  4. Node-Red
  5. Function Node welche zwei Werte vergleicht
    6.4k
207 Beiträge 5 Kommentatoren 45.7k Aufrufe 4 Beobachtet
  • mickymM mickym
    @1984chris Na ja ich denke - wenn Du die Logik begreifst, dann wirst Du das schon selbst schaffen. ;)
    1 Offline
    1 Offline
    1984chris
    #113
    @mickym
    werde es probieren und melde mich.
    • mickymM mickym
      1 Offline
      1 Offline
      1984chris
      #114
      @mickym
      @mickym
      ich begreife die Logik nicht.
      Habs probiert.
      Wieso bekommt jetzt nach Ablauf der Pause der shelly kein true mehr aber Pumpe schon?
              "id": "c00995b3e526eedf",
              "type": "shelly-gen2",
              "z": "b7365eb2cd9f043a",
              "hostname": "192.168.1.110",
              "description": "",
              "mode": "polling",
              "server": "",
              "outputmode": "event",
              "uploadretryinterval": 5000,
              "pollinginterval": "60000",
              "pollstatus": true,
              "getstatusoncommand": true,
              "devicetype": "Relay",
              "outputs": 1,
              "x": 3020,
              "y": 600,
              "wires": [
                      "f95b5910053d7931",
                      "12d5210d37cca83a"
              "id": "12d5210d37cca83a",
              "type": "debug",
              "name": "Status shelly",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 3230,
              "y": 520,
              "wires": []
              "id": "f95b5910053d7931",
              "type": "switch",
              "name": "Check WP",
              "property": "payload.switch0.output",
              "propertyType": "msg",
              "rules": [
                      "t": "true"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 3210,
              "y": 600,
              "wires": [
                      "a81280bcde91cb43"
              "id": "a81280bcde91cb43",
              "type": "change",
              "name": "Setze Laufzeit",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "LaufzeitWP",
                      "tot": "flow"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "$exists(payload) ? payload : 0",
                      "tot": "jsonata"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload + 1",
                      "tot": "jsonata"
                      "t": "set",
                      "p": "LaufzeitWP",
                      "pt": "flow",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 3400,
              "y": 600,
              "wires": [
                      "8dc301ec673ad604",
                      "6952778507c39b73",
                      "8b7cf8516fdd7fa9"
              "id": "8dc301ec673ad604",
              "type": "debug",
              "name": "Laufzeit",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 3580,
              "y": 520,
              "wires": []
              "id": "6952778507c39b73",
              "type": "mqtt out",
              "name": "",
              "topic": "Laufzeit WP",
              "qos": "",
              "retain": "true",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "broker": "642915c7f69dceb8",
              "x": 3570,
              "y": 680,
              "wires": []
              "id": "8b7cf8516fdd7fa9",
              "type": "switch",
              "name": "Laufzeitlimit erreicht?",
              "property": "payload",
              "rules": [
                      "t": "gt",
                      "v": "2",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 3640,
              "y": 600,
              "wires": [
                      "a99fb16f9e1aaf53"
              "id": "a99fb16f9e1aaf53",
              "type": "trigger",
              "name": "",
              "op1": "false",
              "op2": "0",
              "op1type": "bool",
              "op2type": "str",
              "duration": "0",
              "extend": false,
              "overrideDelay": false,
              "units": "ms",
              "reset": "true",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 3860,
              "y": 600,
              "wires": [
                      "d32930fee61a93db"
              "id": "d32930fee61a93db",
              "type": "trigger",
              "name": "PauseWP ",
              "op1": "false",
              "op2": "true",
              "op1type": "bool",
              "op2type": "bool",
              "duration": "1",
              "extend": false,
              "units": "min",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 2,
              "x": 4040,
              "y": 600,
              "wires": [
                      "0df1fcecdcb502cd",
                      "b7384ed837f983ef"
                      "878c47ba3fe7f98d",
                      "b7384ed837f983ef"
              "id": "d64cd3672f38dec5",
              "type": "debug",
              "name": "Ergebnis für Shelly 1",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 4480,
              "y": 540,
              "wires": []
              "id": "0df1fcecdcb502cd",
              "type": "change",
              "name": "PauseWP",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "{\t \"method\": \"Switch.Set\",\t \"parameters\" : {\t \"id\" : 0,\t \"on\": payload \t }\t}",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 4220,
              "y": 540,
              "wires": [
                      "d64cd3672f38dec5"
              "id": "878c47ba3fe7f98d",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "LaufzeitWP",
                      "pt": "flow",
                      "to": "0",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 4240,
              "y": 720,
              "wires": [
                      "a99fb16f9e1aaf53"
              "id": "dbb3de1955f4208b",
              "type": "mqtt in",
              "name": "",
              "qos": "2",
              "datatype": "auto-detect",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 3790,
              "y": 740,
              "wires": [
                      "80e2f07516e1e78f"
              "id": "80e2f07516e1e78f",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "LaufzeitWP",
                      "pt": "flow",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 3980,
              "y": 740,
              "wires": [
              "id": "b7384ed837f983ef",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload ? \"Pumpe ein 1\" : \"Pumpe aus 0\"",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 4270,
              "y": 600,
              "wires": [
                      "f44b626f907ee971"
              "id": "f44b626f907ee971",
              "type": "debug",
              "name": "Ergebnis für Poolpumpe1 nach pause",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 4550,
              "y": 600,
              "wires": []
              "id": "642915c7f69dceb8",
              "type": "mqtt-broker",
              "name": "",
              "broker": "192.168.1.154",
              "port": "1883",
              "clientid": "",
              "autoConnect": true,
              "usetls": false,
              "protocolVersion": "4",
              "keepalive": "60",
              "cleansession": true,
              "autoUnsubscribe": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      • 1 1984chris
        @mickym
        @mickym
        Habs probiert.
                "description": "",
                "mode": "polling",
                "server": "",
                "pollstatus": true,
                "outputs": 1,
                "x": 3020,
                "y": 600,
                "wires": [
                        "f95b5910053d7931",
                        "12d5210d37cca83a"
                "type": "debug",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 3230,
                "y": 520,
                "wires": []
                "type": "switch",
                "name": "Check WP",
                "rules": [
                        "t": "true"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 3210,
                "y": 600,
                "wires": [
                        "a81280bcde91cb43"
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "LaufzeitWP",
                        "tot": "flow"
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                        "t": "set",
                        "p": "LaufzeitWP",
                        "pt": "flow",
                        "to": "payload",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 3400,
                "y": 600,
                "wires": [
                        "8dc301ec673ad604",
                        "6952778507c39b73",
                        "8b7cf8516fdd7fa9"
                "type": "debug",
                "name": "Laufzeit",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 3580,
                "y": 520,
                "wires": []
                "type": "mqtt out",
                "name": "",
                "qos": "",
                "retain": "true",
                "respTopic": "",
                "contentType": "",
                "userProps": "",
                "correl": "",
                "expiry": "",
                "x": 3570,
                "y": 680,
                "wires": []
                "type": "switch",
                "rules": [
                        "t": "gt",
                        "v": "2",
                        "vt": "num"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 3640,
                "y": 600,
                "wires": [
                        "a99fb16f9e1aaf53"
                "type": "trigger",
                "name": "",
                "op1": "false",
                "op2": "0",
                "op1type": "bool",
                "op2type": "str",
                "duration": "0",
                "extend": false,
                "units": "ms",
                "reset": "true",
                "bytopic": "all",
                "topic": "topic",
                "outputs": 1,
                "x": 3860,
                "y": 600,
                "wires": [
                        "d32930fee61a93db"
                "type": "trigger",
                "name": "PauseWP ",
                "op1": "false",
                "op2": "true",
                "op1type": "bool",
                "op2type": "bool",
                "duration": "1",
                "extend": false,
                "units": "min",
                "reset": "",
                "bytopic": "all",
                "topic": "topic",
                "outputs": 2,
                "x": 4040,
                "y": 600,
                "wires": [
                        "0df1fcecdcb502cd",
                        "b7384ed837f983ef"
                        "878c47ba3fe7f98d",
                        "b7384ed837f983ef"
                "type": "debug",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 4480,
                "y": 540,
                "wires": []
                "type": "change",
                "name": "PauseWP",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 4220,
                "y": 540,
                "wires": [
                        "d64cd3672f38dec5"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "LaufzeitWP",
                        "pt": "flow",
                        "to": "0",
                        "tot": "num"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 4240,
                "y": 720,
                "wires": [
                        "a99fb16f9e1aaf53"
                "type": "mqtt in",
                "name": "",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 3790,
                "y": 740,
                "wires": [
                        "80e2f07516e1e78f"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "LaufzeitWP",
                        "pt": "flow",
                        "to": "payload",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 3980,
                "y": 740,
                "wires": [
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 4270,
                "y": 600,
                "wires": [
                        "f44b626f907ee971"
                "type": "debug",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 4550,
                "y": 600,
                "wires": []
                "name": "",
                "port": "1883",
                "clientid": "",
                "usetls": false,
                "keepalive": "60",
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
        mickymM Offline
        mickymM Offline
        mickym
        #115
        Nun Du musst den ganzen Flow beachten - sprich der obige Flow gehört ja mit dazu, da ja nicht in jedem Fall eingeschaltet werden soll, wenn die Laufzeit abgelaufen ist, sondern nur dann, wenn entsprechender Überschuss beim Pausenende vorhanden ist.
        Sowas ist schon macht keinen Sinn, weil Du gleichzeit AUS- und EINSCHALTEST.
        Das ist der Originalflow und der SCHALTER nur die Pumpe aus und dann startet die Pause.
        Gleichzeitig musst Du aber doch den Hauptflow betrachten.
        Hier wird doch ein Wiedereinschalten verhindert, weil die max. Laufzeit überschritten ist. Das Ausschalten spielt keine Rolle, weil es ja eh schon ausgeschaltet ist bzw. wie unten geändert ausgeschaltet wird.
        Wenn die Zwangspause vorbei ist, dann wird gar nichts geschaltet, sondern lediglich die Laufzeit wieder auf 0 gesetzt und der Block zurückgesetzt.
        Das Einschalten muss ja dann auch wieder der normalen Logik folgen und darf ja nur erfolgen, wenn Soc und Überschuss ein Einschalten erfordern. Trotzdem ist mir noch ein Fehler aufgefallen, da der Filter oben blockiert - deswegen musst Du das Ausschaltsignal nach oben zu dem Filter durchreichen! Ich zeig es dir in der folgenden Abbildung:
        PS: Entschuldige manchmal meine Ausdrucksweise. Ich gebe mir wieder mehr Mühe um die korrekte Ausdrucksweise.
        • mickymM Offline
          mickymM Offline
          mickym
          #116
          Was ggf. auch nochzu bedenken ist, ob Du die Laufzeit ggf. zurücksetzt, wenn eine Pause durch das Ausschalten der Pumpe nicht mehr erforderlich ist, da sie eh lange genug ausgeschaltet war.
          1 mickymM 2 Antworten Letzte Antwort
          • mickymM mickym
            1 Offline
            1 Offline
            1984chris
            #117
            @mickym
            jetztz bekomme ich aber am Ende kein ein mehr weder für Shelly noch für Homeserver
            • 1 1984chris
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              #118
              @1984chris Ja weil wahrscheinlich die Laufzeit erreicht wurde. Lösche mal im Kontext die Laufzeit einfach.
              • mickymM mickym
                mickymM Offline
                mickymM Offline
                mickym
                #119
                @mickym sagte in Function Node welche zwei Werte vergleicht:
                Hier mal die Änderung um die Auszeiten zu zählen - damit wird quasi auch wenn über Nacht eh alles ausgeschaltet ist, dass dann die Laufzeit zurückgestellt wird. Du musst halt die Pausenzeit genauso anpassen.
                Hier zum Import:
                [{"id":"1b6c6646565c829e","type":"switch","z":"517cd16e4d7e6ae4","name":"Check WP","property":"payload.switch0.output","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1630,"y":3840,"wires":[["a81280bcde91cb43"],["4b2dcbb7fa3c347f"]]},{"id":"66f1ebe9b8cf6467","type":"switch","z":"517cd16e4d7e6ae4","name":"Pausenlimit erreicht?","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":2060,"y":3940,"wires":[["878c47ba3fe7f98d"]]},{"id":"4b2dcbb7fa3c347f","type":"change","z":"517cd16e4d7e6ae4","name":"Setze PauseWP","rules":[{"t":"set","p":"payload","pt":"msg","to":"PauseWP","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"$exists(payload) ? payload : 0","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"payload + 1","tot":"jsonata"},{"t":"set","p":"PauseWP","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1840,"y":3940,"wires":[["66f1ebe9b8cf6467"]]}]
                • 1 1984chris
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #120
                  @1984chris sagte in Function Node welche zwei Werte vergleicht:
                  @mickym
                  Ach ja und vergiss nicht das Pollintervall in der Shelly Node auf 60000 ms zu setzen. Die Werte für die Laufzeit und die Pause sind ja Minuten.
                  1 1 Antwort Letzte Antwort
                  • mickymM mickym
                    @mickym
                    1 Offline
                    1 Offline
                    1984chris
                    #121
                    @mickym
                    es wird kein ein signal durchgeleitet...
                    • 1 1984chris
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #122
                      @1984chris Gut - dann musst Du mit debug Nodes schauen, wo es hängen bleibt.
                      Aktiviere halt mal alle Debug Nodes bzw. schau wie weit die Nachrichten kommen - ggf. neue Debug Nodes dran machen.
                      Hast Du in dem Switch
                      auch die max. Laufzeit richtig eingetragen?
                      • mickymM mickym
                        1 Offline
                        1 Offline
                        1984chris
                        #123
                        @mickym
                        es liegt an der Laufzeitlimit erreicht Node im Hauptast habe dahinter ein Debug Node und da wird nix angezeigt.
                        • 1 1984chris
                          @mickym
                          1 Offline
                          1 Offline
                          1984chris
                          #124
                          @1984chris
                          habe die Laufzeit auf 2 runtergesetzt zum testen...
                          • 1 1984chris
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #125
                            @1984chris Gut und hast Du den Wert da drin angepasst - da waren ja noch 5 Minuten drin zum Test.
                            • 1 1984chris
                              @1984chris
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #126
                              @1984chris Nein im Gegenteil - das ist das Maximum an Laufzeit. In der Realität wenn Du 5 Stunden Laufzeit haben willst, muss da <= 300 drin stehen.
                              Genauso wie Du unten dann Laufzeit erreicht > 300 einstellen musst.
                              1 2 Antworten Letzte Antwort
                              • mickymM mickym
                                1 Offline
                                1 Offline
                                1984chris
                                #127
                                @mickym
                                mit 2 hab ich Minuten gemeint.
                                • 1 1984chris
                                  @mickym
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #128
                                  @mickym
                                  Ja trotzdem oben wird durchgelassen, wenn die Laufzeit KLEINER als x Minuten ist.
                                  Wenn Du da 2 einträgst, dann blockiert es doch bereits bei der 2. Minute Laufzeit
                                  • mickymM mickym
                                    1 Offline
                                    1 Offline
                                    1984chris
                                    #129
                                    @mickym
                                    hab den Fehler schon es war unter Eigenschaft msg und nicht flow eingestellt.
                                    hab aber nichts geändert...
                                    • 1 1984chris
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #130
                                      @1984chris Trag da oben 300 ein. Es wird durchgelassen, wenn die Kontextvariable LaufzeitWP kleiner als der eingetragene Wert ist.
                                      • mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #131
                                        Um bei Testen den Filter zurückzusetzen kannst Du mit Inject ein msg.reset in den filter einspeisen.
                                        • mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #132
                                          Und zeig mal die Kontextvariable LaufzeitWP aus dem Kontextfenster.
