  3. Einsteigerfragen
  4. Von BETA zurück auf STABLE
    5.5k
betarepository
25 Beiträge 6 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • sissiwupS sissiwup
    @sissiwup
    Sieht viel besser aus:
    iobroker stop && iobroker update && iobroker upgrade self && iobroker upgrade && iobroker start
    Used repository: live-stable
    Adapter    "admin"        : 5.3.1    , installed 5.3.1
    Adapter    "backitup"     : 2.3.3    , installed 2.3.5
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "devices"      : 1.0.9    , installed 1.0.10
    Adapter    "dwd"          : 2.7.7    , installed 2.7.7
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "geofency"     : 1.0.3    , installed 1.1.0
    Adapter    "habpanel"     : 0.4.3    , installed 0.5.0
    Adapter    "hm-rega"      : 3.0.35   , installed 3.0.37
    Adapter    "hm-rpc"       : 1.15.0   , installed 1.15.8
    Adapter    "ical"         : 1.11.4   , installed 1.11.6
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
    Adapter    "info"         : 1.9.8    , installed 1.9.19
    Adapter    "javascript"   : 5.2.21   , installed 5.3.3
    Controller "js-controller": 4.0.19   , installed 4.0.19
    Adapter    "mqtt"         : 2.4.1    , installed 2.7.3
    Adapter    "ping"         : 1.5.0    , installed 1.5.3
    Adapter    "pushover"     : 2.0.5    , installed 2.1.0
    Adapter    "scenes"       : 2.3.8    , installed 2.3.9
    Adapter    "simple-api"   : 2.6.2    , installed 2.6.3
    Adapter    "socketio"     : 3.1.5    , installed 4.1.4
    Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
    Adapter    "sql"          : 1.16.1   , installed 1.16.2
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.11.1   , installed 1.11.1
    Adapter    "trashschedule": 1.4.1    , installed 1.4.3
    Adapter    "vis"          : 1.4.5    , installed 1.4.12
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-inventwo" : 3.2.8    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-metro"    : 1.1.2    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "web"          : 3.4.16   , installed 4.2.0
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Host    "zotac"          is up to date.
    All adapters are up to date
    Jetzt muss ich nur noch die "zu neuen" zurück drehen ...
    Geht das auch per cmdline?
    @sissiwup
    iobroker upgrade ADAPTERNAME@Versionsnummer
    Wenn es stabil mit den jetzigen Versionen funktioniert würde ich da aber gar nix fummeln. Die Versionen werden irgendwann von den stabilen Versionen überschrieben, wenn die Versionsnummer entsprechend die jetzige übersteigt.
    sissiwupS 1 Antwort Letzte Antwort
      @sissiwup
      sissiwupS Offline
      sissiwupS Offline
      sissiwup
      Hallo, du hast Recht. Ich schaue mir das erstmal so an. Danke.
      MfG
      Sissi
      1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
        @sissiwup
        @sissiwup sagte in Von BETA zurück auf STABLE:
        Mit solchen Verkettungen würde ich nicht arbeiten:
        Besser einzeln eingeben. Dann kann man besser auf Rückmeldungen reagieren.
          sissiwupS Offline
          sissiwupS Offline
          sissiwup
          @thomas-braun sagte in Von BETA zurück auf STABLE:
          Ich dachte durch die && hält er an, sobald es einen Fehler gibt.
          Mache ich eigentlich schon Jahrelang so. Bisher ohne Probleme ...
          MfG
          Sissi
            Das stimmt. Aber nicht jede ungewollte Folgeaktion wirft einen Fehler / Return Code <>0.
              @sissiwup
              iobroker repo list
              sagt?
              echad@chet:/opt/iobroker $ iobroker repo list
              live-beta     : http://iobroker.live/repo/sources-dist-latest.json
              live-stable   : http://iobroker.live/repo/sources-dist.json
              Active repo(s): live-beta
              Mit den live-Servern habe ich eigentlich nie Probleme.
              iobroker update
              sagt?
              daruse
              Hallo, das Thema ist zwar schon länger her, aber vllt könnt ihr mir auf die Sprünge helfen.
              Ich hatte erst die VIS-2 beta installiert dann auf VIS-2 gewechselt. Aber irgendwie nicht über die Adapter, sprich ich kann aktuell nicht einfach auf die neueste Version mit update/upgrade hochziehen.
              iobroker repo list:
              Active repo(s): stable
              iobroker update:
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.2
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Adapter    "evcc"         : 0.0.10   , installed 0.0.10
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "modbus"       : 6.0.1    , installed 6.0.1
              Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
              Adapter    "pushover"     : 3.0.6    , installed 3.0.6
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Könnt ihr mir Bitte sagen wie ich auf die "offizielle" stabile VIS-2 Version komme?
              Danke und viele Grüße,
              daruse
              • D daruse
                iobroker repo list:
                iobroker update:
                daruse
                @daruse sagte in Von BETA zurück auf STABLE:
                Es gibt keine. Nur eine Beta-Version, die über den Reiter npm oder über das Beta-Repo zu beziehen ist.
                • D daruse
                  iobroker repo list:
                  iobroker update:
                  daruse
                  Die gibt es nicht!
                  vis2 ist beta
                    daruse
                    Ok Danke das war mir so nicht bewusst.
                    Ich habe aktuell die Version 2.3.5 installiert und im Änderungsprotokoll hab ich bereits die 2.9.8 gesehen. Wie wäre der saubere Weg dies manuell zu updaten?
                    • D daruse
                      Über den Reiter 'npm'
                        daruse
                        Danke, hat geklappt.
                        Noch eine Frage zum Schluss, wenn VIS-2 stable werden sollte, gibt es dann eine Möglichkeit von beta auf stable zu switchen?
                        W 1 Antwort Letzte Antwort
                        • D daruse
                          W Online
                          W Online
                          Wildbill
                          @daruse Sobald die stable-Version Deine installierte Version „einholt“ wirst Du automatisch über anstehende Updates installiert.
                          Gruss, Jürgen
                          • W Wildbill
                            Gruss, Jürgen
                            daruse
                            @wildbill
                            alles klar
                            Danke euch!
                              @sissiwup
                              Die Ausgabe sieht komisch aus. Da ist irgendwas krummes eingetragen.
                              iobroker repo list
                              <input type="text" id="repo_1_name" name="name" role="textbox" class="editable" style="width: 98%;">: <input type="text" id="repo_1_link" name="link" role="textbox" class="editable" style="width: 98%;">
                              online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
                              fast-online   : http://download.iobroker.net/sources-dist.json
                              Sauber ist es wie oben von mir gepostet.
                              SegwayS Offline
                              SegwayS Offline
                              Segway
                              Mhhh, Stolper ich auch wieder über eine solche Konfiguration. Sieht bei mir auch wieder komplett anders. Hab ich wohl wieder was verpasst oder ist das richtig ?
                              iob repo list
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Gruß Dirk
                              • Thomas BraunT Online
                                @segway
                                Wenn es bei dir funktioniert ist das so in Ordnung.
