  3. Einsteigerfragen
  4. SmartControladapter hängt *gelöst*
    5.5k
5 Beiträge 3 Kommentatoren 278 Aufrufe 3 Beobachtet
  • G Offline
    gluecksmann
    schrieb am zuletzt editiert von gluecksmann
    smartcontrol.0
    	2023-12-01 07:41:07.221	warn	Issue #1: [Config Table 'Target Devices'] State 'hue.0.Keller_Switch_LED_Blau.on' does not exist.
    smartcontrol.0
    	2023-12-01 07:41:07.220	error	[User Error (Anwenderfehler)] - 1 error(s) found in adapter configuration. You must fix these issue(s) to use this adapter.
    smartcontrol.0
    	2023-12-01 07:41:06.717	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v16.20.2, js-controller: 5.0.16
    smartcontrol.0
    	2023-12-01 07:41:00.947	info	terminating
    smartcontrol.0
    	2023-12-01 07:41:00.444	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    smartcontrol.0
    	2023-12-01 07:41:00.439	info	terminating
    smartcontrol.0
    	2023-12-01 07:41:00.438	info	Stopping adapter instance successfully proceeded...
    smartcontrol.0
    	2023-12-01 07:41:00.436	info	(0) schedules cleared...
    smartcontrol.0
    	2023-12-01 07:41:00.435	info	(0) timers were active and have been cleared...
    smartcontrol.0
    	2023-12-01 07:41:00.429	info	Got terminate signal TERMINATE_YOURSELF
    smartcontrol.0
    	2023-12-01 07:40:11.654	warn	Issue #1: [Config Table 'Target Devices'] State 'hue.0.Keller_Switch_LED_Blau.on' does not exist.
    smartcontrol.0
    	2023-12-01 07:40:11.652	error	[User Error (Anwenderfehler)] - 1 error(s) found in adapter configuration. You must fix these issue(s) to use this adapter.
    smartcontrol.0
    	2023-12-01 07:40:11.019	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v16.20.2, js-controller: 5.0.16
    Guten Morgen, auch wenn ich IOBroker schon lange nutze, denke ich das mein Niveau imme noch eines Anfängers würdig ist ;-) Was möchte mir dieses Log sagen?
    Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
    • G gluecksmann
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      smartcontrol.0
      @gluecksmann sagte in SmartControladapter hängt:
      node: v16.20.2
      Losgelöst vom Fehler in deiner Konfiguration:
      Bring das auf nodejs@18.
      iob stop
      iob fix
      iob nodejs-update
      • G gluecksmann
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        smartcontrol.0
        CodierknechtC Offline
        Codierknecht
        Dass ein bestimmter DP nicht existiert?
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        G 2 Antworten Letzte Antwort
        • CodierknechtC Codierknecht
          gluecksmann
          @codierknecht
          Ich forsche gerade...danke ...
            gluecksmann
            @codierknecht
            Datenpunkt gefunden...gelöscht.. läuft... DAs Update mache ich gerade... Danke für eure Hilfe
