  4. [neuer Adapter] smartgarden adapter for Gardena smart system
    6.3k
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 439.3k Aufrufe 101 Beobachtet
  • M michihorn
    @richard-0 ich habe alle paar Tage das selbe Problem, immer wieder neue Zugangsdaten anfordern und dann läuft es wieder 1-2 Tage :-(
    Das Log sieht bei mir wie folgt aus:
    smartgarden.0
    2023-07-12 09:29:37.139 info 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2023-07-12 09:29:37.135 info 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2023-07-12 09:29:37.122 info 3/ getConnection: trying to connect again in 500 seconds
    smartgarden.0
    2023-07-12 09:29:37.122 info 3/ getConnection: returned connection error: request returned 403 Forbidden
    smartgarden.0
    2023-07-12 09:29:37.122 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2023-07-12 09:29:37.122 error Error: request returned 403 Forbidden
    smartgarden.0
    2023-07-12 09:29:37.121 info 3/ get_locations failure:..return with error
    smartgarden.0
    2023-07-12 09:29:37.121 info 3/ get_locations failure: response.statusCode/Message=403/Forbidden
    smartgarden.0
    2023-07-12 09:29:37.120 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2023-07-12 09:29:36.994 info 3/ ---> State change by device: state sg.0.info.RateLimitCounter changed, (ack = true)
    smartgarden.0
    2023-07-12 09:29:36.951 info 3/ incrementLimitCounter: new counters : y2023 / m2023-07: 5127 / d2023-07-12: 110 / hr07: 8 / last30days: 5867 / last31days: 5867
    smartgarden.0
    2023-07-12 09:29:36.949 info 3/ get_locations ...
    smartgarden.0
    2023-07-12 09:29:36.949 info 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXX
    smartgarden.0
    2023-07-12 09:29:36.949 info 3/ Connection: expires_in/timeout/factor:86399 / 86313 / 0.999
    smartgarden.0
    2023-07-12 09:29:36.948 info 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    smartgarden.0
    2023-07-12 09:29:36.704 info 3/ ---> State change by device: state sg.0.info.RateLimitCounter changed, (ack = true)
    smartgarden.0
    2023-07-12 09:29:36.672 info 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2023-07-12 09:29:36.652 info 3/ connect ... using client credentials grant
    smartgarden.0
    2023-07-12 09:29:36.652 info 3/ incrementLimitCounter: new counters : y2023 / m2023-07: 5126 / d2023-07-12: 109 / hr07: 7 / last30days: 5866 / last31days: 5866
    smartgarden.0
    2023-07-12 09:29:36.650 info 3/ connect ... empty password
    smartgarden.0
    2023-07-12 09:29:36.650 info 3/ connect ... empty username
    smartgarden.0
    2023-07-12 09:29:36.650 info 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0
    2023-07-12 09:29:36.649 info 3/ connecting to Gardena Smart System Service ...
    smartgarden.0
    2023-07-12 09:29:36.649 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2023-07-12 09:29:36.649 info 3/ connectToGardena...
    smartgarden.0
    2023-07-12 09:29:36.648 info 3/ getConnection...
    Richard 0
    #1023
    @michihorn ich habe das Problem leider durchgängig. Nicht mal das neu erstellen der API im Dev Portal hat etwas geholfen.
    Sonst habe ich auch keine Fehle bei mir im Log gefunden, bis auf den: "Error: request returned 502 Bad Gateway". Diesen bekomme ich auch nur, wenn ich befehle an den Roboter senden will. Die restlichen informationen bekomme ich alle. 😕
    P 1 Antwort Letzte Antwort
    • R Richard 0
      Pistus
      #1024
      mein smart sileno Mähroboter fährt mittels Regensensor bei Regen in die Garage.
      Bei Regen im Falle von wahr
      schreibe Objekt ID steure Wert activity_control_i PARK_UNTILFURTHER_NOTICE
      falls Wert vom Objekt ID Mäher-activity_moving_i = wahr
      mache debug output Es regnet, der Mäher fährt in die Garage, info
      sonst, falls es Regnet und der Mäher befindet sich in der Garage debug output Es regnet, aber der Mäher steht zum laden in der Garage info
      Soweit funktioniert alles.
      Jetzt möchte ich aber, wenn es nicht mehr regnet, den Mäher wieder in seinen Normalzustand versetzen. D.h. mähen nach Zeitplan. Wie kann ich das realisieren.
      Mit
      falls Wert von Objekt ID activity_controll = PARK_UNTIL_FURTHER_NOTIZE
      mache schreibe Objekt_ID activity_control_i steure Wert PAR_UNTIL_NEXT_TASK
      funktioniert das nicht.
      Denn wenn ich danach schreibe debug output Es regnet nicht mehr info
      wird die Info nicht angezeigt.
      Hat Jemand eine Lösung?
      • P Pistus
        Mit
        Kaiman55
        #1025
        @pistus Im Thread habe ich mal mein Blockly gepostet. Damit funktioniert es.
        • M MrLee
          Moin!
          Seit kurzem kann der manuelle Start per App ja auf bestimmte (stay-inzone) Zonen gesetzt werden. Man übergibt Zone und Dauer....
          Seit dem scheint der manuelle Start per API nicht mehr zu funktionieren, das bisherige übergeben der Dauer in sec scheint nicht mehr zu reichen...
          Hat hier jemand schon Informationen wie man diese Funktion bzw. überhaupt wieder manuellen Start bei Mähern über den Adapter nutzt?
          bis denne
          Mr.Lee
          MrLee
          #1026
          @mrlee
          Jemand hier schon was in der API rausgefunden?
          Mr. Lee
          • K Kaiman55
            Pistus
            #1027
            @kaiman55 Danke für deine Info.
            Zu meinem Verständnis.
            Mit PARKUNTIL_FURTHER_NOTIZE wir der Mäher in die Garage geschickt. Wie lange bleibt der Text in der activity_control_i erhalten.
            Meine Abfrage wenn der Mäher in der Garage ist lautet
            Falls Wert vom Objekt ID activity_control_i = PARK_UNTIL_FURTHER_NOTIZE
            Mache schreibe Objekt_ID activity_control_i steure Wert PARK_UNTIL_NEXT_TASK Verzögerung
            Der letzte Schritt funktioniert nicht.
            https://forum.iobroker.net/topic/31289/neuer-adapter-smartgarden-adapter-for-gardena-smart-system/1026?loggedin=true#
            Das müsste er aber wenn in activity_control_i noch PARK_UNTIL_FURTHER_NOTIZE stünde.
            • P Pistus
              mon
              #1028
              Kann man mit dem Adapter den Zeitplan eines Mähers auslesen?
              Ich habe irgendwie keine passenden Objekte dazu gefunden.
              jpgorganizerJ M 2 Antworten Letzte Antwort
              • M mon
                jpgorganizerJ Offline
                jpgorganizer
                #1029
                @mon sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                nein, geht nicht
                smartgarden Adapter für GARDENA smart system
                Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
                • M mon
                  mon
                  #1030
                  @mon Oh das ist ja Schade. Ich war mir sicher ich hatte sowas mal im Forum gesehen. Dann war das vlt. mit dem Gardena Plugin?
                    BlackHawk1942
                    #1031
                    Grüß Euch!
                    Ich hatte den gleichen Fehler. Habe dann, wie hier besprochen, die App bei Husqvarna neu angelegt und dann in den Settings des Adapters UName und PWD raus genommen und entsprechend die AppKey und AppSec eingetragen. Seit dem bekomme ich immer einen "400 Bad Request". Ich habe bereits den Adapter gelöscht und neu angelegt, nicht nur die Instanz.
                    Könnt ihr mir an dieser Stelle ggf helfen? Ich schaffe es einfach nicht meine Daten / Objekte wieder zu bekommen. Wenn ich den Adapter neu starte, dass ist es tw. kurzzeitig "grün", also verbunden und dann aber schnell wieder "gelb". Mit geht es um die Connection zu Gardena. Meine App läuft zuverlässig (iPhone). Es hat sich nichts an Firewall oder dem Netzwerk generell verändert. Lief 1,5 Jahre problemlos und nun bekomme ich es einfach nicht mehr hin.
                    @jpgorganizer hast Du eine Idee?
                    Wenn ich das Testscript von Husqvarna per SSH auf meinem ioB ausführe, dann bekomme ich einen Accesstoken.
                    2023-09-26 10:13:29.938 - info: smartgarden.0 (11810) 1/ reconnect!
                    2023-09-26 10:13:29.938 - info: smartgarden.0 (11810) 1/ getConnection...
                    2023-09-26 10:13:29.939 - info: smartgarden.0 (11810) 1/ connectToGardena...
                    2023-09-26 10:13:29.939 - info: smartgarden.0 (11810) 1/ connecting to Gardena Smart System Service ...
                    2023-09-26 10:13:29.939 - info: smartgarden.0 (11810) 1/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                    2023-09-26 10:13:29.939 - info: smartgarden.0 (11810) 1/ connect ... empty username
                    2023-09-26 10:13:29.939 - info: smartgarden.0 (11810) 1/ connect ... empty password
                    2023-09-26 10:13:29.939 - info: smartgarden.0 (11810) 1/ connect ... using client credentials grant
                    2023-09-26 10:13:30.160 - info: smartgarden.0 (11810) 1/ Connection failure.response.statusCode/Message=400/Bad Request
                    2023-09-26 10:13:30.160 - info: smartgarden.0 (11810) 1/ Connection failure:..return with error
                    2023-09-26 10:13:30.160 - error: smartgarden.0 (11810) Error: request returned 400 Bad Request
                    2023-09-26 10:13:30.160 - info: smartgarden.0 (11810) 1/ getConnection: returned connection error: request returned 400 Bad Request
                    2023-09-26 10:13:30.160 - info: smartgarden.0 (11810) 1/ getConnection: trying to connect again in 300 seconds
                    Teilweise connected er eben kurzzeitig und schließt dann wieder.
                    2023-09-26 10:42:50.469 - info: smartgarden.0 (11810) 1/ Connection: successful: response.statusCode / statusMessage=200 / OK
                    2023-09-26 10:42:50.469 - info: smartgarden.0 (11810) 1/ Connection: expires_in/timeout/factor:86399 / 86313 / 0.999
                    2023-09-26 10:42:50.469 - info: smartgarden.0 (11810) 1/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXX-X-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                    2023-09-26 10:42:50.470 - info: smartgarden.0 (11810) 1/ get_locations ...
                    2023-09-26 10:42:50.672 - info: smartgarden.0 (11810) 1/ get_locations: successful / response.statusMessage: OK
                    2023-09-26 10:42:50.673 - info: smartgarden.0 (11810) 1/ get_locations ... locations={"data":[{"id":"<wurde entfernt>","type":"LOCATION","attributes":{"name":"My Garden"}}]}
                    2023-09-26 10:42:50.673 - info: smartgarden.0 (11810) 1/ get_websocket ...
                    2023-09-26 10:42:50.844 - info: smartgarden.0 (11810) 1/ get_websocket successful: response.statusCode/Message=201/Created
                    2023-09-26 10:42:50.845 - info: smartgarden.0 (11810) 1/ get_websocket ... websocket ok
                    2023-09-26 10:42:50.975 - info: smartgarden.0 (11810) 1/ on_close: ### closed ### close.code=1006 close.reason=
                    Danach geht es direkt in den oben beschriebenen 400.
                    Danke Euch!
                    • B BlackHawk1942
                      Grüß Euch!
                      Danke Euch!
                      martin_olw
                      #1032
                      Hallo zusammen!
                      Dank des Blockly von @Kaiman55 fährt mein Mäher bei Regen automaisch zum Laden und setzt seine Fahrt dann später wieder fort. Das war für mich als Neuling recht einfach machbar ;-)
                      Nun aber eine Neulingsfrage: Ich möchte mir die Restlaufzeit (Mähen oder Laden) von Sekunden in Minuten umrechnen (mathematisch ist mir das klar) lassen und in zwei entsprechende Datenpunkte schreiben. Wie kann ich das machen. Habe es schonmal versucht, aber das funktioniert leider nicht.
                      Danke für eure Hilfe!
                      VG Martin
                      • M martin_olw
                        Hallo zusammen!
                        VG Martin
                        michihorn
                        schrieb am zuletzt editiert von michihorn
                        #1033
                        @martin_olw
                        Ich habe zwar keine Ahnung von Blockly aber im Java sieht das so aus. Restlaufzeit und Restladezeit werden berechet und in einen vorher angelegten DP geschrieben.
                        const id_LZ = "smartgarden.0.LOCATION_xxxxxx-2Df6d9-2D4225-xxxx81-2Dad62bcd5ae1e.DEVICE_5xxx-2De89e-2D46c1-2D9c5e-2D3340cc87b9ff.SERVICE_MOWER_59e2d2b8-2De89e-2D46c1-2D9c5e-2D3340cc87b9ff.activity_mowingTime_remain_i"
                        const id_CT = "smartgarden.0.LOCATION_xxxxxxxx-2Df6d9-2D4225-2D9481-xxxxcd5ae1e.DEVICE_5xxxb8-2De89e-2D46c1-2D9c5e-2D3340cc87b9ff.SERVICE_COMMON_xxxxxxx-2De89e-2D46c1-2Dxxxe-2xxx40cc87b9ff.batteryState_chargingTime_remain_i"
                        on({ id: id_LZ, change: "any" }, function (dp) {
                            var RZ = (dp.state.val / 60).toFixed(0)
                            log(RZ)
                            setState("0_userdata.0.Garten.Rasen.Restlaufzeit", RZ)
                        on({ id: id_CT, change: "any" }, function (dp) {
                            var LZ = (dp.state.val / 60).toFixed(0)
                            log(LZ)
                            setState("0_userdata.0.Garten.Rasen.Restladezeit", LZ)
                        Michael
                        • M michihorn
                          @martin_olw
                              log(RZ)
                              log(LZ)
                          Michael
                          martin_olw
                          schrieb am zuletzt editiert von martin_olw
                          #1034
                          @michihorn Vielen Dank!
                          Ich habe die beiden IDs in Zeile 1 und 2 durch meiner Werte aus den jeweiligen Objekten ersetzt. Auch den Datenpunkt in Zeile 8 und Zeile 14 angepasst. Aber bei mir kommt in den Datenpunkten immer noch "0", obwohl die beiden Werte zur verbleibenden Lauf- und Ladezeit im io aktualisiert werden.
                          Wo kann das Problem liegen, nach was soll ich schauen?
                          • M martin_olw
                            michihorn
                            #1035
                            @martin_olw Hallo, das Script arbeitet nur, wenn sich der Wert des entsprechenden Datenpunktes in Zeile 1 oder 2 ändert, die selbst angelegten Datenpunkte in Zeile 8 und 14 müssen vom Typ Number sein und werden dann entsprechend des Scriptes mit Daten gefüllt.
                            Zeigt mal das LOG bei Ausführung, sollte so aussehen....
                            • M michihorn
                              martin_olw
                              #1036
                              @michihorn Ich habe den Fehler gefunden. Hatte wohl beim Kopieren der beiden Datenpunkte einen Fehler gemacht. Ich habe die Pfade noch einmal neu kopiert (zur Sicherheit in Notepad), verglichen und neu ins Script eingefügt. Dann ging es.
                              Danke!
                                MatthiasPetersen
                                #1037
                                Hi, nachdem ich meinen Gardena Sileno City letztes Jahr auf die aktuellste Version geupdated habe, habe ich heute den Mähroboter aus dem Keller geholt. Mir ist nun aufgefallen, dass die Datenpunkte activity_mowingTime_remain_i und batteryState_chargingTime_remain_i nicht mehr im iobroker gesetzt werden. Nach einem Neustart des Adapters sieht man zwar anhand des Timestamps, dass die Datenpunkte aktualisiert wurden, allerdings immer nur mit dem Wert Null. Meine Biobroker-Installation inkl. des Smartgarden-Adapters sind jeweils auf der aktuellsten Version.
                                Kennt Ihr zufällig das Problem?
                                Viele Grüße
                                Matthias
                                • K Kaiman55
                                  @mcbirne sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  @kaiman55 said in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  r Sensor keinen Regen mehr an (hier nehme ich immer den Regen Wert "in der letzten Stunde", da er son
                                  Wie sendest du es an den Rasenmähern?
                                  Ein Stück weiter oben, habe ich einen Teil des Blockly gepostet. Da siehst Du es.
                                  Edit:
                                  Hier nochmal als Export. Funktioniert bei mir sehr gut.
                                    <block type="comment" id="!5#EPV5tY!uMs.c:xRKl" x="-1487" y="-1312">
                                      <field name="COMMENT">Mählanie bei Regen/Trockenheit rein und raus</field>
                                      <next>
                                        <block type="on_ext" id="Ps5%H5|sm,lZR5Mx~u]2">
                                          <value name="OID0">
                                            <shadow type="field_oid" id="Fhv0CaM~0KQi1#h)-K=K">
                                              <field name="oid">netatmo.0.Wohnbereich-(Innen).Regen.Rain.SumRain1</field>
                                            </shadow>
                                          </value>
                                          <statement name="STATEMENT">
                                            <block type="comment" id="`H(zJXb|OgmoBpa=o*Id">
                                              <field name="COMMENT">Mähen fortsetzen wenn es die letzte Stunde trocken war und rausschicken</field>
                                              <next>
                                                <block type="controls_if" id="kMv#PEDhcxz[S7_+j$:A">
                                                  <value name="IF0">
                                                    <block type="logic_operation" id="6?)|+@t.Z7w{fL;8ODH}" inline="false">
                                                      <field name="OP">AND</field>
                                                      <value name="A">
                                                        <block type="logic_compare" id="{zT!Dnt-6jBo5tofA36z">
                                                          <field name="OP">EQ</field>
                                                          <value name="A">
                                                            <block type="get_value" id="yu]AGvIi!8k]4_aQmx5s">
                                                              <field name="OID">netatmo.0.Wohnbereich-(Innen).Regen.Rain.SumRain1</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="FW{XQ]B(v387y7yZ]Ovs">
                                                              <field name="NUM">0</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_compare" id="9`D18YFlpB1ZPD^Y%c(A">
                                                          <value name="A">
                                                            <block type="get_value" id="(MaIwHj8ttq`64|xLZH_">
                                                              <field name="OID">smartgarden.0.LOCATION_2d4c7365-2D809c-2D4c18-2D91c9-2D8362146ac8f5.DEVICE_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.SERVICE_MOWER_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.activity_mowing_i</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_boolean" id="2nV[8E/H:+S9;jideC5}">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <statement name="DO0">
                                                    <block type="control" id="r?Ws.R4O#`(%{.]6]IEy">
                                                      <field name="OID">smartgarden.0.LOCATION_2d4c7365-2D809c-2D4c18-2D91c9-2D8362146ac8f5.DEVICE_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.SERVICE_MOWER_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.activity_control_i</field>
                                                      <value name="VALUE">
                                                        <block type="text" id=")4/Q=nS46)(.v?~gG,*T">
                                                          <field name="TEXT">START_DONT_OVERRIDE</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="comment" id="+jz?xHrG/M|6f42myVBx">
                                                      <field name="COMMENT">Mäher bei aktiven Regen beenden und in die Hütte schicken</field>
                                                      <next>
                                                        <block type="controls_if" id="i|[`4tT!fw=x*8!O|*r8">
                                                          <value name="IF0">
                                                            <block type="logic_compare" id="/N]7?]TkkIuJTGg%mMn8">
                                                              <field name="OP">NEQ</field>
                                                              <value name="A">
        <block type="get_value" id="Dac0C!co=@NsOer[Pvn~">
        <field name="OID">netatmo.0.Wohnbereich-(Innen).Regen.Rain.Rain</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="math_number" id="bv[S6JBf|Tk+kbbVnSJR">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                            <block type="control" id="358e!BIjwBL?s3R$NVKJ">
        <block type="text" id="E5BZT|~^dqNWTMPBYH}a">
        <field name="TEXT">PARK_UNTIL_FURTHER_NOTICE</field>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  DaHu
                                  #1038
                                  @kaiman55 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
        <xml xmlns="https://developers.google.com/blockly/xml">        <block type="comment" id="!5#EPV5tY!uMs.c:xRKl" x="-1487" y="-1312">        <field name="COMMENT">Mählanie bei Regen/Trockenheit rein und raus</field>        <next>        <block type="on_ext" id="Ps5%H5|sm,lZR5Mx~u]2">        <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation>        <field name="CONDITION">ne</field>        <field name="ACK_CONDITION"></field>        <value name="OID0">        <shadow type="field_oid" id="Fhv0CaM~0KQi1#h)-K=K">        <field name="oid">netatmo.0.Wohnbereich-(Innen).Regen.Rain.SumRain1</field>        </shadow>        </value>        <statement name="STATEMENT">        <block type="comment" id="`H(zJXb|OgmoBpa=o*Id">        <field name="COMMENT">Mähen fortsetzen wenn es die letzte Stunde trocken war und rausschicken</field>        <next>        <block type="controls_if" id="kMv#PEDhcxz[S7_+j$:A">        <value name="IF0">        <block type="logic_operation" id="6?)|+@t.Z7w{fL;8ODH}" inline="false">        <field name="OP">AND</field>        <value name="A">        <block type="logic_compare" id="{zT!Dnt-6jBo5tofA36z">        <field name="OP">EQ</field>        <value name="A">        <block type="get_value" id="yu]AGvIi!8k]4_aQmx5s">        <field name="ATTR">val</field>        <field name="OID">netatmo.0.Wohnbereich-(Innen).Regen.Rain.SumRain1</field>        </block>        </value>        <value name="B">        <block type="math_number" id="FW{XQ]B(v387y7yZ]Ovs">        <field name="NUM">0</field>        </block>        </value>        </block>        </value>        <value name="B">        <block type="logic_compare" id="9`D18YFlpB1ZPD^Y%c(A">        <field name="OP">EQ</field>        <value name="A">        <block type="get_value" id="(MaIwHj8ttq`64|xLZH_">        <field name="ATTR">val</field>        <field name="OID">smartgarden.0.LOCATION_2d4c7365-2D809c-2D4c18-2D91c9-2D8362146ac8f5.DEVICE_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.SERVICE_MOWER_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.activity_mowing_i</field>        </block>        </value>        <value name="B">        <block type="logic_boolean" id="2nV[8E/H:+S9;jideC5}">        <field name="BOOL">FALSE</field>        </block>        </value>        </block>        </value>        </block>        </value>        <statement name="DO0">        <block type="control" id="r?Ws.R4O#`(%{.]6]IEy">        <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation>        <field name="OID">smartgarden.0.LOCATION_2d4c7365-2D809c-2D4c18-2D91c9-2D8362146ac8f5.DEVICE_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.SERVICE_MOWER_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.activity_control_i</field>        <field name="WITH_DELAY">FALSE</field>        <value name="VALUE">        <block type="text" id=")4/Q=nS46)(.v?~gG,*T">        <field name="TEXT">START_DONT_OVERRIDE</field>        </block>        </value>        </block>        </statement>        <next>        <block type="comment" id="+jz?xHrG/M|6f42myVBx">        <field name="COMMENT">Mäher bei aktiven Regen beenden und in die Hütte schicken</field>        <next>        <block type="controls_if" id="i|[`4tT!fw=x*8!O|*r8">        <value name="IF0">        <block type="logic_compare" id="/N]7?]TkkIuJTGg%mMn8">        <field name="OP">NEQ</field>        <value name="A">        <block type="get_value" id="Dac0C!co=@NsOer[Pvn~">        <field name="ATTR">val</field>        <field name="OID">netatmo.0.Wohnbereich-(Innen).Regen.Rain.Rain</field>        </block>        </value>        <value name="B">        <block type="math_number" id="bv[S6JBf|Tk+kbbVnSJR">        <field name="NUM">0</field>        </block>        </value>        </block>        </value>        <statement name="DO0">        <block type="control" id="358e!BIjwBL?s3R$NVKJ">        <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation>        <field name="OID">smartgarden.0.LOCATION_2d4c7365-2D809c-2D4c18-2D91c9-2D8362146ac8f5.DEVICE_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.SERVICE_MOWER_03630692-2Dce44-2D461e-2Daf24-2D63e5f5f5076c.activity_control_i</field>        <field name="WITH_DELAY">FALSE</field>        <value name="VALUE">        <block type="text" id="E5BZT|~^dqNWTMPBYH}a">        <field name="TEXT">PARK_UNTIL_FURTHER_NOTICE</field>        </block>        </value>        </block>        </statement>        </block>        </next>        </block>        </next>        </block>        </next>        </block>        </statement>        </block>        </next>        </block>        </xml>
                                  "Mählanie"....😂 😂 😂 😂 Ich brüll mich gerade weg. Es gibt noch mehr Freaks wie ich auf diesem Planeten. 🤜 🤛
                                  • jpgorganizerJ jpgorganizer
                                    Hallo liebe ioBroker Gemeinde,
                                    da Gardena in 2019 eine Websocket Schnittstelle für die Smart Geräte wie Mähroboter, Bewässerungsanlage (smart irrigation control) veröffentlicht hat und es m.W. noch keinen Adapter dafür gibt, habe ich in den vergangenen Wochen einen Adapter dafür entwickelt.
                                    Ich bitte euch nun diesen zu testen. Für Fragen, Fehler etc. bitte diesen Thread nutzen. Ich werde versuchen die Fragen zu beantworten und auch Fehler zu beheben.
                                    Der Adapter liegt in github unter https://github.com/jpgorganizer/ioBroker.smartgarden.
                                    Viele Grüße
                                    jpgorganizer
                                    Sleepwalker
                                    #1039
                                    Moin,
                                    ich bin gerade auf der Suche nach einem Mähroboter für unseren 2-zonigen Garten, ca. 500m² + 80m². Ein Punkt ist die Integration in ioBroker. Aktuell steht der Sileno Life 1000m² mit Lona auf Platz 1 meiner persönlichen Rangliste. Und da bin ich auf diesen Adapter gestroßen. Was genau mit Alexa und dem Skill machbar ist, konnte ich noch nicht herausfinden.
                                    Allerdings wirkt die Entwicklung dieses Adapters eingestellt, oder täusche ich mich? Falls nicht, gibt es Alternativen?
                                    Ich würde den Mäher gerne:
                                    • bei Regen per ioBroker rein holen (er hat ja keinen eigenen Regensensor)
                                    • manuell in eine bestimmte Zone schicken, denn die 2. Zone ist eher optional für ihn, weil direkt an der Straße mit lediglich 80cm hohem Zaun. Da möchte ich ihn nur fahren lassen, wenn ich zu Hause bin und es manuell anstoße.
                                    • den Hebealarm direkt auslesen können, um darauf reagieren zu können
                                    Gibt es da Möglichkeiten?
                                    Danke und Gruß
                                    • StrathColeS StrathCole
                                      Guten Morgen, alle zusammen.
                                      Ich weiß, dass jpgorganizer gerade an den Ladezeit- und Mähprognosen arbeitet, allerdings brauchte ich für mich ein Skript, das die komplette Zeitplanung aus der Gardena-App ersetzt.
                                      Da ich außerdem eine Bewässerung von Rain Bird habe, die also nicht mit diesem Adapter kombiniert werden kann, habe ich nun ein komplettes Skript geschrieben, das die Steuerung inkl. Vorhersagen usw. übernimmt. Vielleicht ist es ja für den ein oder anderen von euch als Basis interessant. Ich habe versucht, die relevanten Dinge etwas zu kommentieren.
                                      Da das Skript ausschließlich mit diesem Adapter funktioniert, poste ich es mal hier im Thread und nicht separat.
                                      Edit: Skript auf github ausgelagert
                                      Es befindet sich noch in einer sehr frühen Phase, kann also sein, dass es noch ein paar Fehler enthält. Die jeweils aktuelle Version findet ihr hier auf github: https://github.com/StrathCole/smartgarden.schedule/blob/master/sg_schedule.js
                                      Dort könnt ihr auch Wünsche oder Anmerkungen/Fehler hinterlassen, damit wir diesen Thread nicht "kapern" und zumüllen.
                                      So sieht meine rudimentäre Vis dazu dann aus:
                                      michihorn
                                      #1040
                                      @strathcole sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                      Hallo gibt es das Script noch irgendwo, der Github läuft auf 404
                                      Gruß Michael
                                      S H 2 Antworten Letzte Antwort
                                      • M michihorn
                                        Gruß Michael
                                        Sammyray
                                        #1041
                                        Der Adapter funktioniert nur bei Gardena smart system und kann mir nicht bei Geräten der "Gardena Bluetooth App" helfen, oder?
                                        G 1 Antwort Letzte Antwort
                                        • S Sammyray
                                          Gonzokalle
                                          #1042
                                          Habe gerade ein Problem, dass wahrscheinlich nichts mit dem Adapter zu tun hat. Vielleicht ist das Problem ja bekannt. Mein Mähroboter schreibt pünktlich "Unterwegs zum Startpunkt", fährt aber meistens nicht los.
                                          Erst wenn ich ihn manuell parke und wieder starte, fährt es los.
