  4. Homekit Controller startet ständig neu, bis er gestoppt wird
28 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • H Homerunner
    Das habe bereits gemacht, aber die Fehlermeldungen sind geblieben.
    @homerunner
    Dann gibt mal die Langfassung von
    iob diag
    bekannt.
    • H Offline
      Homerunner
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-25-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       15:48:37 up 1 day, 20:38,  1 user,  load average: 0.06, 0.11, 0.08
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Wed 2023-11-01 15:48:37 CET
                 Universal time: Wed 2023-11-01 14:48:37 UTC
                       RTC time: Wed 2023-11-01 14:48:38
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker tty dialout cdrom floppy audio dip video plugdev netdev lpadmin scanner
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.0G        1.4G        398M        5.0M        1.2G        1.4G
      Swap:          3.1G         17M        3.1G
      Total:         6.1G        1.4G        3.5G
               3002 M total memory
               1405 M used memory
               1815 M active memory
                450 M inactive memory
                398 M free memory
                247 M buffer memory
                951 M swap cache
               3069 M total swap
                 17 M used swap
               3052 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      udev           devtmpfs  1.5G     0  1.5G   0% /dev
      tmpfs          tmpfs     301M  8.0M  293M   3% /run
      /dev/sda1      ext4       29G  6.3G   21G  24% /
      tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.5G     0  1.5G   0% /sys/fs/cgroup
      tmpfs          tmpfs     301M     0  301M   0% /run/user/1000
      [Mon Oct 30 19:09:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Oct 30 19:09:50 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
      `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      /var:
      896M    /var/
      711M    /var/cache
      692M    /var/cache/apt
      631M    /var/cache/apt/archives
      166M    /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      32M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      341M    /opt/iobroker/iobroker-data/
      216M    /opt/iobroker/iobroker-data/files
      100M    /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      9.3M    /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://ftp.de.debian.org/debian buster/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.1
      javascript:     7.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
      + system.adapter.mydlink.0                : mydlink               : iobroker                                 -  enabled
      + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
      Adapter    "backitup"     : 2.8.1    , installed 2.8.7
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "deconz"       : 1.3.21   , installed 1.3.22
      Adapter    "discovery"    : 3.1.0    , installed 3.2.0
      Adapter    "homekit-controller": 0.5.8, installed 0.5.8
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.16
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "mydlink"      : 1.3.4    , installed 1.3.4
      Adapter    "panasonic-comfort-cloud": 2.2.4, installed 2.2.4
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "wled"         : 0.7.1    , installed 0.7.1
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Adapter    "zigbee2mqtt"  : 2.13.3   , installed 2.13.3
      Objects and States
      Objects:        4214
      States:         3459
      Hit:1 http://security.debian.org/debian-security buster/updates InRelease
      Hit:2 http://phoscon.de/apt/deconz buster InRelease
      Hit:3 http://ftp.de.debian.org/debian buster InRelease
      Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11436      1/init
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       2104606    17991/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14097      447/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1351999    3148/cupsd
      tcp        0      0 0.0.0.0:44409           0.0.0.0:*               LISTEN      1000       2104641    18021/io.yahka.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       2099756    17266/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2099749    17266/iobroker.js-c
      tcp        0      0 127.0.0.1:39051         0.0.0.0:*               LISTEN      1000       2104722    18021/io.yahka.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          11444      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2102337    17285/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2104588    17976/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14099      447/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1351998    3148/cupsd
      udp        0      0 0.0.0.0:51504           0.0.0.0:*                           106        13971      384/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       2101736    17389/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       2101737    17389/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1352008    3149/cups-browsed
      udp        0      0 192.168.178.115:5353    0.0.0.0:*                           1000       2103535    17961/io.mydlink.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       2102873    17927/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13969      384/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2104373    17882/io.deconz.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13976      380/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11439      1/init
      udp6       0      0 :::45791                :::*                                106        13972      384/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                106        13970      384/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1000       2104375    17882/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       2104374    17882/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          11449      1/init
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[2]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]: Error: undefined is not a valid state value
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Array.forEach (<anonymous>)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[4]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]: Error: undefined is not a valid state value
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Array.forEach (<anonymous>)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30)
      2023-11-01 15:48:41.883  - error: host.iobroker Caught by controller[5]:     at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-11-01 15:48:41.883  - error: host.iobroker instance system.adapter.homekit-controller.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-11-01 15:48:41.884  - info: host.iobroker Restart adapter system.adapter.homekit-controller.0 because enabled
      • H Homerunner
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        iobroker
        /home/iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:          3.1G         17M        3.1G
                 3002 M total memory
                 1405 M used memory
                  398 M free memory
                  247 M buffer memory
                  951 M swap cache
                 3069 M total swap
                   17 M used swap
                 3052 M free swap
        *** FILESYSTEM ***
        /var:
        896M    /var/
        711M    /var/cache
        692M    /var/cache/apt
        166M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        4214
        States:         3459
        Pending Updates: 0
        @homerunner
        Und die Einstellungen im Adapter sehen wie aus?
        H 1 Antwort Letzte Antwort
          @homerunner
          Homerunner
          Kurios ist ja, unter Objekten sind Alle Geräte Grün.
          In der Instanz zeigt er keine Geräte an, ist nur am suchen..Screenshot 2023-11-01 155636.png Screenshot 2023-11-01 145643.png Screenshot 2023-11-01 145643 - Kopie.png Screenshot 2023-11-01 155735.png Colored Text Here
          • H Homerunner
            @homerunner
            Keine Ahnung wo es da hakt.
            • H Offline
              Homerunner
              Trotzdem danke für deine Mühe.
              Hast du einen Tipp, an wen ich mich noch wenden könnte?
              • H Homerunner
                @homerunner sagte in Homekit Controller startet ständig neu, bis er gestoppt wird:
                Bei GitHub ein Issue eröffnen.
                • H Offline
                  Homerunner
                  Ok, werde es versuchen.
                  Ich habe noch eine Baustelle, weiß nicht, ob das auch dein Bereich ist.
                  Du kennst bestimmt die WLED Garagentor Geschichte.
                  Ich habe WLED seitig vorbereitet. Bei mir scheitert es an der Umsetzung der Signale vom Tor in ein Blockly zu schreiben. Ich habe ein Garagentoröffner von Meross und habe fogende Infos:Screenshot 2023-10-25 121031.png
                  • H Offline
                    Homerunner
                    @thomas-braun said in Homekit Controller startet ständig neu, bis er gestoppt wird:
                    Wie und wo kann ich das machen?
                    • H Homerunner
                      @homerunner
                      Hier:
                      https://github.com/Apollon77/ioBroker.homekit-controller
                      Könnte aber das Ding sein:
                      https://github.com/Apollon77/ioBroker.homekit-controller/issues/291
                      • H Offline
                        Homerunner
                        Danke, nun läuft wieder alles gut.
