  3. Einsteigerfragen
  4. [gelöst] frische IOB Installation - WebGUI nicht erreichbar
    5.5k
debian 12webgui
39 Beiträge 6 Kommentatoren 1.8k Aufrufe 6 Beobachtet
    @fierce
    Gib mal die Langfassung vom 'iob diag' zum Besten.
    Fierce
    schrieb am zuletzt editiert von Fierce
    @thomas-braun said in frische IOB Installation - WebGUI nicht erreichbar:
    @fierce
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: Fierce-Server
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.7.7-x64v4-xanmod1
        Architecture: x86-64
     Hardware Vendor: Intel_R_ Client Systems
      Hardware Model: NUC11PAHi5
    Firmware Version: PATGL357.0047.2022.0627.1120
    model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     19:34:26 up 20:31,  2 users,  load average: 2.21, 2.38, 2.46
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Wed 2024-03-06 19:34:26 CET
               Universal time: Wed 2024-03-06 18:34:26 UTC
                     RTC time: Wed 2024-03-06 18:34:26
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    fierce
    /home/fierce
    fierce cdrom floppy sudo audio dip video plugdev users netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:             33G        1.0G         30G        1.8M        1.7G         32G
    Swap:           1.0G          0B        1.0G
    Total:           34G        1.0G         32G
            31752 M total memory
              995 M used memory
              527 M active memory
             1272 M inactive memory
            29560 M free memory
              275 M buffer memory
             1352 M swap cache
              976 M total swap
                0 M used swap
              976 M free swap
    *** FAILED SERVICES ***
      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
    * mnt-plex.mount loaded failed failed /mnt/plex
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs   16G     0   16G   0% /dev
    tmpfs          tmpfs     3.2G  1.2M  3.1G   1% /run
    /dev/nvme0n1p2 ext4      937G   11G  879G   2% /
    tmpfs          tmpfs      16G  4.0K   16G   1% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    efivarfs       efivarfs  192K  111K   77K  59% /sys/firmware/efi/efivars
    /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
    tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    /var:
    6.4G    /var/
    4.7G    /var/lib
    4.5G    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server
    Archived and active journals take up 30.8M in the file system.
    /opt/iobroker/backups:
    2.9M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    111M    /opt/iobroker/iobroker-data/
    71M     /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    37M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    8.5M    /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Fierce-Server                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Fierce-Server                            -  enabled
    + system.adapter.discovery.0              : discovery             : Fierce-Server                            -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Objects and States
    Objects:        147
    States:         105
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 https://downloads.plex.tv/repo/deb public InRelease
    Hit:3 http://ftp.de.debian.org/debian bookworm InRelease
    Hit:4 http://ftp.de.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 http://deb.xanmod.org releases InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37714      20404/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40620      20404/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5228       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4495       622/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      104        10743      599/mosquitto
    tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      999        4524       756/Plex Tuner Serv
    tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      999        7568       581/Plex Media Serv
    tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      104        10748      599/mosquitto
    tcp        0      0 127.0.0.1:37419         0.0.0.0:*               LISTEN      999        9653       703/Plex Plug-in [c
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2094       1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          7547       623/apache2
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4497       622/sshd: /usr/sbin
    tcp6       0      0 :::1883                 :::*                    LISTEN      104        10744      599/mosquitto
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       40656      20423/io.admin.0
    tcp6       0      0 :::8883                 :::*                    LISTEN      104        10749      599/mosquitto
    tcp6       0      0 :::32400                :::*                    LISTEN      999        7566       581/Plex Media Serv
    udp        0      0 192.168.178.64:44371    0.0.0.0:*                           999        7622       581/Plex Media Serv
    udp        0      0 192.168.178.64:47242    0.0.0.0:*                           999        7626       581/Plex Media Serv
    udp        0      0 0.0.0.0:32410           0.0.0.0:*                           999        8523       581/Plex Media Serv
    udp        0      0 0.0.0.0:32412           0.0.0.0:*                           999        8524       581/Plex Media Serv
    udp        0      0 0.0.0.0:32413           0.0.0.0:*                           999        7620       581/Plex Media Serv
    udp        0      0 0.0.0.0:32414           0.0.0.0:*                           999        8522       581/Plex Media Serv
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2585       573/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5229       1/init
    udp        0      0 127.0.0.1:49402         0.0.0.0:*                           999        7621       581/Plex Media Serv
    udp        0      0 0.0.0.0:1901            0.0.0.0:*                           999        7625       581/Plex Media Serv
    udp        0      0 127.0.0.1:54911         0.0.0.0:*                           999        7623       581/Plex Media Serv
    udp        0      0 192.168.178.64:39558    0.0.0.0:*                           999        7624       581/Plex Media Serv
    udp6       0      0 :::111                  :::*                                0          8221       1/init
    2024-03-06 19:30:30.431  - info: host.Fierce-Server 3 instances found
    2024-03-06 19:30:30.433  - info: host.Fierce-Server starting 3 instances
    2024-03-06 19:30:30.482  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewest"
    2024-03-06 19:30:30.486  - info: host.Fierce-Server instance system.adapter.admin.0 started with pid 20423
    2024-03-06 19:30:30.527  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewestNext"
    2024-03-06 19:30:30.528  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmCurrent"
    2024-03-06 19:30:30.529  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewest"
    2024-03-06 19:30:30.530  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewestNext"
    2024-03-06 19:30:30.530  - info: host.Fierce-Server Some obsolete host states deleted.
    2024-03-06 19:30:30.870  - info: admin.0 (20423) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.19
    2024-03-06 19:30:30.877  - info: admin.0 (20423) requesting all objects
    2024-03-06 19:30:30.983  - info: admin.0 (20423) received all objects
    2024-03-06 19:30:31.042  - info: admin.0 (20423) socket.io server listening on port 8081
    2024-03-06 19:30:31.043  - info: admin.0 (20423) http server listening on port 8081
    2024-03-06 19:30:31.043  - info: admin.0 (20423) Use link "http://127.0.0.1:8081" to configure.
    2024-03-06 19:30:32.312  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
    2024-03-06 19:30:32.313  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-03-06 19:30:32.313  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.0
    2024-03-06 19:30:32.314  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
    2024-03-06 19:30:34.377  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    2024-03-06 19:30:34.439  - info: host.Fierce-Server instance system.adapter.backitup.0 started with pid 20450
    2024-03-06 19:30:34.755  - info: backitup.0 (20450) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.19
    2024-03-06 19:30:34.766  - info: backitup.0 (20450) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-03-06 19:30:38.438  - info: host.Fierce-Server instance system.adapter.discovery.0 started with pid 20477
    2024-03-06 19:30:38.783  - info: discovery.0 (20477) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.19
    @fierce
    sudo systemctl set-default multi-user.target
    Und was versprichst du dir von dem Kernel?
    Der Kernel ist Empfehlung aus der Plex Comunity. Soll fürs Medienstreaming Vorteile habe :man-shrugging:
    fierce@Fierce-Server:~$ sudo systemctl set-default multi-user.target
    Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
    Fehler im Log-File bleibt bestehen und WebGUI weiterhin nicht aufrufbar...
    fierce@Fierce-Server:/opt/iobroker$ iob restart
    fierce@Fierce-Server:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
    • F Fierce
      @fierce
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: desktop 🖥️
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      fierce
      /home/fierce
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           34G        1.0G         32G
                995 M used memory
                527 M active memory
              29560 M free memory
                275 M buffer memory
               1352 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FILESYSTEM ***
      /var:
      6.4G    /var/
      4.7G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        147
      States:         105
      Pending Updates: 1
      @fierce
      @fierce
      sudo usermod -a -G adm fierce
      sudo apt update
      iob stop
      sudo apt full-upgrade
      fierce einmal aus und wieder einloggen.
      Ansonsten schaut das eigentlich okay aus.
      F 1 Antwort Letzte Antwort
        @fierce
        sudo apt update
        iob stop
        Fierce
        fierce@Fierce-Server:/opt/iobroker$ sudo usermod -a -G adm fierce
        [sudo] Passwort für fierce:
        fierce@Fierce-Server:/opt/iobroker$ sudo apt update
        OK:1 http://security.debian.org/debian-security bookworm-security InRelease
        OK:2 https://downloads.plex.tv/repo/deb public InRelease
        OK:3 http://ftp.de.debian.org/debian bookworm InRelease
        OK:4 http://ftp.de.debian.org/debian bookworm-updates InRelease
        OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        OK:6 http://deb.xanmod.org releases InRelease
        Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
        fierce@Fierce-Server:/opt/iobroker$ iob stop
        fierce@Fierce-Server:/opt/iobroker$ sudo apt full-upgrade
        Paketaktualisierung (Upgrade) wird berechnet… Fertig
          nodejs
        1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen noch 0 B von 29,8 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 54,3 kB Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n] j
        Changelogs werden gelesen... Fertig
        (Lese Datenbank ... 109430 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../nodejs_18.19.1-1nodesource1_amd64.deb ...
        Detected old npm client, removing...
        Entpacken von nodejs (18.19.1-1nodesource1) über (18.19.0-1nodesource1) ...
        nodejs (18.19.1-1nodesource1) wird eingerichtet ...
        Trigger für man-db (2.11.2-2) werden verarbeitet ...
        fierce@Fierce-Server:/opt/iobroker$ sudo systemctl reboot
        Leider immernoch das gleiche Fehlerbild. Die WebGUI ist einfach nicht aufrufbar...
        • F Fierce
            nodejs
          Fierce
          Noch irgendjemand eine Idee wo man schauen oder was man prüfen könnte ? Den einzigen Fehler den ich gefunden habe ist der folgende aber ich kann nicht einschätzen ob der wirklich dafür verantwortlich ist das die WebGUI nicht aufrufbar ist...
          2024-03-07 21:53:02.596  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
          2024-03-07 21:53:02.598  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
          2024-03-07 21:53:02.598  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
          2024-03-07 21:53:02.598  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
          2024-03-07 21:53:04.661  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          scheinbar wird aber auf den Ports gelauscht
          fierce@Fierce-Server:~$ sudo netstat -tulnp
          Aktive Internetverbindungen (Nur Server)
          Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      596/mosquitto
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      604/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      1/init
          tcp        0      0 127.0.0.1:39819         0.0.0.0:*               LISTEN      703/Plex Plug-in [c
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      555/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      555/iobroker.js-con
          tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      596/mosquitto
          tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      760/Plex Tuner Serv
          tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      576/Plex Media Serv
          tcp6       0      0 :::1883                 :::*                    LISTEN      596/mosquitto
          tcp6       0      0 :::22                   :::*                    LISTEN      604/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      623/apache2
          tcp6       0      0 :::111                  :::*                    LISTEN      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      731/io.admin.0
          tcp6       0      0 :::8883                 :::*                    LISTEN      596/mosquitto
          tcp6       0      0 :::32400                :::*                    LISTEN      576/Plex Media Serv
          udp        0      0 192.168.178.64:43086    0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 0.0.0.0:32410           0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 0.0.0.0:32412           0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 0.0.0.0:32413           0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 0.0.0.0:32414           0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           611/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           1/init
          udp        0      0 127.0.0.1:34595         0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 0.0.0.0:1901            0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 192.168.178.64:34690    0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 192.168.178.64:35225    0.0.0.0:*                           576/Plex Media Serv
          udp        0      0 127.0.0.1:56280         0.0.0.0:*                           576/Plex Media Serv
          udp6       0      0 :::111                  :::*                                1/init
          mcm1957M 2 Antworten Letzte Antwort
          • F Fierce
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            @apollon77
            Hast du da eine Idee?
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • apollon77A Offline
              Naja im ersten schritt ,al das echte Logfile ansehen und nicht während ein ioBroker läuft noch versuchen einen zweiten zu starten. Das KANN nur schieff gehen. :-)
              Ein "iobroker restart" bewirkt das der iobroker systemd servcei restartet und damit läuft ein ioBroker doch schon. Dann nochmal einen Starten gibt erwartungsgemäss den DB Lock Fehler.
              Also ... was steht denn so im Logfile unter /opt/iobroker/log/... ?
              • apollon77A apollon77
                Fierce
                @apollon77
                Hatte schon mehrfach gestoppt und gestartet bzw. den rechner neugestartet. Aufgrund meiner ratlosigkeit hatte ich mich auf den Fehler konzentriert.
                fierce@Fierce-Server:/opt/iobroker/log$ ls -l
                insgesamt 24
                -rw-rwxr--+ 1 iobroker iobroker 1451  5. Mär 21:13 iobroker.2024-03-04.log.gz
                -rw-rw-r--+ 1 iobroker iobroker 5056  6. Mär 19:30 iobroker.2024-03-05.log.gz
                -rw-rw-r--+ 1 iobroker iobroker 1909  7. Mär 19:24 iobroker.2024-03-06.log.gz
                -rw-rw-r--+ 1 iobroker iobroker 1661  7. Mär 21:53 iobroker.2024-03-07.log
                -rw-rwxr--+ 1 iobroker iobroker 1001  7. Mär 19:24 iobroker-audit.json
                lrwxrwxrwx  1 fierce   fierce     23  7. Mär 21:53 iobroker.current.log -> iobroker.2024-03-07.log
                fierce@Fierce-Server:/opt/iobroker/log$ cat iobroker.2024-03-07.log
                2024-03-07 19:24:34.759  - info: admin.0 (731) Request actual repository...
                2024-03-07 19:24:34.832  - info: host.Fierce-Server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2024-03-07 19:24:37.050  - info: admin.0 (731) Repository received successfully.
                2024-03-07 21:52:54.004  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                2024-03-07 21:52:54.005  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2024-03-07 21:52:54.005  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                2024-03-07 21:52:54.006  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                2024-03-07 21:52:56.068  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                fierce@Fierce-Server:/opt/iobroker/log$ iob stop
                fierce@Fierce-Server:/opt/iobroker/log$ iob start
                insgesamt 32
                -rw-rw-r--+ 1 iobroker iobroker  493  8. Mär 14:16 iobroker.2024-03-07.log.gz
                -rw-rw-r--+ 1 iobroker iobroker 5738  8. Mär 14:16 iobroker.2024-03-08.log
                -rw-rwxr--+ 1 iobroker iobroker 1001  8. Mär 14:16 iobroker-audit.json
                lrwxrwxrwx  1 iobroker iobroker   23  8. Mär 14:16 iobroker.current.log -> iobroker.2024-03-08.log
                fierce@Fierce-Server:/opt/iobroker/log$ cat iobroker.2024-03-08.log
                2024-03-08 14:16:27.813  - info: host.Fierce-Server received SIGTERM
                2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.admin.0 (force=false, process=true)
                2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.backitup.0 (force=false, process=true)
                2024-03-08 14:16:27.815  - info: host.Fierce-Server stopInstance system.adapter.discovery.0 (force=false, process=true)
                2024-03-08 14:16:27.813  - info: admin.0 (731) terminating http server on port 8081
                2024-03-08 14:16:27.813  - info: backitup.0 (838) cleaned everything up...
                2024-03-08 14:16:27.817  - info: host.Fierce-Server stopInstance system.adapter.admin.0 send kill signal
                2024-03-08 14:16:27.817  - info: admin.0 (731) Got terminate signal TERMINATE_YOURSELF
                2024-03-08 14:16:27.818  - info: backitup.0 (838) Got terminate signal TERMINATE_YOURSELF
                2024-03-08 14:16:27.818  - info: admin.0 (731) terminating
                2024-03-08 14:16:27.818  - info: backitup.0 (838) terminating
                2024-03-08 14:16:27.818  - info: backitup.0 (838) Terminated (NO_ERROR): Without reason
                2024-03-08 14:16:27.818  - info: admin.0 (731) Terminated (NO_ERROR): Without reason
                2024-03-08 14:16:27.818  - info: discovery.0 (900) Got terminate signal TERMINATE_YOURSELF
                2024-03-08 14:16:27.821  - info: discovery.0 (900) terminating
                2024-03-08 14:16:27.821  - info: discovery.0 (900) Terminated (NO_ERROR): Without reason
                2024-03-08 14:16:27.859  - info: host.Fierce-Server stopInstance system.adapter.backitup.0 send kill signal
                2024-03-08 14:16:27.859  - info: host.Fierce-Server stopInstance system.adapter.discovery.0 send kill signal
                2024-03-08 14:16:28.315  - info: discovery.0 (900) terminating
                2024-03-08 14:16:28.319  - info: admin.0 (731) terminating
                2024-03-08 14:16:28.319  - info: backitup.0 (838) terminating
                2024-03-08 14:16:28.332  - info: host.Fierce-Server instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                2024-03-08 14:16:28.333  - info: host.Fierce-Server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                2024-03-08 14:16:28.377  - info: host.Fierce-Server instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                2024-03-08 14:16:28.377  - info: host.Fierce-Server All instances are stopped.
                2024-03-08 14:16:28.463  - info: host.Fierce-Server terminated
                2024-03-08 14:16:45.183  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                2024-03-08 14:16:45.185  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2024-03-08 14:16:45.185  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                2024-03-08 14:16:45.185  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                2024-03-08 14:16:45.509  - info: host.Fierce-Server connected to Objects and States
                2024-03-08 14:16:45.514  - info: host.Fierce-Server added notifications configuration of host
                2024-03-08 14:16:45.660  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeCurrent"
                2024-03-08 14:16:45.660  - info: host.Fierce-Server 3 instances found
                2024-03-08 14:16:45.662  - info: host.Fierce-Server starting 3 instances
                2024-03-08 14:16:45.710  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewest"
                2024-03-08 14:16:45.714  - info: host.Fierce-Server instance system.adapter.admin.0 started with pid 7346
                2024-03-08 14:16:45.755  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.nodeNewestNext"
                2024-03-08 14:16:45.756  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmCurrent"
                2024-03-08 14:16:45.757  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewest"
                2024-03-08 14:16:45.758  - info: host.Fierce-Server Delete state "system.host.Fierce-Server.versions.npmNewestNext"
                2024-03-08 14:16:45.758  - info: host.Fierce-Server Some obsolete host states deleted.
                2024-03-08 14:16:46.105  - info: admin.0 (7346) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
                2024-03-08 14:16:46.112  - info: admin.0 (7346) requesting all objects
                2024-03-08 14:16:46.215  - info: admin.0 (7346) received all objects
                2024-03-08 14:16:46.257  - info: admin.0 (7346) Request actual repository...
                2024-03-08 14:16:46.263  - info: admin.0 (7346) socket.io server listening on port 8081
                2024-03-08 14:16:46.263  - info: admin.0 (7346) http server listening on port 8081
                2024-03-08 14:16:46.264  - info: admin.0 (7346) Use link "http://127.0.0.1:8081" to configure.
                2024-03-08 14:16:46.324  - info: host.Fierce-Server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2024-03-08 14:16:48.765  - info: admin.0 (7346) Repository received successfully.
                2024-03-08 14:16:49.670  - info: host.Fierce-Server instance system.adapter.backitup.0 started with pid 7373
                2024-03-08 14:16:49.987  - info: backitup.0 (7373) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
                2024-03-08 14:16:50.018  - info: backitup.0 (7373) [iobroker] backup will be activated at 02:48 every 1 day(s)
                2024-03-08 14:16:53.669  - info: host.Fierce-Server instance system.adapter.discovery.0 started with pid 7389
                2024-03-08 14:16:54.011  - info: discovery.0 (7389) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
                in dem log zeigt er kein fehler mehr, beim "node" aber schon
                2024-03-08 14:23:10.139  - info: host.Fierce-Server iobroker.js-controller version 5.0.19 js-controller starting
                2024-03-08 14:23:10.141  - info: host.Fierce-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                2024-03-08 14:23:10.141  - info: host.Fierce-Server hostname: Fierce-Server, node: v18.19.1
                2024-03-08 14:23:10.141  - info: host.Fierce-Server ip addresses: 192.168.178.64 2003:fc:570d:3100:7eb5:66ff:fee9:f6b fe80::7eb5:66ff:fee9:f6b
                2024-03-08 14:23:12.204  - error: host.Fierce-Server-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                WebGUI weiterhin nicht erreichbar (Zeitüberschreitung)
                • F Fierce
                  @apollon77
                  insgesamt 24
                  insgesamt 32
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  @fierce
                  Na ja node node_modules/iobroker.js-controller/controller.js --logs startet ja eine neue, zweite Instanz des js-controllers. Da ist es eigentlich klar, dass ein Locking Fehler auftreten muss.
                  node ... ist KEIN Instrument um sich logs anzusehen falls das der Irrtum ist.
                  mcm1957M F 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    @fierce
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    Da du eine Zeitüberschreitung bekommst:
                    Bist du sicher, dass dein ioBroker Rechner von jenem Rechner auf dem der Browser läuft erreichbar ist?
                    Ich nehme mal an, der Browser läuft auf einem Windows PC.
                    • Funktioniert ein ping vom Windows PC auf den ioBroker NUC?
                    • Steigst du via ssh von deinem Windows PC auf die Commandline des NUC ein oder loggst du dich am NUC mittels lokalem Keyboard + Bildschirm ein?
                    • Hast du irgendwo im LAN ein Firewall die die Verbindung blockieren könnte?
                    • mcm1957M mcm1957
                      @fierce
                      Fierce
                      @mcm57 sagte in frische IOB Installation - WebGUI nicht erreichbar:
                      @fierce
                      Danke für die Erläuterung das macht etwas klarer was ich da eigentlich gemacht habe 😌
                      Der Rechner ist ein Intel NUC 11, auf dem läuft auch mein Plex-Server (Medien-Server). Der Plex Server ist von mehreren Geräte im LAN aus erreichbar und ja ich gehe von dem gleichen Rechner mit ssh auf den NUC mit dem ich auch versuche den ioBroker im Browser (http://192.168.178.64:8081) aufzurufen. Ich hab verschiedene Browser und den Aufruf von diesem Rechner als auch vom Smartphone versucht. Ping ist erfolgreich, eine Firewall im LAN selber hab ich nicht.
                      C:\Users\Fierce>ping 192.168.178.64
                      Ping wird ausgeführt für 192.168.178.64 mit 32 Bytes Daten:
                      Antwort von 192.168.178.64: Bytes=32 Zeit=79ms TTL=64
                      Antwort von 192.168.178.64: Bytes=32 Zeit=94ms TTL=64
                      Antwort von 192.168.178.64: Bytes=32 Zeit=49ms TTL=64
                      Antwort von 192.168.178.64: Bytes=32 Zeit=16ms TTL=64
                      Ping-Statistik für 192.168.178.64:
                          Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                          (0% Verlust),
                      Ca. Zeitangaben in Millisek.:
                          Minimum = 16ms, Maximum = 94ms, Mittelwert = 59ms
                      C:\Users\Fierce>
                      • F Fierce
                        @fierce
                            (0% Verlust),
                        C:\Users\Fierce>
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @fierce
                        Ein reiner "versuchs mas halt" Versuch :-)
                        Am nuc hast du ja keinen Browser (mangel UI, ok soweit).
                        Versuch mal mit curl localhost:8081 abzurufen und schau ob / was passiert.
                        Und auch curl 192.168.178.64:8081 vom Windows PC aus sollte gehen.
                        Ich hab im Moment keine Idee ob der Webserver des Admin nicht mag oder du den Rechner doch nicht erreichst - warum auch immer.
                        • mcm1957M mcm1957
                          @fierce
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          Moment mal
                          Was mir grad auffällt:
                          Auf Port 8081 wird nur mittel :::8081 gelauscht. Bin nicht 100% sicher, aber das sieht nach nur IPv6 aus.
                          Hab aber keine Ahnung ob man dem Admin irgendwie sagen kann schau nur auf IPv6 ...
                          IPv4 hast du ja hoffentlich nicht urgendwie auf Linux Ebene beschränkt / deaktiviert.
                          • mcm1957M mcm1957
                            Moment mal
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            Kann es sein, dass du da ev. IPv6 ausgewählt hast?
                            Frag mich aber nicht wie man das ändern kann wenn man keine Zugriff via GUI mehr hat :-(
                            • mcm1957M mcm1957
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              Ev. versuch den Rechner mal auf seine IPv6 Addresse anzusprechen.
                              Oder richte testweise mal eine zweite Admin Instanz ein
                                mach doch mal folgendes
                                1.) iob stop
                                2.) lösche mal das Logfile (nicht das "current" sondern das mit Datum von heute)
                                3.) iob start
                                Dann warten ... dann logfile bitte mal vollständig posten. ... und bitte keine parallelen Versuche an der CLI
                                • F Fierce
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @fierce said in frische IOB Installation - WebGUI nicht erreichbar:
                                  @apollon77
                                  Das sieht für mich so aus als würe admin NUR auf IPv6 lauschen - warum auch immer.
                                  Daher die Bitte den Rechner durch mal mittels IPv6 anzurufen ...
                                  • mcm1957M mcm1957
                                    @apollon77
                                    ja, aber das würde das jsonl lock nicht erklären, oder?
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @homoran said in frische IOB Installation - WebGUI nicht erreichbar:
                                      Das mit dem Lock hat sich schon geklärt.
                                      Er hat bei laiufender Instanz via node Befehl (!) den js-controller nochmals gestartet,
                                      Na klar, dass es da zu log Konflikt kommt.
                                      Schau dir die Zeile an wo das lock Konflikt als Output kommt. Hab ioch auch erst später gesehen. Das ist kein Befehl um ein Log auszugeben sondern der volle node Befahl den js-congtroller zu starten ....
                                      ABER
                                      Das mit IPv6 ists auch nicht. Bei meinem PI sieht netstat fast ident aus uns ich (glaub ich) benutze IPv4 Zugriff.
                                      • mcm1957M mcm1957
                                        ABER
                                        echad@chet:~ $ sudo netstat -tulpen
                                        Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        5103987    2786798/mosquitto
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22466317   2081231/iobroker.js
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22466322   2081231/iobroker.js
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12573929   2170053/sshd: /usr/
                                        tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       22471121   2081781/io.sainlogi
                                        tcp        0      0 100.107.71.135:45714    0.0.0.0:*               LISTEN      0          14574724   3044818/tailscaled
                                        tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          12180      805/upsd
                                        tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       22467445   2081437/adb
                                        tcp6       0      0 :::1883                 :::*                    LISTEN      107        5103988    2786798/mosquitto
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          12571486   2170053/sshd: /usr/
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22471766   2081611/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22881105   2126862/io.admin.0
                                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22471421   2081916/io.ws.0
                                        tcp6       0      0 fd7a:115c:a1e0:ab:45714 :::*                    LISTEN      0          14574725   3044818/tailscaled
                                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       22470703   2081502/io.nuki-ext
                                        Aber hier spielt es keine Rolle, weil hier auch alles per IPv6 unterwegs ist (was es kann, jedenfalls).
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          Na ja,
                                          Er versucht das Admin Interface ja per IPv4 Addressangabe aufzurufen. (Siehe erstes Post)
                                          Schaltets das irgendwer intern dann auf IPv6 Kommunikation um? Ich dachte wenn ich im Webbrowser http://102.168.178.64:8081 eintippe dann benutzt das System zwingend IPv4.
                                          Aber offensichtlich interpretiere ich den IPv6 Wildcard falsch.
                                          Danke Thomas
