deconz"       : 1.4.1    , installed 1.4.1
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "material"     : 1.3.1    , installed 0.13.9 [Updatable]
        Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
        Adapter    "telegram"     : 3.3.2    , installed 3.3.2
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects:        5762
        States:         4500
        Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
        Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
        Hit:3 https://phoscon.de/apt/deconz bookworm InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        14889      552/redis-server 12
        tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       43947      8421/io.socketio.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       43135      7770/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41552      7770/iobroker.js-co
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12968      398/deCONZ
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13752      398/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14897      573/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       44813      8499/io.simple-api.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2406245    11579/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46203      8353/io.web.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       2405998    11391/io.admin.1
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        14890      552/redis-server 12
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14899      573/sshd: /usr/sbin
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       44355      8096/io.deconz.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       12975      398/deCONZ
        udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       44511      8168/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11965      393/avahi-daemon: r
        udp        0      0 0.0.0.0:58736           0.0.0.0:*                           108        11967      393/avahi-daemon: r
        udp6       0      0 :::1900                 :::*                                1001       44357      8096/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       44356      8096/io.deconz.0
        udp6       0      0 fe80::f396:6d7a:b9a:546 :::*                                0          14946      510/NetworkManager
        udp6       0      0 :::5353                 :::*                                108        11966      393/avahi-daemon: r
        udp6       0      0 :::42526                :::*                                108        11968      393/avahi-daemon: r
        2024-08-09 18:25:42.912  - info: admin.0 (11579) requesting all objects
        2024-08-09 18:25:44.447  - info: admin.0 (11579) received all objects
        2024-08-09 18:25:46.385  - info: admin.0 (11579) Secure socket.io server listening on port 8081
        2024-08-09 18:25:46.392  - info: admin.0 (11579) https server listening on port 8081
        2024-08-09 18:25:46.393  - info: admin.0 (11579) Use link "https://127.0.0.1:8081" to configure.
        2024-08-09 18:25:53.767  - info: admin.0 (11579) ==> Connected system.user.admin from ::ffff:192.168.178.40
        2024-08-09 18:26:05.616  - info: javascript.0 (7919) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: admin.0 is connected
        false
        2024-08-09 18:26:27.894  - info: javascript.0 (7919) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: admin.0 is connected
        true
        2024-08-09 18:30:00.051  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.15.0" started with pid 13265
        2024-08-09 18:30:03.244  - info: ical.0 (13265) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.16.0, js-controller: 6.0.9
        2024-08-09 18:30:04.130  - info: ical.0 (13265) processing URL: Müllkalender https://calendar.google.com/calendar/ical/8n95sqg3r88betcpncgkhe3m8c%40group.calendar.google.com/private-32cc3a968fd521a665efcc600d6ce4d4/basic.ics
        2024-08-09 18:30:09.479  - info: ical.0 (13265) Terminated (NO_ERROR): Without reason
        2024-08-09 18:30:10.018  - info: host.raspberrypi instance system.adapter.ical.0 having pid 13265 terminated with code 0 (NO_ERROR)
        2024-08-09 18:31:10.004  - info: admin.0 (11579) ==> Connected system.user.admin from ::ffff:192.168.178.40
        2024-08-09 18:31:24.900  - warn: admin.0 (11579) backitup has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"tabsStyle"},"message":"must NOT have additional properties"}]
        2024-08-09 18:31:27.463  - error: backitup.0 (8129) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
        2024-08-09 18:32:39.520  - error: backitup.0 (8129) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
        2024-08-09 18:32:45.120  - error: backitup.0 (8129) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
        2024-08-09 18:38:50.020  - info: admin.0 (11579) ==> Connected system.user.admin from ::ffff:192.168.178.40
        2024-08-09 18:38:59.069  - info: host.raspberrypi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
        2024-08-09 18:39:06.936  - info: admin.0 (11579) <== Disconnect system.user.admin from ::ffff:192.168.178.40
        Ro75R Offline
        Ro75R Offline
        Ro75
        @michael-schmitt sagte in Backitup Error:
        Ich habe am 14.08. nodejs von V18 auf V20 aktualisiert. Backitup hat auch wie sonst immer vorher um 2 Uhr am 15.08. ein Backup erstellt. Am 16.08. nicht mehr - ist ausgestiegen mit angegebener Medlung.
        Selbst ein manuelles Backup war nicht möglich. Außer dem Hinweis das der Vorgang gestartet wurde, passierte nichts. Server und ioBroker neu gestartet - keine Änderung.
        Bin jetzt wieder auf nodejs V18 zurück - und Backitup arbeitet wieder.
        Achso, vor Umstellung von nodejs war ich bereits seit mehreren Tagen unterwegs mit
        Admin: 7.0.22
        Beackitup: 3.0.16
        Ro75.
        • Ro75R Ro75
          Admin: 7.0.22
          Beackitup: 3.0.16
          Ro75.
          @ro75
          Das ist merkwürdig. Den Pfad gibt es auf meinem System auch gar nicht:
          echad@chet:~ $ ls -la /opt/iobroker/node_modules/iobroker.backitup/node_modules/
          total 12
          drwxrwxr-x+ 3 iobroker iobroker 4096 Aug 16 09:00 .
          drwxrwxr-x+ 6 iobroker iobroker 4096 Aug 16 09:00 ..
          drwxrwxr-x+ 4 iobroker iobroker 4096 Aug 16 09:00 axios
          echad@chet:~ $
          Hast du backitup mal sauber reinstalliert?
          Ro75R 1 Antwort Letzte Antwort
            @ro75
            total 12
            echad@chet:~ $
            Ro75R Offline
            Ro75R Offline
            Ro75
            @thomas-braun sagte in Backitup Error:
            Nein, dazu sah ich mich nicht veranlasst. Die Version 3.0.16 lief ja ca. 1 Woche unter nodejs18 sauber. Das Problem trat mit der Umstellung auf nodejs 20 auf.
            Ro75.
            • Ro75R Ro75
              Ro75.
              @ro75 sagte in Backitup Error:
              Wohl eher mit der Version von 'npm', die damit einhergeht.
              Ist das denn alles sauber installiert?
                Ro75R Offline
                Ro75R Offline
                Ro75
                schrieb am zuletzt editiert von Ro75
                @thomas-braun bin mir sicher, dass alles ok ist. Hatte mit iob nodejs-update 20 in /opt/iobroker aktualisiert. Da gabs auch eine Meldung, dass die Installation korrekt war/ist - oder so ähnlich.
                Gleiches Verfahren um wieder zurück auf 18 mit gleicher Meldung.
                Ro75.
                • Ro75R Ro75
                  Ro75.
                  @ro75
                  cd /opt/iobroker
                  npm ls
                  npm prune
                    @ro75
                    cd /opt/iobroker
                    npm ls
                    npm prune
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    ubuntu@ubuntu-server:/opt/iobroker$ npm ls
                    [sudo] Passwort für ubuntu:
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                    ├── @iobroker-javascript.0/net-snmp@npm:net-snmp@3.12.0
                    ├── @iobroker-javascript.0/string-pixel-width@npm:string-pixel-width@1.11.0
                    ├── @iobroker-javascript.0/wake_on_lan@npm:wake_on_lan@1.0.0
                    ├── @iobroker-javascript.0/xml2js@npm:xml2js@0.6.2
                    ├── iobroker.admin@7.0.22
                    ├── iobroker.alexa2@3.26.5
                    ├── iobroker.backitup@3.0.16
                    ├── iobroker.daswetter@3.1.15
                    ├── iobroker.dwd@2.8.5
                    ├── iobroker.fritzdect@2.5.9
                    ├── iobroker.homeconnect@1.4.1
                    ├── iobroker.hs100@2.2.0
                    ├── iobroker.hue@3.11.0
                    ├── iobroker.ical@1.15.0
                    ├── iobroker.imap@0.2.0
                    ├── iobroker.influxdb@4.0.2
                    ├── iobroker.javascript@8.7.6
                    ├── iobroker.js-controller@6.0.9
                    ├── iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                    ├── iobroker.netatmo@3.1.0
                    ├── iobroker.notification-manager@1.1.2
                    ├── iobroker.owntracks@1.0.5
                    ├── iobroker.parcel@0.2.7
                    ├── iobroker.ping@1.6.2
                    ├── iobroker.simple-api@2.8.0
                    ├── iobroker.socketio@6.7.0
                    ├── iobroker.sql@2.2.0
                    ├── iobroker.tankerkoenig@2.1.1
                    ├── iobroker.tapo@0.3.3
                    ├── iobroker.time-switch@2.2.2
                    ├── iobroker.tr-064@4.3.0
                    ├── iobroker.upnp@1.0.21
                    ├── iobroker.vis-canvas-gauges@1.0.1
                    ├── iobroker.vis-colorpicker@1.2.0
                    ├── iobroker.vis-google-fonts@1.0.4
                    ├── iobroker.vis-map@1.0.5
                    ├── iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                    ├── iobroker.vis@1.5.6
                    ├── iobroker.web@6.2.5
                    ├── iobroker.ws@2.6.1
                    └── iobroker.zigbee@1.9.5 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#e3a6625eb2cd20069045ef4a470fdc9d2c7f4544)
                    ubuntu@ubuntu-server:/opt/iobroker$ npm prune
                    up to date in 3s
                    144 packages are looking for funding
                    Für mich unauffällig. Wohlgemerkt nodejs 18.
                    Ro75.
                    • Ro75R Ro75
                      up to date in 3s
                      Ro75.
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @ro75
                      • also aktuell (auf LATEST) ist bereits backitup 3.0.19. Was genau da gefixed wurde bitte selbst nachlesen oder nachfragen @simatec)
                      • dass es node_modules @iobroker/adapter_core nicht gibt ist nicht ungewöhnlich. adapter-core ist von "einigen" Adaptern geshared. Und wenn npm merkt dass eine passende (ggF auch zulässiger Weise neuere) Version existiert, dann wird diese verwendet. adapter_core befindet sich dann einen ebene höher im node_modules
                      • durch den node update könnte es sehr wohl zu einem Update der Module gekommen sein - wobei ich zunächst mal sage das ist merh Vermutung denn Wissen. Hier könnte eine Reinstallation von Backitup (oder gleich ein Update) das ggF gerade biegen.
                      • mcm1957M mcm1957
                        @ro75
                        @mcm1957
                        Kann man hier sehen:
                        echad@chet:/opt/iobroker $ npm ls @iobroker/adapter-core
                        ├─┬ iobroker.admin@7.0.24
                        │ ├── @iobroker/adapter-core@3.1.6 overridden
                        │ └─┬ @iobroker/socket-classes@1.5.6
                        │   └── @iobroker/adapter-core@3.1.6 deduped
                        ├─┬ iobroker.alexa2@3.26.5
                        ├─┬ iobroker.alias-manager@1.2.6
                        ├─┬ iobroker.awtrix-light@1.3.0
                        ├─┬ iobroker.backitup@3.0.19
                        • Ro75R Offline
                          Ro75R Offline
                          Ro75
                          So, noch einmal auf nodejs 20 aktualisiert. Backup via Backitup manuell gestartet (über GUI).
                          22:00:50.195INFOguiBackup gestartet ...
                          22:00:52.010DEBUGiobrokerhost.ubuntu-server 15432 states saved
                          22:00:53.818DEBUGiobrokerhost.ubuntu-server 16876 objects saved
                          22:00:59.864DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_08_16-22_00_51_backupiobroker.tar.gz
                          22:00:59.868DEBUGiobrokerThis backup can only be restored with js-controller version up from 4.1
                          22:01:00.919DEBUGiobrokerdone
                          22:01:01.109DEBUGinfluxDBInfluxDB-Backup for is started ...
                          22:01:01.113DEBUGinfluxDBStart InfluxDB Backup ...
                          22:01:01.118DEBUGinfluxDBInfluxDB Backup tmp directory created
                          22:01:10.957DEBUGinfluxDBBackup created: /opt/iobroker/backups/influxDB_2024_08_16-22_01_01_backupiobroker.tar.gz
                          22:01:10.961DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_08_16-22_01_01_backupiobroker"
                          22:01:10.976DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_08_16-22_01_01_backupiobroker" successfully deleted
                          22:01:10.982DEBUGinfluxDBStart InfluxDB Backup ...
                          22:01:10.984DEBUGinfluxDBInfluxDB Backup tmp directory created
                          22:01:11.132DEBUGinfluxDBBackup created: /opt/iobroker/backups/influxDB_2024_08_16-22_01_11_backupiobroker.tar.gz
                          22:01:11.135DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_08_16-22_01_11_backupiobroker"
                          22:01:11.136DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_08_16-22_01_11_backupiobroker" successfully deleted
                          22:01:11.139DEBUGinfluxDBdone
                          22:01:11.304DEBUGmysqlMySql-Backup started ...
                          22:01:11.358DEBUGmysqlMySql File deleted!
                          22:01:11.361DEBUGmysqlMySql-Backup for is finish
                          22:01:11.363DEBUGmysqldone
                          22:01:11.815DEBUGredisStart Redis Backup ...
                          22:01:11.818DEBUGredisCreated redistmp directory
                          22:01:11.820DEBUGredisdetected redis file: dump.rdb | file type: rdb
                          22:01:21.812DEBUGredisPacked 152MB so far...
                          22:01:31.835DEBUGredisPacked 316MB so far...
                          22:01:32.561DEBUGredisBackup created: /opt/iobroker/backups/redis_2024_08_16-22_01_12_backupiobroker.tar.gz
                          22:01:32.565DEBUGredisredis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
                          22:01:32.567DEBUGredisdone
                          22:01:32.873DEBUGzigbeefound zigbee database: zigbee.0
                          22:01:32.876DEBUGzigbeedone
                          22:01:33.186DEBUGgrafanaStart Grafana Backup ...
                          22:01:33.189DEBUGgrafanaCreated grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                          22:01:33.191DEBUGgrafanaCreated dashboard directory
                          22:01:33.193DEBUGgrafanaCreated dashboards_manually_restore directory
                          22:01:33.197DEBUGgrafanaCreated datasource directory
                          22:01:33.199DEBUGgrafanastart Grafana request ...
                          22:01:33.202DEBUGgrafanaGrafana is available ... Status: 200
                          22:01:33.424DEBUGgrafanafound Dashboard: 7-tage
                          22:01:33.429DEBUGgrafanafound Dashboard: 10-monate
                          22:01:33.432DEBUGgrafanafound Dashboard: 12-monate
                          22:01:33.437DEBUGgrafanafound Dashboard: 3-tage
                          22:01:33.444DEBUGgrafanafound Dashboard: 15-minuten
                          22:01:33.448DEBUGgrafanafound Dashboard: 10-tage
                          22:01:33.457DEBUGgrafanafound Dashboard: 60-minuten
                          22:01:33.463DEBUGgrafanafound Dashboard: tanken
                          22:01:33.468DEBUGgrafanafound Dashboard: 24-stunden
                          22:01:33.493DEBUGgrafanafound Dashboard: langzeit
                          22:01:33.508DEBUGgrafanafound Dashboard: hardware
                          22:01:33.513DEBUGgrafanafound Dashboard: 12-stunden
                          22:01:33.623DEBUGgrafanastart Grafana backup compress ...
                          22:01:38.648DEBUGgrafanaBackup created: /opt/iobroker/backups/grafana_2024_08_16-22_01_34_backupiobroker.tar.gz
                          22:01:38.652DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                          22:01:38.657DEBUGgrafanaGrafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                          22:01:38.661DEBUGgrafanadone
                          22:01:39.126DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                          22:01:39.152DEBUGjavascriptsfound Script: QRAnzeige
                          22:01:39.298DEBUGjavascriptsfound Script: APIpiHole
                          22:01:39.452DEBUGjavascriptsfound Script: Biowetter
                          22:01:39.603DEBUGjavascriptsfound Script: Luftdaten
                          22:01:39.753DEBUGjavascriptsfound Script: Boinc
                          22:01:39.903DEBUGjavascriptsfound Script: WOL
                          22:01:40.054DEBUGjavascriptsfound Script: test603349
                          22:01:40.203DEBUGjavascriptsfound Script: DBPowerManagement
                          22:01:40.356DEBUGjavascriptsfound Script: Zigbee
                          22:01:40.506DEBUGjavascriptsfound Script: WANInfo
                          22:01:40.657DEBUGjavascriptsfound Script: Parcel
                          22:01:40.808DEBUGjavascriptsfound Script: Equalizer
                          22:01:40.957DEBUGjavascriptsfound Script: Kontakte
                          22:01:41.109DEBUGjavascriptsfound Script: Pollenflug
                          22:01:41.259DEBUGjavascriptsfound Script: Meldungen
                          22:01:41.409DEBUGjavascriptsfound Script: Kalender_gross
                          22:01:41.558DEBUGjavascriptsfound Script: Vorhersage
                          22:01:41.713DEBUGjavascriptsfound Script: Nachrichtensystem
                          22:01:41.863DEBUGjavascriptsfound Script: Gerätesteuerung
                          22:01:42.014DEBUGjavascriptsfound Script: HPYasu
                          22:01:42.167DEBUGjavascriptsfound Script: DetailInfoListen
                          22:01:42.319DEBUGjavascriptsfound Script: Speedtest
                          22:01:42.469DEBUGjavascriptsfound Script: Haushaltgeräte
                          22:01:42.617DEBUGjavascriptsfound Script: GeoDaten
                          22:01:42.773DEBUGjavascriptsfound Script: Belüftung
                          22:01:42.921DEBUGjavascriptsfound Script: TimerCountdown
                          22:01:43.071DEBUGjavascriptsfound Script: Bildzuordnung
                          22:01:43.224DEBUGjavascriptsfound Script: Beleuchtung
                          22:01:43.370DEBUGjavascriptsfound Script: Kalender_mini
                          22:01:43.524DEBUGjavascriptsfound Script: AkiveView
                          22:01:43.672DEBUGjavascriptsfound Script: Rechenkraft
                          22:01:43.826DEBUGjavascriptsfound Script: PCRyzen
                          22:01:43.977DEBUGjavascriptsfound Script: Listen
                          22:01:44.125DEBUGjavascriptsfound Script: Geräteüberwachung
                          22:01:44.279DEBUGjavascriptsfound Script: vis-materialdesign0
                          22:01:44.427DEBUGjavascriptsfound Script: HPConvertible
                          22:01:44.576DEBUGjavascriptsfound Script: InfoListen
                          22:01:44.727DEBUGjavascriptsfound Script: UbuntuServer
                          22:01:44.879DEBUGjavascriptsfound Script: SNMP
                          22:01:45.030DEBUGjavascriptsfound Script: Dashboard
                          22:01:45.182DEBUGjavascriptsfound Script: DeviceStatistik
                          22:01:45.333DEBUGjavascriptsfound Script: WifiBat
                          22:01:45.490DEBUGjavascriptsfound Script: DBWallpaper
                          22:01:45.636DEBUGjavascriptsfound Script: AqaraSchalter
                          22:01:45.787DEBUGjavascriptsfound Script: IstaAblesung
                          22:01:45.937DEBUGjavascriptsfound Script: MyCloudEx2Ultra
                          22:01:46.086DEBUGjavascriptsfound Script: Hauptsteuerung
                          22:01:46.240DEBUGjavascriptsfound Script: Volumensteuerung
                          22:01:46.391DEBUGjavascriptsfound Script: WhatsApp
                          22:01:46.541DEBUGjavascriptsfound Script: WindowsAnzeige
                          22:01:46.688DEBUGjavascriptsfound Script: Berechnungen
                          22:01:46.842DEBUGjavascriptsfound Script: Musik
                          22:01:46.989DEBUGjavascriptsfound Script: Zeitplanung
                          22:01:47.140DEBUGjavascriptsfound Script: enums_list
                          22:01:47.295DEBUGjavascriptsfound Script: Wetterwarnung
                          22:01:47.444DEBUGjavascriptsfound Script: RandomUserAgent
                          22:01:47.595DEBUGjavascriptsfound Script: WetterBilderTagNacht
                          22:01:47.746DEBUGjavascriptsfound Script: systemweit
                          22:01:47.895DEBUGjavascriptsfound Script: OMVNas
                          22:01:48.048DEBUGjavascriptsfound Script: Tankstellen
                          22:01:48.199DEBUGjavascriptsfound Script: PINAbfrage
                          22:01:48.349DEBUGjavascriptsfound Script: LastFM
                          22:01:48.501DEBUGjavascriptsfound Script: InfluxAliasKor
                          22:01:48.653DEBUGjavascriptsfound Script: Briefanzeige
                          22:01:48.805DEBUGjavascriptsfound Script: Anrufbeantworter
                          22:01:49.024DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                          22:01:49.031DEBUGjavascriptsdone
                          22:01:49.748DEBUGftpFTP connected.
                          22:01:49.750DEBUGftpSend iobroker_2024_08_16-22_00_51_backupiobroker.tar.gz
                          22:02:12.686DEBUGftpSend influxDB_2024_08_16-22_01_01_backupiobroker.tar.gz
                          22:02:23.816DEBUGftpSend influxDB_2024_08_16-22_01_11_backupiobroker.tar.gz
                          22:02:23.899DEBUGftpSend mysql_2024_08_16-22_01_12_backupiobroker.tar.gz
                          22:02:23.975DEBUGftpSend redis_2024_08_16-22_01_12_backupiobroker.tar.gz
                          22:03:38.098DEBUGftpSend zigbee.0_2024_08_16-22_01_33_backupiobroker.tar.gz
                          22:03:38.217DEBUGftpSend grafana_2024_08_16-22_01_34_backupiobroker.tar.gz
                          22:03:38.312DEBUGftpSend javascripts_2024_08_16-22_01_40_backupiobroker.tar.gz
                          22:03:38.438DEBUGftpdone
                          22:03:39.372DEBUGcleandone
                          22:03:39.508DEBUGhistoryHTMLnew history html values created
                          22:03:39.514DEBUGhistoryHTMLdone
                          22:03:39.666DEBUGhistoryJSONnew history json values created
                          22:03:39.668DEBUGhistoryJSONdone
                          22:03:42.178DEBUGnotificationdone
                          22:03:42.330INFOguiDas Backup wurde erfolgreich erstellt!
                          Alles OK und ohne Fehler. Backitup noch immer die Version 3.0.16.
                          up to date in 3s
                          ubuntu@ubuntu-server:/opt/iobroker$ npm ls @iobroker/adapter-core
                          ├─┬ iobroker.admin@7.0.22
                          ├─┬ iobroker.backitup@3.0.16
                          ├─┬ iobroker.daswetter@3.1.15
                          ├─┬ iobroker.dwd@2.8.5
                          ├─┬ iobroker.fritzdect@2.5.9
                          ├─┬ iobroker.homeconnect@1.4.1
                          ├─┬ iobroker.hs100@2.2.0
                          ├─┬ iobroker.hue@3.11.0
                          ├─┬ iobroker.ical@1.15.0
                          ├─┬ iobroker.imap@0.2.0
                          ├─┬ iobroker.influxdb@4.0.2
                          ├─┬ iobroker.javascript@8.7.6
                          ├─┬ iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                          ├─┬ iobroker.netatmo@3.1.0
                          ├─┬ iobroker.notification-manager@1.1.2
                          ├─┬ iobroker.owntracks@1.0.5
                          ├─┬ iobroker.parcel@0.2.7
                          ├─┬ iobroker.ping@1.6.2
                          ├─┬ iobroker.simple-api@2.8.0
                          ├─┬ iobroker.socketio@6.7.0
                          │ ├── @iobroker/adapter-core@3.1.6 deduped
                          │ └─┬ @iobroker/socket-classes@1.5.0
                          ├─┬ iobroker.sql@2.2.0
                          ├─┬ iobroker.tankerkoenig@2.1.1
                          ├─┬ iobroker.tapo@0.3.3
                          ├─┬ iobroker.time-switch@2.2.2
                          ├─┬ iobroker.tr-064@4.3.0
                          ├─┬ iobroker.upnp@1.0.21
                          ├─┬ iobroker.vis-canvas-gauges@1.0.1
                          ├─┬ iobroker.vis-colorpicker@1.2.0
                          ├─┬ iobroker.vis-google-fonts@1.0.4
                          ├─┬ iobroker.vis@1.5.6
                          ├─┬ iobroker.web@6.2.5
                          │ ├─┬ iobroker.socketio@6.6.1
                          │ │ └── @iobroker/adapter-core@3.1.6 deduped
                          │ └─┬ iobroker.ws@2.5.11
                          ├─┬ iobroker.ws@2.6.1
                          └─┬ iobroker.zigbee@1.9.5 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#e3a6625eb2cd20069045ef4a470fdc9d2c7f4544)
                            └─┬ @iobroker/dm-utils@0.1.9
                          Sieht für mich nicht schlecht aus...
                          Ro75.
                          I 1 Antwort Letzte Antwort
                          • Ro75R Ro75
                            up to date in 3s
                            Ro75.
                            I Offline
                            I Offline
                            io2345
                            Und es gibt nur die Möglichkeit, den Backup-Adapter neu zu installieren?
                            Hätte sowas nicht spätestens im Beta-Test der neuen nodejs-Version auffallen müssen? Diesen Adapter hat doch sicherlich jeder bei sich installiert...
                            • I io2345
                              @io2345
                              Und was ist jetzt konkret dein Thema?
                                @io2345
                                I Offline
                                I Offline
                                io2345
                                schrieb am zuletzt editiert von io2345
                                @thomas-braun Gleiches Problem wie der Threadersteller: nodejs upgedatet, Backup läuft nicht mehr mit o.g. Fehlermeldung.
                                • I io2345
                                  @io2345
                                  iob diag
                                  sagt? Die Langfassung.
                                  I 2 Antworten Letzte Antwort
                                    @io2345
                                    iob diag
                                    I Offline
                                    I Offline
                                    io2345
                                    @thomas-braun Ah, hab's schon kapiert. Man muss das machen, um es zu fixen: Beitrag von dir von weiter oben
                                    Danke für den Denkanstoss...
                                      @io2345
                                      iob diag
                                      I Offline
                                      I Offline
                                      io2345
                                      Hab's jetzt interessehalber doch mal laufen lassen:
                                      ```bash
                                      Script v.2024-10-19
                                      *** BASE SYSTEM ***
                                      Failed to query system properties: Connection timed out
                                      OS is similar to:
                                      model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
                                      Docker          : false
                                      Virtualization  : lxc
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       16:36:28 up 16 days, 22:35,  0 user,  load average: 0.61, 0.31, 0.16
                                      CPU threads: 1
                                      *** LIFE CYCLE STATUS ***
                                      Operating System is the current Debian stable version codenamed 'bookworm'!
                                      *** TIME AND TIMEZONES ***
                                      Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                                      Failed to parse bus message: Connection timed out
                                      iobrokeradmin
                                      HOME=/home/iobrokeradmin
                                      GROUPS=iobrokeradmin sudo users iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      *** DISPLAY-SERVER SETUP ***
                                      Desktop:
                                      Terminal:
                                      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                      *** MEMORY ***
                                      Mem:            2.1G        905M        411M         61K        830M        1.2G
                                      Swap:           536M         49K        536M
                                      Total:          2.7G        905M        948M
                                      Active iob-Instances:   6
                                               2048 M total memory
                                                863 M used memory
                                                881 M active memory
                                                652 M inactive memory
                                                392 M free memory
                                                  0 M buffer memory
                                                792 M swap cache
                                                512 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      top - 16:37:43 up 16 days, 22:36,  0 user,  load average: 0.58, 0.36, 0.19
                                      Tasks:  36 total,   1 running,  35 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   2048.0 total,    390.3 free,    865.0 used,    792.7 buff/cache
                                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1183.0 avail Mem
                                        UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
                                      * influxdb.service                   loaded failed failed InfluxDB is an open-source, distributed, time series database
                                      * logrotate.service                  loaded failed failed Rotate log files
                                      * man-db.service                     loaded failed failed Daily man-db regeneration
                                      * nftables.service                   loaded failed failed nftables
                                      * systemd-hostnamed.service          loaded failed failed Hostname Service
                                      * systemd-logind.service             loaded failed failed User Login Management
                                      * systemd-networkd.service           loaded failed failed Network Configuration
                                      * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
                                      * systemd-sysusers.service           loaded failed failed Create System Users
                                      * systemd-timedated.service          loaded failed failed Time & Date Service
                                      * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
                                      * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
                                      * systemd-tmpfiles-setup.service     loaded failed failed Create Volatile Files and Directories
                                      * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
                                      14 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      Filesystem                       Type   Size  Used Avail Use% Mounted on
                                      /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.6G  2.8G  63% /
                                      none                             tmpfs  492K  4.0K  488K   1% /dev
                                      tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
                                      tmpfs                            tmpfs  2.4G   80K  2.4G   1% /run
                                      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                                      [Thu Oct 24 18:58:08 2024] EXT4-fs (dm-1): mounted filesystem b474fcca-8614-4935-abf2-ede52e720980 ro with ordered data mode. Quota mode: none.
                                      [Thu Oct 24 18:58:13 2024] EXT4-fs (dm-1): re-mounted b474fcca-8614-4935-abf2-ede52e720980 r/w. Quota mode: none.
                                      [Thu Oct 24 18:58:38 2024] EXT4-fs warning (device dm-9): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                                      [Thu Oct 24 18:59:23 2024] EXT4-fs (dm-9): 2 orphan inodes deleted
                                      [Thu Oct 24 18:59:23 2024] EXT4-fs (dm-9): recovery complete
                                      [Thu Oct 24 18:59:23 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
                                      [Thu Oct 24 18:59:34 2024] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                                      [Thu Oct 24 18:59:34 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
                                      [Thu Oct 24 19:00:20 2024] EXT4-fs (dm-6): 67 orphan inodes deleted
                                      [Thu Oct 24 19:00:20 2024] EXT4-fs (dm-6): recovery complete
                                      [Thu Oct 24 19:00:20 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
                                      [Thu Oct 24 19:00:23 2024] EXT4-fs warning (device dm-7): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                                      [Thu Oct 24 19:01:07 2024] EXT4-fs (dm-7): 5 orphan inodes deleted
                                      [Thu Oct 24 19:01:07 2024] EXT4-fs (dm-7): recovery complete
                                      [Thu Oct 24 19:01:07 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
                                      [Thu Oct 24 19:11:16 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
                                      [Thu Oct 24 19:11:52 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
                                      [Thu Oct 24 19:11:53 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
                                      [Mon Nov  4 03:00:02 2024] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                                      [Mon Nov  4 03:00:02 2024] EXT4-fs (dm-10): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d ro without journal. Quota mode: none.
                                      [Mon Nov  4 03:01:18 2024] EXT4-fs (dm-10): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
                                      [Mon Nov  4 03:01:19 2024] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                                      [Mon Nov  4 03:01:19 2024] EXT4-fs (dm-10): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 ro without journal. Quota mode: none.
                                      [Mon Nov  4 03:03:42 2024] EXT4-fs (dm-10): unmounting filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336.
                                      [Mon Nov  4 03:03:43 2024] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                                      [Mon Nov  4 03:03:43 2024] EXT4-fs (dm-10): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c ro without journal. Quota mode: none.
                                      [Mon Nov  4 03:09:55 2024] EXT4-fs (dm-10): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
                                      /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
                                      /var:
                                      625M    /var/
                                      330M    /var/cache
                                      326M    /var/cache/apt
                                      250M    /var/cache/apt/archives
                                      149M    /var/log
                                            Users in the 'systemd-journal' group can see all messages. Pass -q to
                                            turn off this notice.
                                      Archived and active journals take up 21.8M in the file system.
                                      5.5M    /opt/iobroker/backups/
                                      4.0K    /opt/iobroker/backups/influxDB_2024_04_15-11_04_32_Proxmox102_backupiobroker
                                      803M    /opt/iobroker/iobroker-data/
                                      741M    /opt/iobroker/iobroker-data/files
                                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      12M     /opt/iobroker/iobroker-data/objects.jsonl
                                      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      /usr/bin/nodejs         v20.15.1
                                      /usr/bin/node           v20.15.1
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.1
                                      nodejs:
                                        Installed: 20.15.1-1nodesource1
                                        Candidate: 20.18.0-1nodesource1
                                        Version table:
                                           20.18.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                           20.17.0-1nodesource1 1001
                                       *** 20.15.1-1nodesource1 1001
                                           18.19.0+dfsg-6~deb12u2 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 http://security.debian.org bookworm-security/main amd64 Packages
                                      Errors in npm tree: 0
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      ioBroker8           ioBroker8 (version: 6.0.11, hostname: ioBroker8     , alive, uptime: 136)
                                      js-controller:  6.0.11
                                      admin:          7.1.5
                                      javascript:     8.8.3
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : ioBroker8                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.backitup.0               : backitup              : ioBroker8                                -  enabled
                                        system.adapter.discovery.0              : discovery             : ioBroker8                                -  enabled
                                      + system.adapter.email.0                  : email                 : ioBroker8                                -  enabled
                                        system.adapter.enigma2.0                : enigma2               : ioBroker8                                -  enabled
                                        system.adapter.habpanel.0               : habpanel              : ioBroker8                                - disabled
                                      + system.adapter.influxdb.0               : influxdb              : ioBroker8                                -  enabled, port: 8086
                                      + system.adapter.javascript.0             : javascript            : ioBroker8                                -  enabled
                                        system.adapter.lg-thinq.0               : lg-thinq              : ioBroker8                                -  enabled
                                        system.adapter.mqtt.0                   : mqtt                  : ioBroker8                                -  enabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.tuya.0                   : tuya                  : ioBroker8                                - disabled
                                        system.adapter.upnp.0                   : upnp                  : ioBroker8                                -  enabled
                                        system.adapter.viessmannapi.0           : viessmannapi          : ioBroker8                                -  enabled
                                        system.adapter.web.0                    : web                   : ioBroker8                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker8                                -  enabled
                                      + instance is alive
                                      Active repo(s): stable
                                      Used repository: stable
                                      Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                      Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
                                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                      Controller "js-controller": 6.0.11   , installed 6.0.11
                                      Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
                                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                      Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
                                      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                      Objects and States
                                      Objects:        13431
                                      States:         9861
                                      Hit:1 http://security.debian.org bookworm-security InRelease
                                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                                      Hit:3 https://repos.influxdata.com/debian stable InRelease
                                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 59
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          33304      1/init
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       39996541   60808/io.mqtt.0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       39994458   60531/iobroker.js-c
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       39994433   60531/iobroker.js-c
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          34299      322/master
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          33634      1/init
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          33310      1/init
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          34300      322/master
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39996749   60847/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       39994573   60553/io.admin.0
                                      udp        0      0 0.0.0.0:38426           0.0.0.0:*                           1001       39996822   60865/io.upnp.0
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          33575      87/dhclient
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          33307      1/init
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       39996984   60865/io.upnp.0
                                      udp6       0      0 :::111                  :::*                                0          33313      1/init
                                      2024-11-10 16:36:06.316  - info: mqtt.0 (60808) Client [SmartPlug2] subscribes on "SmartPlug2/+/get" with regex /SmartPlug2\.[^.]*\.get/
                                      2024-11-10 16:36:06.317  - info: mqtt.0 (60808) Client [SmartPlug2] subscribes on "SmartPlug2/+/get"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.get/
                                      2024-11-10 16:36:06.927  - info: host.ioBroker8 instance system.adapter.web.0 in version "6.2.5" started with pid 60847
                                      2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
                                      2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
                                      2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
                                      2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
                                      2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
                                      2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
                                      2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
                                      2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
                                      2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
                                      2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
                                      2024-11-10 16:36:08.010  - info: web.0 (60847) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.15.1, js-controller: 6.0.11
                                      2024-11-10 16:36:08.081  - info: web.0 (60847) socket.io server listening on port 8082
                                      2024-11-10 16:36:08.083  - info: web.0 (60847) http server listening on port 8082
                                      2024-11-10 16:36:10.927  - info: host.ioBroker8 instance system.adapter.upnp.0 in version "1.0.21" started with pid 60865
                                      2024-11-10 16:36:12.028  - info: upnp.0 (60865) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v20.15.1, js-controller: 6.0.11
                                      2024-11-10 16:36:12.035  - info: upnp.0 (60865) Auto discover: true
                                      2024-11-10 16:36:15.004  - info: host.ioBroker8 instance system.adapter.viessmannapi.0 in version "2.3.0" started with pid 60880
                                      2024-11-10 16:36:16.243  - info: viessmannapi.0 (60880) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v20.15.1, js-controller: 6.0.11
                                      2024-11-10 16:36:27.312  - info: viessmannapi.0 (60880) No installation found
                                      2024-11-10 16:37:15.342  - info: admin.0 (60553) ==> Connected system.user.admin from ::ffff:192.168.0.28
                                      2024-11-10 16:37:15.388  - info: admin.0 (60553) ==> Connected system.user.admin from ::ffff:192.168.0.28
                                      2024-11-10 16:37:18.976  - info: admin.0 (60553) <== Disconnect system.user.admin from ::ffff:192.168.0.28 backitup
                                      • I io2345
                                        ```bash
                                        Script v.2024-10-19
                                        *** BASE SYSTEM ***
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        CPU threads: 1
                                        iobrokeradmin
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Swap:           536M         49K        536M
                                                 2048 M total memory
                                                  863 M used memory
                                                  881 M active memory
                                                  392 M free memory
                                                    0 M buffer memory
                                                  792 M swap cache
                                                  512 M total swap
                                                    0 M used swap
                                                  511 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        625M    /var/
                                        330M    /var/cache
                                        326M    /var/cache/apt
                                        149M    /var/log
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        13431
                                        States:         9861
                                        Pending Updates: 59
                                        @io2345
                                        Dein Host-System scheint aber schwer in den Seilen zu hängen.
                                        Die ganzen failed services und deleted inodes sind jedenfalls nicht normal.
                                          @io2345
                                          I Offline
                                          I Offline
                                          io2345
                                          @thomas-braun Ich bin leider der komplette Laie wenn es um iobroker geht. Ich hab's aber immerhin mit einer A-Z Anleitung geschafft, es aufzusetzen.
                                          Aber wenn es Tipps gibt, was wie zu verbessern wäre, bemühe ich mich gerne, das umzusetzen.
