  4. Repository-Verzeichnisse werden nicht gespeichert
    6.1k
64 Beiträge 4 Kommentatoren 8.4k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @zaphod
    @thomas-braun sagte in Repository-Verzeichnisse werden nicht gespeichert:
    @zaphod
    Wie schauen denn die objects an der Stelle aus?
    Hast du die Datenpunkte :
    config und repositories vorhanden !?
    gehe jeweils auf dem Bleistift und poste hier den Inhalt ( Objektdaten ) davon
    ZaphodZ Offline
    ZaphodZ Offline
    Zaphod
    schrieb am zuletzt editiert von Zaphod
    @glasfaser
    config:
      "common": {
        "name": "System configuration",
        "city": "Wettenberg",
        "country": "Germany",
        "longitude": "...",
        "latitude": "...",
        "language": "de",
        "tempUnit": "°C",
        "currency": "€",
        "dateFormat": "DD.MM.YYYY",
        "isFloatComma": false,
        "licenseConfirmed": true,
        "defaultHistory": "history.0",
        "activeRepo": [
          "stable"
        "diag": "no-city",
        "tabs": [
          "tab-adapters",
          "tab-instances",
          "tab-logs",
          "tab-scenes",
          "tab-javascript",
          "tab-text2command-0",
          "tab-enums",
          "tab-intro",
          "tab-wetty-0",
          "tab-fullcalendar-0",
          "tab-hosts",
          "tab-objects",
          "tab-terminal-0",
          "tab-devices"
        "defaultNewAcl": {
          "object": 1636,
          "state": 1636,
          "file": 1636,
          "owner": "system.user.admin",
        "intro": {},
        "wizard": true,
        "infoAdapterInstall": true,
        "tabsVisible": [
            "name": "tab-intro",
            "visible": true
            "name": "tab-adapters",
            "visible": true
            "name": "tab-instances",
            "visible": true
            "name": "tab-objects",
            "visible": true
            "name": "tab-enums",
            "visible": true
            "name": "tab-logs",
            "visible": true
            "name": "tab-users",
            "visible": true
            "name": "tab-hosts",
            "visible": true
            "name": "tab-files",
            "visible": true
            "name": "tab-backitup-0",
            "visible": true
            "name": "tab-info",
            "visible": true
            "name": "tab-devices",
            "visible": false
            "name": "tab-javascript",
            "visible": true
            "name": "tab-alias-manager",
            "visible": true
            "name": "tab-terminal-0",
            "visible": true
        "firstDayOfWeek": "monday",
        "expertMode": false
      "acl": {
        "object": 1636,
      "_id": "system.config",
      "native": {
        "secret": "bc84dd0d172e1a0c583c4d3d96648f039bc649ffc8e39a58"
      "type": "config",
      "user": "system.user.admin",
      "ts": 1707069666415
    repositories:
      "common": {},
      "native": {},
      "type": "meta",
      "_id": "system.repositories",
      "acl": {
        "object": 1636,
    repositories ist ein leerer Ordner
    • GlasfaserG Offline
      GlasfaserG Offline
      @glasfaser sagte in Repository-Verzeichnisse werden nicht gespeichert:
      und seit wann hast du dieses Problem !?
      ZaphodZ 2 Antworten Letzte Antwort
        ZaphodZ Offline
        ZaphodZ Offline
        Zaphod
        @Glasfaser
        schon sehr lange (> 1 Jahr)
        Hab's damals erfolglos selbst versucht zu lösen.
        .. ich weiß - Probleme verschieben ist auch keine Lösung.
        .. die Not war nicht groß - das System läuft stabil
        • ZaphodZ Zaphod
          @Glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          @zaphod sagte in Repository-Verzeichnisse werden nicht gespeichert:
          Naja ( falscher Gedanke )
          du kannst versuchen :
          Tausch den Inhalt hiermit :
          Mußte es Zippen , also bei dir entpacken ..
          repo.zip
          ZaphodZ 1 Antwort Letzte Antwort
            ZaphodZ Offline
            ZaphodZ Offline
            Zaphod
            @glasfaser
            redis_2023_12_09-02_00_33_ioBroker_backupiobroker.tar.gz
            historyDB_2023_12_09-02_00_34_ioBroker_backupiobroker.tar.gz
            javascripts_2023_12_09-02_01_01_ioBroker_backupiobroker.tar.gz
            iobroker_2023_12_10-02_00_10_ioBroker_backupiobroker.tar.gz
            ich hab' in meiner Dropbox Backups seit Anfang 22 - fast täglich .. vielleicht können die ja auch helfen (obwohl die nicht objects und states differenzieren)
              repo.zip
              ZaphodZ Offline
              ZaphodZ Offline
              Zaphod
              @glasfaser
              hab's in "repository" reinkopiert.
              .. der "schreiben"-button ist aber ausgegraut.
                GlasfaserG Offline
                @zaphod
                Klicke auf 644 dann :
                  @zaphod
                  ZaphodZ Offline
                  ZaphodZ Offline
                  Zaphod
                  @glasfaser
                  verdammt: hab' die Rechte so gesetzt (also insb. bei "Jeder"/schreiben - kann immer noch nicht schreiben.
                  Hab' dann alles gesetzt (666) immer noch kein Schreibrecht.
                  Nutzer/Gruppe ist bei mir "admin"/"Administrator"
                    GlasfaserG Offline
                    @zaphod
                    Bei mir ( Testsystem ) geht auch 644
                    dann :
                    iob stop
                    iob fix
                    sudo reboot
                      @zaphod
                      dann :
                      iob stop
                      iob fix
                      sudo reboot
                      ZaphodZ Offline
                      ZaphodZ Offline
                      Zaphod
                      @glasfaser
                      mach ich.
                      was mich wundert ist, dass bei mir "repositories" als Ordner angezeigt wird,
                      dessen Daten man bearbeiten kann.
                      wo liegt das Ding denn im Filesystem - dann kann ich auch dort mal schauen, ob das ein directory ist und ggf eine repository-Datei mit Deinen Daten anlegen - User/Group und Rechte könnte ich dann auch im Dateisystem eintragen.
                      .. aber erstmal "fixen" (hab' ich heute aber schon mehrmals gemacht;)
                      • ZaphodZ Zaphod
                        @glasfaser
                        mach ich.
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @zaphod
                        Ahh ... diese wichtige Information fehlte
                        Importiere das mal :
                        system.repositories.json
                          @zaphod
                          ZaphodZ Offline
                          ZaphodZ Offline
                          Zaphod
                          @glasfaser
                          in system.repositories.json steht
                          .. also ein leeres json. War das Dein Inhalt?
                          Beim Hochladen wird "ungültige Struktur" gemeldet.
                          Soll ich den Ordner "repositories" 'mal aus den Objekten löschen, bevor ich es hochladen
                            GlasfaserG Offline
                            @glasfaser
                            mach ich.
                            Kannst du mir einen gesamten Screenshot zeigen was alles in system. ist !
                              @glasfaser
                              mach ich.
                              ZaphodZ Offline
                              ZaphodZ Offline
                              Zaphod
                              @glasfaser
                              Ich hab' 'mal die nächste EBene aufgeklappt - wird sonst etwas zu groß für einen ScreenDump.
                              Ich hoffe, Du kannst es noch lesen:
                                GlasfaserG Offline
                                @zaphod
                                also endet er bei repositories
                                ZaphodZ HomoranH 2 Antworten Letzte Antwort
                                  @zaphod
                                  ZaphodZ Offline
                                  ZaphodZ Offline
                                  Zaphod
                                  @glasfaser
                                  yepp
                                  • ZaphodZ Zaphod
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @zaphod
                                    lösche den Ordner repositories , dann :
                                    iob stop
                                    iob setup first
                                    • ZaphodZ Zaphod
                                      @glasfaser
                                      yepp
                                      ZaphodZ Offline
                                      ZaphodZ Offline
                                      Zaphod
                                      @zaphod
                                      und in repositories sind auch keine weiteren Objekte drinnen ...
                                        @zaphod
                                        iob stop
                                        iob setup first
                                        ZaphodZ Offline
                                        ZaphodZ Offline
                                        Zaphod
                                        @glasfaser
                                        ok
                                          @zaphod
                                          iob stop
                                          iob setup first
                                          ZaphodZ Offline
                                          ZaphodZ Offline
                                          Zaphod
                                          @glasfaser said in Repository-Verzeichnisse werden nicht gespeichert:
                                          iob setup first
                                          DU BIST EIN HELD!
                                          repositories-Objekt wieder da (mit den INhalten, die Du mir gezipped geschickt hattest)!
                                          Unter Einstellungen sind die Repositories "stable" und "beta" auch eingetragen !
                                          Die Adapter zeigen nun auch updates an!
                                          ich bin wieder im business 🚀
                                          DANKE DIR!
