  4. ioBroker admin nicht mehr erreichbar
    1.0k
    6.1k
12 Beiträge 5 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • haselchenH haselchen
    @blindyblinds
    Im Terminal eingeben
    iobroker start admin.0
    Edit1:
    Wenns irgendwie möglich ist
    iob diag
    posten.
    BlindyBlinds
    schrieb am zuletzt editiert von BlindyBlinds
    @haselchen Super, das ging schnell mit der Antwort
    2024-03-24 17:12:44.389  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
    2024-03-24 17:13:14.455  - info: host.fujiki instance system.adapter.admin.0 started with pid 8171
    2024-03-24 17:13:15.329  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
    2024-03-24 17:13:15.330  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:                           ^
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2024-03-24 17:13:15.331  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2024-03-24 17:13:15.332  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:23:47
    2024-03-24 17:13:15.332  - error: host.fujiki Caught by controller[0]: Node.js v18.17.1
    2024-03-24 17:13:15.332  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Ergebnis leider gleich (Zeit ist in UTC, also -1 )
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: fujiki
           Icon name: computer-desktop
             Chassis: desktop
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 5.15.0-101-generic
        Architecture: x86-64
     Hardware Vendor: FUJITSU
      Hardware Model: FUTRO S740
    model name	: Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     17:16:28 up  1:54,  2 users,  load average: 0.66, 0.41, 0.32
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2024-03-24 17:16:29 UTC
               Universal time: Sun 2024-03-24 17:16:29 UTC
                     RTC time: Sun 2024-03-24 17:16:29
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: n/a
              RTC in local TZ: no
    *** User and Groups ***
    iUser
    /home/iUser
    iUser adm cdrom sudo dip plugdev lxd
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.7G        1.1G        899M        5.0M        1.7G        2.3G
    Swap:            16G          0B         16G
    Total:           20G        1.1G         17G
             3681 M total memory
             1103 M used memory
              530 M active memory
             1905 M inactive memory
              899 M free memory
              111 M buffer memory
             1566 M swap cache
            16383 M total swap
                0 M used swap
            16383 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem            Type   Size  Used Avail Use% Mounted on
    tmpfs                 tmpfs  369M  1.7M  367M   1% /run
    /dev/sda2             ext4    49G   24G   23G  52% /
    tmpfs                 tmpfs  1.8G  736K  1.8G   1% /dev/shm
    tmpfs                 tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda1             vfat   1.1G  6.1M  1.1G   1% /boot/efi
    tmpfs                 tmpfs  369M  4.0K  369M   1% /run/user/1000
    /dev/mapper/cryptdisk ext4   153G   82G   64G  56% /mnt/cdisk
    [Sun Mar 24 15:21:39 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Mar 24 15:21:42 2024] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    [Sun Mar 24 15:25:13 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                FSTYPE   OPTIONS
    /                   /dev/sda2             ext4     rw,relatime
    |-/snap/core20/2182 /dev/loop2            squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2105 /dev/loop3            squashfs ro,nodev,relatime,errors=continue
    |-/snap/core18/2812 /dev/loop1            squashfs ro,nodev,relatime,errors=continue
    |-/snap/core18/2796 /dev/loop0            squashfs ro,nodev,relatime,errors=continue
    |-/snap/core22/1033 /dev/loop4            squashfs ro,nodev,relatime,errors=continue
    |-/snap/core22/1122 /dev/loop5            squashfs ro,nodev,relatime,errors=continue
    |-/snap/docker/2915 /dev/loop7            squashfs ro,nodev,relatime,errors=continue
    |-/snap/docker/2904 /dev/loop6            squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/27037   /dev/loop8            squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20671 /dev/loop10           squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/27428   /dev/loop9            squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/21184 /dev/loop11           squashfs ro,nodev,relatime,errors=continue
    |-/boot/efi         /dev/sda1             vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    `-/mnt/cdisk        /dev/mapper/cryptdisk ext4     rw,relatime
    /var:
    3.3G	/var/
    2.1G	/var/lib
    1.5G	/var/lib/snapd
    901M	/var/lib/snapd/snaps
    751M	/var/log
    Archived and active journals take up 744.0M in the file system.
    /opt/iobroker/backups:
    35M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    175M	/opt/iobroker/iobroker-data/
    132M	/opt/iobroker/iobroker-data/files
    57M	/opt/iobroker/iobroker-data/files/javascript.admin
    38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    37M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.17.1
    /usr/bin/node 		v18.17.1
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    /usr/bin/corepack 	0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3.4 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.13.16
    javascript: 	7.8.0
    Adapters from github: 	1
    Adapter State
      system.adapter.admin.0                  : admin                 : fujiki                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : fujiki                                   -  enabled
    + system.adapter.discovery.0              : discovery             : fujiki                                   -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : fujiki                                   -  enabled
    + system.adapter.mediola-gateway.0        : mediola-gateway       : fujiki                                   -  enabled
    + system.adapter.simple-api.0             : simple-api            : fujiki                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : fujiki                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.8.1  [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 3.1.0  [Updatable]
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mediola-gateway": 1.1.0  , installed 1.0.1  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 6.5.5  [Updatable]
    Adapter    "web"          : 6.2.3    , installed 6.1.2  [Updatable]
    Adapter    "ws"           : 2.5.10   , installed 2.5.5  [Updatable]
    Objects and States
    Objects: 	274
    States: 	179
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:5 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:6 https://deb.torproject.org/torproject.org jammy InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:5239            0.0.0.0:*               LISTEN      998        25851      716/python3
    tcp        0      0 0.0.0.0:5240            0.0.0.0:*               LISTEN      0          22398      840/nginx: master p
    tcp        0      0 127.0.0.1:32000         0.0.0.0:*               LISTEN      1001       28491      2125/java
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      997        25793      782/pihole-FTL
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      997        25787      782/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25720      793/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1004       73258      7728/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1004       73265      7728/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21391      1/init
    tcp        0      0 0.0.0.0:90              0.0.0.0:*               LISTEN      0          22437      847/lighttpd
    tcp        0      0 0.0.0.0:51821           0.0.0.0:*               LISTEN      0          29046      1409/docker-proxy
    tcp6       0      0 :::7654                 :::*                    LISTEN      1001       29678      2125/java
    tcp6       0      0 ::1:4711                :::*                    LISTEN      997        25794      782/pihole-FTL
    tcp6       0      0 :::5239                 :::*                    LISTEN      998        25857      716/python3
    tcp6       0      0 :::8087                 :::*                    LISTEN      1004       69595      7804/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1004       70561      7788/io.web.0
    tcp6       0      0 127.0.0.1:7659          :::*                    LISTEN      1001       30284      2125/java
    tcp6       0      0 127.0.0.1:7658          :::*                    LISTEN      1001       28672      2125/java
    tcp6       0      0 127.0.0.1:7660          :::*                    LISTEN      1001       32769      2125/java
    tcp6       0      0 172.17.0.1:7652         :::*                    LISTEN      1001       30217      2125/java
    tcp6       0      0 :::4445                 :::*                    LISTEN      1001       31799      2125/java
    tcp6       0      0 :::4444                 :::*                    LISTEN      1001       30882      2125/java
    tcp6       0      0 127.0.0.1:6668          :::*                    LISTEN      1001       30880      2125/java
    tcp6       0      0 :::53                   :::*                    LISTEN      997        25789      782/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          25722      793/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          384        1/init
    tcp6       0      0 :::90                   :::*                    LISTEN      0          22436      847/lighttpd
    tcp6       0      0 ::1:7657                :::*                    LISTEN      1001       30830      2125/java
    tcp6       0      0 192.168.0.97:7657       :::*                    LISTEN      1001       30831      2125/java
    tcp6       0      0 192.168.0.97:7652       :::*                    LISTEN      1001       30218      2125/java
    tcp6       0      0 fdba:fa8:c75f:0:4e:7652 :::*                    LISTEN      1001       30219      2125/java
    tcp6       0      0 :::25418                :::*                    LISTEN      1001       28593      2125/java
    tcp6       0      0 :::51821                :::*                    LISTEN      0          27516      1415/docker-proxy
    udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1004       73390      7819/io.mediola-gat
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           997        25786      782/pihole-FTL
    udp        0      0 192.168.0.97:68         0.0.0.0:*                           101        20116      685/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          21392      1/init
    udp        0      0 172.17.0.1:123          0.0.0.0:*                           115        27643      802/ntpd
    udp        0      0 192.168.0.97:123        0.0.0.0:*                           0          20290      802/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          20288      802/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          20284      802/ntpd
    udp        0      0 0.0.0.0:39319           0.0.0.0:*                           1004       73391      7819/io.mediola-gat
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          29055      1428/docker-proxy
    udp6       0      0 :::1900                 :::*                                1001       30225      2125/java
    udp6       0      0 :::1900                 :::*                                1001       30222      2125/java
    udp6       0      0 :::1900                 :::*                                1001       30750      2125/java
    udp6       0      0 :::53                   :::*                                997        25788      782/pihole-FTL
    udp6       0      0 :::111                  :::*                                0          21393      1/init
    udp6       0      0 fe80::f4d6:b7ff:fec:123 :::*                                115        29698      802/ntpd
    udp6       0      0 fe80::42:93ff:fee6::123 :::*                                115        27648      802/ntpd
    udp6       0      0 fe80::4e52:62ff:feb:123 :::*                                0          20296      802/ntpd
    udp6       0      0 fdba:fa8:c75f:0:4e5:123 :::*                                0          20294      802/ntpd
    udp6       0      0 ::1:123                 :::*                                0          20292      802/ntpd
    udp6       0      0 :::123                  :::*                                0          20281      802/ntpd
    udp6    1280      0 fe80::4e52:62ff:feb:546 :::*                                101        20139      685/systemd-network
    udp6       0      0 :::51820                :::*                                0          29057      1434/docker-proxy
    udp6       0      0 :::25417                :::*                                1001       30234      2125/java
    udp6       0      0 fdba:fa8:c75f:0:4e:7653 :::*                                1001       30230      2125/java
    udp6       0      0 192.168.0.97:7653       :::*                                1001       30229      2125/java
    udp6       0      0 172.17.0.1:7653         :::*                                1001       30228      2125/java
    2024-03-24 17:16:21.045  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
    2024-03-24 17:16:21.045  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:23:47
    2024-03-24 17:16:21.046  - error: host.fujiki Caught by controller[0]: Node.js v18.17.1
    2024-03-24 17:16:21.046  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-03-24 17:16:21.046  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
    2024-03-24 17:16:51.111  - info: host.fujiki instance system.adapter.admin.0 started with pid 8571
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:                           ^
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2024-03-24 17:16:52.022  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:23:47
    2024-03-24 17:16:52.023  - error: host.fujiki Caught by controller[0]: Node.js v18.17.1
    2024-03-24 17:16:52.023  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-03-24 17:16:52.023  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
    • B BlindyBlinds
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                    NTP service: n/a
                RTC in local TZ: no
      iUser
      /home/iUser
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            16G          0B         16G
      Total:           20G        1.1G         17G
               3681 M total memory
               1103 M used memory
                530 M active memory
                899 M free memory
                111 M buffer memory
               1566 M swap cache
              16383 M total swap
                  0 M used swap
              16383 M free swap
      *** FILESYSTEM ***
      /var:
      3.3G	/var/
      2.1G	/var/lib
      1.5G	/var/lib/snapd
      751M	/var/log
      USB-Devices by-id:
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.13.16
      javascript: 	7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	274
      States: 	179
      Pending Updates: 0
      @blindyblinds sagte in ioBroker admin nicht mehr erreichbar:
      Setz die Zeit richtig.
      sudo timedatectl set-timezone 'Europe/Berlin'
      Setz das boot target richtig.
      sudo systemctl set-default multi-user.target
      nodejs muss auch aktualisiert werden.
      iob stop
      iob fix
      iob nodejs-update
      Dann bring die ganzen Adapter auf Stand:
      iob update
      iob upgrade all
      Wenn das alles richtig eingestellt wurde:
      iob start admin
      • I Offline
        I Offline
        iotowago
        Hallo, ich habe ein ähnliches Probelm bei ebenfalls heute stattgefundenem Update.
        Obigen Lösungsweg habe ich bereits durchgeführt.
        Wo kann noch mein Fehler liegen?
        Das ist der Log aus Iobroker Diag:
        2024-03-24 19:19:06.050  - error: host.HP-ProDesk-600-G2-DM instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-03-24 19:19:06.050  - info: host.HP-ProDesk-600-G2-DM Restart adapter system.adapter.admin.0 because enabled
        2024-03-24 19:19:06.402  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: /opt/iobroker/node_modules/iobroker.node-red/main.js:44
        2024-03-24 19:19:06.402  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: class NodeRed extends utils.Adapter {
        2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:                             ^
        2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
        2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.node-red/main.js:44:29)
        2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-03-24 19:19:06.403  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at node:internal/main/run_main_module:28:49
        2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: Node.js v18.19.1
        2024-03-24 19:19:06.404  - error: host.HP-ProDesk-600-G2-DM instance system.adapter.node-red.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-03-24 19:19:06.406  - info: host.HP-ProDesk-600-G2-DM Restart adapter system.adapter.node-red.0 because enabled
        2024-03-24 19:19:07.222  - warn: shelly.0 (31324) [authEnabled] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-24 19:19:07.247  - warn: shelly.0 (31324) [authEnabled] 192.168.2.27 (shellyplus2pm / shellyplus2pm-d48afc768a84 / shellyplus2pm#d48afc768a84#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-24 19:19:07.298  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): "General Status Notifications" are disabled (see adapter documentation for details)
        2024-03-24 19:19:07.322  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.27 (shellyplus2pm / shellyplus2pm-d48afc768a84 / shellyplus2pm#d48afc768a84#1): "General Status Notifications" are disabled (see adapter documentation for details)
        2024-03-24 19:19:07.833  - warn: shelly.0 (31324) [authEnabled] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-24 19:19:08.036  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): "General Status Notifications" are disabled (see adapter documentation for details)
        2024-03-24 19:19:08.229  - warn: shelly.0 (31324) [authEnabled] 192.168.2.128 (shellyplus2pm / shellyplus2pm-d48afc76158c / shellyplus2pm#d48afc76158c#1): This device is not protected via restricted login (see adapter documentation for details)
        2024-03-24 19:19:08.377  - warn: shelly.0 (31324) [Mqtt.statusNotifications] 192.168.2.128 (shellyplus2pm / shellyplus2pm-d48afc76158c / shellyplus2pm#d48afc76158c#1): "General Status Notifications" are disabled (see adapter documentation for details)
        2024-03-24 19:19:10.656  - warn: shelly.0 (31324) [authEnabled] 192.168.2.198 (shellyswitch25 / shellyswitch25-98CDAC2C6600 / SHSW-25#98CDAC2C6600#1): This device is not protected via restricted login (see adapter documentation for details)
        Mod-Edit: Code in Code-Tags posten
        • B BlindyBlinds
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: desktop
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                        NTP service: n/a
                    RTC in local TZ: no
          iUser
          /home/iUser
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:            16G          0B         16G
          Total:           20G        1.1G         17G
                   3681 M total memory
                   1103 M used memory
                    530 M active memory
                    899 M free memory
                    111 M buffer memory
                   1566 M swap cache
                  16383 M total swap
                      0 M used swap
                  16383 M free swap
          *** FILESYSTEM ***
          /var:
          3.3G	/var/
          2.1G	/var/lib
          1.5G	/var/lib/snapd
          751M	/var/log
          USB-Devices by-id:
          /usr/bin/npm 		9.6.7
          /usr/bin/npx 		9.6.7
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.13.16
          javascript: 	7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	274
          States: 	179
          Pending Updates: 0
          /home/iUser
          dein user ist nicht in der Gruppe iobroker
          wie hast du iobroker installiert?
            /home/iUser
            BlindyBlinds
            @homoran said in ioBroker admin nicht mehr erreichbar:
            /home/iUser
            Keine Sorge, der User ist drin
              iob stop
              iob fix
              iob nodejs-update
              iob update
              iob upgrade all
              iob start admin
              BlindyBlinds
              UTC ist ja richtig. Rest ist korrigiert, das mit nodejs sah schon vielversprechend aus. Hat auch etwas gebraucht
              Ergebnis ist aber noch
              2024-03-24 19:01:03.281  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
              2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
              2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:                           ^
              2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
              2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
              2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-03-24 19:01:03.282  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
              2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:28:49
              2024-03-24 19:01:03.283  - error: host.fujiki Caught by controller[0]: Node.js v18.19.1
              2024-03-24 19:01:03.283  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              Ich überleg mal wie die timezone einen TypeError auslöst, aber so weit bin ich noch nicht
              • B BlindyBlinds
                /home/iUser
                sonst noch was in der Ausgabe verändert?
                • B BlindyBlinds
                  UTC ist ja richtig
                  Nein, UTC ist nicht richtig. Da muss eine Zeitzone gesetzt werden. UTC berücksichtigt natürlich (unter anderem) die Sommerzeit nicht.
                  iob diag
                  sagt nun? Und veränder an der Ausgabe NICHTS!
                    UTC ist ja richtig
                    iob diag
                    BlindyBlinds
                    Hm, ich bin natürlich etwas paranoid, aber mein iobroker läuft in der Tat als User "iobroker"
                    Ausgabe ist
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Chassis: desktop
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     17:28:16 up 3 min,  3 users,  load average: 0.28, 0.24, 0.10
                    CPU threads: 4
                                   Local time: Fri 2024-03-29 17:28:16 CET
                               Universal time: Fri 2024-03-29 16:28:16 UTC
                                     RTC time: Fri 2024-03-29 16:28:16
                                    Time zone: Europe/Amsterdam (CET, +0100)
                                  NTP service: n/a
                              RTC in local TZ: no
                    iobroker
                    /home/iobroker
                    iobroker tty dialout sudo audio video
                    X-Server: 	false
                    Desktop:
                    Terminal:
                    Boot Target: 	multi-user.target
                    *** MEMORY ***
                    Mem:            3.7G        649M        2.3G        5.0M        692M        2.8G
                    Swap:            16G          0B         16G
                    Total:           20G        649M         18G
                             3681 M total memory
                              649 M used memory
                              196 M active memory
                              893 M inactive memory
                             2339 M free memory
                               47 M buffer memory
                              644 M swap cache
                            16383 M total swap
                                0 M used swap
                            16383 M free swap
                    *** FILESYSTEM ***
                    /dev/sda2      ext4    49G   25G   23G  53% /
                    [sudo] password for iobroker:
                    [Fri Mar 29 17:24:29 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Fri Mar 29 17:24:31 2024] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                    |-/snap/lxd/27948   /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                    |-/snap/lxd/27428   /dev/loop8  squashfs ro,nodev,relatime,errors=continue
                    `-/boot/efi         /dev/sda1   vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                    /var:
                    3.6G	/var/
                    2.1G	/var/lib
                    1.5G	/var/lib/snapd
                    899M	/var/log
                    Archived and active journals take up 184.0M in the file system.
                    27M	/opt/iobroker/backups/
                    179M	/opt/iobroker/iobroker-data/
                    133M	/opt/iobroker/iobroker-data/files
                    22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                    9.0M	/opt/iobroker/iobroker-data/objects.jsonl
                    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                    USB-Devices by-id:
                    /usr/bin/nodejs 	v18.20.0
                    /usr/bin/node 		v18.20.0
                    /usr/bin/npm 		10.5.0
                    /usr/bin/npx 		10.5.0
                    /usr/bin/corepack 	0.25.2
                    nodejs:
                      Installed: 18.20.0-1nodesource1
                      Candidate: 18.20.0-1nodesource1
                      Version table:
                     *** 18.20.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.19.1-1nodesource1 1001
                         18.19.0-1nodesource1 1001
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.13.16
                    javascript: 	7.8.0
                    Adapters from github: 	0
                    Adapter State
                    + instance is alive
                    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                    Adapter    "mediola-gateway": 1.1.0  , installed 1.1.0
                    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                    Adapter    "ws"           : 2.5.11   , installed 2.5.11
                    Objects and States
                    Objects: 	278
                    States: 	181
                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      997        21470      778/pihole-FTL
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23309      785/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19309      1/init
                    tcp        0      0 0.0.0.0:90              0.0.0.0:*               LISTEN      0          25376      843/lighttpd
                    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      997        21476      778/pihole-FTL
                    tcp        0      0 0.0.0.0:51821           0.0.0.0:*               LISTEN      0          27074      1444/docker-proxy
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1004       25994      699/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1004       26002      699/iobroker.js-con
                    tcp        0      0 0.0.0.0:5240            0.0.0.0:*               LISTEN      0          25336      837/nginx: master p
                    tcp        0      0 0.0.0.0:5239            0.0.0.0:*               LISTEN      998        25891      709/python3
                    tcp6       0      0 :::53                   :::*                    LISTEN      997        21472      778/pihole-FTL
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          23311      785/sshd: /usr/sbin
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          484        1/init
                    tcp6       0      0 :::90                   :::*                    LISTEN      0          25375      843/lighttpd
                    tcp6       0      0 :::51821                :::*                    LISTEN      0          27077      1450/docker-proxy
                    tcp6       0      0 :::5239                 :::*                    LISTEN      998        25897      709/python3
                    tcp6       0      0 ::1:4711                :::*                    LISTEN      997        21477      778/pihole-FTL
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1004       29784      1675/io.simple-api.
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1004       28355      1656/io.web.0
                    udp        0      0 0.0.0.0:57540           0.0.0.0:*                           1004       26567      1690/io.mediola-gat
                    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          26402      1464/docker-proxy
                    udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1004       26566      1690/io.mediola-gat
                    udp        0      0 0.0.0.0:53              0.0.0.0:*                           997        21469      778/pihole-FTL
                    udp        0      0 192.168.0.97:68         0.0.0.0:*                           101        24518      678/systemd-network
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19310      1/init
                    udp        0      0 172.17.0.1:123          0.0.0.0:*                           115        29647      804/ntpd
                    udp        0      0 192.168.0.97:123        0.0.0.0:*                           0          25298      804/ntpd
                    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          25296      804/ntpd
                    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          25292      804/ntpd
                    udp6    1280      0 fe80::4e52:62ff:feb:546 :::*                                101        24513      678/systemd-network
                    udp6       0      0 :::51820                :::*                                0          27080      1472/docker-proxy
                    udp6       0      0 :::53                   :::*                                997        21471      778/pihole-FTL
                    udp6       0      0 :::111                  :::*                                0          18378      1/init
                    udp6       0      0 fe80::c02b:eff:fe0f:123 :::*                                115        29691      804/ntpd
                    udp6       0      0 fe80::42:36ff:fed7::123 :::*                                115        29689      804/ntpd
                    udp6       0      0 fe80::4e52:62ff:feb:123 :::*                                0          25304      804/ntpd
                    udp6       0      0 fdba:fa8:c75f:0:4e5:123 :::*                                0          25302      804/ntpd
                    udp6       0      0 ::1:123                 :::*                                0          25300      804/ntpd
                    udp6       0      0 :::123                  :::*                                0          25289      804/ntpd
                    2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
                    2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                    2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                    2024-03-29 17:28:46.292  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                    2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                    2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                    2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                    2024-03-29 17:28:46.293  - error: host.fujiki Caught by controller[0]: Node.js v18.20.0
                    2024-03-29 17:28:46.293  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-03-29 17:28:46.293  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
                    2024-03-29 17:29:16.319  - info: host.fujiki instance system.adapter.admin.0 started with pid 3110
                    2024-03-29 17:29:17.223  - error: host.fujiki Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/main.js:43
                    2024-03-29 17:29:17.223  - error: host.fujiki Caught by controller[0]: class Admin extends utils.Adapter {
                    2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:                           ^
                    2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
                    2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:43:27)
                    2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                    2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                    2024-03-29 17:29:17.224  - error: host.fujiki Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                    2024-03-29 17:29:17.225  - error: host.fujiki Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                    2024-03-29 17:29:17.226  - error: host.fujiki Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                    2024-03-29 17:29:17.227  - error: host.fujiki Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                    2024-03-29 17:29:17.227  - error: host.fujiki Caught by controller[0]: Node.js v18.20.0
                    2024-03-29 17:29:17.227  - error: host.fujiki instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-03-29 17:29:17.227  - info: host.fujiki Restart adapter system.adapter.admin.0 because enabled
                    System ist frisch durchgestartet und alle Module auf dem neuesten Stand. Schon verrückt worüber sich das admin-Modul beschwert, das noch funktionierende mediola-Modul extended auch den utils.Adapter
                    Installation hatte ich damals nach der Anleitung unter https://iobroker.readthedocs.io/de/latest/getting-started/installation.html ausgeführt.
                    @iotowago wie sieht es bei dir aus?
                    Frohe Ostern wünsche ich schon mal!
                      BlindyBlinds
                      Um das hier zu updaten: Das Problem ist durch umstellen auf den Entwicklerzweig gelöst - die dort vorhandene Version des Adminadapters startet und ist auch wieder erreichbar
