  4. smartgarden - keine Verbindung
    2.9k
    5.0k
2 Beiträge 2 Kommentatoren 133 Aufrufe 2 Beobachtet
  • P Offline
    peterpan1108
    leider komme ich bei dem Thema nicht weiter.
    ich versuche den adapter einzubinden und bekomme immer wieder den gleichen fehler "Error: request returned 404 Not Found"
    kann mir jemand sagen wo ich den fehler mache ?
    smartgarden.0
    2023-11-02 14:28:22.753 info 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2023-11-02 14:28:22.749 info 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2023-11-02 14:28:22.709 info 3/ getConnection: trying to connect again in 300 seconds
    smartgarden.0
    2023-11-02 14:28:22.709 info 3/ getConnection: returned connection error: request returned 404 Not Found
    smartgarden.0
    2023-11-02 14:28:22.708 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2023-11-02 14:28:22.708 error Error: request returned 404 Not Found
    smartgarden.0
    2023-11-02 14:28:22.708 info 3/ get_locations failure:..return with error
    smartgarden.0
    2023-11-02 14:28:22.708 info 3/ get_locations failure: response.statusCode/Message=404/Not Found
    smartgarden.0
    2023-11-02 14:28:22.707 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2023-11-02 14:28:22.509 info 3/ get_locations ...
    smartgarden.0
    2023-11-02 14:28:22.509 info 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    smartgarden.0
    2023-11-02 14:28:22.509 info 3/ Connection: expires_in/timeout/factor:86399 / 86313 / 0.999
    smartgarden.0
    2023-11-02 14:28:22.508 info 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    smartgarden.0
    2023-11-02 14:28:22.341 info 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2023-11-02 14:28:22.282 info 3/ connect ... using client credentials grant
    smartgarden.0
    2023-11-02 14:28:22.281 info 3/ connect ... empty password
    smartgarden.0
    2023-11-02 14:28:22.281 info 3/ connect ... empty username
    smartgarden.0
    2023-11-02 14:28:22.281 info 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0
    2023-11-02 14:28:22.281 info 3/ connecting to Gardena Smart System Service ...
    smartgarden.0
    2023-11-02 14:28:22.281 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2023-11-02 14:28:22.280 info 3/ connectToGardena...
    smartgarden.0
    2023-11-02 14:28:22.280 info 3/ getConnection...
    • arteckA Offline
      arteckA Offline
      arteck
      @peterpan1108 LOG's in Code Tag packen ..bitte
