  3. Einsteigerfragen
  4. Installation
  5. kann keinen Adapter mehr updaten
18 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • maximal1981M maximal1981
    @thomas-braun sagte in kann keinen Adapter mehr updaten:
    iob nodejs-update 18
    ioBroker nodejs updater 2023-10-13
    You requested to intall latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
    /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
    /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
    /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
    *** nodejs is NOT correctly installed ***
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Your nodejs-Installation seems to be faulty. Shall we try to fix it?
    Press <y> to continue or any other key to quit
    Fixing your nodejs setup
    *** Deleting  ***
    rm: cannot remove '': No such file or directory
    *** Deleting  ***
    Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
    You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
    Trying to update your installation now. Please be patient.
    Virtualization: lxc
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:2 http://security.debian.org bookworm-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
    Fetched 18.8 kB in 0s (48.2 kB/s)
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    E: Broken packages
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to update or fix your nodejs. Please run 'iob diag' again to verify.
    reboot
                            v.2023-10-10
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.2.16-3-pve
        Architecture: x86-64
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Vienna (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    7
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
    /home/iobroker/.diag.sh: line 488: npm: command not found
    /home/iobroker/.diag.sh: line 489: npx: command not found
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            6.4G        1.7G        4.3G        118K        485M        4.8G
    Swap:           1.1G          0B        1.1G
    Total:          7.5G        1.7G        5.4G
    Active iob-Instances:   20
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                26635
    States:                 22791
    Size of iob-Database:
    39M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/states.jsonl
    @maximal1981 ist das vollständig?
    wieso sehe ich die Eingabezeilen nie?
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      *** Deleting  ***
      *** Deleting  ***
      Virtualization: lxc
      Package: nodejs
      Pin-Priority: 1001
      E: Broken packages
      reboot
                              v.2023-10-10
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
      Please check
      MEMORY:
      Swap:           1.1G          0B        1.1G
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                26635
      States:                 22791
      Thomas BraunT Offline
      @maximal1981
      apt policy nodejs
      sudo apt install nodejs=18.19.0-1nodesource1
      maximal1981M 1 Antwort Letzte Antwort
        @maximal1981
        apt policy nodejs
        maximal1981M Offline
        maximal1981
        schrieb am zuletzt editiert von maximal1981
        @thomas-braun weil ich dann auch nicht mehr sehe. Das ist was ich nach den aufrufen bekomme.
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
        Nothing to do - Your installation is using the correct paths.
        Virtualization: lxc
        Package: nodejs
        Pin-Priority: 1001
        Fetched 18.8 kB in 0s (50.6 kB/s)
        Skript v.2023-10-10
        *** BASE SYSTEM ***
          Virtualization: lxc
        model name      : AMD Ryzen 5 5600U with Radeon Graphics
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         19:20:05 up 0 min,  2 users,  load average: 1.36, 1.07, 1.02
        CPU threads: 12
        *** Time and Time Zones ***
                       Local time: Fri 2024-01-12 19:20:05 CET
                   Universal time: Fri 2024-01-12 18:20:05 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        maximal1981
        /home/maximal1981
        maximal1981 sudo users iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            6.4G        1.1G        5.0G        118K        298M        5.3G
        Swap:           1.1G          0B        1.1G
        Total:          7.5G        1.1G        6.1G
                 6144 M total memory
                 1071 M used memory
                  123 M active memory
                 1172 M inactive memory
                 4787 M free memory
                    0 M buffer memory
                  284 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  5.0G  2.4G  68% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.5G     0  7.5G   0% /dev/tty
        tmpfs                            tmpfs     7.6G     0  7.6G   0% /dev/shm
        tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
        /var:
        862M    /var/
        470M    /var/log
        469M    /var/log/journal/fdf5cd495bb345a58900f9d60cd51d5c
        246M    /var/cache
        Archived and active journals take up 10.9M in the file system.
        /opt/iobroker/backups:
        453M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        548M    /opt/iobroker/iobroker-data/
        342M    /opt/iobroker/iobroker-data/files
        136M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        39M     /opt/iobroker/iobroker-data/states.jsonl
        30M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        21M     /opt/iobroker/iobroker-data/files/0_userdata.0/iobroker_2023_09_02-14_14_06_backupiobroker.tar.gz
        9.2M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   4
        Adapter State
          system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
          system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
          system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
          system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
        + system.adapter.daikin.0                 : daikin                : iobroker                                 -  enabled
        + system.adapter.daikin.1                 : daikin                : iobroker                                 -  enabled
        + system.adapter.daikin.2                 : daikin                : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
          system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
          system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : iobroker                                 -  enabled
          system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
          system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : iobroker                                 -  enabled
          system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.iceroad.0                : iceroad               : iobroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
          system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
          system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
          system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
          system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
          system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
          system.adapter.unifi-protect.0          : unifi-protect         : iobroker                                 -  enabled
          system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
          system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + instance is alive
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "awattar"      : 1.0.6    , installed 1.0.6
        Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "email"        : 1.2.1    , installed 1.2.1
        Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.2  [Updatable]
        Adapter    "fuelpricemonitor": 0.4.0 , installed 0.4.0
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.12 [Updatable]
        Adapter    "logparser"    : 2.2.1    , installed 2.2.0  [Updatable]
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "parser"       : 2.0.7    , installed 2.0.7
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
        Adapter    "roomba"       : 1.2.2    , installed 1.2.2
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "tado"         : 0.5.1    , installed 0.4.12 [Updatable]
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
        Adapter    "unifi"        : 0.6.7    , installed 0.6.7
        Adapter    "vis"          : 1.5.4    , installed 1.5.4
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Objects and States
        Objects:        26635
        States:         22792
        Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:3 http://security.debian.org bookworm-security InRelease
        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          165612264  307/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          165607810  1/init
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       165597793  147/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       165597786  147/iobroker.js-con
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       165621427  859/io.mqtt.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       165615581  959/io.shelly.1
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          165612265  307/master
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       165597982  986/io.sonos.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          165607812  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          165614151  1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       165614262  329/io.admin.1
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          165615976  90/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          165607811  1/init
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       165620241  908/io.shelly.0
        udp6       0      0 :::111                  :::*                                0          165607813  1/init
        2024-01-12 19:20:20.257  - info: shelly.1 (959) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.12
        2024-01-12 19:20:20.400  - info: shelly.1 (959) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
        2024-01-12 19:20:20.682  - info: shelly.0 (908) [CoAP] Device 192.168.98.26 (shellygas / shellygas-10521CF345C0 / SHGS-1#10521CF345C0#1) connected! Polltime set to 3600 sec.
        2024-01-12 19:20:21.784  - info: shelly.0 (908) [CoAP] Device 192.168.98.21 (shellyplug-s / shellyplug-s-C70598 / SHPLG-S#C70598#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:22.109  - info: shelly.0 (908) [CoAP] Device 192.168.99.45 (shellyswitch25 / shellyswitch25-BCDDC277B11B / SHSW-25#BCDDC277B11B#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:22.445  - info: shelly.0 (908) [CoAP] Device 192.168.98.24 (shelly1pm / shelly1pm-E09806A9E0B6 / SHSW-PM#E09806A9E0B6#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:22.490  - info: shelly.0 (908) [CoAP] Device 192.168.99.21 (shelly1pm / shelly1pm-68C63AFAE21E / SHSW-PM#68C63AFAE21E#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:23.224  - info: host.iobroker instance system.adapter.sonos.0 started with pid 986
        2024-01-12 19:20:23.725  - info: sonos.0 (986) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.19.0, js-controller: 5.0.12
        2024-01-12 19:20:23.793  - info: shelly.0 (908) [CoAP] Device 192.168.99.22 (shelly1 / shelly1-C45BBE775B7A / SHSW-1#C45BBE775B7A#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:24.652  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_32.favorites_list_html" has no existing object, this might lead to an error in future versions
        2024-01-12 19:20:24.652  - info: shelly.0 (908) [CoAP] Device 192.168.99.41 (shellyplug-s / shellyplug-s-B5085F / SHPLG-S#B5085F#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:24.652  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_47.favorites_list_html" has no existing object, this might lead to an error in future versions
        2024-01-12 19:20:24.653  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_47.favorites_list_html" has no existing object, this might lead to an error in future versions
        2024-01-12 19:20:24.756  - info: shelly.0 (908) [CoAP] Device 192.168.98.30 (shellyplug-s / shellyplug-s-C38343 / SHPLG-S#C38343#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:25.400  - info: shelly.0 (908) [CoAP] Device 192.168.98.27 (shelly1pm / shelly1pm-E09806A9E311 / SHSW-PM#E09806A9E311#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:26.407  - info: shelly.0 (908) [CoAP] Device 192.168.99.17 (shelly1 / shelly1-C49979 / SHSW-1#C49979#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:26.697  - info: shelly.0 (908) [CoAP] Device 192.168.99.30 (shelly1 / shelly1-B8E736 / SHSW-1#B8E736#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:26.716  - info: shelly.0 (908) [CoAP] Device 192.168.99.40 (shellyswitch25 / shellyswitch25-E098068D445E / SHSW-25#E098068D445E#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:26.791  - info: shelly.0 (908) [CoAP] Device 192.168.99.35 (shellyswitch25 / shellyswitch25-C45BBE6AB3A2 / SHSW-25#C45BBE6AB3A2#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:27.221  - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
        2024-01-12 19:20:27.228  - info: host.iobroker instance system.adapter.tvspielfilm.0 started with pid 1571
        2024-01-12 19:20:27.781  - info: shelly.0 (908) [CoAP] Device 192.168.98.214 (shellyplug-s / shellyplug-s-083A8DC3528C / SHPLG-S#083A8DC3528C#1) connected! Polltime set to 15 sec.
        2024-01-12 19:20:27.820  - info: tvspielfilm.0 (1571) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.12
        scheint wieder alles normal zu laufen.
        habe aber meines Wissens nichts angegriffen außer eben ein upgrade in linux.
        aber danke für die Hilfe, bist ein Schatz.
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Virtualization: lxc
          Package: nodejs
          Pin-Priority: 1001
          Skript v.2023-10-10
          *** BASE SYSTEM ***
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 12
                           RTC time: n/a
                    RTC in local TZ: no
          maximal1981
          /home/maximal1981
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           1.1G          0B        1.1G
                   6144 M total memory
                   1071 M used memory
                    123 M active memory
                   4787 M free memory
                      0 M buffer memory
                    284 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          *** FILESYSTEM ***
          /var:
          862M    /var/
          470M    /var/log
          246M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        26635
          States:         22792
          Pending Updates: 0
          @maximal1981 sagte in kann keinen Adapter mehr updaten:
          Für die Zukunft: NIE als root, NIE npm manuell anpacken.
          Hintergründe zu deinem 'Problem':
          https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
            maximal1981
            @thomas-braun ich habe npm seit der Einrichtung nicht mehr angefasst.
            war das letzte mal auf der cli für ein apt upgrade. Hatte aber hier noch nie Probleme mit npm.
              Das kam durch das Update von debian.
              ist ein Kollateralschaden.
              und was war das
              npm install -g npm@8
                und was war das
                maximal1981
                @homoran das schlug mir die Adapterinstallation vor, da ging aber schon nichts mehr.
                aber vermutlich wie du als erstes schreibst, kommt es von dem Update vom OS.
                Aber das hatte ich nie, soll das jetzt nicht umgesetzt werden?
                  @maximal1981
                  Im weiteren:
                  Boot Target: graphical.target
                  sudo systemctl set-default multi-host.target
                  sudo useradd -a -G adm maximal1981
                  Und schaufel die diversen Adapter-Updates auf die Kiste.
                    klar, npm war ja weg, wie gerade erklärt
                      Doch, du sollst natürlich weiterhin Updates fahren. Allerdings war bei dir das nodesource-Repository noch nicht auf die aktuellste Version mit dem richtigen Pinning umgestellt. Weswegen dir der Paketmanager die aktuellste Version von nodejs eingespielt hat, die aber nicht zum ioBroker passt.
                      Das ist aber jetzt alles wieder richtig, kannst also nun wieder wie gewohnt deine Updates einspielen.
