  4. Absturz aller Adapter nach Upgrade auf js-controller 5
29 Beiträge 4 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • J Jens77
    @thomas-braun Danke.
    Die Postgres-Pakete würden Postgres-16 installieren, ich verwende für Teslamate derzeit Postgres-14, daher werde ich die zurückhalten. Das hat mit meinem iobroker-Problem aber ziemlich sicher nichts zu tun.
    iob diag verlangt noch nach einem nodejs binary, welches seit nodejs 16 nicht mehr existiert (zumindest nicht in den Paketen von nodesource.com).
    *** BASE SYSTEM ***
    Static hostname: raspberry64
    Icon name: computer
    Operating System: Debian GNU/Linux 11 (bullseye)
    Kernel: Linux 6.1.19-v8+
    Architecture: arm64
    Model : Raspberry Pi 4 Model B Rev 1.2
    Docker : false
    Virtualization : none
    Kernel : aarch64
    Userland : arm64
    Systemuptime and Load:
    20:11:34 up 49 days, 3:25, 6 users, load average: 2.13, 1.94, 1.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    This system needs to be REBOOTED!
    *** Time and Time Zones ***
    Local time: Mon 2023-10-30 20:11:35 CET
    Universal time: Mon 2023-10-30 19:11:35 UTC
    RTC time: n/a
    NTP service: active
    RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    Boot Target: multi-user.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 3.8G 1.9G 154M 20M 1.7G 1.7G
    Swap: 3.8G 91M 3.7G
    Total: 7.6G 2.0G 3.9G
         3793 M total memory
         1935 M used memory
         1079 M active memory
         1656 M inactive memory
          154 M free memory
           49 M buffer memory
         1654 M swap cache
         3802 M total swap
           91 M used swap
         3711 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    • hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
    LOAD = Reflects whether the unit definition was properly loaded.
    SUB = The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 440G 77G 346G 19% /
    devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
    tmpfs tmpfs 1.9G 224K 1.9G 1% /dev/shm
    tmpfs tmpfs 759M 1.1M 758M 1% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    /dev/sda1 vfat 253M 31M 222M 13% /boot
    tmpfs tmpfs 380M 8.0K 380M 1% /run/user/1000
    [Mon Sep 11 17:46:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:73:2C:88 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=38be9e7a-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): 13 orphan inodes deleted
    [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): recovery complete
    [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Sep 11 17:46:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Sep 11 17:46:07 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/sda2 ext4 rw,noatime
    `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    17G /var/
    7.7G /var/lib
    4.9G /var/log
    3.2G /var/log/journal/82d4f63990114b27bac41e9b3e9a49f1
    Archived and active journals take up 3.1G in the file system.
    /opt/iobroker/backups:
    603M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    247M /opt/iobroker/iobroker-data/
    160M /opt/iobroker/iobroker-data/files
    67M /opt/iobroker/iobroker-data/backup-objects
    52M /opt/iobroker/iobroker-data/files/javascript.admin
    34M /opt/iobroker/iobroker-data/files/javascript.admin/static
    21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.9M /opt/iobroker/iobroker-data/objects.jsonl
    7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node v18.17.1
    /usr/bin/npm 9.6.7
    /usr/bin/npx 9.6.7
    /usr/bin/corepack 0.18.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
    Installed: 18.17.1-deb-1nodesource1
    Candidate: 18.17.1-deb-1nodesource1
    Version table:
    *** 18.17.1-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
    12.22.12~dfsg-1~deb11u4 500
    500 http://deb.debian.org/debian bullseye/main arm64 Packages
    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Core adapters versions
    js-controller: 5.0.12
    admin: 6.12.0
    javascript: 7.1.4
    Adapters from github: 0
    Adapter State
    • system.adapter.admin.0 : admin : raspberry64 - enabled, compact enabled (group 1), port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.backitup.0 : backitup : raspberry64 - enabled, compact enabled (group 1)
    • system.adapter.bydhvs.0 : bydhvs : raspberry64 - enabled, compact enabled (group 1)
    • system.adapter.deconz.0 : deconz : raspberry64 - enabled, compact enabled (group 1), port: 80
    • system.adapter.discovery.0 : discovery : raspberry64 - enabled, compact enabled (group 1)
    • system.adapter.fritzdect.0 : fritzdect : raspberry64 - enabled, compact enabled (group 1)
      system.adapter.habpanel.0 : habpanel : raspberry64 - enabled
    • system.adapter.influxdb.0 : influxdb : raspberry64 - enabled, compact enabled (group 1), port: 8086
    • system.adapter.iqontrol.0 : iqontrol : raspberry64 - enabled, compact enabled (group 1)
    • system.adapter.javascript.0 : javascript : raspberry64 - enabled, compact enabled (group 1)
    • system.adapter.mqtt.0 : mqtt : raspberry64 - enabled, compact enabled (group 1), port: 1884, bind: 0.0.0.0
      system.adapter.net-tools.0 : net-tools : raspberry64 - disabled, compact disabled
      system.adapter.netatmo.0 : netatmo : raspberry64 - disabled, compact disabled
    • system.adapter.node-red.0 : node-red : raspberry64 - enabled, compact enabled (group 1), port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0 : openweathermap : raspberry64 - enabled, compact enabled (group 1)
      system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberry64 - disabled, compact enabled (group 1)
    • system.adapter.plenticore.0 : plenticore : raspberry64 - enabled, compact enabled (group 1), port: 80
    • system.adapter.rpi2.0 : rpi2 : raspberry64 - enabled
      system.adapter.smartcontrol.0 : smartcontrol : raspberry64 - disabled, compact enabled (group 1)
    • system.adapter.sonoff.0 : sonoff : raspberry64 - enabled, compact enabled (group 1), port: 1883, bind: 0.0.0.0
    • system.adapter.tesla-motors.0 : tesla-motors : raspberry64 - enabled, compact disabled
    • system.adapter.tr-064.0 : tr-064 : raspberry64 - enabled, compact enabled (group 1)
      system.adapter.weatherunderground.0 : weatherunderground : raspberry64 - enabled, compact enabled (group 1)
    • system.adapter.web.0 : web : raspberry64 - enabled, compact enabled (group 1), port: 8082, bind: 0.0.0.0, run as: admin
    • instance is alive
    ioBroker-Repositories
    stable : http://download.iobroker.net/sources-dist.json
    beta : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter "admin" : 6.12.0 , installed 6.12.0
    Adapter "backitup" : 2.8.1 , installed 2.8.1
    Adapter "bydhvs" : 1.4.0 , installed 1.4.0
    Adapter "deconz" : 1.3.21 , installed 1.3.21
    Adapter "discovery" : 3.1.0 , installed 3.1.0
    Adapter "fritzdect" : 2.3.1 , installed 2.3.1
    Adapter "habpanel" : 0.5.0 , installed 0.5.0
    Adapter "influxdb" : 3.2.0 , installed 3.2.0
    Adapter "iqontrol" : 2.3.0 , installed 2.3.0
    Adapter "jarvis" : 3.1.2 , installed 3.1.2
    Adapter "javascript" : 7.1.4 , installed 7.1.4
    Controller "js-controller": 5.0.12 , installed 5.0.12
    Adapter "mqtt" : 4.1.1 , installed 4.1.1
    Adapter "net-tools" : 0.2.0 , installed 0.2.0
    Adapter "netatmo" : 3.1.0 , installed 3.1.0
    Adapter "node-red" : 4.0.3 , installed 4.0.3
    Adapter "openweathermap": 0.3.9 , installed 0.3.9
    Adapter "panasonic-comfort-cloud": 2.2.4, installed 2.2.4
    Adapter "plenticore" : 2.2.0 , installed 2.2.0
    Adapter "rpi2" : 1.3.2 , installed 1.3.2
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "smartcontrol" : 2.0.1 , installed 2.0.1
    Adapter "socketio" : 6.5.5 , installed 6.5.5
    Adapter "sonoff" : 2.5.3 , installed 2.5.3
    Adapter "synology" : 3.0.0 , installed 3.0.0
    Adapter "tesla-motors" : 1.3.2 , installed 1.3.2
    Adapter "tr-064" : 4.2.18 , installed 4.2.18
    Adapter "weatherunderground": 3.6.0, installed 3.6.0
    Adapter "web" : 6.1.2 , installed 6.1.2
    Adapter "ws" : 2.5.5 , installed 2.5.5
    Objects and States
    Objects: 6466
    States: 5552
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
    Ign:5 http://binaries.erlang-solutions.com/debian stretch InRelease
    Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:7 http://binaries.erlang-solutions.com/debian stretch Release
    Hit:8 https://apt.grafana.com stable InRelease
    Hit:9 https://repos.influxdata.com/debian bullseye InRelease
    Get:10 https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version InRelease [8263 B]
    Hit:11 https://packages.sury.org/php bullseye InRelease
    Hit:12 http://apt.postgresql.org/pub/repos/apt bullseye-pgdg InRelease
    Hit:13 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:14 https://packagecloud.io/timescale/timescaledb/debian bullseye InRelease
    Fetched 8263 B in 6s (1438 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 127.0.0.1:45293 0.0.0.0:* LISTEN 0 101007442 3558521/containerd
    tcp 0 0 127.0.0.1:4100 0.0.0.0:* LISTEN 1003 100600466 3450285/beam.smp
    tcp 0 0 0.0.0.0:32943 0.0.0.0:* LISTEN 1003 100601531 3450285/beam.smp
    tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 0 100598861 3449771/dnsmasq
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 101006440 3558544/sshd: /usr/
    tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 101006581 3558589/deCONZ
    tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 101007552 3558589/deCONZ
    tcp 0 0 0.0.0.0:4369 0.0.0.0:* LISTEN 1003 100601919 3450336/epmd
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 100746363 3486227/iobroker.js
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 100745357 3486227/iobroker.js
    tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 110 100596344 3449823/postgres
    tcp 0 0 0.0.0.0:8000 0.0.0.0:* LISTEN 0 59433239 124555/docker-proxy
    tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 100905151 3527193/iobroker.js
    tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 100905102 3527354/node-red
    tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 100902643 3527193/iobroker.js
    tcp 0 0 172.17.0.1:5432 0.0.0.0:* LISTEN 110 100596345 3449823/postgres
    tcp 0 0 127.0.0.1:2019 0.0.0.0:* LISTEN 998 100555213 3427267/caddy
    tcp6 0 0 :::3000 :::* LISTEN 115 100474205 3407841/grafana
    tcp6 0 0 :::53 :::* LISTEN 0 100598863 3449771/dnsmasq
    tcp6 0 0 :::4101 :::* LISTEN 998 100553324 3427267/caddy
    tcp6 0 0 :::22 :::* LISTEN 0 101006442 3558544/sshd: /usr/
    tcp6 0 0 :::81 :::* LISTEN 998 100553327 3427267/caddy
    tcp6 0 0 :::4369 :::* LISTEN 1003 100601920 3450336/epmd
    tcp6 0 0 :::8082 :::* LISTEN 1001 100905309 3527193/iobroker.js
    tcp6 0 0 :::8081 :::* LISTEN 1001 100903176 3527193/iobroker.js
    tcp6 0 0 :::8086 :::* LISTEN 999 100552823 3426555/influxd
    tcp6 0 0 :::6000 :::* LISTEN 998 100553326 3427267/caddy
    udp 0 0 169.254.39.1:5353 0.0.0.0:* 1001 100905131 3527193/iobroker.js
    udp 0 0 172.17.0.1:5353 0.0.0.0:* 1001 100905130 3527193/iobroker.js
    udp 0 0 192.168.178.54:5353 0.0.0.0:* 1001 100905129 3527193/iobroker.js
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 100595343 3449495/avahi-daemo
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 101006633 3558589/deCONZ
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 100902803 3527193/iobroker.js
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 100902801 3527193/iobroker.js
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 100902798 3527193/iobroker.js
    udp 0 0 0.0.0.0:53 0.0.0.0:* 0 100598860 3449771/dnsmasq
    udp 0 0 0.0.0.0:67 0.0.0.0:* 0 100598857 3449771/dnsmasq
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 100595687 3449541/dhcpcd
    udp 0 0 0.0.0.0:53734 0.0.0.0:* 108 100595345 3449495/avahi-daemo
    udp6 0 0 :::5353 :::* 108 100595344 3449495/avahi-daemo
    udp6 0 0 :::1900 :::* 1001 100902804 3527193/iobroker.js
    udp6 0 0 :::1900 :::* 1001 100902802 3527193/iobroker.js
    udp6 0 0 :::1900 :::* 1001 100902800 3527193/iobroker.js
    udp6 0 0 :::1900 :::* 1001 100902799 3527193/iobroker.js
    udp6 0 0 :::4101 :::* 998 100553325 3427267/caddy
    udp6 0 0 :::53 :::* 0 100598862 3449771/dnsmasq
    udp6 0 0 :::55643 :::* 108 100595346 3449495/avahi-daemo
    udp6 0 0 :::546 :::* 0 100595686 3449541/dhcpcd
    2023-10-30 20:04:50.660 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:05:21.161 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:05:52.873 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:06:26.928 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:07:00.837 - info: influxdb.0 (COMPACT) Store 202 buffered influxDB history points
    2023-10-30 20:07:28.914 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:08:03.707 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:08:12.672 - info: plenticore.0 (COMPACT) Read forecast data before calcMinSoC.
    2023-10-30 20:08:13.146 - info: plenticore.0 (COMPACT) calcMinSoC for day 1.
    2023-10-30 20:08:13.189 - info: plenticore.0 (COMPACT) calcMinSoC for day 2.
    2023-10-30 20:08:13.189 - info: plenticore.0 (COMPACT) Using forecast of day 2 for MinSoC calculation.
    2023-10-30 20:08:15.354 - info: plenticore.0 (COMPACT) got weather data from met.no with 88 elements.
    2023-10-30 20:08:15.559 - info: plenticore.0 (COMPACT) Requested weather data from kachelmannwetter.com
    2023-10-30 20:08:15.698 - info: plenticore.0 (COMPACT) Requested alternative weather data from kachelmannwetter.com
    2023-10-30 20:08:15.707 - info: plenticore.0 (COMPACT) Got all internal forecast data and made it available to main process.
    2023-10-30 20:08:33.873 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:09:06.688 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:09:37.545 - info: influxdb.0 (COMPACT) Store 202 buffered influxDB history points
    2023-10-30 20:10:12.184 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:10:41.886 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:11:15.880 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:11:47.310 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:12:18.711 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:12:52.500 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    2023-10-30 20:13:22.934 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
    [/s]
    Danke für jede Hilfe!
    @jens77 >
      @jens77 sagte in Absturz aller Adapter nach Upgrade auf js-controller 5:
      Doch, in den aktuellen Versionen ist es drin. Installier das.
      Jens77
      @thomas-braun Wie heißt denn das Paket?
      nodejs (v18) ist bereits installiert.
      • J Jens77
        @jens77
        Das Repo muss umgestellt werden.
        Kannst du per Skript / Kommando machen
        iob nodejs-update
          @jens77 >
          Jens77
          @thomas-braun Meine beschriebenen iob-Probleme traten schon auf, bevor neu gestartet werden sollte. Ich habe erst als diese Probleme auftraten ein apt upgrade nachgeschoben, wobei (u.a.) ein neuer Kernel installiert wurde, der jetzt den Neustart fordert.
          Ich denke also nicht, dass es daran liegen wird.
          • J Jens77
            Nein, aber mach es, damit die Updates auch greifen. Die Meldung kommt nicht aus Jux und Dollerei, die hat schon einen Hintergrund.
              @jens77
              iob nodejs-update
              Jens77
              Das Skript ist lustig:
              Nothing to do - Your installation is using the correct paths.
              You are running nodejs v18.17.1. Do you want to install recommended version 18.18.2?
              Was denn jetzt? :-)
              Installing the recommended nodejs version now!
              /home/iobroker/.nodejs-update.sh: line 331: [: : integer expression expected
              /home/iobroker/.nodejs-update.sh: line 348: [: : integer expression expected
              Installing the recommended nodejs version!
              (Reading database ... 89181 files and directories currently installed.)
              Preparing to unpack .../nodejs_18.18.2-1nodesource1_arm64.deb ...
              Detected old npm client, removing...
              Unpacking nodejs (18.18.2-1nodesource1) over (18.17.1-deb-1nodesource1) ...
              Setting up nodejs (18.18.2-1nodesource1) ...
              Gerade probiert - Problem tritt immer noch exakt so auf wie anfangs beschrieben, auch mit Node 18.18.
              • J Jens77
                Was denn jetzt? :-)
                Was denn jetzt?
                Die Installations-Pfade sind richtig, an der Stelle ist also nichts zu tun, die Version ist allerdings nicht richtig/die aktuelle.
                Und genau das wird gemeldet.
                Also ganz 'unlustig' die richtige Diagnose.
                  Was denn jetzt?
                  Jens77
                  @thomas-braun Das stimmt wohl.
                  Der Vollständigkeit halber mache ich jetzt mal einen Neustart, melde mich dann zurück (das kann allerdings etwas dauern). Danke schon mal!
                  • J Jens77
                    @jens77
                    Da hats mal Einschläge im Dateisystem gegeben:
                    Da gibt es mit Sicherheit aber auch ein für Bullseye passendes Repo.
                    mcm1957M J 2 Antworten Letzte Antwort
                      @jens77
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @Jens77
                      Versuch mal das System OHNE Compact mode zu betreiben. Ich hab im Hinterkopf ein komisches Problem bei einem anderen Adapter das mit Compaq Mode zusammen hängen könnte. War damals nicht mehr reproduzierbar. Ist zwar nur ein Hintergrundgedanke und kann absoluter Blödsinn sein - aber wenn dein Problem ohne Compact Mode nicht auftritt und mit schon, dann mention bitte Foxriver76 damit er sich einklinkt. Dann könnte (BETONUNG könnte) ein Problem mit js-controller 5 und compact Mode existieren.
                      Aber wie geschrieben - ist nur ein Hintergrundgedanke und kann total falsch sein !
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • mcm1957M mcm1957
                        @Jens77
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        Und noch was:
                        Wenn da was abstürzt bitte den gesammten Log hier anhängen.
                        Derzeit seh ich nicht wirklich ewas du unter 'stürzt ab' verstehst bzw.w eclhe Fehlermeldungen genau auftreten.
                          @jens77
                          Jens77
                          @thomas-braun Korrekt, die Dateisystemfehler wurden behoben. (auch offline noch mal)
                          Zum Thema Erlang: damals leider nicht. Das (brauche ich für Teslamate) ist aber auch völlig unabhängig von iobroker.
                          • J Jens77
                            Aber nicht unabhänigig vom Gesamtsystem.
                            • mcm1957M mcm1957
                              Und noch was:
                              Jens77
                              @mcm57 Habe ich versucht. Die 520kb lassen das Forensystem abstürzen, jedes Mal wieder.
                              Daher habe ich die 100-fachen Wiederholmeldungen rausgekürzt und den Rest hinter Spolier-Tags versteckt.
                              Aber hier bitte: https://share.rb-hosting.de/s/fkqJWp2RinWCN9S
                              Da ist das vollständige Log eines Adapter-Neustarts.
                                Jens77
                                @thomas-braun Nein, natürlich nicht. Alles ist verbunden.
                                Aber man sollte nach Plausibilität priorisieren. Es gibt Dinge, die haben einen wahrscheinlichen Einfluss und Dinge, deren Einfluss ist eher unwahrscheinlich, und Dinge, denen Einfluss zu unterstellen wäre geradezu absurd.
                                Ansonsten kommt der nächste und fragt nach der Konfiguration unserer Fritzbox, oder was ich zum Abendessen hatte. :-)
                                • mcm1957M mcm1957
                                  Und noch was:
                                  Jens77
                                  @mcm57 Dann klick mal in meiner Originalmeldung auf die Spoiler-Tags. Da sind die Absturz-logs zitiert.
                                  Oder lad dir das ganze Log herunter, das konnte ich hier nicht posten, siehe Link in der vorigen Nachricht.
                                  • J Jens77
                                    @jens77
                                    Schalt den Compact-Mode mal aus.
                                    • mcm1957M mcm1957
                                      @Jens77
                                      Jens77
                                      schrieb am zuletzt editiert von Jens77
                                      @mcm57 das habe ich jetzt gemacht. Bisher ist der Fehler nicht wieder aufgetreten, Adapter lassen sich normal neu starten.
                                      Leider braucht ioBroker ohne Compact Mode mit allen Adaptern fast 2GB RAM, da fängt der Raspi irgendwann an zu schwitzen, das ist also keine langfristige Lösung.
                                      @Foxriver76, kannst du hier weiterhelfen? Vielleicht habe ich einen Bug im compact mode des neuen js-controllers gefunden. Danke für jede Hilfe!
                                      Nochmal zusammengefasst: Der Neustart einzelner Adapter (egal welcher, passiert mit allen, immer) lässt seit Update auf js-controller 5 (von 4) und Node 18 (von 14) den ganzen ioBroker abstürzen, weil die "states database" plötzlich für alle Adapter nicht mehr verfügbar ist. Beispiel-Logfile ist oben verlinkt.
                                      apt upgrade inkl. Reboot half nicht, iob upgrade-nodejs half nicht, iob fix half nicht, die Festplatte hat noch genügend Platz frei (>300GB), aber seit Deaktivieren des Compact Modes mit iob compact off scheint das Problem weg. Nur werde ich damit über kurz oder lang ein RAM-Problem auf dem Raspi bekommen, daher würde ich den Compact Mode gerne wieder anschalten, mit js-controller 4.x lief der über Jahre problemlos.
                                      • J Jens77
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        @jens77 welche Controller Version ist das? Falls stable 5.0.12 hat einen Bug mit Compact Instanzen.
                                        Videotutorials & mehr
                                        • foxriver76F foxriver76
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @foxriver76 said in Absturz aller Adapter nach Upgrade auf js-controller 5:
                                          lt. diag log im Posting https://forum.iobroker.net/topic/69698/absturz-aller-adapter-nach-upgrade-auf-js-controller-5/2
                                          admin: 6.12.0
                                          javascript: 7.1.4
                                          Wenn da was bekannt ist, könnte es das sein.
                                          @foxriver76 - ist das schon gefixed und wenn ja ab 5.0.?? (hab in changelog nichts gesehen)
