  3. Einsteigerfragen
  4. Parser Wert aus Webseite abgreifen und in DP schreiben
    5.5k
100 Beiträge 4 Kommentatoren 8.7k Aufrufe 3 Beobachtet
    Also hier die Datei als txt.....
    untitled text 2.txt
    und hier ein paar Abschnitte wo der Prozent Kurs steht:
    <div class="QuoteStrip-dataContainer">
                                         <div class="QuoteStrip-lastTimeAndPriceContainer">
                                             <div class="QuoteStrip-lastTradeTime">Last | 5:37 PM EST</div>
                                             <div class="QuoteStrip-lastPriceStripContainer">
                                                 <span class="QuoteStrip-lastPrice">15,583.00</span>
                                                 <span class="QuoteStrip-changeUp">
                                                     <img class="QuoteStrip-changeIcon" src="https://static-redesign.cnbcfm.com/dist/06a8f6f9aa697461e185.svg" alt="quote price arrow up"/>
                                                     <span>+327.00</span>
                                                     <span>
                                                         +2.14%<!-- -->
                                                     </span>
                                                 </span>
                                             </div>
                                         </div>
    und hier nochmal
    das scheint aber mehr so Stylesheet zu sein?
    "quote": {
             "data": [{
                 "symbol": "@ND.1",
                 "symbolType": "symbol",
                 "code": 0,
                 "name": "NASDAQ 100 Fut (Dec'23)",
                 "shortName": "NAS FUT",
                 "onAirName": "NASDAQ 100 Fut",
                 "altName": "",
                 "last": "15,583.00",
                 "last_timedate": "5:37 PM EST",
                 "last_time": "2023-11-11T17:37:14.000-0500",
                 "changetype": "UP",
                 "type": "DERIVATIVE",
                 "subType": "Future",
                 "exchange": "CME:Index and Options Market",
                 "source": "Exchange",
                 "open": "15,254.75",
                 "high": "15,612.75",
                 "low": "15,207.25",
                 "change": "+327.00",
                 "change_pct": "+2.14%",
                 "currencyCode": "USD",
                 "volume": "663,399",
                 "volume_alt": "663.4K",
                 "provider": "CNBC Quote Cache",
                 "previous_day_closing": "15,256.00",
                 "altSymbol": "NQZ3",
                 "realTime": "false",
                 "curmktstatus": "REG_MKT",
                 "yrhiprice": "16,062.75",
                 "yrhidate": "07\u002F19\u002F23",
                 "yrloprice": "10,751.00",
                 "yrlodate": "01\u002F06\u002F23",
                 "streamable": "1",
                 "open_interest": "265724",
                 "expiration_date": "2023-12-15",
                 "settlePrice": 15596.25,
                 "settleDate": "2023-11-10",
                 "issue_id": "49020645",
                 "countryCode": "US",
                 "timeZone": "EST",
                 "feedSymbol": "\u002FNQZ3",
                 "portfolioindicator": "N",
                 "EventData": {
                     "is_halted": "N"
    HomoranH Offline
    HomoranH Offline
    @olli_m sagte in Parser Wert aus Webseite abgreifen und in DP schreiben:
    und der wäte im Moment 2.14?
    odercwas willst du als Ergebnis?
      genau die +2,14 möchte ich rausbekommen und hoffen dass sich dass auch dann aktualisiert :-) dann mit dem Parser Adapter..
      aber da stehen halt davor und danach diese <!-- Zeichen dran vielleicht deshalb nicht...?
      ansonsten wenn die +327.00 darüber einfacher sind nehm ich auch die... :-)
        HomoranH Offline
        HomoranH Offline
        dann versuch mal mit price arrow [^\d]+[^\>]+[^\d]+([\d\.]+)
        und frag bloss nicht zu oft ab,
        ? 2 Antworten Letzte Antwort
          @homoran said in Parser Wert aus Webseite abgreifen und in DP schreiben:
          price arrow [^\d]+[^>]+[^\d]+([\d.]+)
          hab den Poll schon hochgesetzt...
          bekomme aber nur ein True rein....
          DJMarc75D HomoranH 2 Antworten Letzte Antwort
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            Du solltest auch den TYP anpassen - Number oder String ;)
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              @djmarc75
              ahh jetzt :-)
                mega danke dir :-)
                hab den Poll auf ne Stunde mal gesetzt....das sollte passen oder halbe stunde? was denkt ihr?
                oder kann ich den noch über nen cronjob von IO so verbinden? weil er z.b. am Wochenende gar nichts abfragen muss weil die Börse ja eh zu hat...?
                  HomoranH Offline
                  HomoranH Offline
                  Abgesehen davon dass die andern schon die richtige Antwort gegeben haben, wäte ein Screenshot vom
                  @homoran sagte in Parser Wert aus Webseite abgreifen und in DP schreiben:
                  regex Editor des Parser Adapters
                  schön gewesen.
                  Da ist alles viel übersichtlicher
                  • ? Offline
                    das ist komisch, hatte ich gemacht aber sehe grad dass der Post gar nicht rausgegangen ist :-/
                    Entschuldige Bitte...
                    und Vielen Dank für deine Hilfe...
                      HomoranH Offline
                      HomoranH Offline
                      auf die Knie 😂
                        auf die Knie 😂
                        wann und wo? 😝
                          auf die Knie 😂
                          Jetzt muss ich mal später schauen dass ich das mit Zeitsteuerung mache, hab schon gesehen, dass man über Blockly das machen könnte , dann würde man die Instanz halt ab und an steuern..ne andere Lösung grad noch net gefunden
                            schön gewesen.
                            Und hoffen dass es sich morgen auch aktualisiert 😆
                              HomoranH Offline
                              HomoranH Offline
                              höchstens um sie am Wochenende abzuschalten.
                              Ansonsten möglichst wenig abfragen um nicht aufzufallen.
                              Wenn in den Nutzungsbedingungen nichts steht ist es doch gut.
                              ? 3 Antworten Letzte Antwort
                                Und die sehen halt dass ich regelmäßig auf der Webseite bin mit meiner IP oder sehen die dass es eine richtige Abfrage ist ?
                                  @homoran hab mich vorhin mal registriert bei nasdaq direkt und dessen api aber weis noch ned wirklich was umsonst ist und wie es funktioniert 🤣
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @olli_m
                                    Also wenn du da nur gelegentlich mal abrufst, sagen wir einmal pro Stunde wird niemand was machen.
                                    Problem sind die Leute, die dann im Sekundentakt abfragen, da sie für einen liveticker kein Geld ausgeben wollen.
                                    Das dann nicht nur für einen Wert sondern für viele und nicht nur eine Person, sondern viele. Wenn du dann 20% mehr serverkapazität brauchst ohne die Chance auf Refinanzierung ist das blöd für die.
                                    So etwas fällt auf und die Seite ergreift Gegenmaßnahmen
                                    Wenn du scraping abrufst siehst du auch keine Werbung die die wahrscheinlich noch zusätzlich anzeigen und darüber wieder Geld verdingen.
                                    Evtl werden über die Seite auch eigene Produkte angezeigt oder auf Produkte verlinkt, über die dann per affiliate links wieder Geld verdient wird, wenn du dann eines der Produkte kaufst.
                                    Auch wenn Internet umsonst aussieht ist da nix umsonst. Wir bezahlen über Werbung anschauen oder unsere Daten.
                                    Meine Adapter und Widgets
                                    Links im Profil
                                    • OliverIOO OliverIO
                                      @olli_m
                                      @OliverIO
                                      ja verstehe ich auch, ja ich lass ihn mal auf eine Stunde und werde am WE die Instanz dann ausschalten :-) denke das ist so ne gute Kombi
                                        Hi
                                        also läuft soweit gut nur die Vorzeichen das + und - kommen leider nicht mit :-/
                                          Hi
                                          HomoranH Offline
                                          HomoranH Offline
                                          nur die Vorzeichen
                                          waren da welche im Textausschnitt?
                                          dann versuch mal mit price arrow [^\d]+[^\>]+[^\d]+([\d\.\+\-]+)
                                          ist modifiziert.
