  4. Node-Red
  5. Function Node welche zwei Werte vergleicht
    6.4k
207 Beiträge 5 Kommentatoren 45.6k Aufrufe 4 Beobachtet
  • C Offline
    csh-de
    Dann sage ich DANKE, hatte eine Fragestellung zum Batterieladen mit PV Überschuss bzw. wenn Batterie unter 11Volt fällt zwangsladen auf zumindest 12V.
    Ist nicht perfekt aber es geht, für Verbesserungen bin ich dankbar.
    klappt gut:
            "id": "72c67f517a573034",
            "type": "tab",
            "label": "Batterieladen Steckdose",
            "disabled": false,
            "info": "",
            "env": []
            "id": "2d01dc6403d94a3a",
            "type": "change",
            "z": "72c67f517a573034",
            "name": "",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "wwdif",
                    "tot": "msg"
                    "t": "set",
                    "p": "wwdif",
                    "pt": "flow",
                    "to": "wwdif",
                    "tot": "msg"
                    "t": "set",
                    "p": "heizdif",
                    "pt": "msg",
                    "to": "heizdif",
                    "tot": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 290,
            "y": 400,
            "wires": [
                    "0ad5b4d399c61de6",
                    "1d719c85322bf761",
                    "dcbc48c6da9cc23f",
                    "ef33073bdbaf2f1a"
            "id": "97c097951912333f",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "heizdif",
                    "tot": "msg"
                    "t": "set",
                    "p": "heizdif",
                    "pt": "flow",
                    "to": "heizdif",
                    "tot": "msg"
                    "t": "set",
                    "p": "wwdif",
                    "pt": "msg",
                    "to": "wwdif",
                    "tot": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 290,
            "y": 340,
            "wires": [
                    "0ad5b4d399c61de6",
                    "dcbc48c6da9cc23f",
                    "ef33073bdbaf2f1a"
            "id": "b9f39f2b57132328",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "14.3",
            "payloadType": "num",
            "x": 110,
            "y": 440,
            "wires": [
                    "2d01dc6403d94a3a"
            "id": "0a913206124826cb",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "4444",
            "x": 110,
            "y": 340,
            "wires": [
                    "97c097951912333f"
            "id": "949129cc76b54963",
            "type": "debug",
            "name": "debug",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 1210,
            "y": 440,
            "wires": []
            "id": "03546add79dfe5e0",
            "type": "trigger",
            "name": "an",
            "op1": "on",
            "op2": "on",
            "op1type": "str",
            "op2type": "str",
            "duration": "1",
            "extend": false,
            "overrideDelay": false,
            "units": "s",
            "reset": "",
            "bytopic": "topic",
            "topic": "playload",
            "outputs": 1,
            "x": 950,
            "y": 340,
            "wires": [
                    "949129cc76b54963",
                    "4e5501b96de32957"
            "id": "385c7e664c0eedeb",
            "type": "switch",
            "name": "Batterie unter 14,8Volt",
            "property": "wwdif",
            "propertyType": "msg",
            "rules": [
                    "t": "lte",
                    "v": "14.8",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 740,
            "y": 340,
            "wires": [
                    "03546add79dfe5e0"
            "id": "0ad5b4d399c61de6",
            "type": "switch",
            "name": "über 800Watt",
            "property": "heizdif",
            "rules": [
                    "t": "gt",
                    "v": "800",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 520,
            "y": 340,
            "wires": [
                    "385c7e664c0eedeb"
            "id": "882c6cfb98dac2c8",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "14.9",
            "x": 110,
            "y": 400,
            "wires": [
                    "2d01dc6403d94a3a"
            "id": "7e14fa1a362fa1a8",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "444",
            "x": 110,
            "y": 300,
            "wires": [
                    "97c097951912333f"
            "id": "dcbc48c6da9cc23f",
            "type": "switch",
            "name": "Batterie über 14,8Volt",
            "rules": [
                    "t": "gte",
                    "v": "14.8",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 740,
            "y": 460,
            "wires": [
                    "b20b2758e7e2a66c"
            "id": "1d719c85322bf761",
            "type": "switch",
            "name": "unter 800Watt",
            "rules": [
                    "t": "lt",
                    "v": "800",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 520,
            "y": 400,
            "wires": [
                    "0c3e2ef811f1afbd"
            "id": "b20b2758e7e2a66c",
            "type": "trigger",
            "name": "aus",
            "op1": "off",
            "op2": "off",
            "op1type": "str",
            "op2type": "str",
            "duration": "1",
            "extend": false,
            "units": "s",
            "reset": "",
            "bytopic": "all",
            "topic": "topic",
            "outputs": 1,
            "x": 950,
            "y": 400,
            "wires": [
                    "949129cc76b54963",
                    "4e5501b96de32957"
            "id": "0c3e2ef811f1afbd",
            "type": "switch",
            "name": "Batterie über 12Volt",
            "rules": [
                    "t": "gte",
                    "v": "12",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 730,
            "y": 400,
            "wires": [
                    "b20b2758e7e2a66c"
            "id": "242de0a519521809",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "11.8",
            "x": 110,
            "y": 520,
            "wires": [
                    "2d01dc6403d94a3a"
            "id": "ef33073bdbaf2f1a",
            "type": "switch",
            "name": "Batterie unter 10Volt",
            "rules": [
                    "t": "lte",
                    "v": "10",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 740,
            "y": 520,
            "wires": [
                    "03546add79dfe5e0"
            "id": "9b0d01c762ab6bbf",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "10",
            "x": 110,
            "y": 560,
            "wires": [
                    "2d01dc6403d94a3a"
            "id": "017a8065f8fc42da",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "12.1",
            "x": 110,
            "y": 480,
            "wires": [
                    "2d01dc6403d94a3a"
            "id": "4e5501b96de32957",
            "type": "mqtt out",
            "name": "",
            "topic": "cmnd/Nous_Steckdose_1/POWER",
            "qos": "0",
            "retain": "",
            "respTopic": "",
            "contentType": "",
            "userProps": "",
            "correl": "",
            "expiry": "",
            "broker": "e9940ef89fc0f548",
            "x": 1220,
            "y": 340,
            "wires": []
            "id": "e9940ef89fc0f548",
            "type": "mqtt-broker",
            "name": "",
            "broker": "192.168.178.153",
            "port": "1883",
            "clientid": "",
            "autoConnect": true,
            "usetls": false,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "userProps": "",
            "sessionExpiry": ""
    • 1 Offline
      1 Offline
      1984chris
      Hallo
      Hätte dazu eine Frage:
      Wie kann ich den Trigger wenn er läuft wieder zurücksetzen wenn heizdif" größer als 20 und der Flow wwdif größer als 5 ist?
      Danke im Voraus
      LG Christoph
      • 1 1984chris
        Hallo
        Danke im Voraus
        LG Christoph
        mickymM Offline
        mickymM Offline
        mickym
        @1984chris Steht doch in der Node - entweder eine bestimmte payload oder msg.reset an die trigger Node senden.
        • 1 Offline
          1 Offline
          1984chris
          Danke für die schnelle Antwort.
          wie funktioniert das wenn ich z.b heizdif größer 20 oder wwdif größer 5 den reset senden soll?
          • 1 1984chris
            mickymM Offline
            mickymM Offline
            mickym
            @1984chris sagte in Function Node welche zwei Werte vergleicht:
            Na wenn Du programmierst, dann machst Du doch eh aus der payload true oder false
            if (msg.heizdif > 20 && msg.wwdif > 5) {
            msg.payload = true;
            else {
            msg.payload = false;
            return msg;
            dann resettest Du die trigger Node in dem Du halt bei payload=false den trigger zurücksetzt.
            • 1 Offline
              1 Offline
              1984chris
              Entschuldigung meinte ein Delay (Verzögerung von ca 5 sek) zurücksetzen.
              Will mir gerade einen Flow zusammenstöpseln für eine Wärmepumpe beim pool wenn ich PV Überschuss habe.
              • 1 Offline
                1 Offline
                1984chris
                Das wäre mein Flow klappt aber nicht ganz
                kannst du mir da weiterhelfen?
                        "id": "b7365eb2cd9f043a",
                        "type": "tab",
                        "label": "Flow 1",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "id": "676fdaa5ab37f82c",
                        "type": "junction",
                        "z": "b7365eb2cd9f043a",
                        "x": 440,
                        "y": 240,
                        "wires": [
                        "id": "106c2bd2ab4d7271",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "move",
                                "p": "payload",
                                "pt": "msg",
                                "to": "SOC",
                                "tot": "msg"
                                "t": "set",
                                "p": "SOC",
                                "pt": "flow",
                                "to": "SOC",
                                "tot": "msg"
                                "t": "set",
                                "p": "Einspeisung",
                                "pt": "msg",
                                "to": "Einspeisung",
                                "tot": "flow"
                                "t": "set",
                                "p": "AutoEin",
                                "pt": "msg",
                                "to": "AutoEin",
                                "tot": "flow"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 350,
                        "y": 340,
                        "wires": [
                                "6f43630b1e5bffa6",
                                "69721ab08dff22a4"
                        "id": "fad797de2d4263e2",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "move",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "msg"
                                "t": "set",
                                "p": "Einspeisung",
                                "pt": "flow",
                                "tot": "msg"
                                "t": "set",
                                "p": "SOC",
                                "pt": "msg",
                                "to": "SOC",
                                "tot": "flow"
                                "t": "set",
                                "p": "AutoEin",
                                "pt": "msg",
                                "to": "AutoEin",
                                "tot": "flow"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 350,
                        "y": 240,
                        "wires": [
                                "6f43630b1e5bffa6",
                                "a19ce5e257844c73"
                        "id": "89741e6a3495365a",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "81",
                        "x": 130,
                        "y": 340,
                        "wires": [
                                "106c2bd2ab4d7271"
                        "id": "70f02e1808782e01",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "2600",
                        "x": 130,
                        "y": 220,
                        "wires": [
                                "fad797de2d4263e2"
                        "id": "41cdc59d895451f9",
                        "type": "switch",
                        "name": "SOC > 80%",
                        "property": "SOC",
                        "rules": [
                                "t": "gt",
                                "v": "80",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 970,
                        "y": 220,
                        "wires": [
                                "ddb53c0fd9b14566"
                        "id": "6f43630b1e5bffa6",
                        "type": "switch",
                        "name": "Einspeiseleistung > 2500W",
                        "property": "Einspeisung",
                        "rules": [
                                "t": "gt",
                                "v": "2500",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 740,
                        "y": 220,
                        "wires": [
                                "41cdc59d895451f9"
                        "id": "15c823b03fb41d53",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "79",
                        "x": 130,
                        "y": 380,
                        "wires": [
                                "106c2bd2ab4d7271"
                        "id": "30202f2f9c2edc68",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "2300",
                        "x": 130,
                        "y": 260,
                        "wires": [
                                "fad797de2d4263e2"
                        "id": "590c95b73bcb4f31",
                        "type": "delay",
                        "name": "5 sek ",
                        "pauseType": "delayv",
                        "timeout": "5",
                        "timeoutUnits": "seconds",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "rateUnits": "second",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "randomUnits": "seconds",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 1110,
                        "y": 360,
                        "wires": [
                                "d74366116650e8db"
                        "id": "7fcd987717f18e60",
                        "type": "change",
                        "name": "Reset Verzögerung wenn PV überschuss wieder größer als Abschaltung",
                        "rules": [
                                "t": "set",
                                "p": "reset",
                                "pt": "msg",
                                "to": "",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 840,
                        "y": 500,
                        "wires": [
                                "590c95b73bcb4f31"
                        "id": "e48419cce5a53fc5",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "move",
                                "p": "payload",
                                "pt": "msg",
                                "to": "AutoEin",
                                "tot": "msg"
                                "t": "set",
                                "p": "AutoEin",
                                "pt": "flow",
                                "to": "AutoEin",
                                "tot": "msg"
                                "t": "set",
                                "p": "SOC",
                                "pt": "msg",
                                "to": "SOC",
                                "tot": "flow"
                                "t": "set",
                                "p": "Einspeisung",
                                "pt": "msg",
                                "tot": "flow"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 350,
                        "y": 160,
                        "wires": [
                                "6f43630b1e5bffa6",
                                "c2e0449225b14c6d"
                        "id": "ddb53c0fd9b14566",
                        "type": "switch",
                        "name": "Auto Ein/Aus",
                        "property": "AutoEin",
                        "rules": [
                                "t": "cont",
                                "v": "AutoEin",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 1170,
                        "y": 220,
                        "wires": [
                                "beffdf77c0512e49",
                                "7fcd987717f18e60"
                        "id": "a19ce5e257844c73",
                        "type": "switch",
                        "name": "Einspeisung <2500",
                        "rules": [
                                "t": "lt",
                                "v": "2500",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 710,
                        "y": 320,
                        "wires": [
                                "590c95b73bcb4f31"
                        "id": "69721ab08dff22a4",
                        "type": "switch",
                        "name": "SOC <80",
                        "property": "SOC",
                        "rules": [
                                "t": "lte",
                                "v": "80",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 680,
                        "y": 360,
                        "wires": [
                                "590c95b73bcb4f31"
                        "id": "c2e0449225b14c6d",
                        "type": "switch",
                        "rules": [
                                "t": "cont",
                                "v": "AutoAus",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 690,
                        "y": 280,
                        "wires": [
                                "590c95b73bcb4f31"
                        "id": "9798baeaeaa55b49",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "AutoEin",
                        "payload": "AutoEin",
                        "payloadType": "str",
                        "x": 120,
                        "y": 140,
                        "wires": [
                                "e48419cce5a53fc5"
                        "id": "14201be83d6b7071",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "AutoAus",
                        "x": 100,
                        "y": 180,
                        "wires": [
                                "e48419cce5a53fc5"
                        "id": "f712bce41f284baa",
                        "type": "comment",
                        "name": "Wenn AutoEin Einspeisung >2500W + SOC Batterie >80%  WP ein /  Wenn AutoEin Aus Einpeisung <2500W + SOC Batterie <80%  WP Aus",
                        "info": "",
                        "x": 940,
                        "y": 60,
                        "wires": []
                        "id": "8a3f49466eef2629",
                        "type": "debug",
                        "name": "debug 15",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1600,
                        "y": 140,
                        "wires": []
                        "id": "415e408af464ee3f",
                        "type": "delay",
                        "name": "5 sek ",
                        "timeout": "5",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 1570,
                        "y": 400,
                        "wires": [
                                "8a3f49466eef2629"
                        "id": "d74366116650e8db",
                        "type": "trigger",
                        "name": "Schalter Aus",
                        "op1": "Pumpe Aus 0",
                        "op2": "",
                        "op1type": "str",
                        "op2type": "nul",
                        "duration": "1",
                        "extend": false,
                        "units": "s",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 1370,
                        "y": 320,
                        "wires": [
                                "415e408af464ee3f"
                        "id": "beffdf77c0512e49",
                        "type": "trigger",
                        "name": "Schalter Ein",
                        "op1": "Pumpe Ein 1",
                        "op2": "",
                        "op1type": "str",
                        "op2type": "nul",
                        "duration": "250",
                        "extend": false,
                        "units": "ms",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 1410,
                        "y": 220,
                        "wires": [
                                "8a3f49466eef2629"
                        "id": "6bbe0fa685697ec3",
                        "type": "comment",
                        "name": "Wenn  Einspeisung >2500W + SOC Batterie >80% dann reser Verzögerung aber wie?",
                        "info": "",
                        "x": 880,
                        "y": 560,
                        "wires": []
                • 1 1984chris
                          "type": "tab",
                          "label": "Flow 1",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "junction",
                          "x": 440,
                          "y": 240,
                          "wires": [
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "move",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "SOC",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "SOC",
                                  "pt": "flow",
                                  "to": "SOC",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "Einspeisung",
                                  "pt": "msg",
                                  "tot": "flow"
                                  "t": "set",
                                  "p": "AutoEin",
                                  "pt": "msg",
                                  "to": "AutoEin",
                                  "tot": "flow"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 350,
                          "y": 340,
                          "wires": [
                                  "6f43630b1e5bffa6",
                                  "69721ab08dff22a4"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "move",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "Einspeisung",
                                  "pt": "flow",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "SOC",
                                  "pt": "msg",
                                  "to": "SOC",
                                  "tot": "flow"
                                  "t": "set",
                                  "p": "AutoEin",
                                  "pt": "msg",
                                  "to": "AutoEin",
                                  "tot": "flow"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 350,
                          "y": 240,
                          "wires": [
                                  "6f43630b1e5bffa6",
                                  "a19ce5e257844c73"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "81",
                          "x": 130,
                          "y": 340,
                          "wires": [
                                  "106c2bd2ab4d7271"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "2600",
                          "x": 130,
                          "y": 220,
                          "wires": [
                                  "fad797de2d4263e2"
                          "type": "switch",
                          "property": "SOC",
                          "rules": [
                                  "t": "gt",
                                  "v": "80",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 970,
                          "y": 220,
                          "wires": [
                                  "ddb53c0fd9b14566"
                          "type": "switch",
                          "rules": [
                                  "t": "gt",
                                  "v": "2500",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 740,
                          "y": 220,
                          "wires": [
                                  "41cdc59d895451f9"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "79",
                          "x": 130,
                          "y": 380,
                          "wires": [
                                  "106c2bd2ab4d7271"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "2300",
                          "x": 130,
                          "y": 260,
                          "wires": [
                                  "fad797de2d4263e2"
                          "type": "delay",
                          "name": "5 sek ",
                          "timeout": "5",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 1110,
                          "y": 360,
                          "wires": [
                                  "d74366116650e8db"
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "reset",
                                  "pt": "msg",
                                  "to": "",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 840,
                          "y": 500,
                          "wires": [
                                  "590c95b73bcb4f31"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "move",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "AutoEin",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "AutoEin",
                                  "pt": "flow",
                                  "to": "AutoEin",
                                  "tot": "msg"
                                  "t": "set",
                                  "p": "SOC",
                                  "pt": "msg",
                                  "to": "SOC",
                                  "tot": "flow"
                                  "t": "set",
                                  "p": "Einspeisung",
                                  "pt": "msg",
                                  "tot": "flow"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 350,
                          "y": 160,
                          "wires": [
                                  "6f43630b1e5bffa6",
                                  "c2e0449225b14c6d"
                          "type": "switch",
                          "rules": [
                                  "t": "cont",
                                  "v": "AutoEin",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 1170,
                          "y": 220,
                          "wires": [
                                  "beffdf77c0512e49",
                                  "7fcd987717f18e60"
                          "type": "switch",
                          "rules": [
                                  "t": "lt",
                                  "v": "2500",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 710,
                          "y": 320,
                          "wires": [
                                  "590c95b73bcb4f31"
                          "type": "switch",
                          "name": "SOC <80",
                          "property": "SOC",
                          "rules": [
                                  "t": "lte",
                                  "v": "80",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 680,
                          "y": 360,
                          "wires": [
                                  "590c95b73bcb4f31"
                          "type": "switch",
                          "rules": [
                                  "t": "cont",
                                  "v": "AutoAus",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 690,
                          "y": 280,
                          "wires": [
                                  "590c95b73bcb4f31"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "AutoEin",
                          "x": 120,
                          "y": 140,
                          "wires": [
                                  "e48419cce5a53fc5"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "x": 100,
                          "y": 180,
                          "wires": [
                                  "e48419cce5a53fc5"
                          "type": "comment",
                          "info": "",
                          "x": 940,
                          "y": 60,
                          "wires": []
                          "type": "debug",
                          "name": "debug 15",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1600,
                          "y": 140,
                          "wires": []
                          "type": "delay",
                          "name": "5 sek ",
                          "timeout": "5",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 1570,
                          "y": 400,
                          "wires": [
                                  "8a3f49466eef2629"
                          "type": "trigger",
                          "op2": "",
                          "op1type": "str",
                          "op2type": "nul",
                          "duration": "1",
                          "extend": false,
                          "units": "s",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 1370,
                          "y": 320,
                          "wires": [
                                  "415e408af464ee3f"
                          "type": "trigger",
                          "op2": "",
                          "op1type": "str",
                          "op2type": "nul",
                          "duration": "250",
                          "extend": false,
                          "units": "ms",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 1410,
                          "y": 220,
                          "wires": [
                                  "8a3f49466eef2629"
                          "type": "comment",
                          "info": "",
                          "x": 880,
                          "y": 560,
                          "wires": []
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @1984chris Nun ehrlich gesagt funktioniert das doch grundsätzlich:
                  Was problematisch ist, dass Du für die verschiedenen Nachrichteneigenschaften x- Nachrichten hast. Damit hast Du ggf. viele Probleme. Ich würde mit den Inject nodes alles erst mal in den Kontext zu speichern und diesen dann auszulesen. Dann wird das ganze viel übersichtlicher. Also das triggern des Flows von dem Kontext erst mal zu trennen.
                  Ich versuch das mal bissi zu vereinfachen, wobei ich Deine 2 Delays auch nicht ganz verstehe.
                  • 1 1984chris
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @1984chris Mal eine blöde Frage - was sollen die Trigger Nodes überhaupt und warum nutzt du wenn nicht nur trigger Nodes?
                    So ich bin mir zwar nicht sicher, was der Sinn ist - ggf. willst Du ja nur kurzfristige Unterbrechungen vermeiden.
                    Schau mal, ob das so tut:
                    [{"id":"a86c1f1e4b75e441","type":"inject","z":"b7365eb2cd9f043a","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"81","payloadType":"num","x":170,"y":920,"wires":[["494bb9361ae7bea3"]]},{"id":"f18c81168d9f50a0","type":"inject","z":"b7365eb2cd9f043a","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2600","payloadType":"num","x":170,"y":820,"wires":[["6fa8637750ac1054"]]},{"id":"a3d2d88cd6708218","type":"inject","z":"b7365eb2cd9f043a","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"79","payloadType":"num","x":170,"y":960,"wires":[["494bb9361ae7bea3"]]},{"id":"f3d26ec9c8d67465","type":"inject","z":"b7365eb2cd9f043a","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2300","payloadType":"num","x":170,"y":860,"wires":[["6fa8637750ac1054"]]},{"id":"84b2fa38187ff34f","type":"inject","z":"b7365eb2cd9f043a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"AutoEin","payload":"AutoEin","payloadType":"str","x":160,"y":720,"wires":[["5e6eefda3fb81cfd"]]},{"id":"eba9ab8e96ae87e8","type":"inject","z":"b7365eb2cd9f043a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AutoAus","payloadType":"str","x":180,"y":760,"wires":[["5e6eefda3fb81cfd"]]},{"id":"5e6eefda3fb81cfd","type":"change","z":"b7365eb2cd9f043a","name":"","rules":[{"t":"set","p":"AutoEin","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":740,"wires":[["c9bdbf8b0e1b8b42"]]},{"id":"6fa8637750ac1054","type":"change","z":"b7365eb2cd9f043a","name":"","rules":[{"t":"set","p":"Einspeisung","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":840,"wires":[["c9bdbf8b0e1b8b42"]]},{"id":"494bb9361ae7bea3","type":"change","z":"b7365eb2cd9f043a","name":"","rules":[{"t":"set","p":"SOC","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":940,"wires":[["c9bdbf8b0e1b8b42"]]},{"id":"c9bdbf8b0e1b8b42","type":"change","z":"b7365eb2cd9f043a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"AutoEin\":$exists($flowContext(\"AutoEin\")),\t   \"Einspeisung\":$exists($flowContext(\"Einspeisung\")),\t   \"SOC\":$exists($flowContext(\"SOC\"))\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":840,"wires":[["9367f9f7.8f5708"]]},{"id":"2975f91defeba563","type":"debug","z":"b7365eb2cd9f043a","name":"Alle Parameter gesetzt?","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1070,"y":760,"wires":[]},{"id":"9367f9f7.8f5708","type":"switch","z":"b7365eb2cd9f043a","name":"AND?","property":"$reduce(payload.*,function($i, $j){$i and $j})","propertyType":"jsonata","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":830,"y":840,"wires":[["2975f91defeba563","c6ee18440c5ede12"]],"info":"# All properties of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n    \"Office\": true,\n    \"Bedroom\": true,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n    \"Office\": true,\n    \"Bedroom\": false,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": true,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."},{"id":"45a1bb09159cf684","type":"switch","z":"b7365eb2cd9f043a","name":"SOC > 80%","property":"SOC","propertyType":"flow","rules":[{"t":"gt","v":"80","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1470,"y":820,"wires":[["55afcaa9b715c923","e6bff6b181617360"],["a24a10d67adf7325"]]},{"id":"5192b4bc40dd7659","type":"switch","z":"b7365eb2cd9f043a","name":"Einspeiseleistung > 2500W","property":"Einspeisung","propertyType":"flow","rules":[{"t":"gt","v":"2500","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1220,"y":820,"wires":[["45a1bb09159cf684"],["0f2c3c5c8743b77e"]]},{"id":"f558e9a1afff1836","type":"debug","z":"b7365eb2cd9f043a","name":"Ergebnis","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":2480,"y":800,"wires":[]},{"id":"c6ee18440c5ede12","type":"switch","z":"b7365eb2cd9f043a","name":"Auto Ein/Aus","property":"AutoEin","propertyType":"flow","rules":[{"t":"cont","v":"AutoEin","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":990,"y":840,"wires":[["5192b4bc40dd7659"],["473eacb13a6cb11c"]]},{"id":"5d671131260cc2d4","type":"change","z":"b7365eb2cd9f043a","name":"Schalter Aus","rules":[{"t":"set","p":"payload","pt":"msg","to":"Pumpe Aus 0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2090,"y":900,"wires":[["ddf39dae01705e59"]]},{"id":"856ab41216e0c0af","type":"delay","z":"b7365eb2cd9f043a","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1900,"y":900,"wires":[["5d671131260cc2d4"]]},{"id":"55afcaa9b715c923","type":"change","z":"b7365eb2cd9f043a","name":"Schalter Ein","rules":[{"t":"set","p":"payload","pt":"msg","to":"Pumpe Ein 1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1690,"y":800,"wires":[["ddf39dae01705e59"]]},{"id":"e6bff6b181617360","type":"change","z":"b7365eb2cd9f043a","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":840,"wires":[["856ab41216e0c0af"]]},{"id":"19225af3a1bf8b1a","type":"rbe","z":"b7365eb2cd9f043a","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":2310,"y":800,"wires":[["f558e9a1afff1836"]]},{"id":"a24a10d67adf7325","type":"junction","z":"b7365eb2cd9f043a","x":1620,"y":900,"wires":[["856ab41216e0c0af"]]},{"id":"0f2c3c5c8743b77e","type":"junction","z":"b7365eb2cd9f043a","x":1380,"y":900,"wires":[["a24a10d67adf7325"]]},{"id":"473eacb13a6cb11c","type":"junction","z":"b7365eb2cd9f043a","x":1100,"y":900,"wires":[["0f2c3c5c8743b77e"]]},{"id":"ddf39dae01705e59","type":"junction","z":"b7365eb2cd9f043a","x":2200,"y":800,"wires":[["19225af3a1bf8b1a"]]}]
                    1 1 Antwort Letzte Antwort
                    • mickymM mickym
                      1 Offline
                      1 Offline
                      1984chris
                      @mickym
                      Hallo
                      Ich habe mit node red noch nichts zu tun gehabt, bis jetzt und kann auch nichts programieren deshalb habe ich mir gedacht alles mit einzelnen nodes zu machen.
                      Habe das Beispiel für mich umbauen wollen weil ich eine Poolwärmepumpe habe und diese z.b nur einschalten soll wenn PV Überschuss >2500W SOC Batterie>80% und der Schalter AutoEin Ein ist. Die Verzögerung ist z.b wenn Wolken drüberziehen und der PV Überschuss <2500W ist, wenn innerhalb 15 min (die 5 sekunden sind nur zum testen) wieder >2500W ein reset erfolgt.
                      Deine Variante funktioniert.Danke
                      Wie gesagt habe leider keine Programierkenntnisse (JSON).
                      Kannst du mir einen Tipp geben wie ich mich in das Thema einarbeiten kann?
                      LG Christoph
                      • 1 1984chris
                        @mickym
                        Hallo
                        LG Christoph
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @1984chris Na ich habe auch sogut wie keinen Code geschrieben - das Einzige war, dass ich sicher gestellt habe, dass alle Daten im Kontext gespeichert sind.
                        Bei Objekten im Debug Fenster kannst Du immer den Pfad kopieren und ich habe nur JSONATA verwendet, um sicher zustellen, dass Du alles im Kontext vorhanden ist.
                        Die JSONATA Doku insgesamt - mit dem tollen Übungsfenster gibts hier: https://docs.jsonata.org/overview
                        Falls Du Dich da einarbeitest helfe ich Dir gerne - habe da auch mit jemand schon Übungen gemacht. Dann musst Dir halt Zeit nehmen.
                        Du siehst ja ich habe es auch ohne Programmieren gemacht und ich kann DICH nur ermutigen NICHT zu programmieren, sondern weiterhin einzelne Nodes zu nutzen. Nur so nutzt Du die Möglichkeiten von NodeRed. Also alles richtig gemacht.
                        Im Februar 2023 habe ich mit einem Forumsteilnehmer ein paar JSONATA Übungen gemacht. Die kannst Du ja mal versuchen nachzuvollziehen: https://forum.iobroker.net/post/943407
                        Ansonsten kann ich Dir die Tutorials von Steve empfehlen - ganz allgemein - die Grundlagen beherrschst Du schon: https://stevesnoderedguide.com/
                        • mickymM mickym
                          1 Offline
                          1 Offline
                          1984chris
                          @mickym
                          für was war der Filter?
                          hab den jetzt entfernt sonst hat der shelly kurz Ein und gleich wieder ausgeschaltet.
                          die zweite Verzögerung ist das als erstes die Poolpumpe ausgeht und dann die Wärmepumpe.
                          Ist das so ok?
                          • 1 1984chris
                            @mickym
                            Ist das so ok?
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @1984chris Der Filter verhindert eigentlich, dass gleiche Nachrichten mehrfach geschickt werden. Deswegen glaube ich nicht, dass der Filter für das Ein- und Ausschalten verantwortlich war. Da musst Du woanders suchen, woher das kommt. Klar kannst du die Delay Nodes in Serie schalten und den Reset gleichzeitig an beide Delays schicken.
                            Generell empfiehlt sich eigentlich neben einer Verzögerung nicht bei absoluten Werten zu schalten und eine gewisse Hysterese einzubauen.
                            • 1 Offline
                              1 Offline
                              1984chris
                              Hallo
                              was meinst du mit Kontext gespeichert? hab google schon bemüht aber nicht gefunden.
                              LG CHristoph
                              • 1 1984chris
                                Hallo
                                LG CHristoph
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @1984chris Na Du hast doch alles aus den Inject Nodes in Variablen gespeichert (in globale). Es gibt Variablen die haben Gültigkeit in einer Function Node, in einem Flow, oder global in allen Flows.
                                Sehen kannst Du diese Variablen alle im Kontextfenster.
                                Und warum Du nichts gefunden hast, verstehe ich nicht. Dem Kontext wurde in der Originaldokumentation sogar ein eigenen Kapitel gewidmet: https://nodered.org/docs/user-guide/context
                                Diese Seite enthält sogar ein Video dazu - allerdings in Englisch.
                                • mickymM mickym
                                  1 Offline
                                  1 Offline
                                  1984chris
                                  @mickym
                                  habe jsonata kontext speichern eigegeben......
                                  • 1 1984chris
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @mickym
                                    In der offiziellen JSONATA Doku findest Du nichts zum Kontext, da JSONATA unter NodeRed ein paar NodeRed spezifische Funktionen hat. Die findest du wenn Du in einer ChangeNode - den JSONATA Editor öffnest.
                                    • mickymM mickym
                                      @mickym
                                      1 Offline
                                      1 Offline
                                      1984chris
                                      @mickym
                                      für was speichert man die Werte im Kontext?
                                      die Und -funktion verstehe ich auch nicht....
                                      • 1 1984chris
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        Also insgesamt laufen die Nachrichtenobjekte ja zeitlich nicht synchronisiert von einer Node zur nächsten.
                                        Wenn Du in einer Inject Node drückst läuft das Nachrichtenobjekt ja schon los - auch wenn Du noch keine andere Inject Node gedrückt hast.
                                        Du hast ja auch bei Deinem Flow im Kontext gespeichert und alles in das Nachrichtenobjekt aufgenommen.
                                        In meinem Flow habe ich das nicht gemacht, sondern direkt die Flowvariablen abgefragt - und die stehen Dir ja zeitlich unbegrenzt und nicht nur in einem Nachrichtenobjekt zur Verfügung
                                        Wenn Du Dir meine switch Nodes anschaust, dann schaue ich gar nicht die Werte im Nachrichtenobjekt nach, sondern im flow Kontext.
                                        Hier prüfe ich einfach die Eigenschaften des Objektes ab mit der $reduce Funktion.
                                        Diese ist wiederum hier beschrieben:
                                        https://docs.jsonata.org/higher-order-functions#reduce
                                        Der erste Parameter ist ein Array und das Erzeuge ich indem ich sage, egal welche Eigenschaften mein Objekt hat - erzeuge daraus ein Array.
                                        Wie Du siehst
                                        wenn ich direkt ein Debug Node dahinter setze sehe ich ein Objekt, das für jede Eigenschaft true oder false liefert, je nachdem ob der Kontext definiert wurde.
                                        Wenn Du das in den JSONATA Exciser eingibst, dann sieht das so aus und Du siehst mit payload.* erzeuge ich ein Array mit allen Parametern,
                                        Dieses Array ergibt ein true, wenn alle Werte true sind.
                                        Das mache ich mit dem 2. Parameter der $reduce Funktion:
                                        Diese Funktion geht durch das Array und akkumuliert alles in der 1. Variable bei mir $i und $j ist der Wert bei Durchgehen des Arrays.
                                        Also bei einem Array
                                          true,
                                          true,
                                          true
                                        Ist $i undefiniert und $j = true (theoretisch kann man mit $i den Initialwert auch noch vorbelegen). In dem Fall gibt $i als funktion von true and true immer noch true. Nur wenn ein Wert falsch ist, wird der gesamte Wert falsch.
                                        Probiere es einfach aus, indem Du im linken Fenster einen Wert auf false setzt.
                                        https://try.jsonata.org/bzBaWUU8r
                                        • mickymM mickym
                                          Wie Du siehst
                                            true,
                                            true,
                                            true
                                          1 Offline
                                          1 Offline
                                          1984chris
                                          @mickym
                                          Bin jetzt noch auf ein Problem gekommen wenn ich Jetzt PV Erzeugung 2500W habe soll die Wärmepumpe einschalten das passt ja aber wenn ich jetzt z.b den Trockner einachalte der hat ja auch ca. 2300W und mehr dann habe ich ja wieder Bezug.
                                          Wie kann ich das lösen??
                                          Es wird immer komplizierter...
