  4. WAGO 750-8212 -> illegal Data adress
13 Beiträge 5 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • L Offline
    legro
    schrieb am zuletzt editiert von legro
    Verzweifelt versuche ich das WAGO-Gateway für CAN/ModbusTCP über den Modbus-Adapter anzusprechen. Ich bekomme es einfach nicht ans Laufen.
    Ich erhalte immer bloß "illegal Data adress" als Fehlermeldung.
    Weiß jemand Rat?
    Hier meine Konfiguration ..
    .. und das zeigt beim Start des Adapters das Protokoll ..
    modbus.3
    2023-11-01 12:36:53.207	warn	Poll error count: 1 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.3
    2023-11-01 12:36:53.206	debug	Received pdu describes an error.
    modbus.3
    2023-11-01 12:36:53.194	debug	[DevID_1/holdingRegs] Poll address 40003 - 3 registers
    modbus.3
    2023-11-01 12:36:53.194	debug	Initialization of scale factors done!
    modbus.3
    2023-11-01 12:36:53.191	debug	[DevID_1] Poll start ---------------------
    modbus.3
    2023-11-01 12:36:53.190	info	Connected to slave 192.168.4.71
    modbus.3
    2023-11-01 12:36:52.804	debug	Add holdingRegisters.1.40005: {"_id":"holdingRegisters.1.40005","type":"state","common":{"name":"Test5","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40005,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.3
    2023-11-01 12:36:52.803	debug	Add holdingRegisters.1.40004: {"_id":"holdingRegisters.1.40004","type":"state","common":{"name":"Test4","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40004,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.3
    2023-11-01 12:36:52.802	debug	Add holdingRegisters.1.40003: {"_id":"holdingRegisters.1.40003","type":"state","common":{"name":"Test3","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40003,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.3
    2023-11-01 12:36:52.801	debug	Initialize Objects for holdingRegs: [{"_address":40003,"deviceId":1,"name":"","description":"Test3","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":true,"isScale":"","address":40003,"id":"holdingRegisters.1.40003"},{"_address":40004,"deviceId":1,"name":"","description":"Test4","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":true,"isScale":"","address":40004,"id":"holdingRegisters.1.40004"},{"_address":40005,"deviceId":1,"name":"","description":"Test5","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":true,"isScale":"","address":40005,"id":"holdingRegisters.1.40005"}]
    modbus.3
    2023-11-01 12:36:52.799	debug	Initialize Objects for inputRegs: []
    modbus.3
    2023-11-01 12:36:52.799	debug	Initialize Objects for coils: []
    modbus.3
    2023-11-01 12:36:52.797	debug	Initialize Objects for disInputs: []
    modbus.3
    2023-11-01 12:36:52.467	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.16.1, js-controller: 5.0.12
    modbus.3
    2023-11-01 12:36:51.860	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.3
    2023-11-01 12:36:46.100	info	terminating
    modbus.3
    2023-11-01 12:36:45.597	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    modbus.3
    2023-11-01 12:36:45.597	debug	Plugin sentry destroyed
    modbus.3
    2023-11-01 12:36:45.596	info	terminating
    modbus.3
    2023-11-01 12:36:45.594	debug	Closing client on purpose.
    modbus.3
    2023-11-01 12:36:45.593	info	Got terminate signal TERMINATE_YOURSELF
    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
    HomoranH DolomitiD B R 4 Antworten Letzte Antwort
    • L legro
      Weiß jemand Rat?
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      modbus.3
      @legro bitte den Threadtitel anpassen, damit das "Problem" erwähnt wird.
      Außerdem bitte die Konfiguration vollständig zeigen.
      L 1 Antwort Letzte Antwort
      • L legro
        Weiß jemand Rat?
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        modbus.3
        DolomitiD Offline
        DolomitiD Offline
        Dolomiti
        @legro
        Was willst du denn auslesen? Laut Handbuch greifst du bei diesem Fehler auf eine ungültige Adresse zu.
        Meinst du vielleicht die Adresse 3 und folgende?
        Zeig mal deine Holding-Register-Übersicht
        Intel N100 (32GB,256GB SSD), Proxmox -> Debian 12 in VM (Master) + Debian 12 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
        • L legro
          Weiß jemand Rat?
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          modbus.3
          Blockmove
          @legro
          Welche SPS-Runtime läuft auf dem Controller?
          In der Modbus-Configuration gibt es da ganz erhebliche Unterschiede.
          The difference beetween Man and Boys:
          The price of their toys 😀
            legro
            @homoran sagte in WAGO 750-8212 -> *illegal Data adress*:
            Ersteres erledigt. Beim zweiten weiß ich nicht so recht, was da fehlen soll.
            • DolomitiD Dolomiti
              @legro
              legro
              @dolomiti sagte in WAGO 750-8212 -> *illegal Data adress*:
              Zu Testzwecken habe ich versucht auf drei - nach Dokumentation existierende - Register zuzugreifen.
              • B Blockmove
                @legro
                legro
                @blockmove sagte in WAGO 750-8212 -> *illegal Data adress*:
                @legro
                Vielleicht kommen wir hiermit weiter. Leider kenne ich mich damit überhaupt nicht aus. Hoffentlich kannst du mir weiterhelfen.
                Die Modbus-Konfiguration habe ich über webvisu vorgenommen, alle übrigen Einstellungen im wbm.
                Wo finde ich die Informationen zur SPS-Runtime? Unter Device Status konnte ich nichts finden.
                aa288199-eb61-4985-a9e6-d5ad67555af6-Bildschirmfoto 2023-11-03 um 12.34.20.png Bildschirmfoto 2023-11-03 um 12.34.20.png
                • L legro
                  @legro sagte in WAGO 750-8212 -> illegal Data adress:
                  zu Testzwecken immer nur mit einem Register testen!
                  was da fehlen soll.
                  das:
                  Register
                  hat der Client tatsächlich die ID 1?
                  the given Adress/Port combination is already in use
                  steht im Screenshot ganz oben
                  • L legro
                    Weiß jemand Rat?
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    modbus.3
                    RGW
                    @legro
                    Bei der Wago beginnen die Modbus-Register "lesend" bei 0, die Modbus-Register "schreibend" bei 32000. (aus Sicht des iobroker)
                    Welche Programm-Variablen du austauschen möchtest, legst du in e!Cockpit im Modbus-Konfigurator fest. Der gibt dir dann auch die o.g. Zugriffsadresse.
                    Deine Einstellung in iobroker "Allgemeines" sehen richtig aus.
                    Gruss
                    Ralf
                    • L Offline
                      legro
                      @homoran sagte in WAGO 750-8212 -> illegal Data adress:
                      Keine Ahnung. Ich habe hier halt auf Verdacht die „1“ eingetragen.
                      DolomitiD 1 Antwort Letzte Antwort
                      • L legro
                        DolomitiD Offline
                        DolomitiD Offline
                        Dolomiti
                        @legro
                        Die 40003 sieht aus wie eine Alias-Adresse. Probier mal Adresse 3 bei den Holding-Registern einzutragen und dann setz dass Häkchen bei Aliases benutzen im Reiter Allgemein.
                          @legro
                          legro
                          @dolomiti
                          Mittlerweile bin ich ein gutes Stück vorangekommen. Nachdem ich zwei Fehler beseitigt hatte, konnte ich endlich via Modbus auf (einige) Register des WAGO-Gateways zugreifen.
                          1. Fehler : Auf dem CAN-Bus wurde der Fehler F.520 gemeldet. Den kann ich (leider nur temporär) beseitigen, indem ich die Anlage komplett stromlos mache und neu starte.
                          2. Fehler : Das WAGO-Gateway mahnt an, dass die Kombination IP:Port bereits im Netzwerk vorhanden sei. Es gibt jedoch die dem WAGO zugewiesene IP definitiv nur einmal. Um auch diesen Fehler zu umschiffen, habe ich den Modbus-Port im WAGO und ioBroker auf 503 konfiguriert.
                          Leider gibt‘s keinen Anlass zur ungetrübten Freude. Nun darf ich mich mit neuen Problemen herumschlagen.
                          Beispiele ..
                          Eigentlich sollte doch wohl auf die im Webinterface des WAGO (webvisu) sichtbaren Register auch mittels Modbus in ioBroker zugegriffen werden können. Dem ist mitnichten so. Auch sind einige Registerwerte ziemlich unsinnig, was wohl an dem jeweiligen Datentypen liegen mag, zu dem ich keine Dokumentation finden kann.
                          Und die Unterstützung durch Viessmann ist so, als ob diese Firma besser Fiesmann heißen sollte.
                          • L legro
                            @dolomiti
                            Beispiele ..
                            nutzt du den?
                            kannst du ihn komplett deaktivieren?
                            Fehler F.520
                            der bedeutet was?
                            wirklich?
                            ich denke es bezieht sich ausschließlich auf die Wago, da kann es sich also nur um den Port handeln.
                            Welchen Port hat denn der CAN Bus.
                            Warum?
                            welche Register wären das?
                            mit welchem Offset?
                            mit welchen Einstellungen?
                            82.9k
