  4. [gelöst] simpleApi kann nicht %B0 aber °
    5.8k
25 Beiträge 2 Kommentatoren 2.8k Aufrufe
    klassisch
    Aber gerne:
    Zuerst ein Beispiel welches funktioniert
    http://IP:8087/set/data.0.email.text?value=Garten-IR-T-Sky%0D%0A192.178.99.99%20%0D%0AFreezepoint:%202017-11-16%20%20%2002:38:41%20Temp:%200.80%20%C2%B0C%20%0D%0AfreezeP:%200.30%20%C2%B0C%20%20%0D%0A%20IR%20Temp:%20-24.51%20%°C%20%20%0D%0A%20&prettyPrint
    Und jetzt eines, welches nicht funktioniert:
    http://IP:8087/set/data.0.email.text?value=Garten-IR-T-Sky%0D%0A192.178.99.99%20%0D%0AFreezepoint:%202017-11-16%20%20%2002:38:41%20Temp:%200.80%20%C2%B0C%20%0D%0AfreezeP:%200.30%20%C2%B0C%20%20%0D%0A%20IR%20Temp:%20-24.51%20%B0C%20%20%0D%0A%20&prettyPrint
    host.orangepiplus2e	2017-11-16 19:17:22.406	warn	instance system.adapter.simple-api.0 already running with pid 4515
    simple-api.0	2017-11-16 19:17:10.977	info	http server listening on port 8087
    simple-api.0	2017-11-16 19:17:10.966	info	Allow states only when user is owner: false
    simple-api.0	2017-11-16 19:17:10.963	info	simpleAPI server listening on port 8087
    simple-api.0	2017-11-16 19:17:10.872	info	starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
    host.orangepiplus2e	2017-11-16 19:17:08.470	info	instance system.adapter.simple-api.0 started with pid 4515
    host.orangepiplus2e	2017-11-16 19:17:08.387	info	object change system.adapter.simple-api.0
    host.orangepiplus2e	2017-11-16 19:16:52.396	info	Restart adapter system.adapter.simple-api.0 because enabled
    host.orangepiplus2e	2017-11-16 19:16:52.393	error	instance system.adapter.simple-api.0 terminated with code 0 (OK)
    simple-api.0	2017-11-16 19:16:52.332	info	terminating
    simple-api.0	2017-11-16 19:16:52.313	info	terminating http server on port 8087
    simple-api.0	2017-11-16 19:16:52.307	error	at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
    simple-api.0	2017-11-16 19:16:52.307	error	at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
    simple-api.0	2017-11-16 19:16:52.307	error	at Server.emit (events.js:172:7)
    simple-api.0	2017-11-16 19:16:52.307	error	at emitTwo (events.js:87:13)
    simple-api.0	2017-11-16 19:16:52.307	error	at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
    simple-api.0	2017-11-16 19:16:52.307	error	at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:379:19)
    simple-api.0	2017-11-16 19:16:52.307	error	at decodeURI (native)
    simple-api.0	2017-11-16 19:16:52.307	error	URIError: URI malformed
    simple-api.0	2017-11-16 19:16:52.280	error	uncaught exception: URI malformed
    simple-api.0	2017-11-16 19:16:43.979	debug	Add to Response-Get: {"id":"data.0.dehumid01.state","val":1,"value":1}
    simple-api.0	2017-11-16 19:16:43.974	debug	Add to Response-Get: {"id":"data.0.dehumid01.p-red","val":1026.15,"value":1026.15}
    simple-api.0	2017-11-16 19:16:43.968	debug	Add to Response-Get: {"id":"data.0.dehumid01.DewT","val":15.13,"value":15.13}
    simple-api.0	2017-11-16 19:16:43.964	debug	Add to Response-Get: {"id":"data.0.dehumid01.H-abs","val":12.49,"value":12.49}
    simple-api.0	2017-11-16 19:16:43.947	debug	Add to Response-Get: {"id":"data.0.dehumid01.H-rel","val":53.28,"value":53.28}
    simple-api.0	2017-11-16 19:16:43.943	debug	Add to Response-Get: {"id":"data.0.dehumid01.Temp","val":25.32,"value":25.32}
    simple-api.0	2017-11-16 19:16:43.916	debug	GET-setBulk for id=data.0.dehumid01.state, oid=stateused=data.0.dehumid01.state, value=1
    simple-api.0	2017-11-16 19:16:43.912	debug	GET-setBulk for id=data.0.dehumid01.p-red, oid=p-redused=data.0.dehumid01.p-red, value=1026.15
    simple-api.0	2017-11-16 19:16:43.909	debug	GET-setBulk for id=data.0.dehumid01.DewT, oid=DewTused=data.0.dehumid01.DewT, value=15.13
    simple-api.0	2017-11-16 19:16:43.904	debug	GET-setBulk for id=data.0.dehumid01.H-abs, oid=H-absused=data.0.dehumid01.H-abs, value=12.49
    simple-api.0	2017-11-16 19:16:43.897	debug	GET-setBulk for id=data.0.dehumid01.H-rel, oid=H-relused=data.0.dehumid01.H-rel, value=53.28
    simple-api.0	2017-11-16 19:16:43.879	debug	GET-setBulk for id=data.0.dehumid01.Temp, oid=Tempused=data.0.dehumid01.Temp, value=25.32
    simple-api.0	2017-11-16 19:16:43.823	debug	Values: {"data.0.dehumid01.Temp":"25.32","data.0.dehumid01.H-rel":"53.28","data.0.dehumid01.H-abs":"12.49","data.0.dehumid01.DewT":"15.13","data.0.dehumid01.p-red":"1026.15","data.0.dehumid01.state":
    • apollon77A Offline
      Dein %B0 ist faktisch falsch, weil das Standard-encoding was angenommen ist UTF-8 ist. Da dein zeichen in dem bereich von UTF-8 liegt wo zwei Byte zur kodierung genutzt werden generierst Du einen Fehler.
      Das Gradzeichen ist UTF-8 kodiert nämlich %C2%B0
      Versuch das mal
        klassisch
        Vielen Dank,
        also misuse. Vom Browser aus funktioniert es so und auch die ESPs können ihre Mails jetzt absetzen.
        Allerdings kommt in der email jetzt vor das ° noch ein A mit accent grave. Aber mit solchen Schönheitsfehlern kann ich leben. Sind der babylonischen Codeverwirrung geschuldet.
          Musst jetzt kn der E-Mail das encoding korrekt setzen dann sollte das weg sein
            klassisch
            @apollon77:
            Musst jetzt kn der E-Mail das encoding korrekt setzen dann sollte das weg sein `
            Ich habe weder in meiner gmx-app noch in Thunderbird eine Einstellmöglichkeit gefunden.
            Was aber funktioniert: Im Script, welches den via simpleApi übertragenen String in den email-Adapter einspeist, habe ich mit
            var text = getState("data.0.email.text"/*text*/).val + 'Content-Type:text/plain; charset="UTF-8"';
            den Befehl
            angehängt. Dann kommt die Mail sowohl in thunderbird als auch in der gmx-mail app korrekt an.
            Hänge ich den Befehlsstring bereits beim Sender (z.B. Browserzeile) an, dann wird an die email
            angehängt und auch im email-Programm angezeigt. Das````
            ="UTF-8"
            "id": "data.0.email.text",
            "value": "\r\nGarten-IR-T-Sky\r\n192.178.99.99 \r\nFreezepoint: 2017-11-16 02:38:41 Temp: 0.80 °C \r\nfreezeP: 0.30 °C \r\n IR Temp: -24.51 °C \r\nContent-Type:text/plain; charset",
            "val": "\r\nGarten-IR-T-Sky\r\n192.178.99.99 \r\nFreezepoint: 2017-11-16 02:38:41 Temp: 0.80 °C \r\nfreezeP: 0.30 °C \r\n IR Temp: -24.51 °C \r\nContent-Type:text/plain; charset"
            Wahrscheinlich wird das = als delimiter für einen neuen Wert interpretiert. Wird wohl einige Zeichen wie = oder ? oder & geben, die in den Emailtexten nicht auftreten dürfen.
            Wie auch immer, wenn ich die utf-8 Umschaltung per script im ioBroker anhefte funktioniert es und macht auch noch den zu übertragenden String kleiner.
            Einziger Nachteil, der für mich als pain text email fan derzeit nicht wirklich wichtig ist: Ich muss mich jetzt an utf-8 und plain text halten. Wenn ich eine html-Mail übertragen wollte, könnte es Schwierigkeiten geben. Da müßte ich in das Transfer-Skript eine Art html-Erkennung einbauen.
            Also für mich gelöst und vielen Dank nochmals!
              klassisch
              Muß jetzt doch nochmals nachfragen.
              Bei der stufenweise Umstellung von email via CCU auf email via ioBroker ist mit aufgefallen, daß % Zeichen den gleichen Effekt haben. simpleApi wird neu gestartet
              Beispiel:
              http://IP:8087/setBulk?data.0.email.to=email@email.de&data.0.email.subject=High%20humidity%20warning%20-%20Garten-IR-T-Sky&data.0.email.text=Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%0D%0A%20&prettyPrint
              [http://IP:8087/setBulk?data.0.email.to= … %2088.39b]%25%20%20%0D%0A%20&prettyPrint
              Habe das %-Zeichen als %25 kodiert. Scheint aber nicht zu gehen. Auch ein einfaches % Zeichen ohne daraufolgende Kodierung scheint nicht zu gehen.
              Blicke bei deiesen verschiedenen Kodierungen und deren Ausprägungen bzw. Verwendungen (%0A vs \x0A vs U+000A) nicht wirklich durch.
                Welche exakte Fehlermeldung kommt denn im Log?
                  klassisch
                  Habe das Log mal auf "silly" gestellt:
                  simple-api.0 2017-11-26 18:05:45.179 debug Add to Response-Get: {"id":"data.0.heating.Keller.p-red","val":1027.83,"value":1027.83}
                  simple-api.0 2017-11-26 18:05:45.178 debug Add to Response-Get: {"id":"data.0.heating.Keller.Dew-T","val":5.27,"value":5.27}
                  simple-api.0 2017-11-26 18:05:45.176 debug Add to Response-Get: {"id":"data.0.heating.Keller.H-abs","val":6.67,"value":6.67}
                  simple-api.0 2017-11-26 18:05:45.135 debug Add to Response-Get: {"id":"data.0.heating.Keller.H-rel","val":50.59,"value":50.59}
                  simple-api.0 2017-11-26 18:05:45.120 debug Add to Response-Get: {"id":"data.0.heating.Keller.Temp","val":15.47,"value":15.47}
                  simple-api.0 2017-11-26 18:05:45.107 debug GET-setBulk for id=data.0.heating.Keller.p-red, oid=p-redused=data.0.heating.Keller.p-red, value=1027.83
                  simple-api.0 2017-11-26 18:05:45.106 debug GET-setBulk for id=data.0.heating.Keller.Dew-T, oid=Dew-Tused=data.0.heating.Keller.Dew-T, value=5.27
                  simple-api.0 2017-11-26 18:05:45.106 debug GET-setBulk for id=data.0.heating.Kelle.H-abs, oid=H-absused=data.0.heating.Keller.H-abs, value=6.67
                  simple-api.0 2017-11-26 18:05:45.105 debug GET-setBulk for id=data.0.heating.Keller.H-rel, oid=H-relused=data.0.heating.Keller.H-rel, value=50.59
                  simple-api.0 2017-11-26 18:05:45.105 debug GET-setBulk for id=data.0.heating.Keller.Temp, oid=Tempused=data.0.heating.Keller.Temp, value=15.47
                  simple-api.0 2017-11-26 18:05:45.071 debug Values: {"data.0.heating.Keller.Temp":"15.47","data.0.heating.Keller.H-rel":"50.59","data.0.heating.Keller.H-abs":"6.67","data.0.heating.Keller.Dew-T":"5.27","data.0.heating.Keller
                  simple-api.0 2017-11-26 18:05:35.749 info http server listening on port 8087
                  simple-api.0 2017-11-26 18:05:35.748 info Allow states only when user is owner: false
                  simple-api.0 2017-11-26 18:05:35.747 info simpleAPI server listening on port 8087
                  simple-api.0 2017-11-26 18:05:35.746 info starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                  host.orangepiplus2e 2017-11-26 18:05:33.132 info instance system.adapter.simple-api.0 started with pid 3841
                  nut.0 2017-11-26 18:05:24.976 info All Nut values set
                  nut.0 2017-11-26 18:05:24.803 info Start NUT update
                  host.orangepiplus2e 2017-11-26 18:05:03.058 info Restart adapter system.adapter.simple-api.0 because enabled
                  host.orangepiplus2e 2017-11-26 18:05:03.057 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                  simple-api.0 2017-11-26 18:04:25.715 debug Add to Response-Get: {"id":"data.0.dehumid01.distWaterTank","val":53.33,"value":53.33}
                  simple-api.0 2017-11-26 18:04:25.715 debug Add to Response-Get: {"id":"data.0.dehumid01.state","val":1,"value":1}
                  simple-api.0 2017-11-26 18:04:25.714 debug Add to Response-Get: {"id":"data.0.dehumid01.p-red","val":1027.31,"value":1027.31}
                  simple-api.0 2017-11-26 18:04:25.714 debug Add to Response-Get: {"id":"data.0.dehumid01.DewT","val":14.32,"value":14.32}
                  simple-api.0 2017-11-26 18:04:25.713 debug Add to Response-Get: {"id":"data.0.dehumid01.H-abs","val":11.88,"value":11.88}
                  simple-api.0 2017-11-26 18:04:25.674 debug Add to Response-Get: {"id":"data.0.dehumid01.H-rel","val":52.42,"value":52.42}
                  simple-api.0 2017-11-26 18:04:25.673 debug Add to Response-Get: {"id":"data.0.dehumid01.Temp","val":24.72,"value":24.72}
                  simple-api.0 2017-11-26 18:04:25.645 debug GET-setBulk for id=data.0.dehumid01.distWaterTank, oid=distWaterTankused=data.0.dehumid01.distWaterTank, value=53.33
                  simple-api.0 2017-11-26 18:04:25.644 debug GET-setBulk for id=data.0.dehumid01.state, oid=stateused=data.0.dehumid01.state, value=1
                  simple-api.0 2017-11-26 18:04:25.643 debug GET-setBulk for id=data.0.dehumid01.p-red, oid=p-redused=data.0.dehumid01.p-red, value=1027.31
                  simple-api.0 2017-11-26 18:04:25.643 debug GET-setBulk for id=data.0.dehumid01.DewT, oid=DewTused=data.0.dehumid01.DewT, value=14.32
                  In ursächlichem Zusammenhang mit der %25 sehe ich
                  Mit dem Log auf "debug"
                  host.orangepiplus2e	2017-11-26 18:11:26.104	info	Restart adapter system.adapter.simple-api.0 because enabled
                  host.orangepiplus2e	2017-11-26 18:11:26.102	error	instance system.adapter.simple-api.0 terminated with code 0 (OK)
                  simple-api.0	2017-11-26 18:11:26.050	info	terminating
                  simple-api.0	2017-11-26 18:11:26.031	info	terminating http server on port 8087
                  simple-api.0	2017-11-26 18:11:26.027	error	at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                  simple-api.0	2017-11-26 18:11:26.027	error	at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
                  simple-api.0	2017-11-26 18:11:26.027	error	at Server.emit (events.js:172:7)
                  simple-api.0	2017-11-26 18:11:26.027	error	at emitTwo (events.js:87:13)
                  simple-api.0	2017-11-26 18:11:26.027	error	at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
                  simple-api.0	2017-11-26 18:11:26.027	error	at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:387:79)
                  simple-api.0	2017-11-26 18:11:26.027	error	at decodeURIComponent (native)
                  simple-api.0	2017-11-26 18:11:26.027	error	URIError: URI malformed
                  simple-api.0	2017-11-26 18:11:26.013	error	uncaught exception: URI malformed
                    Bitte installiere mal die Version vom GitHub (1.6.1) und schick dann nochmal die debug-Ausgabe bitte
                      klassisch
                      Vielen Dank für Deine Mühen!
                      simple-api.0 2017-11-26 22:02:39.636 info http server listening on port 8087
                      simple-api.0 2017-11-26 22:02:39.636 info Allow states only when user is owner: false
                      simple-api.0 2017-11-26 22:02:39.635 info simpleAPI server listening on port 8087
                      simple-api.0 2017-11-26 22:02:39.635 info starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                      host.orangepiplus2e 2017-11-26 22:02:37.014 info instance system.adapter.simple-api.0 started with pid 4545
                      host.orangepiplus2e 2017-11-26 22:02:06.932 info Restart adapter system.adapter.simple-api.0 because enabled
                      host.orangepiplus2e 2017-11-26 22:02:06.930 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                      simple-api.0 2017-11-26 22:02:06.847 info terminating http server on port 8087
                      simple-api.0 2017-11-26 22:02:06.843 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                      simple-api.0 2017-11-26 22:02:06.843 error at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
                      simple-api.0 2017-11-26 22:02:06.843 error at Server.emit (events.js:172:7)
                      simple-api.0 2017-11-26 22:02:06.843 error at emitTwo (events.js:87:13)
                      simple-api.0 2017-11-26 22:02:06.843 error at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
                      simple-api.0 2017-11-26 22:02:06.843 error at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:405:79)
                      simple-api.0 2017-11-26 22:02:06.843 error at decodeURIComponent (native)
                      simple-api.0 2017-11-26 22:02:06.843 error URIError: URI malformed
                      simple-api.0 2017-11-26 22:02:06.829 error uncaught exception: URI malformed
                      simple-api.0 2017-11-26 22:01:05.209 info http server listening on port 8087
                      simple-api.0 2017-11-26 22:01:05.199 info Allow states only when user is owner: false
                      simple-api.0 2017-11-26 22:01:05.197 info simpleAPI server listening on port 8087
                      simple-api.0 2017-11-26 22:01:05.113 info starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                      simple-api.0 2017-11-26 22:01:04.978 debug statesDB connected
                      simple-api.0 2017-11-26 22:01:04.837 debug objectDB connected
                      host.orangepiplus2e 2017-11-26 22:01:01.702 info instance system.adapter.simple-api.0 started with pid 4535
                      host.orangepiplus2e 2017-11-26 22:00:59.227 info instance system.adapter.simple-api.0 terminated with code 0 (OK)
                      Man sieht noch die Instalation der 1.6.1.
                      Ansonsten sehe ich nicht viel Neues. Als Laie würde ich sagen, das kommt tief aus einer JS engine…
                        Ok, installiere bitte mal von Github. Versionsnummer ist die gleiche ich habe beim Dekodieren aber Debug Logging eingebaut. Also bitte nochmal in Debug laufen lassen und dann hier posten was Log sagt.
                          klassisch
                          Guten Morgen,
                          vielen Dank, hier mit der neuesten Version….
                          simple-api.0 2017-11-27 06:29:15.330 info http server listening on port 8087
                          simple-api.0 2017-11-27 06:29:15.329 info Allow states only when user is owner: false
                          simple-api.0 2017-11-27 06:29:15.328 info simpleAPI server listening on port 8087
                          simple-api.0 2017-11-27 06:29:15.328 info starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                          host.orangepiplus2e 2017-11-27 06:29:12.655 info instance system.adapter.simple-api.0 started with pid 5415
                          host.orangepiplus2e 2017-11-27 06:28:42.568 info Restart adapter system.adapter.simple-api.0 because enabled
                          host.orangepiplus2e 2017-11-27 06:28:42.566 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                          simple-api.0 2017-11-27 06:28:42.506 info terminating
                          simple-api.0 2017-11-27 06:28:42.487 info terminating http server on port 8087
                          simple-api.0 2017-11-27 06:28:42.483 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                          simple-api.0 2017-11-27 06:28:42.483 error at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
                          simple-api.0 2017-11-27 06:28:42.483 error at Server.emit (events.js:172:7)
                          simple-api.0 2017-11-27 06:28:42.483 error at emitTwo (events.js:87:13)
                          simple-api.0 2017-11-27 06:28:42.483 error at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
                          simple-api.0 2017-11-27 06:28:42.483 error at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:406:79)
                          simple-api.0 2017-11-27 06:28:42.483 error at decodeURIComponent (native)
                          simple-api.0 2017-11-27 06:28:42.483 error URIError: URI malformed
                          simple-api.0 2017-11-27 06:28:42.469 error uncaught exception: URI malformed
                          simple-api.0 2017-11-27 06:28:42.447 debug
                          simple-api.0 2017-11-27 06:28:42.447 debug High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                          simple-api.0 2017-11-27 06:28:42.447 debug 192.178.99.99
                          simple-api.0 2017-11-27 06:28:42.447 debug Try Decode 2: Garten-IR-T-Sky
                          simple-api.0 2017-11-27 06:28:42.445 debug Decode Result 1: High humidity warning - Garten-IR-T-Sky
                          simple-api.0 2017-11-27 06:28:42.444 debug Try Decode 1: High humidity warning - Garten-IR-T-Sky
                          simple-api.0 2017-11-27 06:28:42.443 debug Decode Result 0: email@gmx.de
                          simple-api.0 2017-11-27 06:28:42.440 debug email@gmx.de
                          host.orangepiplus2e 2017-11-27 06:28:13.850 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                          iobroker 2017-11-27 06:28:13.057 info exit 0
                          iobroker 2017-11-27 06:28:12.922 info upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                          iobroker 2017-11-27 06:28:12.796 info upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                          iobroker 2017-11-27 06:28:12.767 info got /opt/iobroker/node_modules/iobroker.simple-api/admin
                          iobroker 2017-11-27 06:28:12.606 info iobroker.simple-api@1.6.1 opt/iobroker/node_modules/iobroker.simple-api
                          iobroker 2017-11-27 06:27:22.524 info npm install https://github.com/ioBroker/ioBroker.simple-api/tarball/master --production --prefix "/opt/iobroker" (System call)
                          iobroker 2017-11-27 06:27:21.988 info install https://github.com/ioBroker/ioBroker.simple-api/tarball/master
                          iobroker 2017-11-27 06:27:19.750 info url "https://github.com/ioBroker/ioBroker.simple-api/tarball/master" simple-api --debug
                            Bitte 1.6.2 vom Github versuchen, sollte das Problem fixen
                              klassisch
                              Vielen Dank, but not really_
                              simple-api.0 2017-11-27 08:55:05.035 info http server listening on port 8087
                              simple-api.0 2017-11-27 08:55:05.035 info Allow states only when user is owner: false
                              simple-api.0 2017-11-27 08:55:05.034 info simpleAPI server listening on port 8087
                              simple-api.0 2017-11-27 08:55:05.034 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                              host.orangepiplus2e 2017-11-27 08:55:02.445 info instance system.adapter.simple-api.0 started with pid 5837
                              host.orangepiplus2e 2017-11-27 08:54:32.359 info Restart adapter system.adapter.simple-api.0 because enabled
                              host.orangepiplus2e 2017-11-27 08:54:32.356 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                              simple-api.0 2017-11-27 08:54:32.283 info terminating
                              simple-api.0 2017-11-27 08:54:32.224 info terminating http server on port 8087
                              simple-api.0 2017-11-27 08:54:32.218 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
                              simple-api.0 2017-11-27 08:54:32.218 error at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:539:12)
                              simple-api.0 2017-11-27 08:54:32.218 error at Server.emit (events.js:172:7)
                              simple-api.0 2017-11-27 08:54:32.218 error at emitTwo (events.js:87:13)
                              simple-api.0 2017-11-27 08:54:32.218 error at Server.requestProcessor (/opt/iobroker/node_modules/iobroker.simple-api/main.js:81:23)
                              simple-api.0 2017-11-27 08:54:32.218 error at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:406:79)
                              simple-api.0 2017-11-27 08:54:32.218 error at decodeURIComponent (native)
                              simple-api.0 2017-11-27 08:54:32.218 error URIError: URI malformed
                              simple-api.0 2017-11-27 08:54:32.197 error uncaught exception: URI malformed
                              simple-api.0 2017-11-27 08:54:32.146 debug
                              simple-api.0 2017-11-27 08:54:32.146 debug High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                              simple-api.0 2017-11-27 08:54:32.146 debug 192.178.99.99
                              simple-api.0 2017-11-27 08:54:32.146 debug Try Decode 2: Garten-IR-T-Sky
                              simple-api.0 2017-11-27 08:54:32.144 debug Decode Result 1: High humidity warning - Garten-IR-T-Sky
                              simple-api.0 2017-11-27 08:54:32.143 debug Try Decode 1: High humidity warning - Garten-IR-T-Sky
                              simple-api.0 2017-11-27 08:54:32.141 debug Decode Result 0: email@email.de
                              simple-api.0 2017-11-27 08:54:32.138 debug Try Decode 0: email@email.de
                              host.orangepiplus2e 2017-11-27 08:54:10.954 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                              iobroker 2017-11-27 08:54:10.244 info exit 0
                              iobroker 2017-11-27 08:54:10.108 info upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                              iobroker 2017-11-27 08:54:09.967 info upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                              iobroker 2017-11-27 08:54:09.939 info got /opt/iobroker/node_modules/iobroker.simple-api/admin
                              iobroker 2017-11-27 08:54:09.781 info iobroker.simple-api@1.6.2 opt/iobroker/node_modules/iobroker.simple-api
                              Warte noch einen Moment. Eben hat es mit einem Teilstring geklappt. Das % kam durch, lass mich noch etwas schauen…
                              Sehr seltsam. Jetzt hat die Übetrtragung ein paarmal geklappt, dann das
                              simple-api.0	2017-11-27 09:06:13.075	info	http server listening on port 8087
                              simple-api.0	2017-11-27 09:06:13.075	info	Allow states only when user is owner: false
                              simple-api.0	2017-11-27 09:06:13.074	info	simpleAPI server listening on port 8087
                              simple-api.0	2017-11-27 09:06:13.074	info	starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                              host.orangepiplus2e	2017-11-27 09:06:10.503	info	instance system.adapter.simple-api.0 started with pid 5860
                              host.orangepiplus2e	2017-11-27 09:05:40.430	info	Restart adapter system.adapter.simple-api.0 because enabled
                              host.orangepiplus2e	2017-11-27 09:05:40.428	error	instance system.adapter.simple-api.0 terminated with code 0 (OK)
                              simple-api.0	2017-11-27 09:05:40.356	info	terminating http server on port 8087
                              simple-api.0	2017-11-27 09:05:40.355	error	URIError: URI malformed at decodeURI (native) at SimpleAPI.restApi (/opt/iobroker/node_modules/iobroker.simple-api/lib/simpleapi.js:397:19) at Server.requestProcessor (/opt/iobroker/node_m
                              simple-api.0	2017-11-27 09:05:40.353	error	uncaught exception: URI malformed
                              nut.0	2017-11-27 09:05:26.876	info	All Nut values set
                              nut.0	2017-11-27 09:05:26.778	info	Start NUT update
                              email.0	2017-11-27 09:04:39.738	info	sent to email@email.de
                              email.0	2017-11-27 09:04:38.671	info	Send email: {"from":"email.email@gmail.com","to":"email@email.de","subject":"High humidity warning - Garten-IR-T-Sky","text":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-2
                              simple-api.0	2017-11-27 09:04:38.622	debug	Add to Response-Get: {"id":"data.0.email.text","val":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","value":"Garten-IR-T-Sky \r\n192.178.99.99
                              simple-api.0	2017-11-27 09:04:38.603	debug	Add to Response-Get: {"id":"data.0.email.subject","val":"High humidity warning - Garten-IR-T-Sky","value":"High humidity warning - Garten-IR-T-Sky"}
                              simple-api.0	2017-11-27 09:04:38.581	debug	GET-setBulk for id=data.0.email.text, oid=textused=data.0.email.text, value=Garten-IR-T-Sky 192.178.99.99 High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                              simple-api.0	2017-11-27 09:04:38.579	debug	GET-setBulk for id=data.0.email.subject, oid=subjectused=data.0.email.subject, value=High humidity warning - Garten-IR-T-Sky
                              simple-api.0	2017-11-27 09:04:38.556	debug	Values: {"data.0.email.subject":"High humidity warning - Garten-IR-T-Sky","data.0.email.text":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","p
                              Ich starte jetzt mal den Browser neu und den Adapter neu. Dann sehen wir weiter.
                                Versuch nochmal. DU hast nach dem Update den Adapter nicht neu gestartet … da lief noch die Vorgängerversion :-) (die neue hat das Debug-Logging gar nicht mehr). Aber die läuft jetzt ... so please :-))
                                  klassisch
                                  Sorry, war auch gerade dabei alles neu zu starten.
                                  Bisher sieht es gut aus….
                                  simple-api.0 2017-11-27 09:11:58.178 debug Add to Response-Get: {"id":"data.0.email.text","val":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","value":"Garten-IR-T-Sky \r\n192.178.99.9
                                  simple-api.0 2017-11-27 09:11:58.172 debug Add to Response-Get: {"id":"data.0.email.subject","val":"High humidity warning - Garten-IR-T-Sky","value":"High humidity warning - Garten-IR-T-Sky"}
                                  simple-api.0 2017-11-27 09:11:58.155 debug
                                  simple-api.0 2017-11-27 09:11:58.155 debug High Humidity: 2017-11-26 09:57:19 rel Humid: 88.39%
                                  simple-api.0 2017-11-27 09:11:58.155 debug 192.178.99.99
                                  simple-api.0 2017-11-27 09:11:58.155 debug GET-setBulk for id=data.0.email.text, oid=textused=data.0.email.text, value=Garten-IR-T-Sky
                                  simple-api.0 2017-11-27 09:11:58.149 debug GET-setBulk for id=data.0.email.subject, oid=subjectused=data.0.email.subject, value=High humidity warning - Garten-IR-T-Sky
                                  simple-api.0 2017-11-27 09:11:58.133 debug Values: {"data.0.email.subject":"High humidity warning - Garten-IR-T-Sky","data.0.email.text":"Garten-IR-T-Sky \r\n192.178.99.99 \r\nHigh Humidity: 2017-11-26 09:57:19 rel Humid: 88.39% \r\n ","
                                  simple-api.0 2017-11-27 09:11:45.691 info http server listening on port 8087
                                  simple-api.0 2017-11-27 09:11:45.681 info Allow states only when user is owner: false
                                  simple-api.0 2017-11-27 09:11:45.679 info simpleAPI server listening on port 8087
                                  simple-api.0 2017-11-27 09:11:45.606 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                                  simple-api.0 2017-11-27 09:11:44.714 debug statesDB connected
                                  simple-api.0 2017-11-27 09:11:44.574 debug objectDB connected
                                    klassisch
                                    Vielen Dank nochmals! Habe noch etwas gespielt und bisher hat es funktioniert.
                                    Bei unerlaubten Symbolen wie dem %B0 statt dem %C2%B0 schmiert der Adapter noch ab.
                                    Aber es funktioniert jetzt z.B. ein gueltiges°C Symbol %e2%84%83.
                                    Was es alles gibt. So ists, wenn man noch mit ASCII aufgewachsen ist und sich um den neumodischen Designerkram nicht geschert hat…
                                      Hast Du da nochnmal debug, dann fange ich den Fehler da auch ab und es wird dann halt einfach nicht decoded
                                        klassisch
                                        Ja, mit der 1.6.2 kommt natürlich nicht so viel rüber
                                        simple-api.0 2017-11-27 09:54:05.382 info http server listening on port 8087
                                        simple-api.0 2017-11-27 09:54:05.382 info Allow states only when user is owner: false
                                        simple-api.0 2017-11-27 09:54:05.381 info simpleAPI server listening on port 8087
                                        simple-api.0 2017-11-27 09:54:05.380 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v4.8.5
                                        host.orangepiplus2e 2017-11-27 09:54:02.618 info instance system.adapter.simple-api.0 started with pid 5970
                                        host.orangepiplus2e 2017-11-27 09:53:32.521 info Restart adapter system.adapter.simple-api.0 because enabled
                                        host.orangepiplus2e 2017-11-27 09:53:32.518 error instance system.adapter.simple-api.0 terminated with code 0 (OK)
                                        simple-api.0 2017-11-27 09:53:32.385 error uncaught exception: URI malformed
                                        Und der Browserstring war
                                        http://IP:8087/setBulk?data.0.email.text=Garten-IR-T-Sky%20%20%0D%0A192.178.99.99%20%0D%0AHigh%20Humidity:%202017-11-26%20%20%2009:57:19%20rel%20Humid:%2088.39%25%20%20%20%0D%0A%20%B0&prettyPrint
                                        Die %B0 war ganz am Ende.
                                          Next try please …. sollte jetzt "warn" loggen und im zweifel einfach nicht dekodieren
