  4. Homematic IP Cloud Access Point Adapter
    6.3k
homematic cloud adapterhomematic ip cloud adapter
430 Beiträge 101 Kommentatoren 130.0k Aufrufe 89 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @greenhorn
    Greenhorn
    #334
    @ofbeqnpolkkl6mby5e13 Ah, ok, dachte da wird dann wieder 1.22 installiert. Hat geklappt, danke.
    • smarter-frankeS Offline
      smarter-franke
      #335
      So danke an das Dev Team, nun gibt es die Version 1.23.1 als Beta Release. Hat es damit schon jemand getestet?
      Der TOKEN Button funktioniert nun, auch ohne PIN 👍
      ABER, einen Token bekomme ich leider nicht zurück... läuft auf Fehler. Kann es bitte mal jemand anders versuchen, ob ich mich irgendwie doof anstelle?!
      Mein Log:
      2024-05-01 20:20:29.550  - silly: hmip.0 (846) States system redis pmessage io.messagebox.system.adapter.hmip.0/io.messagebox.system.adapter.hmip.0:{"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":22,"ack":false,"time":1714587629548},"_id":45960483}
      2024-05-01 20:20:29.551  - debug: hmip.0 (846) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":22,"ack":false,"time":1714587629548},"_id":45960483}
      2024-05-01 20:20:29.552  - silly: hmip.0 (846) sendTo "requestTokenState" to system.adapter.admin.0 from system.adapter.hmip.0
      2024-05-01 20:20:32.597  - silly: hmip.0 (846) States system redis pmessage io.messagebox.system.adapter.hmip.0/io.messagebox.system.adapter.hmip.0:{"command":"requestToken","message":{"accessPointSgtin":"3014-F711-A000-XXXX-YYYY-ZZZZ","clientId":"","pin":"","deviceName":"iobroker"},"from":"system.adapter.admin.0","callback":{"message":{"accessPointSgtin":"3014-F711-A000-XXXX-YYYY-ZZZZ","clientId":"","pin":"","deviceName":"iobroker"},"id":23,"ack":false,"time":1714587632595},"_id":45960484}
      2024-05-01 20:20:32.599  - debug: hmip.0 (846) message received - {"command":"requestToken","message":{"accessPointSgtin":"3014-F711-A000-XXXX-YYYY-ZZZZ","clientId":"","pin":"","deviceName":"iobroker"},"from":"system.adapter.admin.0","callback":{"message":{"accessPointSgtin":"3014-F711-A000-XXXX-YYYY-ZZZZ","clientId":"","pin":"","deviceName":"iobroker"},"id":23,"ack":false,"time":1714587632595},"_id":45960484}
      2024-05-01 20:20:32.599  - silly: hmip.0 (846) sendTo "requestToken" to system.adapter.admin.0 from system.adapter.hmip.0
      2024-05-01 20:20:32.600  - info: hmip.0 (846) started token request
      2024-05-01 20:20:32.676  - info: hmip.0 (846) auth step 1
      2024-05-01 20:20:32.772  - warn: hmip.0 (846) Request error data: [object Object]
      2024-05-01 20:20:32.772  - warn: hmip.0 (846) Request error status: 403
      2024-05-01 20:20:32.773  - error: hmip.0 (846) error requesting token: Error: error
      2024-05-01 20:20:32.913  - silly: hmip.0 (846) States system redis pmessage io.messagebox.system.adapter.hmip.0/io.messagebox.system.adapter.hmip.0:{"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":24,"ack":false,"time":1714587632911},"_id":45960485}
      2024-05-01 20:20:32.915  - debug: hmip.0 (846) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":24,"ack":false,"time":1714587632911},"_id":45960485}
      2024-05-01 20:20:32.915  - silly: hmip.0 (846) sendTo "requestTokenState" to system.adapter.admin.0 from system.adapter.hmip.0
      Mathias MeisterM 1 Antwort Letzte Antwort
      • smarter-frankeS smarter-franke
        Mein Log:
        Mathias MeisterM Offline
        Mathias Meister
        #336
        @smarter-franke
        Bei mir funktioniert es auch nicht mit der 1.23.1. Ich kann kein Token erzeugen.
        Ich finde immer wieder den Eintrag:
        "Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason"
        O 1 Antwort Letzte Antwort
        • Mathias MeisterM Mathias Meister
          @smarter-franke
          O Abwesend
          O Abwesend
          #337
          @mathias-meister & @smarter-franke
          Problem ist bekannt und wird im entsprechenden Github-Issue bereits behandelt.
            sewox
            #338
            Gibt es hier bereits ein Update zu?
            Warte auch seit März auf die Lösung :-/
            wolfi913W 1 Antwort Letzte Antwort
            • S sewox
              wolfi913W Online
              wolfi913W Online
              wolfi913
              #339
              @sewox sagte in Homematic IP Cloud Access Point Adapter:
              Da ist heute scheinbar ein Update gekommen
              Changelog
              1.23.2 (2024-05-24)
              (bluefox) Allowed calling token request without PIN
              (bluefox) Corrected the token request
              • wolfi913W wolfi913
                Changelog
                1.23.2 (2024-05-24)
                O Abwesend
                O Abwesend
                #340
                @wolfi913
                Scheint aber weiterhin nicht zu funktionieren. Der Commit sieht für mich auch nicht so aus, als ob er das Problem lösen könnte. Aber ich habe auch keine Ahnung von Javascript...
                  @wolfi913
                  wolfi913W Online
                  wolfi913W Online
                  wolfi913
                  #341
                  @ofbeqnpolkkl6mby5e13 sagte in Homematic IP Cloud Access Point Adapter:
                  @wolfi913
                  Hab dazu auch nur das Changelog gelesen. Danach hätte es ja eigentlich wieder funktionieren sollen. Hab's bei mir nicht ausprobiert. Mein AP funktioniert glücklicherweise einwandfrei.
                  Dann sind wir da schon zu Zweit 😂
                    sewox
                    #342
                    Habe die Installation manuell über die Konsole angestoßen:
                    iobroker add hmip@1.23.2
                    Installation klappt und Adapter ist in der gewünschten Version verfügbar. Bei der Token-Erstellung erscheint nicht mehr der kryptische Fehler, jedoch passiert noch nix, wenn ich den Knopf am AP drücke.
                    • S sewox
                      #343
                      @sewox Jupp, sieher auch GitHub issue dazu ... ist jetzt einen Schritt weiter ... Denke BF ist morgen wieder dran oder so :-)
                        sewox
                        #344
                        Hast du zufällig den Link für die Community? Finde zwar die Issue Threads aber keinen mit diesem Thema.
                        • S sewox
                          #345
                          @sewox https://github.com/iobroker-community-adapters/ioBroker.hmip/issues/532
                          • apollon77A apollon77
                            Mathias Meister
                            #346
                            Kurzes Update:
                            Mit der 1.23.3 habe ich beim Versuch ein Token zu erstellen aktuell ganz viele solche Fehler:
                            hmip.0
                            2024-06-25 10:03:02.138 debug message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1502,"ack":false,"time":1719302582137},"_id":51697632}
                            Ich arbeite in der IT und ich bin gerne bereit zu testen, wenn man mich dabei anleitet.
                              Kurzes Update:
                              hmip.0
                              #347
                              @mathias-meister Naja geht denn das Token erstellen? Wenn ja ... ignoriere doch diese Debug Logs :-)
                                Mathias Meister
                                #348
                                Nein, das Erstellen eines Tokens geht nicht. Die Funktion zeigt ein sich ewig drehendes Rad und es passiert nichts. Noch immer ist mein Homematic IP Cloud AP nutzlos.
                                In der App von Homatic hatte ich zuvor eine PIN eingerichtet und da funktioniert auch alles. Genau diese PIN im Adapter einzutragen, zu speichern und dann auf "Token erstellen" zu klicken, bringt nichts.
                                Manchmal sagt er, dass ich am AP den blauen Knopf zur Bestätigung drücken soll und manchmal dreht er ewig nur am Rad. In beiden Fällen komme ich zu keinem Ergebnis.
                                  #349
                                  @mathias-meister Also mit der aktuellen Version geht es fpr andere... bitte debug log aktivieren und mal posten von so einem versuch. ggf mal dir PIN weglassen
                                    Mathias Meister
                                    #350
                                    @apollon77
                                    Es geht nicht. Ich habe jetzt sogar alle Instanzen gelöscht und eine neue erstellt.
                                    Wenn eine PIN eingetragen ist und ich auf "Token erstellen" geklickt habe, soll ich die blaue Taste am AP drücken. (Wie lange übrigens?)
                                    Das Log sieht so aus:
                                    2024-06-27 21:39:51.077 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4196,"ack":false,"time":1719517191077},"_id":51700332}
                                    2024-06-27 21:40:00.015 - info: host.ioBroker instance system.adapter.dwd.0 started with pid 1342492
                                    2024-06-27 21:40:00.731 - info: dwd.0 (1342492) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                                    2024-06-27 21:40:01.673 - info: dwd.0 (1342492) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-06-27 21:40:02.185 - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-06-27 21:40:20.648 - debug: hmip.0 (1342454) message received - {"command":"requestToken","message":{"accessPointSgtin":"3014F711A00003DD89B517D3","clientId":"","pin":"###PIN entfernt###","deviceName":"iobroker"},"from":"system.adapter.admin.0","callback":{"message":{"accessPointSgtin":"3014F711A00003DD89B517D3","clientId":"","pin":"###PIN entfernt###","deviceName":"iobroker"},"id":4197,"ack":false,"time":1719517220647},"_id":51700333}
                                    2024-06-27 21:40:20.648 - info: hmip.0 (1342454) started token request
                                    2024-06-27 21:40:20.762 - info: hmip.0 (1342454) auth step 1
                                    2024-06-27 21:40:20.961 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4198,"ack":false,"time":1719517220961},"_id":51700334}
                                    2024-06-27 21:40:21.269 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4199,"ack":false,"time":1719517221269},"_id":51700335}
                                    2024-06-27 21:40:21.577 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4200,"ack":false,"time":1719517221576},"_id":51700336}
                                    2024-06-27 21:40:21.884 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4201,"ack":false,"time":1719517221883},"_id":51700337}
                                    2024-06-27 21:40:22.192 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4202,"ack":false,"time":1719517222191},"_id":51700338}
                                    2024-06-27 21:40:22.500 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4203,"ack":false,"time":1719517222498},"_id":51700339}
                                    2024-06-27 21:40:22.807 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4204,"ack":false,"time":1719517222806},"_id":51700340}
                                    2024-06-27 21:40:23.115 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4205,"ack":false,"time":1719517223115},"_id":51700341}
                                    2024-06-27 21:40:23.424 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4206,"ack":false,"time":1719517223424},"_id":51700342}
                                    2024-06-27 21:40:23.733 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4207,"ack":false,"time":1719517223732},"_id":51700343}
                                    2024-06-27 21:40:24.040 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4208,"ack":false,"time":1719517224040},"_id":51700344}
                                    2024-06-27 21:40:24.349 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4209,"ack":false,"time":1719517224349},"_id":51700345}
                                    2024-06-27 21:40:24.658 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4210,"ack":false,"time":1719517224657},"_id":51700346}
                                    2024-06-27 21:40:24.965 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4211,"ack":false,"time":1719517224964},"_id":51700347}
                                    2024-06-27 21:40:25.274 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4212,"ack":false,"time":1719517225273},"_id":51700348}
                                    2024-06-27 21:40:25.585 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4213,"ack":false,"time":1719517225584},"_id":51700349}
                                    2024-06-27 21:40:25.891 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4214,"ack":false,"time":1719517225891},"_id":51700350}
                                    2024-06-27 21:40:26.199 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4215,"ack":false,"time":1719517226198},"_id":51700351}
                                    2024-06-27 21:40:26.506 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4216,"ack":false,"time":1719517226505},"_id":51700352}
                                    2024-06-27 21:40:26.816 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4217,"ack":false,"time":1719517226815},"_id":51700353}
                                    2024-06-27 21:40:27.123 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4218,"ack":false,"time":1719517227122},"_id":51700354}
                                    2024-06-27 21:40:27.432 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4219,"ack":false,"time":1719517227431},"_id":51700355}
                                    2024-06-27 21:40:27.741 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4220,"ack":false,"time":1719517227740},"_id":51700356}
                                    2024-06-27 21:40:28.050 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4221,"ack":false,"time":1719517228049},"_id":51700357}
                                    2024-06-27 21:40:28.357 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4222,"ack":false,"time":1719517228357},"_id":51700358}
                                    2024-06-27 21:40:28.666 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4223,"ack":false,"time":1719517228665},"_id":51700359}
                                    2024-06-27 21:40:28.973 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4224,"ack":false,"time":1719517228972},"_id":51700360}
                                    2024-06-27 21:40:29.282 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4225,"ack":false,"time":1719517229282},"_id":51700361}
                                    2024-06-27 21:40:29.591 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4226,"ack":false,"time":1719517229590},"_id":51700362}
                                    2024-06-27 21:40:29.899 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4227,"ack":false,"time":1719517229898},"_id":51700363}
                                    2024-06-27 21:40:30.207 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4228,"ack":false,"time":1719517230206},"_id":51700364}
                                    2024-06-27 21:40:30.515 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4229,"ack":false,"time":1719517230515},"_id":51700365}
                                    2024-06-27 21:40:30.824 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4230,"ack":false,"time":1719517230823},"_id":51700366}
                                    2024-06-27 21:40:31.132 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4231,"ack":false,"time":1719517231131},"_id":51700367}
                                    2024-06-27 21:40:31.439 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4232,"ack":false,"time":1719517231438},"_id":51700368}
                                    2024-06-27 21:40:31.749 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4233,"ack":false,"time":1719517231748},"_id":51700369}
                                    2024-06-27 21:40:32.056 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4234,"ack":false,"time":1719517232055},"_id":51700370}
                                    2024-06-27 21:40:32.363 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4235,"ack":false,"time":1719517232362},"_id":51700371}
                                    2024-06-27 21:40:32.672 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4236,"ack":false,"time":1719517232671},"_id":51700372}
                                    2024-06-27 21:40:32.980 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4237,"ack":false,"time":1719517232979},"_id":51700373}
                                    2024-06-27 21:40:33.287 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4238,"ack":false,"time":1719517233287},"_id":51700374}
                                    2024-06-27 21:40:33.595 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4239,"ack":false,"time":1719517233594},"_id":51700375}
                                    2024-06-27 21:40:33.902 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4240,"ack":false,"time":1719517233901},"_id":51700376}
                                    2024-06-27 21:40:34.209 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4241,"ack":false,"time":1719517234209},"_id":51700377}
                                    2024-06-27 21:42:30.058 - warn: hmip.0 (1342454) Request error: [object Object]
                                    2024-06-27 21:42:30.059 - info: hmip.0 (1342454) auth step 2
                                    2024-06-27 21:45:00.014 - info: host.ioBroker instance system.adapter.dwd.0 started with pid 1342811
                                    2024-06-27 21:45:00.845 - info: dwd.0 (1342811) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                                    2024-06-27 21:45:01.928 - info: dwd.0 (1342811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-06-27 21:45:02.446 - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-06-27 21:46:53.592 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4248,"ack":false,"time":1719517613591},"_id":51700384}
                                    2024-06-27 21:46:53.913 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4249,"ack":false,"time":1719517613913},"_id":51700385}
                                    2024-06-27 21:46:54.221 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4250,"ack":false,"time":1719517614220},"_id":51700386}
                                    '### mehr als 100 ähnlicher Zeilen entfernt ###
                                    2024-06-27 21:49:59.021 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4447,"ack":false,"time":1719517799020},"_id":51700583}
                                    2024-06-27 21:50:00.019 - info: host.ioBroker instance system.adapter.dwd.0 started with pid 1343198
                                    2024-06-27 21:50:00.021 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4448,"ack":false,"time":1719517800020},"_id":51700584}
                                    2024-06-27 21:50:00.764 - info: dwd.0 (1343198) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                                    2024-06-27 21:50:01.020 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4449,"ack":false,"time":1719517801019},"_id":51700585}
                                    2024-06-27 21:50:01.679 - info: dwd.0 (1343198) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-06-27 21:50:02.021 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4450,"ack":false,"time":1719517802021},"_id":51700586}
                                    2024-06-27 21:50:02.190 - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-06-27 21:50:03.020 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4451,"ack":false,"time":1719517803019},"_id":51700587}
                                    '### 100 ähnliche Zeilen entfernt ###
                                    2024-06-27 21:53:14.013 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4754,"ack":false,"time":1719517994013},"_id":51700890}
                                    2024-06-27 21:53:15.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4755,"ack":false,"time":1719517995014},"_id":51700891}
                                    2024-06-27 21:53:16.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4756,"ack":false,"time":1719517996014},"_id":51700892}
                                    2024-06-27 21:53:17.013 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4757,"ack":false,"time":1719517997012},"_id":51700893}
                                    2024-06-27 21:53:18.013 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4758,"ack":false,"time":1719517998012},"_id":51700894}
                                    2024-06-27 21:53:19.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4759,"ack":false,"time":1719517999014},"_id":51700895}
                                    2024-06-27 21:53:20.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4760,"ack":false,"time":1719518000013},"_id":51700896}
                                    2024-06-27 21:53:21.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4761,"ack":false,"time":1719518001012},"_id":51700897}
                                    2024-06-27 21:53:22.013 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4762,"ack":false,"time":1719518002013},"_id":51700898}
                                    2024-06-27 21:53:23.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4763,"ack":false,"time":1719518003013},"_id":51700899}
                                    2024-06-27 21:53:24.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4764,"ack":false,"time":1719518004015},"_id":51700900}
                                    2024-06-27 21:53:25.009 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4765,"ack":false,"time":1719518005009},"_id":51700901}
                                    2024-06-27 21:53:26.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4766,"ack":false,"time":1719518006014},"_id":51700902}
                                    2024-06-27 21:53:27.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4767,"ack":false,"time":1719518007013},"_id":51700903}
                                    2024-06-27 21:53:28.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4768,"ack":false,"time":1719518008013},"_id":51700904}
                                    2024-06-27 21:53:29.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4769,"ack":false,"time":1719518009015},"_id":51700905}
                                    2024-06-27 21:53:30.013 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4770,"ack":false,"time":1719518010013},"_id":51700906}
                                    2024-06-27 21:53:31.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4771,"ack":false,"time":1719518011014},"_id":51700907}
                                    2024-06-27 21:53:32.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4772,"ack":false,"time":1719518012013},"_id":51700908}
                                    2024-06-27 21:53:33.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4773,"ack":false,"time":1719518013014},"_id":51700909}
                                    2024-06-27 21:53:34.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4774,"ack":false,"time":1719518014011},"_id":51700910}
                                    2024-06-27 21:53:35.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4775,"ack":false,"time":1719518015013},"_id":51700911}
                                    2024-06-27 21:53:36.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4776,"ack":false,"time":1719518016010},"_id":51700912}
                                    2024-06-27 21:53:37.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4777,"ack":false,"time":1719518017010},"_id":51700913}
                                    2024-06-27 21:53:38.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4778,"ack":false,"time":1719518018013},"_id":51700914}
                                    2024-06-27 21:53:39.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4779,"ack":false,"time":1719518019013},"_id":51700915}
                                    2024-06-27 21:53:40.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4780,"ack":false,"time":1719518020015},"_id":51700916}
                                    2024-06-27 21:53:41.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4781,"ack":false,"time":1719518021015},"_id":51700917}
                                    2024-06-27 21:53:42.008 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4782,"ack":false,"time":1719518022008},"_id":51700918}
                                    2024-06-27 21:53:43.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4783,"ack":false,"time":1719518023012},"_id":51700919}
                                    2024-06-27 21:53:44.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4784,"ack":false,"time":1719518024010},"_id":51700920}
                                    2024-06-27 21:53:45.010 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4785,"ack":false,"time":1719518025010},"_id":51700921}
                                    2024-06-27 21:53:46.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4786,"ack":false,"time":1719518026014},"_id":51700922}
                                    2024-06-27 21:53:47.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4787,"ack":false,"time":1719518027014},"_id":51700923}
                                    2024-06-27 21:53:48.016 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4788,"ack":false,"time":1719518028015},"_id":51700924}
                                    2024-06-27 21:53:49.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4789,"ack":false,"time":1719518029011},"_id":51700925}
                                    2024-06-27 21:53:50.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4790,"ack":false,"time":1719518030010},"_id":51700926}
                                    2024-06-27 21:53:51.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4791,"ack":false,"time":1719518031011},"_id":51700927}
                                    2024-06-27 21:53:52.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4792,"ack":false,"time":1719518032011},"_id":51700928}
                                    2024-06-27 21:53:53.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4793,"ack":false,"time":1719518033013},"_id":51700929}
                                    2024-06-27 21:53:54.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4794,"ack":false,"time":1719518034011},"_id":51700930}
                                    2024-06-27 21:53:54.343 - info: mystrom.0 (1642) Set update interval for 083AF2A65ED8 to 60
                                    2024-06-27 21:53:54.396 - info: mystrom.0 (1642) Set update interval for 9C9C1FE35248 to 60
                                    2024-06-27 21:53:55.010 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4795,"ack":false,"time":1719518035009},"_id":51700931}
                                    2024-06-27 21:53:56.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4796,"ack":false,"time":1719518036010},"_id":51700932}
                                    2024-06-27 21:53:57.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4797,"ack":false,"time":1719518037014},"_id":51700933}
                                    2024-06-27 21:53:58.019 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4798,"ack":false,"time":1719518038015},"_id":51700934}
                                    2024-06-27 21:53:59.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4799,"ack":false,"time":1719518039014},"_id":51700935}
                                    2024-06-27 21:54:00.015 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4800,"ack":false,"time":1719518040014},"_id":51700936}
                                    2024-06-27 21:54:01.012 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4801,"ack":false,"time":1719518041011},"_id":51700937}
                                    2024-06-27 21:54:02.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4802,"ack":false,"time":1719518042013},"_id":51700938}
                                    2024-06-27 21:54:03.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4803,"ack":false,"time":1719518043013},"_id":51700939}
                                    2024-06-27 21:54:04.014 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4804,"ack":false,"time":1719518044013},"_id":51700940}
                                    2024-06-27 21:54:05.013 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4805,"ack":false,"time":1719518045012},"_id":51700941}
                                    '### viele ähnliche Zeilen entfernt###
                                    2024-06-27 21:55:00.861 - info: dwd.0 (1343538) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                                    2024-06-27 21:55:00.970 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4862,"ack":false,"time":1719518100970},"_id":51700998}
                                    2024-06-27 21:55:01.283 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4863,"ack":false,"time":1719518101277},"_id":51700999}
                                    2024-06-27 21:55:01.590 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4864,"ack":false,"time":1719518101589},"_id":51701000}
                                    2024-06-27 21:55:01.896 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4865,"ack":false,"time":1719518101896},"_id":51701001}
                                    2024-06-27 21:55:01.930 - info: dwd.0 (1343538) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-06-27 21:55:02.204 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4866,"ack":false,"time":1719518102203},"_id":51701002}
                                    2024-06-27 21:55:02.441 - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-06-27 21:55:02.510 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4867,"ack":false,"time":1719518102509},"_id":51701003}
                                    2024-06-27 21:55:03.010 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4868,"ack":false,"time":1719518103009},"_id":51701004}
                                    2024-06-27 21:55:04.009 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4869,"ack":false,"time":1719518104009},"_id":51701005}
                                    2024-06-27 21:55:05.008 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4870,"ack":false,"time":1719518105007},"_id":51701006}
                                    2024-06-27 21:55:06.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4871,"ack":false,"time":1719518106011},"_id":51701007}
                                    2024-06-27 21:55:07.011 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4872,"ack":false,"time":1719518107010},"_id":51701008}
                                    2024-06-27 21:55:08.009 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4873,"ack":false,"time":1719518108009},"_id":51701009}
                                    2024-06-27 21:55:09.007 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4874,"ack":false,"time":1719518109006},"_id":51701010}
                                    2024-06-27 21:55:10.007 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4875,"ack":false,"time":1719518110006},"_id":51701011}
                                    2024-06-27 21:55:11.007 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4876,"ack":false,"time":1719518111006},"_id":51701012}
                                    2024-06-27 21:55:12.008 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4877,"ack":false,"time":1719518112008},"_id":51701013}
                                    2024-06-27 21:55:13.010 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4878,"ack":false,"time":1719518113009},"_id":51701014}
                                    2024-06-27 21:55:14.007 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4879,"ack":false,"time":1719518114006},"_id":51701015}
                                    2024-06-27 21:55:15.060 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4880,"ack":false,"time":1719518115060},"_id":51701016}
                                    2024-06-27 21:55:16.006 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4881,"ack":false,"time":1719518116006},"_id":51701017}
                                    2024-06-27 21:55:17.007 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4882,"ack":false,"time":1719518117006},"_id":51701018}
                                    2024-06-27 21:55:18.008 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4883,"ack":false,"time":1719518118007},"_id":51701019}
                                    2024-06-27 21:55:19.009 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4884,"ack":false,"time":1719518119008},"_id":51701020}
                                    2024-06-27 21:55:20.006 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4885,"ack":false,"time":1719518120005},"_id":51701021}
                                    2024-06-27 21:55:21.008 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4886,"ack":false,"time":1719518121007},"_id":51701022}
                                    2024-06-27 21:55:22.006 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4887,"ack":false,"time":1719518122006},"_id":51701023}
                                    2024-06-27 21:55:23.008 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4888,"ack":false,"time":1719518123007},"_id":51701024}
                                    2024-06-27 21:55:23.316 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4889,"ack":false,"time":1719518123315},"_id":51701025}
                                    2024-06-27 21:55:23.624 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4890,"ack":false,"time":1719518123623},"_id":51701026}
                                    2024-06-27 21:55:23.931 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4891,"ack":false,"time":1719518123930},"_id":51701027}
                                    2024-06-27 21:55:24.239 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4892,"ack":false,"time":1719518124238},"_id":51701028}
                                    2024-06-27 21:55:24.546 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4893,"ack":false,"time":1719518124545},"_id":51701029}
                                    2024-06-27 21:55:24.853 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4894,"ack":false,"time":1719518124852},"_id":51701030}
                                    2024-06-27 21:55:25.160 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4895,"ack":false,"time":1719518125160},"_id":51701031}
                                    2024-06-27 21:55:25.469 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4896,"ack":false,"time":1719518125469},"_id":51701032}
                                    2024-06-27 21:55:25.775 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4897,"ack":false,"time":1719518125775},"_id":51701033}
                                    2024-06-27 21:55:26.080 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4898,"ack":false,"time":1719518126080},"_id":51701034}
                                    2024-06-27 21:55:26.386 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4899,"ack":false,"time":1719518126386},"_id":51701035}
                                    2024-06-27 21:55:26.692 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4900,"ack":false,"time":1719518126692},"_id":51701036}
                                    2024-06-27 21:55:26.999 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4901,"ack":false,"time":1719518126999},"_id":51701037}
                                    2024-06-27 21:55:27.306 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4902,"ack":false,"time":1719518127305},"_id":51701038}
                                    2024-06-27 21:55:27.615 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4903,"ack":false,"time":1719518127615},"_id":51701039}
                                    2024-06-27 21:55:27.922 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4904,"ack":false,"time":1719518127921},"_id":51701040}
                                    2024-06-27 21:55:28.230 - debug: hmip.0 (1342454) message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4905,"ack":false,"time":1719518128229},"_id":51701041}
                                    apollon77A O 2 Antworten Letzte Antwort
                                      @apollon77
                                      #351
                                      @mathias-meister Lass mal die PIN weg bitte
                                        @apollon77
                                        O Abwesend
                                        O Abwesend
                                        #352
                                        @mathias-meister sagte in Homematic IP Cloud Access Point Adapter:
                                        Einmal kurz drücken reicht aus.
                                        • Mathias MeisterM Offline
                                          Mathias Meister
                                          #353
                                          @apollon77
                                          Wenn ich es OHNE Pin versuche, dreht sich in der Instanz nur das Rad und es wird angezeigt "Token-Erstellung gestartet...", aber es kommt nie die Meldung, dass ich jetzt die blaue Taste am Gerät (HAP) drücken soll.
                                          Ich mache das so:
                                          1. Instanz/Adapter stoppen.
                                          2. SGTIN eintragen bzw. überprüfen, ob alle Daten von den vorherigen Versuchen noch stimmen.
                                          3. Abspeichern
                                          4. Klick auf "Token erstellen"
                                          5. "Token-Erstellung gestartet steht da und er dreht für ewig am Rad.
                                          Und so sieht das Log dazu aus:
                                          hmip.0
                                          2024-07-04 15:22:55.679	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7303,"ack":false,"time":1720099375679},"_id":51703446}
                                          hmip.0
                                          2024-07-04 15:22:55.371	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7302,"ack":false,"time":1720099375370},"_id":51703445}
                                          hmip.0
                                          2024-07-04 15:22:54.767	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7301,"ack":false,"time":1720099374766},"_id":51703444}
                                          hmip.0
                                          2024-07-04 15:22:54.461	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7300,"ack":false,"time":1720099374460},"_id":51703443}
                                          hmip.0
                                          2024-07-04 15:22:54.155	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7299,"ack":false,"time":1720099374154},"_id":51703442}
                                          hmip.0
                                          2024-07-04 15:22:53.848	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7298,"ack":false,"time":1720099373848},"_id":51703441}
                                          hmip.0
                                          2024-07-04 15:22:53.539	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7297,"ack":false,"time":1720099373539},"_id":51703440}
                                          hmip.0
                                          2024-07-04 15:22:53.233	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7296,"ack":false,"time":1720099373232},"_id":51703439}
                                          hmip.0
                                          2024-07-04 15:22:52.924	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7295,"ack":false,"time":1720099372924},"_id":51703438}
                                          hmip.0
                                          2024-07-04 15:22:52.617	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7294,"ack":false,"time":1720099372616},"_id":51703437}
                                          hmip.0
                                          2024-07-04 15:22:52.310	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7293,"ack":false,"time":1720099372309},"_id":51703436}
                                          hmip.0
                                          2024-07-04 15:22:52.003	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7292,"ack":false,"time":1720099372002},"_id":51703435}
                                          hmip.0
                                          2024-07-04 15:22:51.694	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7291,"ack":false,"time":1720099371693},"_id":51703434}
                                          hmip.0
                                          2024-07-04 15:22:51.386	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7290,"ack":false,"time":1720099371385},"_id":51703433}
                                          hmip.0
                                          2024-07-04 15:22:51.078	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7289,"ack":false,"time":1720099371077},"_id":51703432}
                                          hmip.0
                                          2024-07-04 15:22:50.771	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7288,"ack":false,"time":1720099370770},"_id":51703431}
                                          hmip.0
                                          2024-07-04 15:22:50.462	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7287,"ack":false,"time":1720099370462},"_id":51703430}
                                          hmip.0
                                          2024-07-04 15:22:50.156	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7286,"ack":false,"time":1720099370156},"_id":51703429}
                                          hmip.0
                                          2024-07-04 15:22:49.847	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7285,"ack":false,"time":1720099369846},"_id":51703428}
                                          hmip.0
                                          2024-07-04 15:22:49.540	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7284,"ack":false,"time":1720099369540},"_id":51703427}
                                          hmip.0
                                          2024-07-04 15:22:49.235	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7283,"ack":false,"time":1720099369234},"_id":51703426}
                                          hmip.0
                                          2024-07-04 15:22:48.929	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7282,"ack":false,"time":1720099368928},"_id":51703425}
                                          hmip.0
                                          2024-07-04 15:22:48.623	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7281,"ack":false,"time":1720099368623},"_id":51703424}
                                          hmip.0
                                          2024-07-04 15:22:48.316	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7280,"ack":false,"time":1720099368316},"_id":51703423}
                                          hmip.0
                                          2024-07-04 15:22:48.009	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7279,"ack":false,"time":1720099368009},"_id":51703422}
                                          hmip.0
                                          2024-07-04 15:22:47.704	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7278,"ack":false,"time":1720099367703},"_id":51703421}
                                          hmip.0
                                          2024-07-04 15:22:47.395	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7277,"ack":false,"time":1720099367394},"_id":51703420}
                                          hmip.0
                                          2024-07-04 15:22:47.088	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7276,"ack":false,"time":1720099367087},"_id":51703419}
                                          hmip.0
                                          2024-07-04 15:22:46.779	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7275,"ack":false,"time":1720099366778},"_id":51703418}
                                          hmip.0
                                          2024-07-04 15:22:46.472	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7274,"ack":false,"time":1720099366471},"_id":51703417}
                                          hmip.0
                                          2024-07-04 15:22:46.163	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7273,"ack":false,"time":1720099366163},"_id":51703416}
                                          hmip.0
                                          2024-07-04 15:22:45.857	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7272,"ack":false,"time":1720099365856},"_id":51703415}
                                          hmip.0
                                          2024-07-04 15:22:45.548	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7271,"ack":false,"time":1720099365547},"_id":51703414}
                                          hmip.0
                                          2024-07-04 15:22:45.238	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7270,"ack":false,"time":1720099365237},"_id":51703413}
                                          hmip.0
                                          2024-07-04 15:22:44.928	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7269,"ack":false,"time":1720099364927},"_id":51703412}
                                          hmip.0
                                          2024-07-04 15:22:44.621	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7268,"ack":false,"time":1720099364620},"_id":51703411}
                                          hmip.0
                                          2024-07-04 15:22:44.312	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7267,"ack":false,"time":1720099364311},"_id":51703410}
                                          hmip.0
                                          2024-07-04 15:22:44.006	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7266,"ack":false,"time":1720099364006},"_id":51703409}
                                          hmip.0
                                          2024-07-04 15:22:43.692	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7265,"ack":false,"time":1720099363692},"_id":51703408}
                                          hmip.0
                                          2024-07-04 15:22:43.385	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7264,"ack":false,"time":1720099363384},"_id":51703407}
                                          hmip.0
                                          2024-07-04 15:22:43.078	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7263,"ack":false,"time":1720099363077},"_id":51703406}
                                          hmip.0
                                          2024-07-04 15:22:42.773	debug	message received - {"command":"requestTokenState","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":7262,"ack":false,"time":1720099362772},"_id":51703405}
                                          hmip.0
                                          2024-07-04 15:22:42.571	info	auth step 1
                                          hmip.0
                                          2024-07-04 15:22:42.467	info	started token request
                                          hmip.0
                                          2024-07-04 15:22:42.466	debug	message received - {"command":"requestToken","message":{"accessPointSgtin":"3014F711A00003DD89B517D3","clientId":"","pin":"","deviceName":"iobroker"},"from":"system.adapter.admin.0","callback":{"message":{"accessPointSgtin":"3014F711A00003DD89B517D3","clientId":"","pin":"","deviceName":"iobroker"},"id":7261,"ack":false,"time":1720099362465},"_id":51703404}
                                          hmip.0
                                          2024-07-04 15:22:41.864	info	token not yet created
                                          hmip.0
                                          2024-07-04 15:22:41.864	debug	ready
                                          hmip.0
                                          2024-07-04 15:22:41.858	info	starting. Version 1.23.3 in /opt/iobroker/node_modules/iobroker.hmip, node: v18.20.2, js-controller: 5.0.19
                                          hmip.0
                                          2024-07-04 15:22:41.685	debug	Plugin sentry Initialize Plugin (enabled=true)
                                          hmip.0
                                          2024-07-04 15:22:41.670	debug	States connected to redis: 127.0.0.1:9000
                                          hmip.0
                                          2024-07-04 15:22:41.657	debug	States create User PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:41.657	debug	States create System PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:41.643	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                          hmip.0
                                          2024-07-04 15:22:41.628	debug	Objects connected to redis: 127.0.0.1:9001
                                          hmip.0
                                          2024-07-04 15:22:41.626	debug	Objects client initialize lua scripts
                                          hmip.0
                                          2024-07-04 15:22:41.601	debug	Objects create User PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:41.601	debug	Objects create System PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:41.600	debug	Objects client ready ... initialize now
                                          hmip.0
                                          2024-07-04 15:22:41.581	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          hmip.0
                                          2024-07-04 15:22:38.590	info	terminating
                                          hmip.0
                                          2024-07-04 15:22:38.089	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          hmip.0
                                          2024-07-04 15:22:38.088	debug	Plugin sentry destroyed
                                          hmip.0
                                          2024-07-04 15:22:38.088	info	terminating
                                          hmip.0
                                          2024-07-04 15:22:38.088	info	cleaned everything up...
                                          hmip.0
                                          2024-07-04 15:22:38.087	info	Got terminate signal TERMINATE_YOURSELF
                                          hmip.0
                                          2024-07-04 15:22:38.060	info	starting. Version 1.23.3 in /opt/iobroker/node_modules/iobroker.hmip, node: v18.20.2, js-controller: 5.0.19
                                          hmip.0
                                          2024-07-04 15:22:37.896	debug	Plugin sentry Initialize Plugin (enabled=true)
                                          hmip.0
                                          2024-07-04 15:22:37.873	debug	States connected to redis: 127.0.0.1:9000
                                          hmip.0
                                          2024-07-04 15:22:37.862	debug	States create User PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:37.861	debug	States create System PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:37.855	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                          hmip.0
                                          2024-07-04 15:22:37.841	debug	Objects connected to redis: 127.0.0.1:9001
                                          hmip.0
                                          2024-07-04 15:22:37.839	debug	Objects client initialize lua scripts
                                          hmip.0
                                          2024-07-04 15:22:37.816	debug	Objects create User PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:37.815	debug	Objects create System PubSub Client
                                          hmip.0
                                          2024-07-04 15:22:37.815	debug	Objects client ready ... initialize now
                                          hmip.0
                                          2024-07-04 15:22:37.795	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          hmip.0
                                          2024-07-04 15:22:13.081	info	terminating
                                          hmip.0
                                          2024-07-04 15:22:12.580	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          hmip.0
                                          2024-07-04 15:22:12.580	debug	Plugin sentry destroyed
                                          hmip.0
                                          2024-07-04 15:22:12.580	info	terminating
                                          hmip.0
                                          2024-07-04 15:22:12.580	info	cleaned everything up...
                                          hmip.0
                                          2024-07-04 15:22:12.579	info	Got terminate signal TERMINATE_YOURSELF
                                          hmip.0
                                          2024-07-04 15:20:08.267	info	token not yet created
                                          hmip.0
                                          2024-07-04 15:20:08.267	debug	ready
                                          hmip.0
                                          2024-07-04 15:20:08.261	info	starting. Version 1.23.3 in /opt/iobroker/node_modules/iobroker.hmip, node: v18.20.2, js-controller: 5.0.19
