  4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
    6.3k
238 Beiträge 62 Kommentatoren 81.6k Aufrufe 44 Beobachtet
  • apollon77A apollon77
    @martiman Ok, so Wrapper Mode ... so you have added the homebridge started by the adapter to our Apple Home and then the states are not provided? The a more complete log (as text from disk logfile) would be helpful
    MartiMan
    #224
    @apollon77 I assume the objects of the Homebridge plugin should be added as a ham subfolder?
    • M MartiMan
      @apollon77
      From what I understand from the manual, the plugin will create the link to the Home app.
      "homebridge-eosstb is a Homebridge plugin allowing you to control your set-top box (typically an ARRIS DCX960 / VIP5002W or HUMAX EOS1008R / 2008C) running on the Magenta AT / Telenet BE / Sunrise CH / Virgin Media GB & IE / Ziggo NL Horizon TV platform with Apple HomeKit using the Home app and the Apple TV Remote in the Control Center."
      This is the full log after a restart of the plugin.
      iobroker.2023-12-06.log.html
      #225
      @martiman Butall this do nt happen automatically ... you need to go into the Apple home and click the "+" and then scan ender the pin you defined in the config to add the bridge to youe apple home. Did you do that?
        MartiMan
        schrieb am zuletzt editiert von MartiMan
        #226
        @apollon77 Late reply, new system running on bookworm now which took me some time...
        Well I'm using yahka for all my lights and gates combined with the S7 adapter so I'm familiar with that.
        From my understanding Homebridge supplies the Homekit bridge that makes that Homebridge plugins will be recognised by the Home app.
        According to the ham README.md the wrapper mode does not support this (I had a RTFM moment lol):
        "IMPORTANT: This mode allows to use the device integrations of the provided homebridge plugins. No "bridge" is provided that can be used by the Home App!"
        So then I should get at least some variables in objects that I can connect to yahka using enum no?
        Or how should I interpret the "device integrations" mentioned above?
        I really don't want to also have Homebridge running for just this plugin.
        UPDATE:
        After installing "homebridge-seasons", as it was tested and confirmed working, I suddenly started getting log errors which I didn't get with homebridge-eosstb plugin alone!?
        Now the ham folder in objects gets a 0 folder with all necessary variables of the seasons plugin.
        Still no eosstb variables.
        2023-12-10 10:10:31.217 - debug: ham.0 (9301) setState Season.Season.Season-Name: set value = Winter
        2023-12-10 10:10:31.219 - error: ham.0 (9301) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-12-10 10:10:31.220 - error: ham.0 (9301) unhandled promise rejection: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 25ec2c37-426c-4b8e-a20f-976770fa1af5
        2023-12-10 10:10:31.347 - error: ham.0 (9301) Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 25ec2c37-426c-4b8e-a20f-976770fa1af5
        at WrapperBridge.Accessory.addBridgedAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/lib/Accessory.ts:594:15)
        at WrapperBridge.addBridgedAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:299:55)
        at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/bridgeService.ts:554:11
        at Array.forEach ()
        at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/bridgeService.ts:542:19
        at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/lib/util/once.ts:10:18
        at SeasonsPlatform.accessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-seasons/index.js:64:3)
        at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/bridgeService.ts:537:17
        at new Promise ()
        at BridgeService.loadPlatformAccessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/bridgeService.js:400:16)
        2023-12-10 10:10:31.348 - error: ham.0 (9301) Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 25ec2c37-426c-4b8e-a20f-976770fa1af5
        2023-12-10 10:10:31.374 - info: ham.0 (9301) cleaned everything up...
        2023-12-10 10:10:31.394 - info: ham.0 (9301) terminating
        2023-12-10 10:10:31.396 - warn: ham.0 (9301) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-12-10 10:10:31.397 - debug: ham.0 (9301) [10/12/2023, 10:10:31] [EOSSTB] Goodbye
        2023-12-10 10:10:31.898 - info: ham.0 (9301) terminating
        2023-12-10 10:10:31.969 - error: host.rpi4 Caught by controller[1]: [10/12/2023, 10:10:30] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        2023-12-10 10:10:31.970 - error: host.rpi4 Caught by controller[2]: [10/12/2023, 10:10:30] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        2023-12-10 10:10:31.970 - error: host.rpi4 Caught by controller[3]: [10/12/2023, 10:10:30] The plugin "homebridge-eosstb" requires a Homebridge version of >=1.6.0 which does not satisfy the current Homebridge version of 1.5.0. You may need to update this plugin (or Homebridge) to a newer version. You may face unexpected issues or stability problems running this plugin.
        2023-12-10 10:10:31.970 - error: host.rpi4 instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-12-10 10:10:31.971 - info: host.rpi4 Restart adapter system.adapter.ham.0 because enabled
        2023-12-10 10:11:02.013 - info: host.rpi4 instance system.adapter.ham.0 started with pid 9342
        So apparently eosstb needs at least homebridge V1.6.0 and ham apparently still runs V1.5.0.
        • M MartiMan
          UPDATE:
          at Array.forEach ()
          at new Promise ()
          #227
          @martiman sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
          hehe ... jooo ... Wrapper mode ist genau das ... und keine Bridge.. Nimm den Local Mode, dann startet er eine Bridge
            MartiMan
            #228
            @apollon77 I installed homebridge for this one and also android plugin for Shield TV. I don’t really need to automate these so Siri access is enough 😉
              hier im Thread dürfen zu dem Homebridge -Adapter (iobroker.ham) gern funktioniernde Plugins berichtet werden, Konfigurationsbeispiele und sonstige Infos. lasst uns sammeln :-)
              Bitte packt auf jeden Fall Pluginname, Version des Plugins, die Version des ham Adapters und EUre nodejs Version mit rein. Danke!
              Danke Ingo
              dfrozen1977
              #229
              @apollon77
              @alexeimotkoff/homebridge-daichi-comfort-conditioner
                "bridge": {
                  "name": "Homebridge",
                  "username": "CC:22:3D:E3:CE:30",
                  "port": 51826,
                  "pin": "031-45-154"
                "platforms": [
                    "name": "Daichi Comfort",
                    "username": "************",
                    "password": "************",
                    "platform": "DaichiComfortConditioner"
              ![HAM.png](/assets/uploads/files/1712289853797-ham.png) ```
              • E Offline
                eugenmayer
                #230
                homebridge-thermotek
                • wrapper mode
                  "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                  "accessories": [],
                  "platforms": [
                      "host": "zz.xx.yy.cc",
                      "port": "6653",
                      "platform": "ThermotecRadiatorControl"
                haselchenH O 2 Antworten Letzte Antwort
                • E eugenmayer
                  • wrapper mode
                    "accessories": [],
                    "platforms": [
                        "port": "6653",
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #231
                  @eugenmayer
                  Dieser Post soll uns was sagen? 🤔
                  O 1 Antwort Letzte Antwort
                  • haselchenH haselchen
                    @eugenmayer
                    O Abwesend
                    O Abwesend
                    oFbEQnpoLKKl6mbY5e13
                    #232
                    @haselchen
                    Dass es ein funktionierendes Plugin ist?
                    • O oFbEQnpoLKKl6mbY5e13
                      @haselchen
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #233
                      @ofbeqnpolkkl6mby5e13
                      Okay, vielleicht hatte ich das einfach nur vermisst 😎
                      Danke Ingo
                      • E eugenmayer
                        • wrapper mode
                          "accessories": [],
                          "platforms": [
                              "port": "6653",
                        O Abwesend
                        O Abwesend
                        #234
                        @eugenmayer
                        Trage die Infos -siehe den Hinweis von @haselchen- bitte noch nach.
                          tob111
                          #235
                          Hallo habe den ham 5.3.1 und versuche gerade über homebridge-ring mein Ring Alarm System einzubinden. An die Sensoren komme ich schön ran, die sind auch alle gelistet. Das Problem ist die Kamera. Da werden zwar auch Infos gelistet, ich würde aber gerne auf die Snapshots zugreifen. Wo finde ich die?
                          • T tob111
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #236
                            @tob111
                            Und der Ring Adapter ist keine Alternative? 🤔
                              @tob111
                              tob111
                              #237
                              @haselchen über den bekomm ich halt nur die kamera bilder. das ginge natürlich auch aber fände es schöner es über einen adapter zu lösen
                              • Gregor PG Offline
                                Gregor PG Offline
                                Gregor P
                                schrieb am zuletzt editiert von Gregor P
                                #238
                                erledigt
