  3. Einsteigerfragen
  4. Von BETA zurück auf STABLE
    5.5k
betarepository
25 Beiträge 6 Kommentatoren 3.3k Aufrufe 4 Beobachtet
  • sissiwupS sissiwup
    live bringt im beta keine Timeouts. Probiere jetzt mal stable. Danke für den Tipp
    sissiwupS Offline
    sissiwupS Offline
    sissiwup
    @sissiwup
    Sieht viel besser aus:
    iobroker stop && iobroker update && iobroker upgrade self && iobroker upgrade && iobroker start
    Used repository: live-stable
    Adapter    "admin"        : 5.3.1    , installed 5.3.1
    Adapter    "backitup"     : 2.3.3    , installed 2.3.5
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "devices"      : 1.0.9    , installed 1.0.10
    Adapter    "dwd"          : 2.7.7    , installed 2.7.7
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "geofency"     : 1.0.3    , installed 1.1.0
    Adapter    "habpanel"     : 0.4.3    , installed 0.5.0
    Adapter    "hm-rega"      : 3.0.35   , installed 3.0.37
    Adapter    "hm-rpc"       : 1.15.0   , installed 1.15.8
    Adapter    "ical"         : 1.11.4   , installed 1.11.6
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
    Adapter    "info"         : 1.9.8    , installed 1.9.19
    Adapter    "javascript"   : 5.2.21   , installed 5.3.3
    Controller "js-controller": 4.0.19   , installed 4.0.19
    Adapter    "mqtt"         : 2.4.1    , installed 2.7.3
    Adapter    "ping"         : 1.5.0    , installed 1.5.3
    Adapter    "pushover"     : 2.0.5    , installed 2.1.0
    Adapter    "scenes"       : 2.3.8    , installed 2.3.9
    Adapter    "simple-api"   : 2.6.2    , installed 2.6.3
    Adapter    "socketio"     : 3.1.5    , installed 4.1.4
    Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
    Adapter    "sql"          : 1.16.1   , installed 1.16.2
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.11.1   , installed 1.11.1
    Adapter    "trashschedule": 1.4.1    , installed 1.4.3
    Adapter    "vis"          : 1.4.5    , installed 1.4.12
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-inventwo" : 3.2.8    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-metro"    : 1.1.2    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "web"          : 3.4.16   , installed 4.2.0
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Host    "zotac"          is up to date.
    All adapters are up to date
    Jetzt muss ich nur noch die "zu neuen" zurück drehen ...
    Geht das auch per cmdline?
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
      @sissiwup
      @sissiwup
      iobroker upgrade ADAPTERNAME@Versionsnummer
      Wenn es stabil mit den jetzigen Versionen funktioniert würde ich da aber gar nix fummeln. Die Versionen werden irgendwann von den stabilen Versionen überschrieben, wenn die Versionsnummer entsprechend die jetzige übersteigt.
      sissiwupS 1 Antwort Letzte Antwort
        @sissiwup
        sissiwupS Offline
        sissiwupS Offline
        sissiwup
        Hallo, du hast Recht. Ich schaue mir das erstmal so an. Danke.
        MfG
        Sissi
          @sissiwup
          @sissiwup sagte in Von BETA zurück auf STABLE:
          Mit solchen Verkettungen würde ich nicht arbeiten:
          Besser einzeln eingeben. Dann kann man besser auf Rückmeldungen reagieren.
            sissiwupS Offline
            sissiwupS Offline
            sissiwup
            @thomas-braun sagte in Von BETA zurück auf STABLE:
            Ich dachte durch die && hält er an, sobald es einen Fehler gibt.
            Mache ich eigentlich schon Jahrelang so. Bisher ohne Probleme ...
            MfG
            Sissi
              Das stimmt. Aber nicht jede ungewollte Folgeaktion wirft einen Fehler / Return Code <>0.
                @sissiwup
                iobroker repo list
                sagt?
                echad@chet:/opt/iobroker $ iobroker repo list
                live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                live-stable   : http://iobroker.live/repo/sources-dist.json
                Active repo(s): live-beta
                Mit den live-Servern habe ich eigentlich nie Probleme.
                iobroker update
                sagt?
                daruse
                Hallo, das Thema ist zwar schon länger her, aber vllt könnt ihr mir auf die Sprünge helfen.
                Ich hatte erst die VIS-2 beta installiert dann auf VIS-2 gewechselt. Aber irgendwie nicht über die Adapter, sprich ich kann aktuell nicht einfach auf die neueste Version mit update/upgrade hochziehen.
                iobroker repo list:
                Active repo(s): stable
                iobroker update:
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.12.2
                Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.17   , installed 5.0.17
                Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Könnt ihr mir Bitte sagen wie ich auf die "offizielle" stabile VIS-2 Version komme?
                Danke und viele Grüße,
                daruse
                • D daruse
                  iobroker repo list:
                  iobroker update:
                  daruse
                  @daruse sagte in Von BETA zurück auf STABLE:
                  Es gibt keine. Nur eine Beta-Version, die über den Reiter npm oder über das Beta-Repo zu beziehen ist.
                  • D daruse
                    iobroker repo list:
                    iobroker update:
                    daruse
                    Die gibt es nicht!
                    vis2 ist beta
                      daruse
                      Ok Danke das war mir so nicht bewusst.
                      Ich habe aktuell die Version 2.3.5 installiert und im Änderungsprotokoll hab ich bereits die 2.9.8 gesehen. Wie wäre der saubere Weg dies manuell zu updaten?
                      • D daruse
                        Über den Reiter 'npm'
                          daruse
                          Danke, hat geklappt.
                          Noch eine Frage zum Schluss, wenn VIS-2 stable werden sollte, gibt es dann eine Möglichkeit von beta auf stable zu switchen?
                          W 1 Antwort Letzte Antwort
                          • D daruse
                            W Online
                            W Online
                            Wildbill
                            @daruse Sobald die stable-Version Deine installierte Version „einholt“ wirst Du automatisch über anstehende Updates installiert.
                            Gruss, Jürgen
                            • W Wildbill
                              Gruss, Jürgen
                              daruse
                              @wildbill
                              alles klar
                              Danke euch!
                                @sissiwup
                                Die Ausgabe sieht komisch aus. Da ist irgendwas krummes eingetragen.
                                iobroker repo list
                                <input type="text" id="repo_1_name" name="name" role="textbox" class="editable" style="width: 98%;">: <input type="text" id="repo_1_link" name="link" role="textbox" class="editable" style="width: 98%;">
                                online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
                                fast-online   : http://download.iobroker.net/sources-dist.json
                                Sauber ist es wie oben von mir gepostet.
                                SegwayS Offline
                                SegwayS Offline
                                Segway
                                Mhhh, Stolper ich auch wieder über eine solche Konfiguration. Sieht bei mir auch wieder komplett anders. Hab ich wohl wieder was verpasst oder ist das richtig ?
                                iob repo list
                                Stable (default): http://download.iobroker.net/sources-dist.json
                                Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                Gruß Dirk
                                • Thomas BraunT Online
                                  @segway
                                  Wenn es bei dir funktioniert ist das so in Ordnung.
