  4. Addition in Blockly ist ein Takt verpätet
    5.2k
16 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    Das wäre mein Vorschlag. Nach wie vor unschön das über den HTTP-Aufruf zu machen und nicht über den Shelly-Adapter / MQTT.
      <variables>
        <variable id="5~z~#Wiey6Wm+:k-(y;)">powerDach</variable>
        <variable id="?t`soW~ls~_ZNU7NtEJ/">powerWand</variable>
        <variable id="pHhGY(Q7*~o%Dd37|tWd">result</variable>
      </variables>
      <block type="schedule" id="k8}]c#R$J#k4)~j3iE/]" x="38" y="-112">
        <field name="SCHEDULE">*/5 * * * * *</field>
        <statement name="STATEMENT">
          <block type="request" id="rk2/ba#iAcz{o.1Q/7a$">
            <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
            <field name="WITH_STATEMENT">TRUE</field>
            <field name="LOG">log</field>
            <value name="URL">
              <shadow type="text" id="pO18(QsS98Vfw5L]vEhf">
                <field name="TEXT">http://</field>
              </shadow>
              <block type="text" id="}?YTa6cQ^5}}%:]9+Jq4">
                <field name="TEXT">http://192.168.42.82/emeter/0/em_data</field>
              </block>
            </value>
              <block type="variables_set" id="nN0NOsiK3NItgy`[i?h:">
                <field name="VAR" id="5~z~#Wiey6Wm+:k-(y;)">powerDach</field>
                <value name="VALUE">
                  <block type="get_attr" id="W;B#3}b+`UbFL|^$j4pB">
                    <value name="PATH">
                      <shadow type="text" id="b!YJsu*sjfmsO8-5P5-a">
                        <field name="TEXT">power</field>
                      </shadow>
                    </value>
                    <value name="OBJECT">
                      <block type="convert_json2object" id="emW/+YWf|iqNRZ8r4IZr">
                          <block type="variables_get" id="bsJ8~?bfvi5w}Tm|Y6/Q">
                            <field name="VAR" id="pHhGY(Q7*~o%Dd37|tWd">result</field>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="request" id="EJiI.Mt]-t@/!+x.EVO]">
                    <field name="LOG"></field>
                    <value name="URL">
                      </shadow>
                      <block type="text" id="R=eVdGpEtS2l0$5lSvtU">
                        <field name="TEXT">http://192.168.42.82/emeter/1/em_data</field>
                      </block>
                    </value>
                      <block type="variables_set" id="Z6sVuRB@UNS=5#w=7IX;">
                        <field name="VAR" id="?t`soW~ls~_ZNU7NtEJ/">powerWand</field>
                          <block type="get_attr" id="y/o-vXfo@{$L$kvE~sN]">
                            <value name="PATH">
                              <shadow type="text" id="{LCKb-*Fj%3.F!?I/0z=">
                              </shadow>
                            </value>
                              <block type="convert_json2object" id="cgwUFo(vLF[~F[7t3##E">
                                  <block type="variables_get" id="ydNn}:!UQtd6de.j5Ns;">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="create_ex" id="qN0qvmtbx3~Ews`Zjv~s">
                            <field name="NAME">Geislingen.Solar.Dach</field>
                            <field name="TYPE">number</field>
                            <field name="READABLE">TRUE</field>
                            <field name="WRITEABLE">FALSE</field>
                              <block type="math_number" id="DA;REE-cDiZGFJWFqJ}Q">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                              <block type="update" id="+/O`77Zs[D]`1PXebcv+">
                                <field name="OID">javascript.0.Geislingen.Solar.Dach</field>
                                  <block type="variables_get" id="CrY;Lp^hcpYdojEKOQzD">
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <next>
                              <block type="create_ex" id="A)W1wsT6SPZW3lv-l4P%">
                                <field name="NAME">Geislingen.Solar.Wand</field>
                                  <block type="math_number" id="s@:ZK()u1VJnh#+/Eo~;">
                                  </block>
                                </value>
                                  <block type="update" id="G{ymt}c@ru:p%9IAFkd4">
                                    <field name="OID">javascript.0.Geislingen.Solar.Wand</field>
                                      <block type="variables_get" id="RMn.aVm(y05[|02h-dq;">
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block type="create_ex" id="-YA!ln})F0;*,VaK*N#8">
                                    <field name="NAME">Geislingen.Solar.gesamt</field>
                                      <block type="math_number" id=",i/x4Z6a5S1T#B0!W64F">
                                      </block>
                                    </value>
                                      <block type="update" id="A~Ab*1ZA[B,$CL,K-kDS">
                                        <field name="OID">javascript.0.Geislingen.Solar.gesamt</field>
                                          <block type="math_arithmetic" id=":iPP{?/N96a3rD@FYLZ7" inline="false">
                                            <field name="OP">ADD</field>
                                            <value name="A">
                                              <shadow type="math_number" id="XF0@Xf|:)@!W9EI^a|jO">
                                                <field name="NUM">1</field>
                                              </shadow>
                                              <block type="variables_get" id=")btF}XTf/=(Krzb_#yHW">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="lXM:`u0kd.-A3`r!OU4J">
                                              </shadow>
                                              <block type="variables_get" id="VAarkCZ;_q,;OHg/_zn!">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    Meckii
    @haus-automatisierung
    Vielen Dank.
    Du magst recht haben dass das so nicht sehr schön ist, aber ich möchte ja was dabei lernen und wollte mich so in Blockly reinarbeiten...
    • M Meckii
      Vielen Dank.
      haus-automatisierungH Offline
      @meckii Naja das kannst Du ja auch mit den Datenpunkten des Shelly-Adapters. Das Problem ist hier ja auch das Polling. Du "verpasst" ja viele Werte und nervst die Geräte per HTTP. Und kannst die Geräte auch nicht mit einem Passwort schützen. Also insgesamt viele Nachteile.
        Meckii
        schrieb am zuletzt editiert von Meckii
        Die Frage ist ob man bei einem Balkonkraftwerk wirklich jenden Messwert braucht :-)
        Ich hätte den Cron später auf 5min oder so gestellt...
        Dennoch vielen Dank :-)
          Meckii
          Habe jetzt mit dem Shelly Adapter experimentiert.
          Der hat ein Problem - oder ich bin zu doof.
          Die Shellys laufen nicht hier bei mir zu Hause sondern in einem anderen Subnet welches über VPN (zwei Fritzboxen) gekoppelt ist.
          Das angeben der IP hat leider nicht funktioniert...
          • M Meckii
            @meckii sagte in Addition in Blockly ist ein Takt verpätet:
            Dann wäre die Frage, was Du alles konfiguriert hast und welche Infos Dir in der Dokumentation des Adapters fehlen. Dort probiere ich ja eigentlich jeden Fall genau zu erklären und welche Infos wofür sind.
            Mit "der Adapter hat ein Problem" kann ich nichts anfangen. :)
              @haus-automatisierung ich nutze keine Shellys.
              Aver war da nicht was, dass (je nach Konfiguration??) es nicht über verschiedene Subnetze geht?
              • haus-automatisierungH Offline
                @homoran sagte in Addition in Blockly ist ein Takt verpätet:
                Das ist sehr allgemein gefragt. Kommt drauf an, was man vor hat. Wenn das Routing konfiguriert ist, klappt das natürlich auch. Meistens ist mDNS ein Problem (für CoAP und multicast - sollte man eh nicht nutzen).
                Aber wenn man MQTT nutzt, dann gibt es ja kein Auto-Discovery oder Multicast.
                Im Thread klappt ja schon der Zugriff von ioBroker zu den Shellies per HTTP. Die Frage ist, ob es auch andersrum klappt: Also dass die Shellies eine MQTT-Verbindung (Port 1882 ist Standard) zum ioBroker im anderen Netz aufbauen dürfen.
                  Meckii
                  MQTT kann ich leider nicht nutzen, da mein Vater die Sellyapp (cloud) beibehalten möchte.
                  Daher der Versuch über CoAP...
                  Vielleicht hab ich Morgen nochmals Zeit da ein bisschen dran rumzuprobieren...
                  • M Meckii
                    Wenn auf dem Shelly unicast konfiguriert ist, sollte das aber klappen?
                      Meckii
                      Ok. Shelly-Adapter läuft und bekommt die Daten per unicast.
                      Leider funktioniert mein Script welches die Addition der zwei Leistungen ausführt nicht.
                        <block type="on_ext" id="9obsf4j}+ALRCYj:v`c/" x="-87" y="-363">
                          <value name="OID0">
                            <shadow type="field_oid" id="7e5~BJi;f-iX;[`VnrY6">
                            </shadow>
                            <block type="logic_operation" id="{LJ$h2Gd6wix3:h}x,`f">
                              <field name="OP">OR</field>
                              <value name="A">
                                <block type="get_object" id="=9teI6aWLh4}0TGbHAl,">
                                  <field name="OID">shelly.0.SHEM#12345678EAB9#1.Emeter0.Power</field>
                                </block>
                              </value>
                              <value name="B">
                                <block type="get_object" id="V6/drw_7odA%65gvXNC*">
                                  <field name="OID">shelly.0.SHEM#12345678EAB9#1.Emeter1.Power</field>
                                </block>
                              </value>
                            </block>
                          </value>
                            <block type="create" id="iEx}%$]rU!v!?!Q09:r9">
                              <field name="NAME">Solar.gesamt</field>
                                <block type="math_number" id="O5_F]Wk}$nsVd?O{t5qK">
                                </block>
                              </value>
                              <value name="COMMON">
                                <block type="text" id="0Bxa?7/i#HAO?)(*BI=|">
                                  <field name="TEXT">{"type": "number", "unit": "W"}</field>
                                </block>
                              </value>
                                  <field name="OID">javascript.0.Solar.gesamt</field>
                                    <block type="math_arithmetic" id=":iPP{?/N96a3rD@FYLZ7">
                                      <value name="A">
                                        </shadow>
                                        <block type="get_value" id="~~[==`uxt.EW0RQ#y|.^">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </shadow>
                                        <block type="get_value" id=",PE~URIbDSC{Jh4J{hy5">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </xml>![Screenshot 2023-11-26 112931.png](/assets/uploads/files/1700994592072-screenshot-2023-11-26-112931.png)
                      • M Meckii
                            <value name="OID0">
                              </shadow>
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                                  </block>
                                </value>
                                  </block>
                                </value>
                                        <value name="A">
                                          </shadow>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                          </block>
                        @meckii Das liegt nicht am Adapter, sondern an deinem falschen Script. Wenn Du mehrere Objekt-IDs überwachen willst musst Du links auf das Zahnrad klicken und diese dann untereinander angeben. Und bitte auf die Objekt ID registrieren, nicht auf ein komplettes Objekt.
                        Grunlagen anschauen. Der Oder-Block gehört da auf keinen Fall hin :)
                          Meckii
                          Jetzt Funktioniert es :-)
                          Vielen lieben Dank!
