  3. Off Topic
  4. InfluxDB
  5. [gelöst]Meldung während upgrade von influxdb
    2.3k
    4.2k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
4 Beiträge 2 Kommentatoren 288 Aufrufe 3 Beobachtet
  • MartinPM Online
    MartinPM Online
    MartinP
    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
    martin@iobroker-test-sicher:/opt/iobroker/node_modules/iobroker.ical/admin$ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages will be upgraded:
      grafana-enterprise influxdb2
    2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 155 MB of archives.
    After this operation, 6674 kB of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    Get:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2 amd64 2.7.3-1 [45.9 MB]
    Get:2 https://apt.grafana.com stable/main amd64 grafana-enterprise amd64 10.2.0 [109 MB]
    Fetched 155 MB in 6s (25.6 MB/s)
    Reading changelogs... Done
    (Reading database ... 48973 files and directories currently installed.)
    Preparing to unpack .../grafana-enterprise_10.2.0_amd64.deb ...
    Unpacking grafana-enterprise (10.2.0) over (10.1.5) ...
    Preparing to unpack .../influxdb2_2.7.3-1_amd64.deb ...
    Unpacking influxdb2 (2.7.3-1) over (2.7.1-1) ...
    Setting up influxdb2 (2.7.3-1) ...
    Config file /etc/influxdb/config.toml already exists, writing defaults to /etc/influxdb/config.toml.defaults
    Setting up grafana-enterprise (10.2.0) ...
    Restarting grafana-server service... OK
    "Config file /etc/influxdb/config.toml already exists, writing defaults to /etc/influxdb/config.toml.defaults"
    Besteht da nicht die Gefahr, dass die config der neuen Version nicht kompatibel zur alten Version ist?
    Was ist da Usus? Machen die Maintainer einen Detektor in den Upgrade-Prozess und ziehen die Notbremse, wenn das Upgrade mit einer unbenutzbaren veralteten Konfiguration enden würde?
    Oder ist es unüblich, Upgrades automatisch auzurollen, die Anpassungen in der Konfiguration erfordern, die nicht automatisiert erfolgen können?
    • MartinPM MartinP
      @martinp sagte in Meldung während upgrade von influxdb:
      Moin,
      ja, wenn der Maintainer, des Paketes denkt, dass die neue Software eine geänderte Konfiguration braucht, dann bietet er das im Updateprozess an, da kannst Du dann während der Installation auswählen, was Du möchtest.
      In diesem Fall besteht keine Gefahr, dass die Konfiguration und Programm nicht zusammen passt.
      Du kannst aber auch ganz einfach ein diff über beide Dateien machen und schauen, welche Unterschiede vorhanden sind, oft sind es die, die Du selber gemacht hat.
      Befehl zum Vergleichen, terminal, putty, ssh- Fenster so groß wie möglich machen:
      # sudo vimdiff /pfad/datei/1 /pfad/datei/2
      Sollte vimdiff nicht da sein, einfach vim nachinstallieren.
      Wie man dann ein Merge von Dateien macht, sollte es nötig sein :)
      You can use the following basic commands to merge:
          do - Get changes from other window into the current window.
          dp - Put the changes from current window into the other window.
          ]c - Jump to the next change.
          [c - Jump to the previous change.
          zo - Open folded lines.
          zc - Close folded lines.
          zr - Unfold both files completely.
          zm - Fold both files completely.
          Ctrlww - change window.
          :only | wq - quit other windows, write and quit.
      Bernd
        Moin,
        Bernd
        MartinPM Online
        MartinPM Online
        MartinP
        @dp20eic Danke für die Hilfe.
        Die beiden Text-Dateien sind identisch.
        Zweizeiler mit 86 Bytes ...
        • MartinPM MartinP
          Moin,
          wenn dieses Thema für Dich jetzt gelöst ist, dann bitte im ersten Post, die Überschrift ergänzen, indem Du [Gelöst] davor packst.
          Bernd
