  4. [gelöst] Listener/Events/ext. Subscriptions stoppen, wie?
    1.0k
    6.1k
22 Beiträge 5 Kommentatoren 5.4k Aufrufe
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    Klingt logisch.
    Hab es einfach mal schnell probiert… das Ergebnis ist trotz Logik gleich.
    host.nuc-g7-i7	2017-05-17 07:03:20.211	info	Restart adapter system.adapter.javascript.1 because enabled
    host.nuc-g7-i7	2017-05-17 07:03:20.209	error	instance system.adapter.javascript.1 terminated with code 0 (OK)
    javascript.1	2017-05-17 07:03:20.190	error
    javascript.1	2017-05-17 07:03:20.190	error	at Device. (C:\ioBroker\node_modules\iobroker.javascript\node_modules\co2-monitor\node_modules\usb\usb.js:200:7)
    javascript.1	2017-05-17 07:03:20.190	error	at Interface.co2Interface.release (C:\ioBroker\node_modules\iobroker.javascript\node_modules\co2-monitor\co2-monitor.js:101:21)
    javascript.1	2017-05-17 07:03:20.190	error	at Device.usb.Device.close (C:\ioBroker\node_modules\iobroker.javascript\node_modules\co2-monitor\node_modules\usb\usb.js:43:7)
    javascript.1	2017-05-17 07:03:20.190	error	at Error (native)
    javascript.1	2017-05-17 07:03:20.190	error	Error: Can't close device with a pending request
    javascript.1	2017-05-17 07:03:20.190	error	uncaught exception: Can't close device with a pending request
    javascript.1	2017-05-17 07:03:20.185	info	script.js.Entwicklung.co2-monitor: ---------------------- **** Skript wurde gestoppt **** ----------------------
    javascript.1	2017-05-17 07:03:20.185	info	Stop script script.js.Entwicklung.co2-monitor
    javascript.1	2017-05-17 07:03:19.137	info	script.js.Entwicklung.co2-monitor: data: {"co2":604,"temperature":"25.663"}
    javascript.1	2017-05-17 07:03:19.137	info	script.js.Entwicklung.co2-monitor: temp: 25.663
    javascript.1	2017-05-17 07:03:16.491	info	script.js.Entwicklung.co2-monitor: data: {"co2":604,"temperature":"25.600"}
    javascript.1	2017-05-17 07:03:16.491	info	script.js.Entwicklung.co2-monitor: co2: 604
    javascript.1	2017-05-17 07:03:14.124	info	script.js.Entwicklung.co2-monitor: data: {"co2":604,"temperature":"25.600"}
    javascript.1	2017-05-17 07:03:14.124	info	script.js.Entwicklung.co2-monitor: temp: 25.600
    javascript.1	2017-05-17 07:03:11.473	info	script.js.Entwicklung.co2-monitor: data: {"co2":604,"temperature":"25.600"}
    javascript.1	2017-05-17 07:03:11.473	info	script.js.Entwicklung.co2-monitor: co2: 604
    javascript.1	2017-05-17 07:03:09.105	info	script.js.Entwicklung.co2-monitor: data: {"co2":603,"temperature":"25.600"}
    javascript.1	2017-05-17 07:03:09.105	info	script.js.Entwicklung.co2-monitor: temp: 25.600
    javascript.1	2017-05-17 07:03:06.458	info	script.js.Entwicklung.co2-monitor: co2: 603
    javascript.1	2017-05-17 07:03:03.616	info	script.js.Entwicklung.co2-monitor: -------- -------- -------- CO2-Monitor connect erfolgreich gestartet -------- -------- --------
    javascript.1	2017-05-17 07:03:01.548	info	script.js.Entwicklung.co2-monitor: registered 0 subscriptions and 0 schedules
    javascript.1	2017-05-17 07:03:00.547	info	script.js.Entwicklung.co2-monitor: -------- -------- -------- CO2-Monitor Skript gestartet -------- -------- --------
    javascript.1	2017-05-17 07:03:00.540	info	Start javascript script.js.Entwicklung.co2-monitor
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @blauholsten:
      Asynchrone Funktionen können meines Kenntnisstandes nicht in try/catch abgearbeitet werden. Try catch ist beim Aufruf des Callbacks schon längst abgearbeitet. `
      Jein. Wenn der Fehler in der Asynchronen Funktion auftritt, bevor sie die Kontrolle an den Aufrufer zurückgibt, sollte es per try-catch abfangbar sein. try-catch im Callback fängt nur Fehler in der eigenen Callback-Funktion ab.
      In diesem Fall scheint der Fehler zwischendrin aufzutreten:
      ruhr's code ->
      * disconnect ->
        |  ruhr's code (nach Aufruf von disconnect)
        |__ disconnect arbeitet noch, bzw hat selbst asynchron was aufgerufen
            | -> fehler
      **    |__ hier käme der Callback
      Fehler in * und ** lassen sich mit try-catch um disconnect (*) bzw. im callback (**) abfangen.
      Fehler in internen asynchronen Aktionen der disconnect-Methode nicht.
      • blauholstenB Offline
        blauholsten
        Was passiert wenn man sowas schreibt…..?
        co2Monitor.disconnect(function() {
           // weitere Aktionen, die nach dem Disconnect ausgeführt werden sollen.
           // wenn keine, dann leer lassen.
        }).on ('error', function  (e) { console.error (e);});
        - Alarm Adapter
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
          interessante Erklärungen!
          ich probiere den Vorschlag nachher aus
          • ruhr70R Offline
            ruhr70R Offline
            ruhr70
            host.nuc-g7-i7	2017-05-17 16:49:29.792	error	instance system.adapter.javascript.1 terminated with code 0 (OK)
            javascript.1	2017-05-17 16:49:29.770	error	error in onStop callback: TypeError: Cannot read property 'on' of undefined
            javascript.1	2017-05-17 16:49:29.770	info	script.js.Entwicklung.co2-monitor: ---------------------- **** Skript wurde gestoppt **** ----------------------
              AlCalzoneA Offline
              AlCalzone
              Eine möglichkeit wäre noch (z.b. am Ende des Skripts):
              process.on('uncaughtException', function (err) {
                // sicherstellen, dass es wirklich der Fehler aus co2Monitor ist, den wir abfangen wollen. Diesen dann ignorieren oder darauf irgendwie reagieren
                // Ansonsten Fehler weitergeben per throw err
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                javascript.1	2017-05-18 20:40:16.857	error	script.js.Entwicklung.co2-monitor: ReferenceError: process is not defined
                  AlCalzoneA Offline
                  AlCalzone
                  Oh… dann funktioniert das nur in Adaptern. Fürchte, es muss in dem Modul nachgebessert werden.
                  • R Offline
                    redoced
                    Der stopPoll Aufruf bekommt eigentlich ein callback, was im original code allerdings nicht genutzt wird.
                    Ändere deinen Code auf folgendes:
                    onStop(function skriptStop () {
                        try{
                            co2Monitor.co2Endpoint.stopPoll(function(){
                                log("Polling gestoppt");
                                co2Monitor.co2Interface.release(true, (error) => {
                    				if(error) {
                    					co2Monitor.emit('error', error);
                    				else {
                    				    log("Interface released");
                    					co2Monitor.co2Device.close();
                    					log("Device geschlossen");
                    					cb(true);
                        } catch (e) {
                            log(e);
                            // hat nicht geklappt
                        log("---------------------- **** Skript wurde gestoppt **** ----------------------");
                    }, 100 /*ms*/);
                    • ruhr70R Offline
                      ruhr70R Offline
                      ruhr70
                      @redoced:
                      Ändere deinen Code auf folgendes: `
                      Danke!!! :D
                      Das hat funktioniert :!: . Dein Post hatte ich nicht gesehen. Und als ich nun das Thema noch einmal angehen wollte habe ich ihn zum Glück gefunden.
                      Hat auf Anhieb geklappt, auch wenn ich keine Ahnung habe, was da abläuft :?
