  3. Off Topic
  4. Android VIS läuft nicht mehr wegen doppelter Portvergabe
    6.0k
13 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
    @herrfrodo sagte in Android VIS läuft nicht mehr:
    Könnte es möglich sein, dass das Tab den Port :8086 benutzt hat,
    sag du es uns!
    steht im iob diag
    HerrFrodo
    Danke für Deine schnelle Antwort!
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     10:10:56 up 15:02,  1 user,  load average: 1.37, 2.17, 2.25
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-02-23 10:10:56 CET
               Universal time: Fri 2024-02-23 09:10:56 UTC
                     RTC time: Fri 2024-02-23 09:10:56
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.7G        480M        6.0M        623M        1.0G
    Swap:            99M         98M        1.0M
    Total:          3.9G        2.8G        482M
             3793 M total memory
             2689 M used memory
              991 M active memory
             1977 M inactive memory
              480 M free memory
               13 M buffer memory
              609 M swap cache
               99 M total swap
               98 M used swap
                1 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                         Type      Size  Used Avail Use% Mounted on
    /dev/root                          ext4       14G  5.9G  7.3G  45% /
    devtmpfs                           devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs                              tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs                              tmpfs     759M   19M  741M   3% /run
    tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                          vfat      253M   31M  222M  13% /boot
    192.168.1.15:/volume1/raspibackups nfs4      7.0T  4.0T  3.1T  57% /backup
    tmpfs                              tmpfs     380M     0  380M   0% /run/user/1000
    [Thu Feb 22 19:08:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6B:79:23 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=fdb672ac-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Feb 22 19:08:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Feb 22 19:08:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Feb 22 19:08:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET    SOURCE                             FSTYPE OPTIONS
    /         /dev/sda2                          ext4   rw,noatime,commit=600,stripe=8191
    |-/boot   /dev/sda1                          vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/backup 192.168.1.15:/volume1/raspibackups nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.1.104,local_lock=none,addr=192.168.1.15
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    1.8G    /var/
    884M    /var/lib
    787M    /var/cache
    781M    /var/cache/apt
    681M    /var/cache/apt/archives
    Archived and active journals take up 17.4M in the file system.
    /opt/iobroker/backups:
    198M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    356M    /opt/iobroker/iobroker-data/
    232M    /opt/iobroker/iobroker-data/files
    80M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    32M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    13M     /opt/iobroker/iobroker-data/states.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
      system.adapter.apg-info.0               : apg-info              : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
    + system.adapter.luxtronik2.0             : luxtronik2            : raspberrypi                              -  enabled, port: 8214
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.1.104
      system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 192.168.1.104
      system.adapter.mqtt.2                   : mqtt                  : raspberrypi                              - disabled, port: 1885, bind: 192.168.1.104
      system.adapter.mqtt.3                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 192.168.1.104
      system.adapter.mqtt.4                   : mqtt                  : raspberrypi                              - disabled, port: 1887, bind: 192.168.1.104
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.odl.1                    : odl                   : raspberrypi                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              - disabled
    + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled
    + system.adapter.signal-cmb.1             : signal-cmb            : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1887, bind: 0.0.0.0
      system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
    + system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "apg-info"     : 0.1.5    , installed 0.1.5
    Adapter    "backitup"     : 2.10.11  , installed 2.9.8  [Updatable]
    Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "odl"          : 3.0.1    , installed 3.0.1
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "tibberlink"   : 2.2.1    , installed 2.2.1
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        11470
    States:         9267
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.1.104:1883      0.0.0.0:*               LISTEN      1001       1015178    15717/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1012394    13586/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1011415    13586/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14563      791/sshd: /usr/sbin
    tcp        0      0 192.168.1.104:42010     0.0.0.0:*               LISTEN      1001       1014988    15498/io.hm-rpc.1
    tcp        0      0 192.168.1.104:42001     0.0.0.0:*               LISTEN      1001       1014383    15483/io.hm-rpc.0
    tcp        0      0 192.168.1.104:42000     0.0.0.0:*               LISTEN      1001       1015921    15518/io.hm-rpc.2
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15564      856/dnsmasq
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       1014439    15441/node-red
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       1017008    15831/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14574      791/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        1011518    14024/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1014150    14493/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1019263    16076/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1018679    16100/io.ws.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        1011385    13531/influxd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1452       371/avahi-daemon: r
    udp        0      0 0.0.0.0:54649           0.0.0.0:*                           108        1454       371/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15563      856/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15560      856/dnsmasq
    udp6       0      0 :::5353                 :::*                                108        1453       371/avahi-daemon: r
    udp6       0      0 :::53474                :::*                                108        1455       371/avahi-daemon: r
    2024-02-23 09:07:34.725  - info: ws.0 (16100) ==> Connected system.user.admin from ::ffff:192.168.1.64
    2024-02-23 09:07:34.819  - info: ws.0 (16100) <== Disconnect system.user.admin from ::ffff:192.168.1.64
    2024-02-23 09:07:36.647  - info: ws.0 (16100) ==> Connected system.user.admin from ::ffff:192.168.1.64
    2024-02-23 09:07:37.850  - info: ws.0 (16100) ==> Connected system.user.admin from ::ffff:192.168.1.64
    2024-02-23 09:07:42.195  - error: ws.0 (16100) Invalid pattern on subscribe: The pattern "µg/m³" is not a valid ID pattern
    2024-02-23 09:12:27.202  - info: luxtronik2.0 (15582) State value to set for "luxtronik2.0.Informationen.Anlagenstatus.Betriebszustand" has to be type "number" but received type "string"
    2024-02-23 09:17:29.796  - info: admin.0 (14493) ==> Connected system.user.admin from ::ffff:192.168.1.64
    2024-02-23 09:17:32.642  - info: admin.0 (14493) <== Disconnect system.user.admin from ::ffff:192.168.1.64
    2024-02-23 09:17:35.907  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-02-23 09:26:37.207  - info: host.raspberrypi instance system.adapter.odl.1 started with pid 24458
    2024-02-23 09:26:42.077  - info: odl.1 (24458) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.odl, node: v18.19.1, js-controller: 5.0.17
    2024-02-23 09:26:46.558  - info: odl.1 (24458) Terminated (NO_ERROR): Without reason
    2024-02-23 09:26:47.326  - info: host.raspberrypi instance system.adapter.odl.1 terminated with code 0 (NO_ERROR)
    2024-02-23 09:27:43.806  - error: luxtronik2.0 (15582) Luxtronik read error, will retry later: Error: heatpump busy - state: 1
    2024-02-23 09:30:00.044  - info: javascript.0 (15189) script.js.common.Astro: Astro: Gültige Zeiten: [aktueller Tag: 8] | [nächster Tag: 6] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
    2024-02-23 09:30:00.061  - info: host.raspberrypi instance system.adapter.luftdaten.0 started with pid 24516
    2024-02-23 09:30:03.741  - info: luftdaten.0 (24516) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.19.1, js-controller: 5.0.17
    2024-02-23 09:30:08.327  - info: luftdaten.0 (24516) Terminated (NO_ERROR): Without reason
    2024-02-23 09:30:08.882  - info: host.raspberrypi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2024-02-23 10:00:00.036  - info: javascript.0 (15189) script.js.common.Astro: Astro: Gültige Zeiten: [aktueller Tag: 8] | [nächster Tag: 6] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
    2024-02-23 10:00:00.072  - info: host.raspberrypi instance system.adapter.luftdaten.0 started with pid 24957
    2024-02-23 10:00:03.725  - info: luftdaten.0 (24957) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.19.1, js-controller: 5.0.17
    2024-02-23 10:00:09.507  - info: luftdaten.0 (24957) Terminated (NO_ERROR): Without reason
    2024-02-23 10:00:10.095  - info: host.raspberrypi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2024-02-23 10:03:52.350  - info: luxtronik2.0 (15582) State value to set for "luxtronik2.0.Informationen.Anlagenstatus.Betriebszustand" has to be type "number" but received type "string"
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: **8086**
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: **8086**, bind: 0.0.0.0, run as: admin
    Wo ein Wille ist, ist auch ein LAN!
    • H HerrFrodo
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         98M        1.0M
               3793 M total memory
               2689 M used memory
                991 M active memory
                480 M free memory
                 13 M buffer memory
                609 M swap cache
                 99 M total swap
                 98 M used swap
                  1 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.8G    /var/
      884M    /var/lib
      787M    /var/cache
      781M    /var/cache/apt
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11470
      States:         9267
      Pending Updates: 0
      @herrfrodo und 8086 ist sogar 2x fettgedruckt.
      Also 1x ändern
      H 1 Antwort Letzte Antwort
        Also 1x ändern
        HerrFrodo
        schrieb am zuletzt editiert von HerrFrodo
        @homoran said in Android VIS läuft nicht mehr:
        Weil ich es markiert habe :-) Wäre doch toll, wenn DIAG das selber könnte :-)
        Also 1x ändern
        Welchen und wie?
        • H HerrFrodo
          Also 1x ändern
          Welchen und wie?
          @herrfrodo sagte in Android VIS läuft nicht mehr wegen doppelter Portvergabe:
          ich hab mich schon gewundert!
          im code kann man nicht fett darstellen :-)
          ob es in der Anzeige bei Doppeltbelegung direkt rot o.ä. auffällig dargestellt werden könnte müsste @thomas-braun wissen
          • H HerrFrodo
            Also 1x ändern
            Welchen und wie?
            Welchen und wie?
            bei Influx weiss ich es nicht, bei socketio in den Einstellungen.
            ggf. beim Web Adapter.
            Ich kenne deine Konfigurationen ja nicht.
            socketio sollte sowieso gegen ws ausgetauscht sein.
              @homoran sagte in Android VIS läuft nicht mehr wegen doppelter Portvergabe:
              Nein. Das kommt so unformatiert aus dem entsprechenden Kommando. Musss der geneigte Admin für sich selber die richtigen Schlüsse draus ziehen.
                Welchen und wie?
                HerrFrodo
                Habe jetzt in den Instanzeinstellungen von socketio den Port von 8086 auf 8087 verändert.
                Funktioniert.
                Aber wie meinst Du das? Soll man socketio löschen? WS habe ich auch.
                • H HerrFrodo
                  Funktioniert.
                  Ja, wird eigentlich nicht mehr benötigt.
                    HerrFrodo
                    @thomas-braun said in Android VIS läuft nicht mehr:
                    Ich habe socketio gelöscht und im Tab den WS-Port angegeben.
                    Läuft nicht.
                    Funktioniert nur mit Socketio
                    • H HerrFrodo
                      Läuft nicht.
                      zeigen
                      Läuft nicht.
                      ...ist keine Fehlerbeschreibung und keine Logausgabe ;-)
                        zeigen
                        Läuft nicht.
                        HerrFrodo
                        Du hast völlig recht!
                        Ich mache den Test nochmal und dokumentiere es ordnungsgemäß!
