  4. Interaktion aus HTML Tabelle möglich?
    6.1k
25 Beiträge 6 Kommentatoren 3.1k Aufrufe 5 Beobachtet
  • jogibear9988J jogibear9988
    @wolfgangfb
    Ja denke der geht nicht. Firefox 95 ist mit Sicherheit zu alt.
    jogibear9988J Offline
    jogibear9988
    Zur not könnte man den vlt. durch polyfills supporten, aber eig. hab ich das nicht vor. Warum nutzt du so eine alte version?
    Check my ioBroker webui - a vis alternative
    see: https://github.com/iobroker-community-adapters/ioBroker.webui
    W 1 Antwort Letzte Antwort
    • W WolfgangFB
      @jogibear9988
      Browser ist Firefox (95.0.2)
      Fehler ist:
      Source-Map-Fehler: Error: request failed with status 404
      Ressourcen-Adresse: http://192.168.1.205:8082/webui/node_modules/dock-spawn-ts/lib/js/ResizableContainer.js
      Source-Map-Adresse: http://192.168.1.205:8082/webui/node_modules/dock-spawn-ts/lib/js/ResizableContainer.js.map
      no screens loaded Not exists IobrokerHandler.js:135:21
      Uncaught (in promise) ReferenceError: CSSContainerRule is not defined
          traverseAndCollectRules http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:102
          buildPatchedStyleSheet http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:95
          applyAllStyles http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerCanvas.js:346
          initialize http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerCanvas.js:581
          emit http://192.168.1.205:8082/webui/node_modules/@node-projects/base-custom-webcomponent/dist/TypedEvent.js:35
          internalSetStylesheets http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:52
          setStylesheets http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:14
          set additionalStylesheets http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/documentContainer.js:26
          initialize http://192.168.1.205:8082/webui/dist/frontend/config/IobrokerWebuiScreenEditor.js:32
          openScreenEditor http://192.168.1.205:8082/webui/dist/frontend/config/IobrokerWebuiAppShell.js:246
          handleCommandButtonClick http://192.168.1.205:8082/webui/dist/frontend/config/CommandHandling.js:52
          onclick http://192.168.1.205:8082/webui/dist/frontend/config/CommandHandling.js:81
      5ea4acc9-b0a2-4bd7-9aa6-be960159ab16:102:18
          set additionalStyles http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerCanvas.js:334
          set additionalStyles http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerView.js:292
          set additionalStyleString http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/documentContainer.js:15
          initialize http://192.168.1.205:8082/webui/dist/frontend/config/IobrokerWebuiScreenEditor.js:61
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @wolfgangfb sagte in Interaktion aus HTML Tabelle möglich?:
      CSSContainerRule
      ja, geht erst ab V110
      https://developer.mozilla.org/en-US/docs/Web/API/CSSContainerRule#browser_compatibility
      V95 ist jetzt exakt 2 Jahre alt.
      https://www.mozilla.org/en-US/firefox/95.0/releasenotes/
      gut v110 ist vom Februar 2023, damit ist das schon ein zeimliches bleeding edge feature. ab gut, browser sollte man schon regelmäßig updaten.
      allerdings gibt es altgeräte, die diese Aktualisierungen nicht mehr erhalten und dann werden diese geräte das nie können.
      hier im iobroker gern genutzt ältere tablets als bedienkonsole einzusetzen.
      @jogibear9988 setzt du babel bei der übersetzung ein? babel kann auf basis einer browserlist definition dir automatisch die features mit entsprechenden polifills ersetzen. d.h. bei der entwicklung kannst du immer die neuesten sachen verwenden, babel weiß dann welche browser was können und über die definition wählt es dann die richtige zusammensetzung.
      https://babeljs.io/docs/babel-preset-env
      Meine Adapter und Widgets
      Links im Profil
      jogibear9988J 1 Antwort Letzte Antwort
      • OliverIOO OliverIO
        CSSContainerRule
        jogibear9988
        @oliverio
        Ja, gibt glaube polyfills dafür (Falls dies aus irgendeinem Grund wirklich nötig wäre).
        Ich hatte mit meinem Designer auf alle möglichen neuen Technologien gesetzt, im Moment habe ich noch ein Polyfill für importmaps drin, das will ich aber auch noch raus schmeißen.
        Für die Runtime könnte man ja überlegen das man div. dinge Polyfillt, aber für den Designer würde ich das nicht tun
          @oliverio
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @jogibear9988
          ist ja gut auf neue Technik zu setzen, aber du hängst ein teil der Nutzer damit ab.
          Die meisten kaufen sich für iobroker nicht die superaktuellste hardware, sondern nutzen eher ungenutzte veraltete hardware, die gerade noch so geht.
          was denkst du was ich in meinen widgets mit es6 Schwierigkeiten hatte und das auch zurückgefahren habe (gut war jetzt nicht so aufwändig), aber es6 ist ja noch viel älter
          aber genau dafür gibt es babel, damit du dir darüber keine gedanken machen musst und im produzierten endergebnis genau die quellen enthalten sind, die die größtmöglichste abdeckung an geräten/browsern/etc. abdeckt.
          als ich spreche hier nur vom client-anteil der auf dem browser läuft.
          für den server-anteil gibt es ja eine baseline, was iobroker als empfohlene node version einsetzt.
          Links im Profil
            @jogibear9988
            jogibear9988
            @oliverio
            Ja mag sein. Bei mir ist das aber auch konzeptbedingt, wie ich z.b. nodemodule als esm code nachlade.
            Gefühlt kann man ja sonst nie auf neue browser features setzen. Im moment braucht webui auf jeden fall einen relativ aktuellen browser
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @jogibear9988
              ne,
              ich glaub dann hast das prinzip noch nicht ganz verstanden
              Links im Profil
                @jogibear9988
                ne,
                jogibear9988
                schrieb am zuletzt editiert von jogibear9988
                @oliverio
                ?? von was meinst du hab ich das prinzip nicht verstanden?
                von npm paketen? ich meine damit das du bei meiner webui zur "laufzeit" npm pakete hinzufügen kannst, welche als ESM module geladen werden. Und ich liefere ja babel nicht mit meiner webui aus.
                Will aber im moment auch wenn es nicht so wäre nicht mit babel auf eine alte es version übersetzen. Wie gesagt, ich nutze viele neue features, dann bräuchte ich auch polyfills dafür (constructible stylesheets, shadodom, customelements, ...) und wüsste bei problemen erst mal nicht, liegts an mir oder kann etwas z.b. nicht zu 100% polyfillt werden.
                  @oliverio
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @jogibear9988
                  alles gut
                  Links im Profil
                    @jogibear9988
                    alles gut
                    jogibear9988
                    @oliverio
                    habe nur nicht verstanden was du meintest das ich nicht verstanden habe ;-)
                      W Offline
                      W Offline
                      WolfgangFB
                      @jogibear9988 sagte in Interaktion aus HTML Tabelle möglich?:
                      Ich habe jetzt die 120 installiert und damit geht es.
                      Ich habe bisher einfach keine Veranlassung gesehenden Browser zu aktualisieren. Der Rechner auf dem das läuft hat kein internet und der Browser wird nur für IO-Broker und Enigma2 verwendet, von daher gab es eben für mich keine veranlassung zu aktualisieren (auf Rechnern die mit dem Internet verbunden sind halte ich den Broser natürlich up to date).
