  4. HILFE Admin nicht erreichbar Befehle im Terminal ohne Effekt
    5.0k
34 Beiträge 2 Kommentatoren 2.8k Aufrufe 2 Beobachtet
    @dellishelly
    Nein, klingt nicht gut.
    Ruf iob diag mal wie in meiner Signatur auf.
    Dellishelly
    Ich hatte das Ding vorhin schonmal gemacht.
    da kam das hier bei raus
    			v.2023-10-25
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		multi-user.target
    Pending OS-Updates: 	21
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
    			/usr/bin/node 		v18.18.0
    npm ERR! code ENOSPC
    npm ERR! syscall write
    npm ERR! errno -28
    npm ERR! nospc ENOSPC: no space left on device, write
    npm ERR! nospc There appears to be insufficient space on your system to finish.
    npm ERR! nospc Clear up some disk space and try again.
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-31T08_30_09_951Z-debug-0.log
    			/usr/bin/npm
    npm ERR! errno -28
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-31T08_30_11_154Z-debug-0.log
    			/usr/bin/npx
    			/usr/bin/corepack 	0.19.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:           3.9G         50M        3.4G        8.0M        443M        3.7G
    Swap:           12M          0B         12M
    Total:         3.9G         50M        3.4G
    Active iob-Instances: 	0
    ioBroker Core: 		js-controller
    			admin
    ioBroker Status:
    Objects: 		0
    States: 		0
    Size of iob-Database:
    29M	/opt/iobroker/iobroker-data/objects.jsonl
    2.7M	/opt/iobroker/iobroker-data/objects.json.migrated
    2.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    88M	/opt/iobroker/iobroker-data/states.jsonl
    16K	/opt/iobroker/iobroker-data/states.json.migrated
    16K	/opt/iobroker/iobroker-data/states.json.bak.migrated
    • D Dellishelly
      			v.2023-10-25
               Icon name: computer
            Architecture: arm
      Kernel: 		armv7l
      Userland: 		armhf
      User-ID: 		1000
      X-Server: 		false
      npm ERR! errno -28
      			/usr/bin/npm
      npm ERR! errno -28
      			/usr/bin/npx
      MEMORY:
      Swap:           12M          0B         12M
      			admin
      ioBroker Status:
      Objects: 		0
      States: 		0
      @dellishelly
      Der Datenträger ist voll. Und Buster tot.
      Installier es neu unter Bookworm. 64Bit, kein Desktop.
        @dellishelly
        Dellishelly
        habe wir hier dazu eine Anleitung ?
        Bookworm 64 bit kein Desktop - da verstehe ich leider nicht was du damit meinst.
        Neuinstallation bedeutet dass die Skripts, Visus und Adaptereinistellungen alle weg sind ? Oder komm ich da noch irgendwie dran ?
        • D Dellishelly
          @dellishelly sagte in HILFE Admin nicht erreichbar Befehle im Terminal ohne Effekt:
          Du hast doch ein Backup.
          Das spielst du ein, nachdem die aktuellste Version des Betriebssystems installiert wurde.
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            Dellishelly
            schrieb am zuletzt editiert von Dellishelly
            ich glaube ich steh leider auf dem Schlauch.
            Also ich nehm mir ne neue SD Karte und folge 1:1 deiner Installationsanleitung ? Was ist hier mit Bookworm gemeint ?
            Wie fahre ich dann fort ? wie bekomme ich das Backup von der alten Karte auf die neue ?
            • D Dellishelly
              Backups liegen immer extern. Auf einem NAS oder einem externen Hoster. Ein Backup auf dem gleichen Datenträger nützt dir ja nix, wenn der einen Defekt hat.
              Also hast du kein gescheites Backup?
                Dellishelly
                Jetzt wo du es sagst, lautet ein...
                leider nur auf dem gleichen Datenträger.......
                • D Dellishelly
                  @dellishelly
                  sudo apt clean
                  Danach solltest du wieder rein kommen.
                  sudo systemctl restart iobroker
                  vielleicht noch. Dann Backup ordentlich einrichten und mit dem Kram in ein aktuelles System umziehen.
                    @dellishelly
                    sudo apt clean
                    Dellishelly
                    pi@iobroker-pi:~ $ sudo apt clean
                    -bash: /usr/bin/sudo: Input/output error
                    pi@iobroker-pi:~ $
                    der Befehl klappt leider auch nicht glaub ich
                    ----- War disconnected........ moment
                    • D Dellishelly
                      pi@iobroker-pi:~ $
                      @dellishelly
                      Das ist schlecht.
                      sudo su -
                      dann vermutlich auch nicht mehr?
                      D Thomas BraunT 2 Antworten Letzte Antwort
                        @dellishelly
                        Das ist schlecht.
                        sudo su -
                        Dellishelly
                        pi@iobroker-pi:~ $ sudo su -
                        root@iobroker-pi:~# apt clean
                        root@iobroker-pi:~# sudo systemctl restart iobroker
                        Failed to restart iobroker.service: Unit iobroker.service has a bad unit file setting.
                        See system logs and 'systemctl status iobroker.service' for details.
                        root@iobroker-pi:~#
                          @dellishelly
                          Das ist schlecht.
                          sudo su -
                          ls -lah /opt/iobroker/backups/
                          sagt?
                            sagt?
                            Dellishelly
                            root@iobroker-pi:~# ls -lah /opt/iobroker/backups/
                            insgesamt 401M
                            drwxrwxr-x+ 2 iobroker iobroker 4,0K Okt 29 02:41 .
                            drwxrwxr-x+ 7 iobroker iobroker 4,0K Okt 31 08:55 ..
                            -rw-rwxr--+ 1 iobroker iobroker  42M Sep 21 02:41 iobroker_2023_09_21-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  42M Sep 29 02:41 iobroker_2023_09_29-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  41M Okt  1 02:41 iobroker_2023_10_01-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  42M Okt  5 02:41 iobroker_2023_10_05-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  40M Okt  9 02:41 iobroker_2023_10_09-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  37M Okt 13 02:41 iobroker_2023_10_13-02_40_13_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  40M Okt 17 02:41 iobroker_2023_10_17-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  41M Okt 21 02:41 iobroker_2023_10_21-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  40M Okt 25 02:41 iobroker_2023_10_25-02_40_11_backupiobroker.tar.gz
                            -rw-rwxr--+ 1 iobroker iobroker  40M Okt 29 02:41 iobroker_2023_10_29-02_40_11_backupiobroker.tar.gz
                            root@iobroker-pi:~#
                            • D Dellishelly
                              insgesamt 401M
                              root@iobroker-pi:~#
                              @dellishelly
                              exit
                              df -h
                              sagt nun?
                              D 2 Antworten Letzte Antwort
                                @dellishelly
                                exit
                                df -h
                                sagt nun?
                                Dellishelly
                                @thomas-braun said in HILFE Admin nicht erreichbar Befehle im Terminal ohne Effekt:
                                exit
                                df -h
                                pi@iobroker-pi:~ $ df -h
                                Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                                /dev/root        15G     14G  653M   96% /
                                devtmpfs        1,8G       0  1,8G    0% /dev
                                tmpfs           1,9G       0  1,9G    0% /dev/shm
                                tmpfs           1,9G    8,4M  1,9G    1% /run
                                tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                                tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
                                /dev/mmcblk0p1  247M     50M  197M   21% /boot
                                tmpfs           389M       0  389M    0% /run/user/1000
                                pi@iobroker-pi:~ $
                                  @dellishelly
                                  exit
                                  df -h
                                  sagt nun?
                                  Dellishelly
                                  ich lese grad nebenbei noch einen topic in dem der admin nicht erreichbar war....
                                  Das Thema mqtt Logfile....
                                  Ich glaube ich hab mir den Speicher mit debug Logfiles zugespamt... kann das sein ?
                                  • D Dellishelly
                                    @dellishelly
                                    Schau per
                                    sudo ncdu /
                                    nach den dicken Dingern.
                                      @dellishelly
                                      Schau per
                                      sudo ncdu /
                                      Dellishelly
                                      sudo ncdu /
                                          3,1 GiB [##########]  iobroker.2023-10-30.log
                                        319,6 MiB [#         ]  iobroker.2023-10-24.log.gz
                                        315,2 MiB [#         ]  iobroker.2023-10-23.log.gz
                                        289,0 MiB [          ]  iobroker.2023-10-25.log.gz
                                        273,3 MiB [          ]  iobroker.2023-10-28.log.gz
                                        259,7 MiB [          ]  iobroker.2023-10-29.log.gz
                                        233,6 MiB [          ]  iobroker.2023-10-27.log.gz
                                        216,3 MiB [          ]  iobroker.2023-10-26.log.gz
                                        177,4 MiB [          ]  iobroker.2023-10-30.log.gz
                                         26,6 MiB [          ]  iobroker.2023-10-31.log
                                          4,0 KiB [          ]  iobroker-audit.json
                                      @   0,0   B [          ]  iobroker.current.log
                                      wie lösch ich das Moped ?
                                      • D Dellishelly
                                        sudo ncdu /
                                        @dellishelly
                                        cd /opt/iobroker/logs
                                        Und dann schaust du per
                                        zless iobroker.2023-10-30.log.gz
                                        in die Datei rein und guckst was da so ausgetickt ist.
                                          @dellishelly
                                          Dellishelly
                                          JavaScript Instanz steht auf silly.....
                                          Thomas BraunT D 2 Antworten Letzte Antwort
