  4. Interaktion aus HTML Tabelle möglich?
    6.0k
25 Beiträge 6 Kommentatoren 3.1k Aufrufe 5 Beobachtet
  • jogibear9988J jogibear9988
    @wolfgangfb
    das ist ne gute frage.
    welchen browser nutzt du? (+version)
    kannst man die dev tools öffnen (F12 im Browser) und schauen ob eine meldung in der console kommt
    W Offline
    W Offline
    WolfgangFB
    @jogibear9988
    Browser ist Firefox (95.0.2)
    Fehler ist:
    Source-Map-Fehler: Error: request failed with status 404
    Ressourcen-Adresse: http://192.168.1.205:8082/webui/node_modules/dock-spawn-ts/lib/js/ResizableContainer.js
    Source-Map-Adresse: http://192.168.1.205:8082/webui/node_modules/dock-spawn-ts/lib/js/ResizableContainer.js.map
    no screens loaded Not exists IobrokerHandler.js:135:21
    Uncaught (in promise) ReferenceError: CSSContainerRule is not defined
        traverseAndCollectRules http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:102
        buildPatchedStyleSheet http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:95
        applyAllStyles http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerCanvas.js:346
        initialize http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerCanvas.js:581
        emit http://192.168.1.205:8082/webui/node_modules/@node-projects/base-custom-webcomponent/dist/TypedEvent.js:35
        internalSetStylesheets http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:52
        setStylesheets http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/services/stylesheetService/AbstractStylesheetService.js:14
        set additionalStylesheets http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/documentContainer.js:26
        initialize http://192.168.1.205:8082/webui/dist/frontend/config/IobrokerWebuiScreenEditor.js:32
        openScreenEditor http://192.168.1.205:8082/webui/dist/frontend/config/IobrokerWebuiAppShell.js:246
        handleCommandButtonClick http://192.168.1.205:8082/webui/dist/frontend/config/CommandHandling.js:52
        onclick http://192.168.1.205:8082/webui/dist/frontend/config/CommandHandling.js:81
    5ea4acc9-b0a2-4bd7-9aa6-be960159ab16:102:18
        set additionalStyles http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerCanvas.js:334
        set additionalStyles http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/designerView/designerView.js:292
        set additionalStyleString http://192.168.1.205:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/documentContainer.js:15
        initialize http://192.168.1.205:8082/webui/dist/frontend/config/IobrokerWebuiScreenEditor.js:61
    jogibear9988J OliverIOO 2 Antworten Letzte Antwort
    • W WolfgangFB
      @jogibear9988
      Fehler ist:
      jogibear9988J Offline
      jogibear9988
      @wolfgangfb
      Ja denke der geht nicht. Firefox 95 ist mit Sicherheit zu alt.
      Check my ioBroker webui - a vis alternative
      see: https://github.com/iobroker-community-adapters/ioBroker.webui
      jogibear9988J 1 Antwort Letzte Antwort
        @wolfgangfb
        jogibear9988
        Zur not könnte man den vlt. durch polyfills supporten, aber eig. hab ich das nicht vor. Warum nutzt du so eine alte version?
        W 1 Antwort Letzte Antwort
        • W WolfgangFB
          @jogibear9988
          Fehler ist:
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @wolfgangfb sagte in Interaktion aus HTML Tabelle möglich?:
          CSSContainerRule
          ja, geht erst ab V110
          https://developer.mozilla.org/en-US/docs/Web/API/CSSContainerRule#browser_compatibility
          V95 ist jetzt exakt 2 Jahre alt.
          https://www.mozilla.org/en-US/firefox/95.0/releasenotes/
          gut v110 ist vom Februar 2023, damit ist das schon ein zeimliches bleeding edge feature. ab gut, browser sollte man schon regelmäßig updaten.
          allerdings gibt es altgeräte, die diese Aktualisierungen nicht mehr erhalten und dann werden diese geräte das nie können.
          hier im iobroker gern genutzt ältere tablets als bedienkonsole einzusetzen.
          @jogibear9988 setzt du babel bei der übersetzung ein? babel kann auf basis einer browserlist definition dir automatisch die features mit entsprechenden polifills ersetzen. d.h. bei der entwicklung kannst du immer die neuesten sachen verwenden, babel weiß dann welche browser was können und über die definition wählt es dann die richtige zusammensetzung.
          https://babeljs.io/docs/babel-preset-env
          Meine Adapter und Widgets
          Links im Profil
          • OliverIOO OliverIO
            CSSContainerRule
            jogibear9988
            @oliverio
            Ja, gibt glaube polyfills dafür (Falls dies aus irgendeinem Grund wirklich nötig wäre).
            Ich hatte mit meinem Designer auf alle möglichen neuen Technologien gesetzt, im Moment habe ich noch ein Polyfill für importmaps drin, das will ich aber auch noch raus schmeißen.
            Für die Runtime könnte man ja überlegen das man div. dinge Polyfillt, aber für den Designer würde ich das nicht tun
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @jogibear9988
              ist ja gut auf neue Technik zu setzen, aber du hängst ein teil der Nutzer damit ab.
              Die meisten kaufen sich für iobroker nicht die superaktuellste hardware, sondern nutzen eher ungenutzte veraltete hardware, die gerade noch so geht.
              was denkst du was ich in meinen widgets mit es6 Schwierigkeiten hatte und das auch zurückgefahren habe (gut war jetzt nicht so aufwändig), aber es6 ist ja noch viel älter
              aber genau dafür gibt es babel, damit du dir darüber keine gedanken machen musst und im produzierten endergebnis genau die quellen enthalten sind, die die größtmöglichste abdeckung an geräten/browsern/etc. abdeckt.
              als ich spreche hier nur vom client-anteil der auf dem browser läuft.
              für den server-anteil gibt es ja eine baseline, was iobroker als empfohlene node version einsetzt.
              Links im Profil
                @jogibear9988
                jogibear9988
                @oliverio
                Ja mag sein. Bei mir ist das aber auch konzeptbedingt, wie ich z.b. nodemodule als esm code nachlade.
                Gefühlt kann man ja sonst nie auf neue browser features setzen. Im moment braucht webui auf jeden fall einen relativ aktuellen browser
                  @oliverio
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @jogibear9988
                  ne,
                  ich glaub dann hast das prinzip noch nicht ganz verstanden
                  Links im Profil
                    @jogibear9988
                    ne,
                    jogibear9988
                    schrieb am zuletzt editiert von jogibear9988
                    @oliverio
                    ?? von was meinst du hab ich das prinzip nicht verstanden?
                    von npm paketen? ich meine damit das du bei meiner webui zur "laufzeit" npm pakete hinzufügen kannst, welche als ESM module geladen werden. Und ich liefere ja babel nicht mit meiner webui aus.
                    Will aber im moment auch wenn es nicht so wäre nicht mit babel auf eine alte es version übersetzen. Wie gesagt, ich nutze viele neue features, dann bräuchte ich auch polyfills dafür (constructible stylesheets, shadodom, customelements, ...) und wüsste bei problemen erst mal nicht, liegts an mir oder kann etwas z.b. nicht zu 100% polyfillt werden.
                      @oliverio
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @jogibear9988
                      alles gut
                      Links im Profil
                        @jogibear9988
                        alles gut
                        jogibear9988
                        @oliverio
                        habe nur nicht verstanden was du meintest das ich nicht verstanden habe ;-)
                          W Offline
                          W Offline
                          WolfgangFB
                          @jogibear9988 sagte in Interaktion aus HTML Tabelle möglich?:
                          Ich habe jetzt die 120 installiert und damit geht es.
                          Ich habe bisher einfach keine Veranlassung gesehenden Browser zu aktualisieren. Der Rechner auf dem das läuft hat kein internet und der Browser wird nur für IO-Broker und Enigma2 verwendet, von daher gab es eben für mich keine veranlassung zu aktualisieren (auf Rechnern die mit dem Internet verbunden sind halte ich den Broser natürlich up to date).
