  4. Fenster offen Meldung (Blockly)
    5.3k
24 Beiträge 8 Kommentatoren 8.6k Aufrufe 9 Beobachtet
  • R Offline
    RappiRN
    So würde ich da rangehen:
    Und hier der Export dazu:
    <xml xmlns="http://www.w3.org/1999/xhtml"><block id="^!r;|,CM:B[pCuB6g~Q3" type="comment" x="288" y="-487"><field name="COMMENT">auf Fensteröffnung triggern</field>
    <next><block id="xA*o7]:Gl0b-]#r!v|fl" type="on"><field name="OID">Object ID</field>
        <statement name="STATEMENT"><block id="dvqT3{Kx^t@G=t[2=.Zn" type="comment"><field name="COMMENT">Temperatur und Fenster auf abfragen</field>
            <next><block id="d[M,o{c,4MREsFllk.L;" type="controls_if"><mutation else="1"></mutation>
                <value name="IF0"><block id="{zc_Am[Dv1.)]WX]|OD[" type="logic_operation" inline="false"><field name="OP">AND</field>
                    <value name="A"><block id="WF|YUTW%dawqMgwWs/M-" type="logic_compare"><field name="OP">EQ</field>
                        <value name="A"><block id="KXeG{[ieyz-*?FBk?!4)" type="get_value"><field name="ATTR">val</field>
                            <field name="OID">ID auswählen</field></block></value>
                        <value name="B"><block id="y]XYMfqoR+Fl78/{Uj/X" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></value>
                    <value name="B"><block id="{H9^(InEi0FIg`WlNMea" type="logic_compare"><field name="OP">LT</field>
                        <value name="A"><block id="h7dj]@(FF.W.w:D#G_Co" type="get_value"><field name="ATTR">val</field>
                        <value name="B"><block id="w,Q{75]Fpg;%O?X%7sqo" type="math_number"><field name="NUM">0</field></block></value></block></value></block></value>
                <statement name="DO0"><block id="!sgESw=,YYo@[pJsYQO," type="timeouts_settimeout"><field name="NAME">timeout</field>
                    <field name="DELAY">10</field>
                    <field name="UNIT">min</field>
                    <statement name="STATEMENT"><block id="#=h88QDQnUVVV|Y+M10T" type="telegram"><value name="MESSAGE"><shadow id="B98q8IxsOgnDC)-a,@T`" type="text"><field name="TEXT">text</field></shadow></value></block></statement></block></statement>
                <statement name="ELSE"><block id="q(IQ`d[@:7jrr7Lrts]I" type="timeouts_cleartimeout"><field name="NAME">timeout</field></block></statement></block></next></block></statement></block></next></block></xml>
    Enrico
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      @totocotonio:
      Kann mir da vielleicht jemand einen Tipp geben wie das am besten machen kann. `
      Da hättest Du auch schon von alleine drauf kommen können. Oder ;)
      Rantanplan
      • R Offline
        RappiRN
        Mein erster Gedanke war auch, zu schreiben, ob er denn schon einen Anfang hat. Ich probiere ja meist auch vorher aus, eine Möglichkeit zu finden, um eben auch ein wenig zu üben, sonst kriegt mans ja nie allein hin. :)
        Hab dann aber doch mal meine Idee dazu erstellt, muss ja auch mal hören, was andere dazu sagen. ;)
        Enrico
          rantanplanR Offline
          rantanplan
          @RappiRN:
          Hab dann aber doch mal meine Idee dazu erstellt, muss ja auch mal hören, was andere dazu sagen. ;) `
          Bei Dir muss man sich keine Gedanken mehr machen :D
          Rantanplan
          • totocotonioT Offline
            totocotonio
            ich bin blutiger Anfänger. :|
            Bin froh das einem hier geholfen wird.
            Ich hab das mit dem Timeout noch nicht so richtig verstanden.
            Wieso muss ich das stoppen?
            Gruß Totocotonio
            Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
              totocotonio
              @rantanplan:
              Da hättest Du auch schon von alleine drauf kommen können. Oder ;) `
              Ich habe da wirklich Probleme damit, für was und welche Blöcke ich da nehmen
              muss.
              Gruß Totocotonio
                rantanplanR Offline
                rantanplan
                @totocotonio:
                Wieso muss ich das stoppen? `
                Nun Du möchtest doch nach 10 Minuten eine Meldung bekommen.
                Das macht der eingesetzte "Timeout".
                Also bildlich ausgedrückt, richtet ioBroker eine Warteschlange ein.
                Das wird JEDESMAL gemacht wenn der Baustein ausgeführt wird.
                Wenn bei dem Beispiel innerhalb der der 10 Minuten das Fenster mehrmals geöffnet wird, wird jedesmal eine neue Warteschlange eingerichtet.
                Wenn das Fenster 5x geöffnet wurde, sind 5 Warteschlangen aktiv.
                Die dann nacheinander abgearbeitet würden. Du bekämst dann also 5 Meldungen. Alle 10 Min. eine.
                Deshalb sollte man sicherheitshalber einen Timeout vorher stoppen.
                Wenn ein Timeout gestoppt wird, wird das was in dem Timeout steht NICHT ausgeführt.
                Rantanplan
                  rantanplanR Offline
                  rantanplan
                  @totocotonio:
                  muss. `
                  Probieren geht über studieren ;)
                  Und es gibt, hier im Forum, schon ganz viel zu lesen.
                  Hier ist niemand mit der "Blockly"-Milch großgezogen worden.
                  Rantanplan
                  • R Offline
                    RappiRN
                    @rantanplan:
                    Wenn ein Timeout gestoppt wird, wird das was in dem Timeout steht NICHT ausgeführt. `
                    Siehste, bin doch noch Anfänger :lol: , ich habe den Timeout hauptsächlich deswegen drin, weil ich die Meldung ja nicht mehr bekommen wenn möchte, wenn der Fensteröffner das Fenster gewissenhaft, wegen der Kälte draußen, wieder nach 7 min schließt! :mrgreen:
                    Enrico
                      rantanplanR Offline
                      rantanplan
                      @RappiRN:
                      Siehste, bin doch noch Anfänger :lol: , ich habe den Timeout hauptsächlich deswegen drin, weil ich die Meldung ja nicht mehr bekommen wenn möchte, wenn der Fensteröffner das Fenster gewissenhaft, wegen der Kälte draußen, wieder nach 7 min schließt! :mrgreen: `
                      Das wäre die sichere Variante.
                      Ein Timeout stoppen, der noch nicht läuft, erzeugt KEINEN Fehler.
                      Rantanplan
                      • R Offline
                        RappiRN
                        @rantanplan:
                        Ein Timeout stoppen, der noch nicht läuft, erzeugt KEINEN Fehler. `
                        Da gebe ich dir Recht, ich glaube aber trotzdem nicht, dass man es schafft, außer der JS-Adapter hängt grad, das Fenster so schnell zu schließen, dass das erste Stop ausgeführt werden würde bevor der Timout startet, oder?
                        Enrico
                          rantanplanR Offline
                          rantanplan
                          @RappiRN:
                          Da gebe ich dir Recht, ich glaube aber trotzdem nicht, dass man es schafft, außer der JS-Adapter hängt grad, das Fenster so schnell zu schließen, dass das erste Stop ausgeführt werden würde bevor der Timout startet, oder? `
                          Ja, da hast Du natürlich recht. Es sollte ja auch nur eine sichere Variante aufzeigen.
                          Es soll auch schon mal passiert sein, dass man beim Blockly erstellen/umstellen ein Stop vergessen hat. ;)
                          Rantanplan
                            totocotonio
                            ich verstehe nur noch Bahnhof :shock:
                            Wieso muss ich den Timeout erst Stoppen wie es rantanplan geschrieben hat?
                            Weil das Fenster vielleicht zwischendurch geschlossen wurde?
                            Hat das damit was zu tun.
                            Gruß Totocotonio
                              rantanplanR Offline
                              rantanplan
                              @totocotonio:
                              Wieso muss ich den Timeout erst Stoppen wie es rantanplan geschrieben hat? `
                              Habe ich, glaub ich, ausführlich beschrieben.
                              Die Folgebeiträge auch lesen.
                              @totocotonio:
                              Hat das damit was zu tun. `
                              Was hindert Dich es mal einfach mal auszuprobieren?
                              Da explodiert nichts ;)
                              Versuch macht Klug ;)
                              Rantanplan
                              • R Offline
                                RappiRN
                                @totocotonio:
                                ich verstehe nur noch Bahnhof :shock: `
                                Ist doch schon mal was, besser als gar nichts zu verstehen! :lol:
                                Probiere doch einfach mal die Varianten durch und teile uns deine Ergebnisse mit! ;)
                                Enrico
                                  totocotonio
                                  danke für eure Hilfe.
                                  Ich "spiele mal etwas rum"
                                  Gruß Totocotonio
                                    rantanplanR Offline
                                    rantanplan
                                    @totocotonio:
                                    Ich "spiele mal etwas rum" `
                                    :!: :!: :!: :D :D :D
                                    Rantanplan
                                    • MyzerATM Offline
                                      MyzerATM Offline
                                      MyzerAT
                                      ich habe das Blockly von oben nach gebaut und leider funktioniert es nicht so wie beschrieben, den wenn man das Fenster paar mal hintereinander auf und zumacht bekommt man auch mehrmals eine Benachrichtigung das es noch offen ist!
                                      habe es dann abgeändert und so hat es dann bei mir auch funktioniert:
                                      lg Rudi
                                      Node 22.23.0
                                      Nodejs 22.23.0
                                      npm 10.9.8
                                      js-controller 7.2.2
                                      • R RappiRN
                                        Enrico
                                        moellmannoutlook.de
                                        @RappiRN
                                        • portyP Offline
                                          portyP Offline
                                          porty
                                          @MyzerAT
                                          bevor das Forum umgebaut wurde war die Lösung für das Problem bereits ersichtlich.
                                          @rantanplan hatte das geschrieben aber das Bild ist nicht mehr Sichtbar.
                                          "Ein Timeout stoppen, der noch nicht läuft, erzeugt KEINEN Fehler."
                                          vor "Ausführen timeout" musste einfach noch ein "Stop Timeout" gesetzt werden.
                                          Kurz gesagt, bei jedem neustart wird der Timeout erst gestoppt und dann neu gestartet.
