  3. Einsteigerfragen
  4. Web Admin nach update nicht erreichbar (Gelöst)
    5.5k
20 Beiträge 3 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • Mono990M Mono990
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     01:02:03 up 39 min,  1 user,  load average: 0.69, 0.79, 1.05
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** Time and Time Zones ***
                   Local time: Thu 2024-02-01 01:02:03 CET
               Universal time: Thu 2024-02-01 00:02:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.7G        1.6G        8.0M        582M        2.0G
    Swap:           99M          0B         99M
    Total:         3.9G        1.7G        1.7G
             3838 M total memory
             1670 M used memory
              263 M active memory
             1880 M inactive memory
             1586 M free memory
               84 M buffer memory
              497 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      115G   71G   40G  64% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Thu Feb  1 00:22:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:2D:4D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=757452ac-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Thu Feb  1 00:22:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Feb  1 00:22:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Feb  1 00:22:49 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    476M    /var/cache
    470M    /var/cache/apt
    421M    /var/lib
    408M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    62G     /opt/iobroker/backups/
    884K    /opt/iobroker/backups/javascripte
    816K    /opt/iobroker/backups/javascripte/common
    /opt/iobroker/iobroker-data:
    984M    /opt/iobroker/iobroker-data/
    668M    /opt/iobroker/iobroker-data/files
    161M    /opt/iobroker/iobroker-data/backup-objects
    160M    /opt/iobroker/iobroker-data/files/vis-2
    87M     /opt/iobroker/iobroker-data/history
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
            500 https://archive.raspbian.org/raspbian buster/main armhf Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.admin@6.13.15 /opt/iobroker/node_modules/iobroker.admin
    npm ERR! invalid: @iobroker/adapter-core@ /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
    npm ERR! invalid: body-parser@ /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser
    npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes
    npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type
    npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.admin/node_modules/depd
    npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy
    npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors
    npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits
    npm ERR! invalid: mime@ /opt/iobroker/node_modules/iobroker.admin/node_modules/mime
    npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished
    npm ERR! invalid: passport@0.6.0 /opt/iobroker/node_modules/passport
    npm ERR! extraneous: qs@ /opt/iobroker/node_modules/iobroker.admin/node_modules/qs
    npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body
    npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof
    npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses
    npm ERR! extraneous: toidentifier@ /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier
    npm ERR! invalid: ws@8.14.2 /opt/iobroker/node_modules/iobroker.admin/node_modules/ws
    npm ERR! invalid: json-schema-traverse@ /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-01T00_02_17_891Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.15
    javascript:     7.1.6
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-01T00_02_37_909Z-debug-0.log
    Adapters from github:   2
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled
      system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.plex.0                   : plex                  : raspberrypi                              - disabled, port: 60
      system.adapter.plexconnect.0            : plexconnect           : raspberrypi                              - disabled, port: 10000
      system.adapter.roomba.0                 : roomba                : raspberrypi                              - disabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.telegram.2               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.time-switch.0            : time-switch           : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      system.adapter.zigbee.1                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.15  , installed 6.13.15
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-watcher": 2.9.6   , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "knx"          : 2.0.24   , installed 2.0.24
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "openknx"      : 0.6.3    , installed 0.6.3
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "plex"         : 1.1.4    , installed 1.1.4
    Adapter    "plexconnect"  : 0.0.7    , installed 0.0.7
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        17503
    States:         15522
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://archive.raspbian.org/raspbian buster InRelease
    Get:4 https://deb.nodesource.com/node_18.x buster InRelease [4584 B]
    Fetched 4584 B in 3s (1663 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16614      629/sshd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        18785      615/influxd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18284      1598/io.shelly.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20602      1458/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       20514      1239/io.mqtt.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       20515      1239/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16664      619/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16657      619/iobroker.js-con
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23617      1875/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        17526      615/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16616      629/sshd
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        16181      617/grafana-server
    udp        0      0 0.0.0.0:43933           0.0.0.0:*                           1001       21312      2030/io.broadlink2.
    udp        0      0 0.0.0.0:34807           0.0.0.0:*                           108        13177      378/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18198      1365/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15857      614/dhcpcd
    udp        0      0 0.0.0.0:40038           0.0.0.0:*                           1001       20730      1585/io.openknx.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       21283      2030/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23605      1898/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13175      378/avahi-daemon: r
    udp        0      0 192.168.188.3:42370     0.0.0.0:*                           1001       21326      1966/io.knx.0
    udp6       0      0 :::546                  :::*                                0          17416      614/dhcpcd
    udp6       0      0 :::33973                :::*                                108        13178      378/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13176      378/avahi-daemon: r
    2024-02-01 00:57:37.477  - info: web.0 (1875) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
    2024-02-01 00:57:42.145  - info: web.0 (1875) ==> Connected system.user.admin from ::ffff:192.168.188.39
    2024-02-01 00:59:37.515  - info: web.0 (1875) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
    2024-02-01 00:59:43.251  - info: web.0 (1875) ==> Connected system.user.admin from ::ffff:192.168.188.39
    2024-02-01 01:00:00.226  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 4380
    2024-02-01 01:00:04.342  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4393
    2024-02-01 01:00:04.464  - info: daswetter.0 (4380) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.17.1, js-controller: 5.0.17
    2024-02-01 01:00:05.163  - warn: trashschedule.0 (1823) no events matches type "Tannenbaum" with match "baum"
    2024-02-01 01:00:09.687  - info: ical.0 (4393) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.17
    2024-02-01 01:00:10.361  - warn: ical.0 (4393) Error reading from URL "
    2024-02-01 01:00:11.024  - warn: ical.0 (4393) Error reading "ht
    2024-02-01 01:00:11.304  - warn: ical.0 (4393) Error reading from URL "ht
    2024-02-01 01:00:11.305  - warn: ical.0 (4393) Error reading "https://calendar.google.com/cale
    2024-02-01 01:00:11.443  - info: ical.0 (4393) processing URL: CalenderMüll https://calendar
    2024-02-01 01:00:11.743  - warn: trashschedule.0 (1823) no events matches type "Tannenbaum" with match "baum"
    2024-02-01 01:00:16.684  - info: ical.0 (4393) Terminated (NO_ERROR): Without reason
    2024-02-01 01:00:17.222  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-02-01 01:00:29.230  - info: daswetter.0 (4380) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-02-01 01:00:29.746  - info: daswetter.0 (4380) cleaned everything up...
    2024-02-01 01:00:29.764  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-01 01:01:37.652  - info: web.0 (1875) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
    2024-02-01 01:01:42.345  - info: web.0 (1875) ==> Connected system.user.admin from ::ffff:192.168.188.39
    iob diag has finished.
    GlasfaserG Offline
    GlasfaserG Offline
    @mono990 sagte in Web Admin nach update nicht erreichbar:
    warn: ical.0 (4393) Error reading from URL "https://calendar.google.com/calendar/ical/...............
    Bitte die privaten URL , unkenntlich machen !
    Stolze ... Backup Sammlung :)
    • GlasfaserG Offline
      GlasfaserG Offline
      eingerichtet das er backups machen soll ist er ja.
      den letzten hatt er aber leider ende 2022 gemacht
      Sicher !?
      Zeige mal :
      ls -lh /opt/iobroker/backups/
      Mono990M 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Sicher !?
        Zeige mal :
        Mono990M Offline
        Mono990M Offline
        Mono990
        @glasfaser
        Danke die privaten urls sind unkentlich gemacht.
        Ja er sollte eigentlich bagups über ftp an meinem NAS machen 😀
        Er hatte sie local gemacht und das waren reichlich ja.
        Ich habe iobroker auf das neue Betriebsystem drauf gemacht und das letzte Backup drauf gespielt.
        jetzt scheint alles wieder zu laufen.
        vielen dank nochmal an thomas-braun
        • Mono990M Mono990
          @glasfaser
          @mono990
          Und wie schaut's nun bei
          iob diag
          aus?
            @mono990
            iob diag
            aus?
            Mono990M Offline
            Mono990M Offline
            Mono990
            @thomas-braun said in Web Admin nach update nicht erreichbar (Gelöst):
            iob diag
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
                      Kernel: Linux 6.1.0-rpi7-rpi-v8
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
             15:11:30 up 19:09,  4 users,  load average: 0.46, 0.51, 0.50
            CPU threads: 4
            Current issues:
                           Local time: Fri 2024-02-02 15:11:30 GMT
                       Universal time: Fri 2024-02-02 15:11:30 UTC
                             RTC time: n/a
                            Time zone: Europe/London (GMT, +0000)
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            4.0G        3.1G        467M        9.7M        480M        859M
            Swap:           104M         99M        5.0M
            Total:          4.1G        3.2G        472M
                     3793 M total memory
                     2973 M used memory
                     1115 M active memory
                     1854 M inactive memory
                      446 M free memory
                        6 M buffer memory
                      451 M swap cache
                       99 M total swap
                       95 M used swap
                        4 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            udev           devtmpfs  1.6G     0  1.6G   0% /dev
            tmpfs          tmpfs     380M  1.3M  379M   1% /run
            /dev/mmcblk0p2 ext4      115G  7.6G  101G   7% /
            tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
            tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
            tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
            [Thu Feb  1 20:01:48 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:2D:4D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=81c6a9cf-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Thu Feb  1 20:01:51 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Thu Feb  1 20:01:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            520M    /var/
            191M    /var/lib
            188M    /var/cache
            181M    /var/cache/apt
            132M    /var/lib/apt/lists
            Archived and active journals take up 39.8M in the file system.
            205M    /opt/iobroker/backups/
            728M    /opt/iobroker/iobroker-data/
            632M    /opt/iobroker/iobroker-data/files
            159M    /opt/iobroker/iobroker-data/files/vis-2
            78M     /opt/iobroker/iobroker-data/files/vis-2/static
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            37M     /opt/iobroker/iobroker-data/objects.jsonl
            26M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
             *** 18.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main arm64 Packages
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.13.15
            javascript:     7.1.6
            Adapter State
              system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
              system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
              system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
              system.adapter.openknx.0                : openknx               : iobroker                                 - disabled
              system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.plex.0                   : plex                  : iobroker                                 -  enabled, port: 60
            + system.adapter.plexconnect.0            : plexconnect           : iobroker                                 -  enabled, port: 10000
              system.adapter.roomba.0                 : roomba                : iobroker                                 - disabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
              system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.wifilight.0              : wifilight             : iobroker                                 - disabled
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
              system.adapter.zigbee.1                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
            + instance is alive
            Adapter    "device-watcher": 2.9.6   , installed 2.10.3
            Objects and States
            Objects:        18519
            States:         16429
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Pending Updates: 113
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14083      801/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       58790      19047/iobroker.js-c
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       58797      19047/iobroker.js-c
            tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       70165      22372/io.mqtt.0
            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       70164      22372/io.mqtt.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       71212      22520/io.sonoff.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       72970      22436/io.shelly.1
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          233211     27056/cupsd
            tcp6       0      0 :::41891                :::*                    LISTEN      1001       114100     24280/io.plex.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       70744      22247/io.fullybrows
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14085      801/sshd: /usr/sbin
            tcp6       0      0 :::10000                :::*                    LISTEN      1001       111841     24187/io.plexconnec
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          233210     27056/cupsd
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       73000      22458/io.socketio.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74829      22793/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       58084      19072/io.admin.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       73466      22877/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13822      524/avahi-daemon: r
            udp        0      0 192.168.188.3:52602     0.0.0.0:*                           1001       71855      22356/io.knx.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       65110      22141/io.shelly.0
            udp        0      0 0.0.0.0:43206           0.0.0.0:*                           104        13824      524/avahi-daemon: r
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          231389     27058/cups-browsed
            udp6       0      0 :::5353                 :::*                                104        13823      524/avahi-daemon: r
            udp6       0      0 :::42240                :::*                                104        13825      524/avahi-daemon: r
            udp6       0      0 fe80::1936:79dc:c8d:546 :::*                                0          18056      658/NetworkManager
            2024-02-02 15:00:10.366  - warn: ical.0 (50822) Error re74&filter=3,6,2,1,7,8": Cannot read URL: "
            2024-02-02 15:00:10.569  - warn: ical.0 (50822) Error reading from URL "h
            2024-02-02 15:00:10.570  - warn: ical.0 (50822) Error reading "cal/3af0906a8e
            2024-02-02 15:00:11.119  - warn: trashschedule.0 (22654) no events matches type "Tannenbaum" with match "baum"
            2024-02-02 15:00:13.861  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:00:16.066  - info: ical.0 (50822) Terminated (NO_ERROR): Without reason
            2024-02-02 15:00:16.607  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2024-02-02 15:00:18.566  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            2024-02-02 15:00:34.977  - info: daswetter.0 (50809) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-02-02 15:00:35.496  - info: daswetter.0 (50809) cleaned everything up...
            2024-02-02 15:00:35.523  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-02-02 15:00:52.849  - info: plex.0 (24280) Player BRAVIA 4K GB ATV3-da812453aa6ba54b-com-plexapp-android is disconnected
            2024-02-02 15:02:13.822  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:02:19.375  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            2024-02-02 15:04:14.031  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:04:20.020  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            2024-02-02 15:06:13.887  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:06:18.605  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            2024-02-02 15:08:13.956  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:08:19.523  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            2024-02-02 15:10:14.070  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:10:18.647  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            2024-02-02 15:12:14.055  - info: web.0 (22793) <== Disconnect system.user.admin from ::ffff:192.168.188.39 vis.0
            2024-02-02 15:12:19.560  - info: web.0 (22793) ==> Connected system.user.admin from ::ffff:192.168.188.39
            Thomas BraunT 4 Antworten Letzte Antwort
            • Mono990M Mono990
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           104M         99M        5.0M
                       3793 M total memory
                       2973 M used memory
                        446 M free memory
                          6 M buffer memory
                        451 M swap cache
                         99 M total swap
                         95 M used swap
                          4 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              520M    /var/
              191M    /var/lib
              188M    /var/cache
              181M    /var/cache/apt
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.13.15
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        18519
              States:         16429
              @mono990
              Tagesführender...
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              ausführen, künftig dann regelmäßig selber Update fahren
              • Mono990M Mono990
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           104M         99M        5.0M
                         3793 M total memory
                         2973 M used memory
                          446 M free memory
                            6 M buffer memory
                          451 M swap cache
                           99 M total swap
                           95 M used swap
                            4 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                520M    /var/
                191M    /var/lib
                188M    /var/cache
                181M    /var/cache/apt
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.13.15
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        18519
                States:         16429
                @mono990
                Und dein Netzteil scheint was schwach auf der Brust zu sein.
                • Mono990M Mono990
                  iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           104M         99M        5.0M
                           3793 M total memory
                           2973 M used memory
                            446 M free memory
                              6 M buffer memory
                            451 M swap cache
                             99 M total swap
                             95 M used swap
                              4 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  520M    /var/
                  191M    /var/lib
                  188M    /var/cache
                  181M    /var/cache/apt
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.15
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        18519
                  States:         16429
                  @mono990
                  Vermutlich auch die falsche Einstellung. Stell da deine Zeitzone ein.
                  • Mono990M Mono990
                    iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M         99M        5.0M
                             3793 M total memory
                             2973 M used memory
                              446 M free memory
                                6 M buffer memory
                              451 M swap cache
                               99 M total swap
                               95 M used swap
                                4 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    520M    /var/
                    191M    /var/lib
                    188M    /var/cache
                    181M    /var/cache/apt
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.15
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        18519
                    States:         16429
                    @mono990
                    Boot Target: graphical.target
                    Stell das auf multi-user um.
                    sudo systemctl set-default multi-user
                    • Mono990M Offline
                      Mono990M Offline
                      Mono990
                      Es ist jetzt alles eingestellt vielen Dank.
                      Das Netzteil hat 5,1V und 3 A das war beim kauf damals dabai. Sollte ich besser ein 4-5 Ampere nehmen?
                      • Mono990M Mono990
                        @mono990
                        Sollte eigentlich ausreichend sein.
                        Mehr gibt's hier nachzulesen:
                        https://botland.de/blog/welches-netzteil-fuer-den-raspberry-pi-4/
