  4. [gelöst] simpleApi kann nicht %B0 aber °
    5.8k
25 Beiträge 2 Kommentatoren 2.8k Aufrufe
  • apollon77A Offline
    Welche exakte Fehlermeldung kommt denn im Log?
      klassisch
      Habe das Log mal auf "silly" gestellt:
      simple-api.0 2017-11-26 18:05:45.179 debug Add to Response-Get: {"id":"data.0.heating.Keller.p-red","val":1027.83,"value":1027.83}
      simple-api.0 2017-11-26 18:05:45.178 debug Add to Response-Get: {"id":"data.0.heating.Keller.Dew-T","val":5.27,"value":5.27}
      simple-api.0 2017-11-26 18:05:45.176 debug Add to Response-Get: {"id":"data.0.heating.Keller.H-abs","val":6.67,"value":6.67}
      simple-api.0 2017-11-26 18:05:45.135 debug Add to Response-Get: {"id":"data.0.heating.Keller.H-rel","val":50.59,"value":50.59}
      simple-api.0 2017-11-26 18:05:45.120 debug Add to Response-Get: {"id":"data.0.heating.Keller.Temp","val":15.47,"value":15.47}
      simple-api.0 2017-11-26 18:05:45.107 debug GET-setBulk for id=data.0.heating.Keller.p-red, oid=p-redused=data.0.heating.Keller.p-red, value=1027.83
      simple-api.0 2017-11-26 18:05:45.106 debug GET-setBulk for id=data.0.heating.Keller.Dew-T, oid=Dew-Tused=data.0.heating.Keller.Dew-T, value=5.27
      simple-api.0 2017-11-26 18:05:45.106 debug GET-setBulk for id=data.0.heating.Kelle.H-abs, oid=H-absused=data.0.heating.Keller.H-abs, value=6.67
      simple-api.0 2017-11-26 18:05:45.105 debug GET-setBulk for id=data.0.heating.Keller.H-rel, oid=H-relused=data.0.heating.Keller.H-rel, value=50.59
      simple-api.0 2017-11-26 18:05:45.105 debug GET-setBulk for id=data.0.heating.Keller.Temp, oid=Tempused=data.0.heating.Keller.Temp, value=15.47
      simple-api.0 2017-11-26 18:05:45.071 debug Values: {"data.0.heating.Keller.Temp":"15.47","data.0.heating.Keller.H-rel":"50.59","data.0.heating.Keller.H-abs":"6.67","data.0.heating.Keller.Dew-T":"5.27","data.0.heating.Keller
      simple-api.0 2017-11-26 18:05:35.749 info http server listening on port 8087
      simple-api.0 2017-11-26 18:05:35.748 info Allow states only when user is owner: false
      simple-api.0 2017-11-26 18:05:35.747 info simpleAPI server listening on port 8087
      simple-api.0 2017-11-26 18:05:35.746 info starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
      host.orangepiplus2e 2017-11-26 18:05:33.132 info instance system.adapter.simple-api.0 started with pid 3841
      nut.0 2017-11-26 18:05:24.976 info All Nut values set
      nut.0 2017-11-26 18:05:24.803 info Start NUT update
      host.orangepiplus2e 2017-11-26 18:05:03.058 info Restart adapter system.adapter.simple-api.0 because enabled
      host.orangepiplus2e 2017-11-26 18:05:03.057 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
      simple-api.0 2017-11-26 18:04:25.715 debug Add to Response-Get: {"id":"data.0.dehumid01.distWaterTank","val":53.33,"value":53.33}
      simple-api.0 2017-11-26 18:04:25.715 debug Add to Response-Get: {"id":"data.0.dehumid01.state","val":1,"value":1}
      simple-api.0 2017-11-26 18:04:25.714 debug Add to Response-Get: {"id":"data.0.dehumid01.p-red","val":1027.31,"value":1027.31}
      simple-api.0 2017-11-26 18:04:25.714 debug Add to Response-Get: {"id":"data.0.dehumid01.DewT","val":14.32,"value":14.32}
      simple-api.0 2017-11-26 18:04:25.713 debug Add to Response-Get: {"id":"data.0.dehumid01.H-abs","val":11.88,"value":11.88}
      simple-api.0 2017-11-26 18:04:25.674 debug Add to Response-Get: {"id":"data.0.dehumid01.H-rel","val":52.42,"value":52.42}
      simple-api.0 2017-11-26 18:04:25.673 debug Add to Response-Get: {"id":"data.0.dehumid01.Temp","val":24.72,"value":24.72}
      simple-api.0 2017-11-26 18:04:25.645 debug GET-setBulk for id=data.0.dehumid01.distWaterTank, oid=distWaterTankused=data.0.dehumid01.distWaterTank, value=53.33
      simple-api.0 2017-11-26 18:04:25.644 debug GET-setBulk for id=data.0.dehumid01.state, oid=stateused=data.0.dehumid01.state, value=1
      simple-api.0 2017-11-26 18:04:25.643 debug GET-setBulk for id=data.0.dehumid01.p-red, oid=p-redused=data.0.dehumid01.p-red, value=1027.31
      simple-api.0 2017-11-26 18:04:25.643 debug GET-setBulk for id=data.0.dehumid01.DewT, oid=DewTused=data.0.dehumid01.DewT, value=14.32
      In ursächlichem Zusammenhang mit der %25 sehe ich
      Mit dem Log auf "debug"
      host.orangepiplus2e	2017-11-26 18:11:26.104	info	Restart adapter system.adapter.simple-api.0 because enabled
      host.orangepiplus2e	2017-11-26 18:11:26.102	error	instance system.adapter.simple-api.0 terminated with code 0 (OK)
      simple-api.0	2017-11-26 18:11:26.050	info	terminating
      simple-api.0	2017-11-26 18:11:26.031	info	terminating http server on port 8087
      simple-api.0	2017-11-26 18:11:26.027	error	at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
      simple-api.0	2017-11-26 18:11:26.027	error	at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
      simple-api.0	2017-11-26 18:11:26.027	error	at Server.emit (events.js:172:7)
      simple-api.0	2017-11-26 18:11:26.027	error	at emitTwo (events.js:87:13)
      simple-api.0	2017-11-26 18:11:26.027	error	at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
      simple-api.0	2017-11-26 18:11:26.027	error	at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:387:79)
      simple-api.0	2017-11-26 18:11:26.027	error	at decodeURIComponent (native)
      simple-api.0	2017-11-26 18:11:26.027	error	URIError: URI malformed
      simple-api.0	2017-11-26 18:11:26.013	error	uncaught exception: URI malformed
        Bitte installiere mal die Version vom GitHub (1.6.1) und schick dann nochmal die debug-Ausgabe bitte
          klassisch
          Vielen Dank für Deine Mühen!
          simple-api.0 2017-11-26 22:02:39.636 info http server listening on port 8087
          simple-api.0 2017-11-26 22:02:39.636 info Allow states only when user is owner: false
          simple-api.0 2017-11-26 22:02:39.635 info simpleAPI server listening on port 8087
          simple-api.0 2017-11-26 22:02:39.635 info starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
          host.orangepiplus2e 2017-11-26 22:02:37.014 info instance system.adapter.simple-api.0 started with pid 4545
          host.orangepiplus2e 2017-11-26 22:02:06.932 info Restart adapter system.adapter.simple-api.0 because enabled
          host.orangepiplus2e 2017-11-26 22:02:06.930 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
          simple-api.0 2017-11-26 22:02:06.847 info terminating http server on port 8087
          simple-api.0 2017-11-26 22:02:06.843 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
          simple-api.0 2017-11-26 22:02:06.843 error at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
          simple-api.0 2017-11-26 22:02:06.843 error at Server.emit (events.js:172:7)
          simple-api.0 2017-11-26 22:02:06.843 error at emitTwo (events.js:87:13)
          simple-api.0 2017-11-26 22:02:06.843 error at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
          simple-api.0 2017-11-26 22:02:06.843 error at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:405:79)
          simple-api.0 2017-11-26 22:02:06.843 error at decodeURIComponent (native)
          simple-api.0 2017-11-26 22:02:06.843 error URIError: URI malformed
          simple-api.0 2017-11-26 22:02:06.829 error uncaught exception: URI malformed
          simple-api.0 2017-11-26 22:01:05.209 info http server listening on port 8087
          simple-api.0 2017-11-26 22:01:05.199 info Allow states only when user is owner: false
          simple-api.0 2017-11-26 22:01:05.197 info simpleAPI server listening on port 8087
          simple-api.0 2017-11-26 22:01:05.113 info starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
          simple-api.0 2017-11-26 22:01:04.978 debug statesDB connected
          simple-api.0 2017-11-26 22:01:04.837 debug objectDB connected
          host.orangepiplus2e 2017-11-26 22:01:01.702 info instance system.adapter.simple-api.0 started with pid 4535
          host.orangepiplus2e 2017-11-26 22:00:59.227 info instance system.adapter.simple-api.0 terminated with code 0 (OK)
          Man sieht noch die Instalation der 1.6.1.
          Ansonsten sehe ich nicht viel Neues. Als Laie würde ich sagen, das kommt tief aus einer JS engine…
            Ok, installiere bitte mal von Github. Versionsnummer ist die gleiche ich habe beim Dekodieren aber Debug Logging eingebaut. Also bitte nochmal in Debug laufen lassen und dann hier posten was Log sagt.
              klassisch
              Guten Morgen,
              vielen Dank, hier mit der neuesten Version….
              simple-api.0 2017-11-27 06:29:15.330 info http server listening on port 8087
              simple-api.0 2017-11-27 06:29:15.329 info Allow states only when user is owner: false
              simple-api.0 2017-11-27 06:29:15.328 info simpleAPI server listening on port 8087
              simple-api.0 2017-11-27 06:29:15.328 info starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
              host.orangepiplus2e 2017-11-27 06:29:12.655 info instance system.adapter.simple-api.0 started with pid 5415
              host.orangepiplus2e 2017-11-27 06:28:42.568 info Restart adapter system.adapter.simple-api.0 because enabled
              host.orangepiplus2e 2017-11-27 06:28:42.566 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
              simple-api.0 2017-11-27 06:28:42.506 info terminating
              simple-api.0 2017-11-27 06:28:42.487 info terminating http server on port 8087
              simple-api.0 2017-11-27 06:28:42.483 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
              simple-api.0 2017-11-27 06:28:42.483 error at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
              simple-api.0 2017-11-27 06:28:42.483 error at Server.emit (events.js:172:7)
              simple-api.0 2017-11-27 06:28:42.483 error at emitTwo (events.js:87:13)
              simple-api.0 2017-11-27 06:28:42.483 error at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
              simple-api.0 2017-11-27 06:28:42.483 error at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:406:79)
              simple-api.0 2017-11-27 06:28:42.483 error at decodeURIComponent (native)
              simple-api.0 2017-11-27 06:28:42.483 error URIError: URI malformed
              simple-api.0 2017-11-27 06:28:42.469 error uncaught exception: URI malformed
              simple-api.0 2017-11-27 06:28:42.447 debug
              simple-api.0 2017-11-27 06:28:42.447 debug High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
              simple-api.0 2017-11-27 06:28:42.447 debug 192.178.99.99
              simple-api.0 2017-11-27 06:28:42.447 debug Try Decode 2: Garten-IR-T-Sky
              simple-api.0 2017-11-27 06:28:42.445 debug Decode Result 1: High humidity warning - Garten-IR-T-Sky
              simple-api.0 2017-11-27 06:28:42.444 debug Try Decode 1: High humidity warning - Garten-IR-T-Sky
              simple-api.0 2017-11-27 06:28:42.443 debug Decode Result 0: email@gmx.de
              simple-api.0 2017-11-27 06:28:42.440 debug email@gmx.de
              host.orangepiplus2e 2017-11-27 06:28:13.850 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              iobroker 2017-11-27 06:28:13.057 info exit 0
              iobroker 2017-11-27 06:28:12.922 info upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
              iobroker 2017-11-27 06:28:12.796 info upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
              iobroker 2017-11-27 06:28:12.767 info got /opt/iobroker/node_modules/iobroker.simple-api/admin
              iobroker 2017-11-27 06:28:12.606 info iobroker.simple-api@1.6.1 opt/iobroker/node_modules/iobroker.simple-api
              iobroker 2017-11-27 06:27:22.524 info npm install https://github.com/ioBroker/ioBroker.simple-api/tarball/master --production --prefix "/opt/iobroker" (System call)
              iobroker 2017-11-27 06:27:21.988 info install https://github.com/ioBroker/ioBroker.simple-api/tarball/master
              iobroker 2017-11-27 06:27:19.750 info url "https://github.com/ioBroker/ioBroker.simple-api/tarball/master" simple-api --debug
                Bitte 1.6.2 vom Github versuchen, sollte das Problem fixen
                  klassisch
                  Vielen Dank, but not really_
                  simple-api.0 2017-11-27 08:55:05.035 info http server listening on port 8087
                  simple-api.0 2017-11-27 08:55:05.035 info Allow states only when user is owner: false
                  simple-api.0 2017-11-27 08:55:05.034 info simpleAPI server listening on port 8087
                  simple-api.0 2017-11-27 08:55:05.034 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                  host.orangepiplus2e 2017-11-27 08:55:02.445 info instance system.adapter.simple-api.0 started with pid 5837
                  host.orangepiplus2e 2017-11-27 08:54:32.359 info Restart adapter system.adapter.simple-api.0 because enabled
                  host.orangepiplus2e 2017-11-27 08:54:32.356 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                  simple-api.0 2017-11-27 08:54:32.283 info terminating
                  simple-api.0 2017-11-27 08:54:32.224 info terminating http server on port 8087
                  simple-api.0 2017-11-27 08:54:32.218 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                  simple-api.0 2017-11-27 08:54:32.218 error at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
                  simple-api.0 2017-11-27 08:54:32.218 error at Server.emit (events.js:172:7)
                  simple-api.0 2017-11-27 08:54:32.218 error at emitTwo (events.js:87:13)
                  simple-api.0 2017-11-27 08:54:32.218 error at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
                  simple-api.0 2017-11-27 08:54:32.218 error at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:406:79)
                  simple-api.0 2017-11-27 08:54:32.218 error at decodeURIComponent (native)
                  simple-api.0 2017-11-27 08:54:32.218 error URIError: URI malformed
                  simple-api.0 2017-11-27 08:54:32.197 error uncaught exception: URI malformed
                  simple-api.0 2017-11-27 08:54:32.146 debug
                  simple-api.0 2017-11-27 08:54:32.146 debug High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                  simple-api.0 2017-11-27 08:54:32.146 debug 192.178.99.99
                  simple-api.0 2017-11-27 08:54:32.146 debug Try Decode 2: Garten-IR-T-Sky
                  simple-api.0 2017-11-27 08:54:32.144 debug Decode Result 1: High humidity warning - Garten-IR-T-Sky
                  simple-api.0 2017-11-27 08:54:32.143 debug Try Decode 1: High humidity warning - Garten-IR-T-Sky
                  simple-api.0 2017-11-27 08:54:32.141 debug Decode Result 0: email@email.de
                  simple-api.0 2017-11-27 08:54:32.138 debug Try Decode 0: email@email.de
                  host.orangepiplus2e 2017-11-27 08:54:10.954 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                  iobroker 2017-11-27 08:54:10.244 info exit 0
                  iobroker 2017-11-27 08:54:10.108 info upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                  iobroker 2017-11-27 08:54:09.967 info upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                  iobroker 2017-11-27 08:54:09.939 info got /opt/iobroker/node_modules/iobroker.simple-api/admin
                  iobroker 2017-11-27 08:54:09.781 info iobroker.simple-api@1.6.2 opt/iobroker/node_modules/iobroker.simple-api
                  Warte noch einen Moment. Eben hat es mit einem Teilstring geklappt. Das % kam durch, lass mich noch etwas schauen…
                  Sehr seltsam. Jetzt hat die Übetrtragung ein paarmal geklappt, dann das
                  simple-api.0	2017-11-27 09:06:13.075	info	http server listening on port 8087
                  simple-api.0	2017-11-27 09:06:13.075	info	Allow states only when user is owner: false
                  simple-api.0	2017-11-27 09:06:13.074	info	simpleAPI server listening on port 8087
                  simple-api.0	2017-11-27 09:06:13.074	info	starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                  host.orangepiplus2e	2017-11-27 09:06:10.503	info	instance system.adapter.simple-api.0 started with pid 5860
                  host.orangepiplus2e	2017-11-27 09:05:40.430	info	Restart adapter system.adapter.simple-api.0 because enabled
                  host.orangepiplus2e	2017-11-27 09:05:40.428	error	instance system.adapter.simple-api.0 terminated with code 0 (OK)
                  simple-api.0	2017-11-27 09:05:40.356	info	terminating http server on port 8087
                  simple-api.0	2017-11-27 09:05:40.355	error	URIError: URI malformed at decodeURI (native) at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:397:19) at Server.requestProcessor (/opt/iobroker/node_m
                  simple-api.0	2017-11-27 09:05:40.353	error	uncaught exception: URI malformed
                  nut.0	2017-11-27 09:05:26.876	info	All Nut values set
                  nut.0	2017-11-27 09:05:26.778	info	Start NUT update
                  email.0	2017-11-27 09:04:39.738	info	sent to email@email.de
                  email.0	2017-11-27 09:04:38.671	info	Send email: {"from":"email.email@gmail.com","to":"email@email.de","subject":"High humidity warning - Garten-IR-T-Sky","text":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-2
                  simple-api.0	2017-11-27 09:04:38.622	debug	Add to Response-Get: {"id":"data.0.email.text","val":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","value":"Garten-IR-T-Sky \r\n192.178.99.99
                  simple-api.0	2017-11-27 09:04:38.603	debug	Add to Response-Get: {"id":"data.0.email.subject","val":"High humidity warning - Garten-IR-T-Sky","value":"High humidity warning - Garten-IR-T-Sky"}
                  simple-api.0	2017-11-27 09:04:38.581	debug	GET-setBulk for id=data.0.email.text, oid=textused=data.0.email.text, value=Garten-IR-T-Sky 192.178.99.99 High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                  simple-api.0	2017-11-27 09:04:38.579	debug	GET-setBulk for id=data.0.email.subject, oid=subjectused=data.0.email.subject, value=High humidity warning - Garten-IR-T-Sky
                  simple-api.0	2017-11-27 09:04:38.556	debug	Values: {"data.0.email.subject":"High humidity warning - Garten-IR-T-Sky","data.0.email.text":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","p
                  Ich starte jetzt mal den Browser neu und den Adapter neu. Dann sehen wir weiter.
                    Versuch nochmal. DU hast nach dem Update den Adapter nicht neu gestartet … da lief noch die Vorgängerversion :-) (die neue hat das Debug-Logging gar nicht mehr). Aber die läuft jetzt ... so please :-))
                      klassisch
                      Sorry, war auch gerade dabei alles neu zu starten.
                      Bisher sieht es gut aus….
                      simple-api.0 2017-11-27 09:11:58.178 debug Add to Response-Get: {"id":"data.0.email.text","val":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","value":"Garten-IR-T-Sky \r\n192.178.99.9
                      simple-api.0 2017-11-27 09:11:58.172 debug Add to Response-Get: {"id":"data.0.email.subject","val":"High humidity warning - Garten-IR-T-Sky","value":"High humidity warning - Garten-IR-T-Sky"}
                      simple-api.0 2017-11-27 09:11:58.155 debug
                      simple-api.0 2017-11-27 09:11:58.155 debug High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                      simple-api.0 2017-11-27 09:11:58.155 debug 192.178.99.99
                      simple-api.0 2017-11-27 09:11:58.155 debug GET-setBulk for id=data.0.email.text, oid=textused=data.0.email.text, value=Garten-IR-T-Sky
                      simple-api.0 2017-11-27 09:11:58.149 debug GET-setBulk for id=data.0.email.subject, oid=subjectused=data.0.email.subject, value=High humidity warning - Garten-IR-T-Sky
                      simple-api.0 2017-11-27 09:11:58.133 debug Values: {"data.0.email.subject":"High humidity warning - Garten-IR-T-Sky","data.0.email.text":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","
                      simple-api.0 2017-11-27 09:11:45.691 info http server listening on port 8087
                      simple-api.0 2017-11-27 09:11:45.681 info Allow states only when user is owner: false
                      simple-api.0 2017-11-27 09:11:45.679 info simpleAPI server listening on port 8087
                      simple-api.0 2017-11-27 09:11:45.606 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                      simple-api.0 2017-11-27 09:11:44.714 debug statesDB connected
                      simple-api.0 2017-11-27 09:11:44.574 debug objectDB connected
                        klassisch
                        Vielen Dank nochmals! Habe noch etwas gespielt und bisher hat es funktioniert.
                        Bei unerlaubten Symbolen wie dem %B0 statt dem %C2%B0 schmiert der Adapter noch ab.
                        Aber es funktioniert jetzt z.B. ein gueltiges°C Symbol %e2%84%83.
                        Was es alles gibt. So ists, wenn man noch mit ASCII aufgewachsen ist und sich um den neumodischen Designerkram nicht geschert hat…
                          Hast Du da nochnmal debug, dann fange ich den Fehler da auch ab und es wird dann halt einfach nicht decoded
                            klassisch
                            Ja, mit der 1.6.2 kommt natürlich nicht so viel rüber
                            simple-api.0 2017-11-27 09:54:05.382 info http server listening on port 8087
                            simple-api.0 2017-11-27 09:54:05.382 info Allow states only when user is owner: false
                            simple-api.0 2017-11-27 09:54:05.381 info simpleAPI server listening on port 8087
                            simple-api.0 2017-11-27 09:54:05.380 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                            host.orangepiplus2e 2017-11-27 09:54:02.618 info instance system.adapter.simple-api.0 started with pid 5970
                            host.orangepiplus2e 2017-11-27 09:53:32.521 info Restart adapter system.adapter.simple-api.0 because enabled
                            host.orangepiplus2e 2017-11-27 09:53:32.518 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                            simple-api.0 2017-11-27 09:53:32.385 error uncaught exception: URI malformed
                            Und der Browserstring war
                            http://IP:8087/setBulk?data.0.email.text=Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%20%0D%0A%20%B0&prettyPrint
                            Die %B0 war ganz am Ende.
                              Next try please …. sollte jetzt "warn" loggen und im zweifel einfach nicht dekodieren
                                klassisch
                                Super, vielen Dank sieht an meinem Beispiel sehr gut aus:
                                simple-api.0 2017-11-27 10:13:30.482 debug Add to Response-Get: {"id":"data.0.email.text","val":"Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%20%0D%0A%20%B0","v
                                simple-api.0 2017-11-27 10:13:30.454 debug GET-setBulk for id=data.0.email.text, oid=textused=data.0.email.text, value=Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20
                                simple-api.0 2017-11-27 10:13:30.447 debug Values: {"data.0.email.text":"Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%20%0D%0A%20%B0","prettyPrint":true,"user":
                                simple-api.0 2017-11-27 10:13:30.446 warn Malformed URL encoding: URIError: URI malformed
                                simple-api.0 2017-11-27 10:13:30.444 warn Malformed URL encoding: URIError: URI malformed
                                simple-api.0 2017-11-27 10:13:18.274 info http server listening on port 8087
                                simple-api.0 2017-11-27 10:13:18.264 info Allow states only when user is owner: false
                                simple-api.0 2017-11-27 10:13:18.262 info simpleAPI server listening on port 8087
                                simple-api.0 2017-11-27 10:13:18.189 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                                simple-api.0 2017-11-27 10:13:18.103 debug statesDB connected
                                simple-api.0 2017-11-27 10:13:17.218 debug objectDB connected
                                Interessant ist das
                                %0A%20%B0","v
                                Da hat er ein
                                ,"v
                                zugefügt.
                                Browserausgabe
                                "id": "data.0.email.text",
                                "val": "Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%20%0D%0A%20%B0",
                                "value": "Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%20%0D%0A%20%B0"
                                Und die email wird dann komplett "unkodiert":
                                Da sieht man gleich, dass was was faul war. Weiss aber nicht, ob es so gedacht war.
                                  Ist das erinfachste eas geht. Wenn es beim Dekodieren einen Fehler gibt, dann einfach nicht dekodieren.
                                  Man könnte jetzt Libraries suchen die vllt "Fehlertoleranter" dekodieren … da fehlt mir aber gerade die Zeit zu :-)
                                    klassisch
                                    Ja, klar man könnte auch aus dem simpleApi einen fullApi machen … ;)
                                    Herzlichen Dank für Deine Zeit!
                                    Mir reicht der simplaApi (derzeit :-) ). Hauptsache der Adapter schmiert nicht mehr "kommentarlos" ab und bedient die erlaubten Zeichen richtig. Wahrscheinlich nutze ich ihn schon weit über sein urspruengliches "mission profile", knapp am abuse.
                                    Wenn er nicht mehr kodiert, dann weiss ich gleich, dass ich in der schoenen neuen Codewelt wieder was vermasselt habe und kann zielgerichteter suchen.
                                    Einen schoenen und erfolgreichen Tag noch!
