  4. iobroker npm warn ERESOLVE overriding peer dependencynpm
    1.0k
    6.1k
27 Beiträge 5 Kommentatoren 3.9k Aufrufe 4 Beobachtet
    @tomtaz sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
    Boot Target: graphical.target
    sudo systemctl set-default multi-user.target
    sudo usermod -aG adm tomtaz
    Mit js-controller 6.0.1-alpha.0-20240603-3deca26fa bist du natürlich hart an der Kante unterwegs.
    Ansonsten sehe ich aber nichts wirklich schräges.
    tomtaz
    @thomas-braun said in iobroker npm warn ERESOLVE overriding peer dependencynpm:
    tomtaz@ioBroker:/opt/iobroker$ sudo systemctl set-default multi-user.target
    Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
    tomtaz@ioBroker:/opt/iobroker$ sudo usermod -aG adm tomtaz
    Beide Befehle ausgeführt:
    Und nun das neue diag
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-30-amd64
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     15:45:10 up 1 day, 19:09,  1 user,  load average: 0.36, 0.26, 0.37
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sun 2024-06-09 15:45:10 CEST
               Universal time: Sun 2024-06-09 13:45:10 UTC
                     RTC time: Sun 2024-06-09 13:45:11
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    tomtaz
    HOME=/home/tomtaz
    GROUPS=tomtaz cdrom floppy audio dip video plugdev netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:             13G        3.3G        8.3G        0.0K        2.4G         10G
    Swap:           2.0G          0B        2.0G
    Total:           16G        3.3G         10G
    Active iob-Instances:   31
            13977 M total memory
             3319 M used memory
              930 M active memory
             4464 M inactive memory
             8257 M free memory
              222 M buffer memory
             2177 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 15:45:10 up 1 day, 19:09,  1 user,  load average: 0.36, 0.26, 0.37
    Tasks: 127 total,   1 running, 126 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.9 us,  3.2 sy,  0.0 ni, 83.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  13977.1 total,   8258.8 free,   3318.7 used,   2399.6 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  10352.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                 Type      Size  Used Avail Use% Mounted on
    udev                       devtmpfs  6.9G     0  6.9G   0% /dev
    tmpfs                      tmpfs     1.4G  516K  1.4G   1% /run
    /dev/sda2                  ext4       44G   23G   19G  56% /
    tmpfs                      tmpfs     6.9G     0  6.9G   0% /dev/shm
    tmpfs                      tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1                  vfat      511M  5.8M  506M   2% /boot/efi
    //192.168.188.203/Ring     cifs      442G   51G  391G  12% /mnt/smbNas/ring
    //192.168.188.203/iobroker cifs      442G   51G  391G  12% /mnt/smbNas/iobroker
    tmpfs                      tmpfs     1.4G     0  1.4G   0% /run/user/1000
    [Fri Jun  7 20:35:41 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jun  7 20:35:42 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET                        SOURCE                     FSTYPE     OPTIONS
    /                             /dev/sda2                  ext4       rw,relatime,errors=remount-ro
    |-/sys                        sysfs                      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security      securityfs                 securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup            cgroup2                    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore            pstore                     pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/firmware/efi/efivars efivarfs                   efivarfs   rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf               none                       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/tracing       tracefs                    tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/debug         debugfs                    debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config        configfs                   configfs   rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections  fusectl                    fusectl    rw,nosuid,nodev,noexec,relatime
    |-/proc                       proc                       proc       rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc  systemd-1                  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1402
    |-/dev                        udev                       devtmpfs   rw,nosuid,relatime,size=7138428k,nr_inodes=1784607,mode=755
    | |-/dev/pts                  devpts                     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                  tmpfs                      tmpfs      rw,nosuid,nodev
    | |-/dev/hugepages            hugetlbfs                  hugetlbfs  rw,relatime,pagesize=2M
    | `-/dev/mqueue               mqueue                     mqueue     rw,nosuid,nodev,noexec,relatime
    |-/run                        tmpfs                      tmpfs      rw,nosuid,nodev,noexec,relatime,size=1431256k,mode=755
    | |-/run/lock                 tmpfs                      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs           sunrpc                     rpc_pipefs rw,relatime
    | `-/run/user/1000            tmpfs                      tmpfs      rw,nosuid,nodev,relatime,size=1431252k,nr_inodes=357813,mode=700,uid=1000,gid=1000
    |-/boot/efi                   /dev/sda1                  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    |-/mnt/smbNas/ring            //192.168.188.203/Ring     cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.188.203,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    `-/mnt/smbNas/iobroker        //192.168.188.203/iobroker cifs       rw,nosuid,nodev,noexec,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.188.203,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    5.1G    /var/
    4.0G    /var/log/journal/8ceb8e89cfec4839974812b8815506e2
    4.0G    /var/log
    802M    /var/lib
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    6.6G    /opt/iobroker/backups/
    244K    /opt/iobroker/backups/influx
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    924M    /opt/iobroker/iobroker-data/files
    281M    /opt/iobroker/iobroker-data/files/javascript.admin
    247M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    245M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.7253116f.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.3
    /usr/bin/node           v18.20.3
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.3-1nodesource1
      Candidate: 18.20.3-1nodesource1
      Version table:
     *** 18.20.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.1-alpha.0-20240603-3deca26fa
    admin:          6.17.14
    javascript:     8.5.0
    nodejs modules from github:     0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: tomtaz
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.divera247.0              : divera247             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.traccar.0                : traccar               : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Stable (default): http://download.iobroker.net/sources-dist.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
    Adapter    "admin"        : 6.17.14  , installed 6.17.14
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.2    , installed 3.0.2
    Adapter    "divera247"    : 0.2.0    , installed 0.1.2  [Updatable]
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "hmip"         : 1.23.3   , installed 1.23.3
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.5.0    , installed 8.5.0
    Controller "js-controller": 5.0.19   , installed 6.0.1
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "ring"         : 5.0.10   , installed 5.0.1  [Updatable]
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.4.0    , installed 3.4.0
    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
    Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
    Adapter    "web"          : 6.2.6    , installed 6.2.6
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Objects and States
    Objects:        15923
    States:         13376
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3620013    94314/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3619051    94314/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11285      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13143      464/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       3619327    94403/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3621349    94638/io.shelly.1
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       3622287    94683/io.mqtt.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11289      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       3619329    94403/node-red
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3619142    94332/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3626313    95332/io.web.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       3621067    94578/io.nuki-exten
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        13927      462/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13154      464/sshd: /usr/sbin
    udp        0      0 0.0.0.0:36148           0.0.0.0:*                           1001       3622327    94698/io.divera247.
    udp        0      0 0.0.0.0:36329           0.0.0.0:*                           1001       3619370    94426/io.telegram.0
    udp        0      0 0.0.0.0:44721           0.0.0.0:*                           1001       3619050    94314/iobroker.js-c
    udp        0      0 0.0.0.0:45091           0.0.0.0:*                           1001       3621050    94578/io.nuki-exten
    udp        0      0 0.0.0.0:53437           0.0.0.0:*                           1001       3623743    95164/io.javascript
    udp        0      0 192.168.188.202:5353    0.0.0.0:*                           1001       3622154    94653/io.tr-064.0
    udp        0      0 0.0.0.0:38273           0.0.0.0:*                           1001       3624891    95332/io.web.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       3621261    94623/io.shelly.0
    udp        0      0 0.0.0.0:54867           0.0.0.0:*                           1001       3619298    94388/io.node-red.0
    udp        0      0 0.0.0.0:46959           0.0.0.0:*                           1001       3622590    94743/io.info.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3621562    94668/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3621563    94668/io.tuya.0
    udp        0      0 0.0.0.0:56280           0.0.0.0:*                           1001       3991010    94638/io.shelly.1
    udp        0      0 0.0.0.0:56284           0.0.0.0:*                           1001       3622969    94728/io.echarts.0
    udp        0      0 0.0.0.0:56681           0.0.0.0:*                           1001       3624169    95190/io.parser.0
    udp        0      0 0.0.0.0:56910           0.0.0.0:*                           1001       3626070    95292/io.upnp.0
    udp        0      0 0.0.0.0:40680           0.0.0.0:*                           1001       3625919    95262/io.traccar.0
    udp        0      0 0.0.0.0:49155           0.0.0.0:*                           1001       3619120    94332/io.admin.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11286      1/init
    udp        0      0 0.0.0.0:49287           0.0.0.0:*                           1001       3624810    95307/io.vis-2.0
    udp        0      0 0.0.0.0:33292           0.0.0.0:*                           1001       3620852    94515/io.hmip.0
    udp        0      0 0.0.0.0:33684           0.0.0.0:*                           1001       3625592    95239/io.tankerkoen
    udp        0      0 0.0.0.0:34350           0.0.0.0:*                           1001       3619452    94456/io.accuweathe
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       3626419    95292/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       3619330    94403/node-red
    udp        0      0 0.0.0.0:34955           0.0.0.0:*                           1001       3619259    94368/io.influxdb.0
    udp        0      0 0.0.0.0:59626           0.0.0.0:*                           1001       3620732    94486/io.backitup.0
    udp        0      0 0.0.0.0:43509           0.0.0.0:*                           1001       3626388    95347/io.fullybrows
    udp        0      0 0.0.0.0:43866           0.0.0.0:*                           1001       3626068    95292/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          11292      1/init
    2024-06-09 15:30:00.031  - info: javascript.0 (95164) script.js.Steuerung.Zeitsteuerung.airbowlBad: [DEBUG] Die Airbwol wird nicht eingeschaltet, da diese zuletzt am/um geschalten wurde: 09.06.2024, 15:25 und wird sich in ca. 55 Minuten anschalten.
    2024-06-09 15:30:08.302  - info: host.ioBroker instance system.adapter.ical.0 having pid 109488 terminated with code 0 (NO_ERROR)
    2024-06-09 15:30:45.008  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 109524
    2024-06-09 15:30:47.032  - info: host.ioBroker instance system.adapter.dwd.0 having pid 109524 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-06-09 15:30:49.015  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 109539
    2024-06-09 15:30:50.214  - info: openweathermap.0 (109539) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
    2024-06-09 15:31:14.675  - info: openweathermap.0 (109539) Terminated (NO_ERROR): Without reason
    2024-06-09 15:31:15.195  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 109539 terminated with code 0 (NO_ERROR)
    2024-06-09 15:34:19.242  - info: web.0 (95332) ==> Connected system.user.admin from ::ffff:192.168.188.158
    2024-06-09 15:34:19.691  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm ist angegangen.
    2024-06-09 15:34:23.462  - info: web.0 (95332) ==> Connected system.user.admin from ::ffff:192.168.188.158
    2024-06-09 15:35:00.017  - info: host.ioBroker instance system.adapter.ical.0 started with pid 109680
    2024-06-09 15:35:07.735  - info: host.ioBroker instance system.adapter.ical.0 having pid 109680 terminated with code 0 (NO_ERROR)
    2024-06-09 15:38:49.643  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm wird ausgeschaltet
    2024-06-09 15:40:00.015  - info: host.ioBroker instance system.adapter.ical.0 started with pid 109839
    2024-06-09 15:40:00.029  - info: javascript.0 (95164) script.js.Steuerung.Zeitsteuerung.airbowlBad: [DEBUG] Die Airbwol wird nicht eingeschaltet, da diese zuletzt am/um geschalten wurde: 09.06.2024, 15:25 und wird sich in ca. 45 Minuten anschalten.
    2024-06-09 15:40:07.827  - info: host.ioBroker instance system.adapter.ical.0 having pid 109839 terminated with code 0 (NO_ERROR)
    2024-06-09 15:40:48.009  - info: host.ioBroker instance system.adapter.openweathermap.0 started with pid 109876
    2024-06-09 15:40:49.076  - info: openweathermap.0 (109876) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
    2024-06-09 15:40:53.465  - info: openweathermap.0 (109876) Terminated (NO_ERROR): Without reason
    2024-06-09 15:40:53.984  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 109876 terminated with code 0 (NO_ERROR)
    2024-06-09 15:41:39.725  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm ist angegangen.
    2024-06-09 15:43:39.756  - info: javascript.0 (95164) script.js.Steuerung.Anwesenheitserkennung.fullyKioskTabletFlur: [DEBUG] Bildschirm wird ausgeschaltet
    2024-06-09 15:45:00.012  - info: host.ioBroker instance system.adapter.ical.0 started with pid 110131
    2024-06-09 15:45:08.465  - info: host.ioBroker instance system.adapter.ical.0 having pid 110131 terminated with code 0 (NO_ERROR)
                            v.2024-05-22
               Chassis: vm
        Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    User-ID:                1000
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    Recommended versions are nodejs 18.20.3 and npm 10.7.0
    MEMORY:
    Swap:           2.0G          0B        2.0G
    Total:           16G        3.3G         10G
    ioBroker Core:          js-controller           6.0.1-alpha.0-20240603-3deca26fa
                            admin                   6.17.14
    Objects type: jsonl
    States  type: jsonl
    Objects:                15923
    States:                 13376
    Size of iob-Database:
    3.2M    /opt/iobroker/iobroker-data/states.jsonl
    Thomas BraunT 3 Antworten Letzte Antwort
    • T tomtaz
      Skript v.2024-05-22
      *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                    NTP service: active
                RTC in local TZ: no
      tomtaz
      HOME=/home/tomtaz
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
      Total:           16G        3.3G         10G
               3319 M used memory
                930 M active memory
               8257 M free memory
                222 M buffer memory
               2177 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      5.1G    /var/
      4.0G    /var/log
      802M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.17.14
      javascript:     8.5.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15923
      States:         13376
      Pending Updates: 0
                              v.2024-05-22
                 Chassis: vm
          Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      MEMORY:
      Swap:           2.0G          0B        2.0G
      Total:           16G        3.3G         10G
                              admin                   6.17.14
      Objects type: jsonl
      States  type: jsonl
      Objects:                15923
      States:                 13376
      @tomtaz
      Nach Änderungen in den Gruppen einmal Neustart.
      • T tomtaz
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                      NTP service: active
                  RTC in local TZ: no
        tomtaz
        HOME=/home/tomtaz
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
        Total:           16G        3.3G         10G
                 3319 M used memory
                  930 M active memory
                 8257 M free memory
                  222 M buffer memory
                 2177 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        /var:
        5.1G    /var/
        4.0G    /var/log
        802M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.17.14
        javascript:     8.5.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        15923
        States:         13376
        Pending Updates: 0
                                v.2024-05-22
                   Chassis: vm
            Virtualization: kvm
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        MEMORY:
        Swap:           2.0G          0B        2.0G
        Total:           16G        3.3G         10G
                                admin                   6.17.14
        Objects type: jsonl
        States  type: jsonl
        Objects:                15923
        States:                 13376
        @tomtaz
        Wo kommen die Module ohne iobroker im Pfad her?
        ├── canvas@2.11.2
        ├── echarts@5.4.3
        ├── moment@2.29.4
        └── ring-client-api@12.0.1
        Die dürften da eigentlich nicht auftauchen, denke ich.
        • T tomtaz
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          tomtaz
          HOME=/home/tomtaz
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           2.0G          0B        2.0G
          Total:           16G        3.3G         10G
                   3319 M used memory
                    930 M active memory
                   8257 M free memory
                    222 M buffer memory
                   2177 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          5.1G    /var/
          4.0G    /var/log
          802M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.17.14
          javascript:     8.5.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        15923
          States:         13376
          Pending Updates: 0
                                  v.2024-05-22
                     Chassis: vm
              Virtualization: kvm
          Installation:           kvm
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                1000
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          MEMORY:
          Swap:           2.0G          0B        2.0G
          Total:           16G        3.3G         10G
                                  admin                   6.17.14
          Objects type: jsonl
          States  type: jsonl
          Objects:                15923
          States:                 13376
          @tomtaz
          Installier den iobroker.admin@6.17.14 nochmal sauber rein.
            @tomtaz
            tomtaz
            Sorry, den hab ich vergessen :-(
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             16:03:42 up 4 min,  1 user,  load average: 0.55, 0.45, 0.19
            CPU threads: 2
                           Local time: Sun 2024-06-09 16:03:42 CEST
                       Universal time: Sun 2024-06-09 14:03:42 UTC
                             RTC time: Sun 2024-06-09 14:03:43
                          NTP service: active
                      RTC in local TZ: no
            tomtaz
            HOME=/home/tomtaz
            GROUPS=tomtaz adm cdrom floppy audio dip video plugdev netdev iobroker
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             13G        2.4G         11G        0.0K        569M         11G
            Swap:           2.0G          0B        2.0G
            Total:           16G        2.4G         13G
                     2389 M used memory
                      206 M active memory
                     2522 M inactive memory
                    11018 M free memory
                       56 M buffer memory
                      512 M swap cache
                     2047 M total swap
                        0 M used swap
                     2047 M free swap
            top - 16:03:42 up 4 min,  1 user,  load average: 0.55, 0.45, 0.19
            Tasks: 131 total,   1 running, 130 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  13977.1 total,  11018.5 free,   2389.1 used,    569.5 buff/cache
            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  11321.7 avail Mem
            *** FILESYSTEM ***
            [Sun Jun  9 15:59:38 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
            [Sun Jun  9 15:59:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
            | `-/proc/sys/fs/binfmt_misc  systemd-1                  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11229
            /var:
            5.1G    /var/
            4.0G    /var/log
            802M    /var/lib
            Archived and active journals take up 3.9G in the file system.
            916M    /opt/iobroker/iobroker-data/files
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
            USB-Devices by-id:
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.17.14
            javascript:     8.5.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        15919
            States:         13462
            Pending Updates: 0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16518      831/io.shelly.1
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       16030      876/io.mqtt.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13901      538/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13894      538/iobroker.js-con
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          425        1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13800      467/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14093      614/node-red
            tcp6       0      0 :::111                  :::*                    LISTEN      0          429        1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      1001       14097      614/node-red
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13983      557/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20185      1500/io.web.0
            tcp6       0      0 :::51989                :::*                    LISTEN      1001       15240      771/io.nuki-extende
            tcp6       0      0 :::8086                 :::*                    LISTEN      998        13276      456/influxd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13802      467/sshd: /usr/sbin
            udp        0      0 0.0.0.0:49153           0.0.0.0:*                           1001       20889      1475/io.vis-2.0
            udp        0      0 0.0.0.0:41010           0.0.0.0:*                           1001       20781      1460/io.upnp.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          426        1/init
            udp        0      0 0.0.0.0:57553           0.0.0.0:*                           1001       19708      1415/io.tankerkoeni
            udp        0      0 0.0.0.0:49520           0.0.0.0:*                           1001       14273      708/io.backitup.0
            udp        0      0 0.0.0.0:49618           0.0.0.0:*                           1001       14024      584/io.influxdb.0
            udp        0      0 0.0.0.0:33527           0.0.0.0:*                           1001       16302      921/io.echarts.0
            udp        0      0 0.0.0.0:58283           0.0.0.0:*                           1001       14757      599/io.node-red.0
            udp        0      0 0.0.0.0:42258           0.0.0.0:*                           1001       20179      1500/io.web.0
            udp        0      0 0.0.0.0:50692           0.0.0.0:*                           1001       20565      1430/io.traccar.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21139      1460/io.upnp.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       14098      614/node-red
            udp        0      0 0.0.0.0:44130           0.0.0.0:*                           1001       21075      1515/io.fullybrowse
            udp        0      0 0.0.0.0:52492           0.0.0.0:*                           1001       16384      936/io.info.0
            udp        0      0 0.0.0.0:52591           0.0.0.0:*                           1001       13893      538/iobroker.js-con
            udp        0      0 0.0.0.0:36931           0.0.0.0:*                           1001       14401      557/io.admin.0
            udp        0      0 0.0.0.0:37330           0.0.0.0:*                           1001       20775      1460/io.upnp.0
            udp        0      0 0.0.0.0:37612           0.0.0.0:*                           1001       14205      678/io.accuweather.
            udp        0      0 0.0.0.0:45815           0.0.0.0:*                           1001       15068      723/io.hmip.0
            udp        0      0 0.0.0.0:45883           0.0.0.0:*                           1001       17942      1385/io.parser.0
            udp        0      0 192.168.188.202:5353    0.0.0.0:*                           1001       15871      846/io.tr-064.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16448      816/io.shelly.0
            udp        0      0 0.0.0.0:47203           0.0.0.0:*                           1001       16841      891/io.divera247.0
            udp        0      0 0.0.0.0:55599           0.0.0.0:*                           1001       15576      771/io.nuki-extende
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15926      861/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15927      861/io.tuya.0
            udp        0      0 0.0.0.0:48183           0.0.0.0:*                           1001       14818      637/io.telegram.0
            udp        0      0 0.0.0.0:49008           0.0.0.0:*                           1001       17800      1351/io.javascript.
            udp6       0      0 :::111                  :::*                                0          432        1/init
            2024-06-09 16:01:35.592  - info: javascript.0 (1351) script.js.Steuerung.Automation.traccar: [DEBUG] in the past hour, the script traccar have send 0000 setState commands
            2024-06-09 16:01:35.623  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G090XG1214720TXQ [Küche] success proceed while Trigger Mode is On! 0 left...
            2024-06-09 16:01:36.547  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Incomming Changes for alexa device #G090XG1211830A5N[{"name":"Schlafzimmer","serialNumber":"G090XG1211830A5N","summary":"","creationTime":1717941689256,"domainApplicationId":"","domainApplicationName":"","cardContent":"","card":"","answerText":"","utteranceType":"ROUTINES_3P","domain":"Echo.SDK","intent":"Unknown"}]
            2024-06-09 16:01:36.556  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Ignoring History becouse no activ Command
            2024-06-09 16:01:36.589  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G090XG1214720WES [Kinderzimmer] success proceed while Trigger Mode is On! 0 left...
            2024-06-09 16:01:37.057  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: [DEBUG] Specified last Commands cleared, while trigger-mode is on...
            2024-06-09 16:01:37.486  - info: host.ioBroker instance system.adapter.trashschedule.0 started with pid 1445
            2024-06-09 16:01:37.592  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G091AA1215130RXA [Büro] success proceed while Trigger Mode is On! 0 left...
            2024-06-09 16:01:38.599  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Command on device #G2A0U20493460BF6 [Wohnzimmer] success proceed while Trigger Mode is On! 0 left...
            2024-06-09 16:01:40.780  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Incomming Changes for alexa device #G091AA1215130RXA[{"name":"Büro","serialNumber":"G091AA1215130RXA","summary":"","creationTime":1717941692235,"domainApplicationId":"","domainApplicationName":"","cardContent":"","card":"","answerText":"","utteranceType":"ROUTINES_3P","domain":"Echo.SDK","intent":"Unknown"}]
            2024-06-09 16:01:40.780  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: Ignoring History becouse no activ Command
            2024-06-09 16:01:41.282  - info: javascript.0 (1351) script.js.Ausfallbehandlung.alexaLostConnection: [DEBUG] Specified last Commands cleared, while trigger-mode is on...
            2024-06-09 16:01:41.544  - info: host.ioBroker instance system.adapter.upnp.0 started with pid 1460
            2024-06-09 16:01:43.053  - info: upnp.0 (1460) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
            2024-06-09 16:01:43.064  - info: upnp.0 (1460) Auto discover: true
            2024-06-09 16:01:45.753  - info: host.ioBroker instance system.adapter.vis-2.0 started with pid 1475
            2024-06-09 16:01:46.796  - error: vis-2.0 (1475) No license found for vis-2. Please get one on https://iobroker.net !
            2024-06-09 16:01:49.455  - info: host.ioBroker instance system.adapter.web.0 started with pid 1500
            2024-06-09 16:01:50.633  - info: web.0 (1500) starting. Version 6.2.6 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240603-3deca26fa
            2024-06-09 16:01:50.716  - info: web.0 (1500) socket.io server listening on port 8082
            2024-06-09 16:01:50.723  - info: web.0 (1500) http server listening on port 8082
            2024-06-09 16:01:50.973  - info: web.0 (1500) ==> Connected system.user.admin from ::ffff:192.168.188.158
            2024-06-09 16:01:53.525  - info: host.ioBroker instance system.adapter.fullybrowser.0 started with pid 1515
            2024-06-09 16:01:54.467  - warn: fullybrowser.0 (1515) Adapter instance settings: REST API timeout of undefined ms is not allowed, set to default of 10000ms
            2024-06-09 16:01:58.066  - info: web.0 (1500) ==> Connected system.user.admin from ::ffff:192.168.188.158
                                    v.2024-05-22
                       Chassis: vm
                Virtualization: kvm
            Installation:           kvm
            Kernel:                 x86_64
            Userland:               64 bit
            User-ID:                1000
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            MEMORY:
            Mem:             13G        2.4G         10G        0.0K        787M         11G
            Swap:           2.0G          0B        2.0G
            Total:           16G        2.4G         12G
                                    admin                   6.17.14
            Objects type: jsonl
            States  type: jsonl
            Objects:                15919
            States:                 13462
            23M     /opt/iobroker/iobroker-data/objects.jsonl
            3.0M    /opt/iobroker/iobroker-data/states.jsonl
              @tomtaz
              ├── canvas@2.11.2
              ├── echarts@5.4.3
              ├── moment@2.29.4
              tomtaz
              Wo diese herkommen, kann ich Dir beim besten willen nicht sagen. Echarts nutze ich aber und den ring-client-api auch für die Ring-Cams
              @tomtaz
              tomtaz@ioBroker:/opt/iobroker$ npm install iobroker.admin@6.17.14
              npm warn While resolving: @iobroker/adapter-core@3.1.4
              npm warn Found: @iobroker/types@6.0.0
              npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
              npm warn   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
              npm warn     iobroker.admin@"6.17.14" from the root project
              npm warn
              npm warn Could not resolve dependency:
              npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
              npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
              npm warn   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
              npm warn
              npm warn Conflicting peer dependency: @iobroker/types@5.0.19
              npm warn node_modules/@iobroker/types
              up to date in 4s
              174 packages are looking for funding
                run `npm fund` for details
              • T tomtaz
                @tomtaz
                npm warn
                npm warn
                up to date in 4s
                @tomtaz
                Aber echarts muss so im tree stehen:
                ├── iobroker.echarts@1.7.2
                Das haste mal irgendwann irgendwie in das System gedübelt.
                Bitte nicht direkt npm-Kommandos verwenden. Das führt nämlich unter Umständen genau zu solchen schrägen Installationen.
                iob upgrade iobroker.admin@6.17.14 --omit=dev
                • T tomtaz
                  @tomtaz
                  npm warn
                  npm warn
                  up to date in 4s
                  @tomtaz
                  Neben deinem strubbeligen npm-tree kommt die Ursprungsmeldung von dem js-controller in der Alpha-Version.
                  Auf meinem System kommt nämlich:
                  echad@chet:/opt/iobroker $ iob stop
                  echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                  npm warn
                  npm warn
                  up to date in 8s
                  190 packages are looking for funding
                    @tomtaz
                    npm warn
                    npm warn
                    up to date in 8s
                    tomtaz
                    Ahh ok, Danke für die Info. Dann muss es wohl von der Alpha.
                    Bloß wie korrigiere ich nun die
                    ├── canvas@2.11.2
                    ├── echarts@5.4.3
                    ├── moment@2.29.4
                    am besten korrigiert? Per NPM deinstallieren?
                    • T tomtaz
                      ├── canvas@2.11.2
                      ├── echarts@5.4.3
                      ├── moment@2.29.4
                      Wenn sie auch per npm reingedrückt worden sind ja.
                        @tomtaz
                        @thomas-braun sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                        schon gar nicht im falschen Verzeichnis!
                        aber genau dort von wo sie auch installiert wurden
                          Diamand2k22
                          @Thomas-Braun
                          bei mir ist leider auch was strubbelig, zumindest bekomm ich den selben Fehler wie tomtaz.
                          aber npm tree schaut sauber aus!
                          pi4b@pi4b:~$ cd /opt/iobroker && npm ls
                          iobroker.inst@3.0.0 /opt/iobroker
                          ├── iobroker.adguard@0.0.8
                          ├── iobroker.admin@6.17.14
                          ├── iobroker.alarm@3.6.0
                          ├── iobroker.alexa2@3.26.5
                          ├── iobroker.alias-manager@1.2.6
                          ├── iobroker.backitup@3.0.5
                          ├── iobroker.blueconnect@0.0.5 (git+ssh://git@github.com/kopierschnitte/ioBroker        .blueconnect.git#f50eada99eaffdd21802ee0cbd5bcff4fd42469d)
                          ├── iobroker.bmw@2.8.0
                          ├── iobroker.bydhvs@1.5.0
                          ├── iobroker.daswetter@3.1.15
                          ├── iobroker.device-reminder@3.1.2
                          ├── iobroker.device-watcher@2.12.1
                          ├── iobroker.discovery@4.5.0
                          ├── iobroker.dwd@2.8.5
                          ├── iobroker.ecovacs-deebot@1.4.15
                          ├── iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBr        oker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
                          ├── iobroker.evcc@0.1.1
                          ├── iobroker.fritzdect@2.5.9
                          ├── iobroker.fronius-solarweb@0.1.0
                          ├── iobroker.fronius-wattpilot@4.6.3
                          ├── iobroker.fronius@2.1.0
                          ├── iobroker.ham@5.3.1
                          ├── iobroker.heizoel@1.0.3
                          ├── iobroker.ical@1.15.0
                          ├── iobroker.icons-mfd-svg@1.2.0
                          ├── iobroker.influxdb@4.0.2
                          ├── iobroker.intex@0.1.5
                          ├── iobroker.iot@3.3.0
                          ├── iobroker.javascript@8.6.0
                          ├── iobroker.js-controller@5.0.19
                          ├── iobroker.lovelace@4.1.10
                          ├── iobroker.midea@0.0.7
                          ├── iobroker.modbus@6.2.3
                          ├── iobroker.node-red@5.2.1
                          ├── iobroker.oilfox@4.3.0
                          ├── iobroker.opendtu@1.0.1
                          ├── iobroker.parser@2.1.0
                          ├── iobroker.ping@1.6.2
                          ├── iobroker.pushover@3.0.6
                          ├── iobroker.rpi2@1.3.2
                          ├── iobroker.shelly@7.0.0
                          ├── iobroker.simple-api@2.8.0
                          ├── iobroker.socketio@6.7.0
                          ├── iobroker.synology@3.1.0
                          ├── iobroker.telegram@3.5.3
                          ├── iobroker.tibberlink@3.3.1
                          ├── iobroker.tr-064@4.3.0
                          ├── iobroker.trashschedule@3.3.0
                          ├── iobroker.tuya@3.15.0
                          ├── iobroker.vis-inventwo@3.3.4
                          ├── iobroker.vis-materialdesign@0.5.9
                          ├── iobroker.vis@1.5.6
                          ├── iobroker.web@6.2.6
                          ├── iobroker.whatsapp-cmb@0.3.0
                          ├── iobroker.ws@2.6.1
                          └── iobroker.zigbee2mqtt@2.13.6
                          • D Diamand2k22
                            @Thomas-Braun
                            @diamand2k22
                            Der strubbelige npm tree ist ja auch nur eine Begleiterscheinung.
                            Was genau wird dir in dein LogFile geschrieben?
                              @diamand2k22
                              Diamand2k22
                              $ iobroker add vis-icontwo auto --host pi4b --debug
                              NPM version: 10.7.0
                              Installing iobroker.vis-icontwo@1.5.0... (System call)
                              npm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                              npm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                              Thomas BraunT haus-automatisierungH 2 Antworten Letzte Antwort
                              • D Diamand2k22
                                NPM version: 10.7.0
                                @diamand2k22
                                Installier den admin nochmal frisch drüber.
                                  @diamand2k22
                                  Diamand2k22
                                  du meinst so oder
                                  • D Diamand2k22
                                    du meinst so oder
                                    @diamand2k22
                                    Ganz genau.
                                    • D Diamand2k22
                                      NPM version: 10.7.0
                                      haus-automatisierungH Offline
                                      @diamand2k22 sagte in iobroker npm warn ERESOLVE overriding peer dependencynpm:
                                      Das liegt an der Definition der dependencies im admin (@iobroker/types sollte eine devDependency sein). PR wurde schon erstellt: https://github.com/ioBroker/ioBroker.admin/pull/2507
                                      📚 Meine Dokumentation
                                        Diamand2k22
                                        @haus-automatisierung
                                        passt, danke für den Hinweis 👍
