  3. Einsteigerfragen
  4. Backup EACCES: permission denied [gelöst]
    5.5k
29 Beiträge 6 Kommentatoren 4.7k Aufrufe 5 Beobachtet
  • G GiB64
    @thomas-braun woher der User kommt kann ich nicht sagen war mit User pi unterwegs und hatte zeitweise auch "sudo su".
    Der Moint ist nfs und der funtkioniert laut Backup-Log ja auch...
    Diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberry64
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     14:00:46 up  1:56,  3 users,  load average: 1.49, 0.98, 1.09
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-10-25 14:00:46 CEST
               Universal time: Wed 2023-10-25 12:00:46 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        3.0G        303M         42M        536M        674M
    Swap:            99M         99M        0.0K
    Total:          3.9G        3.1G        304M
             3793 M total memory
             2953 M used memory
             2870 M active memory
              279 M inactive memory
              303 M free memory
               37 M buffer memory
              498 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * rc-local.service loaded failed failed /etc/rc.local Compatibility
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                                      Type      Size  Used Avail Use% Mounted on
    /dev/root                                       ext4      228G   53G  164G  25% /
    devtmpfs                                        devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs                                           tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs                                           tmpfs     759M  1.3M  758M   1% /run
    tmpfs                                           tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                                       vfat      253M   31M  222M  13% /boot
    tmpfs                                           tmpfs     380M   24K  380M   1% /run/user/1000
    192.168.1.13:/volume1/homes/gib/ioBroker/Backup nfs4       15T   11T  4.3T  71% /opt/iobroker/backups
    [Wed Oct 25 12:04:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:18:FD:47 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=42eef330-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Oct 25 12:04:33 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Oct 25 12:04:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Oct 25 12:04:36 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET                  SOURCE                                          FSTYPE OPTIONS
    /                       /dev/sda2                                       ext4   rw,noatime
    |-/boot                 /dev/sda1                                       vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/opt/iobroker/backups 192.168.1.13:/volume1/homes/gib/ioBroker/Backup nfs4   rw,relatime,vers=4.0,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.1.19,local_lock=none,addr=192.168.1.13
    /var:
    43G     /var/
    41G     /var/lib/influxdb/engine/data/41eab7a7769b909a/autogen
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    du: cannot read directory '/opt/iobroker/backups/': Permission denied
    12K     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    616M    /opt/iobroker/iobroker-data/files
    218M    /opt/iobroker/iobroker-data/backup-objects
    156M    /opt/iobroker/iobroker-data/history
    96M     /opt/iobroker/iobroker-data/files/vis-2-beta
    61M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0E0QPU-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.14
    admin:          6.11.0
    javascript:     7.1.5
    Adapters from github:   2
    Adapter State
      system.adapter.adb.0                    : adb                   : raspberry64                              - disabled
    + system.adapter.admin.0                  : admin                 : raspberry64                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberry64                              -  enabled
    + system.adapter.backitup.0               : backitup              : raspberry64                              -  enabled
    + system.adapter.ble.0                    : ble                   : raspberry64                              -  enabled
      system.adapter.cameras.0                : cameras               : raspberry64                              - disabled, port: 8200, bind: 127.0.0.1
    + system.adapter.chromecast.0             : chromecast            : raspberry64                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspberry64                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberry64                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberry64                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberry64                              -  enabled
    + system.adapter.email.0                  : email                 : raspberry64                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberry64                              -  enabled
      system.adapter.firetv.0                 : firetv                : raspberry64                              - disabled
      system.adapter.flot.0                   : flot                  : raspberry64                              - disabled
    + system.adapter.hiob.0                   : hiob                  : raspberry64                              -  enabled
    + system.adapter.history.0                : history               : raspberry64                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberry64                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberry64                              -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberry64                              -  enabled, port: 12010
    + system.adapter.hue-extended.0           : hue-extended          : raspberry64                              -  enabled
      system.adapter.hue.0                    : hue                   : raspberry64                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberry64                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberry64                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberry64                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberry64                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberry64                              -  enabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : raspberry64                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspberry64                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberry64                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberry64                              -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : raspberry64                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberry64                              -  enabled
    + system.adapter.radar2.0                 : radar2                : raspberry64                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberry64                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberry64                              -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : raspberry64                              -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : raspberry64                              -  enabled
    + system.adapter.socketio.0               : socketio              : raspberry64                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberry64                              -  enabled
    + system.adapter.synology.0               : synology              : raspberry64                              -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberry64                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberry64                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : raspberry64                              -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : raspberry64                              -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberry64                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberry64                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberry64                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberry64                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberry64                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberry64                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberry64                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberry64                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberry64                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberry64                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberry64                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberry64                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberry64                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberry64                              - disabled
    + system.adapter.web.0                    : web                   : raspberry64                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : raspberry64                              -  enabled
      system.adapter.ws.0                     : ws                    : raspberry64                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 6.12.0   , installed 6.11.0 [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "cameras"      : 1.3.0    , installed 1.3.0
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "device-reminder": 3.0.0  , installed 2.0.1  [Updatable]
    Adapter    "device-watcher": 2.9.4   , installed 2.9.4
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.5.4    , installed 1.5.4
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "firetv"       : 2.0.2    , installed 2.0.2
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "history"      : 3.0.1    , installed 3.0.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.5  [Updatable]
    Controller "js-controller": 5.0.14   , installed 5.0.14
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "radar2"       : 2.0.8    , installed 2.0.8
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "smartthings"  : 0.1.0    , installed 0.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
    Adapter    "vis-2-widgets-material": 1.3.1, installed 1.3.1
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        12557
    States:         10923
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15323      633/vncserver-x11-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13949      593/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       130846     29159/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       133175     29159/iobroker.js-c
    tcp        0      0 192.168.1.19:12010      0.0.0.0:*               LISTEN      1001       131032     29356/io.hm-rpc.1
    tcp        0      0 192.168.1.19:12001      0.0.0.0:*               LISTEN      1001       132360     29331/io.hm-rpc.0
    tcp        0      0 0.0.0.0:41351           0.0.0.0:*               LISTEN      0          133807     -
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13828      636/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       135069     30050/io.jarvis.0
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15322      633/vncserver-x11-c
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16293      604/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       134900     29930/io.socketio.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       134865     29903/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       130889     29177/io.admin.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13948      593/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      117        15745      660/xrdp
    tcp6       0      0 :::44113                :::*                    LISTEN      0          133808     -
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        17862      594/grafana
    tcp6       0      0 ::1:9666                :::*                    LISTEN      1000       18128      596/java
    tcp6       0      0 :::33265                :::*                    LISTEN      1000       19526      596/java
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          13847      631/xrdp-sesman
    tcp6       0      0 127.0.0.1:9665          :::*                    LISTEN      1000       16821      596/java
    tcp6       0      0 127.0.0.1:9666          :::*                    LISTEN      1000       18127      596/java
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13830      636/sshd: /usr/sbin
    tcp6       0      0 :::2211                 :::*                    LISTEN      1001       135775     29971/io.hiob.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       133489     29397/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15290      503/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13970      705/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       134040     29914/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       130957     29294/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15094      446/avahi-daemon: r
    udp        0      0 0.0.0.0:57229           0.0.0.0:*                           108        15096      446/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15760      503/dhcpcd
    udp6       0      0 :::60165                :::*                                108        15097      446/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15095      446/avahi-daemon: r
    2023-10-25 14:00:00.616  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: <b>------ Wohnzimmer ------- Aussensensor: TF_Terrasse -----------</b>
    2023-10-25 14:00:04.048  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:00:04.049  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: Erzeugung JSON Start
    2023-10-25 14:00:04.049  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:00:04.050  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: strJSONfinal = [{"Raum":"TF_Terrasse","Feuchtegehalt_Absolut":"10.42","relative_Luftfeuchtigkeit":"99.00","Taupunkt":"14.60","Temperatur":"14.80","DETAILS.Enthalpie":"41.22","DETAILS.Sättigungsdampfdruck":"16.83","DETAILS.Dampfdruck":"16.67","Dampfgewicht":"12.54","DETAILS.Dampfgewicht_maximal":"12.67","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Keller","Feuchtegehalt_Absolut":"8.51","relative_Luftfeuchtigkeit":"57.00","Taupunkt":"11.60","Temperatur":"20.40","DETAILS.Enthalpie":"42.11","DETAILS.Sättigungsdampfdruck":"23.97","DETAILS.Dampfdruck":"13.66","Dampfgewicht":"10.08","DETAILS.Dampfgewicht_maximal":"17.69","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"false","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"},{"Raum":"Mia","Feuchtegehalt_Absolut":"9.69","relative_Luftfeuchtigkeit":"66.00","Taupunkt":"13.50","Temperatur":"20.10","DETAILS.Enthalpie":"44.81","DETAILS.Sättigungsdampfdruck":"23.53","DETAILS.Dampfdruck":"15.53","Dampfgewicht":"11.47","DETAILS.Dampfgewicht_maximal":"17.38","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"true","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"},{"Raum":"Wohnzimmer","Feuchtegehalt_Absolut":"9.38","relative_Luftfeuchtigkeit":"62.00","Taupunkt":"13.10","Temperatur":"20.60","DETAILS.Enthalpie":"44.54","DETAILS.Sättigungsdampfdruck":"24.26","DETAILS.Dampfdruck":"15.04","Dampfgewicht":"11.10","DETAILS.Dampfgewicht_maximal":"17.90","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"true","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"}]
    2023-10-25 14:00:04.050  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: anyLueften = false, Anzahl Lüftungsempfehlungen: 0
    2023-10-25 14:00:04.051  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:00:04.051  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: Erzeugung JSON Ende
    2023-10-25 14:00:30.005  - info: smartmeter.0 (29514) Received 4 values, 2 updated
    2023-10-25 14:01:31.924  - info: smartmeter.0 (29514) Received 4 values, 2 updated
    2023-10-25 14:01:57.218  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: <span style="color:black;"><b>Änderung:TF_Terrasse: hm-rpc.1.000EDF298BCC25.1.ACTUAL_TEMPERATURE: 15</b></span>
    2023-10-25 14:01:57.726  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: <b>------ TF_Terrasse ------- Aussen, keine Lüftungsempfehlung -----------</b>
    2023-10-25 14:02:01.224  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:02:01.225  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: Erzeugung JSON Start
    2023-10-25 14:02:01.226  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:02:01.227  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: strJSONfinal = [{"Raum":"TF_Terrasse","Feuchtegehalt_Absolut":"10.55","relative_Luftfeuchtigkeit":"99.00","Taupunkt":"14.80","Temperatur":"15.00","DETAILS.Enthalpie":"41.77","DETAILS.Sättigungsdampfdruck":"17.05","DETAILS.Dampfdruck":"16.88","Dampfgewicht":"12.69","DETAILS.Dampfgewicht_maximal":"12.82","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Keller","Feuchtegehalt_Absolut":"8.51","relative_Luftfeuchtigkeit":"57.00","Taupunkt":"11.60","Temperatur":"20.40","DETAILS.Enthalpie":"42.11","DETAILS.Sättigungsdampfdruck":"23.97","DETAILS.Dampfdruck":"13.66","Dampfgewicht":"10.08","DETAILS.Dampfgewicht_maximal":"17.69","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"false","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"},{"Raum":"Mia","Feuchtegehalt_Absolut":"9.69","relative_Luftfeuchtigkeit":"66.00","Taupunkt":"13.50","Temperatur":"20.10","DETAILS.Enthalpie":"44.81","DETAILS.Sättigungsdampfdruck":"23.53","DETAILS.Dampfdruck":"15.53","Dampfgewicht":"11.47","DETAILS.Dampfgewicht_maximal":"17.38","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"true","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"},{"Raum":"Wohnzimmer","Feuchtegehalt_Absolut":"9.38","relative_Luftfeuchtigkeit":"62.00","Taupunkt":"13.10","Temperatur":"20.60","DETAILS.Enthalpie":"44.54","DETAILS.Sättigungsdampfdruck":"24.26","DETAILS.Dampfdruck":"15.04","Dampfgewicht":"11.10","DETAILS.Dampfgewicht_maximal":"17.90","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"true","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"}]
    2023-10-25 14:02:01.227  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: anyLueften = false, Anzahl Lüftungsempfehlungen: 0
    2023-10-25 14:02:01.236  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:02:01.237  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: Erzeugung JSON Ende
    2023-10-25 14:02:01.237  - info: javascript.0 (29235) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
    2023-10-25 14:02:13.868  - info: hue-extended.0 (29666) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
    2023-10-25 14:02:13.873  - info: hue-extended.0 (29666) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
    2023-10-25 14:02:13.874  - info: hue-extended.0 (29666) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
    2023-10-25 14:02:32.026  - info: smartmeter.0 (29514) Received 4 values, 2 updated
    @gib64 sagte in Backup EACCES: permission denied:
    auch "sudo su".
    Warum????? Lasst den Schwachsinn ganz einfach bleiben.
    G 1 Antwort Letzte Antwort
      auch "sudo su".
      GiB64
      @thomas-braun Weil ich einen dauerhaften Mount auf mein NAS einrichten wollte und die Anleitung aus dem Raspi Forum hat das halt empfohlen: https://forum-raspberrypi.de/forum/thread/40061-netzwerkfreigabe-mounten-mit-systemd-mount-unit/
      • G GiB64
        Diag:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 3793 M total memory
                 2953 M used memory
                  303 M free memory
                   37 M buffer memory
                  498 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        43G     /var/
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.11.0
        javascript:     7.1.5
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12557
        States:         10923
        Pending Updates: 2
        Der Moint ist nfs
        Bei NFS müssen user und Gruppe auf beiden Systemen gleich sein. Der 1026 dürfte dann vom NAS kommen.
        Irgendwo kann man das aber umstellen. Müsste ich aber jetzt auch nachlesen.
        • G GiB64
          Diag:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         99M        0.0K
                   3793 M total memory
                   2953 M used memory
                    303 M free memory
                     37 M buffer memory
                    498 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          43G     /var/
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.11.0
          javascript:     7.1.5
          Adapter State
          + instance is alive
          Objects and States
          Objects:        12557
          States:         10923
          Pending Updates: 2
          X-Server: true
          Ausschalten. Hat auf einem Server nix zu suchen.
            Der Moint ist nfs
            GiB64
            @thomas-braun Aber das ist doch das einzigste, was da noch funktioniert:
            [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.1.13:/volume1/homes/gib/ioBroker/Backup /opt/iobroker/backups"
            [DEBUG] [mount] - mount successfully completed
            [DEBUG] [mount] - done
            Es wird im Diag ja die rc.local angemeckert und da war ich auch drin zu gange wegen dem dauerhaften Mount versucht...
            Thomas BraunT Dr. BakteriusD 2 Antworten Letzte Antwort
            • G GiB64
              @gib64
              RC.local wird nicht mehr verwendet. Das läuft alles über systemd. Ich denke die Anleitung ist falsch/veraltet. Zeigt eigentlich alleine schon das herumgehampel mit einer root Shell.
                @gib64
                GiB64
                @thomas-braun Es ist als Linux DAU echt nicht einfach... Die Anleitung heißt doch sogar: "Netzwerkfreigabe mounten mit systemd Mount Unit" und ist trotzdem falsch?? wow...
                DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                • G GiB64
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Die Anleitung ist vom
                  26. August 2018
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    26. August 2018
                    GiB64
                    schrieb am zuletzt editiert von GiB64
                    @djmarc75 Hast Du eine aktuellere? Ich habe jetzt bestimmt schon 4-5 Anleitungen durch und bekomme nicht mal mehr einen dauerhaften mount hin... weder NFS noch CFIS!
                    • G GiB64
                      CodierknechtC Online
                      Codierknecht
                      @gib64
                      Ich auch nicht.
                      Ich verwende WebDAV. Sicher nicht die performanteste Art, aber für die paar MB Backup reicht's.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • G GiB64
                        Dr. BakteriusD Offline
                        Dr. Bakterius
                        Das Mounten ist ja auch nicht das Problem sondern die Schreibrechte. Wie @Thomas-Braun schon geschrieben hat, muss auf dem NAS auch der User mit den entsprechenden Rechten existieren.
                        G 2 Antworten Letzte Antwort
                          GiB64
                          @dr-bakterius Das kann ich kaum glauben denn da habe ich nichts gemacht und es hat ja bis anf. diesen Monat perfekt funktioniert:
                          gib@DS416j:~/ioBroker/Backup$ ls -l
                          total 506536
                          -rwxrwxrwx+ 1 gib  users    75667 Nov 10  2022  2022-11-10-scripts.zip
                          -rwxrwxrwx+ 1 gib  users    88251 Nov 12  2022  2022-11-12-scripts.zip
                          -rwxrwxrwx+ 1 gib  users    72538 Nov 13  2022  2022-11-13-scripts.zip
                          -rwxrwxrwx+ 1 gib  users    85854 Nov 22  2022  2022-11-22-scripts.zip
                          drwxrwxrwx+ 2 root users     4096 Nov 22  2022  @eaDir
                          -rwxrwxrwx+ 1 1001  1001     3279 Sep 27 02:41  grafana_2023_09_27-02_41_05_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3281 Sep 28 02:41  grafana_2023_09_28-02_41_06_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3276 Sep 29 02:41  grafana_2023_09_29-02_41_07_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3275 Sep 30 02:41  grafana_2023_09_30-02_41_18_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3281 Oct  1 02:41  grafana_2023_10_01-02_41_12_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3277 Oct  2 02:41  grafana_2023_10_02-02_41_17_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3283 Oct  3 02:41  grafana_2023_10_03-02_41_15_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3275 Oct  4 02:41  grafana_2023_10_04-02_41_09_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3280 Oct  5 02:41  grafana_2023_10_05-02_41_16_GiB_                                                  backupiobroker.tar.gz
                          -rwxrwxrwx+ 1 1001  1001     3280 Oct  6 02:41  grafana_2023_10_06-02_41_26_GiB_                                                  backupiobroker.tar.gz
                          • G GiB64
                            Du hast doch geschrieben, du hättest irgendwas in rc.watweißich geändert.
                            Schau auf dem NFS Server in die Einstellungen, ob man das da irgendwo anderen usern (ist für den iobroker in der Regel 1001:1001) umstellen kann.
                              GiB64
                              @thomas-braun Ich habe wirklich noch nie auf meinem NAS einen IoBroker User eingerichtet. Kann es deshalb funktionieren?:
                              • CodierknechtC Codierknecht
                                @gib64
                                Ich auch nicht.
                                GiB64
                                @codierknecht said in Backup EACCES: permission denied:
                                WebDAV
                                Sorry aber ich möchte das nicht noch komplexer machen. NFS oder SMB Mount ist doch kein Hexenwerk, dachte ich bis heute jedenfalls. Das muss mit Boardmitteln funktionieren!
                                  GiB64
                                  @dr-bakterius Die Fehler kommen aber schon bevor versucht wird die Datei zu verschieben:
                                  	[iobroker/historyDB] Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2023_10_25-14_43_14_GiB_backupiobroker.tar.gz'
                                  • G GiB64
                                    @gib64
                                    Kannst du bei 'Squash' auf dem Server was umstellen?
                                      @gib64
                                      GiB64
                                      @thomas-braun said in Backup EACCES: permission denied:
                                      Squash
                                      Musste ich googlen aber das hört sich nicht gut an: Wenn Sie mit dieser Squash -Option NFS -Berechtigungen einrichten, werden alle Benutzer auf dem Synology NAS als „Administratoren“ behandelt und haben Zugriff auf alle Dateien/Ordner. Wenn Benutzer Dateien/Ordner erstellen, wird der Ersteller der Datei/des Ordners als „admin“ aufgeführt.
                                      • G GiB64
                                        Squash
                                        @gib64
                                        Neben dem root-squash gibt es das soweit ich weiß auch für user.
                                          @gib64
                                          GiB64
                                          ok, es liegt an der Berechtigung des mounts:
                                          pi@raspberry64:~ $ sudo mount 192.168.1.13:/volume1/homes/gib/ioBroker/Backup /opt/iobroker/backups
                                          pi@raspberry64:~ $ cd /opt/iobroker/backups
                                          pi@raspberry64:/opt/iobroker/backups $ ls -l
                                          ls: cannot open directory '.': Permission denied
                                          Mir fällt gerade ein das ich anf. des Monats mein Synology NAS auf DSM Ver. 7 geupdatet habe. Damit scheint sich was geändert zu haben. Mit squash komm ich nicht weiter....
