  4. Node-Red
  5. Node Red DP erstellen
    6.4k
42 Beiträge 2 Kommentatoren 5.3k Aufrufe 2 Beobachtet
  • mickymM mickym
    Du musst in der 1. Change Node (Ändere srcBle) nur auf die Objekteigenschaft verweisen:
    Das rot unterstrichene bitte dort anfügen.
    Und hinten NICHTS ändern - das topic in der Change Node bleibt so wie ich es erstellt habe.
    Nichts mit payload etc.
    Hier nochmal ein frischer Import:
           "id": "97b845b5a6599224",
           "type": "split",
           "z": "517cd16e4d7e6ae4",
           "name": "teile Objekt in Einzelnachrichten",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "arraySpltType": "len",
           "stream": false,
           "addname": "topic",
           "x": 830,
           "y": 660,
           "wires": [
                   "4ec1e6e4e84579e7"
           "id": "042bf417501565f3",
           "type": "change",
           "name": "Ändere srcBle",
           "rules": [
                   "t": "change",
                   "p": "srcBle.mac",
                   "pt": "msg",
                   "from": ":",
                   "fromt": "str",
                   "to": "-",
                   "tot": "str"
                   "t": "set",
                   "p": "srcBle",
                   "pt": "msg",
                   "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle.mac",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 280,
           "y": 660,
           "wires": [
                   "adb8c34172c9605f"
           "id": "adb8c34172c9605f",
           "type": "change",
           "name": "Entferne payload-Eigenschaften",
           "rules": [
                   "t": "delete",
                   "p": "payload.address",
                   "pt": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 530,
           "y": 660,
           "wires": [
                   "97b845b5a6599224"
           "id": "4ec1e6e4e84579e7",
           "type": "change",
           "name": "erstelle topic",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "srcBle & \".\" & topic",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1070,
           "y": 660,
           "wires": [
                   "bd42f02cc76dacad"
           "id": "bd42f02cc76dacad",
           "type": "ioBroker out",
           "name": "schreibe Werte",
           "topic": "",
           "ack": "true",
           "autoCreate": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "false",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1260,
           "y": 660,
           "wires": []
    dos1973
    @mickym
    nee klappt nicht.
    habe es ergänzt
    sieht alles genauso aus
    • D dos1973
      @mickym
      nee klappt nicht.
      habe es ergänzt
      mickymM Offline
      mickymM Offline
      mickym
      @dos1973 Entweder nochmal frischer Import - oder Du hast hinten an der topic Node was geändert. Ansonsten klemm die iobroker-out Node ab, mach einen debug dahinter und poste das. Aber erst neu importieren.
      Die Nachrichten, die in die iobroker-Out NOde gehen müssen so aussehen:
      • mickymM mickym
        dos1973
        @mickym
        ich habe es komplett neu importiert
        • D dos1973
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          @dos1973 sagte in Node Red DP erstellen:
          @mickym
          Und Debug Node hinten dran gemacht und bitte Screenshot der einzelnen Nachrichten bevor diese in die iobroker-Out Node gehen. - Ich hab dir gerade geschickt wie das aussehen muss.
          • mickymM mickym
            @mickym
            dos1973
            @mickym
            ich hoffe ich habs verstanden
            • D dos1973
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              @dos1973 OK ich weiß nicht wo die 2 Punkte her kommen.
              Ich werde nochmal mit diesem Objekt Deinen Input nachbauen und Du sagst, ob der mit Deinem identisch ist.
              {"scriptVersion":"0.1","src":"shellies/Pro3_EM","srcBle":{"mac":"b4:35:22:fe:56:ad"},"payload":{"encryption":false,"BTHome_version":2,"pid":253,"battery":100,"button":2,"rssi":-79,"address":"b4:35:22:fe:56:ad"}}
              • mickymM mickym
                dos1973
                @mickym
                ist irgendwie eine schwere geburt...
                • mickymM Offline
                  mickymM Offline
                  mickym
                  Ich denke ich habe den Fehler gefunden:
                  da muss der Punkt raus - sorry war schlampig meinerseits
                  FALLS NICHT DANN
                  ... bitte diesen ganzen Flow importieren und bestätigen erstmal, dass nun das konstruierte Eingangsobjekt genauso wie Deine Nachrichten aussehen:
                  Also mit der Inject Node testen.
                  Wenn das so ist dann kannst Du vor die 2. Reihe Deine mqtt-In klemmen
                         "id": "85395d3e7d299c24",
                         "type": "inject",
                         "name": "Eingangswerte",
                         "props": [
                                 "p": "input",
                                 "v": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                                 "vt": "json"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 180,
                         "y": 780,
                         "wires": [
                                 "9ac0c724ea2285d2",
                                 "71622aabe05c1ac5"
                         "id": "9ac0c724ea2285d2",
                         "type": "change",
                         "name": "konstruiere OriginalObjekt",
                         "rules": [
                                 "t": "move",
                                 "p": "input.scriptVersion",
                                 "pt": "msg",
                                 "to": "scriptVersion",
                                 "tot": "msg"
                                 "t": "move",
                                 "p": "input.src",
                                 "pt": "msg",
                                 "to": "src",
                                 "tot": "msg"
                                 "t": "set",
                                 "p": "input.srcBle",
                                 "pt": "msg",
                                 "to": "srcBle",
                                 "tot": "msg"
                                 "t": "move",
                                 "p": "input.payload",
                                 "pt": "msg",
                                 "to": "payload",
                                 "tot": "msg"
                                 "t": "delete",
                                 "p": "input",
                                 "pt": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 410,
                         "y": 780,
                         "wires": [
                                 "dbf5c78009b4f581",
                                 "f19cc6f7778c2633"
                         "id": "71622aabe05c1ac5",
                         "type": "debug",
                         "name": "Eingabewert",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "true",
                         "targetType": "full",
                         "statusVal": "",
                         "statusType": "auto",
                         "x": 370,
                         "y": 740,
                         "wires": []
                         "id": "dbf5c78009b4f581",
                         "type": "debug",
                         "name": "Originalobjekt",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "true",
                         "statusVal": "",
                         "x": 620,
                         "y": 740,
                         "wires": []
                         "id": "831875c3be845a77",
                         "type": "split",
                         "splt": "\\n",
                         "spltType": "str",
                         "arraySplt": 1,
                         "stream": false,
                         "addname": "topic",
                         "x": 790,
                         "y": 840,
                         "wires": [
                                 "4e6bbe32dfcc7c5d"
                         "id": "f19cc6f7778c2633",
                         "type": "change",
                         "rules": [
                                 "t": "change",
                                 "p": "srcBle.mac",
                                 "pt": "msg",
                                 "from": ":",
                                 "fromt": "str",
                                 "to": "-",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "srcBle",
                                 "pt": "msg",
                                 "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete\" & srcBle.mac",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 240,
                         "y": 840,
                         "wires": [
                                 "c1cac0b6dc174190"
                         "id": "c1cac0b6dc174190",
                         "type": "change",
                         "rules": [
                                 "t": "delete",
                                 "pt": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 490,
                         "y": 840,
                         "wires": [
                                 "831875c3be845a77"
                         "id": "4e6bbe32dfcc7c5d",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1030,
                         "y": 840,
                         "wires": [
                                 "15bab36dddd209ed",
                                 "474c1b7582b85047"
                         "id": "474c1b7582b85047",
                         "type": "debug",
                         "name": "Einzelnachrichten",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "payload",
                         "targetType": "msg",
                         "statusVal": "",
                         "x": 1230,
                         "y": 800,
                         "wires": []
                         "id": "15bab36dddd209ed",
                         "d": true,
                         "topic": "",
                         "ack": "true",
                         "stateName": "",
                         "role": "",
                         "payloadType": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1220,
                         "y": 840,
                         "wires": []
                  • mickymM mickym
                    FALLS NICHT DANN
                           "type": "inject",
                           "props": [
                                   "p": "input",
                                   "vt": "json"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "x": 180,
                           "y": 780,
                           "wires": [
                                   "9ac0c724ea2285d2",
                                   "71622aabe05c1ac5"
                           "type": "change",
                           "rules": [
                                   "t": "move",
                                   "pt": "msg",
                                   "tot": "msg"
                                   "t": "move",
                                   "p": "input.src",
                                   "pt": "msg",
                                   "to": "src",
                                   "tot": "msg"
                                   "t": "set",
                                   "pt": "msg",
                                   "to": "srcBle",
                                   "tot": "msg"
                                   "t": "move",
                                   "pt": "msg",
                                   "to": "payload",
                                   "tot": "msg"
                                   "t": "delete",
                                   "p": "input",
                                   "pt": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 410,
                           "y": 780,
                           "wires": [
                                   "dbf5c78009b4f581",
                                   "f19cc6f7778c2633"
                           "type": "debug",
                           "active": false,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "complete": "true",
                           "statusVal": "",
                           "x": 370,
                           "y": 740,
                           "wires": []
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "complete": "true",
                           "statusVal": "",
                           "x": 620,
                           "y": 740,
                           "wires": []
                           "type": "split",
                           "splt": "\\n",
                           "spltType": "str",
                           "arraySplt": 1,
                           "stream": false,
                           "addname": "topic",
                           "x": 790,
                           "y": 840,
                           "wires": [
                                   "4e6bbe32dfcc7c5d"
                           "type": "change",
                           "rules": [
                                   "t": "change",
                                   "p": "srcBle.mac",
                                   "pt": "msg",
                                   "from": ":",
                                   "fromt": "str",
                                   "to": "-",
                                   "tot": "str"
                                   "t": "set",
                                   "p": "srcBle",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 240,
                           "y": 840,
                           "wires": [
                                   "c1cac0b6dc174190"
                           "type": "change",
                           "rules": [
                                   "t": "delete",
                                   "pt": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 490,
                           "y": 840,
                           "wires": [
                                   "831875c3be845a77"
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 1030,
                           "y": 840,
                           "wires": [
                                   "15bab36dddd209ed",
                                   "474c1b7582b85047"
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1230,
                           "y": 800,
                           "wires": []
                           "d": true,
                           "topic": "",
                           "ack": "true",
                           "stateName": "",
                           "role": "",
                           "payloadType": "",
                           "stateUnit": "",
                           "stateMin": "",
                           "stateMax": "",
                           "x": 1220,
                           "y": 840,
                           "wires": []
                    dos1973
                    @mickym
                    wenn ich den "Eingangswert Triggere" passiert nichts in der DP struktur
                    • D dos1973
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @dos1973 Das ist klar - ist doch hinten deaktiviert. Wie gesagt mach einfach den Punkt raus an dem Originalflow den Du schon hast.
                      • mickymM mickym
                        dos1973
                        @mickym
                        ja, habs zu spät gesehen :-)
                        • D dos1973
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @dos1973
                          Das sollte aber hinhauen. Wie gesagt vorher war nur der Punkt zuviel
                          • mickymM mickym
                            @dos1973
                            dos1973
                            @mickym
                            das ist jetzt der neue flow.
                            es passt aber nicht??
                            • D dos1973
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @dos1973 Klemm bitte nochmal die iobroker out Node ab. Lösche bitte in den Objekten nochmal den Baum Shelly-BLE-Geräte und poste nun die Einzelnachrichten im Debugfenster. Vielleicht auch den Browser refreshen -
                              • mickymM mickym
                                dos1973
                                @mickym
                                mach icg gleich.
                                aber schau mal hier.
                                ich triggere das manuell und das kommt an. hier fehlt do schon die mac als übergeordneter folder
                                • D dos1973
                                  @mickym
                                  mach icg gleich.
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @dos1973 Oh ich sehe - mein Fehler - ich bin heute anscheinend nicht fit.
                                  • mickymM mickym
                                    dos1973
                                    @mickym
                                    • mickymM Offline
                                      mickymM Offline
                                      mickym
                                      So nun kommen bei mir aber die topics mit der mac Adresse raus:
                                      Also das Ganze nochmal zum Import - erst mit der Inject Node testen:
                                             "type": "inject",
                                             "props": [
                                                     "p": "input",
                                                     "vt": "json"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "x": 180,
                                             "y": 780,
                                             "wires": [
                                                     "9ac0c724ea2285d2",
                                                     "71622aabe05c1ac5"
                                             "type": "change",
                                             "rules": [
                                                     "t": "move",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                                     "t": "move",
                                                     "p": "input.src",
                                                     "pt": "msg",
                                                     "to": "src",
                                                     "tot": "msg"
                                                     "t": "move",
                                                     "pt": "msg",
                                                     "to": "srcBle",
                                                     "tot": "msg"
                                                     "t": "move",
                                                     "pt": "msg",
                                                     "to": "payload",
                                                     "tot": "msg"
                                                     "t": "delete",
                                                     "p": "input",
                                                     "pt": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 410,
                                             "y": 780,
                                             "wires": [
                                                     "dbf5c78009b4f581",
                                                     "f19cc6f7778c2633"
                                             "type": "debug",
                                             "active": false,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "complete": "true",
                                             "statusVal": "",
                                             "x": 370,
                                             "y": 740,
                                             "wires": []
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "complete": "true",
                                             "statusVal": "",
                                             "x": 620,
                                             "y": 740,
                                             "wires": []
                                             "type": "split",
                                             "splt": "\\n",
                                             "spltType": "str",
                                             "arraySplt": 1,
                                             "stream": false,
                                             "addname": "topic",
                                             "x": 790,
                                             "y": 840,
                                             "wires": [
                                                     "4e6bbe32dfcc7c5d"
                                             "type": "change",
                                             "rules": [
                                                     "t": "change",
                                                     "p": "srcBle.mac",
                                                     "pt": "msg",
                                                     "from": ":",
                                                     "fromt": "str",
                                                     "to": "-",
                                                     "tot": "str"
                                                     "t": "set",
                                                     "p": "srcBle",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 240,
                                             "y": 840,
                                             "wires": [
                                                     "c1cac0b6dc174190"
                                             "type": "change",
                                             "rules": [
                                                     "t": "delete",
                                                     "pt": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 490,
                                             "y": 840,
                                             "wires": [
                                                     "831875c3be845a77"
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "topic",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1030,
                                             "y": 840,
                                             "wires": [
                                                     "15bab36dddd209ed",
                                                     "474c1b7582b85047"
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 1230,
                                             "y": 800,
                                             "wires": []
                                             "topic": "",
                                             "ack": "true",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1220,
                                             "y": 840,
                                             "wires": []
                                      • mickymM Offline
                                        mickymM Offline
                                        mickym
                                        Und wenn es mit der Inject Node geht und mit den Nachrichten aus dem mqtt-In Node nicht - dann bitte mal genau schauen ,ob Du noch Unterschiede im konstruierten Nachrichtenobjekt mit der Inject Node und der aus der mqtt-In Node feststellen kannst.
                                        • mickymM mickym
                                          dos1973
                                          @mickym
                                          ja mit inject gehts, mit der nachrichten nicht
                                          der untere ist mit inject, der obere mit der nachricht
