  4. Raspbian light Stretch für Raspberry Pi 2/3 All-In-One mit piVCCU
    5.8k
49 Beiträge 6 Kommentatoren 9.7k Aufrufe
  • C Offline
    christianbl88
    Das Ergebniss:
    pi@raspberrypi:~ $ uname -a
    Linux raspberrypi 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux
    pi@raspberrypi:~ $ ls -la /lib/modules/
    total 16
    drwxr-xr-x  4 root root 4096 Nov  1 15:39 .
    drwxr-xr-x 16 root root 4096 Nov  1 16:15 ..
    drwxr-xr-x  3 root root 4096 Nov  1 15:39 4.9.59+
    drwxr-xr-x  3 root root 4096 Nov 30 19:04 4.9.59-v7+
    pi@raspberrypi:~ $ ls -la /lib/modules/*/kernel/drivers/pivccu/*
    -rw-r--r-- 1 root root 10732 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/dw_apb_raw_uart.ko
    -rw-r--r-- 1 root root 16680 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/eq3_char_loop.ko
    -rw-r--r-- 1 root root 17796 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/generic_raw_uart.ko
    -rw-r--r-- 1 root root  9912 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/pl011_raw_uart.ko
    -rw-r--r-- 1 root root  5332 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/plat_eq3ccu2.ko
    pi@raspberrypi:~ $ lsmod
    Module                  Size  Used by
    iptable_filter          2220  0
    bridge                112535  0
    stp                     2218  1 bridge
    llc                     5790  2 bridge,stp
    fuse                   94600  3
    snd_bcm2835            23131  0
    snd_pcm                97825  1 snd_bcm2835
    snd_timer              22706  1 snd_pcm
    snd                    68784  3 snd_timer,snd_bcm2835,snd_pcm
    bcm2835_gpiomem         3791  0
    uio_pdrv_genirq         3718  0
    uio                    10166  1 uio_pdrv_genirq
    fixed                   3029  0
    ip_tables              12512  1 iptable_filter
    x_tables               20921  2 ip_tables,iptable_filter
    ipv6                  384613  13 bridge
    pi@raspberrypi:~ $ ls -la /boot/overlays/pivccu*
    -rwxr-xr-x 1 root root 296 Nov 30 19:04 /boot/overlays/pivccu-bcm2835.dtbo
    pi@raspberrypi:~ $ cat /proc/device-tree/compatible
    brcm,bcm2835pi@raspberrypi:~ $ ls -la /proc/device-tree/soc/serial*/compatible
    -r--r--r-- 1 root root 13 Nov 30 21:28 /proc/device-tree/soc/serial@7e201000/compatible
    -r--r--r-- 1 root root 22 Nov 30 21:28 /proc/device-tree/soc/serial@7e215040/compatible
    pi@raspberrypi:~ $ cat /proc/device-tree/soc/serial*/compatible
    pivccu,pl011brcm,bcm2835-aux-uartpi@raspberrypi:~ $
      deimos
      @Homoran:
      @Homoran:
      Danke, dann sehe ich da heute abend mal nach. `
      Ergebnis 1 ( /etc/apt/sources.list)
      deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free $
      # Uncomment line below then 'apt-get update' to enable 'apt-get source'
      #deb-src http://archive.raspbian.org/raspbian/ stretch main contrib non-free rpi
      deb http://alexreinert.github.io/piVCCU stable main
      deb http://alexreinert.github.io/piVCCU testing main
      Ergebnis 1 ( Ergebnis 1 ( /etc/apt/sources.list.d/pivccu.list)
      =leer
      muss ich dann wohl nochmal mit deinem Image neu machen :shock: `
      Die drei Einträge in der sources.list sind nicht gut, aber das produziert erstmal nur Warnungen und man kann sich nicht sicher sein, ob jetzt testing oder stable verwendet wird.
      Das die zweite Datei nicht exisitiert ist nicht schlimm. Es muss ein Eintrag entweder in der ersten oder in der zweiten sein. In meinem Image habe ich das immer in der zweiten eigenen, aber das muss nicht zwingend so sein. In meiner ersten Anleitung war es auch noch direkt in der sources.list.
      Viele Grüße
      Alex
        deimos
        ok, das sieht erstmal gut aus. Dann jetzt bitte mal
        sudo modprobe pl011_raw_uart
        sudo lsmod
        sudo dmesg | grep uart
        sudo pivccu-info
        • C Offline
          christianbl88
          pi@raspberrypi:~ $ sudo modprobe pl011_raw_uart
          modprobe: FATAL: Module pl011_raw_uart not found in directory /lib/modules/4.9.59+
          pi@raspberrypi:~ $ sudo lsmod
          Module                  Size  Used by
          bridge                112535  0
          stp                     2218  1 bridge
          fuse                   94600  3
          snd_bcm2835            23131  0
          fixed                   3029  0
          pi@raspberrypi:~ $ sudo dmesg | grep uart
          pi@raspberrypi:~ $ sudo pivccu-info
          piVCCU version: 2.29.23-16
          Kernel modules: Not available
          Raw UART dev:   Not available
          Board serial:   Unknown
          State:          STOPPED
            deimos
            Ok, ich habe einen neuen Verdacht. Machst du bitte mal ein Detail-Foto von deinem Pi?
            • C Offline
              christianbl88
              Foto pi~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201711 ... 530fb9.jpg">https://uploads.tapatalk-cdn.com/20171130/bb328ae59fa6dd90d33b8c277c530fb9.jpg</link_text>" />
              Gesendet von meinem ONEPLUS A3003 mit Tapatalk~~
                deimos
                Verdacht bestätigt: Das ist kein Pi 2 B.
                • C Offline
                  christianbl88
                  Huch… Wie was... [emoji28]
                    deimos
                    Den Bilder nach dürfte es ein Pi 1 B sein. Der wird von piVCCU nicht unterstützt. (macht auch wenig Sinn, der hat kaum CPU Power und je nach Produktionsdatum nur 256MB RAM).
                    • C Offline
                      christianbl88
                      @christianbl88:
                      Gesendet von meinem ONEPLUS A3003 mit Tapatalk ` Vielen Dank für die Hilfestellung.. tut mir leid das mit das nicht selbst bewusst geworden ist… War der vollen überzeugen daß das einer ist..
