  4. [GELÖST] Text-Wert eines states ausgeben anstatt Nummer
    5.7k
14 Beiträge 8 Kommentatoren 5.1k Aufrufe 6 Beobachtet
    miggedy
    Danke für die Ideen. Ein neues Script und Datenpunkt wollte ich auf Grund der Übersichtlichkeit vermeiden. Habe mich daher für die Idee von peoples entschieden (musste nur die Werte-Liste noch anpassen da das Widget 0-basiert ist und die Status-Werte des Roboters "Lücken" hat). Aber so klappt es.
    [{"tpl":"tplValueList","data":{"oid":"mihome-vacuum.0.info.state","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"valuelist":"Unknown;\nUnknown;\nSleep no Charge;\nSleep;\nUnknown;\nCleaning;\nReturning home;\nManuell mode;\nCharging;\nUnknown;\nPaused;\nSpot cleaning;\nError"},"style":{"left":"433px","top":"18px","width":"110px","height":"20px","color":"#FFFFFF"},"widgetSet":"basic"}]
    Danke euch!
      tropisch
      @miggedy said in [GELÖST] Text-Wert eines states ausgeben anstatt Nummer:
      Habe gerade genau das gleiche Problem :)
      Welches Widget verwendet man für sowas?
      • T tropisch
        tropisch
        @tropisch said in [GELÖST] Text-Wert eines states ausgeben anstatt Nummer:
        Problem gelöst.
        Falls noch jemand diese Frage hat: Widgets - Widgets importieren
        • OstfrieseUnterwegsO Offline
          OstfrieseUnterwegs
          Ich habe bei meinem Landroid das gleiche Problem. Irgendwie muss es doch noch eine andere Lösung geben, Immerhin steht ja alles in der DP Definition drin und in der Admin Oberfläche wird auch der Klartext angezeigt.
          • bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            nehmt dies:
            https://forum.iobroker.net/topic/21865/beschreibung-eines-objekts-in-vis-zeigen/9
            Danke.
              OstfrieseUnterwegs
              Ja, nee... dass es damit geht (aber nur in der VIS), ist mir schon klar. Aber das heisst, dass ich bereits im System vorhandene Werte nochmal eingeben muss. Das sind für mich nur work-arounds. Denken wir mal, dass Worx einen zusätzlichen Status 99 - Dein Landroid hebt in zwei Minuten ab erfindet. Dann muss ich in vile Visualisierungen und Scripte anpassen.
              Ich glaube ich mache mal ein GIT Issue auf - passt wahrscheinlich in ioBroker.javascript.
                OstfrieseUnterwegs
                @apollon77
                Ich habe gesehen, dass Du einen Enhancement Request zu einem ähnlichen Thema aufgemacht hast (https://github.com/ioBroker/ioBroker.javascript/issues/381)
                Kannst Du in diesem Thread helfen: Wie kann ich mit getState (oder getObject ?) an den Klartext eines State values kommen?
                • apollon77A Offline
                  Wenn ein Objekt sowas hat dann per getObject das Objekt laden und da unter common.states stehen die Textzeilen werte.
                  OstfrieseUnterwegsO MichaelScM 2 Antworten Letzte Antwort
                  • apollon77A apollon77
                    OstfrieseUnterwegs
                    @apollon77 Super, danke, funktioniert
                      MichaelScM Offline
                      MichaelScM Offline
                      MichaelSc
                      @apollon77 Danke, diese relativ alte Antwort hat auch mir heut geholfen!
                      iOBroker (and the other stuff) on a Proxmox Installation on an Intel NUC10.
                      IoT: Discarded Zigbee-System and all the hardware related to Zigbee; replaced with HomeMatic IP - very reliable.
                      MichaelScM 1 Antwort Letzte Antwort
                      • MichaelScM MichaelSc
                        MichaelScM Offline
                        MichaelScM Offline
                        MichaelSc
                        @michaelsc said in [GELÖST] Text-Wert eines states ausgeben anstatt Nummer:
                        @apollon77: Hat zwar geholfen, aber nicht zum Erfolg geführt - ich komme mit der Syntax nicht klar.
                        Wie muss denn bitte so ein getObject genau aussehen? Ich hätte gerne den Namen zurück, der da drinsteht, aber da muss man doch eine bestimmte Syntax einhalten, denke ich mal...
