  4. Test ViessmannAPI v2.0.0
    6.5k
827 Beiträge 129 Kommentatoren 388.6k Aufrufe 125 Beobachtet
    Schweiz
    #683
    Hi, ich bekomme den Adapter leider nicht ans laufen...
    viessmannapi.0
    	2024-01-14 14:43:54.446	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    viessmannapi.0
    	2024-01-14 14:43:54.508	debug	Objects client ready ... initialize now
    viessmannapi.0
    	2024-01-14 14:43:54.511	debug	Objects create System PubSub Client
    viessmannapi.0
    	2024-01-14 14:43:54.514	debug	Objects create User PubSub Client
    viessmannapi.0
    	2024-01-14 14:43:54.587	debug	Objects client initialize lua scripts
    viessmannapi.0
    	2024-01-14 14:43:54.599	debug	Objects connected to redis: 127.0.0.1:9001
    viessmannapi.0
    	2024-01-14 14:43:54.648	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    viessmannapi.0
    	2024-01-14 14:43:54.671	debug	States create System PubSub Client
    viessmannapi.0
    	2024-01-14 14:43:54.673	debug	States create User PubSub Client
    viessmannapi.0
    	2024-01-14 14:43:54.750	debug	States connected to redis: 127.0.0.1:9000
    viessmannapi.0
    	2024-01-14 14:43:54.815	debug	Plugin sentry Initialize Plugin (enabled=true)
    viessmannapi.0
    	2024-01-14 14:43:54.826	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    viessmannapi.0
    	2024-01-14 14:43:55.067	info	starting. Version 2.4.0 (non-npm: TA2k/ioBroker.viessmannapi#3c01443c736270a8c3abe0212c651303fc15d8b3) in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.19.0, js-controller: 5.0.17
    viessmannapi.0
    	2024-01-14 14:43:55.587	error	AxiosError: Request failed with status code 401
    viessmannapi.0
    	2024-01-14 14:43:55.589	error	{"error":"invalid_request","error_description":"Client not registered."}
    viessmannapi.0
    	2024-01-14 14:43:55.987	error	AxiosError: Request failed with status code 400
    viessmannapi.0
    	2024-01-14 14:43:55.988	error	{"error":"invalid_request","error_description":"Invalid request: Missing or empty code parameter"}
    zugang mit der ViCare funktioniert...
    MFG Schweizer
      Schweiz
      #684
      @schweiz
      erledigt...
      Irgendwie hab ich mir gedacht, ich gebe mal einfach ein falsches Password ein, dann muss er mir ja sagen dass das Password falsch ist... hat er auch, dann habe ich es nocheinm eingegeben und nun geht der Adapter... kommisch!???
      MFG Schweizer
      • Tiger VIT Tiger VI
        @ritschy2000 Evtl. für dich noch interessant, habe vor kurzem den Datenpunkt gefunden.
        => viessmannapi.0.xxxxxx.0.features.heating.compressors.0.properties.phase.value
        Wenn die WP die Kühlung aktiviert und der Kompressor läuft wird dieser auf "cooling" gesetzt. Diesen Wert nutze ich als Trigger um die Logik der KNX Stellantriebe auf Kühlen zu stellen.
        @LaBamba bei mir wird der Wert immernoch mit einer Kommastelle von der API ausgegeben.
        I Online
        I Online
        io2345
        #685
        @tiger-vi Hast du den genannten Datenpunkt in Betrieb und funktioniert der an heißen Tagen? Habe eben einen kurzen Test gemacht, allerdings nur Natural Cooling über den Aktorentest in der Steuerung der WP eingeschaltet. Zumindest in diesem Fall ändert sich der Status dieses Datenpunktes nicht (das müsste bei dir genauso sein, falls du es ausprobieren möchtest). Kann aber natürlich sein, dass das ein anderer Trigger ist, der trotzdem das gewünschte Ergebnis liefert.
        • madingM mading
          @quotschmacher sagte in Test ViessmannAPI v2.0.0:
          ich greife das mal auf: das sollte ja dann eigentlich zum einschalten über bewegungsmelder so laufen, das ich in viessmannapi.0.2050879.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue bei auslösung des bewegungsmelders einen zeitplan mit der aktuellen zeit + ne stunde oder so eintrage und wenn keine bewegung mehr, dann einen leeren zeitplan. oder bin ich da jetzt ganz auf dem holzweg?
          nochmal der vollständigkeithalber: zirkulationspumpe steuern geht soweit ganz gut (vitodens 200).
          // schedule zum einschalten, allerdings nur zwischen 6 und 21 uhr
          var pump_on = '{"mon":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"tue":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"wed":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"thu":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"fri":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"sat":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"sun":[{"start":"06:00","end":"21:00","mode":"on","position":0}]}'
          // schedule leeren - pumpe ausschalten
          var pump_off = '{"mon":[], "tue":[],"wed":[],"thu":[],"fri":[],"sat":[],"sun":[]}'
          setState("viessmannapi.0.xxx.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue", JSON.parse(pump_on)); // oder pump_off
          der vorteil das ganze über ein "begrenztes" schedule zu lösen: man muss bei der auswertung eines bewegungsmelders keine zeiten mehr auswerten. wenn der melder nach 21 triggert und das schedule neu gesetzt wird, startet die pumpe eh nicht.
          ich hab gestern ganz wild die schedules hin und her geschaltet und es hat super funktioniert.
          danke für den adapter @tombox
          Hey, da will ich mich mal dran hängen. Ich hatte überlegt, mir einen kippschalter im Bad irgendwo zu platzieren, mit dem ich die Zirkulationspumpe ad hoc starten kann (Use Case: man steht im Bad und will duschen/ das Waschbecken mit WW benutzen). Eigentlich sollte es doch mit dem Skript kein Problem sein:
          • Eine Schaltervariable (bool) in den eigenen Datenpunkten zu setzen, welche von einem Blockly überwacht wird
          • ist die Variable auf true, wird der schedule (pump_on) gesetzt -> die Zirkulation läuft an
          • nach z.B. 5min wird automatisch pump_off gesetzt
          Verstehe ich es richtig, dass mit deinem Skript die Zirkulationspumpe von 6-21 Uhr durch laufen würde, wenn sie nicht wieder deaktiviert wird?
          edit: hab mal ein blockly gebaut
            <block type="procedures_defcustomnoreturn" id="C|6p3lu0hRewiE]Z{qnx" x="188" y="88">
              <mutation statements="false"></mutation>
              <field name="NAME">start-zirk</field>
              <field name="SCRIPT">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</field>
            </block>
            <block type="on_ext" id="OrrP|oAEW44xm)#CHi/x" x="563" y="88">
              <value name="OID0">
                <shadow type="field_oid" id="Vf:2${EvnUSG~})eift%">
                  <field name="oid">0_userdata.0.EigeneDatenpunkte.Heizung.ZirkulationAn</field>
                </shadow>
              </value>
              <statement name="STATEMENT">
                <block type="controls_if" id=")wR[o:^O40MXsYo|IaVD">
                  <value name="IF0">
                    <block type="logic_compare" id="vKpLM;XY_RcIGh6,W8}T">
                      <field name="OP">EQ</field>
                      <value name="A">
                        <block type="on_source" id=")fMs4Fcf$,iYXBW!bX,$">
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_boolean" id="J5ijXAEjpY!7;c[{N/*G">
                        </block>
                      </value>
                    </block>
                  </value>
                  <statement name="DO0">
                    <block type="procedures_callcustomnoreturn" id="cPECRG/O*H71[C0pKS3W">
                      <mutation name="start-zirk"></mutation>
                      <next>
                        <block type="telegram" id="T9Dc^Salh?]_(:9YeLNs">
                          <field name="LOG"></field>
                          <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                          <value name="MESSAGE">
                            <shadow type="text" id="1_-=OC9}y+2rbxEF,Ps7">
                              <field name="TEXT">Zirkulationspumpe gestartet. 5 Minuten Timeout</field>
                            </shadow>
                          </value>
                          <next>
                            <block type="timeouts_wait" id="^+@b5Hgy=9Kt_8[LpCQ#">
                              <field name="DELAY">5</field>
                              <field name="UNIT">min</field>
                              <next>
                                <block type="update" id="3`LHXWh~d.hYJhTrvq]*">
                                  <field name="OID">0_userdata.0.EigeneDatenpunkte.Heizung.ZirkulationAn</field>
                                  <value name="VALUE">
                                    <block type="logic_boolean" id="ex|rf*=(uRZ~2{=|JWFM">
                                    </block>
                                  </value>
                                  <next>
                                    <block type="procedures_callcustomnoreturn" id="/vYJRv|tZ55;~!uax+W3">
                                      <mutation name="stop-zirk"></mutation>
                                      <next>
                                        <block type="telegram" id=":QA|!PHN6C*+Eo6eIfHX">
                                            <shadow type="text" id="G!f5)/iMynkY@xR7o@ZR">
                                              <field name="TEXT">Zirkulationspumpe gestoppt.</field>
                                            </shadow>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
            <block type="procedures_defcustomnoreturn" id="]0SXN4W+S6mvOy.:^$No" x="188" y="113">
              <field name="NAME">stop-zirk</field>
              <field name="SCRIPT">Ly8gc2NoZWR1bGUgbGVlcmVuIC0gcHVtcGUgYXVzc2NoYWx0ZW4NCg0KdmFyIHB1bXBfb2ZmID0gJ3sibW9uIjpbXSwgInR1ZSI6W10sIndlZCI6W10sInRodSI6W10sImZyaSI6W10sInNhdCI6W10sInN1biI6W119JyANCg0KIA0KDQpzZXRTdGF0ZSgidmllc3NtYW5uYXBpLjAuNjQ4NTEuMC5mZWF0dXJlcy5oZWF0aW5nLmRody5wdW1wcy5jaXJjdWxhdGlvbi5zY2hlZHVsZS5jb21tYW5kcy5zZXRTY2hlZHVsZS5zZXRWYWx1ZSIsIEpTT04ucGFyc2UocHVtcF9vZmYpKTsgLy8gb2RlciBwdW1wX29mZg==</field>
            </block>
          </xml>
          Danke!
          mading
          I Online
          I Online
          io2345
          schrieb am zuletzt editiert von io2345
          #686
          @mading Mein Gott, was ihr für knifflige Sachen macht: Geo-Lokalisation, Wahnsinn. Aber selbst ein Wandschalter ist noch zu viel Aufwand.
          Am einfachsten wäre doch, in der Oberfläche des ioBroker eine Art "virtuellen Schalter" zu haben, wo man drauf drückt und dann läuft die Zirkulationspumpe für fünf Minuten, bevor sie sich wieder abstellt.
          Bin ziemlicher Anfänger in solchen Sachen (hab vorgestern erst ioBroker auf dem Raspi installiert).
          Könnt ihr abschätzen, ob sich sowas realisieren lässt - oder hat sowas in der Art gar schon einer der Forumsteilnehmer am Laufen?
          EDIT: Mein Gott, ich scheitere schon daran, dein Blockly-Script bei mir in Blockly einzufügen. Kann offenbar nur das anzeigen, was ich selbst zusammen-geblockt habe....
          N madingM 2 Antworten Letzte Antwort
          • I io2345
            N Offline
            N Offline
            nobbiman
            schrieb am zuletzt editiert von nobbiman
            #687
            @io2345 Kann verstehen, dass du das auch im ioBroker realisieren möchtest, wobei ich dir leider auch (noch) nicht helfen kann.
            Aber einen Tipp für die praktische Umsetzung deines Problems gebe ich dir gerne mit:
            Ich steuere meine Zirkupumpe (Keller) über einen Funkschalter (könnte ein Shelly Plug S sein oder ein anderes Shelly-Teil). Im Bad liegt bei mir ein Shelly Button 1, den man betätigt, sobald man das Bad betritt und sich zum Duschen/Waschen vorbereitet. Der Button steuert dann den Shelly Plug S, der auf eine Laufzeit von 3-4 Min programmiert wird.
            Vorteil dieser Lösung: Der Schalter ist vor Ort und so langsam gewöhnen sich auch die Familienmitglieder an dessen rechzeitiger Betätigung.
            Ich hatte früher eine Steuerung über FHEM im FTUI auf einem iPad realisiert, der im EG lag. Wenn man ins OG kam und hatte vergessen den "3-Minuten-Schalter" zu betätigen, wurde doch das Wasser so lange laufen gelassen, bis es warm wurde weil niemand Lust hatte, nochmals ins EG zu gehen.
            Mir gefällt die jetzige Lösung sehr gut!
            • I io2345
              madingM Online
              madingM Online
              mading
              #688
              @io2345 sagte in Test ViessmannAPI v2.0.0:
              Ich habe eine Schaltsteck an der Zirkulationspumpe. Im Bad habe ich einen homematic Taster mit Ink Display. Drücke ich auf eine Taste, läuft die ZP für 5 Min.
              • madingM mading
                  </block>
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                            <next>
                                  </shadow>
                                </value>
                                <next>
                                    <next>
                                          </block>
                                        </value>
                                        <next>
                                            <next>
                                                  </shadow>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                  </block>
                </xml>
                Danke!
                mading
                I Online
                I Online
                io2345
                #689
                @mading Funktioniert astrein.
                Falls ein Anfänger wie ich das ebenfalls importieren möchte: Hier ein paar Hinweise, wie man Frust vermeiden kann:
                Das Blockly enthält einen Block, in dem Meldungen über einen Adapter des IM-Dienstes Telegram verschickt werden. Falls man beim Importieren des Scripts eine Fehlermeldung erhält bezüglich fehlerhafter Telegram-Konfiguration, dann fehlt bei euch wahrscheinlich dieser Adapter.
                Der konfigurierte Datenpunkt, der geschaltet wird, muss bei euch im Blockly abgeändert werden: hinter "viessmannapi.0.... ist eine eindeutige ID, an dieser Stelle müsst ihr die eure eintragen.
                Das Blockly verwendet einen eigenen Datenpunkt, den ihr erst anlegen müsst: Unter 0_userdata.0.EigeneDatenpunkte.Heizung einen Unterpunkt "ZirkulationAn" als Binärwert.
                Wer das Script ohne Hardwareschalter einfach von einem Mobilgerät oder Computer aufrufen will, kann sich z.B. eine Visualisierung (wie HABpanel) als Adapter installieren und dort eine Schaltfläche einfügen, die beim Antippen in den - im letzten Abschnitt erstellten Datenpunkt - schreibt.
                • M m4rgott
                  Ich habe die Lösung schon gefunden.
                  Ein Konvertierungsblock "JSON nach Objekt" vor den zu schreibenden Wert hat geholfen.
                  Bastler52
                  schrieb am zuletzt editiert von Bastler52
                  #690
                  @m4rgott Kannst Du uns dann die Lösung zeigen bitte. (vor {"mon" .. ist gemeint oder?)
                  • B Bastler52
                    m4rgott
                    #691
                    Hi @bastler52
                    die obenstehenden Blocklys sind genau so bei mir im Einsatz. Deshalb weiß ich nicht welche Lösung Du suchst.
                    Ich habe nur die Anlagennummer durch "xxx" ersetzt.
                    Wie oben beschrieben habe ich für den neuen Zeitplan den bestehenden Wert aus dem Datenpunkt viessmannapi.0.xxx.0.features.heating.dhw.pumps.circulation.schedule.properties.entries.value geholt und den nach meinen Vorstellungen angepasst.
                    Ich hoffe das hilft Dir weiter.
                    • M m4rgott
                      Hi @bastler52
                      Bastler52
                      #692
                      @m4rgott Danke scheinbar habe ich etwas übersehen oder wurde nicht angezeigt. Wollte nur sicher gehen dass ich deinen Beitrag richtig verstanden habe f8471e71-0515-46c9-99b4-1a2c8887705f-image.png
                      genau das habe ich nicht gesehen und danach hatte ich gefragt ob och das richtig verstanden habe.
                      Ich habe an sich die Lösung auch um Einsatz aber als Java Skript.
                      DANKE für deine Reaktion
                        @juggi1962
                        noe, bei mir laeuft alles wie gehabt... polle alle 5minuten..
                        hast du das mal gemacht, was in der Fehlermeldung steht?
                        MAXI885
                        #693
                        @ilovegym
                        aktuell nutze ich den Adapter noch nicht, hätte aber eine Frage zur Anschaffung der Hardware.
                        Es gibt für den VITOCONNECT 100 OPT01 auch einen Nachfolger, den OPTO2, ist das für die Verwendung mit iobroker egal,
                        welches Gerät man benutzt ?
                        Vielen Dank & Grüße !
                        ? T 2 Antworten Letzte Antwort
                        • M MAXI885
                          @ilovegym
                          #694
                          @maxi885
                          kann dir nicht 100% bestaetigen, da ich auch nur den Vitoconnect 100 habe.
                          Aber, rein von der Logik des Adapters aus, sollte es funktionieren, da dieser die Daten ja von dem Viessmann-Server von der API holt.
                          Wie die Daten dahin kommen, ob mit Modul-1 oder 2 oder X ist eigentlich egal....
                          • M MAXI885
                            @ilovegym
                            tombox
                            #695
                            @maxi885 Kompatibilitätsliste: https://documentation.viessmann.com/static/compatibility
                            • T tombox
                              MAXI885
                              #696
                              @tombox said in Test ViessmannAPI v2.0.0:
                              super, vielen Dank !
                              Die Liste bezieht sich schon auf den neuen OPTO2, da steht meine etwas ältere Vitotronic 200 KW1 sogar dabei :-)
                                Backes
                                #697
                                Guten Morgen,
                                ist es normal, dass wenn das RateLimit einmal erreicht wurde, das der Adapter manuell neugestartet werden muss damit er wieder funktioniert am nächsten Tag? Hab das RateLimit letzte Woche einmal überschritten und er hat seitdem gehangen und keine Daten mehr gezogen.
                                Beste Grüße!
                                • B Backes
                                  Guten Morgen,
                                  Beste Grüße!
                                  Dominik F.D Offline
                                  Dominik F.D Offline
                                  Dominik F.
                                  #698
                                  ich habe heute den Adapter installiert und soweit ich das überblicken kann funktioniert alles.
                                  Ich nutze bei meiner Heizung die geofencing Funktion. Gibt es dazu Datenpunkte wo ich sehen kann wer im Umkreis ist und wer nicht?
                                  • I Online
                                    I Online
                                    io2345
                                    #699
                                    Jetzt bräuchte ich doch nochmal Hilfe von Spezialisten:
                                    Wollte das Script verbessern, dass es den eingestellten Zirkulationspumpen-Schedule aus der WP zunächst ausliest und ganz am Schluss wieder zurückschreibt.
                                    Das klappt aber nicht so recht. Es kommt beim Schreiben von Werten immer der Hinweis:
                                    State value to set for ... has to be one of type "string", "number", "boolean" but received type "object"
                                    Nun habe ich schon einige Forumseinträge hierzu gelesen, wo es um "stringify" oder "toString" geht, oder auch, dass der Adapter selbst das regeln muss. Vermutlich bin ich einfach nicht helle genug, bisher habe ich jedenfalls nicht verstanden, was ich nun konkret tun muss, um das Problem zu umgehen. Könnt ihr mir helfen?
                                    Hier der Code:
                                    async function start_zirk() {
                                        // Schedule wird zum Einschalten der Pumpe temporär verändert, so dass die Pumpe
                                        // zwischen 00:00 und 23:59 Uhr zuverlässig eingeschaltet ist. Das in der Wärmepumpe
                                        // vorhandene Zeitprogramm der Zirkulationspumpe wird in einen eigenen Datenpunkt gesichert
                                        var pump_on = '{"mon":[{"start":"00:00","end":"23:59","mode":"on","position":0}],"tue":[{"start":"00:00","end":"23:59","mode":"on","position":0}],"wed":[{"start":"00:00","end":"23:59","mode":"on","position":0}],"thu":[{"start":"00:00","end":"23:59","mode":"on","position":0}],"fri":[{"start":"00:00","end":"23:59","mode":"on","position":0}],"sat":[{"start":"00:00","end":"23:59","mode":"on","position":0}],"sun":[{"start":"00:00","end":"23:59","mode":"on","position":0}]}';
                                        var schedule_sichern = getState('viessmannapi.0.133000.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue').val;
                                        setState('0_userdata.0.EigeneDatenpunkte.Heizung.ZwischenspeicherZirkulationspumpeSchedule', schedule_sichern.val);
                                        setState("viessmannapi.0.133000.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue", JSON.parse(pump_on)); // oder pump_off
                                    async function stop_zirk() {
                                        // Der urspüngliche Schedule wird zurückgeschrieben.
                                        var schedule_wiederherstellen = getState('0_userdata.0.EigeneDatenpunkte.Heizung.ZwischenspeicherZirkulationspumpeSchedule').val;
                                        setState("viessmannapi.0.133000.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue", schedule_wiederherstellen.val);
                                    on({ id: [].concat(['0_userdata.0.EigeneDatenpunkte.Heizung.ZirkulationAn_']), change: 'ne' }, async (obj) => {
                                      let value = obj.state.val;
                                      let oldValue = obj.oldState.val;
                                      if ((obj.state ? obj.state.val : "") == true) {
                                        await start_zirk();
                                        log ("Zirkulationspumpe läuft für zwei Minuten");
                                        await wait(120000);
                                        setState('0_userdata.0.EigeneDatenpunkte.Heizung.ZirkulationAn_' /* EigeneDatenpunkte.Heizung.ZirkulationAn  */, false, true);
                                        await stop_zirk();
                                    • I io2345
                                      Hier der Code:
                                          await start_zirk();
                                          await wait(120000);
                                          await stop_zirk();
                                      Michi_Pi
                                      #700
                                      @io2345 ich bin jetzt kein Spezialist, aber was mir auffällt ist, dass du beim zurückspeichern das nicht als JSON machst.
                                      Probier mal
                                      JSON.parse(schedule_wiederherstellen.val))
                                      I 1 Antwort Letzte Antwort
                                      • M Michi_Pi
                                        Probier mal
                                        I Online
                                        I Online
                                        io2345
                                        #701
                                        @michi_pi
                                        Danke für die Rückmeldung. Hätte erwähnen sollen, dass ich das schon probiert hatte. Dann kommt allerdings ein tiefroter Fehler:
                                        script.js.common.Zirkulation_kurz_einschalten_verbessert_JS: SyntaxError: Unexpected token u in JSON at position 0
                                        error at JSON.parse (<anonymous>)
                                        at start_zirk (script.js.common.Zirkulation_kurz_einschalten_verbessert_JS:9:103)
                                        at Object.<anonymous> (script.js.common.Zirkulation_kurz_einschalten_verbessert_JS:25:11)
                                        at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                                        at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                                        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                                        at processImmediate (node:internal/timers:476:21)
                                        Denke, das ist der Grund, warum der fixe Wert in Codezeile 6 in Hochkommata steht. Weiss aber nicht, wie ich das mit den anderen, zu übergebenden Werten, hinbekomme.
                                        • I io2345
                                          @michi_pi
                                          Michi_Pi
                                          schrieb am zuletzt editiert von Michi_Pi
                                          #702
                                          @io2345 probiers mal hiermit. Die lokale Zwischenspeichern hab ich jetzt mal wegelassen.
                                          var pump_on, schedule_sichern, schedule_wiederherstellen;
                                              pump_on = '{"mon":[{"start":"00:00","end":"23:59","mode":"on","position":0}],\
                                                              "tue":[{"start":"00:00","end":"23:59","mode":"on","position":0}],\
                                                              "wed":[{"start":"00:00","end":"23:59","mode":"on","position":0}],\
                                                              "thu":[{"start":"00:00","end":"23:59","mode":"on","position":0}],\
                                                              "fri":[{"start":"00:00","end":"23:59","mode":"on","position":0}],\
                                                              "sat":[{"start":"00:00","end":"23:59","mode":"on","position":0}],\
                                              //setState('0_userdata.0.EigeneDatenpunkte.Heizung.ZwischenspeicherZirkulationspumpeSchedule', JSON.parse(schedule_sichern));
                                              //schedule_wiederherstellen = getState('0_userdata.0.EigeneDatenpunkte.Heizung.ZwischenspeicherZirkulationspumpeSchedule').val;
                                              schedule_wiederherstellen = schedule_sichern;
                                              setState("viessmannapi.0.133000.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue", JSON.parse(schedule_wiederherstellen));
                                              await start_zirk();
                                              await wait(120000);
                                              await stop_zirk();
