  4. Raspbian light Stretch für Raspberry Pi 2/3 All-In-One mit piVCCU
    5.8k
49 Beiträge 6 Kommentatoren 9.7k Aufrufe
    @Homoran:
    Danke, dann sehe ich da heute abend mal nach. `
    Ergebnis 1 ( /etc/apt/sources.list)
    deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free $
    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
    #deb-src http://archive.raspbian.org/raspbian/ stretch main contrib non-free rpi
    deb http://alexreinert.github.io/piVCCU stable main
    deb http://alexreinert.github.io/piVCCU testing main
    Ergebnis 1 ( Ergebnis 1 ( /etc/apt/sources.list.d/pivccu.list)
    =leer
    muss ich dann wohl nochmal mit deinem Image neu machen :shock:
    • C Offline
      christianbl88
      So System neu aufgespielt und erfolgreich Expandiert.
      Beim Upgrade hat er am ende diese Fehler angezeigt.
      Setting up pivccu (2.29.23-16) ...
      Created symlink /etc/systemd/system/multi-user.target.wants/pivccu.service → /lib/systemd/system/pivccu.service.
      Job for pivccu.service failed because the control process exited with error code.
      See "systemctl status pivccu.service" and "journalctl -xe" for details.
      WARNING: No network bridge could be detected.
      Processing triggers for man-db (2.7.6.1-2) ...
      Setting up libcurl3:armhf (7.52.1-5+deb9u3) ...
      Setting up curl (7.52.1-5+deb9u3) ...
      Processing triggers for libc-bin (2.24-11+deb9u1) ...
      Der Fehler besteht weiter..:
      pi@raspberrypi:~ $ systemctl start pivccu
      Failed to start pivccu.service: The name org.freedesktop.PolicyKit1 was not provided by any .service files
      See system logs and 'systemctl status pivccu.service' for details.
      ! pi@raspberrypi:~ $ systemctl status pivccu.service
      ● pivccu.service - piVCCU
      Loaded: loaded (/lib/systemd/system/pivccu.service; enabled; vendor preset: e
      Active: failed (Result: exit-code) since Thu 2017-11-30 19:07:11 UTC; 16min a
      Process: 496 ExecStart=/var/lib/piVCCU/start_container.sh (code=exited, status
      CPU: 79ms
      ! Nov 30 19:07:10 raspberrypi systemd[1]: Starting piVCCU...
      Nov 30 19:07:11 raspberrypi start_container.sh[496]: <11>Nov 30 19:07:11 piVCCU:
      Nov 30 19:07:11 raspberrypi systemd[1]: pivccu.service: Control process exited,
      Nov 30 19:07:11 raspberrypi systemd[1]: Failed to start piVCCU.
      Nov 30 19:07:11 raspberrypi systemd[1]: pivccu.service: Unit entered failed stat
      Nov 30 19:07:11 raspberrypi systemd[1]: pivccu.service: Failed with result 'exit
      lines 1-12/12 (END)...skipping...
      Loaded: loaded (/lib/systemd/system/pivccu.service; enabled; vendor preset: enabled)
      Active: failed (Result: exit-code) since Thu 2017-11-30 19:07:11 UTC; 16min ago
      Process: 496 ExecStart=/var/lib/piVCCU/start_container.sh (code=exited, status=1/FAILURE)
      CPU: 79ms
      Nov 30 19:07:11 raspberrypi start_container.sh[496]: <11>Nov 30 19:07:11 piVCCU: Could not locate raw uart interface. Are the kernel modules and the device tree overlays installed?
      Nov 30 19:07:11 raspberrypi systemd[1]: pivccu.service: Control process exited, code=exited status=1
      Nov 30 19:07:11 raspberrypi systemd[1]: pivccu.service: Unit entered failed state.
      Nov 30 19:07:11 raspberrypi systemd[1]: pivccu.service: Failed with result 'exit-code'.
      ~~@christianbl88:~~
      > Der Pi bricht die Erweiterung auf die ganze SD-Karte ab mit (weiß nicht genau was da stand) konnte nicht epandiert werden!! Vermute das der "leere" Bereich falsch Partitioniert ist! `
      ****Geändert: Code in Code-Tags; Homoran (Mod)****
        deimos
        kannst du bitte genauer beschreiben, wie du das System neu aufgesetzt hast?
        Besteht das Problem auch nach einem Neustart?
        Und dann bitte mal die Ausgabe folgender Befehle (jeweils Zeile pro Zeile ausführen)
        sudo dpkg --get-selection | grep pivccu
        sudo dmesg | grep uart
        cat /boot/config.txt
        sudo pivccu-info
        Viele Grüße
        Alex
        • C Offline
          christianbl88
          mit dem Win32Diskmanager das Image aus dem Download bereich aufgespielt.
          Danach das Password geändert.
          reboot
          Expand filesystem (Ohne Fehler und über die Konsole geprüft)
          sudo reboot
          und zum Schluss:
          sudo apt-get update && sudo apt-get upgrade -y
          sudo reboot
          `pi@raspberrypi:~ $ sudo dpkg --get-selection | grep pivccu
          dpkg: error: unknown option --get-selection
          Type dpkg --help for help about installing and deinstalling packages [*];
          Use 'apt' or 'aptitude' for user-friendly package management;
          Type dpkg -Dhelp for a list of dpkg debug flag values;
          Type dpkg --force-help for a list of forcing options;
          Type dpkg-deb --help for help about manipulating *.deb files;
          Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
          pi@raspberrypi:~ $ sudo dmesg | grep uart
          pi@raspberrypi:~ $ cat /boot/config.txt
          # For more options and information see
          # http://rpf.io/configtxt
          # Some settings may impact device functionality. See link above for details
          # uncomment if you get no picture on HDMI for a default "safe" mode
          #hdmi_safe=1
          # uncomment this if your display has a black border of unused pixels visible
          # and your display can output without overscan
          #disable_overscan=1
          # uncomment the following to adjust overscan. Use positive numbers if console
          # goes off screen, and negative if there is too much border
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          # uncomment to force a console size. By default it will be display's size minus
          # overscan.
          #framebuffer_width=1280
          #framebuffer_height=720
          # uncomment if hdmi display is not detected and composite is being output
          #hdmi_force_hotplug=1
          # uncomment to force a specific HDMI mode (this will force VGA)
          #hdmi_group=1
          #hdmi_mode=1
          # uncomment to force a HDMI mode rather than DVI. This can make audio work in
          # DMT (computer monitor) modes
          #hdmi_drive=2
          # uncomment to increase signal to HDMI, if you have interference, blanking, or
          # no display
          #config_hdmi_boost=4
          # uncomment for composite PAL
          #sdtv_mode=2
          #uncomment to overclock the arm. 700 MHz is the default.
          #arm_freq=800
          # Uncomment some or all of these to enable the optional hardware interfaces
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable the lirc-rpi module
          #dtoverlay=lirc-rpi
          # Additional overlays and parameters are documented /boot/overlays/README
          # Enable audio (loads snd_bcm2835)
          dtparam=audio=on
          dtoverlay=pi3-disable-bt
          dtoverlay=pivccu-bcm2835`
          `~~[code]~~pi@raspberrypi:~ $ sudo pivccu-info
          piVCCU version: 2.29.23-16
          Kernel modules: Not available
          Raw UART dev:   Not available
          Board serial:   Unknown
          State:          STOPPED
          [/code]`
          ~~[quote]~~Hi,
          `~~[code]~~sudo dpkg --get-selection | grep pivccu
          sudo pivccu-info
          [/code]`
          Viele Grüße
          Alex `  `
          • C Offline
            christianbl88
            Auch nach einem neustart besteht das Problem. Hab auch das ganze mal Spannung's frei gemacht
              deimos
              Ok, ich habe eine Ahnung.
              Bitte mal
              sudo dpkg --get-selections | grep pivccu
              sudo dpkg -s pivccu
              sudo dpkg -s pivccu-modules-raspberrypi
              cat /etc/apt/source.list
              • C Offline
                christianbl88
                pi@raspberrypi:~ $ sudo dpkg --get-selections | grep pivccu
                pivccu                                          install
                pivccu-modules-raspberrypi                      install
                pi@raspberrypi:~ $ sudo dpkg -s pivccu
                Package: pivccu
                Status: install ok installed
                Priority: extra
                Section: misc
                Maintainer: Alexander Reinert <alex@areinert.de>Architecture: armhf
                Version: 2.29.23-16
                Depends: pivccu-kernel-modules
                Pre-Depends: lxc, bridge-utils, systemd
                Conffiles:
                 /etc/piVCCU/lxc.config 5fcfff8ebb7c6f59c48ee5861216edbf
                 /lib/systemd/system/pivccu.service c4c2be318a53f427124b4c0364d12636
                Description: piVCCU - Homematic CCU LXC container
                  This package contains piVCCU - a Homematic CCU LXC container
                Homepage: https://github.com/alexreinert/piVCCU
                pi@raspberrypi:~ $ sudo dpkg -s pivccu-modules-raspberrypi
                Package: pivccu-modules-raspberrypi
                Priority: extra
                Section: kernel
                Version: 1.20171029-1-3
                Provides: pivccu-kernel-modules
                Depends: raspberrypi-kernel (= 1.20171029-1)
                Description: Raspberry Pi kernel modules needed for Homematic
                  This package contains the Raspberry Pi kernel needed for Homematic.
                pi@raspberrypi:~ $ cat /etc/apt/source.list
                cat: /etc/apt/source.list: No such file or directory
                pi@raspberrypi:~ $</alex@areinert.de></alex@areinert.de>
                  deimos
                  Und welches Image genau hast du genommen? Das originale von pivccu.de oder das angepasste mit ioBroker?
                    Ich fürchte meins :(
                    hast du dir das hier mal angesehen?
                    http://forum.iobroker.net/viewtopic.php … 76#p100305
                    • C Offline
                      christianbl88
                      Dieses hier aus dem Download bereich:
                      ioBroker_Image_RPi_2-3_20171109_stretch_pivCCU
                        deimos
                        Sorry, beim letzten Befehl muss es sources.list sein (Blöde Autokorrektur…)
                        • C Offline
                          christianbl88
                          @deimos:
                          Sorry, beim letzten Befehl muss es sources.list sein (Blöde Autokorrektur…) `
                          pi@raspberrypi:~ $ cat /etc/apt/sources.list
                          deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
                            deimos
                            Ich versuch das Image mal bei mir zu starten, kann aber etwas dauern. Welchen Pi hast du? 2 oder 3?
                            • C Offline
                              christianbl88
                              pi2 model B
                                Auf so einem habe ich die Installation gemacht
                                  deimos
                                  Ok, habe das Image jetzt grade mal ausprobiert auf einen Pi2B:
                                  • Image auf SD Karte geschrieben
                                  • Erster Start –> piVCCU läuft wunderbar
                                  • Expand Filesystem über raspi-config & Reboot
                                  • piVCCU läuft wunderbar
                                  • sudo apt update && sudo apt upgrade, danach Reboot
                                  Am Image liegt es also nicht.
                                  Aus irgendeinem Grund sind bei dir aber die Kernel Module nicht geladen. Den Grund müssen wir rausbekommen.
                                  Mach bitte mal:
                                  uname -a
                                  ls -la /lib/modules/
                                  ls -la /lib/modules/*/kernel/drivers/pivccu/*
                                  lsmod
                                  ls -la /boot/overlays/pivccu*
                                  cat /proc/device-tree/compatible
                                  ls -la /proc/device-tree/soc/serial*/compatible
                                  cat /proc/device-tree/soc/serial*/compatible
                                  Viele Grüße
                                  Alex
                                  • C Offline
                                    christianbl88
                                    Das Ergebniss:
                                    pi@raspberrypi:~ $ uname -a
                                    Linux raspberrypi 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux
                                    pi@raspberrypi:~ $ ls -la /lib/modules/
                                    total 16
                                    drwxr-xr-x  4 root root 4096 Nov  1 15:39 .
                                    drwxr-xr-x 16 root root 4096 Nov  1 16:15 ..
                                    drwxr-xr-x  3 root root 4096 Nov  1 15:39 4.9.59+
                                    drwxr-xr-x  3 root root 4096 Nov 30 19:04 4.9.59-v7+
                                    pi@raspberrypi:~ $ ls -la /lib/modules/*/kernel/drivers/pivccu/*
                                    -rw-r--r-- 1 root root 10732 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/dw_apb_raw_uart.ko
                                    -rw-r--r-- 1 root root 16680 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/eq3_char_loop.ko
                                    -rw-r--r-- 1 root root 17796 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/generic_raw_uart.ko
                                    -rw-r--r-- 1 root root  9912 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/pl011_raw_uart.ko
                                    -rw-r--r-- 1 root root  5332 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/plat_eq3ccu2.ko
                                    pi@raspberrypi:~ $ lsmod
                                    Module                  Size  Used by
                                    iptable_filter          2220  0
                                    bridge                112535  0
                                    stp                     2218  1 bridge
                                    llc                     5790  2 bridge,stp
                                    fuse                   94600  3
                                    snd_bcm2835            23131  0
                                    snd_pcm                97825  1 snd_bcm2835
                                    snd_timer              22706  1 snd_pcm
                                    snd                    68784  3 snd_timer,snd_bcm2835,snd_pcm
                                    bcm2835_gpiomem         3791  0
                                    uio_pdrv_genirq         3718  0
                                    uio                    10166  1 uio_pdrv_genirq
                                    fixed                   3029  0
                                    ip_tables              12512  1 iptable_filter
                                    x_tables               20921  2 ip_tables,iptable_filter
                                    ipv6                  384613  13 bridge
                                    pi@raspberrypi:~ $ ls -la /boot/overlays/pivccu*
                                    -rwxr-xr-x 1 root root 296 Nov 30 19:04 /boot/overlays/pivccu-bcm2835.dtbo
                                    pi@raspberrypi:~ $ cat /proc/device-tree/compatible
                                    brcm,bcm2835pi@raspberrypi:~ $ ls -la /proc/device-tree/soc/serial*/compatible
                                    -r--r--r-- 1 root root 13 Nov 30 21:28 /proc/device-tree/soc/serial@7e201000/compatible
                                    -r--r--r-- 1 root root 22 Nov 30 21:28 /proc/device-tree/soc/serial@7e215040/compatible
                                    pi@raspberrypi:~ $ cat /proc/device-tree/soc/serial*/compatible
                                    pivccu,pl011brcm,bcm2835-aux-uartpi@raspberrypi:~ $
                                      deimos
                                      @Homoran:
                                      @Homoran:
                                      =leer
                                      muss ich dann wohl nochmal mit deinem Image neu machen :shock: `
                                      Die drei Einträge in der sources.list sind nicht gut, aber das produziert erstmal nur Warnungen und man kann sich nicht sicher sein, ob jetzt testing oder stable verwendet wird.
                                      Das die zweite Datei nicht exisitiert ist nicht schlimm. Es muss ein Eintrag entweder in der ersten oder in der zweiten sein. In meinem Image habe ich das immer in der zweiten eigenen, aber das muss nicht zwingend so sein. In meiner ersten Anleitung war es auch noch direkt in der sources.list.
                                      Viele Grüße
                                      Alex
                                        deimos
                                        ok, das sieht erstmal gut aus. Dann jetzt bitte mal
                                        sudo modprobe pl011_raw_uart
                                        sudo lsmod
                                        sudo pivccu-info
                                        • C Offline
                                          christianbl88
                                          pi@raspberrypi:~ $ sudo modprobe pl011_raw_uart
                                          modprobe: FATAL: Module pl011_raw_uart not found in directory /lib/modules/4.9.59+
                                          pi@raspberrypi:~ $ sudo lsmod
                                          Module                  Size  Used by
                                          bridge                112535  0
                                          stp                     2218  1 bridge
                                          fuse                   94600  3
                                          snd_bcm2835            23131  0
                                          fixed                   3029  0
                                          State:          STOPPED
